V6.0 Climate Control via DEW POINT COMFORT - (Triggers - Door, Presence, Light Notification & TTS) Home Assistant
V6.0 Climate Control via DEW POINT COMFORT - Triggers - Door, Presence, TTS, Home Assistant
This flow uses Outside Dew Point Temperature to control any Climate Entity through Home Assistant.
Tested on TADO Smart AC Control V3+ this does not require a paid subcription to TADO.
This flow overcomes the authentication issues with the current HA TADO Integration
  • Home and Away Presence Sensing
  • Door and Window Open Detection
  • Uses Outside Dew Point to set Heating, Comfort or Cooling Programs
  • Uses Indoor Dew Point to set Heating, Drying, Cooling or OFF Modes
  • Heat Boost Mode if the Dew Point is low in a room
  • Sets A/C to OFF or Economy Setting when set room temperature is reached
  • Avoids sending commands to A/C for the same mode, allowing idle state.
  • Activates Dehumidifier or Drying Mode, to improve Dew Point Comfort and reduce humidity
  • Coloured Light Notifications to signify A/C mode
Dew point control is a method of regulating the amount of moisture in the air to maintain a comfortable room temperature. It's important for underfloor cooling systems and can help reduce energy costs.
How it works
  • Dew point control regulates the amount of condensation that forms when warm air meets cold surfaces.
  • A low dew point makes the air feel drier, while a high dew point makes it feel more humid.
  • Air conditioning removes moisture and heat from the air, which lowers the dew point.
How to control dew point
  • Use a dehumidifier or humidifier to control the humidity level.
  • Ventilate the home properly. (Ventilation control coming in the next update)
  • Use a dew point sensor to calculate a rooms from temperature and humidity.
  • Use a hygrometer to measure humidity.
Benefits of dew point control Reduces energy usage, Prevents heat loss, Helps save money on heating bills, and Ensures that your home remains comfortable all year round.
REQUIREMENTS
FEATURES
NEW TADO AUTHENTICATION FLOW
IF YOU HAVE HAVE PREVIOUS node-red-contrib-tado-client NODES INSTALLED, ENSURE YOU CHANGE THE SERVER TO YOUR CURRENT SERVER
Tado no longer uses username/password auth.
Instead you should inject into the "Authentication Flow" and monitor the debug output. This will trigger a device auth flow, that will require you to visit a URL to login. The URL Login will be printed by the TADO Debug Node, Open the Deug Window to view.
Once you've logged in a token will be printed to the debug window. You can use this token to bypass the auth processnext time. An example of this is shown in the "Persistent Authentication" group - you'll need to enable this. Once enabled this will Tado [authenticate] node will automatically give an Authenticated if sucessful.
You should also replace the home_id in the calls with your home_id which can be found using the first example of getMe API call.
  • Tado [getMe] and Get all Zones Nodes
      1. Double Click Tado [getMe] Node, Add the Tado Config from previous step...
      1. Find your homes ID in the debug message [window payload.homes[0].id]
      1. Enter your Home ID into the other Nodes to fetch information from the API
      1. Each Tado Node in this flow will your Home ID and some Zone ID
      1. Find the path >_Copy Path Button in the Debug Node i.e. [payload.comfort[0].temperatureLevel]
      1. Copy the path into the Function Nodes in this
TADO HOME ASSISTANT INTEGRATION SETTINGS
  • Click CONFIGURE and select MANUAL in Adjust Tado options.
  • image
SET TADO HOME AND AWAY SWITCH (Controlled in Automation and Dashboard Switch)
  • Home and Away Switch Triggers
    • Trigger when persons in zone.home are more than 1
    • Poll zone.home more that one every 5 minutes, catches if a door or manual input has turned off the home switch
    • Switch exposed to Home Assistant to allow manual control and display notifcations
    • Switch sets TADO Preset Modes, Home and Away (In the Tado App you can set different smart schedules for Home and Away Modes)
    • This Switch is what is activated in the flow.
    • Sends msg.topic: check so TTS does not activate everytime there is a change
TADO MOBILE DEVICE APP SETTINGS
  • NOTE: When setting the TADO Intergration to MANUAL I set the Home and Away modes in the APP as below
    • I have set my TADO Schedule Home Mode to OFF for both Heat Pumps.
    • I have set my TADO Schedule Away Mode to OFF for both Heat Pumps.
    • image
  • NOTE: When setting the TADO Intergration to TADO DEFAULT I set the Home and Away modes as below
    • I have set my TADO Schedule Home Mode to POPULATED SCHEDULE for both Heat Pumps.
    • image
  • *NOTE: There seems to be some limitations with sending dry mode via Action Node.
  • One of my heat pump only accepts the mode dry with no temperature settings. I use API Method sending No Temperature.
  • If using the Action Node.
    • I have set my TADO Schedule Home Mode to DRY for both Heat Pumps.
    • image
  • Set TADO Home Intergration Settings to TADO SCHEDULE.
  • Set Action Node to climate.set_havac_mode to {"hvac_mode":"auto"}
  • image
ACTIVATION - DEACTIVATION
  • Check every 10 Minutes Topic: check
    • Turns ON Home and Away Switch, only if TADO Mode is Home and Contact Sensors are OFF (Doors Closed)
    • If TADO Mode Home and Contact Sensors are ON (Doors Open) turns OFF A/C
  • Contact Sensors CLOSED 15sec - Topic:door
    • When all Contact Sensors are OFF (Doors Closed) Activates A/C
    • Sends msg.topic: door so TTS does activate between set times
  • Contact Sensors OPEN 2 Mins - Topic:door
    • When all Contact Sensors are ON (Doors Open) Turns OFF A/C
CHECK DEW POINT
  • Check Outside Dew Point to Set Program
    • Dewpoint (<12.79 - Dry)(12.8-15.4 - Comfortable)(>15.5 Humid)
    • Activates Programs based on Outside Dew Point Comfort, which is a combination of temperature and humidity.
  • TADO Intergration Unavailable Use API
    • Checks if the Home Assistant Climate Control Entity is available. (Which means it is authorised)
    • If Unavailable diverts the flow from the TADO Integration Home Assistant Action Call Method to the node-red-contrib-tado-client API method
    • NOTE: When the TADO Integration needs re-authentication in Home Assistant, the API method will continue to work but the Thermostat card will be unavailable in Home Assistant, until the Tado Integration is re-authenticated.
  • Check Outdoor Temperature
    • Temperature (<+ 21) and (<= 25)
    • On rare occassions or depending on your climate, Hot days can have a Low Dewpoint or Cold Days can have a High Dewpoint.
    • These Checks ensure the right Program is chosen.
  • Check Inside Dewpoint to Set Heating Program
    • Dewpoint (<10.0 - Dry)(10.1-12.79 - Pleasant)(12.8-15.4 - Comfortable)(15.5-18.39 - Sticky)(>18.4 - Muggy)
    • Sets the modes of the heat pump based on the above Dew Point thresholds
    • There is 3 programs Heating, Comfort and Cooling
    • The below chart is what the comfort values are based off and can vary slightly depending on your climate.
    • image
MODES
TOP: node-red-contrib-tado-client API method BOTTOM: TADO Integration Home Assistant Action Call Method
  • Indoor Temperature Check~~
    • Ensures if the room is above your setpoint it puts one setting lower.
  • Don't set if already Set~~
    • As the dewpoint is checked every 5mins, this ensures your A/C handles the set temperature. Avoids multiple ON and Mode commands that keep your A/C running, unnecessarily
    • Allow Home Assistant Thermostat Card to revert to idle state
  • HEAT PUMP MODES USING SERVICE (ACTION) CALLS THROUGH HOME ASSISTANT** image
  • HEAT PUMP MODES - USING TADO API CALLS AND - HA SERVICE CALLS TO SET HA THERMOSTAT** image
  • Active Time
    • Set the time you want the heating or cooling to be active, if false goes to sets the A/C to a lower more power efficient setting (auto=TADO Smart Schedule)
  • HEAT BOOST MODE, HEAT 23, HEAT 22, HEAT 21 (TTS Topic: door)
    • Sets HVAC mode to heat
    • Sets Temperature to 23°C, 22°C, 21°C
    • HA Thermostat card will say Heating
    • NOTE: Not recommended to send swing or fan mode changes, A/C will default to auto and set swing without them)
    • *NOTE: The difference in height/temperature from my TADO V3+ thermostat is about 3°C, keep this in mind when setting heat
    • If between set times and msg.topic: door TTS will activate
  • TADO SCHEDULE DRY MODE (TTS Topic: door)
    • Sets HVAC to home
    • Sets mode to auto via (auto=TADO Smart Schedule, if using V4.0 Modes)
    • Sets mode to dry via (TADO API, if using V5.0 Modes)
    • HA Thermostat card will say Drying
    • NOTE: If using V4.0 Modes, this uses the temperature or mode settings from your TADO Smart Schedule in my case I use it for the dry mode
  • OFF MODE (TTS Topic: door)
    • Sets HVAC to off
    • HA Thermostat card will say Off
  • COOL MODE (TTS Topic: door)
    • Sets HVAC to cool
    • Sets Temperature 26°C
    • HA Thermostat card will say Cooling
    • NOTE: The difference in height/temperature from my TADO V3+ thermostat is about 3°C, keep this in mind when setting cool temperature
DEHUMIDIFER
  • Turns ON and OFF Dehumidifier with smart plug.
  • NOTE: Drying the air reduces dewpoint temperature
AWAY MODE DEHUMIDIFACTION - UTILISING DRY MODE ON AIR CONDITIONER
FAN CONTROL
  • Turns on fan if there is a 4 degree difference between ceiling and floor.
NOTIFICATION LIGHT
  • Activates a status bar lights depending on the mode that is active
[{"id":"e71a7dfbd7dd368a","type":"inject","z":"5fb50193cc6a2ad5","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":180,"y":420,"wires":[["7943d5ea4d7b9bc5"]]},{"id":"9f3b03300e47c760","type":"inject","z":"5fb50193cc6a2ad5","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":180,"y":480,"wires":[["e41536ec7ce1b2c9"]]},{"id":"97c5bd8794286783","type":"tado","z":"5fb50193cc6a2ad5","acMode":"AUTO","apiCall":"getZoneStates","childlock":false,"configName":"83e627ce7e032c20","defaultTerminationTimeout":900,"defaultTerminationType":"manual","deviceId":"","endDate":"","fanSpeed":"AUTO","geoTracking":true,"homeId":"INSERT HOME ID","horizontalSwing":"off","name":"Get all Zones States","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","tariffId":"","tariffInCents":0,"temperature":"18","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","verticalSwing":"off","windowDetection":true,"windowDetectionTimeout":900,"year":"","zoneId":"","x":420,"y":540,"wires":[["988ce4f2b08f793f"]]},{"id":"4f2b02128ee11e3a","type":"inject","z":"5fb50193cc6a2ad5","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":180,"y":540,"wires":[["97c5bd8794286783"]]},{"id":"8cb2c47224a8a790","type":"inject","z":"5fb50193cc6a2ad5","name":"Test","props":[{"p":"payload"},{"p":"topic2","v":"door","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":890,"y":600,"wires":[["101ff4c8766e2f48"]]},{"id":"101ff4c8766e2f48","type":"link out","z":"5fb50193cc6a2ad5","name":"TEST OUT","mode":"link","links":["2926bf43d0347873"],"x":1005,"y":600,"wires":[]},{"id":"a83643d44f41c005","type":"inject","z":"5fb50193cc6a2ad5","name":"Test","props":[{"p":"payload"},{"p":"topic2","v":"door","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":3557.199951171875,"y":768.3999633789062,"wires":[["cd1a39c723fb895a"]]},{"id":"cd1a39c723fb895a","type":"link out","z":"5fb50193cc6a2ad5","name":"TEST OUT","mode":"link","links":["2926bf43d0347873"],"x":3637.199951171875,"y":768.3999633789062,"wires":[]},{"id":"0539ebc23c779a3e","type":"inject","z":"5fb50193cc6a2ad5","name":"Test","props":[{"p":"payload"},{"p":"topic2","v":"door","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":5210,"y":760,"wires":[["a75092e1cb72dd6f"]]},{"id":"a75092e1cb72dd6f","type":"link out","z":"5fb50193cc6a2ad5","name":"TEST OUT","mode":"link","links":["2926bf43d0347873"],"x":5325,"y":760,"wires":[]},{"id":"e57245b89f6adf3f","type":"inject","z":"5fb50193cc6a2ad5","name":"Test","props":[{"p":"payload"},{"p":"topic2","v":"door","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":3530,"y":2220,"wires":[["02b94220c2d07698"]]},{"id":"02b94220c2d07698","type":"link out","z":"5fb50193cc6a2ad5","name":"TEST OUT","mode":"link","links":["2926bf43d0347873"],"x":3645,"y":2220,"wires":[]},{"id":"43f94c229ab123e5","type":"inject","z":"5fb50193cc6a2ad5","name":"Test","props":[{"p":"payload"},{"p":"topic2","v":"door","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":2214.800048828125,"y":2204.39990234375,"wires":[["a7970941d7e908c8"]]},{"id":"a7970941d7e908c8","type":"link out","z":"5fb50193cc6a2ad5","name":"TEST OUT","mode":"link","links":["2926bf43d0347873"],"x":2294.800048828125,"y":2204.39990234375,"wires":[]},{"id":"efa7ba0cd44d77f9","type":"group","z":"5fb50193cc6a2ad5","name":"DEWPOINT COMFORT A/C MODE, DOOR TRIGGERS, PRESENCE DETECTION AND TTS","style":{"fill":"#dbcbe7","fill-opacity":"0.47","label":true},"nodes":["039ec143e4e7dd01","3d181cc7cd6e0871","de002435f2c50b86","fd220e4c1b06e1a3","2eb6fb258078d230","2fe87852caa8cba4","40466ba49a049683","59af5f11e0571b7f","62194f3abe3ce1ad","f3d522ebe8298997","7943d5ea4d7b9bc5","e41536ec7ce1b2c9","988ce4f2b08f793f","d170ecdb93efbd2b","fe854a754e098039","d195fb64657c1201","35cc0d0a876bf4e7","087dd5e58fc9b08d","cab0745b37c20736","147894e5cbd062c5","6b0716a73157c888","018047ddf17ffb2c","9807fada71ed6391"],"x":48,"y":41,"w":6816,"h":2898},{"id":"039ec143e4e7dd01","type":"group","z":"5fb50193cc6a2ad5","g":"efa7ba0cd44d77f9","name":"SET TADO HOME AND AWAY SWITCH (Controlled in Automation and Dashboard Switch)","style":{"label":true,"fill":"#bfdbef","fill-opacity":"0.46"},"nodes":["7fd652f45a4e23c0","ed26d656791ea4a1","1277ee064a784f40","02eed4ac72557462","d4c49fd6666619dc","04a493fd2509dae4","182f1a77cb073f29","ad247a66482b5b84","960b45c073df4f3c","1e5e4d02ae871477","62681239d0bb17fc","83078cc49d4e26f8","11b0966d0f42bc8a","f2a8a34da6819e50"],"x":74,"y":1393,"w":1718,"h":468},{"id":"7fd652f45a4e23c0","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"039ec143e4e7dd01","name":"TADO Preset mode home","server":"","version":7,"debugenabled":false,"action":"climate.set_preset_mode","floorId":[],"areaId":[],"deviceId":["1d2bcc499a5b8ef266105be599b319f1","eaa527238407b25def1f7d8eb7864ce1"],"entityId":["climate.air_conditioning_downstairs","climate.air_conditioning"],"labelId":[],"data":"{\"preset_mode\":\"home\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"climate","service":"set_preset_mode","x":470,"y":1500,"wires":[[]]},{"id":"ed26d656791ea4a1","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"039ec143e4e7dd01","name":"TADO Preset mode away","server":"","version":7,"debugenabled":false,"action":"climate.set_preset_mode","floorId":[],"areaId":[],"deviceId":["1d2bcc499a5b8ef266105be599b319f1","eaa527238407b25def1f7d8eb7864ce1"],"entityId":["climate.air_conditioning_downstairs","climate.air_conditioning"],"labelId":[],"data":"{\"preset_mode\":\"away\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"climate","service":"set_preset_mode","x":470,"y":1580,"wires":[["1e5e4d02ae871477","11b0966d0f42bc8a"]]},{"id":"1277ee064a784f40","type":"ha-switch","z":"5fb50193cc6a2ad5","g":"039ec143e4e7dd01","name":"Home and Away Switch","version":0,"debugenabled":false,"inputs":1,"outputs":2,"entityConfig":"66a95c33221af678","enableInput":true,"outputOnStateChange":true,"outputProperties":[{"property":"outputType","propertyType":"msg","value":"state change","valueType":"str"},{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"}],"x":200,"y":1540,"wires":[["7fd652f45a4e23c0"],["ed26d656791ea4a1"]],"server":""},{"id":"02eed4ac72557462","type":"trigger-state","z":"5fb50193cc6a2ad5","g":"039ec143e4e7dd01","name":"HOME Set Persons","server":"","version":5,"inputs":0,"outputs":2,"exposeAsEntityConfig":"","entities":{"entity":["zone.home"],"substring":[],"regex":[]},"debugEnabled":false,"constraints":[{"targetType":"this_entity","targetValue":"","propertyType":"current_state","propertyValue":"new_state.state","comparatorType":">","comparatorValueDatatype":"num","comparatorValue":"0"}],"customOutputs":[],"outputInitially":false,"stateType":"num","enableInput":false,"x":210,"y":1700,"wires":[["d4c49fd6666619dc"],["04a493fd2509dae4"]]},{"id":"d4c49fd6666619dc","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"039ec143e4e7dd01","name":"Home and Switch ON","server":"","version":7,"debugenabled":false,"action":"switch.turn_on","floorId":[],"areaId":[],"deviceId":["c627cb78f91d85be074a2908eb79787b"],"entityId":[],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"switch","service":"turn_on","x":720,"y":1700,"wires":[[]]},{"id":"04a493fd2509dae4","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"039ec143e4e7dd01","name":"Home and Switch OFF","server":"","version":7,"debugenabled":false,"action":"switch.turn_off","floorId":[],"areaId":[],"deviceId":["c627cb78f91d85be074a2908eb79787b"],"entityId":[],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"switch","service":"turn_off","x":720,"y":1760,"wires":[[]]},{"id":"182f1a77cb073f29","type":"poll-state","z":"5fb50193cc6a2ad5","g":"039ec143e4e7dd01","name":"Poll: HOME +1","server":"","version":3,"exposeAsEntityConfig":"","updateInterval":"5","updateIntervalType":"num","updateIntervalUnits":"minutes","outputInitially":false,"outputOnChanged":false,"entityId":"zone.home","stateType":"str","ifState":"1","ifStateType":"num","ifStateOperator":"gte","outputs":2,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":200,"y":1820,"wires":[["ad247a66482b5b84"],["04a493fd2509dae4"]]},{"id":"ad247a66482b5b84","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"039ec143e4e7dd01","name":"Contact Sensors OFF","server":"","version":3,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"binary_sensor.middle_floor_sensor_group","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"seconds","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":240,"y":1760,"wires":[["d4c49fd6666619dc"],[]]},{"id":"960b45c073df4f3c","type":"tado","z":"5fb50193cc6a2ad5","g":"039ec143e4e7dd01","acMode":"DRY","apiCall":"clearZoneOverlay","childlock":false,"configName":"83e627ce7e032c20","defaultTerminationTimeout":900,"defaultTerminationType":"TADO_MODE","deviceId":"","endDate":"","fanSpeed":"AUTO","geoTracking":true,"homeId":"INSERT HOME ID","horizontalSwing":"OFF","name":"Down (2) [ClearZoneOverlay]","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","tariffId":"","tariffInCents":0,"temperature":"","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","verticalSwing":"OFF","windowDetection":true,"windowDetectionTimeout":900,"year":"","zoneId":"2","x":780,"y":1640,"wires":[["f2a8a34da6819e50"]]},{"id":"1e5e4d02ae871477","type":"tado","z":"5fb50193cc6a2ad5","g":"039ec143e4e7dd01","acMode":"DRY","apiCall":"clearZoneOverlay","childlock":false,"configName":"83e627ce7e032c20","defaultTerminationTimeout":900,"defaultTerminationType":"TADO_MODE","deviceId":"","endDate":"","fanSpeed":"AUTO","geoTracking":true,"homeId":"INSERT HOME ID","horizontalSwing":"OFF","name":"Liv (1)[ClearZoneOverlay]","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","tariffId":"","tariffInCents":0,"temperature":"","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","verticalSwing":"OFF","windowDetection":true,"windowDetectionTimeout":900,"year":"","zoneId":"1","x":770,"y":1520,"wires":[["b483139905be8533"]]},{"id":"62681239d0bb17fc","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"039ec143e4e7dd01","name":"Down HVAC OFF","server":"","version":7,"debugenabled":false,"action":"climate.turn_off","floorId":[],"areaId":[],"deviceId":["eaa527238407b25def1f7d8eb7864ce1"],"entityId":["climate.air_conditioning_downstairs"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"climate","service":"turn_off","x":1330,"y":1720,"wires":[[]]},{"id":"83078cc49d4e26f8","type":"group","z":"5fb50193cc6a2ad5","g":"039ec143e4e7dd01","name":"AWAY MODE HUMIDITY CONTROL - API CALL TO SET A/C - SERVICE CALL TO  UPDATE  HA THERMOSTAT CARD ","style":{"label":true,"fill":"#000000"},"nodes":["5cee276c4a53f9f5","28a451e5864b7441","3fb866922e1304f2","e1633b88c9d37adb","37e634d4e5d21d13","f3409cf0858e3ceb","c3f8554edd572c7e","b483139905be8533"],"x":1014,"y":1419,"w":752,"h":262},{"id":"5cee276c4a53f9f5","type":"tado","z":"5fb50193cc6a2ad5","g":"83078cc49d4e26f8","acMode":"DRY","apiCall":"setZoneOverlay","childlock":false,"configName":"83e627ce7e032c20","defaultTerminationTimeout":900,"defaultTerminationType":"TADO_MODE","deviceId":"","endDate":"","fanSpeed":"AUTO","geoTracking":true,"homeId":"INSERT HOME ID","horizontalSwing":"OFF","name":"Liv Dry Mode [setZoneOverlay]  API Call","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","tariffId":"","tariffInCents":0,"temperature":"","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","verticalSwing":"OFF","windowDetection":true,"windowDetectionTimeout":900,"year":"","zoneId":"1","x":1360,"y":1640,"wires":[["28a451e5864b7441"]]},{"id":"28a451e5864b7441","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"83078cc49d4e26f8","name":"Liv HVAC Dry","server":"","version":7,"debugenabled":false,"action":"climate.set_hvac_mode","floorId":[],"areaId":[],"deviceId":["1d2bcc499a5b8ef266105be599b319f1"],"entityId":["climate.air_conditioning"],"labelId":[],"data":"{\"hvac_mode\":\"dry\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"climate","service":"set_hvac_mode","x":1660,"y":1640,"wires":[[]]},{"id":"3fb866922e1304f2","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"83078cc49d4e26f8","name":"State: dry","server":"","version":3,"outputs":2,"halt_if":"dry","halt_if_type":"str","halt_if_compare":"is","entity_id":"climate.air_conditioning","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1100,"y":1640,"wires":[[],["5cee276c4a53f9f5"]]},{"id":"e1633b88c9d37adb","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"83078cc49d4e26f8","name":"Contact Sensors ON (OPEN)","server":"","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"binary_sensor.middle_floor_sensor_group","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"seconds","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1160,"y":1580,"wires":[["37e634d4e5d21d13"],["3fb866922e1304f2"]]},{"id":"37e634d4e5d21d13","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"83078cc49d4e26f8","name":"Liv HVAC OFF","server":"","version":7,"debugenabled":false,"action":"climate.turn_off","floorId":[],"areaId":[],"deviceId":["1d2bcc499a5b8ef266105be599b319f1"],"entityId":["climate.air_conditioning"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"climate","service":"turn_off","x":1660,"y":1580,"wires":[[]]},{"id":"f3409cf0858e3ceb","type":"switch","z":"5fb50193cc6a2ad5","g":"83078cc49d4e26f8","name":"Dewpoint (<14.9 - Comfortable)(>15.5 Humid)","property":"payload","propertyType":"msg","rules":[{"t":"btwn","v":"0","vt":"num","v2":"15.54","v2t":"num"},{"t":"btwn","v":"15.5","vt":"num","v2":"100","v2t":"num"}],"checkall":"true","repair":false,"outputs":2,"x":1260,"y":1520,"wires":[["37e634d4e5d21d13"],["e1633b88c9d37adb"]]},{"id":"c3f8554edd572c7e","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"83078cc49d4e26f8","name":"DEWPOINT UPSTAIRS","server":"","version":3,"outputs":2,"halt_if":"0","halt_if_type":"num","halt_if_compare":"gt","entity_id":"sensor.dewpoint_upstairs","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"living","valueType":"str"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1390,"y":1460,"wires":[["f3409cf0858e3ceb"],[]]},{"id":"b483139905be8533","type":"delay","z":"5fb50193cc6a2ad5","g":"83078cc49d4e26f8","name":"","pauseType":"delay","timeout":"15","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":1100,"y":1460,"wires":[["c3f8554edd572c7e"]]},{"id":"11b0966d0f42bc8a","type":"delay","z":"5fb50193cc6a2ad5","g":"039ec143e4e7dd01","name":"","pauseType":"delay","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":720,"y":1580,"wires":[["960b45c073df4f3c"]]},{"id":"f2a8a34da6819e50","type":"delay","z":"5fb50193cc6a2ad5","g":"039ec143e4e7dd01","name":"","pauseType":"delay","timeout":"15","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":1080,"y":1720,"wires":[["62681239d0bb17fc"]]},{"id":"66a95c33221af678","type":"ha-entity-config","server":"","deviceConfig":"5e60cfe5ba3cd7eb","name":"Home and Away Switch","version":"6","entityType":"switch","haConfig":[{"property":"name","value":"Home and Away Switch"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":"switch"}],"resend":false,"debugEnabled":false},{"id":"5e60cfe5ba3cd7eb","type":"ha-device-config","name":"Home and Away Switch","hwVersion":"","manufacturer":"Node-RED","model":"","swVersion":"","server":""},{"id":"3d181cc7cd6e0871","type":"group","z":"5fb50193cc6a2ad5","g":"efa7ba0cd44d77f9","name":"AIR CONDITIONING LIGHT NOTIFICATIONS","style":{"fill":"#ffffbf","fill-opacity":"0.42","label":true},"nodes":["9439fb501fd8f75c","f7929285509cfd3f","fcb38a32af6bd8bd","936e737c0b585095","f2d7f193a8b804cd","4021e222232c2513","d2a784a2b9b6f623","c0850c5ce010c8b2","d671379b9964f1c9","169a222be7bd2622","d72669531a76c6bb","0208aa0a1b61fa2b","07e35cc3734ce59a","5dda933785a35309","58a5adff0d97f876","4d814238dfb3079e","aaa8fb5e9163e373","cd8e558052e19d13","09db7e2c8fe2dd64","1e7b446593ae6be0","4cdc512f1f67c9ba","9f3d4ea0afd5163f","2c49a184a836955d","53841f9127ac0ba5","5d2a9020643e8aba","27a71518fa5977c5","dca27f8ae4d490de","091878704413b5e6","4cbce3f669798943","f2093b70c3d7a5ec","98ced3f1f1754be8","7e01d5baf7a1d55d","1d141f870f3ed486","fbc67c235c8b0395","2c18c09ad774890d","9e9ff1480a84f2bf","ce9deeebe1bc3bc4","4df4811a8197afc9","73e3f03c4ba7698d","9e4477c8ba761eb0","cda8e3dc2bf83482","d16ba1e3a53aaf08","4ae7a9a2de380c99","245bd6ba6844e736"],"x":74,"y":2279,"w":1742,"h":362},{"id":"9439fb501fd8f75c","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"3d181cc7cd6e0871","name":"Yellow","server":"","version":7,"debugenabled":false,"action":"light.turn_on","floorId":[],"areaId":[],"deviceId":["4447a7dbb90664c319f100a328f0fded"],"entityId":[],"labelId":[],"data":"{\"hs_color\":[ 60, 100], \"brightness\": 255}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"light","service":"turn_on","x":510,"y":2320,"wires":[[]]},{"id":"f7929285509cfd3f","type":"trigger-state","z":"5fb50193cc6a2ad5","g":"3d181cc7cd6e0871","name":"Cool Set","server":"","version":5,"inputs":0,"outputs":2,"exposeAsEntityConfig":"","entities":{"entity":["climate.air_conditioning"],"substring":[],"regex":[]},"debugEnabled":false,"constraints":[{"targetType":"this_entity","targetValue":"","propertyType":"current_state","propertyValue":"new_state.state","comparatorType":"is","comparatorValueDatatype":"str","comparatorValue":"cool"}],"customOutputs":[],"outputInitially":false,"stateType":"str","enableInput":false,"x":160,"y":2400,"wires":[["091878704413b5e6"],[]]},{"id":"fcb38a32af6bd8bd","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"3d181cc7cd6e0871","name":"Light Blue","server":"","version":7,"debugenabled":false,"action":"light.turn_on","floorId":[],"areaId":[],"deviceId":["4447a7dbb90664c319f100a328f0fded"],"entityId":[],"labelId":[],"data":"{\"hs_color\":[120, 100], \"brightness\": 255}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"light","service":"turn_on","x":520,"y":2380,"wires":[[]]},{"id":"936e737c0b585095","type":"trigger-state","z":"5fb50193cc6a2ad5","g":"3d181cc7cd6e0871","name":"Auto Set","server":"","version":5,"inputs":0,"outputs":2,"exposeAsEntityConfig":"","entities":{"entity":["climate.air_conditioning"],"substring":[],"regex":[]},"debugEnabled":false,"constraints":[{"targetType":"this_entity","targetValue":"","propertyType":"current_state","propertyValue":"new_state.state","comparatorType":"is","comparatorValueDatatype":"str","comparatorValue":"auto"}],"customOutputs":[],"outputInitially":false,"stateType":"str","enableInput":false,"x":160,"y":2460,"wires":[["4cbce3f669798943"],[]]},{"id":"f2d7f193a8b804cd","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"3d181cc7cd6e0871","name":"Lime","server":"","version":7,"debugenabled":false,"action":"light.turn_on","floorId":[],"areaId":[],"deviceId":["4447a7dbb90664c319f100a328f0fded"],"entityId":[],"labelId":[],"data":"{\"hs_color\":[120, 100], \"brightness\": 255}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"light","service":"turn_on","x":510,"y":2440,"wires":[[]]},{"id":"4021e222232c2513","type":"trigger-state","z":"5fb50193cc6a2ad5","g":"3d181cc7cd6e0871","name":"Heat Set","server":"","version":5,"inputs":0,"outputs":2,"exposeAsEntityConfig":"","entities":{"entity":["climate.air_conditioning"],"substring":[],"regex":[]},"debugEnabled":false,"constraints":[{"targetType":"this_entity","targetValue":"","propertyType":"current_state","propertyValue":"new_state.state","comparatorType":"is","comparatorValueDatatype":"str","comparatorValue":"heat"}],"customOutputs":[],"outputInitially":false,"stateType":"str","enableInput":false,"x":720,"y":2340,"wires":[["f2093b70c3d7a5ec"],[]]},{"id":"d2a784a2b9b6f623","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"3d181cc7cd6e0871","name":"Orange","server":"","version":7,"debugenabled":false,"action":"light.turn_on","floorId":[],"areaId":[],"deviceId":["4447a7dbb90664c319f100a328f0fded"],"entityId":[],"labelId":[],"data":"{\"hs_color\":[40, 100], \"brightness\": 255}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"light","service":"turn_on","x":1080,"y":2320,"wires":[[]]},{"id":"c0850c5ce010c8b2","type":"trigger-state","z":"5fb50193cc6a2ad5","g":"3d181cc7cd6e0871","name":"OFF Set","server":"","version":5,"inputs":0,"outputs":2,"exposeAsEntityConfig":"","entities":{"entity":["climate.air_conditioning"],"substring":[],"regex":[]},"debugEnabled":false,"constraints":[{"targetType":"this_entity","targetValue":"","propertyType":"current_state","propertyValue":"new_state.state","comparatorType":"is","comparatorValueDatatype":"str","comparatorValue":"off"}],"customOutputs":[],"outputInitially":false,"stateType":"str","enableInput":false,"x":720,"y":2400,"wires":[["98ced3f1f1754be8"],[]]},{"id":"d671379b9964f1c9","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"3d181cc7cd6e0871","name":"Dark Blue","server":"","version":7,"debugenabled":false,"action":"light.turn_on","floorId":[],"areaId":[],"deviceId":["4447a7dbb90664c319f100a328f0fded"],"entityId":[],"labelId":[],"data":"{\"hs_color\":[240, 100], \"brightness\": 255}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"light","service":"turn_on","x":1080,"y":2380,"wires":[[]]},{"id":"169a222be7bd2622","type":"trigger-state","z":"5fb50193cc6a2ad5","g":"3d181cc7cd6e0871","name":"HOME Set","server":"","version":5,"inputs":0,"outputs":2,"exposeAsEntityConfig":"","entities":{"entity":["sensor.home_tado_mode"],"substring":[],"regex":[]},"debugEnabled":false,"constraints":[{"targetType":"this_entity","targetValue":"","propertyType":"current_state","propertyValue":"new_state.state","comparatorType":"is","comparatorValueDatatype":"str","comparatorValue":"HOME"}],"customOutputs":[],"outputInitially":false,"stateType":"str","enableInput":false,"x":720,"y":2460,"wires":[["7e01d5baf7a1d55d"],[]]},{"id":"d72669531a76c6bb","type":"trigger-state","z":"5fb50193cc6a2ad5","g":"3d181cc7cd6e0871","name":"AWAY Set","server":"","version":5,"inputs":0,"outputs":2,"exposeAsEntityConfig":"","entities":{"entity":["sensor.home_tado_mode"],"substring":[],"regex":[]},"debugEnabled":false,"constraints":[{"targetType":"this_entity","targetValue":"","propertyType":"current_state","propertyValue":"new_state.state","comparatorType":"is","comparatorValueDatatype":"str","comparatorValue":"AWAY"}],"customOutputs":[],"outputInitially":false,"stateType":"str","enableInput":false,"x":720,"y":2520,"wires":[["1d141f870f3ed486"],[]]},{"id":"0208aa0a1b61fa2b","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"3d181cc7cd6e0871","name":"Lime","server":"","version":7,"debugenabled":false,"action":"light.turn_on","floorId":[],"areaId":[],"deviceId":["4447a7dbb90664c319f100a328f0fded"],"entityId":[],"labelId":[],"data":"{\"hs_color\":[120, 100], \"brightness\": 255}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"light","service":"turn_on","x":1070,"y":2440,"wires":[["07e35cc3734ce59a"]]},{"id":"07e35cc3734ce59a","type":"msg-resend","z":"5fb50193cc6a2ad5","g":"3d181cc7cd6e0871","interval":"2","intervalUnit":"secs","maximum":"10","bytopic":false,"clone":false,"firstDelayed":false,"addCounters":false,"waitForResend":false,"highRate":false,"outputCountField":"","outputMaxField":"","name":"","x":1230,"y":2440,"wires":[["aaa8fb5e9163e373"]]},{"id":"5dda933785a35309","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"3d181cc7cd6e0871","name":"Dark Blue","server":"","version":7,"debugenabled":false,"action":"light.turn_on","floorId":[],"areaId":[],"deviceId":["4447a7dbb90664c319f100a328f0fded"],"entityId":[],"labelId":[],"data":"{\"hs_color\":[240, 100], \"brightness\": 255}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"light","service":"turn_on","x":1080,"y":2500,"wires":[["58a5adff0d97f876"]]},{"id":"58a5adff0d97f876","type":"msg-resend","z":"5fb50193cc6a2ad5","g":"3d181cc7cd6e0871","interval":"2","intervalUnit":"secs","maximum":"10","bytopic":false,"clone":false,"firstDelayed":false,"addCounters":false,"waitForResend":false,"highRate":false,"outputCountField":"","outputMaxField":"","name":"","x":1230,"y":2500,"wires":[["09db7e2c8fe2dd64"]]},{"id":"4d814238dfb3079e","type":"trigger-state","z":"5fb50193cc6a2ad5","g":"3d181cc7cd6e0871","name":"Dry Set","server":"","version":5,"inputs":0,"outputs":2,"exposeAsEntityConfig":"","entities":{"entity":["climate.air_conditioning"],"substring":[],"regex":[]},"debugEnabled":false,"constraints":[{"targetType":"this_entity","targetValue":"","propertyType":"current_state","propertyValue":"new_state.state","comparatorType":"is","comparatorValueDatatype":"str","comparatorValue":"dry"}],"customOutputs":[],"outputInitially":false,"stateType":"str","enableInput":false,"x":150,"y":2340,"wires":[["dca27f8ae4d490de"],[]]},{"id":"aaa8fb5e9163e373","type":"light-transition","z":"5fb50193cc6a2ad5","g":"3d181cc7cd6e0871","name":"","startRGB":"#00ff04","transitionRGB":"#008000","endRGB":"#00ff1e","startMired":"","endMired":"","transitionTime":"5","transitionTimeUnits":"Second","steps":"20","startBright":"100","endBright":"100","brightnessType":"Percent","transitionType":"Linear","colorTransitionType":"Weighted","x":1440,"y":2440,"wires":[["cd8e558052e19d13"],[]]},{"id":"cd8e558052e19d13","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"3d181cc7cd6e0871","name":"Green Flash","server":"","version":7,"debugenabled":false,"action":"light.turn_on","floorId":[],"areaId":[],"deviceId":[],"entityId":["light.local_30cm_twin_bar_light"],"labelId":[],"data":"{\t    \"rgb_color\": payload.rgb_color\t}\t","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"light","service":"turn_on","x":1670,"y":2440,"wires":[["245bd6ba6844e736"]]},{"id":"09db7e2c8fe2dd64","type":"light-transition","z":"5fb50193cc6a2ad5","g":"3d181cc7cd6e0871","name":"","startRGB":"#002aff","transitionRGB":"#e100ff","endRGB":"#0011ff","startMired":"","endMired":"","transitionTime":"5","transitionTimeUnits":"Second","steps":"20","startBright":"100","endBright":"100","brightnessType":"Percent","transitionType":"Linear","colorTransitionType":"Weighted","x":1440,"y":2500,"wires":[["1e7b446593ae6be0"],[]]},{"id":"1e7b446593ae6be0","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"3d181cc7cd6e0871","name":"Blue Flash","server":"","version":7,"debugenabled":false,"action":"light.turn_on","floorId":[],"areaId":[],"deviceId":[],"entityId":["light.local_30cm_twin_bar_light"],"labelId":[],"data":"{\t    \"rgb_color\": payload.rgb_color\t}\t","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"light","service":"turn_on","x":1670,"y":2500,"wires":[["4ae7a9a2de380c99"]]},{"id":"4cdc512f1f67c9ba","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"3d181cc7cd6e0871","name":"Magenta","server":"","version":7,"debugenabled":false,"action":"light.turn_on","floorId":[],"areaId":[],"deviceId":["4447a7dbb90664c319f100a328f0fded"],"entityId":[],"labelId":[],"data":"{\"hs_color\":[ 300, 100], \"brightness\": 255}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"light","service":"turn_on","x":1680,"y":2360,"wires":[[]]},{"id":"9f3d4ea0afd5163f","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"3d181cc7cd6e0871","name":"Red","server":"","version":7,"debugenabled":false,"action":"light.turn_on","floorId":[],"areaId":[],"deviceId":["4447a7dbb90664c319f100a328f0fded"],"entityId":[],"labelId":[],"data":"{\"hs_color\":[ 0, 100], \"brightness\": 255}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"light","service":"turn_on","x":1490,"y":2320,"wires":[[]]},{"id":"2c49a184a836955d","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"3d181cc7cd6e0871","name":"Purple","server":"","version":7,"debugenabled":false,"action":"light.turn_on","floorId":[],"areaId":[],"deviceId":["4447a7dbb90664c319f100a328f0fded"],"entityId":[],"labelId":[],"data":"{\"hs_color\":[ 270, 100], \"brightness\": 255}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"light","service":"turn_on","x":1670,"y":2320,"wires":[[]]},{"id":"53841f9127ac0ba5","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"3d181cc7cd6e0871","name":"Red Flash","server":"","version":7,"debugenabled":false,"action":"light.turn_on","floorId":[],"areaId":[],"deviceId":["4447a7dbb90664c319f100a328f0fded"],"entityId":[],"labelId":[],"data":"{\"color_name\": \"red\", \"flash\": \"short\"}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"light","service":"turn_on","x":1510,"y":2360,"wires":[[]]},{"id":"5d2a9020643e8aba","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"3d181cc7cd6e0871","name":"Indiego","server":"","version":7,"debugenabled":false,"action":"light.turn_on","floorId":[],"areaId":[],"deviceId":["4447a7dbb90664c319f100a328f0fded"],"entityId":[],"labelId":[],"data":"{\"hs_color\":[275, 100], \"brightness\": 255}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"light","service":"turn_on","x":1340,"y":2320,"wires":[[]]},{"id":"27a71518fa5977c5","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"3d181cc7cd6e0871","name":"Dark Blue","server":"","version":7,"debugenabled":false,"action":"light.turn_on","floorId":[],"areaId":[],"deviceId":["4447a7dbb90664c319f100a328f0fded"],"entityId":[],"labelId":[],"data":"{\"hs_color\":[240, 100], \"brightness\": 255}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"light","service":"turn_on","x":1340,"y":2360,"wires":[[]]},{"id":"dca27f8ae4d490de","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"3d181cc7cd6e0871","name":"","startTime":"05:30:00","endTime":"00:00:00","outputs":2,"x":330,"y":2340,"wires":[["9439fb501fd8f75c"],["2c18c09ad774890d"]]},{"id":"091878704413b5e6","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"3d181cc7cd6e0871","name":"","startTime":"05:30:00","endTime":"00:00:00","outputs":2,"x":330,"y":2400,"wires":[["fcb38a32af6bd8bd"],["ce9deeebe1bc3bc4"]]},{"id":"4cbce3f669798943","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"3d181cc7cd6e0871","name":"","startTime":"05:30:00","endTime":"00:00:00","outputs":2,"x":330,"y":2460,"wires":[["f2d7f193a8b804cd"],["4df4811a8197afc9"]]},{"id":"f2093b70c3d7a5ec","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"3d181cc7cd6e0871","name":"","startTime":"05:30:00","endTime":"00:00:00","outputs":2,"x":890,"y":2340,"wires":[["d2a784a2b9b6f623"],["73e3f03c4ba7698d"]]},{"id":"98ced3f1f1754be8","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"3d181cc7cd6e0871","name":"","startTime":"05:30:00","endTime":"00:00:00","outputs":2,"x":890,"y":2400,"wires":[["d671379b9964f1c9"],["9e4477c8ba761eb0"]]},{"id":"7e01d5baf7a1d55d","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"3d181cc7cd6e0871","name":"","startTime":"05:30:00","endTime":"00:00:00","outputs":2,"x":890,"y":2460,"wires":[["0208aa0a1b61fa2b"],["cda8e3dc2bf83482"]]},{"id":"1d141f870f3ed486","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"3d181cc7cd6e0871","name":"","startTime":"05:30:00","endTime":"00:00:00","outputs":2,"x":890,"y":2520,"wires":[["5dda933785a35309"],["d16ba1e3a53aaf08"]]},{"id":"fbc67c235c8b0395","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"3d181cc7cd6e0871","name":"","server":"","version":7,"debugenabled":false,"action":"light.turn_off","floorId":[],"areaId":[],"deviceId":["4447a7dbb90664c319f100a328f0fded"],"entityId":[],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"light","service":"turn_off","x":870,"y":2600,"wires":[[]]},{"id":"2c18c09ad774890d","type":"link out","z":"5fb50193cc6a2ad5","g":"3d181cc7cd6e0871","name":"Light Out","mode":"link","links":["9e9ff1480a84f2bf"],"x":425,"y":2360,"wires":[]},{"id":"9e9ff1480a84f2bf","type":"link in","z":"5fb50193cc6a2ad5","g":"3d181cc7cd6e0871","name":"Light In","links":["2c18c09ad774890d","ce9deeebe1bc3bc4","4df4811a8197afc9","73e3f03c4ba7698d","9e4477c8ba761eb0","cda8e3dc2bf83482","d16ba1e3a53aaf08","4ae7a9a2de380c99","245bd6ba6844e736"],"x":765,"y":2600,"wires":[["fbc67c235c8b0395"]]},{"id":"ce9deeebe1bc3bc4","type":"link out","z":"5fb50193cc6a2ad5","g":"3d181cc7cd6e0871","name":"Light Out","mode":"link","links":["9e9ff1480a84f2bf"],"x":425,"y":2420,"wires":[]},{"id":"4df4811a8197afc9","type":"link out","z":"5fb50193cc6a2ad5","g":"3d181cc7cd6e0871","name":"Light Out","mode":"link","links":["9e9ff1480a84f2bf"],"x":425,"y":2480,"wires":[]},{"id":"73e3f03c4ba7698d","type":"link out","z":"5fb50193cc6a2ad5","g":"3d181cc7cd6e0871","name":"Light Out","mode":"link","links":["9e9ff1480a84f2bf"],"x":985,"y":2360,"wires":[]},{"id":"9e4477c8ba761eb0","type":"link out","z":"5fb50193cc6a2ad5","g":"3d181cc7cd6e0871","name":"Light Out","mode":"link","links":["9e9ff1480a84f2bf"],"x":985,"y":2420,"wires":[]},{"id":"cda8e3dc2bf83482","type":"link out","z":"5fb50193cc6a2ad5","g":"3d181cc7cd6e0871","name":"Light Out","mode":"link","links":["9e9ff1480a84f2bf"],"x":985,"y":2480,"wires":[]},{"id":"d16ba1e3a53aaf08","type":"link out","z":"5fb50193cc6a2ad5","g":"3d181cc7cd6e0871","name":"Light Out","mode":"link","links":["9e9ff1480a84f2bf"],"x":985,"y":2540,"wires":[]},{"id":"4ae7a9a2de380c99","type":"link out","z":"5fb50193cc6a2ad5","g":"3d181cc7cd6e0871","name":"Light Out","mode":"link","links":["9e9ff1480a84f2bf"],"x":1775,"y":2500,"wires":[]},{"id":"245bd6ba6844e736","type":"link out","z":"5fb50193cc6a2ad5","g":"3d181cc7cd6e0871","name":"Light Out","mode":"link","links":["9e9ff1480a84f2bf"],"x":1775,"y":2440,"wires":[]},{"id":"de002435f2c50b86","type":"group","z":"5fb50193cc6a2ad5","g":"efa7ba0cd44d77f9","name":"Check Outside Dewpoint to Set Program","style":{"label":true,"fill":"#001f60","fill-opacity":"0.2"},"nodes":["1bc894807cde420e","dfb789ae373889a9","e760333aa214acda","5e26ad2cdbcdcd6d","6784eab8cb3d6e99"],"x":808,"y":631.5,"w":598,"h":557},{"id":"1bc894807cde420e","type":"switch","z":"5fb50193cc6a2ad5","g":"de002435f2c50b86","name":"Dewpoint (<12.79 - Dry)(12.8-15.49 - Comfortable)(>15.5 Humid)","property":"payload","propertyType":"msg","rules":[{"t":"btwn","v":"-20","vt":"num","v2":"12.79","v2t":"num"},{"t":"btwn","v":"12.8","vt":"num","v2":"15.49","v2t":"num"},{"t":"btwn","v":"15.5","vt":"num","v2":"50","v2t":"num"}],"checkall":"true","repair":false,"outputs":3,"x":1150,"y":1140,"wires":[["7109a465a826add3"],["235db10bbd6bacb6"],["9b0dbfc4dc35f873"]]},{"id":"dfb789ae373889a9","type":"group","z":"5fb50193cc6a2ad5","g":"de002435f2c50b86","name":"BOM AUSTRALIA BACK-UP SENSOR","style":{"label":true},"nodes":["e0581882574d59fe","e9936f1e918c5d47"],"x":834,"y":779,"w":532,"h":182},{"id":"e0581882574d59fe","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"dfb789ae373889a9","name":"IF DEWPOINT OUTSIDE UNKNOWN","server":"","version":3,"outputs":2,"halt_if":"unknown","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.dewpoint_outside","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1010,"y":920,"wires":[["e9936f1e918c5d47"],["e760333aa214acda"]]},{"id":"e9936f1e918c5d47","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"dfb789ae373889a9","name":"DEWPOINT AIRPORT","server":"","version":3,"outputs":2,"halt_if":"-20","halt_if_type":"num","halt_if_compare":"gt","entity_id":"sensor.dewpoint_airport","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1240,"y":820,"wires":[["5e26ad2cdbcdcd6d","6784eab8cb3d6e99"],[]]},{"id":"e760333aa214acda","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"de002435f2c50b86","name":"DEWPOINT OUTSIDE","server":"","version":3,"outputs":2,"halt_if":"-20","halt_if_type":"num","halt_if_compare":"gt","entity_id":"sensor.dewpoint_outside","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1240,"y":1020,"wires":[["5e26ad2cdbcdcd6d","6784eab8cb3d6e99"],[]]},{"id":"5e26ad2cdbcdcd6d","type":"switch","z":"5fb50193cc6a2ad5","g":"de002435f2c50b86","name":"Dewpoint (<12.79 - Dry)(12.8-15.49 - Comfortable)(>15.5 Humid)","property":"payload","propertyType":"msg","rules":[{"t":"btwn","v":"-20","vt":"num","v2":"12.79","v2t":"num"},{"t":"btwn","v":"12.8","vt":"num","v2":"15.49","v2t":"num"},{"t":"btwn","v":"15.5","vt":"num","v2":"50","v2t":"num"}],"checkall":"true","repair":false,"outputs":3,"x":1150,"y":680,"wires":[["34609ecad79a6e23"],["137506c1ab439356"],["4e760bfc85386566"]]},{"id":"6784eab8cb3d6e99","type":"delay","z":"5fb50193cc6a2ad5","g":"de002435f2c50b86","name":"","pauseType":"delay","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":960,"y":1080,"wires":[["1bc894807cde420e"]]},{"id":"fd220e4c1b06e1a3","type":"group","z":"5fb50193cc6a2ad5","g":"efa7ba0cd44d77f9","name":"DOWNSTAIRS DEHUMIDIFIER","style":{"fill":"#ffbfbf","fill-opacity":"0.48","label":true},"nodes":["4646e4029d9049f9","957661580e499fa4","4853274f3aa9bb31","842fb996fbb3755a","2097e97d662019ae","3a720edc1b3aba8b","7f0f76ffdfabad03","6dbdd06803d2ff47","730f0cfebfd099ae"],"x":74,"y":1899,"w":1712,"h":142},{"id":"4646e4029d9049f9","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"fd220e4c1b06e1a3","name":"Dehumidifier OFF","server":"","version":7,"debugenabled":false,"action":"switch.turn_off","floorId":[],"areaId":[],"deviceId":["0037262b42f8c2f57653b2d6f879bf82"],"entityId":[],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"switch","service":"turn_off","x":430,"y":2000,"wires":[[]]},{"id":"957661580e499fa4","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"fd220e4c1b06e1a3","name":"Dehumidifier ON","server":"","version":7,"debugenabled":false,"action":"switch.turn_on","floorId":[],"areaId":[],"deviceId":["0037262b42f8c2f57653b2d6f879bf82"],"entityId":[],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"switch","service":"turn_on","x":420,"y":1940,"wires":[["2097e97d662019ae"]]},{"id":"4853274f3aa9bb31","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"fd220e4c1b06e1a3","name":"Cyan","server":"","version":7,"debugenabled":false,"action":"light.turn_on","floorId":[],"areaId":[],"deviceId":["4447a7dbb90664c319f100a328f0fded"],"entityId":[],"labelId":[],"data":"{\"hs_color\":[180, 100], \"brightness\": 255}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"light","service":"turn_on","x":970,"y":1940,"wires":[[]]},{"id":"842fb996fbb3755a","type":"poll-state","z":"5fb50193cc6a2ad5","g":"fd220e4c1b06e1a3","name":"Poll Dewpoint >= 15.5","server":"","version":3,"exposeAsEntityConfig":"","updateInterval":"10","updateIntervalType":"num","updateIntervalUnits":"minutes","outputInitially":true,"outputOnChanged":true,"entityId":"sensor.dewpoint_downstairs","stateType":"str","ifState":"15.5","ifStateType":"num","ifStateOperator":"gte","outputs":2,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":200,"y":1960,"wires":[["957661580e499fa4"],["4646e4029d9049f9"]]},{"id":"2097e97d662019ae","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"fd220e4c1b06e1a3","name":"Dehumidifier Power >=0W","server":"","version":3,"outputs":2,"halt_if":"0","halt_if_type":"num","halt_if_compare":"gte","entity_id":"sensor.dehumidifier_power","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":730,"y":1940,"wires":[["4853274f3aa9bb31"],["6dbdd06803d2ff47"]]},{"id":"3a720edc1b3aba8b","type":"light-transition","z":"5fb50193cc6a2ad5","g":"fd220e4c1b06e1a3","name":"","startRGB":"#00eeff","transitionRGB":"#ff00d0","endRGB":"#00fbff","startMired":"","endMired":"","transitionTime":"5","transitionTimeUnits":"Second","steps":"20","startBright":"100","endBright":"100","brightnessType":"Percent","transitionType":"Linear","colorTransitionType":"Weighted","x":1200,"y":2000,"wires":[["7f0f76ffdfabad03"],[]]},{"id":"7f0f76ffdfabad03","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"fd220e4c1b06e1a3","name":"Pink Cyan Flash","server":"","version":7,"debugenabled":false,"action":"light.turn_on","floorId":[],"areaId":[],"deviceId":[],"entityId":["light.local_30cm_twin_bar_light"],"labelId":[],"data":"{\t    \"rgb_color\": payload.rgb_color\t}\t","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"light","service":"turn_on","x":1420,"y":2000,"wires":[["730f0cfebfd099ae"]]},{"id":"6dbdd06803d2ff47","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"fd220e4c1b06e1a3","name":"","startTime":"05:55:00","endTime":"21:00:00","outputs":2,"x":990,"y":2000,"wires":[["3a720edc1b3aba8b"],[]]},{"id":"730f0cfebfd099ae","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"fd220e4c1b06e1a3","name":"TTS Empty Dehumidifier","server":"","version":7,"debugenabled":false,"action":"notify.google_assistant_sdk","floorId":[],"areaId":[],"deviceId":[],"entityId":[],"labelId":[],"data":"{\"message\":\"the dehumidifier downstairs needs to be emptied\",\"title\":\"Dehumidifier Full\",\"target\":\"attic speaker\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"notify","service":"google_assistant_sdk","x":1650,"y":2000,"wires":[[]]},{"id":"2eb6fb258078d230","type":"group","z":"5fb50193cc6a2ad5","g":"efa7ba0cd44d77f9","name":"UPSTAIRS FAN","style":{"fill":"#ffbfbf","fill-opacity":"0.48","label":true},"nodes":["0f128653e7e0822e","363f907f2a3e303f","54acca01e0279e59","88d478e2cd2b5ab6","18b4eef3d1f98bc5","bdc9f2537af79482","0ac541d00e4732f0","23992708ba5e6a99","bc3c87c8de32c81d"],"x":74,"y":2099,"w":1212,"h":122},{"id":"0f128653e7e0822e","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"2eb6fb258078d230","name":"Fan OFF","server":"","version":7,"debugenabled":false,"action":"fan.turn_off","floorId":[],"areaId":[],"deviceId":["2a1b3077937dc785c5b9f2c0d72e8e5b"],"entityId":[],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"fan","service":"turn_off","x":1000,"y":2180,"wires":[[]]},{"id":"363f907f2a3e303f","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"2eb6fb258078d230","name":"Fan ON","server":"","version":7,"debugenabled":false,"action":"fan.turn_on","floorId":[],"areaId":[],"deviceId":[],"entityId":["fan.ceiling_fan"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"fan","service":"turn_on","x":1000,"y":2140,"wires":[["54acca01e0279e59"]]},{"id":"54acca01e0279e59","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"2eb6fb258078d230","name":"Purple","server":"","version":7,"debugenabled":false,"action":"light.turn_on","floorId":[],"areaId":[],"deviceId":["4447a7dbb90664c319f100a328f0fded"],"entityId":[],"labelId":[],"data":"{\"hs_color\":[275, 100], \"brightness\": 255}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"light","service":"turn_on","x":1210,"y":2140,"wires":[[]]},{"id":"88d478e2cd2b5ab6","type":"join","z":"5fb50193cc6a2ad5","g":"2eb6fb258078d230","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","useparts":false,"accumulate":true,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":350,"y":2160,"wires":[["18b4eef3d1f98bc5"]]},{"id":"18b4eef3d1f98bc5","type":"function","z":"5fb50193cc6a2ad5","g":"2eb6fb258078d230","name":"4 Degrees Diff","func":"var upstairsTemp = parseFloat(msg.payload.upstairs);\nvar middleTemp = parseFloat(msg.payload.middle);\n\nif (upstairsTemp !== undefined && middleTemp !== undefined) {\n    var tempDifference = upstairsTemp - middleTemp;\n\n    if (tempDifference > 4) {\n        return { payload: \"ON\", topic: \"fan_control\" };\n    } else {\n        return { payload: \"OFF\", topic: \"fan_control\" };\n    }\n}\nreturn null;\n","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":520,"y":2160,"wires":[["bdc9f2537af79482"]]},{"id":"bdc9f2537af79482","type":"switch","z":"5fb50193cc6a2ad5","g":"2eb6fb258078d230","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"ON","vt":"str"},{"t":"eq","v":"OFF","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":690,"y":2160,"wires":[["bc3c87c8de32c81d"],["0f128653e7e0822e"]]},{"id":"0ac541d00e4732f0","type":"poll-state","z":"5fb50193cc6a2ad5","g":"2eb6fb258078d230","name":"Upstairs Temp","server":"","version":3,"exposeAsEntityConfig":"","updateInterval":"60","updateIntervalType":"num","updateIntervalUnits":"seconds","outputInitially":false,"outputOnChanged":false,"entityId":"sensor.netatmo_devonport_tas_indoor_temperature","stateType":"str","ifState":"","ifStateType":"str","ifStateOperator":"is","outputs":1,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"upstairs","valueType":"str"}],"x":170,"y":2140,"wires":[["88d478e2cd2b5ab6"]]},{"id":"23992708ba5e6a99","type":"poll-state","z":"5fb50193cc6a2ad5","g":"2eb6fb258078d230","name":"Middle Temp","server":"","version":3,"exposeAsEntityConfig":"","updateInterval":"60","updateIntervalType":"num","updateIntervalUnits":"seconds","outputInitially":false,"outputOnChanged":false,"entityId":"sensor.air_conditioning_temperature","stateType":"str","ifState":"","ifStateType":"str","ifStateOperator":"is","outputs":1,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"middle","valueType":"str"}],"x":170,"y":2180,"wires":[["88d478e2cd2b5ab6"]]},{"id":"bc3c87c8de32c81d","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"2eb6fb258078d230","name":"","startTime":"05:30:00","endTime":"00:00:00","outputs":2,"x":850,"y":2140,"wires":[["363f907f2a3e303f"],[]]},{"id":"2fe87852caa8cba4","type":"group","z":"5fb50193cc6a2ad5","g":"efa7ba0cd44d77f9","name":"Outdoor Check Temperature","style":{"label":true},"nodes":["625d434943a374a0","349cab79ae84c936","63906bb6081aae1f"],"x":1874,"y":299,"w":212,"h":202},{"id":"625d434943a374a0","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"2fe87852caa8cba4","name":"Outdoor <=25","server":"","version":3,"outputs":2,"halt_if":"25","halt_if_type":"num","halt_if_compare":"lte","entity_id":"sensor.netatmo_devonport_tas_indoor_outdoor_temperature","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1980,"y":460,"wires":[["349cab79ae84c936"],["a17efd7cb5c0d152"]]},{"id":"349cab79ae84c936","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"2fe87852caa8cba4","name":"Outdoor <=21","server":"","version":3,"outputs":2,"halt_if":"21","halt_if_type":"num","halt_if_compare":"lte","entity_id":"sensor.netatmo_devonport_tas_indoor_outdoor_temperature","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1980,"y":400,"wires":[["12e87c7a20b53939"],["10dd0a9021620845"]]},{"id":"63906bb6081aae1f","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"2fe87852caa8cba4","name":"Outdoor  <=21","server":"","version":3,"outputs":2,"halt_if":"21","halt_if_type":"num","halt_if_compare":"lte","entity_id":"sensor.netatmo_devonport_tas_indoor_outdoor_temperature","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1980,"y":340,"wires":[["12e87c7a20b53939"],["10dd0a9021620845"]]},{"id":"40466ba49a049683","type":"group","z":"5fb50193cc6a2ad5","g":"efa7ba0cd44d77f9","name":"Outdoor Check Temperature","style":{"label":true},"nodes":["7ec8bbea4a70b892","330ec0419e4bc16b","b754b820d2b0bb42"],"x":1874,"y":1739,"w":212,"h":202},{"id":"7ec8bbea4a70b892","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"40466ba49a049683","name":"Outdoor <=25","server":"","version":3,"outputs":2,"halt_if":"25","halt_if_type":"num","halt_if_compare":"lte","entity_id":"sensor.netatmo_devonport_tas_indoor_outdoor_temperature","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1980,"y":1900,"wires":[["330ec0419e4bc16b"],["df9398a34a874589"]]},{"id":"330ec0419e4bc16b","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"40466ba49a049683","name":"Outdoor <=21","server":"","version":3,"outputs":2,"halt_if":"21","halt_if_type":"num","halt_if_compare":"lte","entity_id":"sensor.netatmo_devonport_tas_indoor_outdoor_temperature","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1980,"y":1840,"wires":[["2296de89b7df106d"],["b5cbcdae65c8c561"]]},{"id":"b754b820d2b0bb42","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"40466ba49a049683","name":"Outdoor  <=21","server":"","version":3,"outputs":2,"halt_if":"21","halt_if_type":"num","halt_if_compare":"lte","entity_id":"sensor.netatmo_devonport_tas_indoor_outdoor_temperature","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1980,"y":1780,"wires":[["2296de89b7df106d"],["b5cbcdae65c8c561"]]},{"id":"59af5f11e0571b7f","type":"comment","z":"5fb50193cc6a2ad5","g":"efa7ba0cd44d77f9","name":"README First","info":"Various examples of how to use the *Tado* node\n\nIF YOU HAVE HAVE PREVIOUS node-red-contrib-tado-client NODES INSTALLED, ENSURE YOU CHANGE THE SERVER TO YOUR CURRENT SERVER\n\nTado no longer uses username/password auth.\n\nInstead you should `inject` into the \"Authentication Flow\"\nand monitor the debug output. This will trigger a device\nauth flow, that will require you to visit a URL to login.\nThe URL Login will be printed by the TADO Debug Node, Open the Deug Window to view.\n\nOnce you've logged in a token will be printed to the\ndebug window. You can use this token to bypass the auth process\nnext time. An example of this is shown in the \"Persistent\nAuthentication\" group - you'll need to enable this.\nOnce enabled this will Tado [authenticate] node will automatically give an Authenticated if sucessful.\n\nYou should also replace the `home_id` in the calls\nwith your `home_id` which can be found using the first\nexample of `getMe` API call.","x":160,"y":140,"wires":[]},{"id":"62194f3abe3ce1ad","type":"group","z":"5fb50193cc6a2ad5","g":"efa7ba0cd44d77f9","name":"Authentication Flow","style":{"label":true},"nodes":["aa6197daac170533","45b73ebb4d7ee195","e997b0aa011bb55c","c7aabca69c2ebb5c"],"x":94,"y":179,"w":392,"h":142},{"id":"aa6197daac170533","type":"tado","z":"5fb50193cc6a2ad5","g":"62194f3abe3ce1ad","acMode":"AUTO","apiCall":"authenticate","childlock":false,"configName":"83e627ce7e032c20","defaultTerminationTimeout":900,"defaultTerminationType":"manual","deviceId":"","endDate":"","fanSpeed":"AUTO","geoTracking":true,"homeId":"","horizontalSwing":"off","name":"","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","tariffId":"","tariffInCents":0,"temperature":"18","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","verticalSwing":"off","windowDetection":true,"windowDetectionTimeout":900,"zoneId":"","x":370,"y":220,"wires":[["c7aabca69c2ebb5c"]]},{"id":"45b73ebb4d7ee195","type":"inject","z":"5fb50193cc6a2ad5","g":"62194f3abe3ce1ad","name":"","props":[],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":190,"y":220,"wires":[["aa6197daac170533"]]},{"id":"e997b0aa011bb55c","type":"tado-token","z":"5fb50193cc6a2ad5","d":true,"g":"62194f3abe3ce1ad","configName":"83e627ce7e032c20","x":180,"y":280,"wires":[["c7aabca69c2ebb5c"]]},{"id":"c7aabca69c2ebb5c","type":"debug","z":"5fb50193cc6a2ad5","g":"62194f3abe3ce1ad","name":"Token","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":390,"y":280,"wires":[]},{"id":"f3d522ebe8298997","type":"group","z":"5fb50193cc6a2ad5","g":"efa7ba0cd44d77f9","name":"Persistent Auth","style":{"label":true},"nodes":["46bf1b7c312a38cd","c12d3b5c037862e1","0606513b0d73274e","1033174eec14ab95","9a53914cd4dc4e71","a6365dd957825c93","72eb471e04471de1"],"x":514,"y":179,"w":772,"h":142},{"id":"46bf1b7c312a38cd","type":"tado","z":"5fb50193cc6a2ad5","g":"f3d522ebe8298997","acMode":"AUTO","apiCall":"authenticate","childlock":false,"configName":"83e627ce7e032c20","defaultTerminationTimeout":900,"defaultTerminationType":"manual","deviceId":"","endDate":"","fanSpeed":"AUTO","geoTracking":true,"homeId":"","horizontalSwing":"off","name":"","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","tariffId":"","tariffInCents":0,"temperature":"18","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","verticalSwing":"off","windowDetection":true,"windowDetectionTimeout":900,"zoneId":"","x":1010,"y":280,"wires":[["72eb471e04471de1"]]},{"id":"c12d3b5c037862e1","type":"tado-token","z":"5fb50193cc6a2ad5","g":"f3d522ebe8298997","configName":"83e627ce7e032c20","x":600,"y":280,"wires":[["0606513b0d73274e"]]},{"id":"0606513b0d73274e","type":"file","z":"5fb50193cc6a2ad5","g":"f3d522ebe8298997","name":"","filename":"/data/tado.json","filenameType":"str","appendNewline":false,"createDir":false,"overwriteFile":"true","encoding":"none","x":780,"y":280,"wires":[[]]},{"id":"1033174eec14ab95","type":"file in","z":"5fb50193cc6a2ad5","g":"f3d522ebe8298997","name":"","filename":"/data/tado.json","filenameType":"str","format":"utf8","chunk":false,"sendError":false,"encoding":"none","allProps":false,"x":780,"y":220,"wires":[["a6365dd957825c93"]]},{"id":"9a53914cd4dc4e71","type":"inject","z":"5fb50193cc6a2ad5","g":"f3d522ebe8298997","name":"","props":[],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","x":610,"y":220,"wires":[["1033174eec14ab95"]]},{"id":"a6365dd957825c93","type":"change","z":"5fb50193cc6a2ad5","g":"f3d522ebe8298997","name":"","rules":[{"t":"set","p":"refreshToken","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1000,"y":220,"wires":[["46bf1b7c312a38cd"]]},{"id":"72eb471e04471de1","type":"debug","z":"5fb50193cc6a2ad5","g":"f3d522ebe8298997","name":"Auth","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1190,"y":280,"wires":[]},{"id":"7943d5ea4d7b9bc5","type":"tado","z":"5fb50193cc6a2ad5","g":"efa7ba0cd44d77f9","acMode":"AUTO","apiCall":"getMe","childlock":false,"configName":"83e627ce7e032c20","defaultTerminationTimeout":"","deviceId":"","endDate":"","fanSpeed":"AUTO","geoTracking":true,"homeId":"","name":"","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","tariffId":"","tariffInCents":0,"temperature":"18","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","windowDetection":true,"windowDetectionTimeout":900,"zoneId":"","x":390,"y":420,"wires":[["988ce4f2b08f793f"]]},{"id":"e41536ec7ce1b2c9","type":"tado","z":"5fb50193cc6a2ad5","g":"efa7ba0cd44d77f9","acMode":"AUTO","apiCall":"getZones","childlock":false,"configName":"83e627ce7e032c20","defaultTerminationTimeout":900,"defaultTerminationType":"manual","deviceId":"","endDate":"","fanSpeed":"AUTO","geoTracking":true,"homeId":"INSERT HOME ID","horizontalSwing":"off","name":"Get all Zones","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","tariffId":"","tariffInCents":0,"temperature":"18","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","verticalSwing":"off","windowDetection":true,"windowDetectionTimeout":900,"year":"","zoneId":"","x":390,"y":480,"wires":[["988ce4f2b08f793f"]]},{"id":"988ce4f2b08f793f","type":"debug","z":"5fb50193cc6a2ad5","g":"efa7ba0cd44d77f9","name":"TADO","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":610,"y":460,"wires":[]},{"id":"d170ecdb93efbd2b","type":"comment","z":"5fb50193cc6a2ad5","g":"efa7ba0cd44d77f9","name":"INSTRUCTIONS FOR USE - DOUBLE CLICK ME","info":"THIS IS USED TO CONNECT TO THE TADO API\n1. Double Click Tado [getMe] Node, Add the Tado Config from previous step.... \n2. Find your homes ID in the debug message [window payload.homes[0].id] \n3. Enter your Home ID into the other Nodes to fetch information from the API\n4. Each Tado Node in this flow will your Home ID and some Zone ID\n5. Find the path >_Copy Path Button in the Debug Node [payload.comfort[0].temperatureLevel]\n6. Copy the path into the Function Nodes in this","x":270,"y":360,"wires":[]},{"id":"fe854a754e098039","type":"group","z":"5fb50193cc6a2ad5","g":"efa7ba0cd44d77f9","name":"Activation (Linked to Home And Away Switch below)","style":{"label":true},"nodes":["41def5c3645a7414","0caa4747d3f18e68","2926bf43d0347873","77834d661894e4a2"],"x":74,"y":599,"w":692,"h":388},{"id":"41def5c3645a7414","type":"server-state-changed","z":"5fb50193cc6a2ad5","g":"fe854a754e098039","name":"Contact Sensors CLOSED 15sec - Topic2:door","server":"","version":6,"outputs":2,"exposeAsEntityConfig":"","entities":{"entity":["binary_sensor.middle_floor_sensor_group"],"substring":[],"regex":[]},"outputInitially":false,"stateType":"str","ifState":"off","ifStateType":"str","ifStateOperator":"is","outputOnlyOnStateChange":true,"for":"15","forType":"num","forUnits":"seconds","ignorePrevStateNull":true,"ignorePrevStateUnknown":true,"ignorePrevStateUnavailable":true,"ignoreCurrentStateUnknown":true,"ignoreCurrentStateUnavailable":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic2","propertyType":"msg","value":"door","valueType":"str"}],"x":280,"y":640,"wires":[["0caa4747d3f18e68"],[]]},{"id":"0caa4747d3f18e68","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"fe854a754e098039","name":"Home and Away Switch ON","server":"","version":7,"debugenabled":false,"action":"switch.turn_on","floorId":[],"areaId":[],"deviceId":[],"entityId":["switch.home_and_away_switch"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":true,"domain":"switch","service":"turn_on","x":620,"y":720,"wires":[["e0581882574d59fe"]]},{"id":"2926bf43d0347873","type":"link in","z":"5fb50193cc6a2ad5","g":"fe854a754e098039","name":"TEST IN","links":["31e80b5425bff681","101ff4c8766e2f48","cd1a39c723fb895a","a75092e1cb72dd6f","0215cece076baf97","02b94220c2d07698","a7970941d7e908c8"],"x":445,"y":720,"wires":[["0caa4747d3f18e68"]]},{"id":"77834d661894e4a2","type":"group","z":"5fb50193cc6a2ad5","g":"fe854a754e098039","name":"Check every 10 Minutes Topic: check","style":{"label":true},"nodes":["f8db6447dc455858","45bdacf7da64e86b","0555a26594e8f054"],"x":104,"y":759,"w":332,"h":202},{"id":"f8db6447dc455858","type":"inject","z":"5fb50193cc6a2ad5","g":"77834d661894e4a2","name":"10min Topic:check","props":[{"p":"payload"},{"p":"topic2","v":"check","vt":"str"}],"repeat":"600","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":270,"y":800,"wires":[["45bdacf7da64e86b"]]},{"id":"45bdacf7da64e86b","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"77834d661894e4a2","name":"TADO HOME","server":"","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.home_and_away_switch","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":320,"y":860,"wires":[["0555a26594e8f054"],["12e5ba8858a0c61c"]]},{"id":"0555a26594e8f054","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"77834d661894e4a2","name":"Contact Sensors OFF (CLOSED)","server":"","version":3,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"binary_sensor.middle_floor_sensor_group","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"seconds","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":270,"y":920,"wires":[["0caa4747d3f18e68"],["12e5ba8858a0c61c"]]},{"id":"d195fb64657c1201","type":"group","z":"5fb50193cc6a2ad5","g":"efa7ba0cd44d77f9","name":"Deactivation (Linked to Home And Away Switch below)","style":{"label":true},"nodes":["fabef38390ca65c5","12e5ba8858a0c61c","11f309de04a6ad3b"],"x":74,"y":1019,"w":692,"h":328},{"id":"fabef38390ca65c5","type":"server-state-changed","z":"5fb50193cc6a2ad5","g":"d195fb64657c1201","name":"Contact Sensors OPEN 2 Mins - Topic2:door","server":"","version":6,"outputs":2,"exposeAsEntityConfig":"","entities":{"entity":["binary_sensor.middle_floor_sensor_group"],"substring":[],"regex":[]},"outputInitially":false,"stateType":"str","ifState":"on","ifStateType":"str","ifStateOperator":"is","outputOnlyOnStateChange":true,"for":"2","forType":"num","forUnits":"minutes","ignorePrevStateNull":true,"ignorePrevStateUnknown":true,"ignorePrevStateUnavailable":true,"ignoreCurrentStateUnknown":true,"ignoreCurrentStateUnavailable":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic2","propertyType":"msg","value":"door","valueType":"str"}],"x":270,"y":1140,"wires":[["12e5ba8858a0c61c"],[]]},{"id":"12e5ba8858a0c61c","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"d195fb64657c1201","name":"Home and Away Switch OFF","server":"","version":7,"debugenabled":false,"action":"switch.turn_off","floorId":[],"areaId":[],"deviceId":[],"entityId":["switch.home_and_away_switch"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":true,"domain":"switch","service":"turn_off","x":620,"y":1060,"wires":[["9708fe6949fa3727"]]},{"id":"11f309de04a6ad3b","type":"group","z":"5fb50193cc6a2ad5","g":"d195fb64657c1201","name":"OFF (TTS Topic: door)","style":{"label":true},"nodes":["1bb0e9b500dc1346","9708fe6949fa3727","59d46fd44ba644c9"],"x":114,"y":1239,"w":512,"h":82},{"id":"1bb0e9b500dc1346","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"11f309de04a6ad3b","name":"TTS Door Open","server":"","version":7,"debugenabled":false,"action":"tts.cloud_say","floorId":[],"areaId":[],"deviceId":[],"entityId":[],"labelId":[],"data":"{\"entity_id\":\"media_player.attic_speaker\",\"message\":\"a door or window has been open for 2 minutes, I have switched the airconditioners off\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"tts","service":"cloud_say","x":520,"y":1280,"wires":[[]]},{"id":"9708fe6949fa3727","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"11f309de04a6ad3b","name":"","startTime":"05:55:00","endTime":"21:00:00","outputs":2,"x":210,"y":1280,"wires":[["59d46fd44ba644c9"],[]]},{"id":"59d46fd44ba644c9","type":"switch","z":"5fb50193cc6a2ad5","g":"11f309de04a6ad3b","name":"msg.topic","property":"topic2","propertyType":"msg","rules":[{"t":"eq","v":"check","vt":"str"},{"t":"eq","v":"door","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":360,"y":1280,"wires":[[],["1bb0e9b500dc1346"]]},{"id":"35cc0d0a876bf4e7","type":"group","z":"5fb50193cc6a2ad5","g":"efa7ba0cd44d77f9","name":"Downstairs","style":{"label":true,"fill":"#6f2fa0","fill-opacity":"0.63"},"nodes":["465eb5fe44442655","980935b641dcda4a","eb97d1601c2504be","a407445ed121dcef","184d1918b0d43138","bf2915b15469ec9f","b72c03d40ed7a7b5","f7fa4d2f52a851e1","a2f73de74c3ba609","e11b91fc93d564f4","f0bf9b5d1e6705e4","9055e8d79436663d","93f73edb692f52ec","c5e3899a37f93bae","24441776b84a6954","6f15733de9f19b9a","5727a428e863615c","96380ca6c62796d1","076d08c06c3b1727","2de55c8aa201987b","0215cece076baf97"],"x":2108,"y":1527,"w":4530,"h":1386},{"id":"465eb5fe44442655","type":"link out","z":"5fb50193cc6a2ad5","g":"35cc0d0a876bf4e7","name":"Down Comfort Program (Comf)","mode":"link","links":["515f9edbc6e70862"],"x":3375,"y":2100,"wires":[]},{"id":"980935b641dcda4a","type":"link out","z":"5fb50193cc6a2ad5","g":"35cc0d0a876bf4e7","name":"Down Cooling Program","mode":"link","links":["515f9edbc6e70862"],"x":2705,"y":2080,"wires":[]},{"id":"eb97d1601c2504be","type":"tado","z":"5fb50193cc6a2ad5","g":"35cc0d0a876bf4e7","acMode":"AUTO","apiCall":"getZoneStates","childlock":false,"configName":"83e627ce7e032c20","defaultTerminationTimeout":"","deviceId":"","endDate":"","fanSpeed":"AUTO","geoTracking":true,"homeId":"INSERT HOME ID","name":"","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","tariffId":"","tariffInCents":0,"temperature":"18","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","windowDetection":true,"windowDetectionTimeout":900,"year":"","zoneId":"","x":2880,"y":2040,"wires":[["1a5a5790f503c58b"]]},{"id":"a407445ed121dcef","type":"tado","z":"5fb50193cc6a2ad5","g":"35cc0d0a876bf4e7","acMode":"AUTO","apiCall":"getZoneStates","childlock":false,"configName":"83e627ce7e032c20","defaultTerminationTimeout":"","deviceId":"","endDate":"","fanSpeed":"AUTO","geoTracking":true,"homeId":"INSERT HOME ID","name":"","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","tariffId":"","tariffInCents":0,"temperature":"18","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","windowDetection":true,"windowDetectionTimeout":900,"year":"","zoneId":"","x":2880,"y":1940,"wires":[["e4f251ab70dae232"]]},{"id":"184d1918b0d43138","type":"tado","z":"5fb50193cc6a2ad5","g":"35cc0d0a876bf4e7","acMode":"AUTO","apiCall":"getZoneStates","childlock":false,"configName":"83e627ce7e032c20","defaultTerminationTimeout":"","deviceId":"","endDate":"","fanSpeed":"AUTO","geoTracking":true,"homeId":"INSERT HOME ID","name":"","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","tariffId":"","tariffInCents":0,"temperature":"18","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","windowDetection":true,"windowDetectionTimeout":900,"year":"","zoneId":"","x":2880,"y":1840,"wires":[["cb252ee7b4e6c788"]]},{"id":"bf2915b15469ec9f","type":"group","z":"5fb50193cc6a2ad5","g":"35cc0d0a876bf4e7","name":"Check Inside Dewpoint to set Heating Program DOWNSTAIRS","style":{"label":true,"fill":"#ff0000"},"nodes":["2296de89b7df106d","9a80a56c8808bbf5"],"x":2134,"y":1579,"w":592,"h":177},{"id":"2296de89b7df106d","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"bf2915b15469ec9f","name":"DEWPOINT DOWNSTAIRS","server":"","version":3,"outputs":2,"halt_if":"-20","halt_if_type":"num","halt_if_compare":"gt","entity_id":"sensor.dewpoint_downstairs","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":2280,"y":1620,"wires":[["9a80a56c8808bbf5"],[]]},{"id":"9a80a56c8808bbf5","type":"switch","z":"5fb50193cc6a2ad5","g":"bf2915b15469ec9f","name":"Dewpoint (<10.0 - Dry)(10.1-12.79 - Pleas)(12.8-15.49 - Comf)(>15.5 Sticky))","property":"payload","propertyType":"msg","rules":[{"t":"btwn","v":"-20","vt":"num","v2":"10","v2t":"num"},{"t":"btwn","v":"10.1","vt":"num","v2":"12.79","v2t":"num"},{"t":"btwn","v":"12.8","vt":"num","v2":"15.49","v2t":"num"},{"t":"btwn","v":"15.5","vt":"num","v2":"50","v2t":"num"}],"checkall":"true","repair":false,"outputs":4,"x":2430,"y":1700,"wires":[["3b7d9f8401e947df"],["58c7b8464e30296e"],["467a0956907bb674"],["eb97d1601c2504be"]]},{"id":"b72c03d40ed7a7b5","type":"group","z":"5fb50193cc6a2ad5","g":"35cc0d0a876bf4e7","name":"Check Inside Dewpoint to set Comfort Program DOWNSTAIRS","style":{"label":true,"fill":"#92d04f"},"nodes":["b5cbcdae65c8c561","5bc5f888bbeed8d2"],"x":2134,"y":1779,"w":592,"h":177},{"id":"b5cbcdae65c8c561","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"b72c03d40ed7a7b5","name":"DEWPOINT DOWNSTAIRS","server":"","version":3,"outputs":2,"halt_if":"0","halt_if_type":"num","halt_if_compare":"gt","entity_id":"sensor.dewpoint_downstairs","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":2280,"y":1820,"wires":[["5bc5f888bbeed8d2"],[]]},{"id":"5bc5f888bbeed8d2","type":"switch","z":"5fb50193cc6a2ad5","g":"b72c03d40ed7a7b5","name":"Dewpoint (<10.0 - Dry)(10.1-12.79 - Pleas)(12.8-15.49 - Comf)(>15.5 Sticky))","property":"payload","propertyType":"msg","rules":[{"t":"btwn","v":"-20","vt":"num","v2":"10","v2t":"num"},{"t":"btwn","v":"10.1","vt":"num","v2":"12.79","v2t":"num"},{"t":"btwn","v":"12.8","vt":"num","v2":"15.49","v2t":"num"},{"t":"btwn","v":"15.5","vt":"num","v2":"50","v2t":"num"}],"checkall":"true","repair":false,"outputs":4,"x":2430,"y":1900,"wires":[["184d1918b0d43138"],["a407445ed121dcef"],["eb97d1601c2504be"],["0765ee22eff40303"]]},{"id":"f7fa4d2f52a851e1","type":"group","z":"5fb50193cc6a2ad5","g":"35cc0d0a876bf4e7","name":"Check Inside Dewpoint to set Cooling Program DOWNSTAIRS","style":{"label":true,"fill":"#3f93cf"},"nodes":["df9398a34a874589","e03ad8c921de9c5b"],"x":2134,"y":1979,"w":512,"h":184.5},{"id":"df9398a34a874589","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"f7fa4d2f52a851e1","name":"DEWPOINT DOWNSTAIRS","server":"","version":3,"outputs":2,"halt_if":"0","halt_if_type":"num","halt_if_compare":"gt","entity_id":"sensor.dewpoint_downstairs","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":2280,"y":2020,"wires":[["e03ad8c921de9c5b"],[]]},{"id":"e03ad8c921de9c5b","type":"switch","z":"5fb50193cc6a2ad5","g":"f7fa4d2f52a851e1","name":"Dewpoint (<15.49 - Comf)(15.5-18.39 - Sticky)(>18.4 - Muggy)","property":"payload","propertyType":"msg","rules":[{"t":"btwn","v":"-20","vt":"num","v2":"10","v2t":"num"},{"t":"btwn","v":"10.1","vt":"num","v2":"12.79","v2t":"num"},{"t":"btwn","v":"12.8","vt":"num","v2":"15.49","v2t":"num"},{"t":"btwn","v":"15.5","vt":"num","v2":"18.39","v2t":"num"},{"t":"btwn","v":"18.4","vt":"num","v2":"50","v2t":"num"}],"checkall":"true","repair":false,"outputs":5,"x":2390,"y":2100,"wires":[["980935b641dcda4a"],["980935b641dcda4a"],["980935b641dcda4a"],["0765ee22eff40303"],["bf6f5509b5fc3efd"]]},{"id":"a2f73de74c3ba609","type":"group","z":"5fb50193cc6a2ad5","g":"35cc0d0a876bf4e7","name":"Don't Set if already Set","style":{"label":true},"nodes":["515f9edbc6e70862","680e5120763f2030","9426314ae56bb58d","a1ac09ca46806983","f3be25eec9b7a489","758a0b6aca43db33","58eee3195c37ccac","6c85b73cfe14fbe9","8368f6da846b211c","b63899926154d5d1","55d1bcf39f8f8671","58710c58bb6e662b","c72e5ba83283c8b8","d5c265857dd812a6","bf6f5509b5fc3efd","0765ee22eff40303","467a0956907bb674","58c7b8464e30296e","3b7d9f8401e947df","c300d481f179eed3","5d353ad453b5fe3e","b06dabfdc5a21c24","fd51d988eaf05f3d","e3b0a9f6c0eb1a30","b67fc1236c86ef1c","de615b4d9910ae96","53d83121935a92c9","86c6dedad4e9fd26"],"x":3444,"y":1559,"w":1262,"h":622},{"id":"515f9edbc6e70862","type":"link in","z":"5fb50193cc6a2ad5","g":"a2f73de74c3ba609","name":"Down HVAC OFF","links":["980935b641dcda4a","465eb5fe44442655","15436ce83c6e7861","27056c600a9c9dce"],"x":3485,"y":2000,"wires":[["d5c265857dd812a6"]]},{"id":"680e5120763f2030","type":"switch","z":"5fb50193cc6a2ad5","g":"a2f73de74c3ba609","name":"IS COOL","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"COOL","vt":"str"},{"t":"neq","v":"COOL","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":4020,"y":2140,"wires":[[],["361a73f6ec8d47c8"]]},{"id":"9426314ae56bb58d","type":"switch","z":"5fb50193cc6a2ad5","g":"a2f73de74c3ba609","name":"IS OFF","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"OFF","vt":"str"},{"t":"neq","v":"OFF","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":4020,"y":2040,"wires":[[],["2fcacacd560e8cb1"]]},{"id":"a1ac09ca46806983","type":"switch","z":"5fb50193cc6a2ad5","g":"a2f73de74c3ba609","name":"IS DRY","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"DRY","vt":"str"},{"t":"neq","v":"DRY","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":4020,"y":1940,"wires":[[],["38099d25e4688e7d"]]},{"id":"f3be25eec9b7a489","type":"switch","z":"5fb50193cc6a2ad5","g":"a2f73de74c3ba609","name":"IS SET 21","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"21.00","vt":"str"},{"t":"neq","v":"21.00","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":4010,"y":1840,"wires":[["86c6dedad4e9fd26"],["73221f6caafae3f6"]]},{"id":"758a0b6aca43db33","type":"switch","z":"5fb50193cc6a2ad5","g":"a2f73de74c3ba609","name":"IS SET 22","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"22.00","vt":"str"},{"t":"neq","v":"22.00","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":4010,"y":1740,"wires":[["de615b4d9910ae96"],["2368174710e861fe"]]},{"id":"58eee3195c37ccac","type":"switch","z":"5fb50193cc6a2ad5","g":"a2f73de74c3ba609","name":"IS SET 23","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"23.00","vt":"str"},{"t":"neq","v":"23.00","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":4010,"y":1640,"wires":[["fd51d988eaf05f3d"],["934c6b80fca23b89"]]},{"id":"6c85b73cfe14fbe9","type":"function","z":"5fb50193cc6a2ad5","g":"a2f73de74c3ba609","name":"Setting.TempSetpoint Downstairs Zone [2]","func":"const topic = msg.topic;  // preserve the topic\nif (msg.payload && msg.payload.zoneStates && msg.payload.zoneStates[\"2\"] && msg.payload.zoneStates[\"2\"].setting && msg.payload.zoneStates[\"2\"].setting.temperature) {\n    msg.payload = msg.payload.zoneStates[\"2\"].setting.temperature.celsius;\n} else {\n    msg.payload = 0.0;\n}\nmsg.topic = topic;        // restore the topic\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":3920,"y":1600,"wires":[["58eee3195c37ccac"]]},{"id":"8368f6da846b211c","type":"function","z":"5fb50193cc6a2ad5","g":"a2f73de74c3ba609","name":"Setting.TempSetpoint Downstairs Zone [2]","func":"const topic = msg.topic;  // preserve the topic\nif (msg.payload && msg.payload.zoneStates && msg.payload.zoneStates[\"2\"] && msg.payload.zoneStates[\"2\"].setting && msg.payload.zoneStates[\"2\"].setting.temperature) {\n    msg.payload = msg.payload.zoneStates[\"2\"].setting.temperature.celsius;\n} else {\n    msg.payload = 0.0;\n}\nmsg.topic = topic;        // restore the topic\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":3920,"y":1700,"wires":[["758a0b6aca43db33"]]},{"id":"b63899926154d5d1","type":"function","z":"5fb50193cc6a2ad5","g":"a2f73de74c3ba609","name":"Setting.TempSetpoint Downstairs Zone [2]","func":"const topic = msg.topic;  // preserve the topic\nif (msg.payload && msg.payload.zoneStates && msg.payload.zoneStates[\"2\"] && msg.payload.zoneStates[\"2\"].setting && msg.payload.zoneStates[\"2\"].setting.temperature) {\n    msg.payload = msg.payload.zoneStates[\"2\"].setting.temperature.celsius;\n} else {\n    msg.payload = 0.0;\n}\nmsg.topic = topic;        // restore the topic\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":3920,"y":1800,"wires":[["f3be25eec9b7a489"]]},{"id":"55d1bcf39f8f8671","type":"function","z":"5fb50193cc6a2ad5","g":"a2f73de74c3ba609","name":"Setting.Mode Downstairs Zone [2]","func":"const topic = msg.topic;  // preserve the topic\nif (msg.payload && msg.payload.zoneStates && msg.payload.zoneStates[\"2\"] && msg.payload.zoneStates[\"2\"].setting && msg.payload.zoneStates[\"2\"].setting.mode) {\n    msg.payload = msg.payload.zoneStates[\"2\"].setting.mode;\n} else {\n    msg.payload = msg.payload.zoneStates[\"2\"].setting.power;\n}\nmsg.topic = topic;        // restore the topic\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":3940,"y":1900,"wires":[["a1ac09ca46806983"]]},{"id":"58710c58bb6e662b","type":"function","z":"5fb50193cc6a2ad5","g":"a2f73de74c3ba609","name":"Setting.Mode Downstairs Zone [2]","func":"const topic = msg.topic;  // preserve the topic\nif (msg.payload && msg.payload.zoneStates && msg.payload.zoneStates[\"2\"] && msg.payload.zoneStates[\"2\"].setting && msg.payload.zoneStates[\"2\"].setting.mode) {\n    msg.payload = msg.payload.zoneStates[\"2\"].setting.mode;\n} else {\n    msg.payload = msg.payload.zoneStates[\"2\"].setting.power;\n}\nmsg.topic = topic;        // restore the topic\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":3940,"y":2000,"wires":[["9426314ae56bb58d"]]},{"id":"c72e5ba83283c8b8","type":"function","z":"5fb50193cc6a2ad5","g":"a2f73de74c3ba609","name":"Setting.Mode Downstairs Zone [2]","func":"const topic = msg.topic;  // preserve the topic\nif (msg.payload && msg.payload.zoneStates && msg.payload.zoneStates[\"2\"] && msg.payload.zoneStates[\"2\"].setting && msg.payload.zoneStates[\"2\"].setting.mode) {\n    msg.payload = msg.payload.zoneStates[\"2\"].setting.mode;\n} else {\n    msg.payload = msg.payload.zoneStates[\"2\"].setting.power;\n}\nmsg.topic = topic;        // restore the topic\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":3940,"y":2100,"wires":[["680e5120763f2030"]]},{"id":"d5c265857dd812a6","type":"tado","z":"5fb50193cc6a2ad5","g":"a2f73de74c3ba609","acMode":"AUTO","apiCall":"getZoneStates","childlock":false,"configName":"83e627ce7e032c20","defaultTerminationTimeout":"","deviceId":"","endDate":"","fanSpeed":"AUTO","geoTracking":true,"homeId":"INSERT HOME ID","name":"","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","tariffId":"","tariffInCents":0,"temperature":"18","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","windowDetection":true,"windowDetectionTimeout":900,"year":"","zoneId":"","x":3620,"y":2000,"wires":[["58710c58bb6e662b"]]},{"id":"bf6f5509b5fc3efd","type":"tado","z":"5fb50193cc6a2ad5","g":"a2f73de74c3ba609","acMode":"AUTO","apiCall":"getZoneStates","childlock":false,"configName":"83e627ce7e032c20","defaultTerminationTimeout":"","deviceId":"","endDate":"","fanSpeed":"AUTO","geoTracking":true,"homeId":"INSERT HOME ID","name":"","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","tariffId":"","tariffInCents":0,"temperature":"18","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","windowDetection":true,"windowDetectionTimeout":900,"year":"","zoneId":"","x":3620,"y":2100,"wires":[["c72e5ba83283c8b8"]]},{"id":"0765ee22eff40303","type":"tado","z":"5fb50193cc6a2ad5","g":"a2f73de74c3ba609","acMode":"AUTO","apiCall":"getZoneStates","childlock":false,"configName":"83e627ce7e032c20","defaultTerminationTimeout":"","deviceId":"","endDate":"","fanSpeed":"AUTO","geoTracking":true,"homeId":"INSERT HOME ID","name":"","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","tariffId":"","tariffInCents":0,"temperature":"18","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","windowDetection":true,"windowDetectionTimeout":900,"year":"","zoneId":"","x":3620,"y":1900,"wires":[["55d1bcf39f8f8671"]]},{"id":"467a0956907bb674","type":"tado","z":"5fb50193cc6a2ad5","g":"a2f73de74c3ba609","acMode":"AUTO","apiCall":"getZoneStates","childlock":false,"configName":"83e627ce7e032c20","defaultTerminationTimeout":"","deviceId":"","endDate":"","fanSpeed":"AUTO","geoTracking":true,"homeId":"INSERT HOME ID","name":"","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","tariffId":"","tariffInCents":0,"temperature":"18","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","windowDetection":true,"windowDetectionTimeout":900,"year":"","zoneId":"","x":3620,"y":1800,"wires":[["b63899926154d5d1"]]},{"id":"58c7b8464e30296e","type":"tado","z":"5fb50193cc6a2ad5","g":"a2f73de74c3ba609","acMode":"AUTO","apiCall":"getZoneStates","childlock":false,"configName":"83e627ce7e032c20","defaultTerminationTimeout":"","deviceId":"","endDate":"","fanSpeed":"AUTO","geoTracking":true,"homeId":"INSERT HOME ID","name":"","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","tariffId":"","tariffInCents":0,"temperature":"18","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","windowDetection":true,"windowDetectionTimeout":900,"year":"","zoneId":"","x":3620,"y":1700,"wires":[["8368f6da846b211c"]]},{"id":"3b7d9f8401e947df","type":"tado","z":"5fb50193cc6a2ad5","g":"a2f73de74c3ba609","acMode":"AUTO","apiCall":"getZoneStates","childlock":false,"configName":"83e627ce7e032c20","defaultTerminationTimeout":"","deviceId":"","endDate":"","fanSpeed":"AUTO","geoTracking":true,"homeId":"INSERT HOME ID","name":"","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","tariffId":"","tariffInCents":0,"temperature":"18","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","windowDetection":true,"windowDetectionTimeout":900,"year":"","zoneId":"","x":3620,"y":1600,"wires":[["6c85b73cfe14fbe9"]]},{"id":"c300d481f179eed3","type":"switch","z":"5fb50193cc6a2ad5","g":"a2f73de74c3ba609","name":"NOT HEAT","property":"payload","propertyType":"msg","rules":[{"t":"neq","v":"HEAT","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":4610,"y":1900,"wires":[["73221f6caafae3f6"]]},{"id":"5d353ad453b5fe3e","type":"switch","z":"5fb50193cc6a2ad5","g":"a2f73de74c3ba609","name":"NOT HEAT","property":"payload","propertyType":"msg","rules":[{"t":"neq","v":"HEAT","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":4610,"y":1700,"wires":[["934c6b80fca23b89"]]},{"id":"b06dabfdc5a21c24","type":"function","z":"5fb50193cc6a2ad5","g":"a2f73de74c3ba609","name":"Setting.Mode Downstairs Zone [2]","func":"const topic = msg.topic;  // preserve the topic\nif (msg.payload && msg.payload.zoneStates && msg.payload.zoneStates[\"2\"] && msg.payload.zoneStates[\"2\"].setting && msg.payload.zoneStates[\"2\"].setting.mode) {\n    msg.payload = msg.payload.zoneStates[\"2\"].setting.mode;\n} else {\n    msg.payload = msg.payload.zoneStates[\"2\"].setting.power;\n}\nmsg.topic = topic;        // restore the topic\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":4540,"y":1660,"wires":[["5d353ad453b5fe3e"]]},{"id":"fd51d988eaf05f3d","type":"tado","z":"5fb50193cc6a2ad5","g":"a2f73de74c3ba609","acMode":"AUTO","apiCall":"getZoneStates","childlock":false,"configName":"83e627ce7e032c20","defaultTerminationTimeout":"","deviceId":"","endDate":"","fanSpeed":"AUTO","geoTracking":true,"homeId":"INSERT HOME ID","name":"","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","tariffId":"","tariffInCents":0,"temperature":"18","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","windowDetection":true,"windowDetectionTimeout":900,"year":"","zoneId":"","x":4260,"y":1660,"wires":[["b06dabfdc5a21c24"]]},{"id":"e3b0a9f6c0eb1a30","type":"switch","z":"5fb50193cc6a2ad5","g":"a2f73de74c3ba609","name":"NOT HEAT","property":"payload","propertyType":"msg","rules":[{"t":"neq","v":"HEAT","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":4610,"y":1800,"wires":[["2368174710e861fe"]]},{"id":"b67fc1236c86ef1c","type":"function","z":"5fb50193cc6a2ad5","g":"a2f73de74c3ba609","name":"Setting.Mode Downstairs Zone [2]","func":"const topic = msg.topic;  // preserve the topic\nif (msg.payload && msg.payload.zoneStates && msg.payload.zoneStates[\"2\"] && msg.payload.zoneStates[\"2\"].setting && msg.payload.zoneStates[\"2\"].setting.mode) {\n    msg.payload = msg.payload.zoneStates[\"2\"].setting.mode;\n} else {\n    msg.payload = msg.payload.zoneStates[\"2\"].setting.power;\n}\nmsg.topic = topic;        // restore the topic\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":4540,"y":1760,"wires":[["e3b0a9f6c0eb1a30"]]},{"id":"de615b4d9910ae96","type":"tado","z":"5fb50193cc6a2ad5","g":"a2f73de74c3ba609","acMode":"AUTO","apiCall":"getZoneStates","childlock":false,"configName":"83e627ce7e032c20","defaultTerminationTimeout":"","deviceId":"","endDate":"","fanSpeed":"AUTO","geoTracking":true,"homeId":"INSERT HOME ID","name":"","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","tariffId":"","tariffInCents":0,"temperature":"18","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","windowDetection":true,"windowDetectionTimeout":900,"year":"","zoneId":"","x":4260,"y":1760,"wires":[["b67fc1236c86ef1c"]]},{"id":"53d83121935a92c9","type":"function","z":"5fb50193cc6a2ad5","g":"a2f73de74c3ba609","name":"Setting.Mode Downstairs Zone [2]","func":"const topic = msg.topic;  // preserve the topic\nif (msg.payload && msg.payload.zoneStates && msg.payload.zoneStates[\"2\"] && msg.payload.zoneStates[\"2\"].setting && msg.payload.zoneStates[\"2\"].setting.mode) {\n    msg.payload = msg.payload.zoneStates[\"2\"].setting.mode;\n} else {\n    msg.payload = msg.payload.zoneStates[\"2\"].setting.power;\n}\nmsg.topic = topic;        // restore the topic\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":4540,"y":1860,"wires":[["c300d481f179eed3"]]},{"id":"86c6dedad4e9fd26","type":"tado","z":"5fb50193cc6a2ad5","g":"a2f73de74c3ba609","acMode":"AUTO","apiCall":"getZoneStates","childlock":false,"configName":"83e627ce7e032c20","defaultTerminationTimeout":"","deviceId":"","endDate":"","fanSpeed":"AUTO","geoTracking":true,"homeId":"INSERT HOME ID","name":"","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","tariffId":"","tariffInCents":0,"temperature":"18","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","windowDetection":true,"windowDetectionTimeout":900,"year":"","zoneId":"","x":4260,"y":1860,"wires":[["53d83121935a92c9"]]},{"id":"e11b91fc93d564f4","type":"group","z":"5fb50193cc6a2ad5","g":"35cc0d0a876bf4e7","name":"Active Time","style":{"label":true},"nodes":["934c6b80fca23b89","73221f6caafae3f6","38099d25e4688e7d","361a73f6ec8d47c8","2368174710e861fe","15436ce83c6e7861","27056c600a9c9dce"],"x":4844,"y":1599,"w":212,"h":582},{"id":"934c6b80fca23b89","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"e11b91fc93d564f4","name":"","startTime":"05:30:00","endTime":"00:00:00","outputs":2,"x":4940,"y":1640,"wires":[["a265667cf248580b"],["441483402f10a97c"]]},{"id":"73221f6caafae3f6","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"e11b91fc93d564f4","name":"","startTime":"05:30:00","endTime":"00:00:00","outputs":2,"x":4940,"y":1840,"wires":[["931e554807baa9b7"],["15436ce83c6e7861"]]},{"id":"38099d25e4688e7d","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"e11b91fc93d564f4","name":"","startTime":"05:30:00","endTime":"00:00:00","outputs":2,"x":4940,"y":1940,"wires":[["9278acb4306b6e9d"],["27056c600a9c9dce"]]},{"id":"361a73f6ec8d47c8","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"e11b91fc93d564f4","name":"","startTime":"05:30:00","endTime":"00:00:00","outputs":2,"x":4940,"y":2140,"wires":[["53974d0d33be90dc"],["9278acb4306b6e9d"]]},{"id":"2368174710e861fe","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"e11b91fc93d564f4","name":"","startTime":"05:30:00","endTime":"00:00:00","outputs":2,"x":4940,"y":1740,"wires":[["441483402f10a97c"],["931e554807baa9b7"]]},{"id":"15436ce83c6e7861","type":"link out","z":"5fb50193cc6a2ad5","g":"e11b91fc93d564f4","name":"Liv Heating Program (Night/OFF)","mode":"link","links":["515f9edbc6e70862"],"x":5015,"y":1880,"wires":[]},{"id":"27056c600a9c9dce","type":"link out","z":"5fb50193cc6a2ad5","g":"e11b91fc93d564f4","name":"Liv Comfort Program (Night/OFF)","mode":"link","links":["515f9edbc6e70862"],"x":5015,"y":1980,"wires":[]},{"id":"f0bf9b5d1e6705e4","type":"group","z":"5fb50193cc6a2ad5","g":"35cc0d0a876bf4e7","name":"Indoor Check Temperature","style":{"label":true},"nodes":["30b41b134b40e6e3","4ff01ab5999923b6","6621eb59e6670126","cb252ee7b4e6c788","e4f251ab70dae232","1a5a5790f503c58b"],"x":2994,"y":1799,"w":352,"h":322},{"id":"30b41b134b40e6e3","type":"switch","z":"5fb50193cc6a2ad5","g":"f0bf9b5d1e6705e4","name":"Downstairs <= 23","property":"payload","propertyType":"msg","rules":[{"t":"lte","v":"23","vt":"str"},{"t":"gt","v":"23","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":3230,"y":1880,"wires":[["3b7d9f8401e947df"],["58c7b8464e30296e"]]},{"id":"4ff01ab5999923b6","type":"switch","z":"5fb50193cc6a2ad5","g":"f0bf9b5d1e6705e4","name":"Downstairs <= 22","property":"payload","propertyType":"msg","rules":[{"t":"lte","v":"22","vt":"str"},{"t":"gt","v":"22","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":3230,"y":2000,"wires":[["58c7b8464e30296e"],["467a0956907bb674"]]},{"id":"6621eb59e6670126","type":"switch","z":"5fb50193cc6a2ad5","g":"f0bf9b5d1e6705e4","name":"Downstairs <= 21","property":"payload","propertyType":"msg","rules":[{"t":"lte","v":"21","vt":"str"},{"t":"gt","v":"21","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":3230,"y":2080,"wires":[["467a0956907bb674"],["465eb5fe44442655"]]},{"id":"cb252ee7b4e6c788","type":"function","z":"5fb50193cc6a2ad5","g":"f0bf9b5d1e6705e4","name":"Data.Temperature Downstairs Zone [2]","func":"const topic = msg.topic;  // preserve the topic\nmsg.payload = msg.payload.zoneStates[\"2\"].sensorDataPoints.insideTemperature.celsius\nmsg.topic = topic;        // restore the topic\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":3170,"y":1840,"wires":[["30b41b134b40e6e3"]]},{"id":"e4f251ab70dae232","type":"function","z":"5fb50193cc6a2ad5","g":"f0bf9b5d1e6705e4","name":"Data.Temperature Downstairs Zone [2]","func":"const topic = msg.topic;  // preserve the topic\nmsg.payload = msg.payload.zoneStates[\"2\"].sensorDataPoints.insideTemperature.celsius\nmsg.topic = topic;        // restore the topic\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":3170,"y":1940,"wires":[["4ff01ab5999923b6"]]},{"id":"1a5a5790f503c58b","type":"function","z":"5fb50193cc6a2ad5","g":"f0bf9b5d1e6705e4","name":"Data.Temperature Downstairs Zone [2]","func":"const topic = msg.topic;  // preserve the topic\nmsg.payload = msg.payload.zoneStates[\"2\"].sensorDataPoints.insideTemperature.celsius\nmsg.topic = topic;        // restore the topic\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":3170,"y":2040,"wires":[["6621eb59e6670126"]]},{"id":"9055e8d79436663d","type":"group","z":"5fb50193cc6a2ad5","g":"35cc0d0a876bf4e7","name":"HEAT PUMP MODES DOWNSTAIRS USING SERVICE CALLS THROUGH HOME ASSISTANT","style":{"label":true},"nodes":["086b7250f03cf568","bde91fc194cc6b81","417fc926043019bd","27dfbdb0f36d02d6","3c48c24fa1c915b2","daf9a6226607d801"],"x":5128,"y":2253,"w":1057,"h":634},{"id":"086b7250f03cf568","type":"group","z":"5fb50193cc6a2ad5","g":"9055e8d79436663d","name":"COOL MODE DOWNSTAIRS (TTS Topic: door)","style":{"label":true,"fill":"#3f93cf","fill-opacity":"0.2"},"nodes":["d42654148176807a","b335ea7b71bf041f","bf4448379f5fad6a","d2ec05cfeddf2412"],"x":5154,"y":2779,"w":892,"h":82},{"id":"d42654148176807a","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"086b7250f03cf568","name":"Down HVAC 26","server":"","version":7,"debugenabled":false,"action":"climate.set_temperature","floorId":[],"areaId":[],"deviceId":["eaa527238407b25def1f7d8eb7864ce1"],"entityId":["climate.air_conditioning_downstairs"],"labelId":[],"data":"{\"temperature\":\"26\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"climate","service":"set_temperature","x":5520,"y":2820,"wires":[["bf4448379f5fad6a"]]},{"id":"b335ea7b71bf041f","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"086b7250f03cf568","name":"Down HVAC Cool","server":"","version":7,"debugenabled":false,"action":"climate.set_hvac_mode","floorId":[],"areaId":[],"deviceId":["eaa527238407b25def1f7d8eb7864ce1"],"entityId":["climate.air_conditioning_downstairs"],"labelId":[],"data":"{\"hvac_mode\":\"cool\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"climate","service":"set_hvac_mode","x":5270,"y":2820,"wires":[["d42654148176807a"]]},{"id":"bf4448379f5fad6a","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"086b7250f03cf568","name":"","startTime":"05:55:00","endTime":"21:00:00","outputs":2,"x":5730,"y":2820,"wires":[["d2ec05cfeddf2412"],[]]},{"id":"d2ec05cfeddf2412","type":"switch","z":"5fb50193cc6a2ad5","g":"086b7250f03cf568","name":"msg.topic2","property":"topic2","propertyType":"msg","rules":[{"t":"eq","v":"check","vt":"str"},{"t":"eq","v":"door","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":5950,"y":2820,"wires":[[],[]]},{"id":"bde91fc194cc6b81","type":"group","z":"5fb50193cc6a2ad5","g":"9055e8d79436663d","name":"HEAT MODE 21 DOWNSTAIRS (TTS Topic: door)","style":{"label":true,"fill":"#ff7f7f","fill-opacity":"0.2"},"nodes":["5e54fbf1bd3a37e0","a5b509473860b821","1015329cf9736905","fff640b7ecf702df"],"x":5154,"y":2379,"w":892,"h":82},{"id":"5e54fbf1bd3a37e0","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"bde91fc194cc6b81","name":"","startTime":"05:55:00","endTime":"21:00:00","outputs":2,"x":5730,"y":2420,"wires":[["a5b509473860b821"],[]]},{"id":"a5b509473860b821","type":"switch","z":"5fb50193cc6a2ad5","g":"bde91fc194cc6b81","name":"msg.topic2","property":"topic2","propertyType":"msg","rules":[{"t":"eq","v":"check","vt":"str"},{"t":"eq","v":"door","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":5950,"y":2420,"wires":[[],[]]},{"id":"1015329cf9736905","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"bde91fc194cc6b81","name":"Down HVAC 22","server":"","version":7,"debugenabled":false,"action":"climate.set_temperature","floorId":[],"areaId":[],"deviceId":["eaa527238407b25def1f7d8eb7864ce1"],"entityId":["climate.air_conditioning_downstairs"],"labelId":[],"data":"{\"temperature\":\"22\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"climate","service":"set_temperature","x":5520,"y":2420,"wires":[["5e54fbf1bd3a37e0"]]},{"id":"fff640b7ecf702df","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"bde91fc194cc6b81","name":"Down HVAC Heat","server":"","version":7,"debugenabled":false,"action":"climate.set_hvac_mode","floorId":[],"areaId":[],"deviceId":["eaa527238407b25def1f7d8eb7864ce1"],"entityId":["climate.air_conditioning_downstairs"],"labelId":[],"data":"{\"hvac_mode\":\"heat\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"climate","service":"set_hvac_mode","x":5270,"y":2420,"wires":[["1015329cf9736905"]]},{"id":"417fc926043019bd","type":"group","z":"5fb50193cc6a2ad5","g":"9055e8d79436663d","name":"HEAT MODE 19 DOWNSTAIRS (TTS Topic: door)","style":{"label":true,"fill":"#ffbfbf","fill-opacity":"0.2"},"nodes":["f4e11f61dbc0ad10","048e0abac7188719","118ad130d2b2c0f9","356110284e03dbe9"],"x":5154,"y":2479,"w":892,"h":82},{"id":"f4e11f61dbc0ad10","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"417fc926043019bd","name":"","startTime":"05:55:00","endTime":"21:00:00","outputs":2,"x":5730,"y":2520,"wires":[["048e0abac7188719"],[]]},{"id":"048e0abac7188719","type":"switch","z":"5fb50193cc6a2ad5","g":"417fc926043019bd","name":"msg.topic2","property":"topic2","propertyType":"msg","rules":[{"t":"eq","v":"check","vt":"str"},{"t":"eq","v":"door","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":5950,"y":2520,"wires":[[],[]]},{"id":"118ad130d2b2c0f9","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"417fc926043019bd","name":"Down HVAC 21","server":"","version":7,"debugenabled":false,"action":"climate.set_temperature","floorId":[],"areaId":[],"deviceId":["eaa527238407b25def1f7d8eb7864ce1"],"entityId":["climate.air_conditioning_downstairs"],"labelId":[],"data":"{\"temperature\":\"21\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"climate","service":"set_temperature","x":5520,"y":2520,"wires":[["f4e11f61dbc0ad10"]]},{"id":"356110284e03dbe9","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"417fc926043019bd","name":"Down HVAC Heat","server":"","version":7,"debugenabled":false,"action":"climate.set_hvac_mode","floorId":[],"areaId":[],"deviceId":["eaa527238407b25def1f7d8eb7864ce1"],"entityId":["climate.air_conditioning_downstairs"],"labelId":[],"data":"{\"hvac_mode\":\"heat\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"climate","service":"set_hvac_mode","x":5270,"y":2520,"wires":[["118ad130d2b2c0f9"]]},{"id":"27dfbdb0f36d02d6","type":"group","z":"5fb50193cc6a2ad5","g":"9055e8d79436663d","name":"HEAT MODE 23 DOWNSTAIRS (TTS Topic: door)","style":{"label":true,"fill":"#ff3f3f","fill-opacity":"0.2"},"nodes":["6396c334afa5638f","35e2a053a94b8afe","15e2a69864eabddd","1985900cddaa1c4b"],"x":5154,"y":2279,"w":892,"h":82},{"id":"6396c334afa5638f","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"27dfbdb0f36d02d6","name":"","startTime":"05:55:00","endTime":"21:00:00","outputs":2,"x":5730,"y":2320,"wires":[["35e2a053a94b8afe"],[]]},{"id":"35e2a053a94b8afe","type":"switch","z":"5fb50193cc6a2ad5","g":"27dfbdb0f36d02d6","name":"msg.topic2","property":"topic2","propertyType":"msg","rules":[{"t":"eq","v":"check","vt":"str"},{"t":"eq","v":"door","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":5950,"y":2320,"wires":[[],[]]},{"id":"15e2a69864eabddd","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"27dfbdb0f36d02d6","name":"Down HVAC 23","server":"","version":7,"debugenabled":false,"action":"climate.set_temperature","floorId":[],"areaId":[],"deviceId":["eaa527238407b25def1f7d8eb7864ce1"],"entityId":["climate.air_conditioning_downstairs"],"labelId":[],"data":"{\"temperature\":\"23\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"climate","service":"set_temperature","x":5520,"y":2320,"wires":[["6396c334afa5638f"]]},{"id":"1985900cddaa1c4b","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"27dfbdb0f36d02d6","name":"Down HVAC Heat","server":"","version":7,"debugenabled":false,"action":"climate.set_hvac_mode","floorId":[],"areaId":[],"deviceId":["eaa527238407b25def1f7d8eb7864ce1"],"entityId":["climate.air_conditioning_downstairs"],"labelId":[],"data":"{\"hvac_mode\":\"heat\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"climate","service":"set_hvac_mode","x":5270,"y":2320,"wires":[["15e2a69864eabddd"]]},{"id":"3c48c24fa1c915b2","type":"group","z":"5fb50193cc6a2ad5","g":"9055e8d79436663d","name":"DRY MODE DOWNSTAIRS - TADO API CALL TO SET A/C - (SERVICE CALL TO  UPDATE HA THERMOSTAT CARD climate.set_hvac_mode) (TTS Topic: door)","style":{"label":true,"fill":"#ffff00","fill-opacity":"0.2"},"nodes":["a2357d4c107250bb","0192302e0f1cf9ab","380b9991205863ba","13a8fb7c9d3fe1f5"],"x":5154,"y":2579,"w":1005,"h":82},{"id":"a2357d4c107250bb","type":"switch","z":"5fb50193cc6a2ad5","g":"3c48c24fa1c915b2","name":"msg.topic2","property":"topic2","propertyType":"msg","rules":[{"t":"eq","v":"check","vt":"str"},{"t":"eq","v":"door","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":5950,"y":2620,"wires":[[],[]]},{"id":"0192302e0f1cf9ab","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"3c48c24fa1c915b2","name":"","startTime":"05:55:00","endTime":"21:00:00","outputs":2,"x":5730,"y":2620,"wires":[["a2357d4c107250bb"],[]]},{"id":"380b9991205863ba","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"3c48c24fa1c915b2","name":"Down HVAC Dry","server":"","version":7,"debugenabled":false,"action":"climate.set_hvac_mode","floorId":[],"areaId":[],"deviceId":["eaa527238407b25def1f7d8eb7864ce1"],"entityId":["climate.air_conditioning_downstairs"],"labelId":[],"data":"{\"hvac_mode\":\"dry\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"climate","service":"set_hvac_mode","x":5260,"y":2620,"wires":[["13a8fb7c9d3fe1f5"]]},{"id":"13a8fb7c9d3fe1f5","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"3c48c24fa1c915b2","name":"Down HVAC 24","server":"","version":7,"debugenabled":false,"action":"climate.set_temperature","floorId":[],"areaId":[],"deviceId":["eaa527238407b25def1f7d8eb7864ce1"],"entityId":["climate.air_conditioning_downstairs"],"labelId":[],"data":"{\"temperature\":\"24\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"climate","service":"set_temperature","x":5520,"y":2620,"wires":[["0192302e0f1cf9ab"]]},{"id":"daf9a6226607d801","type":"group","z":"5fb50193cc6a2ad5","g":"9055e8d79436663d","name":"OFF MODE DOWNSTAIRS (Uses the schedule configured in the app to OFF for HOME Mode) (TTS Topic: door)","style":{"label":true,"fill":"#000000","fill-opacity":"0.1"},"nodes":["cc8aec42633169ab","7fd1f658726749fd","19d8d6736c2c3cf3"],"x":5154,"y":2679,"w":892,"h":82},{"id":"cc8aec42633169ab","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"daf9a6226607d801","name":"","startTime":"05:55:00","endTime":"21:00:00","outputs":2,"x":5730,"y":2720,"wires":[["7fd1f658726749fd"],[]]},{"id":"7fd1f658726749fd","type":"switch","z":"5fb50193cc6a2ad5","g":"daf9a6226607d801","name":"msg.topic2","property":"topic2","propertyType":"msg","rules":[{"t":"eq","v":"check","vt":"str"},{"t":"eq","v":"door","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":5950,"y":2720,"wires":[[],[]]},{"id":"19d8d6736c2c3cf3","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"daf9a6226607d801","name":"Down HVAC OFF","server":"","version":7,"debugenabled":false,"action":"climate.turn_off","floorId":[],"areaId":[],"deviceId":["eaa527238407b25def1f7d8eb7864ce1"],"entityId":["climate.air_conditioning_downstairs"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"climate","service":"turn_off","x":5270,"y":2720,"wires":[["cc8aec42633169ab"]]},{"id":"93f73edb692f52ec","type":"group","z":"5fb50193cc6a2ad5","g":"35cc0d0a876bf4e7","name":"HEAT PUMP MODES DOWNSTAIRS - USING TADO API CALLS AND - HA SERVICE CALLS TO SET HA THERMOSTAT","style":{"label":true},"nodes":["d3c75eaf2a50f221","3e3b04e3a1a5e4e4","375fe9bb5f5ca348","17902f0d3ae6ae0e","c33aa1546ea46dfe","08b90c2b2dd7b2d8","44855b6d626a7d6f"],"x":5128,"y":1553,"w":1484,"h":634},{"id":"d3c75eaf2a50f221","type":"group","z":"5fb50193cc6a2ad5","g":"93f73edb692f52ec","name":"COOL MODE DOWNSTAIRS  - TADO API CALL TO SET A/C - (SERVICE CALL TO  UPDATE HA THERMOSTAT CARD climate.set_hvac_mode) (TTS Topic: door)","style":{"label":true,"fill":"#3f93cf","fill-opacity":"0.2"},"nodes":["f15080db79339f4b","882e346c54710f5b","53974d0d33be90dc","ee56d8e190ac8aa5"],"x":5474,"y":2079,"w":1112,"h":82},{"id":"f15080db79339f4b","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"d3c75eaf2a50f221","name":"","startTime":"05:55:00","endTime":"21:00:00","outputs":2,"x":6310,"y":2120,"wires":[["882e346c54710f5b"],[]]},{"id":"882e346c54710f5b","type":"switch","z":"5fb50193cc6a2ad5","g":"d3c75eaf2a50f221","name":"msg.topic2","property":"topic2","propertyType":"msg","rules":[{"t":"eq","v":"check","vt":"str"},{"t":"eq","v":"door","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":6490,"y":2120,"wires":[[],[]]},{"id":"53974d0d33be90dc","type":"tado","z":"5fb50193cc6a2ad5","g":"d3c75eaf2a50f221","acMode":"COOL","apiCall":"setZoneOverlay","childlock":false,"configName":"83e627ce7e032c20","defaultTerminationTimeout":900,"defaultTerminationType":"TADO_MODE","deviceId":"","endDate":"","fanSpeed":"AUTO","geoTracking":true,"homeId":"INSERT HOME ID","horizontalSwing":"OFF","name":"Down Cool 25 [setZoneOverlay]  API Call","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","tariffId":"","tariffInCents":0,"temperature":"25","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","verticalSwing":"OFF","windowDetection":true,"windowDetectionTimeout":900,"year":"","zoneId":"2","x":5660,"y":2120,"wires":[["ee56d8e190ac8aa5"]]},{"id":"ee56d8e190ac8aa5","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"d3c75eaf2a50f221","name":"Down HVAC Cool","server":"","version":7,"debugenabled":false,"action":"climate.set_hvac_mode","floorId":[],"areaId":[],"deviceId":["eaa527238407b25def1f7d8eb7864ce1"],"entityId":["climate.air_conditioning_downstairs"],"labelId":[],"data":"{\"hvac_mode\":\"cool\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"climate","service":"set_hvac_mode","x":6050,"y":2120,"wires":[["f15080db79339f4b"]]},{"id":"3e3b04e3a1a5e4e4","type":"group","z":"5fb50193cc6a2ad5","g":"93f73edb692f52ec","name":"HEAT MODE 21 DOWNSTAIRS - TADO API CALL TO SET A/C - (SERVICE CALL TO  UPDATE HA THERMOSTAT CARD climate.set_hvac_mode) (TTS Topic: door)","style":{"label":true,"fill":"#ff7f7f","fill-opacity":"0.2"},"nodes":["1962e18c47b10861","cb91b1852662f617","441483402f10a97c","d760c3436784cfd3"],"x":5474,"y":1679,"w":1112,"h":82},{"id":"1962e18c47b10861","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"3e3b04e3a1a5e4e4","name":"","startTime":"05:55:00","endTime":"21:00:00","outputs":2,"x":6310,"y":1720,"wires":[["cb91b1852662f617"],[]]},{"id":"cb91b1852662f617","type":"switch","z":"5fb50193cc6a2ad5","g":"3e3b04e3a1a5e4e4","name":"msg.topic2","property":"topic2","propertyType":"msg","rules":[{"t":"eq","v":"check","vt":"str"},{"t":"eq","v":"door","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":6490,"y":1720,"wires":[[],[]]},{"id":"441483402f10a97c","type":"tado","z":"5fb50193cc6a2ad5","g":"3e3b04e3a1a5e4e4","acMode":"HEAT","apiCall":"setZoneOverlay","childlock":false,"configName":"83e627ce7e032c20","defaultTerminationTimeout":900,"defaultTerminationType":"TADO_MODE","deviceId":"","endDate":"","fanSpeed":"AUTO","geoTracking":true,"homeId":"INSERT HOME ID","horizontalSwing":"OFF","name":"Down Heat 22 [setZoneOverlay]  API Call","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","tariffId":"","tariffInCents":0,"temperature":"22","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","verticalSwing":"OFF","windowDetection":true,"windowDetectionTimeout":900,"year":"","zoneId":"2","x":5660,"y":1720,"wires":[["d760c3436784cfd3"]]},{"id":"d760c3436784cfd3","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"3e3b04e3a1a5e4e4","name":"Down HVAC Heat","server":"","version":7,"debugenabled":false,"action":"climate.set_hvac_mode","floorId":[],"areaId":[],"deviceId":["eaa527238407b25def1f7d8eb7864ce1"],"entityId":["climate.air_conditioning_downstairs"],"labelId":[],"data":"{\"hvac_mode\":\"heat\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"climate","service":"set_hvac_mode","x":6050,"y":1720,"wires":[["1962e18c47b10861"]]},{"id":"375fe9bb5f5ca348","type":"group","z":"5fb50193cc6a2ad5","g":"93f73edb692f52ec","name":"HEAT MODE 19 DOWNSTAIRS - TADO API CALL TO SET A/C - (SERVICE CALL TO  UPDATE HA THERMOSTAT CARD climate.set_hvac_mode) (TTS Topic: door)","style":{"label":true,"fill":"#ffbfbf","fill-opacity":"0.2"},"nodes":["a8c885c43c1d83c4","b3fe484da3a0ec08","931e554807baa9b7","c463e5c704fd8676"],"x":5474,"y":1779,"w":1112,"h":82},{"id":"a8c885c43c1d83c4","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"375fe9bb5f5ca348","name":"","startTime":"05:55:00","endTime":"21:00:00","outputs":2,"x":6310,"y":1820,"wires":[["b3fe484da3a0ec08"],[]]},{"id":"b3fe484da3a0ec08","type":"switch","z":"5fb50193cc6a2ad5","g":"375fe9bb5f5ca348","name":"msg.topic2","property":"topic2","propertyType":"msg","rules":[{"t":"eq","v":"check","vt":"str"},{"t":"eq","v":"door","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":6490,"y":1820,"wires":[[],[]]},{"id":"931e554807baa9b7","type":"tado","z":"5fb50193cc6a2ad5","g":"375fe9bb5f5ca348","acMode":"HEAT","apiCall":"setZoneOverlay","childlock":false,"configName":"83e627ce7e032c20","defaultTerminationTimeout":900,"defaultTerminationType":"TADO_MODE","deviceId":"","endDate":"","fanSpeed":"AUTO","geoTracking":true,"homeId":"INSERT HOME ID","horizontalSwing":"OFF","name":"Down Heat 21 [setZoneOverlay]  API Call","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","tariffId":"","tariffInCents":0,"temperature":"21","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","verticalSwing":"OFF","windowDetection":true,"windowDetectionTimeout":900,"year":"","zoneId":"2","x":5660,"y":1820,"wires":[["c463e5c704fd8676"]]},{"id":"c463e5c704fd8676","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"375fe9bb5f5ca348","name":"Down HVAC Heat","server":"","version":7,"debugenabled":false,"action":"climate.set_hvac_mode","floorId":[],"areaId":[],"deviceId":["eaa527238407b25def1f7d8eb7864ce1"],"entityId":["climate.air_conditioning_downstairs"],"labelId":[],"data":"{\"hvac_mode\":\"heat\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"climate","service":"set_hvac_mode","x":6050,"y":1820,"wires":[["a8c885c43c1d83c4"]]},{"id":"17902f0d3ae6ae0e","type":"group","z":"5fb50193cc6a2ad5","g":"93f73edb692f52ec","name":"OFF MODE DOWNSTAIRS (Uses the schedule configured in the app to OFF for HOME Mode) (TTS Topic: door)","style":{"label":true,"fill":"#000000","fill-opacity":"0.1"},"nodes":["09f22b54a3057c9f","1749994a1bcdbe93","67d0d99e1783e85f","4436c9aa0499b361"],"x":5474,"y":1979,"w":1112,"h":82},{"id":"09f22b54a3057c9f","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"17902f0d3ae6ae0e","name":"","startTime":"05:55:00","endTime":"21:00:00","outputs":2,"x":6310,"y":2020,"wires":[["1749994a1bcdbe93"],[]]},{"id":"1749994a1bcdbe93","type":"switch","z":"5fb50193cc6a2ad5","g":"17902f0d3ae6ae0e","name":"msg.topic2","property":"topic2","propertyType":"msg","rules":[{"t":"eq","v":"check","vt":"str"},{"t":"eq","v":"door","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":6490,"y":2020,"wires":[[],[]]},{"id":"67d0d99e1783e85f","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"17902f0d3ae6ae0e","name":"Down HVAC OFF","server":"","version":7,"debugenabled":false,"action":"climate.turn_off","floorId":[],"areaId":[],"deviceId":["eaa527238407b25def1f7d8eb7864ce1"],"entityId":["climate.air_conditioning_downstairs"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"climate","service":"turn_off","x":6050,"y":2020,"wires":[["09f22b54a3057c9f"]]},{"id":"4436c9aa0499b361","type":"tado","z":"5fb50193cc6a2ad5","g":"17902f0d3ae6ae0e","acMode":"COOL","apiCall":"setZoneOverlay","childlock":false,"configName":"83e627ce7e032c20","defaultTerminationTimeout":900,"defaultTerminationType":"TADO_MODE","deviceId":"","endDate":"","fanSpeed":"AUTO","geoTracking":true,"homeId":"INSERT HOME ID","horizontalSwing":"OFF","name":"Down OFF [setZoneOverlay] API Call - Manual","openWindowMode":true,"power":"off","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","tariffId":"","tariffInCents":0,"temperature":"25","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","verticalSwing":"OFF","windowDetection":true,"windowDetectionTimeout":900,"year":"","zoneId":"2","x":5680,"y":2020,"wires":[["67d0d99e1783e85f"]]},{"id":"c33aa1546ea46dfe","type":"group","z":"5fb50193cc6a2ad5","g":"93f73edb692f52ec","name":"Clear TADO Timer/Manual Overlay","style":{"label":true},"nodes":["2fcacacd560e8cb1"],"x":5154,"y":1979,"w":292,"h":82},{"id":"2fcacacd560e8cb1","type":"tado","z":"5fb50193cc6a2ad5","g":"c33aa1546ea46dfe","acMode":"DRY","apiCall":"clearZoneOverlay","childlock":false,"configName":"83e627ce7e032c20","defaultTerminationTimeout":900,"defaultTerminationType":"TADO_MODE","deviceId":"","endDate":"","fanSpeed":"AUTO","geoTracking":true,"homeId":"INSERT HOME ID","horizontalSwing":"OFF","name":"Down (2) [ClearZoneOverlay]","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","tariffId":"","tariffInCents":0,"temperature":"","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","verticalSwing":"OFF","windowDetection":true,"windowDetectionTimeout":900,"year":"","zoneId":"2","x":5300,"y":2020,"wires":[["4436c9aa0499b361"]]},{"id":"08b90c2b2dd7b2d8","type":"group","z":"5fb50193cc6a2ad5","g":"93f73edb692f52ec","name":"HEAT MODE 23 DOWNSTAIRS - TADO API CALL TO SET A/C - (SERVICE CALL TO  UPDATE HA THERMOSTAT CARD climate.set_hvac_mode) (TTS Topic: door)","style":{"label":true,"fill":"#ff3f3f","fill-opacity":"0.2"},"nodes":["ef6da48459021dde","80e6a4f6a71774d7","a265667cf248580b","e49d3504cf0024bf"],"x":5474,"y":1579,"w":1112,"h":82},{"id":"ef6da48459021dde","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"08b90c2b2dd7b2d8","name":"","startTime":"05:55:00","endTime":"21:00:00","outputs":2,"x":6310,"y":1620,"wires":[["80e6a4f6a71774d7"],[]]},{"id":"80e6a4f6a71774d7","type":"switch","z":"5fb50193cc6a2ad5","g":"08b90c2b2dd7b2d8","name":"msg.topic2","property":"topic2","propertyType":"msg","rules":[{"t":"eq","v":"check","vt":"str"},{"t":"eq","v":"door","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":6490,"y":1620,"wires":[[],[]]},{"id":"a265667cf248580b","type":"tado","z":"5fb50193cc6a2ad5","g":"08b90c2b2dd7b2d8","acMode":"HEAT","apiCall":"setZoneOverlay","childlock":false,"configName":"83e627ce7e032c20","defaultTerminationTimeout":900,"defaultTerminationType":"TADO_MODE","deviceId":"","endDate":"","fanSpeed":"AUTO","geoTracking":true,"homeId":"INSERT HOME ID","horizontalSwing":"OFF","name":"Down Heat 23 [setZoneOverlay]  API Call","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","tariffId":"","tariffInCents":0,"temperature":"23","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","verticalSwing":"OFF","windowDetection":true,"windowDetectionTimeout":900,"year":"","zoneId":"2","x":5660,"y":1620,"wires":[["e49d3504cf0024bf"]]},{"id":"e49d3504cf0024bf","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"08b90c2b2dd7b2d8","name":"Down HVAC Heat","server":"","version":7,"debugenabled":false,"action":"climate.set_hvac_mode","floorId":[],"areaId":[],"deviceId":["eaa527238407b25def1f7d8eb7864ce1"],"entityId":["climate.air_conditioning_downstairs"],"labelId":[],"data":"{\"hvac_mode\":\"heat\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"climate","service":"set_hvac_mode","x":6050,"y":1620,"wires":[["ef6da48459021dde"]]},{"id":"44855b6d626a7d6f","type":"group","z":"5fb50193cc6a2ad5","g":"93f73edb692f52ec","name":"DRY MODE DOWNSTAIRS - TADO API CALL TO SET A/C - (SERVICE CALL TO  UPDATE HA THERMOSTAT CARD climate.set_hvac_mode) (TTS Topic: door)","style":{"label":true,"fill":"#ffff00","fill-opacity":"0.2"},"nodes":["85d60ea92ea84417","3123aa4006cd982d","9278acb4306b6e9d","f8b71338e7242c6b"],"x":5474,"y":1879,"w":1112,"h":82},{"id":"85d60ea92ea84417","type":"switch","z":"5fb50193cc6a2ad5","g":"44855b6d626a7d6f","name":"msg.topic2","property":"topic2","propertyType":"msg","rules":[{"t":"eq","v":"check","vt":"str"},{"t":"eq","v":"door","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":6490,"y":1920,"wires":[[],[]]},{"id":"3123aa4006cd982d","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"44855b6d626a7d6f","name":"","startTime":"05:55:00","endTime":"21:00:00","outputs":2,"x":6310,"y":1920,"wires":[["85d60ea92ea84417"],[]]},{"id":"9278acb4306b6e9d","type":"tado","z":"5fb50193cc6a2ad5","g":"44855b6d626a7d6f","acMode":"DRY","apiCall":"setZoneOverlay","childlock":false,"configName":"83e627ce7e032c20","defaultTerminationTimeout":900,"defaultTerminationType":"TADO_MODE","deviceId":"","endDate":"","fanSpeed":"AUTO","geoTracking":true,"homeId":"INSERT HOME ID","horizontalSwing":"OFF","name":"Down Dry Mode [setZoneOverlay]  API Call","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","tariffId":"","tariffInCents":0,"temperature":"24","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","verticalSwing":"OFF","windowDetection":true,"windowDetectionTimeout":900,"year":"","zoneId":"2","x":5670,"y":1920,"wires":[["f8b71338e7242c6b"]]},{"id":"f8b71338e7242c6b","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"44855b6d626a7d6f","name":"Down HVAC Dry","server":"","version":7,"debugenabled":false,"action":"climate.set_hvac_mode","floorId":[],"areaId":[],"deviceId":["eaa527238407b25def1f7d8eb7864ce1"],"entityId":["climate.air_conditioning_downstairs"],"labelId":[],"data":"{\"hvac_mode\":\"dry\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"climate","service":"set_hvac_mode","x":6040,"y":1920,"wires":[["3123aa4006cd982d"]]},{"id":"c5e3899a37f93bae","type":"link out","z":"5fb50193cc6a2ad5","g":"35cc0d0a876bf4e7","name":"TADO Down Cooling Program (Comfy/OFF)","mode":"link","links":["c112dfd37781f285"],"x":2715,"y":2760,"wires":[]},{"id":"24441776b84a6954","type":"group","z":"5fb50193cc6a2ad5","g":"35cc0d0a876bf4e7","name":"Check Inside Dewpoint to set Heating Program DOWNSTAIRS","style":{"label":true,"fill":"#ff0000"},"nodes":["946fce7fdd85fbd4","235be3cf0e7705a3"],"x":2144,"y":2259,"w":592,"h":177},{"id":"946fce7fdd85fbd4","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"24441776b84a6954","name":"DEWPOINT DOWNSTAIRS","server":"","version":3,"outputs":2,"halt_if":"-20","halt_if_type":"num","halt_if_compare":"gt","entity_id":"sensor.dewpoint_downstairs","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":2290,"y":2300,"wires":[["235be3cf0e7705a3"],[]]},{"id":"235be3cf0e7705a3","type":"switch","z":"5fb50193cc6a2ad5","g":"24441776b84a6954","name":"Dewpoint (<10.0 - Dry)(10.1-12.79 - Pleas)(12.8-15.49 - Comf)(>15.5 Sticky))","property":"payload","propertyType":"msg","rules":[{"t":"btwn","v":"-20","vt":"num","v2":"10","v2t":"num"},{"t":"btwn","v":"10.1","vt":"num","v2":"12.79","v2t":"num"},{"t":"btwn","v":"12.8","vt":"num","v2":"15.49","v2t":"num"},{"t":"btwn","v":"15.5","vt":"num","v2":"50","v2t":"num"}],"checkall":"true","repair":false,"outputs":4,"x":2440,"y":2380,"wires":[["3d0bd35c30452c9c"],["fccb449f25cd59b1"],["33c3bcc4bfd2c68b"],["d3022db7eebcadbf"]]},{"id":"6f15733de9f19b9a","type":"group","z":"5fb50193cc6a2ad5","g":"35cc0d0a876bf4e7","name":"Check Inside Dewpoint to set Comfort Program DOWNSTAIRS","style":{"label":true,"fill":"#92d04f"},"nodes":["fd3ec93ac1488b42","b17f9f4de3529ef0"],"x":2144,"y":2459,"w":592,"h":177},{"id":"fd3ec93ac1488b42","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"6f15733de9f19b9a","name":"DEWPOINT DOWNSTAIRS","server":"","version":3,"outputs":2,"halt_if":"0","halt_if_type":"num","halt_if_compare":"gt","entity_id":"sensor.dewpoint_downstairs","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":2290,"y":2500,"wires":[["b17f9f4de3529ef0"],[]]},{"id":"b17f9f4de3529ef0","type":"switch","z":"5fb50193cc6a2ad5","g":"6f15733de9f19b9a","name":"Dewpoint (<10.0 - Dry)(10.1-12.79 - Pleas)(12.8-15.49 - Comf)(>15.5 Sticky))","property":"payload","propertyType":"msg","rules":[{"t":"btwn","v":"-20","vt":"num","v2":"10","v2t":"num"},{"t":"btwn","v":"10.1","vt":"num","v2":"12.79","v2t":"num"},{"t":"btwn","v":"12.8","vt":"num","v2":"15.49","v2t":"num"},{"t":"btwn","v":"15.5","vt":"num","v2":"50","v2t":"num"}],"checkall":"true","repair":false,"outputs":4,"x":2440,"y":2580,"wires":[["904caedf350a312c"],["594079441157ef44"],["d3022db7eebcadbf"],["e9f6bf430bb7c0ee"]]},{"id":"5727a428e863615c","type":"group","z":"5fb50193cc6a2ad5","g":"35cc0d0a876bf4e7","name":"Check Inside Dewpoint to set Cooling Program DOWNSTAIRS","style":{"label":true,"fill":"#3f93cf"},"nodes":["97706539517c04f2","26ebc9c0cc7f18d4"],"x":2144,"y":2659,"w":512,"h":184.5},{"id":"97706539517c04f2","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"5727a428e863615c","name":"DEWPOINT DOWNSTAIRS","server":"","version":3,"outputs":2,"halt_if":"0","halt_if_type":"num","halt_if_compare":"gt","entity_id":"sensor.dewpoint_downstairs","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":2290,"y":2700,"wires":[["26ebc9c0cc7f18d4"],[]]},{"id":"26ebc9c0cc7f18d4","type":"switch","z":"5fb50193cc6a2ad5","g":"5727a428e863615c","name":"Dewpoint (<15.49 - Comf)(15.5-18.39 - Sticky)(>18.4 - Muggy)","property":"payload","propertyType":"msg","rules":[{"t":"btwn","v":"-20","vt":"num","v2":"10","v2t":"num"},{"t":"btwn","v":"10.1","vt":"num","v2":"12.79","v2t":"num"},{"t":"btwn","v":"12.8","vt":"num","v2":"15.49","v2t":"num"},{"t":"btwn","v":"15.5","vt":"num","v2":"18.39","v2t":"num"},{"t":"btwn","v":"18.4","vt":"num","v2":"50","v2t":"num"}],"checkall":"true","repair":false,"outputs":5,"x":2400,"y":2780,"wires":[["c5e3899a37f93bae"],["c5e3899a37f93bae"],["c5e3899a37f93bae"],["e9f6bf430bb7c0ee"],["2492d94c63b53f6c"]]},{"id":"96380ca6c62796d1","type":"group","z":"5fb50193cc6a2ad5","g":"35cc0d0a876bf4e7","name":"Active Time","style":{"label":true},"nodes":["a10464e759902260","ea6424075eed10be","7dd27f4fc2e01bb7","c3a0226f259053d4","118330440e5cd271","d9f841710430930a","de5601b0639f951b"],"x":4854,"y":2279,"w":212,"h":582},{"id":"a10464e759902260","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"96380ca6c62796d1","name":"","startTime":"05:30:00","endTime":"00:00:00","outputs":2,"x":4950,"y":2320,"wires":[["1985900cddaa1c4b"],["fff640b7ecf702df"]]},{"id":"ea6424075eed10be","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"96380ca6c62796d1","name":"","startTime":"05:30:00","endTime":"00:00:00","outputs":2,"x":4950,"y":2520,"wires":[["356110284e03dbe9"],["d9f841710430930a"]]},{"id":"7dd27f4fc2e01bb7","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"96380ca6c62796d1","name":"","startTime":"05:30:00","endTime":"00:00:00","outputs":2,"x":4950,"y":2620,"wires":[["380b9991205863ba"],["de5601b0639f951b"]]},{"id":"c3a0226f259053d4","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"96380ca6c62796d1","name":"","startTime":"05:30:00","endTime":"00:00:00","outputs":2,"x":4950,"y":2820,"wires":[["b335ea7b71bf041f"],["380b9991205863ba"]]},{"id":"118330440e5cd271","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"96380ca6c62796d1","name":"","startTime":"05:30:00","endTime":"00:00:00","outputs":2,"x":4950,"y":2420,"wires":[["fff640b7ecf702df"],["356110284e03dbe9"]]},{"id":"d9f841710430930a","type":"link out","z":"5fb50193cc6a2ad5","g":"96380ca6c62796d1","name":"TADO Down Heating Program (Night/OFF)","mode":"link","links":["c112dfd37781f285"],"x":5025,"y":2560,"wires":[]},{"id":"de5601b0639f951b","type":"link out","z":"5fb50193cc6a2ad5","g":"96380ca6c62796d1","name":"TADO Down Comfort Program (Night/OFF)","mode":"link","links":["c112dfd37781f285"],"x":5025,"y":2660,"wires":[]},{"id":"076d08c06c3b1727","type":"link out","z":"5fb50193cc6a2ad5","g":"35cc0d0a876bf4e7","name":"TADO Down Comfort Program (Comf)","mode":"link","links":["c112dfd37781f285"],"x":3045,"y":2680,"wires":[]},{"id":"2de55c8aa201987b","type":"inject","z":"5fb50193cc6a2ad5","g":"35cc0d0a876bf4e7","name":"Test","props":[{"p":"payload"},{"p":"topic2","v":"door","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":5210,"y":2220,"wires":[["0215cece076baf97"]]},{"id":"0215cece076baf97","type":"link out","z":"5fb50193cc6a2ad5","g":"35cc0d0a876bf4e7","name":"TEST OUT","mode":"link","links":["2926bf43d0347873"],"x":5325,"y":2220,"wires":[]},{"id":"087dd5e58fc9b08d","type":"group","z":"5fb50193cc6a2ad5","g":"efa7ba0cd44d77f9","name":"Living Room","style":{"label":true},"nodes":["a87fc938aef30c01","145cf9dd310cc6e1","47a03478c3ca0936","2992f68cfb6f5c51","5d70172db147875c","bd042d33ae0b21d7","34159a70ce093a6b","c80d0c896c588cab","6b92e40bf31f6b7d","7599ea43ce1f41ed","754a415d107b3cec","34bfbcec2d579f8e","f7ec128dc8f3c659","8f78a2259b52cd0a","31e80b5425bff681","a3de13b84f99e239","807a123fbc77b81e","f1c3afcc82667e3a","eb0e18a5c656f903","30679304285bae5a","f3dc5e6e1109d0cd"],"x":2108,"y":67,"w":4730,"h":1386},{"id":"a87fc938aef30c01","type":"link out","z":"5fb50193cc6a2ad5","g":"087dd5e58fc9b08d","name":"Liv Comfort Program (Comfy/OFF)","mode":"link","links":["e879d85ab145a8b4"],"x":3405,"y":660,"wires":[]},{"id":"145cf9dd310cc6e1","type":"link out","z":"5fb50193cc6a2ad5","g":"087dd5e58fc9b08d","name":"Liv Cooling Program (Comfy/OFF)","mode":"link","links":["e879d85ab145a8b4"],"x":2725,"y":640,"wires":[]},{"id":"47a03478c3ca0936","type":"tado","z":"5fb50193cc6a2ad5","g":"087dd5e58fc9b08d","acMode":"AUTO","apiCall":"getZoneStates","childlock":false,"configName":"83e627ce7e032c20","defaultTerminationTimeout":"","deviceId":"","endDate":"","fanSpeed":"AUTO","geoTracking":true,"homeId":"INSERT HOME ID","name":"","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","tariffId":"","tariffInCents":0,"temperature":"18","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","windowDetection":true,"windowDetectionTimeout":900,"year":"","zoneId":"","x":2900,"y":400,"wires":[["3d9007d415c868a7"]]},{"id":"2992f68cfb6f5c51","type":"tado","z":"5fb50193cc6a2ad5","g":"087dd5e58fc9b08d","acMode":"AUTO","apiCall":"getZoneStates","childlock":false,"configName":"83e627ce7e032c20","defaultTerminationTimeout":"","deviceId":"","endDate":"","fanSpeed":"AUTO","geoTracking":true,"homeId":"INSERT HOME ID","name":"","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","tariffId":"","tariffInCents":0,"temperature":"18","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","windowDetection":true,"windowDetectionTimeout":900,"year":"","zoneId":"","x":2900,"y":580,"wires":[["57e811b9667c4350"]]},{"id":"5d70172db147875c","type":"tado","z":"5fb50193cc6a2ad5","g":"087dd5e58fc9b08d","acMode":"AUTO","apiCall":"getZoneStates","childlock":false,"configName":"83e627ce7e032c20","defaultTerminationTimeout":"","deviceId":"","endDate":"","fanSpeed":"AUTO","geoTracking":true,"homeId":"INSERT HOME ID","name":"","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","tariffId":"","tariffInCents":0,"temperature":"18","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","windowDetection":true,"windowDetectionTimeout":900,"year":"","zoneId":"","x":2900,"y":500,"wires":[["85e7e87b456d676e"]]},{"id":"bd042d33ae0b21d7","type":"group","z":"5fb50193cc6a2ad5","g":"087dd5e58fc9b08d","name":"Check Inside Dewpoint to set Heating Program LIVING ROOM","style":{"label":true,"fill":"#ff0000"},"nodes":["f4bc63e9c12c5b3d","12e87c7a20b53939"],"x":2144,"y":139,"w":592,"h":177},{"id":"f4bc63e9c12c5b3d","type":"switch","z":"5fb50193cc6a2ad5","g":"bd042d33ae0b21d7","name":"Dewpoint (<10.0 - Dry)(10.1-12.79 - Pleas)(12.8-15.49 - Comf)(>15.5 Sticky))","property":"payload","propertyType":"msg","rules":[{"t":"btwn","v":"-20","vt":"num","v2":"10","v2t":"num"},{"t":"btwn","v":"10.1","vt":"num","v2":"12.79","v2t":"num"},{"t":"btwn","v":"12.8","vt":"num","v2":"15.49","v2t":"num"},{"t":"btwn","v":"15.5","vt":"num","v2":"50","v2t":"num"}],"checkall":"true","repair":false,"outputs":4,"x":2440,"y":260,"wires":[["7a665a9cadb864f1"],["dcab5b1ca38c256c"],["7c0c58827ff290a3"],["2992f68cfb6f5c51"]]},{"id":"12e87c7a20b53939","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"bd042d33ae0b21d7","name":"DEWPOINT LIVING ROOM","server":"","version":3,"outputs":2,"halt_if":"-20","halt_if_type":"num","halt_if_compare":"gt","entity_id":"sensor.dewpoint_living_room","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":2290,"y":180,"wires":[["f4bc63e9c12c5b3d"],[]]},{"id":"34159a70ce093a6b","type":"group","z":"5fb50193cc6a2ad5","g":"087dd5e58fc9b08d","name":"Check Inside Dewpoint to set Cooling Program LIVING ROOM","style":{"label":true,"fill":"#3f93cf"},"nodes":["a17efd7cb5c0d152","e5ee24919126bfd6"],"x":2134,"y":539,"w":512,"h":184.5},{"id":"a17efd7cb5c0d152","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"34159a70ce093a6b","name":"DEWPOINT LIVING ROOM","server":"","version":3,"outputs":2,"halt_if":"-20","halt_if_type":"num","halt_if_compare":"gt","entity_id":"sensor.dewpoint_living_room","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":2280,"y":580,"wires":[["e5ee24919126bfd6"],[]]},{"id":"e5ee24919126bfd6","type":"switch","z":"5fb50193cc6a2ad5","g":"34159a70ce093a6b","name":"Dewpoint (<15.49 - Comf)(15.5-18.39 - Sticky)(>18.4 - Muggy)","property":"payload","propertyType":"msg","rules":[{"t":"btwn","v":"-20","vt":"num","v2":"10","v2t":"num"},{"t":"btwn","v":"10.1","vt":"num","v2":"12.79","v2t":"num"},{"t":"btwn","v":"12.8","vt":"num","v2":"15.49","v2t":"num"},{"t":"btwn","v":"15.5","vt":"num","v2":"18.39","v2t":"num"},{"t":"btwn","v":"18.4","vt":"num","v2":"50","v2t":"num"}],"checkall":"true","repair":false,"outputs":5,"x":2390,"y":660,"wires":[["145cf9dd310cc6e1"],["145cf9dd310cc6e1"],["145cf9dd310cc6e1"],["1fb4f2f24fb3debb"],["6ecc7e71acae1e84"]]},{"id":"c80d0c896c588cab","type":"group","z":"5fb50193cc6a2ad5","g":"087dd5e58fc9b08d","name":"Check Inside Dewpoint to set Comfort Program LIVING ROOM","style":{"label":true,"fill":"#92d04f"},"nodes":["10dd0a9021620845","04b8be990948f3b9"],"x":2144,"y":339,"w":592,"h":177},{"id":"10dd0a9021620845","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"c80d0c896c588cab","name":"DEWPOINT LIVING ROOM","server":"","version":3,"outputs":2,"halt_if":"-20","halt_if_type":"num","halt_if_compare":"gt","entity_id":"sensor.dewpoint_living_room","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":2290,"y":380,"wires":[["04b8be990948f3b9"],[]]},{"id":"04b8be990948f3b9","type":"switch","z":"5fb50193cc6a2ad5","g":"c80d0c896c588cab","name":"Dewpoint (<10.0 - Dry)(10.1-12.79 - Pleas)(12.8-15.49 - Comf)(>15.5 Sticky))","property":"payload","propertyType":"msg","rules":[{"t":"btwn","v":"-20","vt":"num","v2":"10","v2t":"num"},{"t":"btwn","v":"10.1","vt":"num","v2":"12.79","v2t":"num"},{"t":"btwn","v":"12.8","vt":"num","v2":"15.49","v2t":"num"},{"t":"btwn","v":"15.5","vt":"num","v2":"50","v2t":"num"}],"checkall":"true","repair":false,"outputs":4,"x":2440,"y":460,"wires":[["47a03478c3ca0936"],["5d70172db147875c"],["2992f68cfb6f5c51"],["1fb4f2f24fb3debb"]]},{"id":"6b92e40bf31f6b7d","type":"group","z":"5fb50193cc6a2ad5","g":"087dd5e58fc9b08d","name":"Don't Set if already Set","style":{"label":true},"nodes":["e879d85ab145a8b4","7bc391448d3e27ba","45e0a22bbadc628f","78f4db94c43a4bbb","cdec14ade751ae54","8c19e1316a2f33ba","3bcc04bfc0b20057","63a7db080bd8c032","92b31f5e780d7edb","b46c1b6108de987a","ecde7ff1e817fcd0","f22af35320119fac","499ea2cd4058d49a","3320c8afffe09549","6ecc7e71acae1e84","1fb4f2f24fb3debb","7c0c58827ff290a3","dcab5b1ca38c256c","7a665a9cadb864f1","1b2375d7738034c4","7e3bb855b7be3496","e9846a6dc330242c","55aa9fe9c6ce49c1","49dea51e0d105eb3","84cb57c92babd4ff","b08efc1ed938cbd9","37ee22272096ca2c","193e4ddac179a339"],"x":3474,"y":119,"w":1262,"h":622},{"id":"e879d85ab145a8b4","type":"link in","z":"5fb50193cc6a2ad5","g":"6b92e40bf31f6b7d","name":"Liv HVAC OFF","links":["3781126db1ab25f1","94450bb3c44292f3","a87fc938aef30c01","145cf9dd310cc6e1"],"x":3515,"y":560,"wires":[["3320c8afffe09549"]]},{"id":"7bc391448d3e27ba","type":"switch","z":"5fb50193cc6a2ad5","g":"6b92e40bf31f6b7d","name":"IS DRY","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"DRY","vt":"str"},{"t":"neq","v":"DRY","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":4070,"y":500,"wires":[[],["92df298a88396c97"]]},{"id":"45e0a22bbadc628f","type":"switch","z":"5fb50193cc6a2ad5","g":"6b92e40bf31f6b7d","name":"IS COOL","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"COOL","vt":"str"},{"t":"neq","v":"COOL","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":4070,"y":700,"wires":[[],["5bd70155b38d435e"]]},{"id":"78f4db94c43a4bbb","type":"switch","z":"5fb50193cc6a2ad5","g":"6b92e40bf31f6b7d","name":"IS OFF","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"OFF","vt":"str"},{"t":"neq","v":"OFF","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":4070,"y":600,"wires":[[],["fd0951ec42a38cd7"]]},{"id":"cdec14ade751ae54","type":"switch","z":"5fb50193cc6a2ad5","g":"6b92e40bf31f6b7d","name":"IS SET 23","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"23.00","vt":"str"},{"t":"neq","v":"23.00","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":4060,"y":200,"wires":[["e9846a6dc330242c"],["c3f0521d1ac8d2d4"]]},{"id":"8c19e1316a2f33ba","type":"switch","z":"5fb50193cc6a2ad5","g":"6b92e40bf31f6b7d","name":"IS SET 22","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"22.00","vt":"str"},{"t":"neq","v":"22.00","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":4060,"y":300,"wires":[["84cb57c92babd4ff"],["bdfe5befdb3032ef"]]},{"id":"3bcc04bfc0b20057","type":"switch","z":"5fb50193cc6a2ad5","g":"6b92e40bf31f6b7d","name":"IS SET 21","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"21.00","vt":"str"},{"t":"neq","v":"21.00","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":4060,"y":400,"wires":[["193e4ddac179a339"],["9c366b8be2947e38"]]},{"id":"63a7db080bd8c032","type":"function","z":"5fb50193cc6a2ad5","g":"6b92e40bf31f6b7d","name":"Setting.Mode Living Room Zone  [1]","func":"const topic = msg.topic;  // preserve the topic\nif (msg.payload && msg.payload.zoneStates && msg.payload.zoneStates[\"1\"] && msg.payload.zoneStates[\"1\"].setting && msg.payload.zoneStates[\"1\"].setting.mode) {\n    msg.payload = msg.payload.zoneStates[\"1\"].setting.mode;\n} else {\n    msg.payload = msg.payload.zoneStates[\"1\"].setting.power;\n}\nmsg.topic = topic;        // restore the topic\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":3990,"y":660,"wires":[["45e0a22bbadc628f"]]},{"id":"92b31f5e780d7edb","type":"function","z":"5fb50193cc6a2ad5","g":"6b92e40bf31f6b7d","name":"Setting.Mode Living Room Zone  [1]","func":"const topic = msg.topic;  // preserve the topic\nif (msg.payload && msg.payload.zoneStates && msg.payload.zoneStates[\"1\"] && msg.payload.zoneStates[\"1\"].setting && msg.payload.zoneStates[\"1\"].setting.mode) {\n    msg.payload = msg.payload.zoneStates[\"1\"].setting.mode;\n} else {\n    msg.payload = msg.payload.zoneStates[\"1\"].setting.power;\n}\nmsg.topic = topic;        // restore the topic\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":3990,"y":460,"wires":[["7bc391448d3e27ba"]]},{"id":"b46c1b6108de987a","type":"function","z":"5fb50193cc6a2ad5","g":"6b92e40bf31f6b7d","name":"Setting.TempSetpoint Living Room Zone [1]","func":"const topic = msg.topic;  // preserve the topic\nreturn msg; if (msg.payload && msg.payload.zoneStates && msg.payload.zoneStates[\"1\"] && msg.payload.zoneStates[\"1\"].setting && msg.payload.zoneStates[\"1\"].setting.temperature) {\n    msg.payload = msg.payload.zoneStates[\"1\"].setting.temperature.celsius;\n} else {\n    msg.payload = 0.0;\n}\nmsg.topic = topic;        // restore the topic\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":3960,"y":160,"wires":[["cdec14ade751ae54"]]},{"id":"ecde7ff1e817fcd0","type":"function","z":"5fb50193cc6a2ad5","g":"6b92e40bf31f6b7d","name":"Setting.TempSetpoint Living Room Zone [1]","func":"const topic = msg.topic;  // preserve the topic\nreturn msg; if (msg.payload && msg.payload.zoneStates && msg.payload.zoneStates[\"1\"] && msg.payload.zoneStates[\"1\"].setting && msg.payload.zoneStates[\"1\"].setting.temperature) {\n    msg.payload = msg.payload.zoneStates[\"1\"].setting.temperature.celsius;\n} else {\n    msg.payload = 0.0;\n}\nmsg.topic = topic;        // restore the topic\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":3960,"y":260,"wires":[["8c19e1316a2f33ba"]]},{"id":"f22af35320119fac","type":"function","z":"5fb50193cc6a2ad5","g":"6b92e40bf31f6b7d","name":"Setting.TempSetpoint Living Room Zone [1]","func":"const topic = msg.topic;  // preserve the topic\nreturn msg; if (msg.payload && msg.payload.zoneStates && msg.payload.zoneStates[\"1\"] && msg.payload.zoneStates[\"1\"].setting && msg.payload.zoneStates[\"1\"].setting.temperature) {\n    msg.payload = msg.payload.zoneStates[\"1\"].setting.temperature.celsius;\n} else {\n    msg.payload = 0.0;\n}\nmsg.topic = topic;        // restore the topic\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":3960,"y":360,"wires":[["3bcc04bfc0b20057"]]},{"id":"499ea2cd4058d49a","type":"function","z":"5fb50193cc6a2ad5","g":"6b92e40bf31f6b7d","name":"Setting.Mode Living Room Zone  [1]","func":"const topic = msg.topic;  // preserve the topic\nif (\n    msg.payload &&\n    msg.payload.zoneStates &&\n    msg.payload.zoneStates[\"1\"] &&\n    msg.payload.zoneStates[\"1\"].setting\n) {\n    if (msg.payload.zoneStates[\"1\"].setting.mode !== undefined) {\n        msg.payload = msg.payload.zoneStates[\"1\"].setting.mode;\n    } else if (msg.payload.zoneStates[\"1\"].setting.power !== undefined) {\n        msg.payload = msg.payload.zoneStates[\"1\"].setting.power;\n    } else {\n        node.error(\"Both 'mode' and 'power' are undefined.\");\n    }\n} else {\n    node.error(\"Required properties are missing or undefined.\");\n}\nmsg.topic = topic;        // restore the topic\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":3990,"y":560,"wires":[["78f4db94c43a4bbb"]]},{"id":"3320c8afffe09549","type":"tado","z":"5fb50193cc6a2ad5","g":"6b92e40bf31f6b7d","acMode":"AUTO","apiCall":"getZoneStates","childlock":false,"configName":"83e627ce7e032c20","defaultTerminationTimeout":"","deviceId":"","endDate":"","fanSpeed":"AUTO","geoTracking":true,"homeId":"INSERT HOME ID","name":"","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","tariffId":"","tariffInCents":0,"temperature":"18","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","windowDetection":true,"windowDetectionTimeout":900,"year":"","zoneId":"","x":3650,"y":560,"wires":[["499ea2cd4058d49a"]]},{"id":"6ecc7e71acae1e84","type":"tado","z":"5fb50193cc6a2ad5","g":"6b92e40bf31f6b7d","acMode":"AUTO","apiCall":"getZoneStates","childlock":false,"configName":"83e627ce7e032c20","defaultTerminationTimeout":"","deviceId":"","endDate":"","fanSpeed":"AUTO","geoTracking":true,"homeId":"INSERT HOME ID","name":"","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","tariffId":"","tariffInCents":0,"temperature":"18","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","windowDetection":true,"windowDetectionTimeout":900,"year":"","zoneId":"","x":3650,"y":660,"wires":[["63a7db080bd8c032"]]},{"id":"1fb4f2f24fb3debb","type":"tado","z":"5fb50193cc6a2ad5","g":"6b92e40bf31f6b7d","acMode":"AUTO","apiCall":"getZoneStates","childlock":false,"configName":"83e627ce7e032c20","defaultTerminationTimeout":"","deviceId":"","endDate":"","fanSpeed":"AUTO","geoTracking":true,"homeId":"INSERT HOME ID","name":"","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","tariffId":"","tariffInCents":0,"temperature":"18","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","windowDetection":true,"windowDetectionTimeout":900,"year":"","zoneId":"","x":3650,"y":460,"wires":[["92b31f5e780d7edb"]]},{"id":"7c0c58827ff290a3","type":"tado","z":"5fb50193cc6a2ad5","g":"6b92e40bf31f6b7d","acMode":"AUTO","apiCall":"getZoneStates","childlock":false,"configName":"83e627ce7e032c20","defaultTerminationTimeout":"","deviceId":"","endDate":"","fanSpeed":"AUTO","geoTracking":true,"homeId":"INSERT HOME ID","name":"","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","tariffId":"","tariffInCents":0,"temperature":"18","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","windowDetection":true,"windowDetectionTimeout":900,"year":"","zoneId":"","x":3650,"y":360,"wires":[["f22af35320119fac"]]},{"id":"dcab5b1ca38c256c","type":"tado","z":"5fb50193cc6a2ad5","g":"6b92e40bf31f6b7d","acMode":"AUTO","apiCall":"getZoneStates","childlock":false,"configName":"83e627ce7e032c20","defaultTerminationTimeout":"","deviceId":"","endDate":"","fanSpeed":"AUTO","geoTracking":true,"homeId":"INSERT HOME ID","name":"","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","tariffId":"","tariffInCents":0,"temperature":"18","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","windowDetection":true,"windowDetectionTimeout":900,"year":"","zoneId":"","x":3650,"y":260,"wires":[["ecde7ff1e817fcd0"]]},{"id":"7a665a9cadb864f1","type":"tado","z":"5fb50193cc6a2ad5","g":"6b92e40bf31f6b7d","acMode":"AUTO","apiCall":"getZoneStates","childlock":false,"configName":"83e627ce7e032c20","defaultTerminationTimeout":"","deviceId":"","endDate":"","fanSpeed":"AUTO","geoTracking":true,"homeId":"INSERT HOME ID","name":"","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","tariffId":"","tariffInCents":0,"temperature":"18","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","windowDetection":true,"windowDetectionTimeout":900,"year":"","zoneId":"","x":3650,"y":160,"wires":[["b46c1b6108de987a"]]},{"id":"1b2375d7738034c4","type":"function","z":"5fb50193cc6a2ad5","g":"6b92e40bf31f6b7d","name":"Setting.Mode Living Room Zone  [1]","func":"const topic = msg.topic;  // preserve the topic\nif (msg.payload && msg.payload.zoneStates && msg.payload.zoneStates[\"1\"] && msg.payload.zoneStates[\"1\"].setting && msg.payload.zoneStates[\"1\"].setting.mode) {\n    msg.payload = msg.payload.zoneStates[\"1\"].setting.mode;\n} else {\n    msg.payload = msg.payload.zoneStates[\"1\"].setting.power;\n}\nmsg.topic = topic;        // restore the topic\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":4570,"y":220,"wires":[["7e3bb855b7be3496"]]},{"id":"7e3bb855b7be3496","type":"switch","z":"5fb50193cc6a2ad5","g":"6b92e40bf31f6b7d","name":"NOT HEAT","property":"payload","propertyType":"msg","rules":[{"t":"neq","v":"HEAT","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":4640,"y":260,"wires":[["c3f0521d1ac8d2d4"]]},{"id":"e9846a6dc330242c","type":"tado","z":"5fb50193cc6a2ad5","g":"6b92e40bf31f6b7d","acMode":"AUTO","apiCall":"getZoneStates","childlock":false,"configName":"83e627ce7e032c20","defaultTerminationTimeout":"","deviceId":"","endDate":"","fanSpeed":"AUTO","geoTracking":true,"homeId":"INSERT HOME ID","name":"","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","tariffId":"","tariffInCents":0,"temperature":"18","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","windowDetection":true,"windowDetectionTimeout":900,"year":"","zoneId":"","x":4290,"y":220,"wires":[["1b2375d7738034c4"]]},{"id":"55aa9fe9c6ce49c1","type":"switch","z":"5fb50193cc6a2ad5","g":"6b92e40bf31f6b7d","name":"NOT HEAT","property":"payload","propertyType":"msg","rules":[{"t":"neq","v":"HEAT","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":4640,"y":360,"wires":[["bdfe5befdb3032ef"]]},{"id":"49dea51e0d105eb3","type":"function","z":"5fb50193cc6a2ad5","g":"6b92e40bf31f6b7d","name":"Setting.Mode Living Room Zone  [1]","func":"const topic = msg.topic;  // preserve the topic\nif (msg.payload && msg.payload.zoneStates && msg.payload.zoneStates[\"1\"] && msg.payload.zoneStates[\"1\"].setting && msg.payload.zoneStates[\"1\"].setting.mode) {\n    msg.payload = msg.payload.zoneStates[\"1\"].setting.mode;\n} else {\n    msg.payload = msg.payload.zoneStates[\"1\"].setting.power;\n}\nmsg.topic = topic;        // restore the topic\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":4570,"y":320,"wires":[["55aa9fe9c6ce49c1"]]},{"id":"84cb57c92babd4ff","type":"tado","z":"5fb50193cc6a2ad5","g":"6b92e40bf31f6b7d","acMode":"AUTO","apiCall":"getZoneStates","childlock":false,"configName":"83e627ce7e032c20","defaultTerminationTimeout":"","deviceId":"","endDate":"","fanSpeed":"AUTO","geoTracking":true,"homeId":"INSERT HOME ID","name":"","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","tariffId":"","tariffInCents":0,"temperature":"18","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","windowDetection":true,"windowDetectionTimeout":900,"year":"","zoneId":"","x":4290,"y":320,"wires":[["49dea51e0d105eb3"]]},{"id":"b08efc1ed938cbd9","type":"switch","z":"5fb50193cc6a2ad5","g":"6b92e40bf31f6b7d","name":"NOT HEAT","property":"payload","propertyType":"msg","rules":[{"t":"neq","v":"HEAT","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":4640,"y":460,"wires":[["9c366b8be2947e38"]]},{"id":"37ee22272096ca2c","type":"function","z":"5fb50193cc6a2ad5","g":"6b92e40bf31f6b7d","name":"Setting.Mode Living Room Zone  [1]","func":"const topic = msg.topic;  // preserve the topic\nif (msg.payload && msg.payload.zoneStates && msg.payload.zoneStates[\"1\"] && msg.payload.zoneStates[\"1\"].setting && msg.payload.zoneStates[\"1\"].setting.mode) {\n    msg.payload = msg.payload.zoneStates[\"1\"].setting.mode;\n} else {\n    msg.payload = msg.payload.zoneStates[\"1\"].setting.power;\n}\nmsg.topic = topic;        // restore the topic\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":4570,"y":420,"wires":[["b08efc1ed938cbd9"]]},{"id":"193e4ddac179a339","type":"tado","z":"5fb50193cc6a2ad5","g":"6b92e40bf31f6b7d","acMode":"AUTO","apiCall":"getZoneStates","childlock":false,"configName":"83e627ce7e032c20","defaultTerminationTimeout":"","deviceId":"","endDate":"","fanSpeed":"AUTO","geoTracking":true,"homeId":"INSERT HOME ID","name":"","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","tariffId":"","tariffInCents":0,"temperature":"18","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","windowDetection":true,"windowDetectionTimeout":900,"year":"","zoneId":"","x":4290,"y":420,"wires":[["37ee22272096ca2c"]]},{"id":"7599ea43ce1f41ed","type":"group","z":"5fb50193cc6a2ad5","g":"087dd5e58fc9b08d","name":"Active Time","style":{"label":true},"nodes":["c3f0521d1ac8d2d4","9c366b8be2947e38","92df298a88396c97","5bd70155b38d435e","bdfe5befdb3032ef","3781126db1ab25f1","94450bb3c44292f3"],"x":4854,"y":139,"w":212,"h":582},{"id":"c3f0521d1ac8d2d4","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"7599ea43ce1f41ed","name":"","startTime":"05:30:00","endTime":"00:00:00","outputs":2,"x":4950,"y":180,"wires":[["cabc6f619b4358d9"],["486e5246fcfcf78f"]]},{"id":"9c366b8be2947e38","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"7599ea43ce1f41ed","name":"","startTime":"05:30:00","endTime":"00:00:00","outputs":2,"x":4950,"y":380,"wires":[["9badedb77550384b"],["3781126db1ab25f1"]]},{"id":"92df298a88396c97","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"7599ea43ce1f41ed","name":"","startTime":"05:30:00","endTime":"00:00:00","outputs":2,"x":4950,"y":480,"wires":[["ef98c65a06fa66f4"],["94450bb3c44292f3"]]},{"id":"5bd70155b38d435e","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"7599ea43ce1f41ed","name":"","startTime":"05:30:00","endTime":"00:00:00","outputs":2,"x":4950,"y":680,"wires":[["9e1fe1be37c26df8"],["ef98c65a06fa66f4"]]},{"id":"bdfe5befdb3032ef","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"7599ea43ce1f41ed","name":"","startTime":"05:30:00","endTime":"00:00:00","outputs":2,"x":4950,"y":280,"wires":[["486e5246fcfcf78f"],["9badedb77550384b"]]},{"id":"3781126db1ab25f1","type":"link out","z":"5fb50193cc6a2ad5","g":"7599ea43ce1f41ed","name":"Liv Heating Program (Night/OFF)","mode":"link","links":["e879d85ab145a8b4"],"x":5025,"y":420,"wires":[]},{"id":"94450bb3c44292f3","type":"link out","z":"5fb50193cc6a2ad5","g":"7599ea43ce1f41ed","name":"Liv Comfort Program (Night/OFF)","mode":"link","links":["e879d85ab145a8b4"],"x":5025,"y":520,"wires":[]},{"id":"754a415d107b3cec","type":"group","z":"5fb50193cc6a2ad5","g":"087dd5e58fc9b08d","name":"Indoor Check Temperature","style":{"label":true},"nodes":["870ea4da18d80eb8","ab108d0db0524737","cb91c8f1d72dd0ad","57e811b9667c4350","85e7e87b456d676e","3d9007d415c868a7"],"x":3014,"y":359,"w":372,"h":302},{"id":"870ea4da18d80eb8","type":"switch","z":"5fb50193cc6a2ad5","g":"754a415d107b3cec","name":"Living <= 21","property":"payload","propertyType":"msg","rules":[{"t":"lte","v":"21","vt":"str"},{"t":"gt","v":"21","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":3290,"y":620,"wires":[["7c0c58827ff290a3"],["a87fc938aef30c01"]]},{"id":"ab108d0db0524737","type":"switch","z":"5fb50193cc6a2ad5","g":"754a415d107b3cec","name":"Living <= 22","property":"payload","propertyType":"msg","rules":[{"t":"lte","v":"22","vt":"str"},{"t":"gt","v":"22","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":3290,"y":540,"wires":[["dcab5b1ca38c256c"],["7c0c58827ff290a3"]]},{"id":"cb91c8f1d72dd0ad","type":"switch","z":"5fb50193cc6a2ad5","g":"754a415d107b3cec","name":"Living <= 23","property":"payload","propertyType":"msg","rules":[{"t":"lte","v":"23","vt":"str"},{"t":"gt","v":"23","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":3290,"y":440,"wires":[["7a665a9cadb864f1"],["dcab5b1ca38c256c"]]},{"id":"57e811b9667c4350","type":"function","z":"5fb50193cc6a2ad5","g":"754a415d107b3cec","name":"Data.Temperature Living Room Zone [1]","func":"const topic = msg.topic;  // preserve the topic\nmsg.payload = msg.payload.zoneStates[\"1\"].sensorDataPoints.insideTemperature.celsius\nmsg.topic = topic;        // restore the topic\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":3200,"y":580,"wires":[["870ea4da18d80eb8"]]},{"id":"85e7e87b456d676e","type":"function","z":"5fb50193cc6a2ad5","g":"754a415d107b3cec","name":"Data.Temperature Living Room Zone [1]","func":"const topic = msg.topic;  // preserve the topic\nmsg.payload = msg.payload.zoneStates[\"1\"].sensorDataPoints.insideTemperature.celsius\nmsg.topic = topic;        // restore the topic\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":3200,"y":500,"wires":[["ab108d0db0524737"]]},{"id":"3d9007d415c868a7","type":"function","z":"5fb50193cc6a2ad5","g":"754a415d107b3cec","name":"Data.Temperature Living Room Zone [1]","func":"const topic = msg.topic;  // preserve the topic\nmsg.payload = msg.payload.zoneStates[\"1\"].sensorDataPoints.insideTemperature.celsius\nmsg.topic = topic;        // restore the topic\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":3200,"y":400,"wires":[["cb91c8f1d72dd0ad"]]},{"id":"34bfbcec2d579f8e","type":"group","z":"5fb50193cc6a2ad5","g":"087dd5e58fc9b08d","name":"HEAT PUMP MODES LIVING ROOM USING SERVICE CALLS THROUGH HOME ASSISTANT","style":{"label":true},"nodes":["81d0645fa148292c","d406fb0c09639792","710962d8f7a9c867","1bbe7f53bfda6e54","827a46f57765576a","9c8458b8ebf98057","0411e90e2ee4ea83"],"x":5128,"y":793,"w":1628,"h":634},{"id":"81d0645fa148292c","type":"group","z":"5fb50193cc6a2ad5","g":"34bfbcec2d579f8e","name":"OFF MODE LIVING ROOM - SETS TADO PRESET MODE AWAY - SETS TADO SCHEDULE OFF - SERVICE CALL OFF UPDATE THERMOSTAT CARD (TTS Topic: door)","style":{"label":true,"fill":"#000000","fill-opacity":"0.21"},"nodes":["a3169b9331517224","9551b4b83823afc7","4dec785df35493e6","1fd18514383590de"],"x":5654,"y":1219,"w":1076,"h":82},{"id":"a3169b9331517224","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"81d0645fa148292c","name":"Liv HVAC OFF","server":"","version":7,"debugenabled":false,"action":"climate.turn_off","floorId":[],"areaId":[],"deviceId":["1d2bcc499a5b8ef266105be599b319f1"],"entityId":["climate.air_conditioning"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"climate","service":"turn_off","x":5760,"y":1260,"wires":[["9551b4b83823afc7"]]},{"id":"9551b4b83823afc7","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"81d0645fa148292c","name":"","startTime":"05:55:00","endTime":"21:00:00","outputs":2,"x":5970,"y":1260,"wires":[["4dec785df35493e6"],[]]},{"id":"4dec785df35493e6","type":"switch","z":"5fb50193cc6a2ad5","g":"81d0645fa148292c","name":"msg.topic2","property":"topic2","propertyType":"msg","rules":[{"t":"eq","v":"check","vt":"str"},{"t":"eq","v":"door","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":6170,"y":1260,"wires":[[],["1fd18514383590de"]]},{"id":"1fd18514383590de","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"81d0645fa148292c","name":"TTS Door Open","server":"","version":7,"debugenabled":false,"action":"tts.cloud_say","floorId":[],"areaId":[],"deviceId":[],"entityId":[],"labelId":[],"data":"{\"entity_id\":\"media_player.attic_speaker_ma\",\"message\":\"Door closed, heat pumps set to on.\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"tts","service":"cloud_say","x":6380,"y":1260,"wires":[[]]},{"id":"d406fb0c09639792","type":"group","z":"5fb50193cc6a2ad5","g":"34bfbcec2d579f8e","name":"HEAT BOOST MODE LIVING ROOM (TTS Topic: door)","style":{"label":true,"fill":"#ff0000","fill-opacity":"0.2"},"nodes":["0688c7a8f2265048","829e369959e2506e","28ae2ba5a1f90950","8701780326ae7eeb","9cb6d79b55c494bb"],"x":5154,"y":819,"w":1332,"h":82},{"id":"0688c7a8f2265048","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"d406fb0c09639792","name":"","startTime":"05:55:00","endTime":"21:00:00","outputs":2,"x":5970,"y":860,"wires":[["829e369959e2506e"],[]]},{"id":"829e369959e2506e","type":"switch","z":"5fb50193cc6a2ad5","g":"d406fb0c09639792","name":"msg.topic2","property":"topic2","propertyType":"msg","rules":[{"t":"eq","v":"check","vt":"str"},{"t":"eq","v":"door","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":6170,"y":860,"wires":[[],["9cb6d79b55c494bb"]]},{"id":"28ae2ba5a1f90950","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"d406fb0c09639792","name":"Liv HVAC 23","server":"","version":7,"debugenabled":false,"action":"climate.set_temperature","floorId":[],"areaId":[],"deviceId":["1d2bcc499a5b8ef266105be599b319f1"],"entityId":["climate.air_conditioning"],"labelId":[],"data":"{\"temperature\":\"23\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"climate","service":"set_temperature","x":5750,"y":860,"wires":[["0688c7a8f2265048"]]},{"id":"8701780326ae7eeb","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"d406fb0c09639792","name":"Liv HVAC heat","server":"","version":7,"debugenabled":false,"action":"climate.set_hvac_mode","floorId":[],"areaId":[],"deviceId":["1d2bcc499a5b8ef266105be599b319f1"],"entityId":["climate.air_conditioning"],"labelId":[],"data":"{\"hvac_mode\":\"heat\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"climate","service":"set_hvac_mode","x":5260,"y":860,"wires":[["28ae2ba5a1f90950"]]},{"id":"9cb6d79b55c494bb","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"d406fb0c09639792","name":"TTS Heat 23","server":"","version":7,"debugenabled":false,"action":"tts.cloud_say","floorId":[],"areaId":[],"deviceId":[],"entityId":[],"labelId":[],"data":"{\"entity_id\":\"media_player.attic_speaker_ma\",\"message\":\"The door is closed, up stairs is set to Heat 23\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"tts","service":"cloud_say","x":6390,"y":860,"wires":[[]]},{"id":"710962d8f7a9c867","type":"group","z":"5fb50193cc6a2ad5","g":"34bfbcec2d579f8e","name":"HEAT 23 MODE LIVING ROOM (TTS Topic: door)","style":{"label":true,"fill":"#ff3f3f","fill-opacity":"0.2"},"nodes":["f6efb129282bb4e4","6ec69e426f50974b","9a48366f11db3a8a","3605821960ac5876","3b3f9189bc2c0fad"],"x":5154,"y":919,"w":1332,"h":82},{"id":"f6efb129282bb4e4","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"710962d8f7a9c867","name":"","startTime":"05:55:00","endTime":"21:00:00","outputs":2,"x":5970,"y":960,"wires":[["6ec69e426f50974b"],[]]},{"id":"6ec69e426f50974b","type":"switch","z":"5fb50193cc6a2ad5","g":"710962d8f7a9c867","name":"msg.topic2","property":"topic2","propertyType":"msg","rules":[{"t":"eq","v":"check","vt":"str"},{"t":"eq","v":"door","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":6170,"y":960,"wires":[[],["3b3f9189bc2c0fad"]]},{"id":"9a48366f11db3a8a","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"710962d8f7a9c867","name":"Liv HVAC 22","server":"","version":7,"debugenabled":false,"action":"climate.set_temperature","floorId":[],"areaId":[],"deviceId":["1d2bcc499a5b8ef266105be599b319f1"],"entityId":["climate.air_conditioning"],"labelId":[],"data":"{\"temperature\":\"22\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"climate","service":"set_temperature","x":5750,"y":960,"wires":[["f6efb129282bb4e4"]]},{"id":"3605821960ac5876","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"710962d8f7a9c867","name":"Liv HVAC heat","server":"","version":7,"debugenabled":false,"action":"climate.set_hvac_mode","floorId":[],"areaId":[],"deviceId":["1d2bcc499a5b8ef266105be599b319f1"],"entityId":["climate.air_conditioning"],"labelId":[],"data":"{\"hvac_mode\":\"heat\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"climate","service":"set_hvac_mode","x":5260,"y":960,"wires":[["9a48366f11db3a8a"]]},{"id":"3b3f9189bc2c0fad","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"710962d8f7a9c867","name":"TTS Heat 22","server":"","version":7,"debugenabled":false,"action":"tts.cloud_say","floorId":[],"areaId":[],"deviceId":[],"entityId":[],"labelId":[],"data":"{\"entity_id\":\"media_player.attic_speaker_ma\",\"message\":\"Door closed, up stairs is set to Heat 22\",\"title\":\"Door or Window Closed, Heat 22\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"tts","service":"cloud_say","x":6390,"y":960,"wires":[[]]},{"id":"1bbe7f53bfda6e54","type":"group","z":"5fb50193cc6a2ad5","g":"34bfbcec2d579f8e","name":"HEAT 21 MODE LIVING ROOM (TTS Topic: door)","style":{"label":true,"fill":"#ff7f7f","fill-opacity":"0.2"},"nodes":["2bda77da16dbc20e","80420c28a714caf3","42edf5e9ce8ca427","0a4771a1513c87af","cb74863d8bb1c53d"],"x":5154,"y":1019,"w":1332,"h":82},{"id":"2bda77da16dbc20e","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"1bbe7f53bfda6e54","name":"","startTime":"05:55:00","endTime":"21:00:00","outputs":2,"x":5970,"y":1060,"wires":[["80420c28a714caf3"],[]]},{"id":"80420c28a714caf3","type":"switch","z":"5fb50193cc6a2ad5","g":"1bbe7f53bfda6e54","name":"msg.topic2","property":"topic2","propertyType":"msg","rules":[{"t":"eq","v":"check","vt":"str"},{"t":"eq","v":"door","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":6170,"y":1060,"wires":[[],["cb74863d8bb1c53d"]]},{"id":"42edf5e9ce8ca427","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"1bbe7f53bfda6e54","name":"Liv HVAC 21","server":"","version":7,"debugenabled":false,"action":"climate.set_temperature","floorId":[],"areaId":[],"deviceId":["1d2bcc499a5b8ef266105be599b319f1"],"entityId":["climate.air_conditioning"],"labelId":[],"data":"{\"temperature\":\"21\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"climate","service":"set_temperature","x":5750,"y":1060,"wires":[["2bda77da16dbc20e"]]},{"id":"0a4771a1513c87af","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"1bbe7f53bfda6e54","name":"Liv HVAC heat","server":"","version":7,"debugenabled":false,"action":"climate.set_hvac_mode","floorId":[],"areaId":[],"deviceId":["1d2bcc499a5b8ef266105be599b319f1"],"entityId":["climate.air_conditioning"],"labelId":[],"data":"{\"hvac_mode\":\"heat\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"climate","service":"set_hvac_mode","x":5260,"y":1060,"wires":[["42edf5e9ce8ca427"]]},{"id":"cb74863d8bb1c53d","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"1bbe7f53bfda6e54","name":"TTS Heat 21","server":"","version":7,"debugenabled":false,"action":"tts.cloud_say","floorId":[],"areaId":[],"deviceId":[],"entityId":[],"labelId":[],"data":"{\"entity_id\":\"media_player.attic_speaker_ma\",\"message\":\"Door Closed, up stairs is set to Heat 21\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"tts","service":"cloud_say","x":6390,"y":1060,"wires":[[]]},{"id":"827a46f57765576a","type":"group","z":"5fb50193cc6a2ad5","g":"34bfbcec2d579f8e","name":"COOL MODE LIVING ROOM (TTS Topic: door)","style":{"label":true,"fill":"#3f93cf","fill-opacity":"0.2"},"nodes":["baef4d0147c4cf24","c6c781c0bb0a424a","8a466b2e397f45d0","7871e2c6d42b9ad4","6102b44a89ec40d4"],"x":5154,"y":1319,"w":1332,"h":82},{"id":"baef4d0147c4cf24","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"827a46f57765576a","name":"Liv HVAC 26","server":"","version":7,"debugenabled":false,"action":"climate.set_temperature","floorId":[],"areaId":[],"deviceId":["1d2bcc499a5b8ef266105be599b319f1"],"entityId":["climate.air_conditioning"],"labelId":[],"data":"{\"temperature\":\"26\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"climate","service":"set_temperature","x":5750,"y":1360,"wires":[["8a466b2e397f45d0"]]},{"id":"c6c781c0bb0a424a","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"827a46f57765576a","name":"Liv HVAC Cool","server":"","version":7,"debugenabled":false,"action":"climate.set_hvac_mode","floorId":[],"areaId":[],"deviceId":["1d2bcc499a5b8ef266105be599b319f1"],"entityId":["climate.air_conditioning"],"labelId":[],"data":"{\"hvac_mode\":\"cool\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"climate","service":"set_hvac_mode","x":5260,"y":1360,"wires":[["baef4d0147c4cf24"]]},{"id":"8a466b2e397f45d0","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"827a46f57765576a","name":"","startTime":"05:55:00","endTime":"21:00:00","outputs":2,"x":5970,"y":1360,"wires":[["7871e2c6d42b9ad4"],[]]},{"id":"7871e2c6d42b9ad4","type":"switch","z":"5fb50193cc6a2ad5","g":"827a46f57765576a","name":"msg.topic2","property":"topic2","propertyType":"msg","rules":[{"t":"eq","v":"check","vt":"str"},{"t":"eq","v":"door","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":6170,"y":1360,"wires":[[],["6102b44a89ec40d4"]]},{"id":"6102b44a89ec40d4","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"827a46f57765576a","name":"TTS Cool","server":"","version":7,"debugenabled":false,"action":"tts.cloud_say","floorId":[],"areaId":[],"deviceId":[],"entityId":[],"labelId":[],"data":"{\"entity_id\":\"media_player.attic_speaker_ma\",\"message\":\"Door closed, up stairs set to Cool 26\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"tts","service":"cloud_say","x":6400,"y":1360,"wires":[[]]},{"id":"9c8458b8ebf98057","type":"group","z":"5fb50193cc6a2ad5","g":"34bfbcec2d579f8e","name":"TADO SCHEDULE DRY MODE LIVING ROOM - TADO API CALL TO SET A/C - (SERVICE CALL TO  UPDATE HA THERMOSTAT CARD climate.set_hvac_mode) (TTS Topic: door)","style":{"label":true,"fill":"#ffff00","fill-opacity":"0.2"},"nodes":["793a28b5095603a2","4deb3644fa40aeb9","331c6b5ea7a86db2","f35ae73abf856d5f","477b311e83f6af11"],"x":5154,"y":1119,"w":1332,"h":82},{"id":"793a28b5095603a2","type":"switch","z":"5fb50193cc6a2ad5","g":"9c8458b8ebf98057","name":"msg.topic2","property":"topic2","propertyType":"msg","rules":[{"t":"eq","v":"check","vt":"str"},{"t":"eq","v":"door","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":6170,"y":1160,"wires":[[],["477b311e83f6af11"]]},{"id":"4deb3644fa40aeb9","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"9c8458b8ebf98057","name":"","startTime":"05:55:00","endTime":"21:00:00","outputs":2,"x":5970,"y":1160,"wires":[["793a28b5095603a2"],[]]},{"id":"331c6b5ea7a86db2","type":"tado","z":"5fb50193cc6a2ad5","g":"9c8458b8ebf98057","acMode":"DRY","apiCall":"setZoneOverlay","childlock":false,"configName":"83e627ce7e032c20","defaultTerminationTimeout":900,"defaultTerminationType":"TADO_MODE","deviceId":"","endDate":"","fanSpeed":"AUTO","geoTracking":true,"homeId":"INSERT HOME ID","horizontalSwing":"OFF","name":"Liv Dry Mode [setZoneOverlay] API Call - No Temp - Manual","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","tariffId":"","tariffInCents":0,"temperature":"","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","verticalSwing":"OFF","windowDetection":true,"windowDetectionTimeout":900,"year":"","zoneId":"1","x":5400,"y":1160,"wires":[["f35ae73abf856d5f"]]},{"id":"f35ae73abf856d5f","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"9c8458b8ebf98057","name":"Liv HVAC Dry","server":"","version":7,"debugenabled":false,"action":"climate.set_hvac_mode","floorId":[],"areaId":[],"deviceId":["1d2bcc499a5b8ef266105be599b319f1"],"entityId":["climate.air_conditioning"],"labelId":[],"data":"{\"hvac_mode\":\"dry\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"climate","service":"set_hvac_mode","x":5760,"y":1160,"wires":[["4deb3644fa40aeb9"]]},{"id":"477b311e83f6af11","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"9c8458b8ebf98057","name":"TTS Dry","server":"","version":7,"debugenabled":false,"action":"tts.cloud_say","floorId":[],"areaId":[],"deviceId":[],"entityId":[],"labelId":[],"data":"{\"entity_id\":\"media_player.attic_speaker_ma\",\"message\":\"door closed, up stairs set to Dry Mode\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"tts","service":"cloud_say","x":6400,"y":1160,"wires":[[]]},{"id":"0411e90e2ee4ea83","type":"group","z":"5fb50193cc6a2ad5","g":"34bfbcec2d579f8e","name":"Clear TADO Timer/Manual Overlay","style":{"label":true},"nodes":["569e69b0899942ae"],"x":5154,"y":1219,"w":292,"h":82},{"id":"569e69b0899942ae","type":"tado","z":"5fb50193cc6a2ad5","g":"0411e90e2ee4ea83","acMode":"DRY","apiCall":"clearZoneOverlay","childlock":false,"configName":"83e627ce7e032c20","defaultTerminationTimeout":900,"defaultTerminationType":"TADO_MODE","deviceId":"","endDate":"","fanSpeed":"AUTO","geoTracking":true,"homeId":"INSERT HOME ID","horizontalSwing":"OFF","name":"Liv (1) [ClearZoneOverlay]","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","tariffId":"","tariffInCents":0,"temperature":"","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","verticalSwing":"OFF","windowDetection":true,"windowDetectionTimeout":900,"year":"","zoneId":"1","x":5300,"y":1260,"wires":[["a3169b9331517224"]]},{"id":"f7ec128dc8f3c659","type":"group","z":"5fb50193cc6a2ad5","g":"087dd5e58fc9b08d","name":"HEAT PUMP MODES LIVING ROOM - USING TADO API CALLS AND - HA SERVICE CALLS TO SET HA THERMOSTAT","style":{"label":true},"nodes":["4568cafdb328e713","e4e15670cfb4466c","6af24511e05a707f","11d86dcbe6fb897c","0f2ec2553b255ba1","9ee79f75609d99e5","fbea9db4e818ae36"],"x":5128,"y":93,"w":1684,"h":634},{"id":"4568cafdb328e713","type":"group","z":"5fb50193cc6a2ad5","g":"f7ec128dc8f3c659","name":"TADO SCHEDULE DRY MODE LIVING ROOM - TADO API CALL TO SET A/C - (SERVICE CALL TO  UPDATE HA THERMOSTAT CARD climate.set_hvac_mode) (TTS Topic: door)","style":{"label":true,"fill":"#ffff00","fill-opacity":"0.2"},"nodes":["da6d7dae1eff57cf","056b8be1dcfa21eb","ef98c65a06fa66f4","1a98d4c447bbf347","db244d7eff8e8886"],"x":5474,"y":419,"w":1312,"h":82},{"id":"da6d7dae1eff57cf","type":"switch","z":"5fb50193cc6a2ad5","g":"4568cafdb328e713","name":"msg.topic2","property":"topic2","propertyType":"msg","rules":[{"t":"eq","v":"check","vt":"str"},{"t":"eq","v":"door","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":6490,"y":460,"wires":[[],["db244d7eff8e8886"]]},{"id":"056b8be1dcfa21eb","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"4568cafdb328e713","name":"","startTime":"05:55:00","endTime":"21:00:00","outputs":2,"x":6310,"y":460,"wires":[["da6d7dae1eff57cf"],[]]},{"id":"ef98c65a06fa66f4","type":"tado","z":"5fb50193cc6a2ad5","g":"4568cafdb328e713","acMode":"DRY","apiCall":"setZoneOverlay","childlock":false,"configName":"83e627ce7e032c20","defaultTerminationTimeout":900,"defaultTerminationType":"TADO_MODE","deviceId":"","endDate":"","fanSpeed":"AUTO","geoTracking":true,"homeId":"INSERT HOME ID","horizontalSwing":"OFF","name":"Liv Dry Mode [setZoneOverlay] API Call - No Temp - Manual","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","tariffId":"","tariffInCents":0,"temperature":"","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","verticalSwing":"OFF","windowDetection":true,"windowDetectionTimeout":900,"year":"","zoneId":"1","x":5720,"y":460,"wires":[["1a98d4c447bbf347"]]},{"id":"1a98d4c447bbf347","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"4568cafdb328e713","name":"Liv HVAC Dry","server":"","version":7,"debugenabled":false,"action":"climate.set_hvac_mode","floorId":[],"areaId":[],"deviceId":["1d2bcc499a5b8ef266105be599b319f1"],"entityId":["climate.air_conditioning"],"labelId":[],"data":"{\"hvac_mode\":\"dry\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"climate","service":"set_hvac_mode","x":6080,"y":460,"wires":[["056b8be1dcfa21eb"]]},{"id":"db244d7eff8e8886","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"4568cafdb328e713","name":"TTS Dry","server":"","version":7,"debugenabled":false,"action":"tts.cloud_say","floorId":[],"areaId":[],"deviceId":[],"entityId":[],"labelId":[],"data":"{\"entity_id\":\"media_player.attic_speaker_ma\",\"message\":\"Door closed, Up-stairs is set to Dry Mode.\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"tts","service":"cloud_say","x":6700,"y":460,"wires":[[]]},{"id":"e4e15670cfb4466c","type":"group","z":"5fb50193cc6a2ad5","g":"f7ec128dc8f3c659","name":"COOL MODE LIVING ROOM - TADO API CALL TO SET A/C - (SERVICE CALL TO  UPDATE HA THERMOSTAT CARD climate.set_hvac_mode) (TTS Topic: door)","style":{"label":true,"fill":"#3f93cf","fill-opacity":"0.2"},"nodes":["3cf699bb2b262ac6","56e47bf7269de773","c751eaa4216fb44c","9e1fe1be37c26df8","07ad722bc9e8b901"],"x":5474,"y":619,"w":1312,"h":82},{"id":"3cf699bb2b262ac6","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"e4e15670cfb4466c","name":"TTS Cool","server":"","version":7,"debugenabled":false,"action":"tts.cloud_say","floorId":[],"areaId":[],"deviceId":[],"entityId":[],"labelId":[],"data":"{\"entity_id\":\"media_player.attic_speaker_ma\",\"message\":\"Door closed, Up-stairs is set to Cool 26.\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"tts","service":"cloud_say","x":6700,"y":660,"wires":[[]]},{"id":"56e47bf7269de773","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"e4e15670cfb4466c","name":"","startTime":"05:55:00","endTime":"21:00:00","outputs":2,"x":6310,"y":660,"wires":[["c751eaa4216fb44c"],[]]},{"id":"c751eaa4216fb44c","type":"switch","z":"5fb50193cc6a2ad5","g":"e4e15670cfb4466c","name":"msg.topic2","property":"topic2","propertyType":"msg","rules":[{"t":"eq","v":"check","vt":"str"},{"t":"eq","v":"door","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":6490,"y":660,"wires":[[],["3cf699bb2b262ac6"]]},{"id":"9e1fe1be37c26df8","type":"tado","z":"5fb50193cc6a2ad5","g":"e4e15670cfb4466c","acMode":"COOL","apiCall":"setZoneOverlay","childlock":false,"configName":"83e627ce7e032c20","defaultTerminationTimeout":900,"defaultTerminationType":"TADO_MODE","deviceId":"","endDate":"","fanSpeed":"AUTO","geoTracking":true,"homeId":"INSERT HOME ID","horizontalSwing":"OFF","name":"Liv Cool 25 [setZoneOverlay] API Call - Manual","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","tariffId":"","tariffInCents":0,"temperature":"25","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","verticalSwing":"OFF","windowDetection":true,"windowDetectionTimeout":900,"year":"","zoneId":"1","x":5680,"y":660,"wires":[["07ad722bc9e8b901"]]},{"id":"07ad722bc9e8b901","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"e4e15670cfb4466c","name":"Liv HVAC Cool","server":"","version":7,"debugenabled":false,"action":"climate.set_hvac_mode","floorId":[],"areaId":[],"deviceId":[],"entityId":["climate.air_conditioning"],"labelId":[],"data":"{\"hvac_mode\":\"cool\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"climate","service":"set_hvac_mode","x":6080,"y":660,"wires":[["56e47bf7269de773"]]},{"id":"6af24511e05a707f","type":"group","z":"5fb50193cc6a2ad5","g":"f7ec128dc8f3c659","name":"HEAT BOOST MODE LIVING ROOM - TADO API CALL TO SET A/C - (SERVICE CALL TO  UPDATE HA THERMOSTAT CARD climate.set_hvac_mode) (TTS Topic: door)","style":{"label":true,"fill":"#ff0000","fill-opacity":"0.2"},"nodes":["ca91cf0606cf72b8","41453270ae3c0914","b193de46e35d68ac","cabc6f619b4358d9","f62f0a5dcd1a3c47"],"x":5474,"y":119,"w":1312,"h":82},{"id":"ca91cf0606cf72b8","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"6af24511e05a707f","name":"TTS Heat 23","server":"","version":7,"debugenabled":false,"action":"tts.cloud_say","floorId":[],"areaId":[],"deviceId":[],"entityId":[],"labelId":[],"data":"{\"entity_id\":\"media_player.attic_speaker_ma\",\"message\":\"Door Closed, Up-stairs is set to Heat 23.\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"tts","service":"cloud_say","x":6690,"y":160,"wires":[[]]},{"id":"41453270ae3c0914","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"6af24511e05a707f","name":"","startTime":"05:55:00","endTime":"21:00:00","outputs":2,"x":6310,"y":160,"wires":[["b193de46e35d68ac"],[]]},{"id":"b193de46e35d68ac","type":"switch","z":"5fb50193cc6a2ad5","g":"6af24511e05a707f","name":"msg.topic2","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"check","vt":"str"},{"t":"eq","v":"door","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":6490,"y":160,"wires":[[],["ca91cf0606cf72b8"]]},{"id":"cabc6f619b4358d9","type":"tado","z":"5fb50193cc6a2ad5","g":"6af24511e05a707f","acMode":"HEAT","apiCall":"setZoneOverlay","childlock":false,"configName":"83e627ce7e032c20","defaultTerminationTimeout":900,"defaultTerminationType":"TADO_MODE","deviceId":"","endDate":"","fanSpeed":"AUTO","geoTracking":true,"homeId":"INSERT HOME ID","horizontalSwing":"OFF","name":"Liv Heat 23 Mode [setZoneOverlay] API Call - Manual","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","tariffId":"","tariffInCents":0,"temperature":"23","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","verticalSwing":"OFF","windowDetection":true,"windowDetectionTimeout":900,"year":"","zoneId":"1","x":5700,"y":160,"wires":[["f62f0a5dcd1a3c47"]]},{"id":"f62f0a5dcd1a3c47","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"6af24511e05a707f","name":"Liv HVAC Heat","server":"","version":7,"debugenabled":false,"action":"climate.set_hvac_mode","floorId":[],"areaId":[],"deviceId":[],"entityId":["climate.air_conditioning"],"labelId":[],"data":"{\"hvac_mode\":\"heat\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"climate","service":"set_hvac_mode","x":6080,"y":160,"wires":[["41453270ae3c0914"]]},{"id":"11d86dcbe6fb897c","type":"group","z":"5fb50193cc6a2ad5","g":"f7ec128dc8f3c659","name":"OFF MODE LIVING ROOM (Uses the schedule configured in the app to OFF for HOME Mode) (TTS Topic: door)","style":{"label":true,"fill":"#000000","fill-opacity":"0.21"},"nodes":["6f0a6d0d095ad0d3","c9bfe63450758126","5bce79b9bc0df25a","870b5bd8cdb5c803","6ea966731eda867e"],"x":5474,"y":519,"w":1312,"h":82},{"id":"6f0a6d0d095ad0d3","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"11d86dcbe6fb897c","name":"TTS Door Open","server":"","version":7,"debugenabled":false,"action":"tts.cloud_say","floorId":[],"areaId":[],"deviceId":[],"entityId":[],"labelId":[],"data":"{\"entity_id\":\"media_player.attic_speaker_ma\",\"message\":\"Door Closed, Upstairs Heat Pumps Turned ON.\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"tts","service":"cloud_say","x":6680,"y":560,"wires":[[]]},{"id":"c9bfe63450758126","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"11d86dcbe6fb897c","name":"","startTime":"05:55:00","endTime":"21:00:00","outputs":2,"x":6310,"y":560,"wires":[["5bce79b9bc0df25a"],[]]},{"id":"5bce79b9bc0df25a","type":"switch","z":"5fb50193cc6a2ad5","g":"11d86dcbe6fb897c","name":"msg.topic2","property":"topic2","propertyType":"msg","rules":[{"t":"eq","v":"check","vt":"str"},{"t":"eq","v":"door","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":6490,"y":560,"wires":[[],["6f0a6d0d095ad0d3"]]},{"id":"870b5bd8cdb5c803","type":"tado","z":"5fb50193cc6a2ad5","g":"11d86dcbe6fb897c","acMode":"COOL","apiCall":"setZoneOverlay","childlock":false,"configName":"83e627ce7e032c20","defaultTerminationTimeout":900,"defaultTerminationType":"TADO_MODE","deviceId":"","endDate":"","fanSpeed":"AUTO","geoTracking":true,"homeId":"INSERT HOME ID","horizontalSwing":"OFF","name":"Liv OFF [setZoneOverlay] API Call - Manual","openWindowMode":true,"power":"off","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","tariffId":"","tariffInCents":0,"temperature":"25","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","verticalSwing":"OFF","windowDetection":true,"windowDetectionTimeout":900,"year":"","zoneId":"1","x":5670,"y":560,"wires":[["6ea966731eda867e"]]},{"id":"6ea966731eda867e","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"11d86dcbe6fb897c","name":"Liv HVAC OFF","server":"","version":7,"debugenabled":false,"action":"climate.set_hvac_mode","floorId":[],"areaId":[],"deviceId":[],"entityId":["climate.air_conditioning"],"labelId":[],"data":"{\"hvac_mode\":\"off\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"climate","service":"set_hvac_mode","x":6080,"y":560,"wires":[["c9bfe63450758126"]]},{"id":"0f2ec2553b255ba1","type":"group","z":"5fb50193cc6a2ad5","g":"f7ec128dc8f3c659","name":"HEAT 22 MODE LIVING ROOM - TADO API CALL TO SET A/C - (SERVICE CALL TO  UPDATE HA THERMOSTAT CARD climate.set_hvac_mode) (TTS Topic: door)","style":{"label":true,"fill":"#ff3f3f","fill-opacity":"0.2"},"nodes":["0ed64a2ff89ce34b","573bed54663e70c9","2917a322420199b7","486e5246fcfcf78f","98b342dddf12c256"],"x":5474,"y":219,"w":1312,"h":82},{"id":"0ed64a2ff89ce34b","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"0f2ec2553b255ba1","name":"TTS Heat 22","server":"","version":7,"debugenabled":false,"action":"tts.cloud_say","floorId":[],"areaId":[],"deviceId":[],"entityId":[],"labelId":[],"data":"{\"entity_id\":\"media_player.attic_speaker_ma\",\"message\":\"Door closed - Up-stairs is set to Heat 22.\",\"title\":\"Door or Window Closed, Heat 23\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"tts","service":"cloud_say","x":6690,"y":260,"wires":[[]]},{"id":"573bed54663e70c9","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"0f2ec2553b255ba1","name":"","startTime":"05:55:00","endTime":"21:00:00","outputs":2,"x":6310,"y":260,"wires":[["2917a322420199b7"],[]]},{"id":"2917a322420199b7","type":"switch","z":"5fb50193cc6a2ad5","g":"0f2ec2553b255ba1","name":"msg.topic2","property":"topic2","propertyType":"msg","rules":[{"t":"eq","v":"check","vt":"str"},{"t":"eq","v":"door","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":6490,"y":260,"wires":[[],["0ed64a2ff89ce34b"]]},{"id":"486e5246fcfcf78f","type":"tado","z":"5fb50193cc6a2ad5","g":"0f2ec2553b255ba1","acMode":"HEAT","apiCall":"setZoneOverlay","childlock":false,"configName":"83e627ce7e032c20","defaultTerminationTimeout":900,"defaultTerminationType":"TADO_MODE","deviceId":"","endDate":"","fanSpeed":"AUTO","geoTracking":true,"homeId":"INSERT HOME ID","horizontalSwing":"OFF","name":"Liv Heat 22 Mode [setZoneOverlay] API Calll - Manual","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","tariffId":"","tariffInCents":0,"temperature":"22","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","verticalSwing":"OFF","windowDetection":true,"windowDetectionTimeout":900,"year":"","zoneId":"1","x":5700,"y":260,"wires":[["98b342dddf12c256"]]},{"id":"98b342dddf12c256","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"0f2ec2553b255ba1","name":"Liv HVAC Heat","server":"","version":7,"debugenabled":false,"action":"climate.set_hvac_mode","floorId":[],"areaId":[],"deviceId":["1d2bcc499a5b8ef266105be599b319f1"],"entityId":["climate.air_conditioning"],"labelId":[],"data":"{\"hvac_mode\":\"heat\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"climate","service":"set_hvac_mode","x":6080,"y":260,"wires":[["573bed54663e70c9"]]},{"id":"9ee79f75609d99e5","type":"group","z":"5fb50193cc6a2ad5","g":"f7ec128dc8f3c659","name":"HEAT 21 MODE LIVING ROOM - TADO API CALL TO SET A/C - (SERVICE CALL TO  UPDATE HA THERMOSTAT CARD climate.set_hvac_mode) (TTS Topic: door)","style":{"label":true,"fill":"#ff7f7f","fill-opacity":"0.2"},"nodes":["b173c268e10a87c7","26dc62099425fd69","293534f7fa61c445","9badedb77550384b","2410186bdeb1b5e4"],"x":5474,"y":319,"w":1312,"h":82},{"id":"b173c268e10a87c7","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"9ee79f75609d99e5","name":"TTS Heat 21","server":"","version":7,"debugenabled":false,"action":"tts.cloud_say","floorId":[],"areaId":[],"deviceId":[],"entityId":[],"labelId":[],"data":"{\"entity_id\":\"media_player.attic_speaker_ma\",\"message\":\"Door closed, Up-stairs is set to Heat 21.\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"tts","service":"cloud_say","x":6690,"y":360,"wires":[[]]},{"id":"26dc62099425fd69","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"9ee79f75609d99e5","name":"","startTime":"05:55:00","endTime":"21:00:00","outputs":2,"x":6310,"y":360,"wires":[["293534f7fa61c445"],[]]},{"id":"293534f7fa61c445","type":"switch","z":"5fb50193cc6a2ad5","g":"9ee79f75609d99e5","name":"msg.topic2","property":"topic2","propertyType":"msg","rules":[{"t":"eq","v":"check","vt":"str"},{"t":"eq","v":"door","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":6490,"y":360,"wires":[[],["b173c268e10a87c7"]]},{"id":"9badedb77550384b","type":"tado","z":"5fb50193cc6a2ad5","g":"9ee79f75609d99e5","acMode":"HEAT","apiCall":"setZoneOverlay","childlock":false,"configName":"83e627ce7e032c20","defaultTerminationTimeout":900,"defaultTerminationType":"TADO_MODE","deviceId":"","endDate":"","fanSpeed":"AUTO","geoTracking":true,"homeId":"INSERT HOME ID","horizontalSwing":"OFF","name":"Liv Heat 21 Mode [setZoneOverlay] API Calll - Manual","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","tariffId":"","tariffInCents":0,"temperature":"21","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","verticalSwing":"OFF","windowDetection":true,"windowDetectionTimeout":900,"year":"","zoneId":"1","x":5700,"y":360,"wires":[["2410186bdeb1b5e4"]]},{"id":"2410186bdeb1b5e4","type":"api-call-service","z":"5fb50193cc6a2ad5","g":"9ee79f75609d99e5","name":"Liv HVAC Heat","server":"","version":7,"debugenabled":false,"action":"climate.set_hvac_mode","floorId":[],"areaId":[],"deviceId":["1d2bcc499a5b8ef266105be599b319f1"],"entityId":["climate.air_conditioning"],"labelId":[],"data":"{\"hvac_mode\":\"heat\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","blockInputOverrides":false,"domain":"climate","service":"set_hvac_mode","x":6080,"y":360,"wires":[["26dc62099425fd69"]]},{"id":"fbea9db4e818ae36","type":"group","z":"5fb50193cc6a2ad5","g":"f7ec128dc8f3c659","name":"Clear TADO Timer/Manual Overlay","style":{"label":true},"nodes":["fd0951ec42a38cd7"],"x":5154,"y":519,"w":292,"h":82},{"id":"fd0951ec42a38cd7","type":"tado","z":"5fb50193cc6a2ad5","g":"fbea9db4e818ae36","acMode":"DRY","apiCall":"clearZoneOverlay","childlock":false,"configName":"83e627ce7e032c20","defaultTerminationTimeout":900,"defaultTerminationType":"TADO_MODE","deviceId":"","endDate":"","fanSpeed":"AUTO","geoTracking":true,"homeId":"INSERT HOME ID","horizontalSwing":"OFF","name":"Liv (1) [ClearZoneOverlay]","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","tariffId":"","tariffInCents":0,"temperature":"","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","verticalSwing":"OFF","windowDetection":true,"windowDetectionTimeout":900,"year":"","zoneId":"1","x":5300,"y":560,"wires":[["870b5bd8cdb5c803"]]},{"id":"8f78a2259b52cd0a","type":"inject","z":"5fb50193cc6a2ad5","g":"087dd5e58fc9b08d","name":"Test","props":[{"p":"payload"},{"p":"topic2","v":"door","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":2230,"y":760,"wires":[["31e80b5425bff681"]]},{"id":"31e80b5425bff681","type":"link out","z":"5fb50193cc6a2ad5","g":"087dd5e58fc9b08d","name":"TEST OUT","mode":"link","links":["2926bf43d0347873"],"x":2345,"y":760,"wires":[]},{"id":"a3de13b84f99e239","type":"link out","z":"5fb50193cc6a2ad5","g":"087dd5e58fc9b08d","name":"TADO Liv Cooling Program (Comfy/OFF)","mode":"link","links":["27a718aace4233ae"],"x":2725,"y":1300,"wires":[]},{"id":"807a123fbc77b81e","type":"group","z":"5fb50193cc6a2ad5","g":"087dd5e58fc9b08d","name":"Check Inside Dewpoint to set Heating Program LIVING ROOM","style":{"label":true,"fill":"#ff0000"},"nodes":["47fb0a2899fba8c6","7427e5f7115d9b23"],"x":2144,"y":799,"w":592,"h":177},{"id":"47fb0a2899fba8c6","type":"switch","z":"5fb50193cc6a2ad5","g":"807a123fbc77b81e","name":"Dewpoint (<10.0 - Dry)(10.1-12.79 - Pleas)(12.8-15.49 - Comf)(>15.5 Sticky))","property":"payload","propertyType":"msg","rules":[{"t":"btwn","v":"-20","vt":"num","v2":"10","v2t":"num"},{"t":"btwn","v":"10.1","vt":"num","v2":"12.79","v2t":"num"},{"t":"btwn","v":"12.8","vt":"num","v2":"15.49","v2t":"num"},{"t":"btwn","v":"15.5","vt":"num","v2":"50","v2t":"num"}],"checkall":"true","repair":false,"outputs":4,"x":2440,"y":920,"wires":[["cee55bf086e931a0"],["98abbe73d1dd4049"],["e3101ed1cf7cfb29"],["230334b2b5addfb2"]]},{"id":"7427e5f7115d9b23","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"807a123fbc77b81e","name":"DEWPOINT LIVING ROOM","server":"","version":3,"outputs":2,"halt_if":"-20","halt_if_type":"num","halt_if_compare":"gt","entity_id":"sensor.dewpoint_living_room","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":2290,"y":840,"wires":[["47fb0a2899fba8c6"],[]]},{"id":"f1c3afcc82667e3a","type":"group","z":"5fb50193cc6a2ad5","g":"087dd5e58fc9b08d","name":"Check Inside Dewpoint to set Cooling Program LIVING ROOM","style":{"label":true,"fill":"#3f93cf"},"nodes":["2648b0ba35b62658","0dced45aa0424202"],"x":2134,"y":1199,"w":512,"h":184.5},{"id":"2648b0ba35b62658","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"f1c3afcc82667e3a","name":"DEWPOINT LIVING ROOM","server":"","version":3,"outputs":2,"halt_if":"-20","halt_if_type":"num","halt_if_compare":"gt","entity_id":"sensor.dewpoint_living_room","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":2280,"y":1240,"wires":[["0dced45aa0424202"],[]]},{"id":"0dced45aa0424202","type":"switch","z":"5fb50193cc6a2ad5","g":"f1c3afcc82667e3a","name":"Dewpoint (<15.49 - Comf)(15.5-18.39 - Sticky)(>18.4 - Muggy)","property":"payload","propertyType":"msg","rules":[{"t":"btwn","v":"-20","vt":"num","v2":"10","v2t":"num"},{"t":"btwn","v":"10.1","vt":"num","v2":"12.79","v2t":"num"},{"t":"btwn","v":"12.8","vt":"num","v2":"15.49","v2t":"num"},{"t":"btwn","v":"15.5","vt":"num","v2":"18.39","v2t":"num"},{"t":"btwn","v":"18.4","vt":"num","v2":"50","v2t":"num"}],"checkall":"true","repair":false,"outputs":5,"x":2390,"y":1320,"wires":[["a3de13b84f99e239"],["a3de13b84f99e239"],["a3de13b84f99e239"],["f173d5041ae65880"],["0d34494c8a478896"]]},{"id":"eb0e18a5c656f903","type":"group","z":"5fb50193cc6a2ad5","g":"087dd5e58fc9b08d","name":"Check Inside Dewpoint to set Comfort Program LIVING ROOM","style":{"label":true,"fill":"#92d04f"},"nodes":["fc9de90693b45009","8dd9d3d443876a8d"],"x":2144,"y":999,"w":592,"h":177},{"id":"fc9de90693b45009","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"eb0e18a5c656f903","name":"DEWPOINT LIVING ROOM","server":"","version":3,"outputs":2,"halt_if":"-20","halt_if_type":"num","halt_if_compare":"gt","entity_id":"sensor.dewpoint_living_room","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":2290,"y":1040,"wires":[["8dd9d3d443876a8d"],[]]},{"id":"8dd9d3d443876a8d","type":"switch","z":"5fb50193cc6a2ad5","g":"eb0e18a5c656f903","name":"Dewpoint (<10.0 - Dry)(10.1-12.79 - Pleas)(12.8-15.49 - Comf)(>15.5 Sticky))","property":"payload","propertyType":"msg","rules":[{"t":"btwn","v":"-20","vt":"num","v2":"10","v2t":"num"},{"t":"btwn","v":"10.1","vt":"num","v2":"12.79","v2t":"num"},{"t":"btwn","v":"12.8","vt":"num","v2":"15.49","v2t":"num"},{"t":"btwn","v":"15.5","vt":"num","v2":"50","v2t":"num"}],"checkall":"true","repair":false,"outputs":4,"x":2440,"y":1120,"wires":[["50f183922b7f91b3"],["eddfdcb298ba0670"],["230334b2b5addfb2"],["f173d5041ae65880"]]},{"id":"30679304285bae5a","type":"group","z":"5fb50193cc6a2ad5","g":"087dd5e58fc9b08d","name":"Indoor Check Temperature","style":{"label":true},"nodes":["230334b2b5addfb2","eddfdcb298ba0670","50f183922b7f91b3"],"x":2874,"y":1019,"w":192,"h":202},{"id":"230334b2b5addfb2","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"30679304285bae5a","name":"Living <=21","server":"","version":3,"outputs":2,"halt_if":"21","halt_if_type":"num","halt_if_compare":"lte","entity_id":"sensor.air_conditioning_temperature","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":2970,"y":1180,"wires":[["e3101ed1cf7cfb29"],["f3dc5e6e1109d0cd"]]},{"id":"eddfdcb298ba0670","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"30679304285bae5a","name":"Living <=22","server":"","version":3,"outputs":2,"halt_if":"22","halt_if_type":"num","halt_if_compare":"lte","entity_id":"sensor.air_conditioning_temperature","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":2970,"y":1120,"wires":[["98abbe73d1dd4049"],["e3101ed1cf7cfb29"]]},{"id":"50f183922b7f91b3","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"30679304285bae5a","name":"Living  <=23","server":"","version":3,"outputs":2,"halt_if":"23","halt_if_type":"num","halt_if_compare":"lte","entity_id":"sensor.air_conditioning_temperature","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":2970,"y":1060,"wires":[["cee55bf086e931a0"],["98abbe73d1dd4049"]]},{"id":"f3dc5e6e1109d0cd","type":"link out","z":"5fb50193cc6a2ad5","g":"087dd5e58fc9b08d","name":"TADO Liv Comfort Program (Comfy/OFF)","mode":"link","links":["27a718aace4233ae"],"x":3085,"y":1220,"wires":[]},{"id":"cab0745b37c20736","type":"group","z":"5fb50193cc6a2ad5","g":"efa7ba0cd44d77f9","name":"Outdoor Check Temperature","style":{"label":true},"nodes":["e6ae5404e8872f52","140d62014de27d0f","d51f7b96b706035f"],"x":1874,"y":959,"w":212,"h":202},{"id":"e6ae5404e8872f52","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"cab0745b37c20736","name":"Outdoor <=25","server":"","version":3,"outputs":2,"halt_if":"25","halt_if_type":"num","halt_if_compare":"lte","entity_id":"sensor.netatmo_devonport_tas_indoor_outdoor_temperature","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1980,"y":1120,"wires":[["140d62014de27d0f"],["0dced45aa0424202"]]},{"id":"140d62014de27d0f","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"cab0745b37c20736","name":"Outdoor <=21","server":"","version":3,"outputs":2,"halt_if":"21","halt_if_type":"num","halt_if_compare":"lte","entity_id":"sensor.netatmo_devonport_tas_indoor_outdoor_temperature","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1980,"y":1060,"wires":[["7427e5f7115d9b23"],["fc9de90693b45009"]]},{"id":"d51f7b96b706035f","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"cab0745b37c20736","name":"Outdoor  <=21","server":"","version":3,"outputs":2,"halt_if":"21","halt_if_type":"num","halt_if_compare":"lte","entity_id":"sensor.netatmo_devonport_tas_indoor_outdoor_temperature","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1980,"y":1000,"wires":[["7427e5f7115d9b23"],["fc9de90693b45009"]]},{"id":"147894e5cbd062c5","type":"group","z":"5fb50193cc6a2ad5","g":"efa7ba0cd44d77f9","name":"TADO Intergration Unavailable Use API","style":{"label":true},"nodes":["7109a465a826add3","235db10bbd6bacb6","9b0dbfc4dc35f873"],"x":1414,"y":1059,"w":252,"h":162},{"id":"7109a465a826add3","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"147894e5cbd062c5","name":"TADO: unavailable","server":"","version":3,"outputs":2,"halt_if":"unavailable","halt_if_type":"str","halt_if_compare":"is","entity_id":"climate.air_conditioning_downstairs","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1530,"y":1100,"wires":[["b754b820d2b0bb42"],["720bd89171807954"]]},{"id":"235db10bbd6bacb6","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"147894e5cbd062c5","name":"TADO: unavailable","server":"","version":3,"outputs":2,"halt_if":"unavailable","halt_if_type":"str","halt_if_compare":"is","entity_id":"climate.air_conditioning_downstairs","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1530,"y":1140,"wires":[["330ec0419e4bc16b"],["426a17bbbf625840"]]},{"id":"9b0dbfc4dc35f873","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"147894e5cbd062c5","name":"TADO: unavailable","server":"","version":3,"outputs":2,"halt_if":"unavailable","halt_if_type":"str","halt_if_compare":"is","entity_id":"climate.air_conditioning_downstairs","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1530,"y":1180,"wires":[["7ec8bbea4a70b892"],["6b7cd77d8b0d90f3"]]},{"id":"6b0716a73157c888","type":"group","z":"5fb50193cc6a2ad5","g":"efa7ba0cd44d77f9","name":"TADO Intergration Unavailable Use API","style":{"label":true},"nodes":["34609ecad79a6e23","137506c1ab439356","4e760bfc85386566"],"x":1414,"y":599,"w":252,"h":162},{"id":"34609ecad79a6e23","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"6b0716a73157c888","name":"TADO: unavailable","server":"","version":3,"outputs":2,"halt_if":"unavailable","halt_if_type":"str","halt_if_compare":"is","entity_id":"climate.air_conditioning","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1530,"y":640,"wires":[["63906bb6081aae1f"],["d51f7b96b706035f"]]},{"id":"137506c1ab439356","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"6b0716a73157c888","name":"TADO: unavailable","server":"","version":3,"outputs":2,"halt_if":"unavailable","halt_if_type":"str","halt_if_compare":"is","entity_id":"climate.air_conditioning","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1530,"y":680,"wires":[["349cab79ae84c936"],["140d62014de27d0f"]]},{"id":"4e760bfc85386566","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"6b0716a73157c888","name":"TADO: unavailable","server":"","version":3,"outputs":2,"halt_if":"unavailable","halt_if_type":"str","halt_if_compare":"is","entity_id":"climate.air_conditioning","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1530,"y":720,"wires":[["625d434943a374a0"],["e6ae5404e8872f52"]]},{"id":"018047ddf17ffb2c","type":"group","z":"5fb50193cc6a2ad5","g":"efa7ba0cd44d77f9","name":"Outdoor Check Temperature","style":{"label":true},"nodes":["6b7cd77d8b0d90f3","426a17bbbf625840","720bd89171807954"],"x":1874,"y":2419,"w":212,"h":202},{"id":"6b7cd77d8b0d90f3","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"018047ddf17ffb2c","name":"Outdoor <=25","server":"","version":3,"outputs":2,"halt_if":"25","halt_if_type":"num","halt_if_compare":"lte","entity_id":"sensor.netatmo_devonport_tas_indoor_outdoor_temperature","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1980,"y":2580,"wires":[["426a17bbbf625840"],["97706539517c04f2"]]},{"id":"426a17bbbf625840","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"018047ddf17ffb2c","name":"Outdoor <=21","server":"","version":3,"outputs":2,"halt_if":"21","halt_if_type":"num","halt_if_compare":"lte","entity_id":"sensor.netatmo_devonport_tas_indoor_outdoor_temperature","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1980,"y":2520,"wires":[["946fce7fdd85fbd4"],["fd3ec93ac1488b42"]]},{"id":"720bd89171807954","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"018047ddf17ffb2c","name":"Outdoor  <=21","server":"","version":3,"outputs":2,"halt_if":"21","halt_if_type":"num","halt_if_compare":"lte","entity_id":"sensor.netatmo_devonport_tas_indoor_outdoor_temperature","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1980,"y":2460,"wires":[["946fce7fdd85fbd4"],["fd3ec93ac1488b42"]]},{"id":"9807fada71ed6391","type":"group","z":"5fb50193cc6a2ad5","g":"efa7ba0cd44d77f9","name":"Catch All Errors","style":{"label":true},"nodes":["36fce5f6f17aab67","9695db893b016b53"],"x":814,"y":419,"w":382,"h":82},{"id":"36fce5f6f17aab67","type":"catch","z":"5fb50193cc6a2ad5","g":"9807fada71ed6391","name":"","scope":null,"uncaught":false,"x":900,"y":460,"wires":[["9695db893b016b53"]]},{"id":"9695db893b016b53","type":"debug","z":"5fb50193cc6a2ad5","g":"9807fada71ed6391","name":"Catch All Errors","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1070,"y":460,"wires":[]},{"id":"263dbbe3972f43bf","type":"group","z":"5fb50193cc6a2ad5","name":"Active Time","style":{"label":true},"nodes":["f437686397606f4a","d7c8edb9e823bd27","d09398021b4d814d","be0d8cde8442a180","68ac43bcec654138","a93423432f583619","5eaa16af82ccab13"],"x":4854,"y":799,"w":212,"h":582},{"id":"f437686397606f4a","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"263dbbe3972f43bf","name":"","startTime":"05:30:00","endTime":"00:00:00","outputs":2,"x":4950,"y":840,"wires":[["8701780326ae7eeb"],["3605821960ac5876"]]},{"id":"d7c8edb9e823bd27","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"263dbbe3972f43bf","name":"","startTime":"05:30:00","endTime":"00:00:00","outputs":2,"x":4950,"y":1040,"wires":[["0a4771a1513c87af"],["a93423432f583619"]]},{"id":"d09398021b4d814d","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"263dbbe3972f43bf","name":"","startTime":"05:30:00","endTime":"00:00:00","outputs":2,"x":4950,"y":1140,"wires":[["331c6b5ea7a86db2"],["5eaa16af82ccab13"]]},{"id":"be0d8cde8442a180","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"263dbbe3972f43bf","name":"","startTime":"05:30:00","endTime":"00:00:00","outputs":2,"x":4950,"y":1340,"wires":[["c6c781c0bb0a424a"],["331c6b5ea7a86db2"]]},{"id":"68ac43bcec654138","type":"time-of-day","z":"5fb50193cc6a2ad5","g":"263dbbe3972f43bf","name":"","startTime":"05:30:00","endTime":"00:00:00","outputs":2,"x":4950,"y":940,"wires":[["3605821960ac5876"],["0a4771a1513c87af"]]},{"id":"a93423432f583619","type":"link out","z":"5fb50193cc6a2ad5","g":"263dbbe3972f43bf","name":"TADO Liv Heating Program (Night/OFF)","mode":"link","links":["27a718aace4233ae"],"x":5025,"y":1080,"wires":[]},{"id":"5eaa16af82ccab13","type":"link out","z":"5fb50193cc6a2ad5","g":"263dbbe3972f43bf","name":"Liv Comfort Program (Night/OFF)","mode":"link","links":["27a718aace4233ae"],"x":5025,"y":1180,"wires":[]},{"id":"f7567f9bb61c7885","type":"group","z":"5fb50193cc6a2ad5","name":"Don't Set if Already Set","style":{"label":true},"nodes":["7e95fb1b4df948e2","a37a6c70d4401115","e3101ed1cf7cfb29","98abbe73d1dd4049","cee55bf086e931a0","5a0974c26826b7d7","014fa58858f951f3","f173d5041ae65880","0d34494c8a478896","27a718aace4233ae"],"x":3474,"y":799,"w":512,"h":602},{"id":"7e95fb1b4df948e2","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"f7567f9bb61c7885","name":"Living = off","server":"","version":3,"outputs":2,"halt_if":"off","halt_if_type":"jsonata","halt_if_compare":"is","entity_id":"climate.air_conditioning","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":3630,"y":1260,"wires":[[],["569e69b0899942ae"]]},{"id":"a37a6c70d4401115","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"f7567f9bb61c7885","name":"Living = heat","server":"","version":3,"outputs":2,"halt_if":"heat","halt_if_type":"str","halt_if_compare":"is","entity_id":"climate.air_conditioning","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":3890,"y":840,"wires":[[],["f437686397606f4a"]]},{"id":"e3101ed1cf7cfb29","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"f7567f9bb61c7885","name":"Living = Set Point 21","server":"","version":3,"outputs":2,"halt_if":"($entity().attributes.temperature) = 21","halt_if_type":"jsonata","halt_if_compare":"jsonata","entity_id":"climate.air_conditioning","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":3660,"y":1060,"wires":[["014fa58858f951f3"],["d7c8edb9e823bd27"]]},{"id":"98abbe73d1dd4049","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"f7567f9bb61c7885","name":"Living Set Point= 22","server":"","version":3,"outputs":2,"halt_if":"($entity().attributes.temperature) = 22","halt_if_type":"jsonata","halt_if_compare":"jsonata","entity_id":"climate.air_conditioning","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":3660,"y":960,"wires":[["5a0974c26826b7d7"],["68ac43bcec654138"]]},{"id":"cee55bf086e931a0","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"f7567f9bb61c7885","name":"Living Set Point= 23","server":"","version":3,"outputs":2,"halt_if":"($entity().attributes.temperature) = 23","halt_if_type":"jsonata","halt_if_compare":"jsonata","entity_id":"climate.air_conditioning","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":3660,"y":860,"wires":[["a37a6c70d4401115"],["f437686397606f4a"]]},{"id":"5a0974c26826b7d7","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"f7567f9bb61c7885","name":"Living = heat","server":"","version":3,"outputs":2,"halt_if":"heat","halt_if_type":"str","halt_if_compare":"is","entity_id":"climate.air_conditioning","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":3890,"y":940,"wires":[[],["68ac43bcec654138"]]},{"id":"014fa58858f951f3","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"f7567f9bb61c7885","name":"Living = heat","server":"","version":3,"outputs":2,"halt_if":"heat","halt_if_type":"str","halt_if_compare":"is","entity_id":"climate.air_conditioning","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":3890,"y":1040,"wires":[[],["d7c8edb9e823bd27"]]},{"id":"f173d5041ae65880","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"f7567f9bb61c7885","name":"Living = dry","server":"","version":3,"outputs":2,"halt_if":"dry","halt_if_type":"str","halt_if_compare":"is","entity_id":"climate.air_conditioning","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":3630,"y":1160,"wires":[[],["d09398021b4d814d"]]},{"id":"0d34494c8a478896","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"f7567f9bb61c7885","name":"Living = cool","server":"","version":3,"outputs":2,"halt_if":"cool","halt_if_type":"jsonata","halt_if_compare":"is","entity_id":"climate.air_conditioning","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":3630,"y":1360,"wires":[[],["be0d8cde8442a180"]]},{"id":"27a718aace4233ae","type":"link in","z":"5fb50193cc6a2ad5","g":"f7567f9bb61c7885","name":"TADO Living OFF","links":["a93423432f583619","5eaa16af82ccab13","a3de13b84f99e239","f3dc5e6e1109d0cd"],"x":3515,"y":1260,"wires":[["7e95fb1b4df948e2"]]},{"id":"37b339dd2ed54599","type":"group","z":"5fb50193cc6a2ad5","name":"Indoor Check Temperature","style":{"label":true},"nodes":["d3022db7eebcadbf","594079441157ef44","904caedf350a312c"],"x":2874,"y":2479,"w":192,"h":202},{"id":"d3022db7eebcadbf","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"37b339dd2ed54599","name":"Down <=21","server":"","version":3,"outputs":2,"halt_if":"21","halt_if_type":"num","halt_if_compare":"lte","entity_id":"sensor.air_conditioning_downstairs_temperature","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":2970,"y":2640,"wires":[["33c3bcc4bfd2c68b"],["076d08c06c3b1727"]]},{"id":"594079441157ef44","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"37b339dd2ed54599","name":"Down <=22","server":"","version":3,"outputs":2,"halt_if":"22","halt_if_type":"num","halt_if_compare":"lte","entity_id":"sensor.air_conditioning_downstairs_temperature","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":2970,"y":2580,"wires":[["fccb449f25cd59b1"],["33c3bcc4bfd2c68b"]]},{"id":"904caedf350a312c","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"37b339dd2ed54599","name":"Down  <=23","server":"","version":3,"outputs":2,"halt_if":"23","halt_if_type":"num","halt_if_compare":"lte","entity_id":"sensor.air_conditioning_downstairs_temperature","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":2970,"y":2520,"wires":[["3d0bd35c30452c9c"],["fccb449f25cd59b1"]]},{"id":"ae4fb0df664f15f8","type":"group","z":"5fb50193cc6a2ad5","name":"Don't Set if Already Set","style":{"label":true},"nodes":["306bf0571f6da32e","8357284394001c48","33c3bcc4bfd2c68b","fccb449f25cd59b1","3d0bd35c30452c9c","d3d22e86a65f0925","f91311cbbcd744c8","e9f6bf430bb7c0ee","2492d94c63b53f6c","c112dfd37781f285"],"x":3454,"y":2259,"w":512,"h":602},{"id":"306bf0571f6da32e","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"ae4fb0df664f15f8","name":"Down = off","server":"","version":3,"outputs":2,"halt_if":"off","halt_if_type":"jsonata","halt_if_compare":"is","entity_id":"climate.air_conditioning_downstairs","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":3610,"y":2720,"wires":[[],["19d8d6736c2c3cf3"]]},{"id":"8357284394001c48","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"ae4fb0df664f15f8","name":"Down = heat","server":"","version":3,"outputs":2,"halt_if":"heat","halt_if_type":"str","halt_if_compare":"is","entity_id":"climate.air_conditioning_downstairs","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":3870,"y":2300,"wires":[[],["a10464e759902260"]]},{"id":"33c3bcc4bfd2c68b","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"ae4fb0df664f15f8","name":"Down = Set Point 21","server":"","version":3,"outputs":2,"halt_if":"($entity().attributes.temperature) = 21","halt_if_type":"jsonata","halt_if_compare":"jsonata","entity_id":"climate.air_conditioning_downstairs","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":3640,"y":2520,"wires":[["f91311cbbcd744c8"],["ea6424075eed10be"]]},{"id":"fccb449f25cd59b1","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"ae4fb0df664f15f8","name":"Down Set Point= 22","server":"","version":3,"outputs":2,"halt_if":"($entity().attributes.temperature) = 22","halt_if_type":"jsonata","halt_if_compare":"jsonata","entity_id":"climate.air_conditioning_downstairs","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":3640,"y":2420,"wires":[["d3d22e86a65f0925"],["118330440e5cd271"]]},{"id":"3d0bd35c30452c9c","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"ae4fb0df664f15f8","name":"Down Set Point= 23","server":"","version":3,"outputs":2,"halt_if":"($entity().attributes.temperature) = 23","halt_if_type":"jsonata","halt_if_compare":"jsonata","entity_id":"climate.air_conditioning_downstairs","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":3640,"y":2320,"wires":[["8357284394001c48"],["a10464e759902260"]]},{"id":"d3d22e86a65f0925","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"ae4fb0df664f15f8","name":"Down = heat","server":"","version":3,"outputs":2,"halt_if":"heat","halt_if_type":"str","halt_if_compare":"is","entity_id":"climate.air_conditioning_downstairs","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":3870,"y":2400,"wires":[[],["118330440e5cd271"]]},{"id":"f91311cbbcd744c8","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"ae4fb0df664f15f8","name":"Down = heat","server":"","version":3,"outputs":2,"halt_if":"heat","halt_if_type":"str","halt_if_compare":"is","entity_id":"climate.air_conditioning_downstairs","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":3870,"y":2500,"wires":[[],["ea6424075eed10be"]]},{"id":"e9f6bf430bb7c0ee","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"ae4fb0df664f15f8","name":"Down = dry","server":"","version":3,"outputs":2,"halt_if":"dry","halt_if_type":"str","halt_if_compare":"is","entity_id":"climate.air_conditioning_downstairs","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":3610,"y":2620,"wires":[[],["7dd27f4fc2e01bb7"]]},{"id":"2492d94c63b53f6c","type":"api-current-state","z":"5fb50193cc6a2ad5","g":"ae4fb0df664f15f8","name":"Down = cool","server":"","version":3,"outputs":2,"halt_if":"cool","halt_if_type":"jsonata","halt_if_compare":"is","entity_id":"climate.air_conditioning_downstairs","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":3610,"y":2820,"wires":[[],["c3a0226f259053d4"]]},{"id":"c112dfd37781f285","type":"link in","z":"5fb50193cc6a2ad5","g":"ae4fb0df664f15f8","name":"TADO Down OFF","links":["c5e3899a37f93bae","d9f841710430930a","de5601b0639f951b","076d08c06c3b1727"],"x":3495,"y":2720,"wires":[["306bf0571f6da32e"]]},{"id":"83e627ce7e032c20","type":"tado-config","name":"Home"}]
Created 1 year, 11 months ago
Updated 1 year, 8 months ago
Rating: 5 3
  • catch (x1)
  • change (x1)
  • comment (x2)
  • debug (x4)
  • delay (x4)
  • file (x1)
  • file in (x1)
  • function (x25)
  • inject (x13)
  • join (x1)
  • link in (x6)
  • link out (x32)
  • switch (x65)
  • dew
  • point
  • tado
  • airconditioning
  • a/c
  • control
  • door
  • presence
  • light
  • notification
  • climate
  • climate-control
  • thermostat
  • temperature
  • TTS
  • Home
  • Assistant
  • dewpoint
  • heat
  • pump
  • heatpump
  • air
  • conditioning
  • room
  • detection
