node-red-contrib-tado-client 1.2.0
Tado web API client node for Node Red
npm install node-red-contrib-tado-client
Tado Web API Node with shared config
A Node-RED node with the shared configuration that lets you connect to the Tado Web API.
Please note: The library used by this node is derived from reverse engineering the Tado Web API and hence may be unstable.
[!IMPORTANT]
Tado has changed how authentication works! They no longer accept username/password based authentication. As such, this library has switched to the Oauth device flow. This is effective as of v1.0.0. Please upgrade ASAP to avoid broken integrations. See the examples/tado.json for more info.
[!IMPORTANT] From v0.9.0 onward this node requires at least nodejs v12 due to using async functions.
Node-RED Palette (Preferred)
You can install the node from the built-in Node-RED palette. It is available on the menu in the top-right corner of Node-RED, under the "Manage Palette" option; search for tado.
Using NPM
Run the following command in the root directory of your Node-RED install or home directory (usually ~/.node-red) and will also install needed libraries.
Getting Started
[!TIP] The example in examples/tado.json shows you how to complete device authentication and how to persist the refresh token between restarts of NoedRed
[!TIP] From v0.12.0 onwards TadoX support is available as a separate node
Install the Example Flow
There is an example flow available in the repo. I'd recommend giving it a go to trial the functionality available. Link to example
[!NOTE] You can currently only use a single instance of the "Tado Token" node within a flow. If you add more than one then only the latest node you added will work. This is a known issue.
Link to Node-RED documenation on import/export
The example can be installed from the Node-RED menu in the top-right, then choose "Import", and paste the JSON from the example into the box. It is a good idea to change the target to "New Flow" so you don't override any of your existing nodes. Once imported make sure to deploy the changes.
Find your home_id
In order to use most API calls you'll need to know your Tado home_id. This can be found using the first example (getMe) from the example flow. Make sure you've done the previous step and click the inject button to the left of the getMe node. You should see your home_id in the debug message pane on the righthand side. You can now edit other Tado nodes to include this home_id value.
Going further
You can create multiple Tado nodes, each of which interacts with a single end-point on the Tado API. Many are demoed in the example.
The node is triggered by each message on the input, regardless of content. This allows creating flows using other nodes to trigger the API. If the message on the input contains any of the following fields then they will ovewrite the properties on the node.
  • Account:
    • authenticate (msg.refreshToken)
    • getMe (msg.homeId)
  • Home:
    • getAirComfort (msg.homeId)
    • getAirComfortDetailed (msg.homeId)
    • getHeatingCircuits (msg.homeId)
    • getHome (msg.homeId)
    • getInstallations (msg.homeId)
    • getState (msg.homeId)
    • getUsers (msg.homeId)
    • getWeather (msg.homeId)
  • Zone:
    • getZones (msg.homeId)
    • clearZoneOverlay (msg.homeId, msg.zoneId)
    • getAwayConfiguration (msg.homeId, msg.zoneId)
    • getTimeTable (msg.homeId, msg.zoneId, msg.timetableId)
    • getTimeTables (msg.homeId, msg.zoneId)
    • getZoneCapabilities (msg.homeId, msg.zoneId)
    • getZoneControl (msg.homeId, msg.zoneId)
    • getZoneDayReport (msg.homeId, msg.zoneId, msg.reportDate)
    • getZoneOverlay (msg.homeId, msg.zoneId)
    • getZoneState (msg.homeId, msg.zoneId)
    • getZoneStates (msg.homeId)
    • setOpenWindowMode (msg.homeId, msg.zoneId, msg.openWindowMode)
    • setZoneOverlay (msg.homeId, msg.zoneId, msg.power, msg.temperature, msg.terminationType, msg.fanSpeed, msg.acMode)
  • Device:
    • getDevices (msg.homeId)
    • getDeviceTemperatureOffset (msg.deviceId)
    • identifyDevice (msg.deviceId)
    • setChildlock (msg.deviceId, msg.childlock)
    • setDeviceTemperatureOffset (msg.deviceId, msg.temperatureOffset)
    • setWindowDetection (msg.homeId, msg.zoneId, msg.windowDetection, msg.windowDetectionTimeout)
  • Mobile Device:
    • getMobileDevices (msg.homeId)
    • getMobileDevice (msg.homeId, msg.deviceId)
    • getMobileDeviceSettings (msg.homeId, msg.deviceId)
    • setGeoTracking (msg.homeId, msg.deviceId, msg.geoTracking)
  • Presence:
    • isAnyoneAtHome (msg.homeId)
    • setPresence (msg.homeId)
    • updatePresence (msg.homeId)
  • Energy IQ:
    • getEnergyIQ (msg.homeId)
    • getEnergyIQTariff (msg.homeId)
    • addEnergyIQTariff (msg.homeId, msg.unit, msg.startDate, msg.endDate, msg.tariffInCents)
    • updateEnergyIQTariff (msg.homeId, msg.tariffId, msg.unit, msg.startDate, msg.endDate, msg.tariffInCents)
    • getEnergyIQMeterReadings (msg.homeId)
    • addEnergyIQMeterReading (msg.homeId, msg.readingDate, msg.reading)
    • deleteEnergyIQMeterReading (msg.homeId)
[!NOTE] For AC users - Tado changed from FanSpeed to FanLevel. If you zone shows FanLevel then please use Level1, Level2, etc. as the FanSpeed parameter, otherwise use High, Medium, Low.
The response from the Tado API is represented in msg.payload and the generating API call is msg.topic.
Advanced Usage
It is now possible to make API calls that aren't in the list above but that have been implemented in the underlying library.
This can be done by injecting a msg.apiCall with the function name and a msg.payload with an array of arguments.
For instance to call the clearZoneOverlays API as defined here but not yet exposed in Node-RED, you could do the following.
  • Configure an Inject node with the following properties
    • msg.apiCall = clearZoneOverlays
    • msg.payload = [12345, [1, 2, 3]] - where 12345 is your home_id and [1, 2, 3] is a list of zones to clear
Other available apiCalls can be found by reading the library documenation but some noteworthy calls are:
  • clearZoneOverlays
  • setZoneOverlays
  • apiCall
    • This is the generic API call wrapper with authenticaion already handled you can call this method to test new API calls that even the underlying library doesn't yet support. If you find something useful then please open a PR or Issue with what you find. Thanks!
Examples of using this advanced functionality can be found in the examples here
Credits
This node is based on the work of SCPhillips
Version: 1.2.0
Updated 1 year, 1 month ago
Rating: 5.0 9
79 in the last week
  • tado-token
  • tado-config
  • tado
  • tadox-token
  • tadox-config
  • tadox
  • tado
