node-red-node-group 1.0.0
A Node-RED node to allow flows containing groups to be imported into Node-RED 1.0.x or earlier.
npm install node-red-node-group
node-red-node-group
A Node-RED node to allow flows containing groups to be imported into older versions of Node-RED.
The ability to create groups was introduced in Node-RED 1.1.0, adding a new core node type called group.
This module provides its own group node type that can be installed into older versions of Node-RED to allow them to run flows containing that type.
It does not provide any group-like functionality - it only registers a placeholder group node type.
The module will only register the type if it detects it is being loaded into Node-RED 1.0.x or older, otherwise it does nothing.
npm i node-red-node-group
Version: 1.0.0
Updated 7 years ago
Rating: 1.5 2
8 in the last week
  • group
