TTS: Full Text Weather Report, BOM Australia Integration, Extract Weather Warning Data & Other Text
Thanks @StormyKnight17 I thought I would place a few examples down on how I used your template examples. It actually took me a number of years to find, as this post does not come up easily in Google Search. This post has been made to help others point to the closed Severe Weather Alert Issue #37
THE SIX SENSORS BELOW MAKE ONE FULL WEATHER REPORT.
I did have it as one complete code in my configuration.yaml but it kept breaking, I had to divide it up. (obviously too long to parse)
Combining all templates in a Custom: Mushroom Template Card results in the below. This will parse as a complete code.
image Card changes colour, Crimson for Major or Minor warning_group_type.
NOTE: sensor.text_dewpoint_comfort_outside is created using Weather Word Descriptions from Dew Point, Temperature, VOC & Tado (Simple Air Comfort Card)
Template to place in Mushroom Template Card shown above:
type: custom:mushroom-template-card
primary: '{{ states(''sensor.devonport_short_text_0'') | upper}}'
secondary: >-
  {{ states('sensor.weather_report_warnings') }} {{
  states('sensor.weather_report_temperature') }} {{
  states('sensor.weather_report_conditions') }} {{-
  states('sensor.weather_report_conditions_2') }} {{
  states('sensor.weather_report_rain') }} {{
  states('sensor.weather_report_fire_uv') }}
icon: null
entity: button.weather_report
multiline_secondary: true
multiline_primary: true
tap_action:
  action: toggle
fill_container: true
icon_color: ''
card_mod:
  style: |
    ha-card  {
       --card-primary-font-size: 20px !important;
       --card-primary-line-height: 1.2
    ha-card  {
       --card-secondary-font-size: 20px !important;
       --card-secondary-line-height: 1.2
       --text-shadow: 0 0 3px #FF0000, 0 0 5px #0000FF !important;
    ha-card  {
      {% for state in states('sensor.devonport_warnings') %}
      {%- if '0' in state %}
      background: radial-gradient(circle, var(--ha-card-background), var(--ha-card-background), darkslategrey)
      {%- elif '1' in state %}
      background: radial-gradient(circle, var(--ha-card-background), var(--ha-card-background), deepskyblue)
      {%- elif '2' in state %}
      background: radial-gradient(circle, var(--ha-card-background), var(--ha-card-background), crimson)
      {%- elif '3' in state %}
      {%- elif '4' in state %}
      {%- endif -%}
      {%- endfor -%}
# Template Weather Warning Phase Text - Act as trigger for lovelace conditional card
Note: to prevent early execution of 'elif' statement:
  • (new and renewal) may need to change to (new and wal). or just (new)
  • (upgrade and downgrade) may need to change to (up and down) or just (grade)
  - platform: template
    sensors:
      weather_warning_phase:
        entity_id: sensor.devonport_warnings
        friendly_name: "Weather Warning Phase"
        value_template: >-
          {%- for state in state_attr('sensor.devonport_warnings', 'warnings') -%}
          {%- if 'new' in state.phase %}
          {{state.phase | upper}}
          {%- elif 'renewal' in state.phase %}
          {%- elif 'update' in state.phase %}
          {%- elif 'upgrade' in state.phase %}
          {%- elif 'downgrade' in state.phase %}
          {%- elif 'final' in state.phase %}
          {%- elif 'cancelled' in state.phase %}
          {%- endif -%}
          {%- endfor -%}
For use in Node Red The state from the sensors below are recombined into the full weather report that can be sent to TTS.
NOTE: There is a 255 Character limit on the condition report. This will return 'unknown' if the state of the BOM Extended Text Weather Report exceeds this limit.
NOTE: The state from 'sensor.your_location_extended_text_0' has been split to two sensors at 230 characters each. This includes room for text prior the condition report.
# Template Sensor Weather Report Text- BOM Current Feel - Temperature Report - TTS Input
    sensors:
      weather_report_temperature:
        entity_id: sensor.weather_report_temperature
        friendly_name: "Weather Report Temperature"
        value_template: >-
          {{'Currently it is'}}
          {{ states('sensor.netatmo_devonport_tas_indoor_outdoor_temperature', with_unit=true) }}
          {{'but feels like'}}
          {{ states('sensor.outside_feels_like_temperature',with_unit=true) }}
          {{', it is'}}
          {{ states('sensor.text_dewpoint_comfort_outside', with_unit=true)  | lower }}
          {{'and'}}
          {{states('sensor.text_temperature_comfort_outside', with_unit=true) | lower}}
          {{'outside. The '}}
          {{ states('sensor.devonport_now_now_label', with_unit=true) }}
          {{'is'}}
          {{ states('sensor.devonport_now_temp_now', with_unit=true) }}
          {{ states('sensor.devonport_now_later_label', with_unit=true) }}
          {{'will be'}}
          {{ states('sensor.devonport_now_temp_later', with_unit=true) }}
# Template Sensor Weather Report Text- BOM Current Feel - Temp and Conditions Report - TTS Input - To avoid 255 character limit spilt over two sensors.
    sensors:
      weather_report_conditions:
        entity_id: sensor.weather_report_conditions
        friendly_name: "Weather Report Conditions"
        value_template: >-
          {{'. Conditions are'}}
          {% set details = state_attr('sensor.devonport_extended_text_0', 'state') %}
          {{ details[:230] if state | length < 230 else '' -}}
      weather_report_conditions_2:
        entity_id: sensor.weather_report_conditions_2
        friendly_name: "Weather Report Conditions_2"
        value_template: >-
          {%- set details = state_attr('sensor.devonport_extended_text_0', 'state') %}
          {{- details[230:] if state | length < 230 else '' }}
# Template Sensor Weather Report Text - BOM Current rain and chance of rain - TTS Input
    sensors:
      weather_report_rain:
        entity_id: sensor.weather_report_rain
        friendly_name: "Weather Report Rain"
        value_template: >-
          {%- if is_state('sensor.devonport_rain_chance_0', '0') %}
          {{'There is No Rain Forecast, with'}}
          {{states('sensor.devonport_airport_rain_since_9am', with_unit=true) }}
          {{'since 9 AM.'}}
          {%- else %}
          {{'There is a'}}
          {{ states('sensor.devonport_rain_chance_0', with_unit=true) }}
          {{'chance of'}}
          {{ states('sensor.devonport_rain_amount_range_0', with_unit=true) }}
          {{'mm rain, with'}}
          {{ states('sensor.devonport_airport_rain_since_9am', with_unit=true) }}
          {{'since 9 AM.'}}
          {%- endif -%}
# Template Sensor Weather Report Text - BOM Current Fire Danger and UV - TTS Input
    sensors:
      weather_report_fire_uv:
        entity_id: sensor.weather_report_fire_uv
        friendly_name: "Weather Report Fire UV"
        value_template: >-
          {%- if is_state('sensor.devonport_fire_danger_0', 'unknown') %}
          {{'Fire Danger is LOW,'}}
          {%- else %}
          {{'Fire Danger Rating is'}}
          {{ states('sensor.devonport_fire_danger_0') | upper }}
          {%- endif -%}
          {%- if is_state('sensor.devonport_uv_category_0', 'unknown') %}
          {{'and NO UV'}}
          {%- else %}
          {{'and UV is'}}
          {{ states('sensor.devonport_uv_category_0') | upper }}
          {%- endif -%}
# Template Sensor Weather Report Text - BOM Current weather warnings - TTS Input
    sensors:
      weather_report_warnings:
        entity_id: sensor.weather_report_warnings
        friendly_name: "Weather Report Warnings"
        value_template: >-
          {%- for state in state_attr('sensor.devonport_warnings', 'warnings') %}
          {%- if 'cancelled' in state.phase %}
            NO WEATHER WARNINGS
          {%- elif 'minor' in state.warning_group_type%}
          {{ state.warning_group_type | upper}} {{ state.title | upper }}
          {%- elif 'major' in state.warning_group_type%}
          {%- endif %}
          {%- endfor -%}
To enter all of the above sensors into your configuration.yaml file just copy the below. Ensure it is under the -platform: template section. You will have to change the sensor names to your own entities. # ALL BOM TEXT SENSORS
    sensors:
        value_template: >-
          {%- endif -%}
          {%- endfor -%}
# Template Weather Report Text- BOM Current Feel - Temp Report - TTS Input
        value_template: >-
          {{', it is'}}
          {{'and'}}
          {{'outside. The '}}
          {{'is'}}
          {{'will be'}}
# Template Weather Report Text- BOM Current Conditions - TTS Input - To avoid 255 character limit spilt over two sensors.
        value_template: >-
        value_template: >-
# Template Weather Report Text - BOM Current rain and chance of rain - TTS Input
        value_template: >-
          {{'since 9am.'}}
          {%- else %}
          {{'There is a'}}
          {{'chance of'}}
          {{'mm rain, with'}}
          {{'since 9am.'}}
          {%- endif -%}
# Template Weather Report Text - BOM Current Fire Danger and UV - TTS Input
        value_template: >-
          {%- else %}
          {%- endif -%}
          {{'and NO UV'}}
          {%- else %}
          {{'and UV is'}}
          {%- endif -%}
# Template Weather Report Text - BOM Current weather warnings - TTS Input
        value_template: >-
            NO WEATHER WARNINGS
          {%- endif %}
          {%- endfor -%}
[{"id":"b10568117bd2249f","type":"group","z":"60be9160.d8815","name":"BOM WEATHER REPORTS","style":{"fill":"#bfdbef","fill-opacity":"0.5","label":true},"nodes":["52f23ec3.3b5e2","436314631faa644c","8e72667a7b8a53fb","8c03099508090358","e9250718e596a7a0","8e6a4b4896846515","8f9e710269a1ce06","6c339547ecab3316","c90fdc0c25c507b8"],"x":68,"y":53,"w":1638,"h":574},{"id":"52f23ec3.3b5e2","type":"debug","z":"60be9160.d8815","g":"b10568117bd2249f","name":"BOM","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1610,"y":100,"wires":[]},{"id":"436314631faa644c","type":"group","z":"60be9160.d8815","g":"b10568117bd2249f","name":"Send at Set Times or by button entity attached to mushroom template card.","style":{"label":true},"nodes":["7dabf8e3.27a638","6ad03f6fcb89fbcf","474339c540df3139","6cad931ac5e45a2f","3d638cc8a92265d7"],"x":94,"y":79,"w":473,"h":322},{"id":"7dabf8e3.27a638","type":"inject","z":"60be9160.d8815","g":"436314631faa644c","name":"08:00","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"00 08 * * 1,2,3,4,5","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":185,"y":180,"wires":[["8e62e35b.288c1","3f68e608c8a43e22","fbf8ad71d2094160","b51ad8c87f4478b2","e27ab99566eba5a6","36c183f0734f2a6d"]],"l":false},{"id":"6ad03f6fcb89fbcf","type":"inject","z":"60be9160.d8815","g":"436314631faa644c","name":"08:45","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"45 08 * * 6,0","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":185,"y":240,"wires":[["8e62e35b.288c1","3f68e608c8a43e22","fbf8ad71d2094160","b51ad8c87f4478b2","e27ab99566eba5a6","36c183f0734f2a6d"]],"l":false},{"id":"474339c540df3139","type":"inject","z":"60be9160.d8815","g":"436314631faa644c","name":"17:50","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"50 17 * * *","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":185,"y":300,"wires":[["8e62e35b.288c1","3f68e608c8a43e22","fbf8ad71d2094160","b51ad8c87f4478b2","e27ab99566eba5a6","36c183f0734f2a6d"]],"l":false},{"id":"6cad931ac5e45a2f","type":"inject","z":"60be9160.d8815","g":"436314631faa644c","name":"19:30","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"30 19 * * *","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":185,"y":360,"wires":[["8e62e35b.288c1","3f68e608c8a43e22","fbf8ad71d2094160","b51ad8c87f4478b2","e27ab99566eba5a6","36c183f0734f2a6d"]],"l":false},{"id":"3d638cc8a92265d7","type":"ha-button","z":"60be9160.d8815","g":"436314631faa644c","name":"Weather Report","version":0,"debugenabled":false,"outputs":1,"entityConfig":"d80419cf90c3e120","outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"x":200,"y":120,"wires":[["e27ab99566eba5a6","8e62e35b.288c1","3f68e608c8a43e22","fbf8ad71d2094160","b51ad8c87f4478b2","36c183f0734f2a6d"]]},{"id":"d80419cf90c3e120","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"1de690ce29283996","name":"Weather Report","version":"6","entityType":"button","haConfig":[{"property":"name","value":"Weather Report"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"bb380e72.b8825","type":"server","name":"Home Assistant","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":"30","areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true},{"id":"1de690ce29283996","type":"ha-device-config","name":"Weather Report","hwVersion":"","manufacturer":"Node-RED","model":"","swVersion":""},{"id":"8e72667a7b8a53fb","type":"group","z":"60be9160.d8815","g":"b10568117bd2249f","name":"Current state of template sensors.","style":{"label":true},"nodes":["8e62e35b.288c1","3f68e608c8a43e22","fbf8ad71d2094160","b51ad8c87f4478b2","e27ab99566eba5a6","36c183f0734f2a6d"],"x":394,"y":119,"w":432,"h":382},{"id":"8e62e35b.288c1","type":"api-current-state","z":"60be9160.d8815","g":"8e72667a7b8a53fb","name":"","server":"bb380e72.b8825","version":3,"outputs":2,"halt_if":"boo","halt_if_type":"str","halt_if_compare":"is_not","entity_id":"sensor.weather_report_conditions","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":600,"y":220,"wires":[["ab3edfca4a37ee06"],[]]},{"id":"3f68e608c8a43e22","type":"api-current-state","z":"60be9160.d8815","g":"8e72667a7b8a53fb","name":"","server":"bb380e72.b8825","version":3,"outputs":2,"halt_if":"boo","halt_if_type":"str","halt_if_compare":"is_not","entity_id":"sensor.weather_report_rain","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":580,"y":340,"wires":[["70b0190cf16a65b0"],[]]},{"id":"fbf8ad71d2094160","type":"api-current-state","z":"60be9160.d8815","g":"8e72667a7b8a53fb","name":"","server":"bb380e72.b8825","version":3,"outputs":2,"halt_if":"boo","halt_if_type":"str","halt_if_compare":"is_not","entity_id":"sensor.weather_report_fire_uv","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":590,"y":400,"wires":[["4f888875dd178dfd"],[]]},{"id":"b51ad8c87f4478b2","type":"api-current-state","z":"60be9160.d8815","g":"8e72667a7b8a53fb","name":"","server":"bb380e72.b8825","version":3,"outputs":2,"halt_if":"boo","halt_if_type":"str","halt_if_compare":"is_not","entity_id":"sensor.weather_report_warnings","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":600,"y":460,"wires":[["d4a20e9115d79bfb"],[]]},{"id":"e27ab99566eba5a6","type":"api-current-state","z":"60be9160.d8815","g":"8e72667a7b8a53fb","name":"","server":"bb380e72.b8825","version":3,"outputs":2,"halt_if":"boo","halt_if_type":"str","halt_if_compare":"is_not","entity_id":"sensor.weather_report_temperature","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":610,"y":160,"wires":[["8bdc113a65ce9153"],[]]},{"id":"36c183f0734f2a6d","type":"api-current-state","z":"60be9160.d8815","g":"8e72667a7b8a53fb","name":"","server":"bb380e72.b8825","version":3,"outputs":2,"halt_if":"boo","halt_if_type":"str","halt_if_compare":"is_not","entity_id":"sensor.weather_report_conditions_2","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":610,"y":280,"wires":[["4af196b5cfc59e7e"],[]]},{"id":"8c03099508090358","type":"group","z":"60be9160.d8815","g":"b10568117bd2249f","name":"Delay messages in order","style":{"label":true},"nodes":["3eb8859467fdea12","70b0190cf16a65b0","4f888875dd178dfd","d4a20e9115d79bfb","8bdc113a65ce9153"],"x":1034,"y":119,"w":192,"h":382},{"id":"3eb8859467fdea12","type":"delay","z":"60be9160.d8815","g":"8c03099508090358","name":"","pauseType":"delay","timeout":"2","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":1120,"y":220,"wires":[["dc53debf5e0f3a1f"]]},{"id":"70b0190cf16a65b0","type":"delay","z":"60be9160.d8815","g":"8c03099508090358","name":"","pauseType":"delay","timeout":"2.2","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":1130,"y":340,"wires":[["dc53debf5e0f3a1f"]]},{"id":"4f888875dd178dfd","type":"delay","z":"60be9160.d8815","g":"8c03099508090358","name":"","pauseType":"delay","timeout":"2.3","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":1130,"y":400,"wires":[["dc53debf5e0f3a1f"]]},{"id":"d4a20e9115d79bfb","type":"delay","z":"60be9160.d8815","g":"8c03099508090358","name":"","pauseType":"delay","timeout":"2.4","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":1130,"y":460,"wires":[["dc53debf5e0f3a1f"]]},{"id":"8bdc113a65ce9153","type":"delay","z":"60be9160.d8815","g":"8c03099508090358","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":1130,"y":160,"wires":[["dc53debf5e0f3a1f"]]},{"id":"e9250718e596a7a0","type":"group","z":"60be9160.d8815","g":"b10568117bd2249f","name":"Join and send after 6","style":{"label":true},"nodes":["dc53debf5e0f3a1f"],"x":1254,"y":119,"w":232,"h":82},{"id":"dc53debf5e0f3a1f","type":"join","z":"60be9160.d8815","g":"e9250718e596a7a0","name":"Weather Report","mode":"custom","build":"string","property":"payload","propertyType":"msg","key":"topic","joiner":" ","joinerType":"str","accumulate":false,"timeout":"","count":"6","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":1370,"y":160,"wires":[["c8812fd4f0b26ac8"]]},{"id":"8e6a4b4896846515","type":"group","z":"60be9160.d8815","g":"b10568117bd2249f","name":"Change abbreviations","style":{"label":true},"nodes":["c8812fd4f0b26ac8"],"x":1274,"y":219,"w":212,"h":82},{"id":"c8812fd4f0b26ac8","type":"change","z":"60be9160.d8815","g":"8e6a4b4896846515","name":"","rules":[{"t":"change","p":"payload","pt":"msg","from":"°C","fromt":"str","to":"degrees","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"km/h","fromt":"str","to":"kilometers per hour","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"mm","fromt":"str","to":"millimeters","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Max","fromt":"str","to":"Maximum","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"comfy","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Overnight min","fromt":"str","to":"Overnight Minimum","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"9am.","fromt":"str","to":"9 AM. ","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1380,"y":260,"wires":[["52f23ec3.3b5e2","52b5c08ffc191b8b"]]},{"id":"8f9e710269a1ce06","type":"group","z":"60be9160.d8815","g":"b10568117bd2249f","name":"Output to TTS Speaker Group","style":{"label":true},"nodes":["306336766891dd5e"],"x":1434,"y":419,"w":232,"h":82},{"id":"306336766891dd5e","type":"api-call-service","z":"60be9160.d8815","g":"8f9e710269a1ce06","name":"TTS Attic Speaker","server":"bb380e72.b8825","version":7,"debugenabled":true,"action":"tts.cloud_say","floorId":[],"areaId":[],"deviceId":[],"entityId":[],"labelId":[],"data":"{ \"entity_id\":\"media_player.attic_speaker\",\"message\": msg.payload }","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"tts","service":"cloud_say","x":1550,"y":460,"wires":[["52f23ec3.3b5e2"]]},{"id":"6c339547ecab3316","type":"group","z":"60be9160.d8815","g":"b10568117bd2249f","name":"If state exceed 254 characters and returns 'unknown', read the BOM Extended Text 0 instead. Two Sensor Split should not require this.","style":{"label":true,"fill":"#ff0000","fill-opacity":"0.42","color":"#000000"},"nodes":["ab3edfca4a37ee06","9876127b964a1dcd"],"x":594,"y":519,"w":842,"h":82},{"id":"ab3edfca4a37ee06","type":"api-current-state","z":"60be9160.d8815","g":"6c339547ecab3316","name":"Conditions Unknown","server":"bb380e72.b8825","version":3,"outputs":2,"halt_if":"unknown","halt_if_type":"str","halt_if_compare":"is_not","entity_id":"sensor.weather_report_conditions","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":720,"y":560,"wires":[["3eb8859467fdea12"],["9876127b964a1dcd"]]},{"id":"9876127b964a1dcd","type":"api-current-state","z":"60be9160.d8815","g":"6c339547ecab3316","name":"","server":"bb380e72.b8825","version":3,"outputs":2,"halt_if":"boo","halt_if_type":"str","halt_if_compare":"is_not","entity_id":"sensor.devonport_extended_text_0","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1050,"y":560,"wires":[["3eb8859467fdea12"],[]]},{"id":"c90fdc0c25c507b8","type":"group","z":"60be9160.d8815","g":"b10568117bd2249f","name":"TTS only between times","style":{"label":true},"nodes":["52b5c08ffc191b8b"],"x":1434,"y":319,"w":192,"h":82},{"id":"52b5c08ffc191b8b","type":"time-of-day","z":"60be9160.d8815","g":"c90fdc0c25c507b8","name":"","startTime":"06:00:00","endTime":"21:00:00","outputs":1,"x":1530,"y":360,"wires":[["306336766891dd5e"]]}]
Created 2 years, 9 months ago
Updated 1 year, 11 months ago
Rating: 5 4
  • change (x1)
  • delay (x5)
  • inject (x4)
  • join (x1)
  • BOM
  • Weather
  • Australia
  • Text
  • To
  • Speech
  • TTS
  • Report
  • Full
