Weather Word Descriptions from Dew Point, Temperature, VOC & Tado (Simple Air Comfort Card)
Putting words to what it feels like
This flow converts numeric temperature and humidity values into text descriptions. Makes them available in Home Assistant and use in Simple Air Comfort Card or other Custom Cards.
It contains 5 methods.
  • TADO COMFORT TEXT DESCRIPTION (TADO API)
    • Humidty DRY, COMFY, HUMID
    • Temperature COLD, COMFY, WARM
    • Gets the words from Tado API, Funtion Node filters based on payload address.
    • Requires node-red-tado-client to extract the text description from the Tado API
    • Requires Node-RED Companion Integration
  • HUMIDITY COMFORT TEXT DESCRIPTION (NON TADO DEVICES)
    • Humidty , DRY(<39.9%),(40%)**COMFY**(59.9%)**, **HUMID**(>60%) (Same as Tado)
    • Switches Temperatures to words based on the above values. msg.topic changes the words
    • Requires any Temperature Sensors.
  • TEMPERATURE COMFORT TEXT DESCRIPTION
  • VOC TEXT DESCRIPTION
    • VOC ppm Changes words based on the below values:
SIMPLE AIR COMFORT CARD
THE DESCRIPTIONS CAN BE USED AS A TEXT DESCRIPTION IN THE
CODE FOR TABLET AND PHONE VERSIONS CAN BE FOUND HERE
Inside Colour Scale for Dewpoint Comfort, Background Colour Scale for Temperature Comfort
image image
THIS IS USED TO CONNECT TO THE TADO API AND GET THE TEXT DESCRIPTION FOR THE TEMP AND HUMIDITY.
TADO Temp(COLD,COMFY,WARM) - Humidity (DRY,COMFY,HUMID)
REQUIREMENTS: node-red-contrib-tado-client
TADO [getMe] Node Setup
  1. Double Click Tado [getMe] Node, Add a New Tado Config...
  2. Enter your TADO Account login details into the config.
  3. Click Done.
  4. Click the Inject Node timestamp.
  5. Find your homes ID in the debug message [window payload.homes[0].id]
TADO Other Nodes
  1. Enter your Home ID into the other Nodes to fetch information from the API
  2. Click the time stamp into the Tado [getAirComfort] Node
  3. Find the path >_Copy Path Button in the Debug Node [payload.comfort[0].temperatureLevel]
Function Node
  1. Copy the path above into the Function Node
  2. CLICK the Inject Node timestamp to Test
  3. Your sensor should display the text and be in home assistant, updated every 1 minute.
DEWPOINT COMFORT TEXT DESCRIPTION
  1. INSTALL DewPoint Sensor Calculator via HACS
  2. You will have to add as a Custom Repository using the 3 Dot menu top right in HACS.
  3. CLICK INTEGRATIONS in HACS
  4. CLICK 3 button menu top right
  5. CLICK Custom Repositories
  6. PASTE https://github.com/miguelangel-nubla/home-assistant-dewpoint in the Repository Field
  7. SELECT Integration in the Category field
  8. CLICK ADD
  9. RESTART HOME assistant
  10. Setup your sensors in your configuration.yaml file.
sensor:
  - platform: dewpoint
    sensors:
      dewpoint_outside:
        temperature: sensor.temperature_outside
        rel_hum: sensor.humidity_outside
      dewpoint_office:
        temperature: sensor.temperature_office
        rel_hum: sensor.humidity_office
  1. Insert your dewpoint sensor in the 'Current State' Node
  1. Insert your temperature sensor in the 'Current State' Node
VOC COMFORT DESCRIPTION
HUMIDITY COMFORT DESCRIPTION (NON TADO DEVICES)
[{"id":"f237a1dd1abe1cd9","type":"tab","label":"Simple Air Comfort Card Sensors","disabled":false,"info":"","env":[]},{"id":"7c164373aa514aec","type":"group","z":"f237a1dd1abe1cd9","name":"TADO COMFORT TEXT SENSORS.","style":{"label":true,"fill":"#c8e7a7","fill-opacity":"0.51"},"nodes":["3e9d7930ad5ef2e2","8b3e4c26c811bf70","6e7576d933a4a995","0976b872320eb2ed","dfeb4a856de32953","eb6e8e648150dc02","067ec60416625ff7","a13b62ed5cc45ee2","3e561ba962e64a61","afb0e3ef57ccacfd","784310d2ebfd2ae6","e5b698adeabc5816","739e05a3d64c2da4","7340f2b650af8378","665b5d60fec3d32d","5b958659dfd88fad","2e1dfe39a0384499","ce0aea9208f6ad30","5f1664d7fde0423f","3146be8f10fe5e42","1484ca91eadc7641","9d97559fd81b9dd0","aabda1c5b7dc9d42"],"x":174,"y":99,"w":1292,"h":602},{"id":"9a17701f3c3b0fc1","type":"group","z":"f237a1dd1abe1cd9","name":"Airport Dewpoint Comfort Text","style":{"fill":"#dbcbe7","fill-opacity":"0.5","label":true},"nodes":["8bc3fa49098a601b","3b2eb7ae5480f2ee","695f89695769ff11","f5053ff4effe1c23","f64eaecb9ed52a50","48ef65b09bcded05","5aa3e602f8a20b33","4515910338f10a06","83f7c125142933fb","3f3622b80e1657e1","6d54ea7e436fdd0f","398d3e272ac8a486"],"x":314,"y":779,"w":1152,"h":362},{"id":"48ad0e7ff822c6a9","type":"group","z":"f237a1dd1abe1cd9","name":"Downstairs Dewpoint Comfort Text","style":{"fill":"#dbcbe7","fill-opacity":"0.5","label":true},"nodes":["8489effe51fa5eb6","0b134345a349d83b","cc5dbf09ea45e71b","3f68e9bfaa09c070","3486be1d0e386178","6f38643d9059912c","19c664435672d812","5b4b61eac912be03","aa94fc645be3070b","bd01c8e8f9fe379b","cd9138b79abaffd9","b48444f3d60b498c","d65f4f34e12a7551"],"x":314,"y":1179,"w":1152,"h":382},{"id":"8d0916b3abd91aaf","type":"group","z":"f237a1dd1abe1cd9","name":"Outside Dewpoint Comfort Text","style":{"fill":"#dbcbe7","fill-opacity":"0.5","label":true},"nodes":["e6c45cbdc415a6d1","d8061e7582df2c57","85eebef2c46fcc91","d5f1ea380a16e324","faeccb281c6f0b1f","946cc750eab1ee96","67f9d5dd013c1f5a","93465b309fd7dac9","28e29142ee21761c","8d40a0ac16d3c5ac","04494c08542c992c","19a06e9a85a0bb61"],"x":314,"y":1999,"w":1152,"h":362},{"id":"0f4795eb69eae00e","type":"group","z":"f237a1dd1abe1cd9","name":"Living Room Dewpoint Comfort Text","style":{"label":true,"fill":"#dbcbe7","fill-opacity":"0.5"},"nodes":["e34dcc93f44c3d94","3fe02323d89e5294","c903d4f10333b6e5","97e08e6c2ac74cd5","e005f94a8c53a86e","383be06b3c4c3ac3","0c7efadde29059f1","7e28dcfa1b66c2ec","2d79cbc4d09e58b9","109144d6bc7a39aa","9ea82db21c925370","70ffe3834f6b54f5"],"x":314,"y":1599,"w":1152,"h":362},{"id":"5ffc1a5a6ebe585d","type":"group","z":"f237a1dd1abe1cd9","name":"ALTERNATE WORDS","style":{"label":true},"nodes":["cce7a5ceb2d2b421","6549925f36452186","0dc0670a6176a313","b220e62e3497febd","1adb668ec5929abd","c091e0276ce24310","cdea3d146507b5e5","252106f7f789f4d5"],"x":1554,"y":779,"w":232,"h":362},{"id":"464b08b13eac8e80","type":"group","z":"f237a1dd1abe1cd9","name":"Upstairs Dewpoint Comfort Text","style":{"fill":"#dbcbe7","fill-opacity":"0.5","label":true},"nodes":["4f6206903db8ae50","2b0c58a8c7e8c3ba","222d5288c6e9d93a","349e06a3f9b7618f","56347a7a958a055a","c302b2a12f056b68","d19aabf91cc2aa31","b01bf5f56286421e","23b96a50f7055363","7596a5f28d083515","179a13c53c92291f","ec09b041e140027d"],"x":314,"y":2419,"w":1152,"h":362},{"id":"4616a089546015eb","type":"group","z":"f237a1dd1abe1cd9","name":"Living Room Temperature Text","style":{"label":true,"fill":"#ffbfbf","fill-opacity":"0.5"},"nodes":["01ade7c603a0278a","7d083f6bcf50f0e7","02120a55de03ad84","4139e79aa75c7e2d","32425e5617adc3a9","098af15c31d17d3c","cc2fc8d30cebef9b","a71bf10c204b11a7","92681abd85e6d7e6","3af088de0d22d148","2d17f6da19bbf9cf","1350f30d8ae3a655","878ac0e5286fb69e"],"x":314,"y":3819,"w":1152,"h":402},{"id":"7173d8039a32824a","type":"group","z":"f237a1dd1abe1cd9","name":"Airport Temperature Text","style":{"label":true,"fill":"#ffbfbf","fill-opacity":"0.5"},"nodes":["2b47e87df5456f1e","a083e1f4b198eb9b","746e5a6f4a507a1d","f571663c63cd6dd6","1acb7c36ee246281","68c14f9c18e60ff0","6492a0d7bd1b8779","d0fc2ade8c489745","566c7b94d768a106","24312ce259dacccc","0522bfd494e822ef","7e0d497a2d590aae","e4105f49340f7c3c"],"x":314,"y":2899,"w":1152,"h":402},{"id":"f6b19d555014ff15","type":"group","z":"f237a1dd1abe1cd9","name":"Downstairs Temperature Text","style":{"label":true,"fill":"#ffbfbf","fill-opacity":"0.5"},"nodes":["95e55f5f943cf7f8","35476ea18f4dde18","cb0d6a67af050555","f43b0538fbf13249","b49eae849b2c426a","ba6c0d6b74180bb0","21aef8b707a080fc","7b428cb57eef154e","475a39a5bc2457ec","460bd517152bf5af","61f7e5ebda9c275d","6dd2720d885a899b","1f7d36222ea60cca"],"x":314,"y":3359,"w":1152,"h":402},{"id":"46cbcbb3dce71e3b","type":"group","z":"f237a1dd1abe1cd9","name":"Outside Temperature Text","style":{"label":true,"fill":"#ffbfbf","fill-opacity":"0.5"},"nodes":["14270cd891cb07b3","c14fd408d848be75","14d3af4350fd070e","9c8ee840f1b4d922","b0aefece994685cd","e4f9f511900f900e","1cf33882938d2e07","485127c9766bfe03","5912869d401d455d","d18d868830dd46d9","f613c3ef927ca02f","04496ce1c49de1bc","000fe7b1476b9767"],"x":314,"y":4279,"w":1152,"h":402},{"id":"fb4a75e8044bdf96","type":"group","z":"f237a1dd1abe1cd9","name":"Upstairs Temperature Text","style":{"label":true,"fill":"#ffbfbf","fill-opacity":"0.5"},"nodes":["bed1a9c8914d2bc3","1f666e01e8dfe971","dd99428e6357d9a5","14f36c65bd6565e8","e374d0c96d5b5532","af4c038a21b059ac","3f2e4788bc1ebb9a","a67794d2b5c2f1c0","064496cf8fde5e4b","b7fa37744b40e723","1ccce3796e2197ca","62c47b13aecb727a","ee3689a3d3e307e2"],"x":314,"y":4739,"w":1152,"h":402},{"id":"faf3195d9122a4d0","type":"group","z":"f237a1dd1abe1cd9","name":"Aquarium Air Quality Text","style":{"fill":"#ffffbf","fill-opacity":"0.49","label":true},"nodes":["ba60e6d88367f9d5","9a94494992cbd042","cdd0ad438e9b2b51","43b280fe01c9c81e","52b807f3895ebd25","083726a3bf488ea2","ecb84b7b7811be73"],"x":314,"y":5199,"w":1112,"h":182},{"id":"a36def9e9bfa7cae","type":"group","z":"f237a1dd1abe1cd9","name":"Airport Humidity Comfort Text","style":{"fill":"#bfdbef","fill-opacity":"0.5","label":true},"nodes":["a04e394b91fc7fda","3b1dc7d124b06903","c9e972176eb2f6c9","0b836404f77474d0","555397890103c20c","474d0e785e496c01","2282ceefc90b8d2b"],"x":314,"y":5439,"w":1112,"h":182},{"id":"af783cc74b08fab8","type":"group","z":"f237a1dd1abe1cd9","name":"Outside Humidty Comfort Text","style":{"fill":"#bfdbef","fill-opacity":"0.5","label":true},"nodes":["e0b40a80f10ff490","87bb7ab68b0b96c4","d4279e9508816950","a515247b1d1cf793","1051e9e0197952f3","7f3f96f1d570143c","69e20f0ade971756"],"x":314,"y":5679,"w":1112,"h":182},{"id":"fa9293e728faf3fa","type":"group","z":"f237a1dd1abe1cd9","name":"Upstairs Humidity Comfort Text","style":{"fill":"#bfdbef","fill-opacity":"0.5","label":true},"nodes":["aa2587cf2a922c74","8f8d44caa8de0719","e3ba472d66a26bc2","45929454771a71cd","60dd93ddb3065f98","3a2a31454e530b73","4ffafa2fa44a7440"],"x":314,"y":5919,"w":1112,"h":182},{"id":"d65f4f34e12a7551","type":"junction","z":"f237a1dd1abe1cd9","g":"48ad0e7ff822c6a9","x":1100,"y":1380,"wires":[["cc5dbf09ea45e71b"]]},{"id":"3e9d7930ad5ef2e2","type":"function","z":"f237a1dd1abe1cd9","g":"7c164373aa514aec","name":"Humid Downstairs","func":"msg.payload = msg.payload.comfort[1].humidityLevel\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":910,"y":420,"wires":[["7340f2b650af8378"]]},{"id":"8b3e4c26c811bf70","type":"tado","z":"f237a1dd1abe1cd9","g":"7c164373aa514aec","configName":"83e627ce7e032c20","apiCall":"getAirComfortDetailed","homeId":"668738","acMode":"AUTO","childlock":false,"deviceId":"","fanSpeed":"AUTO","geoTracking":true,"name":"","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","endDate":"","tariffId":"","tariffInCents":0,"temperature":"18","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","windowDetection":true,"windowDetectionTimeout":900,"zoneId":"","x":580,"y":300,"wires":[["0976b872320eb2ed"]]},{"id":"6e7576d933a4a995","type":"inject","z":"f237a1dd1abe1cd9","g":"7c164373aa514aec","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":280,"y":300,"wires":[["8b3e4c26c811bf70"]]},{"id":"0976b872320eb2ed","type":"debug","z":"f237a1dd1abe1cd9","g":"7c164373aa514aec","name":"debug 6","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":880,"y":260,"wires":[]},{"id":"dfeb4a856de32953","type":"tado","z":"f237a1dd1abe1cd9","g":"7c164373aa514aec","configName":"83e627ce7e032c20","apiCall":"getMe","homeId":"","acMode":"AUTO","childlock":false,"deviceId":"","fanSpeed":"AUTO","geoTracking":true,"name":"","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","endDate":"","tariffId":"","tariffInCents":0,"temperature":"18","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","windowDetection":true,"windowDetectionTimeout":900,"zoneId":"","x":530,"y":180,"wires":[["0976b872320eb2ed"]]},{"id":"eb6e8e648150dc02","type":"tado","z":"f237a1dd1abe1cd9","g":"7c164373aa514aec","configName":"83e627ce7e032c20","apiCall":"getAirComfort","homeId":"668738","acMode":"AUTO","childlock":false,"deviceId":"","fanSpeed":"AUTO","geoTracking":true,"name":"","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"","startDate":"","endDate":"","tariffId":"","tariffInCents":0,"temperature":"18","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","windowDetection":true,"windowDetectionTimeout":900,"zoneId":"","x":560,"y":360,"wires":[["0976b872320eb2ed","afb0e3ef57ccacfd","3e9d7930ad5ef2e2","784310d2ebfd2ae6","e5b698adeabc5816","3146be8f10fe5e42","1484ca91eadc7641"]]},{"id":"067ec60416625ff7","type":"inject","z":"f237a1dd1abe1cd9","g":"7c164373aa514aec","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"60","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":290,"y":360,"wires":[["eb6e8e648150dc02"]]},{"id":"a13b62ed5cc45ee2","type":"tado","z":"f237a1dd1abe1cd9","g":"7c164373aa514aec","configName":"83e627ce7e032c20","apiCall":"getWeather","homeId":"668738","acMode":"AUTO","childlock":false,"deviceId":"","fanSpeed":"AUTO","geoTracking":true,"name":"","openWindowMode":true,"power":"on","presence":"HOME","reading":0,"readingDate":"","readingId":"","reportDate":"2024-03-10","startDate":"","endDate":"","tariffId":"","tariffInCents":0,"temperature":"18","temperatureOffset":0,"terminationTimeout":900,"terminationType":"manual","timetableId":"","unit":"m3","windowDetection":true,"windowDetectionTimeout":900,"zoneId":"1","x":550,"y":240,"wires":[["0976b872320eb2ed"]]},{"id":"3e561ba962e64a61","type":"inject","z":"f237a1dd1abe1cd9","g":"7c164373aa514aec","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":280,"y":240,"wires":[["a13b62ed5cc45ee2"]]},{"id":"afb0e3ef57ccacfd","type":"function","z":"f237a1dd1abe1cd9","g":"7c164373aa514aec","name":"Humid Liv","func":"msg.payload = msg.payload.comfort[0].humidityLevel\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":880,"y":360,"wires":[["739e05a3d64c2da4"]]},{"id":"784310d2ebfd2ae6","type":"function","z":"f237a1dd1abe1cd9","g":"7c164373aa514aec","name":"Temp Liv","func":"msg.payload = msg.payload.comfort[0].temperatureLevel\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":880,"y":480,"wires":[["5b958659dfd88fad"]]},{"id":"e5b698adeabc5816","type":"function","z":"f237a1dd1abe1cd9","g":"7c164373aa514aec","name":"Temp Downstairs","func":"msg.payload = msg.payload.comfort[1].temperatureLevel\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":910,"y":540,"wires":[["665b5d60fec3d32d"]]},{"id":"739e05a3d64c2da4","type":"ha-sensor","z":"f237a1dd1abe1cd9","g":"7c164373aa514aec","name":"Text Humid Comfort Living Room TADO","entityConfig":"342e9f732e307789","version":0,"state":"payload","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":1220,"y":360,"wires":[[]]},{"id":"7340f2b650af8378","type":"ha-sensor","z":"f237a1dd1abe1cd9","g":"7c164373aa514aec","name":"Text Humid Comfort Downstairs TADO","entityConfig":"0bea21c95733d694","version":0,"state":"payload","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":1210,"y":420,"wires":[[]]},{"id":"665b5d60fec3d32d","type":"ha-sensor","z":"f237a1dd1abe1cd9","g":"7c164373aa514aec","name":"Text Temp Comfort Downstairs TADO","entityConfig":"1b10a150d847503f","version":0,"state":"payload","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":1210,"y":540,"wires":[[]]},{"id":"5b958659dfd88fad","type":"ha-sensor","z":"f237a1dd1abe1cd9","g":"7c164373aa514aec","name":"Text Temp Comfort Living TADO","entityConfig":"2945a8dbfe07293f","version":0,"state":"payload","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":1190,"y":480,"wires":[[]]},{"id":"2e1dfe39a0384499","type":"inject","z":"f237a1dd1abe1cd9","g":"7c164373aa514aec","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":280,"y":180,"wires":[["dfeb4a856de32953"]]},{"id":"ce0aea9208f6ad30","type":"comment","z":"f237a1dd1abe1cd9","g":"7c164373aa514aec","name":"INSTRUCTIONS FOR USE - DOUBLE CLICK ME","info":"THIS IS USED TO CONNECT TO THE TADO API AND GET THE TEXT DESCRIPTION FOR THE TEMP AND HUMIDITY. \nTemp(COLD,COMFY,WARM) - Humidity (DRY,COMFY,HUMID)\nTHESE CAN BE USED AS A TEXT DESCRIPTION IN THE SIMPLE AIR COMFORT CARD \nhttps://community.home-assistant.io/t/simple-air-comfort-card/670656\n1. Double Click Tado [getMe] Node, Add a New Tado Config... \n2. Enter your TADO Account login details into the config. Click Done. \n3. Find you homes ID in the debug message [window payload.homes[0].id] \n4. Enter your Home ID into the other Nodes to fetch information from the API\n5. Click the time stamp into the Tado [getAirComfort] Node\n6. Find the path >_Copy Path Button in the Debug Node [payload.comfort[0].temperatureLevel]\n7. Copy the path into the Function Node","x":390,"y":140,"wires":[]},{"id":"40960c70ab5a16e5","type":"inject","z":"f237a1dd1abe1cd9","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"60","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":130,"y":1780,"wires":[["8bc3fa49098a601b","8489effe51fa5eb6","3fe02323d89e5294","e6c45cbdc415a6d1","4f6206903db8ae50"]]},{"id":"8bc3fa49098a601b","type":"api-current-state","z":"f237a1dd1abe1cd9","g":"9a17701f3c3b0fc1","name":"DEWPOINT AIRPORT","server":"bb380e72.b8825","version":3,"outputs":2,"halt_if":"0","halt_if_type":"num","halt_if_compare":"gt","entity_id":"sensor.dewpoint_airport","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"airport","valueType":"str"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":460,"y":960,"wires":[["3b2eb7ae5480f2ee"],[]]},{"id":"3b2eb7ae5480f2ee","type":"switch","z":"f237a1dd1abe1cd9","g":"9a17701f3c3b0fc1","name":"","property":"payload","propertyType":"msg","rules":[{"t":"lt","v":"5","vt":"str"},{"t":"btwn","v":"5.1","vt":"num","v2":"10","v2t":"num"},{"t":"btwn","v":"10.1","vt":"num","v2":"12.9","v2t":"num"},{"t":"btwn","v":"13","vt":"num","v2":"15","v2t":"num"},{"t":"btwn","v":"15.1","vt":"num","v2":"17.9","v2t":"num"},{"t":"btwn","v":"18","vt":"num","v2":"20.9","v2t":"num"},{"t":"btwn","v":"21","vt":"num","v2":"23.9","v2t":"num"},{"t":"gt","v":"24","vt":"num"}],"checkall":"true","repair":false,"outputs":8,"x":690,"y":960,"wires":[["695f89695769ff11"],["f5053ff4effe1c23"],["f64eaecb9ed52a50"],["48ef65b09bcded05"],["5aa3e602f8a20b33"],["4515910338f10a06"],["83f7c125142933fb"],["3f3622b80e1657e1"]]},{"id":"695f89695769ff11","type":"change","z":"f237a1dd1abe1cd9","g":"9a17701f3c3b0fc1","name":"TOO DRY","rules":[{"t":"change","p":"topic","pt":"msg","from":"airport","fromt":"str","to":"Too Dry","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":900,"y":820,"wires":[["6d54ea7e436fdd0f"]]},{"id":"f5053ff4effe1c23","type":"change","z":"f237a1dd1abe1cd9","g":"9a17701f3c3b0fc1","name":"COMFY DRY","rules":[{"t":"change","p":"topic","pt":"msg","from":"airport","fromt":"str","to":"Comfy Dry","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":910,"y":860,"wires":[["6d54ea7e436fdd0f"]]},{"id":"f64eaecb9ed52a50","type":"change","z":"f237a1dd1abe1cd9","g":"9a17701f3c3b0fc1","name":"PLEASANT","rules":[{"t":"change","p":"topic","pt":"msg","from":"airport","fromt":"str","to":"Pleasant","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":910,"y":900,"wires":[["6d54ea7e436fdd0f"]]},{"id":"48ef65b09bcded05","type":"change","z":"f237a1dd1abe1cd9","g":"9a17701f3c3b0fc1","name":"COMFORTABLE","rules":[{"t":"change","p":"topic","pt":"msg","from":"airport","fromt":"str","to":"Comfortable","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":930,"y":940,"wires":[["6d54ea7e436fdd0f"]]},{"id":"5aa3e602f8a20b33","type":"change","z":"f237a1dd1abe1cd9","g":"9a17701f3c3b0fc1","name":"STICKY HUMID","rules":[{"t":"change","p":"topic","pt":"msg","from":"airport","fromt":"str","to":"Sticky Humid","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":920,"y":980,"wires":[["6d54ea7e436fdd0f"]]},{"id":"4515910338f10a06","type":"change","z":"f237a1dd1abe1cd9","g":"9a17701f3c3b0fc1","name":"MUGGY","rules":[{"t":"change","p":"topic","pt":"msg","from":"airport","fromt":"str","to":"Muggy","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":900,"y":1020,"wires":[["6d54ea7e436fdd0f"]]},{"id":"83f7c125142933fb","type":"change","z":"f237a1dd1abe1cd9","g":"9a17701f3c3b0fc1","name":"SWELTERING","rules":[{"t":"change","p":"topic","pt":"msg","from":"airport","fromt":"str","to":"Sweltering","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":920,"y":1060,"wires":[["6d54ea7e436fdd0f"]]},{"id":"3f3622b80e1657e1","type":"change","z":"f237a1dd1abe1cd9","g":"9a17701f3c3b0fc1","name":"STIFILING","rules":[{"t":"change","p":"topic","pt":"msg","from":"airport","fromt":"str","to":"Stifiling","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":910,"y":1100,"wires":[["6d54ea7e436fdd0f"]]},{"id":"6d54ea7e436fdd0f","type":"ha-sensor","z":"f237a1dd1abe1cd9","g":"9a17701f3c3b0fc1","name":"Text Dewpoint Comfort Airport","entityConfig":"54d904eea36be7a2","version":0,"state":"topic","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":1310,"y":940,"wires":[[]]},{"id":"398d3e272ac8a486","type":"comment","z":"f237a1dd1abe1cd9","g":"9a17701f3c3b0fc1","name":"INSTRUCTIONS FOR USE - DOUBLE CLICK ME","info":"1. INSTALL https://github.com/miguelangel-nubla/home-assistant-dewpoint DewPoint Sensor Calculator sensor via HACS\n2. You will have to add as a Custom Respository using the 3 Dot menu top right in HACS.\n3. CLICK INTERGRATIONS in HACS\n4. CLICK 3 button menu top right\n5. CLICK Custom Respositories\n6. PASTE https://github.com/miguelangel-nubla/home-assistant-dewpoint in the Repository Field\n7. SELECT Intergration in the Category field\n8. CLICK ADD \n9. RESTART HOME assistant\n10. Setup your sensors in your configuration.yaml file.\nsensor:\n  - platform: dewpoint\n    sensors:\n      dewpoint_outside:\n        temperature: sensor.temperature_outside\n        rel_hum: sensor.humidity_outside\n      dewpoint_office:\n        temperature: sensor.temperature_office\n        rel_hum: sensor.humidity_office\n11. Insert your dewpoint sensor in the 'Current State' Node","x":530,"y":820,"wires":[]},{"id":"8489effe51fa5eb6","type":"api-current-state","z":"f237a1dd1abe1cd9","g":"48ad0e7ff822c6a9","name":"DEWPOINT DOWNSTAIRS","server":"bb380e72.b8825","version":3,"outputs":2,"halt_if":"0","halt_if_type":"num","halt_if_compare":"gt","entity_id":"sensor.dewpoint_downstairs","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"downstairs","valueType":"str"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":460,"y":1380,"wires":[["0b134345a349d83b"],[]]},{"id":"0b134345a349d83b","type":"switch","z":"f237a1dd1abe1cd9","g":"48ad0e7ff822c6a9","name":"","property":"payload","propertyType":"msg","rules":[{"t":"lt","v":"5","vt":"str"},{"t":"btwn","v":"5.1","vt":"num","v2":"10","v2t":"num"},{"t":"btwn","v":"10.1","vt":"num","v2":"12.9","v2t":"num"},{"t":"btwn","v":"13","vt":"num","v2":"15","v2t":"num"},{"t":"btwn","v":"15.1","vt":"num","v2":"17.9","v2t":"num"},{"t":"btwn","v":"18","vt":"num","v2":"20.9","v2t":"num"},{"t":"btwn","v":"21","vt":"num","v2":"23.9","v2t":"num"},{"t":"gt","v":"24","vt":"num"}],"checkall":"true","repair":false,"outputs":8,"x":690,"y":1380,"wires":[["3f68e9bfaa09c070"],["3486be1d0e386178"],["6f38643d9059912c"],["19c664435672d812"],["5b4b61eac912be03"],["aa94fc645be3070b"],["bd01c8e8f9fe379b"],["cd9138b79abaffd9"]]},{"id":"cc5dbf09ea45e71b","type":"ha-sensor","z":"f237a1dd1abe1cd9","g":"48ad0e7ff822c6a9","name":"Text Dewpoint Comfort Downstairs","entityConfig":"d25ff2fcac41fc46","version":0,"state":"topic","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":1300,"y":1380,"wires":[[]]},{"id":"3f68e9bfaa09c070","type":"change","z":"f237a1dd1abe1cd9","g":"48ad0e7ff822c6a9","name":"TOO DRY","rules":[{"t":"change","p":"topic","pt":"msg","from":"downstairs","fromt":"str","to":"Too Dry","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":900,"y":1240,"wires":[["d65f4f34e12a7551"]]},{"id":"3486be1d0e386178","type":"change","z":"f237a1dd1abe1cd9","g":"48ad0e7ff822c6a9","name":"COMFY DRY","rules":[{"t":"change","p":"topic","pt":"msg","from":"downstairs","fromt":"str","to":"Comfy Dry","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":910,"y":1280,"wires":[["d65f4f34e12a7551"]]},{"id":"6f38643d9059912c","type":"change","z":"f237a1dd1abe1cd9","g":"48ad0e7ff822c6a9","name":"PLEASANT","rules":[{"t":"change","p":"topic","pt":"msg","from":"downstairs","fromt":"str","to":"Pleasant","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":910,"y":1320,"wires":[["d65f4f34e12a7551"]]},{"id":"19c664435672d812","type":"change","z":"f237a1dd1abe1cd9","g":"48ad0e7ff822c6a9","name":"COMFORTABLE","rules":[{"t":"change","p":"topic","pt":"msg","from":"downstairs","fromt":"str","to":"Comfortable","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":930,"y":1360,"wires":[["d65f4f34e12a7551"]]},{"id":"5b4b61eac912be03","type":"change","z":"f237a1dd1abe1cd9","g":"48ad0e7ff822c6a9","name":"STICKY HUMID","rules":[{"t":"change","p":"topic","pt":"msg","from":"downstairs","fromt":"str","to":"Sticky Humid","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":920,"y":1400,"wires":[["d65f4f34e12a7551"]]},{"id":"aa94fc645be3070b","type":"change","z":"f237a1dd1abe1cd9","g":"48ad0e7ff822c6a9","name":"MUGGY","rules":[{"t":"change","p":"topic","pt":"msg","from":"downstairs","fromt":"str","to":"Muggy","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":900,"y":1440,"wires":[["d65f4f34e12a7551"]]},{"id":"bd01c8e8f9fe379b","type":"change","z":"f237a1dd1abe1cd9","g":"48ad0e7ff822c6a9","name":"SWELTERING","rules":[{"t":"change","p":"topic","pt":"msg","from":"downstairs","fromt":"str","to":"Sweltering","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":920,"y":1480,"wires":[["d65f4f34e12a7551"]]},{"id":"cd9138b79abaffd9","type":"change","z":"f237a1dd1abe1cd9","g":"48ad0e7ff822c6a9","name":"STIFILING","rules":[{"t":"change","p":"topic","pt":"msg","from":"downstairs","fromt":"str","to":"Stifiling","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":910,"y":1520,"wires":[["d65f4f34e12a7551"]]},{"id":"b48444f3d60b498c","type":"comment","z":"f237a1dd1abe1cd9","g":"48ad0e7ff822c6a9","name":"INSTRUCTIONS FOR USE - DOUBLE CLICK ME","info":"1. INSTALL https://github.com/miguelangel-nubla/home-assistant-dewpoint DewPoint Sensor Calculator sensor via HACS\n2. You will have to add as a Custom Respository using the 3 Dot menu top right in HACS.\n3. CLICK INTERGRATIONS in HACS\n4. CLICK 3 button menu top right\n5. CLICK Custom Respositories\n6. PASTE https://github.com/miguelangel-nubla/home-assistant-dewpoint in the Repository Field\n7. SELECT Intergration in the Category field\n8. CLICK ADD \n9. RESTART HOME assistant\n10. Setup your sensors in your configuration.yaml file.\nsensor:\n  - platform: dewpoint\n    sensors:\n      dewpoint_outside:\n        temperature: sensor.temperature_outside\n        rel_hum: sensor.humidity_outside\n      dewpoint_office:\n        temperature: sensor.temperature_office\n        rel_hum: sensor.humidity_office\n11. Insert your dewpoint sensor in the 'Current State' Node","x":530,"y":1220,"wires":[]},{"id":"e6c45cbdc415a6d1","type":"api-current-state","z":"f237a1dd1abe1cd9","g":"8d0916b3abd91aaf","name":"DEWPOINT OUTSIDE","server":"bb380e72.b8825","version":3,"outputs":2,"halt_if":"0","halt_if_type":"num","halt_if_compare":"gt","entity_id":"sensor.dewpoint_outside","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"outside","valueType":"str"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":460,"y":2180,"wires":[["d8061e7582df2c57"],[]]},{"id":"d8061e7582df2c57","type":"switch","z":"f237a1dd1abe1cd9","g":"8d0916b3abd91aaf","name":"","property":"payload","propertyType":"msg","rules":[{"t":"lt","v":"5","vt":"str"},{"t":"btwn","v":"5.1","vt":"num","v2":"10","v2t":"num"},{"t":"btwn","v":"10.1","vt":"num","v2":"12.9","v2t":"num"},{"t":"btwn","v":"13","vt":"num","v2":"15","v2t":"num"},{"t":"btwn","v":"15.1","vt":"num","v2":"17.9","v2t":"num"},{"t":"btwn","v":"18","vt":"num","v2":"20.9","v2t":"num"},{"t":"btwn","v":"21","vt":"num","v2":"23.9","v2t":"num"},{"t":"gt","v":"24","vt":"num"}],"checkall":"true","repair":false,"outputs":8,"x":690,"y":2180,"wires":[["d5f1ea380a16e324"],["faeccb281c6f0b1f"],["946cc750eab1ee96"],["67f9d5dd013c1f5a"],["93465b309fd7dac9"],["28e29142ee21761c"],["8d40a0ac16d3c5ac"],["04494c08542c992c"]]},{"id":"85eebef2c46fcc91","type":"ha-sensor","z":"f237a1dd1abe1cd9","g":"8d0916b3abd91aaf","name":"Text Dewpoint Comfort Outside","entityConfig":"dd54d12d846a0210","version":0,"state":"topic","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":1310,"y":2180,"wires":[[]]},{"id":"d5f1ea380a16e324","type":"change","z":"f237a1dd1abe1cd9","g":"8d0916b3abd91aaf","name":"TOO DRY","rules":[{"t":"change","p":"topic","pt":"msg","from":"outside","fromt":"str","to":"Too Dry","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":900,"y":2040,"wires":[["85eebef2c46fcc91"]]},{"id":"faeccb281c6f0b1f","type":"change","z":"f237a1dd1abe1cd9","g":"8d0916b3abd91aaf","name":"COMFY DRY","rules":[{"t":"change","p":"topic","pt":"msg","from":"outside","fromt":"str","to":"Comfy Dry","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":910,"y":2080,"wires":[["85eebef2c46fcc91"]]},{"id":"946cc750eab1ee96","type":"change","z":"f237a1dd1abe1cd9","g":"8d0916b3abd91aaf","name":"PLEASANT","rules":[{"t":"change","p":"topic","pt":"msg","from":"outside","fromt":"str","to":"Pleasant","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":910,"y":2120,"wires":[["85eebef2c46fcc91"]]},{"id":"67f9d5dd013c1f5a","type":"change","z":"f237a1dd1abe1cd9","g":"8d0916b3abd91aaf","name":"COMFORTABLE","rules":[{"t":"change","p":"topic","pt":"msg","from":"outside","fromt":"str","to":"Comfortable","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":930,"y":2160,"wires":[["85eebef2c46fcc91"]]},{"id":"93465b309fd7dac9","type":"change","z":"f237a1dd1abe1cd9","g":"8d0916b3abd91aaf","name":"STICKY HUMID","rules":[{"t":"change","p":"topic","pt":"msg","from":"outside","fromt":"str","to":"Sticky Humid","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":920,"y":2200,"wires":[["85eebef2c46fcc91"]]},{"id":"28e29142ee21761c","type":"change","z":"f237a1dd1abe1cd9","g":"8d0916b3abd91aaf","name":"MUGGY","rules":[{"t":"change","p":"topic","pt":"msg","from":"outside","fromt":"str","to":"Muggy","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":900,"y":2240,"wires":[["85eebef2c46fcc91"]]},{"id":"8d40a0ac16d3c5ac","type":"change","z":"f237a1dd1abe1cd9","g":"8d0916b3abd91aaf","name":"SWELTERING","rules":[{"t":"change","p":"topic","pt":"msg","from":"outside","fromt":"str","to":"Sweltering","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":920,"y":2280,"wires":[["85eebef2c46fcc91"]]},{"id":"04494c08542c992c","type":"change","z":"f237a1dd1abe1cd9","g":"8d0916b3abd91aaf","name":"STIFLING","rules":[{"t":"change","p":"topic","pt":"msg","from":"outside","fromt":"str","to":"Stifling","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":900,"y":2320,"wires":[["85eebef2c46fcc91"]]},{"id":"19a06e9a85a0bb61","type":"comment","z":"f237a1dd1abe1cd9","g":"8d0916b3abd91aaf","name":"INSTRUCTIONS FOR USE - DOUBLE CLICK ME","info":"1. INSTALL https://github.com/miguelangel-nubla/home-assistant-dewpoint DewPoint Sensor Calculator sensor via HACS\n2. You will have to add as a Custom Respository using the 3 Dot menu top right in HACS.\n3. CLICK INTERGRATIONS in HACS\n4. CLICK 3 button menu top right\n5. CLICK Custom Respositories\n6. PASTE https://github.com/miguelangel-nubla/home-assistant-dewpoint in the Repository Field\n7. SELECT Intergration in the Category field\n8. CLICK ADD \n9. RESTART HOME assistant\n10. Setup your sensors in your configuration.yaml file.\nsensor:\n  - platform: dewpoint\n    sensors:\n      dewpoint_outside:\n        temperature: sensor.temperature_outside\n        rel_hum: sensor.humidity_outside\n      dewpoint_office:\n        temperature: sensor.temperature_office\n        rel_hum: sensor.humidity_office\n11. Insert your dewpoint sensor in the 'Current State' Node","x":530,"y":2080,"wires":[]},{"id":"e34dcc93f44c3d94","type":"change","z":"f237a1dd1abe1cd9","g":"0f4795eb69eae00e","name":"COMFORTABLE","rules":[{"t":"change","p":"topic","pt":"msg","from":"living","fromt":"str","to":"Comfortable","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":930,"y":1760,"wires":[["97e08e6c2ac74cd5"]]},{"id":"3fe02323d89e5294","type":"api-current-state","z":"f237a1dd1abe1cd9","g":"0f4795eb69eae00e","name":"DEWPOINT LIVING ROOM","server":"bb380e72.b8825","version":3,"outputs":2,"halt_if":"0","halt_if_type":"num","halt_if_compare":"gt","entity_id":"sensor.dewpoint_living_room","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"living","valueType":"str"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":480,"y":1780,"wires":[["c903d4f10333b6e5"],[]]},{"id":"c903d4f10333b6e5","type":"switch","z":"f237a1dd1abe1cd9","g":"0f4795eb69eae00e","name":"","property":"payload","propertyType":"msg","rules":[{"t":"lt","v":"5","vt":"str"},{"t":"btwn","v":"5.1","vt":"num","v2":"10","v2t":"num"},{"t":"btwn","v":"10.1","vt":"num","v2":"12.9","v2t":"num"},{"t":"btwn","v":"13","vt":"num","v2":"15","v2t":"num"},{"t":"btwn","v":"15.1","vt":"num","v2":"17.9","v2t":"num"},{"t":"btwn","v":"18","vt":"num","v2":"20.9","v2t":"num"},{"t":"btwn","v":"21","vt":"num","v2":"23.9","v2t":"num"},{"t":"gt","v":"24","vt":"num"}],"checkall":"true","repair":false,"outputs":8,"x":690,"y":1780,"wires":[["e005f94a8c53a86e"],["383be06b3c4c3ac3"],["0c7efadde29059f1"],["e34dcc93f44c3d94"],["7e28dcfa1b66c2ec"],["2d79cbc4d09e58b9"],["109144d6bc7a39aa"],["9ea82db21c925370"]]},{"id":"97e08e6c2ac74cd5","type":"ha-sensor","z":"f237a1dd1abe1cd9","g":"0f4795eb69eae00e","name":"Text Dewpoint Comfort Living","entityConfig":"6fcaa548b4287ada","version":0,"state":"topic","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":1320,"y":1780,"wires":[[]]},{"id":"e005f94a8c53a86e","type":"change","z":"f237a1dd1abe1cd9","g":"0f4795eb69eae00e","name":"TOO DRY","rules":[{"t":"change","p":"topic","pt":"msg","from":"living","fromt":"str","to":"Too Dry","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":900,"y":1640,"wires":[["97e08e6c2ac74cd5"]]},{"id":"383be06b3c4c3ac3","type":"change","z":"f237a1dd1abe1cd9","g":"0f4795eb69eae00e","name":"COMFY DRY","rules":[{"t":"change","p":"topic","pt":"msg","from":"living","fromt":"str","to":"Comfy Dry","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":910,"y":1680,"wires":[["97e08e6c2ac74cd5"]]},{"id":"0c7efadde29059f1","type":"change","z":"f237a1dd1abe1cd9","g":"0f4795eb69eae00e","name":"PLEASANT","rules":[{"t":"change","p":"topic","pt":"msg","from":"living","fromt":"str","to":"Pleasant","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":910,"y":1720,"wires":[["97e08e6c2ac74cd5"]]},{"id":"7e28dcfa1b66c2ec","type":"change","z":"f237a1dd1abe1cd9","g":"0f4795eb69eae00e","name":"STICKY HUMID","rules":[{"t":"change","p":"topic","pt":"msg","from":"living","fromt":"str","to":"Sticky Humid","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":920,"y":1800,"wires":[["97e08e6c2ac74cd5"]]},{"id":"2d79cbc4d09e58b9","type":"change","z":"f237a1dd1abe1cd9","g":"0f4795eb69eae00e","name":"MUGGY","rules":[{"t":"change","p":"topic","pt":"msg","from":"living","fromt":"str","to":"Muggy","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":900,"y":1840,"wires":[["97e08e6c2ac74cd5"]]},{"id":"109144d6bc7a39aa","type":"change","z":"f237a1dd1abe1cd9","g":"0f4795eb69eae00e","name":"SWELTERING","rules":[{"t":"change","p":"topic","pt":"msg","from":"living","fromt":"str","to":"Sweltering","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":920,"y":1880,"wires":[["97e08e6c2ac74cd5"]]},{"id":"9ea82db21c925370","type":"change","z":"f237a1dd1abe1cd9","g":"0f4795eb69eae00e","name":"STIFILING","rules":[{"t":"change","p":"topic","pt":"msg","from":"living","fromt":"str","to":"Stifling","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":910,"y":1920,"wires":[["97e08e6c2ac74cd5"]]},{"id":"70ffe3834f6b54f5","type":"comment","z":"f237a1dd1abe1cd9","g":"0f4795eb69eae00e","name":"INSTRUCTIONS FOR USE - DOUBLE CLICK ME","info":"1. INSTALL https://github.com/miguelangel-nubla/home-assistant-dewpoint DewPoint Sensor Calculator sensor via HACS\n2. You will have to add as a Custom Respository using the 3 Dot menu top right in HACS.\n3. CLICK INTERGRATIONS in HACS\n4. CLICK 3 button menu top right\n5. CLICK Custom Respositories\n6. PASTE https://github.com/miguelangel-nubla/home-assistant-dewpoint in the Repository Field\n7. SELECT Intergration in the Category field\n8. CLICK ADD \n9. RESTART HOME assistant\n10. Setup your sensors in your configuration.yaml file.\nsensor:\n  - platform: dewpoint\n    sensors:\n      dewpoint_outside:\n        temperature: sensor.temperature_outside\n        rel_hum: sensor.humidity_outside\n      dewpoint_office:\n        temperature: sensor.temperature_office\n        rel_hum: sensor.humidity_office\n11. Insert your dewpoint sensor in the 'Current State' Node","x":530,"y":1680,"wires":[]},{"id":"cce7a5ceb2d2b421","type":"change","z":"f237a1dd1abe1cd9","g":"5ffc1a5a6ebe585d","name":"TOO DRY","rules":[{"t":"change","p":"topic","pt":"msg","from":"airport","fromt":"str","to":"Too Dry","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1640,"y":820,"wires":[[]]},{"id":"6549925f36452186","type":"change","z":"f237a1dd1abe1cd9","g":"5ffc1a5a6ebe585d","name":"DRY","rules":[{"t":"change","p":"topic","pt":"msg","from":"airport","fromt":"str","to":"Dry Cool","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1630,"y":860,"wires":[[]]},{"id":"0dc0670a6176a313","type":"change","z":"f237a1dd1abe1cd9","g":"5ffc1a5a6ebe585d","name":"PLEASANT","rules":[{"t":"change","p":"topic","pt":"msg","from":"airport","fromt":"str","to":"Pleasant","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1650,"y":900,"wires":[[]]},{"id":"b220e62e3497febd","type":"change","z":"f237a1dd1abe1cd9","g":"5ffc1a5a6ebe585d","name":"COMFORTABLE","rules":[{"t":"change","p":"topic","pt":"msg","from":"airport","fromt":"str","to":"Comfortable","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1670,"y":940,"wires":[[]]},{"id":"1adb668ec5929abd","type":"change","z":"f237a1dd1abe1cd9","g":"5ffc1a5a6ebe585d","name":"STICKY HUMID","rules":[{"t":"change","p":"topic","pt":"msg","from":"airport","fromt":"str","to":"Sticky Humid","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1660,"y":980,"wires":[[]]},{"id":"c091e0276ce24310","type":"change","z":"f237a1dd1abe1cd9","g":"5ffc1a5a6ebe585d","name":"MUGGY","rules":[{"t":"change","p":"topic","pt":"msg","from":"airport","fromt":"str","to":"Muggy","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1640,"y":1020,"wires":[[]]},{"id":"cdea3d146507b5e5","type":"change","z":"f237a1dd1abe1cd9","g":"5ffc1a5a6ebe585d","name":"VERY MUGGY","rules":[{"t":"change","p":"topic","pt":"msg","from":"airport","fromt":"str","to":"Very Muggy","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1660,"y":1060,"wires":[[]]},{"id":"252106f7f789f4d5","type":"change","z":"f237a1dd1abe1cd9","g":"5ffc1a5a6ebe585d","name":"SOUPY HUMID","rules":[{"t":"change","p":"topic","pt":"msg","from":"airport","fromt":"str","to":"Soupy Humid","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1660,"y":1100,"wires":[[]]},{"id":"4f6206903db8ae50","type":"api-current-state","z":"f237a1dd1abe1cd9","g":"464b08b13eac8e80","name":"DEWPOINT UPSTAIRS","server":"bb380e72.b8825","version":3,"outputs":2,"halt_if":"0","halt_if_type":"num","halt_if_compare":"gt","entity_id":"sensor.dewpoint_upstairs","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"upstairs","valueType":"str"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":470,"y":2600,"wires":[["2b0c58a8c7e8c3ba"],[]]},{"id":"2b0c58a8c7e8c3ba","type":"switch","z":"f237a1dd1abe1cd9","g":"464b08b13eac8e80","name":"","property":"payload","propertyType":"msg","rules":[{"t":"lt","v":"5","vt":"str"},{"t":"btwn","v":"5.1","vt":"num","v2":"10","v2t":"num"},{"t":"btwn","v":"10.1","vt":"num","v2":"12.9","v2t":"num"},{"t":"btwn","v":"13","vt":"num","v2":"15","v2t":"num"},{"t":"btwn","v":"15.1","vt":"num","v2":"17.9","v2t":"num"},{"t":"btwn","v":"18","vt":"num","v2":"20.9","v2t":"num"},{"t":"btwn","v":"21","vt":"num","v2":"23.9","v2t":"num"},{"t":"gt","v":"24","vt":"num"}],"checkall":"true","repair":false,"outputs":8,"x":690,"y":2600,"wires":[["349e06a3f9b7618f"],["56347a7a958a055a"],["c302b2a12f056b68"],["d19aabf91cc2aa31"],["b01bf5f56286421e"],["23b96a50f7055363"],["7596a5f28d083515"],["179a13c53c92291f"]]},{"id":"222d5288c6e9d93a","type":"ha-sensor","z":"f237a1dd1abe1cd9","g":"464b08b13eac8e80","name":"Text Dewpoint Comfort Upstairs","entityConfig":"42bf29847067a3c5","version":0,"state":"topic","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":1310,"y":2600,"wires":[[]]},{"id":"349e06a3f9b7618f","type":"change","z":"f237a1dd1abe1cd9","g":"464b08b13eac8e80","name":"TOO DRY","rules":[{"t":"change","p":"topic","pt":"msg","from":"upstairs","fromt":"str","to":"Too Dry","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":900,"y":2460,"wires":[["222d5288c6e9d93a"]]},{"id":"56347a7a958a055a","type":"change","z":"f237a1dd1abe1cd9","g":"464b08b13eac8e80","name":"COMFY DRY","rules":[{"t":"change","p":"topic","pt":"msg","from":"upstairs","fromt":"str","to":"Comfy Dry","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":910,"y":2500,"wires":[["222d5288c6e9d93a"]]},{"id":"c302b2a12f056b68","type":"change","z":"f237a1dd1abe1cd9","g":"464b08b13eac8e80","name":"PLEASANT","rules":[{"t":"change","p":"topic","pt":"msg","from":"upstairs","fromt":"str","to":"Pleasant","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":910,"y":2540,"wires":[["222d5288c6e9d93a"]]},{"id":"d19aabf91cc2aa31","type":"change","z":"f237a1dd1abe1cd9","g":"464b08b13eac8e80","name":"COMFORTABLE","rules":[{"t":"change","p":"topic","pt":"msg","from":"upstairs","fromt":"str","to":"Comfortable","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":930,"y":2580,"wires":[["222d5288c6e9d93a"]]},{"id":"b01bf5f56286421e","type":"change","z":"f237a1dd1abe1cd9","g":"464b08b13eac8e80","name":"STICKY HUMID","rules":[{"t":"change","p":"topic","pt":"msg","from":"upstairs","fromt":"str","to":"Sticky Humid","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":920,"y":2620,"wires":[["222d5288c6e9d93a"]]},{"id":"23b96a50f7055363","type":"change","z":"f237a1dd1abe1cd9","g":"464b08b13eac8e80","name":"MUGGY","rules":[{"t":"change","p":"topic","pt":"msg","from":"upstairs","fromt":"str","to":"Muggy","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":900,"y":2660,"wires":[["222d5288c6e9d93a"]]},{"id":"7596a5f28d083515","type":"change","z":"f237a1dd1abe1cd9","g":"464b08b13eac8e80","name":"SWELTERING","rules":[{"t":"change","p":"topic","pt":"msg","from":"upstairs","fromt":"str","to":"Sweltering","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":920,"y":2700,"wires":[["222d5288c6e9d93a"]]},{"id":"179a13c53c92291f","type":"change","z":"f237a1dd1abe1cd9","g":"464b08b13eac8e80","name":"STIFLING","rules":[{"t":"change","p":"topic","pt":"msg","from":"upstairs","fromt":"str","to":"Stifling","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":900,"y":2740,"wires":[["222d5288c6e9d93a"]]},{"id":"ec09b041e140027d","type":"comment","z":"f237a1dd1abe1cd9","g":"464b08b13eac8e80","name":"INSTRUCTIONS FOR USE - DOUBLE CLICK ME","info":"1. INSTALL https://github.com/miguelangel-nubla/home-assistant-dewpoint DewPoint Sensor Calculator sensor via HACS\n2. You will have to add as a Custom Respository using the 3 Dot menu top right in HACS.\n3. CLICK INTERGRATIONS in HACS\n4. CLICK 3 button menu top right\n5. CLICK Custom Respositories\n6. PASTE https://github.com/miguelangel-nubla/home-assistant-dewpoint in the Repository Field\n7. SELECT Intergration in the Category field\n8. CLICK ADD \n9. RESTART HOME assistant\n10. Setup your sensors in your configuration.yaml file.\nsensor:\n  - platform: dewpoint\n    sensors:\n      dewpoint_outside:\n        temperature: sensor.temperature_outside\n        rel_hum: sensor.humidity_outside\n      dewpoint_office:\n        temperature: sensor.temperature_office\n        rel_hum: sensor.humidity_office\n11. Insert your dewpoint sensor in the 'Current State' Node","x":530,"y":2500,"wires":[]},{"id":"06926d21c0a26e33","type":"inject","z":"f237a1dd1abe1cd9","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"60","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":110,"y":4000,"wires":[["a083e1f4b198eb9b","35476ea18f4dde18","7d083f6bcf50f0e7","c14fd408d848be75","1f666e01e8dfe971"]]},{"id":"01ade7c603a0278a","type":"change","z":"f237a1dd1abe1cd9","g":"4616a089546015eb","name":"COOL","rules":[{"t":"change","p":"topic","pt":"msg","from":"living","fromt":"str","to":"COOL","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":870,"y":3980,"wires":[["4139e79aa75c7e2d"]]},{"id":"7d083f6bcf50f0e7","type":"api-current-state","z":"f237a1dd1abe1cd9","g":"4616a089546015eb","name":"TEMPERATURE LIVING ROOM","server":"bb380e72.b8825","version":3,"outputs":2,"halt_if":"0","halt_if_type":"num","halt_if_compare":"gt","entity_id":"sensor.air_conditioning_temperature","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"living","valueType":"str"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":470,"y":4020,"wires":[["02120a55de03ad84"],[]]},{"id":"02120a55de03ad84","type":"switch","z":"f237a1dd1abe1cd9","g":"4616a089546015eb","name":"","property":"payload","propertyType":"msg","rules":[{"t":"lt","v":"3","vt":"num"},{"t":"btwn","v":"3.1","vt":"num","v2":"4.9","v2t":"num"},{"t":"btwn","v":"5","vt":"num","v2":"8.9","v2t":"num"},{"t":"btwn","v":"9","vt":"num","v2":"13.9","v2t":"num"},{"t":"btwn","v":"14","vt":"num","v2":"18.9","v2t":"num"},{"t":"btwn","v":"19","vt":"num","v2":"23.9","v2t":"num"},{"t":"btwn","v":"24","vt":"num","v2":"27.9","v2t":"num"},{"t":"btwn","v":"28","vt":"num","v2":"34.9","v2t":"num"},{"t":"gt","v":"35","vt":"num"}],"checkall":"true","repair":false,"outputs":9,"x":670,"y":4020,"wires":[["32425e5617adc3a9"],["098af15c31d17d3c"],["cc2fc8d30cebef9b"],["01ade7c603a0278a"],["a71bf10c204b11a7"],["92681abd85e6d7e6"],["3af088de0d22d148"],["2d17f6da19bbf9cf"],["1350f30d8ae3a655"]]},{"id":"4139e79aa75c7e2d","type":"ha-sensor","z":"f237a1dd1abe1cd9","g":"4616a089546015eb","name":"Text Temperature Comfort Living","entityConfig":"f67b15906bc496bb","version":0,"state":"topic","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":1310,"y":4000,"wires":[[]]},{"id":"32425e5617adc3a9","type":"change","z":"f237a1dd1abe1cd9","g":"4616a089546015eb","name":"FROSTY","rules":[{"t":"change","p":"topic","pt":"msg","from":"living","fromt":"str","to":"FROSTY","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":880,"y":3860,"wires":[["4139e79aa75c7e2d"]]},{"id":"098af15c31d17d3c","type":"change","z":"f237a1dd1abe1cd9","g":"4616a089546015eb","name":"COLD","rules":[{"t":"change","p":"topic","pt":"msg","from":"living","fromt":"str","to":"COLD","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":870,"y":3900,"wires":[["4139e79aa75c7e2d"]]},{"id":"cc2fc8d30cebef9b","type":"change","z":"f237a1dd1abe1cd9","g":"4616a089546015eb","name":"CHILLY","rules":[{"t":"change","p":"topic","pt":"msg","from":"living","fromt":"str","to":"CHILLY","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":880,"y":3940,"wires":[["4139e79aa75c7e2d"]]},{"id":"a71bf10c204b11a7","type":"change","z":"f237a1dd1abe1cd9","g":"4616a089546015eb","name":"MILD","rules":[{"t":"change","p":"topic","pt":"msg","from":"living","fromt":"str","to":"MILD","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":870,"y":4020,"wires":[["4139e79aa75c7e2d"]]},{"id":"92681abd85e6d7e6","type":"change","z":"f237a1dd1abe1cd9","g":"4616a089546015eb","name":"PERFECT","rules":[{"t":"change","p":"topic","pt":"msg","from":"living","fromt":"str","to":"PERFECT","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":890,"y":4060,"wires":[["4139e79aa75c7e2d"]]},{"id":"3af088de0d22d148","type":"change","z":"f237a1dd1abe1cd9","g":"4616a089546015eb","name":"WARM","rules":[{"t":"change","p":"topic","pt":"msg","from":"living","fromt":"str","to":"WARM","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":880,"y":4100,"wires":[["4139e79aa75c7e2d"]]},{"id":"2d17f6da19bbf9cf","type":"change","z":"f237a1dd1abe1cd9","g":"4616a089546015eb","name":"HOT","rules":[{"t":"change","p":"topic","pt":"msg","from":"living","fromt":"str","to":"HOT","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":870,"y":4140,"wires":[["4139e79aa75c7e2d"]]},{"id":"1350f30d8ae3a655","type":"change","z":"f237a1dd1abe1cd9","g":"4616a089546015eb","name":"BOILING","rules":[{"t":"change","p":"topic","pt":"msg","from":"living","fromt":"str","to":"BOILING","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":880,"y":4180,"wires":[["4139e79aa75c7e2d"]]},{"id":"2b47e87df5456f1e","type":"change","z":"f237a1dd1abe1cd9","g":"7173d8039a32824a","name":"COOL","rules":[{"t":"change","p":"topic","pt":"msg","from":"living","fromt":"str","to":"COOL","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":870,"y":3060,"wires":[["f571663c63cd6dd6"]]},{"id":"a083e1f4b198eb9b","type":"api-current-state","z":"f237a1dd1abe1cd9","g":"7173d8039a32824a","name":"TEMPERATURE AIRPORT","server":"bb380e72.b8825","version":3,"outputs":2,"halt_if":"0","halt_if_type":"num","halt_if_compare":"gt","entity_id":"sensor.devonport_airport_temp","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"living","valueType":"str"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":460,"y":3100,"wires":[["746e5a6f4a507a1d"],[]]},{"id":"746e5a6f4a507a1d","type":"switch","z":"f237a1dd1abe1cd9","g":"7173d8039a32824a","name":"","property":"payload","propertyType":"msg","rules":[{"t":"lt","v":"3","vt":"str"},{"t":"btwn","v":"3.1","vt":"num","v2":"4.9","v2t":"num"},{"t":"btwn","v":"5","vt":"num","v2":"8.9","v2t":"num"},{"t":"btwn","v":"9","vt":"num","v2":"13.9","v2t":"num"},{"t":"btwn","v":"14","vt":"num","v2":"18.9","v2t":"num"},{"t":"btwn","v":"19","vt":"num","v2":"23.9","v2t":"num"},{"t":"btwn","v":"24","vt":"num","v2":"27.9","v2t":"num"},{"t":"btwn","v":"28","vt":"num","v2":"34.9","v2t":"num"},{"t":"gt","v":"35","vt":"num"}],"checkall":"true","repair":false,"outputs":9,"x":670,"y":3100,"wires":[["1acb7c36ee246281"],["68c14f9c18e60ff0"],["6492a0d7bd1b8779"],["2b47e87df5456f1e"],["d0fc2ade8c489745"],["566c7b94d768a106"],["24312ce259dacccc"],["0522bfd494e822ef"],["7e0d497a2d590aae"]]},{"id":"f571663c63cd6dd6","type":"ha-sensor","z":"f237a1dd1abe1cd9","g":"7173d8039a32824a","name":"Text Temperature Comfort Airport","entityConfig":"2bf6f5ae9b3e904b","version":0,"state":"topic","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":1300,"y":3080,"wires":[[]]},{"id":"1acb7c36ee246281","type":"change","z":"f237a1dd1abe1cd9","g":"7173d8039a32824a","name":"FROSTY","rules":[{"t":"change","p":"topic","pt":"msg","from":"living","fromt":"str","to":"FROSTY","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":880,"y":2940,"wires":[["f571663c63cd6dd6"]]},{"id":"68c14f9c18e60ff0","type":"change","z":"f237a1dd1abe1cd9","g":"7173d8039a32824a","name":"COLD","rules":[{"t":"change","p":"topic","pt":"msg","from":"living","fromt":"str","to":"COLD","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":870,"y":2980,"wires":[["f571663c63cd6dd6"]]},{"id":"6492a0d7bd1b8779","type":"change","z":"f237a1dd1abe1cd9","g":"7173d8039a32824a","name":"CHILLY","rules":[{"t":"change","p":"topic","pt":"msg","from":"living","fromt":"str","to":"CHILLY","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":880,"y":3020,"wires":[["f571663c63cd6dd6"]]},{"id":"d0fc2ade8c489745","type":"change","z":"f237a1dd1abe1cd9","g":"7173d8039a32824a","name":"MILD","rules":[{"t":"change","p":"topic","pt":"msg","from":"living","fromt":"str","to":"MILD","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":870,"y":3100,"wires":[["f571663c63cd6dd6"]]},{"id":"566c7b94d768a106","type":"change","z":"f237a1dd1abe1cd9","g":"7173d8039a32824a","name":"PERFECT","rules":[{"t":"change","p":"topic","pt":"msg","from":"living","fromt":"str","to":"PERFECT","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":890,"y":3140,"wires":[["f571663c63cd6dd6"]]},{"id":"24312ce259dacccc","type":"change","z":"f237a1dd1abe1cd9","g":"7173d8039a32824a","name":"WARM","rules":[{"t":"change","p":"topic","pt":"msg","from":"living","fromt":"str","to":"WARM","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":880,"y":3180,"wires":[["f571663c63cd6dd6"]]},{"id":"0522bfd494e822ef","type":"change","z":"f237a1dd1abe1cd9","g":"7173d8039a32824a","name":"HOT","rules":[{"t":"change","p":"topic","pt":"msg","from":"living","fromt":"str","to":"HOT","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":870,"y":3220,"wires":[["f571663c63cd6dd6"]]},{"id":"7e0d497a2d590aae","type":"change","z":"f237a1dd1abe1cd9","g":"7173d8039a32824a","name":"BOILING","rules":[{"t":"change","p":"topic","pt":"msg","from":"living","fromt":"str","to":"BOILING","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":880,"y":3260,"wires":[["f571663c63cd6dd6"]]},{"id":"e4105f49340f7c3c","type":"comment","z":"f237a1dd1abe1cd9","g":"7173d8039a32824a","name":"INSTRUCTIONS FOR USE - DOUBLE CLICK ME","info":"1. Insert your temperature sensor in the 'Current State' Node\n2. payload.topic is what switched the numbers to words\n2. Ensure the Sensor is setup and named.","x":530,"y":2940,"wires":[]},{"id":"95e55f5f943cf7f8","type":"change","z":"f237a1dd1abe1cd9","g":"f6b19d555014ff15","name":"COOL","rules":[{"t":"change","p":"topic","pt":"msg","from":"living","fromt":"str","to":"COOL","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":870,"y":3520,"wires":[["f43b0538fbf13249"]]},{"id":"35476ea18f4dde18","type":"api-current-state","z":"f237a1dd1abe1cd9","g":"f6b19d555014ff15","name":"TEMPERATURE DOWNSTAIRS","server":"bb380e72.b8825","version":3,"outputs":2,"halt_if":"0","halt_if_type":"num","halt_if_compare":"gt","entity_id":"sensor.air_conditioning_downstairs_temperature","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"living","valueType":"str"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":470,"y":3560,"wires":[["cb0d6a67af050555"],[]]},{"id":"cb0d6a67af050555","type":"switch","z":"f237a1dd1abe1cd9","g":"f6b19d555014ff15","name":"","property":"payload","propertyType":"msg","rules":[{"t":"lt","v":"3","vt":"str"},{"t":"btwn","v":"3.1","vt":"num","v2":"4.9","v2t":"num"},{"t":"btwn","v":"5","vt":"num","v2":"8.9","v2t":"num"},{"t":"btwn","v":"9","vt":"num","v2":"13.9","v2t":"num"},{"t":"btwn","v":"14","vt":"num","v2":"18.9","v2t":"num"},{"t":"btwn","v":"19","vt":"num","v2":"23.9","v2t":"num"},{"t":"btwn","v":"24","vt":"num","v2":"27.9","v2t":"num"},{"t":"btwn","v":"28","vt":"num","v2":"34.9","v2t":"num"},{"t":"gt","v":"35","vt":"num"}],"checkall":"true","repair":false,"outputs":9,"x":670,"y":3560,"wires":[["b49eae849b2c426a"],["ba6c0d6b74180bb0"],["21aef8b707a080fc"],["95e55f5f943cf7f8"],["7b428cb57eef154e"],["475a39a5bc2457ec"],["460bd517152bf5af"],["61f7e5ebda9c275d"],["6dd2720d885a899b"]]},{"id":"f43b0538fbf13249","type":"ha-sensor","z":"f237a1dd1abe1cd9","g":"f6b19d555014ff15","name":"Text Temperature Comfort Downstairs","entityConfig":"907b0dc00e3026e6","version":0,"state":"topic","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":1290,"y":3540,"wires":[[]]},{"id":"b49eae849b2c426a","type":"change","z":"f237a1dd1abe1cd9","g":"f6b19d555014ff15","name":"FROSTY","rules":[{"t":"change","p":"topic","pt":"msg","from":"living","fromt":"str","to":"FROSTY","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":880,"y":3400,"wires":[["f43b0538fbf13249"]]},{"id":"ba6c0d6b74180bb0","type":"change","z":"f237a1dd1abe1cd9","g":"f6b19d555014ff15","name":"COLD","rules":[{"t":"change","p":"topic","pt":"msg","from":"living","fromt":"str","to":"COLD","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":870,"y":3440,"wires":[["f43b0538fbf13249"]]},{"id":"21aef8b707a080fc","type":"change","z":"f237a1dd1abe1cd9","g":"f6b19d555014ff15","name":"CHILLY","rules":[{"t":"change","p":"topic","pt":"msg","from":"living","fromt":"str","to":"CHILLY","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":880,"y":3480,"wires":[["f43b0538fbf13249"]]},{"id":"7b428cb57eef154e","type":"change","z":"f237a1dd1abe1cd9","g":"f6b19d555014ff15","name":"MILD","rules":[{"t":"change","p":"topic","pt":"msg","from":"living","fromt":"str","to":"MILD","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":870,"y":3560,"wires":[["f43b0538fbf13249"]]},{"id":"475a39a5bc2457ec","type":"change","z":"f237a1dd1abe1cd9","g":"f6b19d555014ff15","name":"PERFECT","rules":[{"t":"change","p":"topic","pt":"msg","from":"living","fromt":"str","to":"PERFECT","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":890,"y":3600,"wires":[["f43b0538fbf13249"]]},{"id":"460bd517152bf5af","type":"change","z":"f237a1dd1abe1cd9","g":"f6b19d555014ff15","name":"WARM","rules":[{"t":"change","p":"topic","pt":"msg","from":"living","fromt":"str","to":"WARM","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":880,"y":3640,"wires":[["f43b0538fbf13249"]]},{"id":"61f7e5ebda9c275d","type":"change","z":"f237a1dd1abe1cd9","g":"f6b19d555014ff15","name":"HOT","rules":[{"t":"change","p":"topic","pt":"msg","from":"living","fromt":"str","to":"HOT","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":870,"y":3680,"wires":[["f43b0538fbf13249"]]},{"id":"6dd2720d885a899b","type":"change","z":"f237a1dd1abe1cd9","g":"f6b19d555014ff15","name":"BOILING","rules":[{"t":"change","p":"topic","pt":"msg","from":"living","fromt":"str","to":"BOILING","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":880,"y":3720,"wires":[["f43b0538fbf13249"]]},{"id":"14270cd891cb07b3","type":"change","z":"f237a1dd1abe1cd9","g":"46cbcbb3dce71e3b","name":"COOL","rules":[{"t":"change","p":"topic","pt":"msg","from":"living","fromt":"str","to":"COOL","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":870,"y":4440,"wires":[["9c8ee840f1b4d922"]]},{"id":"c14fd408d848be75","type":"api-current-state","z":"f237a1dd1abe1cd9","g":"46cbcbb3dce71e3b","name":"TEMPERATURE OUTSIDE","server":"bb380e72.b8825","version":3,"outputs":2,"halt_if":"0","halt_if_type":"num","halt_if_compare":"gt","entity_id":"sensor.netatmo_devonport_tas_indoor_outdoor_temperature","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"living","valueType":"str"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":460,"y":4480,"wires":[["14d3af4350fd070e"],[]]},{"id":"14d3af4350fd070e","type":"switch","z":"f237a1dd1abe1cd9","g":"46cbcbb3dce71e3b","name":"","property":"payload","propertyType":"msg","rules":[{"t":"lt","v":"3","vt":"str"},{"t":"btwn","v":"3.1","vt":"num","v2":"4.9","v2t":"num"},{"t":"btwn","v":"5","vt":"num","v2":"8.9","v2t":"num"},{"t":"btwn","v":"9","vt":"num","v2":"13.9","v2t":"num"},{"t":"btwn","v":"14","vt":"num","v2":"18.9","v2t":"num"},{"t":"btwn","v":"19","vt":"num","v2":"23.9","v2t":"num"},{"t":"btwn","v":"24","vt":"num","v2":"27.9","v2t":"num"},{"t":"btwn","v":"28","vt":"num","v2":"34.9","v2t":"num"},{"t":"gt","v":"35","vt":"num"}],"checkall":"true","repair":false,"outputs":9,"x":670,"y":4480,"wires":[["b0aefece994685cd"],["e4f9f511900f900e"],["1cf33882938d2e07"],["14270cd891cb07b3"],["485127c9766bfe03"],["5912869d401d455d"],["d18d868830dd46d9"],["f613c3ef927ca02f"],["04496ce1c49de1bc"]]},{"id":"9c8ee840f1b4d922","type":"ha-sensor","z":"f237a1dd1abe1cd9","g":"46cbcbb3dce71e3b","name":"Text Temperature Comfort Outside","entityConfig":"001c273a2a395deb","version":0,"state":"topic","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":1300,"y":4460,"wires":[[]]},{"id":"b0aefece994685cd","type":"change","z":"f237a1dd1abe1cd9","g":"46cbcbb3dce71e3b","name":"FROSTY","rules":[{"t":"change","p":"topic","pt":"msg","from":"living","fromt":"str","to":"FROSTY","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":880,"y":4320,"wires":[["9c8ee840f1b4d922"]]},{"id":"e4f9f511900f900e","type":"change","z":"f237a1dd1abe1cd9","g":"46cbcbb3dce71e3b","name":"COLD","rules":[{"t":"change","p":"topic","pt":"msg","from":"living","fromt":"str","to":"COLD","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":870,"y":4360,"wires":[["9c8ee840f1b4d922"]]},{"id":"1cf33882938d2e07","type":"change","z":"f237a1dd1abe1cd9","g":"46cbcbb3dce71e3b","name":"CHILLY","rules":[{"t":"change","p":"topic","pt":"msg","from":"living","fromt":"str","to":"CHILLY","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":880,"y":4400,"wires":[["9c8ee840f1b4d922"]]},{"id":"485127c9766bfe03","type":"change","z":"f237a1dd1abe1cd9","g":"46cbcbb3dce71e3b","name":"MILD","rules":[{"t":"change","p":"topic","pt":"msg","from":"living","fromt":"str","to":"MILD","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":870,"y":4480,"wires":[["9c8ee840f1b4d922"]]},{"id":"5912869d401d455d","type":"change","z":"f237a1dd1abe1cd9","g":"46cbcbb3dce71e3b","name":"PERFECT","rules":[{"t":"change","p":"topic","pt":"msg","from":"living","fromt":"str","to":"PERFECT","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":890,"y":4520,"wires":[["9c8ee840f1b4d922"]]},{"id":"d18d868830dd46d9","type":"change","z":"f237a1dd1abe1cd9","g":"46cbcbb3dce71e3b","name":"WARM","rules":[{"t":"change","p":"topic","pt":"msg","from":"living","fromt":"str","to":"WARM","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":880,"y":4560,"wires":[["9c8ee840f1b4d922"]]},{"id":"f613c3ef927ca02f","type":"change","z":"f237a1dd1abe1cd9","g":"46cbcbb3dce71e3b","name":"HOT","rules":[{"t":"change","p":"topic","pt":"msg","from":"living","fromt":"str","to":"HOT","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":870,"y":4600,"wires":[["9c8ee840f1b4d922"]]},{"id":"04496ce1c49de1bc","type":"change","z":"f237a1dd1abe1cd9","g":"46cbcbb3dce71e3b","name":"BOILING","rules":[{"t":"change","p":"topic","pt":"msg","from":"living","fromt":"str","to":"BOILING","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":880,"y":4640,"wires":[["9c8ee840f1b4d922"]]},{"id":"bed1a9c8914d2bc3","type":"change","z":"f237a1dd1abe1cd9","g":"fb4a75e8044bdf96","name":"COOL","rules":[{"t":"change","p":"topic","pt":"msg","from":"upstairs","fromt":"str","to":"COOL","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":870,"y":4900,"wires":[["14f36c65bd6565e8"]]},{"id":"1f666e01e8dfe971","type":"api-current-state","z":"f237a1dd1abe1cd9","g":"fb4a75e8044bdf96","name":"TEMPERATURE UPSTAIRS","server":"bb380e72.b8825","version":3,"outputs":2,"halt_if":"0","halt_if_type":"num","halt_if_compare":"gt","entity_id":"sensor.netatmo_devonport_tas_indoor_temperature","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"upstairs","valueType":"str"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":460,"y":4940,"wires":[["dd99428e6357d9a5"],[]]},{"id":"dd99428e6357d9a5","type":"switch","z":"f237a1dd1abe1cd9","g":"fb4a75e8044bdf96","name":"","property":"payload","propertyType":"msg","rules":[{"t":"lt","v":"3","vt":"str"},{"t":"btwn","v":"3.1","vt":"num","v2":"4.9","v2t":"num"},{"t":"btwn","v":"5","vt":"num","v2":"8.9","v2t":"num"},{"t":"btwn","v":"9","vt":"num","v2":"13.9","v2t":"num"},{"t":"btwn","v":"14","vt":"num","v2":"18.9","v2t":"num"},{"t":"btwn","v":"19","vt":"num","v2":"23.9","v2t":"num"},{"t":"btwn","v":"24","vt":"num","v2":"27.9","v2t":"num"},{"t":"btwn","v":"28","vt":"num","v2":"34.9","v2t":"num"},{"t":"gt","v":"35","vt":"num"}],"checkall":"true","repair":false,"outputs":9,"x":670,"y":4940,"wires":[["e374d0c96d5b5532"],["af4c038a21b059ac"],["3f2e4788bc1ebb9a"],["bed1a9c8914d2bc3"],["a67794d2b5c2f1c0"],["064496cf8fde5e4b"],["b7fa37744b40e723"],["1ccce3796e2197ca"],["62c47b13aecb727a"]]},{"id":"14f36c65bd6565e8","type":"ha-sensor","z":"f237a1dd1abe1cd9","g":"fb4a75e8044bdf96","name":"Text Temperature Comfort Upstairs","entityConfig":"6f0db733629a856d","version":0,"state":"topic","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":1300,"y":4920,"wires":[[]]},{"id":"e374d0c96d5b5532","type":"change","z":"f237a1dd1abe1cd9","g":"fb4a75e8044bdf96","name":"FROSTY","rules":[{"t":"change","p":"topic","pt":"msg","from":"upstairs","fromt":"str","to":"FROSTY","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":880,"y":4780,"wires":[["14f36c65bd6565e8"]]},{"id":"af4c038a21b059ac","type":"change","z":"f237a1dd1abe1cd9","g":"fb4a75e8044bdf96","name":"COLD","rules":[{"t":"change","p":"topic","pt":"msg","from":"upstairs","fromt":"str","to":"COLD","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":870,"y":4820,"wires":[["14f36c65bd6565e8"]]},{"id":"3f2e4788bc1ebb9a","type":"change","z":"f237a1dd1abe1cd9","g":"fb4a75e8044bdf96","name":"CHILLY","rules":[{"t":"change","p":"topic","pt":"msg","from":"upstairs","fromt":"str","to":"CHILLY","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":880,"y":4860,"wires":[["14f36c65bd6565e8"]]},{"id":"a67794d2b5c2f1c0","type":"change","z":"f237a1dd1abe1cd9","g":"fb4a75e8044bdf96","name":"MILD","rules":[{"t":"change","p":"topic","pt":"msg","from":"upstairs","fromt":"str","to":"MILD","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":870,"y":4940,"wires":[["14f36c65bd6565e8"]]},{"id":"064496cf8fde5e4b","type":"change","z":"f237a1dd1abe1cd9","g":"fb4a75e8044bdf96","name":"PERFECT","rules":[{"t":"change","p":"topic","pt":"msg","from":"upstairs","fromt":"str","to":"PERFECT","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":890,"y":4980,"wires":[["14f36c65bd6565e8"]]},{"id":"b7fa37744b40e723","type":"change","z":"f237a1dd1abe1cd9","g":"fb4a75e8044bdf96","name":"WARM","rules":[{"t":"change","p":"topic","pt":"msg","from":"upstairs","fromt":"str","to":"WARM","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":880,"y":5020,"wires":[["14f36c65bd6565e8"]]},{"id":"1ccce3796e2197ca","type":"change","z":"f237a1dd1abe1cd9","g":"fb4a75e8044bdf96","name":"HOT","rules":[{"t":"change","p":"topic","pt":"msg","from":"upstairs","fromt":"str","to":"HOT","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":870,"y":5060,"wires":[["14f36c65bd6565e8"]]},{"id":"62c47b13aecb727a","type":"change","z":"f237a1dd1abe1cd9","g":"fb4a75e8044bdf96","name":"BOILING","rules":[{"t":"change","p":"topic","pt":"msg","from":"upstairs","fromt":"str","to":"BOILING","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":880,"y":5100,"wires":[["14f36c65bd6565e8"]]},{"id":"e90c20eb287ba0af","type":"inject","z":"f237a1dd1abe1cd9","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"60","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":170,"y":5300,"wires":[["43b280fe01c9c81e"]]},{"id":"03423252f2fd4cbd","type":"inject","z":"f237a1dd1abe1cd9","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"60","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":170,"y":5540,"wires":[["474d0e785e496c01"]]},{"id":"8b5c9bb9929df910","type":"inject","z":"f237a1dd1abe1cd9","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"60","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":170,"y":5780,"wires":[["7f3f96f1d570143c"]]},{"id":"3128e2f07d0a77a6","type":"inject","z":"f237a1dd1abe1cd9","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"60","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":170,"y":6020,"wires":[["3a2a31454e530b73"]]},{"id":"ba60e6d88367f9d5","type":"change","z":"f237a1dd1abe1cd9","g":"faf3195d9122a4d0","name":"NORMAL","rules":[{"t":"change","p":"topic","pt":"msg","from":"voc","fromt":"str","to":"NORMAL","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":900,"y":5260,"wires":[["52b807f3895ebd25"]]},{"id":"9a94494992cbd042","type":"change","z":"f237a1dd1abe1cd9","g":"faf3195d9122a4d0","name":"ABNORMAL","rules":[{"t":"change","p":"topic","pt":"msg","from":"voc","fromt":"str","to":"ABNORMAL","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":910,"y":5300,"wires":[["52b807f3895ebd25"]]},{"id":"cdd0ad438e9b2b51","type":"change","z":"f237a1dd1abe1cd9","g":"faf3195d9122a4d0","name":"HIGH","rules":[{"t":"change","p":"topic","pt":"msg","from":"voc","fromt":"str","to":"HIGH","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":890,"y":5340,"wires":[["52b807f3895ebd25"]]},{"id":"43b280fe01c9c81e","type":"api-current-state","z":"f237a1dd1abe1cd9","g":"faf3195d9122a4d0","name":"Aquarium VOC","server":"bb380e72.b8825","version":3,"outputs":2,"halt_if":"0","halt_if_type":"num","halt_if_compare":"gt","entity_id":"sensor.aarlo_air_quality_maverick_poo_poo_bunny","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"voc","valueType":"str"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":420,"y":5300,"wires":[["ecb84b7b7811be73"],[]]},{"id":"52b807f3895ebd25","type":"ha-sensor","z":"f237a1dd1abe1cd9","g":"faf3195d9122a4d0","name":"Text Aquarium Air Quality","entityConfig":"30e159446ef9d2b3","version":0,"state":"topic","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":1290,"y":5300,"wires":[[]]},{"id":"a04e394b91fc7fda","type":"switch","z":"f237a1dd1abe1cd9","g":"a36def9e9bfa7cae","name":"","property":"payload","propertyType":"msg","rules":[{"t":"lt","v":"39.9","vt":"str"},{"t":"btwn","v":"40","vt":"num","v2":"60","v2t":"num"},{"t":"gt","v":"60.1","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":670,"y":5540,"wires":[["3b1dc7d124b06903"],["0b836404f77474d0"],["c9e972176eb2f6c9"]]},{"id":"3b1dc7d124b06903","type":"change","z":"f237a1dd1abe1cd9","g":"a36def9e9bfa7cae","name":"DRY","rules":[{"t":"change","p":"topic","pt":"msg","from":"humidity","fromt":"str","to":"DRY","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":890,"y":5500,"wires":[["555397890103c20c"]]},{"id":"c9e972176eb2f6c9","type":"change","z":"f237a1dd1abe1cd9","g":"a36def9e9bfa7cae","name":"HUMID","rules":[{"t":"change","p":"topic","pt":"msg","from":"humidity","fromt":"str","to":"HUMID","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":900,"y":5580,"wires":[["555397890103c20c"]]},{"id":"0b836404f77474d0","type":"change","z":"f237a1dd1abe1cd9","g":"a36def9e9bfa7cae","name":"COMFY","rules":[{"t":"change","p":"topic","pt":"msg","from":"humidity","fromt":"str","to":"COMFY","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":900,"y":5540,"wires":[["555397890103c20c"]]},{"id":"555397890103c20c","type":"ha-sensor","z":"f237a1dd1abe1cd9","g":"a36def9e9bfa7cae","name":"Text Humidity Comfort Airport DIRECT","entityConfig":"b1526b8e7bf2fcb2","version":0,"state":"topic","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":1250,"y":5540,"wires":[[]]},{"id":"474d0e785e496c01","type":"api-current-state","z":"f237a1dd1abe1cd9","g":"a36def9e9bfa7cae","name":"Airport Humidity","server":"bb380e72.b8825","version":3,"outputs":2,"halt_if":"0","halt_if_type":"num","halt_if_compare":"gt","entity_id":"sensor.devonport_airport_humidity","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"humidity","valueType":"str"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":420,"y":5540,"wires":[["a04e394b91fc7fda"],[]]},{"id":"e0b40a80f10ff490","type":"switch","z":"f237a1dd1abe1cd9","g":"af783cc74b08fab8","name":"","property":"payload","propertyType":"msg","rules":[{"t":"lt","v":"39.9","vt":"str"},{"t":"btwn","v":"40","vt":"num","v2":"60","v2t":"num"},{"t":"gt","v":"60.1","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":670,"y":5780,"wires":[["87bb7ab68b0b96c4"],["a515247b1d1cf793"],["d4279e9508816950"]]},{"id":"87bb7ab68b0b96c4","type":"change","z":"f237a1dd1abe1cd9","g":"af783cc74b08fab8","name":"DRY","rules":[{"t":"change","p":"topic","pt":"msg","from":"humidity","fromt":"str","to":"DRY","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":890,"y":5740,"wires":[["1051e9e0197952f3"]]},{"id":"d4279e9508816950","type":"change","z":"f237a1dd1abe1cd9","g":"af783cc74b08fab8","name":"HUMID","rules":[{"t":"change","p":"topic","pt":"msg","from":"humidity","fromt":"str","to":"HUMID","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":900,"y":5820,"wires":[["1051e9e0197952f3"]]},{"id":"a515247b1d1cf793","type":"change","z":"f237a1dd1abe1cd9","g":"af783cc74b08fab8","name":"COMFY","rules":[{"t":"change","p":"topic","pt":"msg","from":"humidity","fromt":"str","to":"COMFY","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":900,"y":5780,"wires":[["1051e9e0197952f3"]]},{"id":"1051e9e0197952f3","type":"ha-sensor","z":"f237a1dd1abe1cd9","g":"af783cc74b08fab8","name":"Text Humidity Comfort Outside DIRECT","entityConfig":"11d66c684676f7d9","version":0,"state":"topic","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":1240,"y":5780,"wires":[[]]},{"id":"7f3f96f1d570143c","type":"api-current-state","z":"f237a1dd1abe1cd9","g":"af783cc74b08fab8","name":"Outside Humidity","server":"bb380e72.b8825","version":3,"outputs":2,"halt_if":"0","halt_if_type":"num","halt_if_compare":"gt","entity_id":"sensor.netatmo_devonport_tas_indoor_outdoor_humidity","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"humidity","valueType":"str"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":430,"y":5780,"wires":[["e0b40a80f10ff490"],[]]},{"id":"aa2587cf2a922c74","type":"switch","z":"f237a1dd1abe1cd9","g":"fa9293e728faf3fa","name":"","property":"payload","propertyType":"msg","rules":[{"t":"lt","v":"39.9","vt":"str"},{"t":"btwn","v":"40","vt":"num","v2":"60","v2t":"num"},{"t":"gt","v":"60.1","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":670,"y":6020,"wires":[["8f8d44caa8de0719"],["45929454771a71cd"],["e3ba472d66a26bc2"]]},{"id":"8f8d44caa8de0719","type":"change","z":"f237a1dd1abe1cd9","g":"fa9293e728faf3fa","name":"DRY","rules":[{"t":"change","p":"topic","pt":"msg","from":"humidity","fromt":"str","to":"DRY","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":890,"y":5980,"wires":[["60dd93ddb3065f98"]]},{"id":"e3ba472d66a26bc2","type":"change","z":"f237a1dd1abe1cd9","g":"fa9293e728faf3fa","name":"HUMID","rules":[{"t":"change","p":"topic","pt":"msg","from":"humidity","fromt":"str","to":"HUMID","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":900,"y":6060,"wires":[["60dd93ddb3065f98"]]},{"id":"45929454771a71cd","type":"change","z":"f237a1dd1abe1cd9","g":"fa9293e728faf3fa","name":"COMFY","rules":[{"t":"change","p":"topic","pt":"msg","from":"humidity","fromt":"str","to":"COMFY","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":900,"y":6020,"wires":[["60dd93ddb3065f98"]]},{"id":"60dd93ddb3065f98","type":"ha-sensor","z":"f237a1dd1abe1cd9","g":"fa9293e728faf3fa","name":"Text Humidity Comfort Humidity Upstairs DIRECT","entityConfig":"ae2394fde902cd08","version":0,"state":"topic","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":1210,"y":6020,"wires":[[]]},{"id":"3a2a31454e530b73","type":"api-current-state","z":"f237a1dd1abe1cd9","g":"fa9293e728faf3fa","name":"Upstairs Humidity","server":"bb380e72.b8825","version":3,"outputs":2,"halt_if":"0","halt_if_type":"num","halt_if_compare":"gt","entity_id":"sensor.netatmo_devonport_tas_indoor_humidity","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"humidity","valueType":"str"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":430,"y":6020,"wires":[["aa2587cf2a922c74"],[]]},{"id":"1f7d36222ea60cca","type":"comment","z":"f237a1dd1abe1cd9","g":"f6b19d555014ff15","name":"INSTRUCTIONS FOR USE - DOUBLE CLICK ME","info":"1. Insert your temperature sensor in the 'Current State' Node\n2. payload.topic is what switched the numbers to words\n2. Ensure the Sensor is setup and named.","x":530,"y":3400,"wires":[]},{"id":"878ac0e5286fb69e","type":"comment","z":"f237a1dd1abe1cd9","g":"4616a089546015eb","name":"INSTRUCTIONS FOR USE - DOUBLE CLICK ME","info":"1. Insert your temperature sensor in the 'Current State' Node\n2. payload.topic is what switched the numbers to words\n2. Ensure the Sensor is setup and named.","x":530,"y":3860,"wires":[]},{"id":"000fe7b1476b9767","type":"comment","z":"f237a1dd1abe1cd9","g":"46cbcbb3dce71e3b","name":"INSTRUCTIONS FOR USE - DOUBLE CLICK ME","info":"1. Insert your temperature sensor in the 'Current State' Node\n2. payload.topic is what switched the numbers to words\n2. Ensure the Sensor is setup and named.","x":530,"y":4320,"wires":[]},{"id":"ee3689a3d3e307e2","type":"comment","z":"f237a1dd1abe1cd9","g":"fb4a75e8044bdf96","name":"INSTRUCTIONS FOR USE - DOUBLE CLICK ME","info":"1. Insert your temperature sensor in the 'Current State' Node\n2. payload.topic is what switched the numbers to words\n2. Ensure the Sensor is setup and named.","x":530,"y":4780,"wires":[]},{"id":"083726a3bf488ea2","type":"comment","z":"f237a1dd1abe1cd9","g":"faf3195d9122a4d0","name":"INSTRUCTIONS FOR USE - DOUBLE CLICK ME","info":"1. If you have a VOC Sensor this will conver the ppm of the sensor to readable text","x":550,"y":5240,"wires":[]},{"id":"2282ceefc90b8d2b","type":"comment","z":"f237a1dd1abe1cd9","g":"a36def9e9bfa7cae","name":"INSTRUCTIONS FOR USE - DOUBLE CLICK ME","info":"1. For Non-TADO Devices this will convert humidity to comfort words similar to TADO","x":530,"y":5480,"wires":[]},{"id":"69e20f0ade971756","type":"comment","z":"f237a1dd1abe1cd9","g":"af783cc74b08fab8","name":"INSTRUCTIONS FOR USE - DOUBLE CLICK ME","info":"1. For Non-TADO Devices this will convert humidity to comfort words similar to TADO","x":530,"y":5720,"wires":[]},{"id":"4ffafa2fa44a7440","type":"comment","z":"f237a1dd1abe1cd9","g":"fa9293e728faf3fa","name":"INSTRUCTIONS FOR USE - DOUBLE CLICK ME","info":"1. For Non-TADO Devices this will convert humidity to comfort words similar to TADO","x":530,"y":5960,"wires":[]},{"id":"5f1664d7fde0423f","type":"comment","z":"f237a1dd1abe1cd9","g":"7c164373aa514aec","name":"INSTRUCTIONS FOR USE - DOUBLE CLICK ME","info":"1. These Snesors Grab the words HUMID,COMFY,DRY or WARM,COMFY,COLD","x":1250,"y":320,"wires":[]},{"id":"3146be8f10fe5e42","type":"function","z":"f237a1dd1abe1cd9","g":"7c164373aa514aec","name":"Temp Upstairs Radial%","func":"msg.payload = msg.payload.comfort[0].coordinate.radial\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":930,"y":600,"wires":[["9d97559fd81b9dd0"]]},{"id":"1484ca91eadc7641","type":"function","z":"f237a1dd1abe1cd9","g":"7c164373aa514aec","name":"Temp Downstairs Radial%","func":"msg.payload = msg.payload.comfort[1].coordinate.radial\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":930,"y":660,"wires":[["aabda1c5b7dc9d42"]]},{"id":"9d97559fd81b9dd0","type":"ha-sensor","z":"f237a1dd1abe1cd9","g":"7c164373aa514aec","name":"Radial% Temp Comfort Living TADO","entityConfig":"6bac5c351f335b62","version":0,"state":"payload","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":1210,"y":600,"wires":[[]]},{"id":"aabda1c5b7dc9d42","type":"ha-sensor","z":"f237a1dd1abe1cd9","g":"7c164373aa514aec","name":"Radial% Temp Comfort Downstairs TADO","entityConfig":"d516b36dd6e3305b","version":0,"state":"payload","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":1220,"y":660,"wires":[[]]},{"id":"ecb84b7b7811be73","type":"switch","z":"f237a1dd1abe1cd9","g":"faf3195d9122a4d0","name":"","property":"payload","propertyType":"msg","rules":[{"t":"btwn","v":"0","vt":"num","v2":"15.9","v2t":"num"},{"t":"btwn","v":"16","vt":"num","v2":"25.9","v2t":"num"},{"t":"gte","v":"26","vt":"str"}],"checkall":"false","repair":false,"outputs":3,"x":670,"y":5300,"wires":[["ba60e6d88367f9d5"],["9a94494992cbd042"],["cdd0ad438e9b2b51"]]},{"id":"83e627ce7e032c20","type":"tado-config","name":"Home"},{"id":"342e9f732e307789","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"424de856f01d937c","name":"Text Humid Comfort Living Room TADO","version":"6","entityType":"sensor","haConfig":[{"property":"name","value":"Text Humid Comfort Living Room TADO"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":"diagnostic"},{"property":"device_class","value":""},{"property":"unit_of_measurement","value":""},{"property":"state_class","value":""}],"resend":false,"debugEnabled":false},{"id":"0bea21c95733d694","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"d332edb02ff44fce","name":"Text Humid Comfort Downstairs TADO","version":"6","entityType":"sensor","haConfig":[{"property":"name","value":"Text Humid Comfort Downstairs TADO"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":"diagnostic"},{"property":"device_class","value":""},{"property":"unit_of_measurement","value":""},{"property":"state_class","value":""}],"resend":false,"debugEnabled":false},{"id":"1b10a150d847503f","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"a47628b373eee6d6","name":"Text Temp Comfort Downstairs TADO","version":"6","entityType":"sensor","haConfig":[{"property":"name","value":"Text Temp Comfort Downstairs TADO"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":"diagnostic"},{"property":"device_class","value":""},{"property":"unit_of_measurement","value":""},{"property":"state_class","value":""}],"resend":false,"debugEnabled":false},{"id":"2945a8dbfe07293f","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"756205d2738a45a1","name":"Text Temp Comfort Living TADO","version":"6","entityType":"sensor","haConfig":[{"property":"name","value":"Text Temp Comfort Living TADO"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""},{"property":"unit_of_measurement","value":""},{"property":"state_class","value":""}],"resend":false,"debugEnabled":false},{"id":"bb380e72.b8825","type":"server","name":"Home Assistant","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":"30","areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true},{"id":"54d904eea36be7a2","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"c14f2672952cdcc4","name":"Text Dewpoint Comfort Airport","version":"6","entityType":"sensor","haConfig":[{"property":"name","value":"Text Dewpoint Comfort Airport"},{"property":"icon","value":"mdi:format-text"},{"property":"entity_picture","value":""},{"property":"entity_category","value":"diagnostic"},{"property":"device_class","value":""},{"property":"unit_of_measurement","value":""},{"property":"state_class","value":""}],"resend":false,"debugEnabled":false},{"id":"d25ff2fcac41fc46","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"6e60982ac855dab1","name":"Text Dewpoint Comfort Downstairs","version":"6","entityType":"sensor","haConfig":[{"property":"name","value":"Text Dewpoint Comfort Downstairs"},{"property":"icon","value":"mdi:format-text"},{"property":"entity_picture","value":""},{"property":"entity_category","value":"diagnostic"},{"property":"device_class","value":""},{"property":"unit_of_measurement","value":""},{"property":"state_class","value":""}],"resend":false,"debugEnabled":false},{"id":"dd54d12d846a0210","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"5099de566808603e","name":"Text Dewpoint Comfort Outside","version":"6","entityType":"sensor","haConfig":[{"property":"name","value":"Text Dewpoint Comfort Outside"},{"property":"icon","value":"mdi:format-text"},{"property":"entity_picture","value":""},{"property":"entity_category","value":"diagnostic"},{"property":"device_class","value":""},{"property":"unit_of_measurement","value":""},{"property":"state_class","value":""}],"resend":false,"debugEnabled":false},{"id":"6fcaa548b4287ada","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"8442342d6cd9196f","name":"Text Dewpoint Comfort Living","version":"6","entityType":"sensor","haConfig":[{"property":"name","value":"Text Dewpoint Comfort Living"},{"property":"icon","value":"mdi:format-text"},{"property":"entity_picture","value":""},{"property":"entity_category","value":"diagnostic"},{"property":"device_class","value":""},{"property":"unit_of_measurement","value":""},{"property":"state_class","value":""}],"resend":false,"debugEnabled":false},{"id":"42bf29847067a3c5","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"f463ec2d456b189d","name":"Text Dewpoint Comfort Upstairs","version":"6","entityType":"sensor","haConfig":[{"property":"name","value":"Text Dewpoint Comfort Upstairs"},{"property":"icon","value":"mdi:format-text"},{"property":"entity_picture","value":""},{"property":"entity_category","value":"diagnostic"},{"property":"device_class","value":""},{"property":"unit_of_measurement","value":""},{"property":"state_class","value":""}],"resend":false,"debugEnabled":false},{"id":"f67b15906bc496bb","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"78dc4fa27082302b","name":"Text Temperature Comfort Living","version":"6","entityType":"sensor","haConfig":[{"property":"name","value":"Text Temperature Comfort Living"},{"property":"icon","value":"mdi:format-text"},{"property":"entity_picture","value":""},{"property":"entity_category","value":"diagnostic"},{"property":"device_class","value":""},{"property":"unit_of_measurement","value":""},{"property":"state_class","value":""}],"resend":false,"debugEnabled":false},{"id":"2bf6f5ae9b3e904b","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"15a50bfb540293b1","name":"Text Temperature Comfort Airport","version":"6","entityType":"sensor","haConfig":[{"property":"name","value":"Text Temperature Comfort Airport"},{"property":"icon","value":"mdi:format-text"},{"property":"entity_picture","value":""},{"property":"entity_category","value":"diagnostic"},{"property":"device_class","value":""},{"property":"unit_of_measurement","value":""},{"property":"state_class","value":""}],"resend":false,"debugEnabled":false},{"id":"907b0dc00e3026e6","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"d3a6abefab8d9d36","name":"Text Temperature Comfort Downstairs","version":"6","entityType":"sensor","haConfig":[{"property":"name","value":"Text Temperature Comfort Downstairs"},{"property":"icon","value":"mdi:format-text"},{"property":"entity_picture","value":""},{"property":"entity_category","value":"diagnostic"},{"property":"device_class","value":""},{"property":"unit_of_measurement","value":""},{"property":"state_class","value":""}],"resend":false,"debugEnabled":false},{"id":"001c273a2a395deb","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"a7d52b4c03462d65","name":"Text Temperature Comfort Outside","version":"6","entityType":"sensor","haConfig":[{"property":"name","value":"Text Temperature Comfort Outside"},{"property":"icon","value":"mdi:format-text"},{"property":"entity_picture","value":""},{"property":"entity_category","value":"diagnostic"},{"property":"device_class","value":""},{"property":"unit_of_measurement","value":""},{"property":"state_class","value":""}],"resend":false,"debugEnabled":false},{"id":"6f0db733629a856d","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"6d68af4fa4d6c706","name":"Text Temperature Comfort Upstairs","version":"6","entityType":"sensor","haConfig":[{"property":"name","value":"Text Temperature Comfort Upstairs"},{"property":"icon","value":"mdi:format-text"},{"property":"entity_picture","value":""},{"property":"entity_category","value":"diagnostic"},{"property":"device_class","value":""},{"property":"unit_of_measurement","value":""},{"property":"state_class","value":""}],"resend":false,"debugEnabled":false},{"id":"30e159446ef9d2b3","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"e4aaee18f2207f17","name":"Text Aquarium Air Quality","version":"6","entityType":"sensor","haConfig":[{"property":"name","value":"Text Aquarium Air Quality"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":"diagnostic"},{"property":"device_class","value":""},{"property":"unit_of_measurement","value":""},{"property":"state_class","value":""}],"resend":false,"debugEnabled":false},{"id":"b1526b8e7bf2fcb2","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"a1a18a6462d55de8","name":"Text Humidity Comfort Airport DIRECT","version":"6","entityType":"sensor","haConfig":[{"property":"name","value":"Text Humidity Comfort Airport DIRECT"},{"property":"icon","value":"mdi:format-text"},{"property":"entity_picture","value":""},{"property":"entity_category","value":"diagnostic"},{"property":"device_class","value":""},{"property":"unit_of_measurement","value":""},{"property":"state_class","value":""}],"resend":false,"debugEnabled":false},{"id":"11d66c684676f7d9","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"7fcc9985cb4b8878","name":"Text Humidity Comfort Outside DIRECT","version":"6","entityType":"sensor","haConfig":[{"property":"name","value":"Text Humidity Comfort Outside DIRECT"},{"property":"icon","value":"mdi:format-text"},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""},{"property":"unit_of_measurement","value":""},{"property":"state_class","value":""}],"resend":false,"debugEnabled":false},{"id":"ae2394fde902cd08","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"91072e4d6f9cdec8","name":"Text Humidity Comfort Upstairs DIRECT","version":"6","entityType":"sensor","haConfig":[{"property":"name","value":"Text Humidity Comfort Upstairs DIRECT"},{"property":"icon","value":"mdi:format-text"},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""},{"property":"unit_of_measurement","value":""},{"property":"state_class","value":""}],"resend":false,"debugEnabled":false},{"id":"6bac5c351f335b62","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"ea5a78da4a364108","name":"Radial% Temp Comfort Living TADO","version":"6","entityType":"sensor","haConfig":[{"property":"name","value":"Radial% Temp Comfort Living TADO"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":"diagnostic"},{"property":"device_class","value":""},{"property":"unit_of_measurement","value":""},{"property":"state_class","value":""}],"resend":false,"debugEnabled":false},{"id":"d516b36dd6e3305b","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"51fb736de2c5f0da","name":"Radial% Temp Comfort Downstairs TADO","version":"6","entityType":"sensor","haConfig":[{"property":"name","value":"Radial% Temp Comfort Downstairs TADO"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":"diagnostic"},{"property":"device_class","value":""},{"property":"unit_of_measurement","value":""},{"property":"state_class","value":""}],"resend":false,"debugEnabled":false},{"id":"424de856f01d937c","type":"ha-device-config","name":"Text Humid Comfort Living Room TADO","hwVersion":"","manufacturer":"Node-RED","model":"TADO-New","swVersion":""},{"id":"d332edb02ff44fce","type":"ha-device-config","name":"Text Humid Comfort Downstairs TADO","hwVersion":"","manufacturer":"Node-RED","model":"TADO-New","swVersion":""},{"id":"a47628b373eee6d6","type":"ha-device-config","name":"Text Temp Comfort Downstairs TADO","hwVersion":"","manufacturer":"Node-RED","model":"TADO-New","swVersion":""},{"id":"756205d2738a45a1","type":"ha-device-config","name":"Text Temp Comfort Living TADO","hwVersion":"","manufacturer":"Node-RED","model":"TADO-New","swVersion":""},{"id":"c14f2672952cdcc4","type":"ha-device-config","name":"Text Dewpoint Comfort Airport","hwVersion":"","manufacturer":"Node-RED","model":"","swVersion":""},{"id":"6e60982ac855dab1","type":"ha-device-config","name":"Text Dewpoint Comfort Downstairs","hwVersion":"","manufacturer":"Node-RED","model":"","swVersion":""},{"id":"5099de566808603e","type":"ha-device-config","name":"Text Dewpoint Comfort Outside","hwVersion":"","manufacturer":"Node-RED","model":"","swVersion":""},{"id":"8442342d6cd9196f","type":"ha-device-config","name":"Text Dewpoint Comfort Living","hwVersion":"","manufacturer":"Node-RED","model":"","swVersion":""},{"id":"f463ec2d456b189d","type":"ha-device-config","name":"Text Dewpoint Comfort Upstairs","hwVersion":"","manufacturer":"Node-RED","model":"","swVersion":""},{"id":"78dc4fa27082302b","type":"ha-device-config","name":"Text Temperature Comfort Living","hwVersion":"","manufacturer":"Node-RED","model":"","swVersion":""},{"id":"15a50bfb540293b1","type":"ha-device-config","name":"Text Temperature Comfort Airport","hwVersion":"","manufacturer":"Node-RED","model":"","swVersion":""},{"id":"d3a6abefab8d9d36","type":"ha-device-config","name":"Text Temperature Comfort Downstairs","hwVersion":"","manufacturer":"Node-RED","model":"","swVersion":""},{"id":"a7d52b4c03462d65","type":"ha-device-config","name":"Text Temperature Comfort Outside","hwVersion":"","manufacturer":"Node-RED","model":"","swVersion":""},{"id":"6d68af4fa4d6c706","type":"ha-device-config","name":"Text Temperature Comfort Upstairs","hwVersion":"","manufacturer":"Node-RED","model":"","swVersion":""},{"id":"e4aaee18f2207f17","type":"ha-device-config","name":"Text Aquarium Air Quality","hwVersion":"","manufacturer":"Node-RED","model":"","swVersion":""},{"id":"a1a18a6462d55de8","type":"ha-device-config","name":"Text Humidity Comfort Airport DIRECT ","hwVersion":"","manufacturer":"Node-RED","model":"","swVersion":""},{"id":"7fcc9985cb4b8878","type":"ha-device-config","name":"Text Humidity Comfort Outside DIRECT","hwVersion":"","manufacturer":"Node-RED","model":"","swVersion":""},{"id":"91072e4d6f9cdec8","type":"ha-device-config","name":"Text Humidity Comfort Upstairs DIRECT","hwVersion":"","manufacturer":"Node-RED","model":"","swVersion":""},{"id":"ea5a78da4a364108","type":"ha-device-config","name":"Radial% Temp Comfort Living TADO","hwVersion":"","manufacturer":"Node-RED","model":"","swVersion":""},{"id":"51fb736de2c5f0da","type":"ha-device-config","name":"Radial% Temp Comfort Downstairs TADO","hwVersion":"","manufacturer":"Node-RED","model":"","swVersion":""}]
Created 2 years, 10 months ago
Rating: 5 3
  • change (x105)
  • comment (x16)
  • function (x6)
  • inject (x10)
  • switch (x14)
  • Air
  • Comfort
  • Humidity
  • Temperature
  • DewPoint
  • Tado
  • Outdoor
  • Indoor
  • weather
  • Convertor
  • Text
  • Description
  • Weather
  • Words
  • Simple
  • Card
  • Home
  • Assistant
  • Dew
  • Point
  • Simple Air Comfort Card
  • VOC
  • CO2
