Harmony Hub Activity Selector & Button Mapper (Sanytron Astrion & HA)
Requirements
node-red-contrib-harmony-extra
node-red-contrib-home-assistant-websocket
Functions
Harmony Button Mapper
The Button Press Nodes are exposed to Home Assistant as button entities.
The Flow detects what Harmony Activity is Active and then will Re-Map the button Press to the right device.
Wrap the buttons exposed to Home Assistant in scripts repeat for each button entity
image image
Map each script to the ROS TV Card
ROS TV CARD YAML
type: custom:aiks-tv-card
uuid: 3b7fbb52-3718-4d69-8f8c-6e519f26a2e2
tv_type: android_tv
tv_name: Shield TV
media_play_entity: media_player.shield_debug_bridge
entities:
  - key: POWER
    type: script
    entity_id: script.ros_tv_toggle
    value: SHIELD TV
  - key: UP
    type: script
    entity_id: script.ros_up
    value: UP
  - key: DOWN
    type: script
    entity_id: script.ros_down
    value: DOWN
  - key: LEFT
    type: script
    entity_id: script.ros_left
    value: LEFT
  - key: RIGHT
    type: script
    entity_id: script.ros_right
    value: RIGHT
  - key: CENTER
    type: script
    entity_id: script.ros_select
    value: CENTER
  - key: BACK
    type: script
    entity_id: script.ros_back
    value: BACK
  - key: PLAY
    type: script
    entity_id: script.ros_play
    value: PLAY
  - key: PAUSE
    type: script
    entity_id: script.ros_pause
    value: PAUSE
  - key: VOLUME_UP
    type: script
    entity_id: script.ros_volume_up
    value: ""
  - key: VOLUME_DOWN
    type: script
    entity_id: script.ros_volume_down
    value: ""
  - key: MUTE
    type: script
    entity_id: script.ros_mute
    value: MUTE
  - key: UN_MUTE
    type: script
    value: UNMUTE
  - key: SETTINGS
    type: script
    entity_id: script.ros_menu
    value: SETTINGS
  - key: HOME
    type: script
    entity_id: script.ros_home
    value: HOME
  - key: MENU
    type: script
    value: MENU
  - key: CHANNEL_UP
    type: script
    entity_id: script.ros_surroundmode
    value: ""
  - key: CHANNEL_DOWN
    type: script
    value: ""
  - key: NUM_0
    type: ""
    entity_id: ""
    value: ""
  - key: NUM_1
    type: ""
    entity_id: ""
    value: ""
  - key: NUM_2
    type: ""
    entity_id: ""
    value: ""
  - key: NUM_3
    type: ""
    entity_id: ""
    value: ""
  - key: NUM_4
    type: ""
    entity_id: ""
    value: ""
  - key: NUM_5
    type: ""
    entity_id: ""
    value: ""
  - key: NUM_6
    type: ""
    entity_id: ""
    value: ""
  - key: NUM_7
    type: ""
    entity_id: ""
    value: ""
  - key: NUM_8
    type: ""
    entity_id: ""
    value: ""
  - key: NUM_9
    type: ""
    entity_id: ""
    value: ""
  - key: DELETE
    type: ""
    entity_id: ""
    value: ""
  - key: KEY_A
    type: ""
    entity_id: ""
    value: ""
  - key: KEY_B
    type: ""
    entity_id: ""
    value: ""
  - key: KEY_C
    type: ""
    entity_id: ""
    value: ""
Harmony Activity Mapper
Provides switch entites that can be used with the ROS Switch Control card
Automatically manages the state of the switches and keeps sync with the Harmony Hub if operating from the Harmony remote, not just the Astrion Remote.
Map each switch to the ROS Switch Control Card
These will be available on the remote to switch between activities including off.
NOTE: ROS TV Toggle is mapped to the power button in the ROS TV Card, it switches remote.harmony_hub on (last activity) and powers off using the power_off activity.
ROS Switch Control Card YAML
type: custom:aiks-switch-card
entities:
  - entity_id: switch.harmony_off_harmony_off
    uuid: f66fa7af-053c-4606-bf9a-5c123fafaedd
    alias: ""
  - entity_id: switch.tv
    uuid: b9877ab7-00dd-4443-adac-305a578284db
    alias: ""
  - entity_id: switch.normal_tv
    uuid: 93003fa3-9dc2-4871-83c2-029edbd3469a
    alias: ""
  - entity_id: switch.dvd
    uuid: c493d80a-48e8-4e17-bd02-4705a036908e
    alias: ""
  - entity_id: switch.nintendo
    uuid: e9dea932-ab4a-4afb-8b5c-18bad10ed89b
    alias: ""
  - entity_id: switch.record_player
    uuid: cb5f9118-d7d1-43d5-bdb9-1c13b7a14681
    alias: ""
Keep Harmony Alive
Sometimes NodeRED drops connection with the Harmony Hub, resulting in a non-responsive remote. This flow ensures the connection stays alive
image image
[{"id":"e6058a2e41facfd8","type":"api-call-service","z":"fbc96b6cec386837","name":"","server":"bb380e72.b8825","version":7,"debugenabled":false,"action":"script.restart_harmony_hub","floorId":[],"areaId":[],"deviceId":[],"entityId":[],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":true,"domain":"script","service":"restart_harmony_hub","x":940,"y":240,"wires":[[]]},{"id":"79051232efb39abe","type":"debug","z":"fbc96b6cec386837","name":"debug 1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":2120,"y":200,"wires":[]},{"id":"1c0305e181a69a96","type":"switch","z":"fbc96b6cec386837","name":"msg.payload","property":"payload","propertyType":"msg","rules":[{"t":"true"},{"t":"false"}],"checkall":"true","repair":false,"outputs":2,"x":1850,"y":300,"wires":[["79051232efb39abe"],["e98f6ee8fc6224ee"]]},{"id":"53b2d45edf939238","type":"switch","z":"fbc96b6cec386837","name":"msg.payload","property":"payload","propertyType":"msg","rules":[{"t":"true"},{"t":"false"}],"checkall":"true","repair":false,"outputs":2,"x":1850,"y":360,"wires":[["79051232efb39abe"],["e98f6ee8fc6224ee"]]},{"id":"f659e0cf96a8539f","type":"switch","z":"fbc96b6cec386837","name":"msg.payload","property":"payload","propertyType":"msg","rules":[{"t":"true"},{"t":"false"}],"checkall":"true","repair":false,"outputs":2,"x":1850,"y":420,"wires":[["79051232efb39abe"],["e98f6ee8fc6224ee"]]},{"id":"cc38149e45b8c783","type":"switch","z":"fbc96b6cec386837","name":"msg.payload","property":"payload","propertyType":"msg","rules":[{"t":"true"},{"t":"false"}],"checkall":"true","repair":false,"outputs":2,"x":1850,"y":480,"wires":[["79051232efb39abe"],["e98f6ee8fc6224ee"]]},{"id":"7d087e72be5b0c69","type":"switch","z":"fbc96b6cec386837","name":"msg.payload","property":"payload","propertyType":"msg","rules":[{"t":"true"},{"t":"false"}],"checkall":"true","repair":false,"outputs":2,"x":1850,"y":540,"wires":[["79051232efb39abe"],["e98f6ee8fc6224ee"]]},{"id":"8369e92cdf06c9ce","type":"group","z":"fbc96b6cec386837","name":"Button Entities (Wraped in scripts for ROS TV Card)","style":{"label":true},"nodes":["8aab8aeae3bdc7ae","8fd5a07b49e8bb3a","a4b96ab23ce3d663","cd1cdc1a5f3fe08d","2da382adad467c6c","84b799ddd542ba22","70d5d5e2ce7b7bfc","261aaded942e4160","f5ebbdddb8cb16f8","c44160c392ee6666","75642f1f8d166d08","15aec5c5c450e28d","e9b0340a9dce1390","ee291ac418d0f613","1220c1d58bb31502"],"x":208,"y":298,"w":844,"h":1509},{"id":"8aab8aeae3bdc7ae","type":"ha-button","z":"fbc96b6cec386837","g":"8369e92cdf06c9ce","name":"Harmony Up","version":0,"debugenabled":false,"outputs":1,"entityConfig":"67bc85994e5c6d17","outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"x":330,"y":380,"wires":[["b5bdce60f3d30526"]]},{"id":"8fd5a07b49e8bb3a","type":"ha-button","z":"fbc96b6cec386837","g":"8369e92cdf06c9ce","name":"Harmony Down","version":0,"debugenabled":false,"outputs":1,"entityConfig":"dfc4830a913f1d86","outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"x":340,"y":440,"wires":[["aa30ad05053e822c"]]},{"id":"a4b96ab23ce3d663","type":"ha-button","z":"fbc96b6cec386837","g":"8369e92cdf06c9ce","name":"Harmony Left","version":0,"debugenabled":false,"outputs":1,"entityConfig":"ca1b92ca8bacf0c3","outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"x":330,"y":500,"wires":[["b6f4a92e1a1e6de3"]]},{"id":"cd1cdc1a5f3fe08d","type":"ha-button","z":"fbc96b6cec386837","g":"8369e92cdf06c9ce","name":"Harmony Right","version":0,"debugenabled":false,"outputs":1,"entityConfig":"ca2a4c203e9cc0b1","outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"x":340,"y":560,"wires":[["493644565a2a7f3b"]]},{"id":"2da382adad467c6c","type":"ha-button","z":"fbc96b6cec386837","g":"8369e92cdf06c9ce","name":"Harmony Select","version":0,"debugenabled":false,"outputs":1,"entityConfig":"5db89a4bf57bce2b","outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"x":340,"y":620,"wires":[["23cc066878440174"]]},{"id":"84b799ddd542ba22","type":"ha-button","z":"fbc96b6cec386837","g":"8369e92cdf06c9ce","name":"Harmony Skip Back","version":0,"debugenabled":false,"outputs":1,"entityConfig":"bc296c6b71a6c03a","outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"x":350,"y":680,"wires":[["1e545c5f8d69de3e"]]},{"id":"70d5d5e2ce7b7bfc","type":"ha-button","z":"fbc96b6cec386837","g":"8369e92cdf06c9ce","name":"Harmony Skip Forward","version":0,"debugenabled":false,"outputs":1,"entityConfig":"7e00791ced34893f","outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"x":360,"y":740,"wires":[["5bafb3b12480ed6c"]]},{"id":"261aaded942e4160","type":"ha-button","z":"fbc96b6cec386837","g":"8369e92cdf06c9ce","name":"Harmony Play","version":0,"debugenabled":false,"outputs":1,"entityConfig":"f0f91851098d8ea9","outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"x":330,"y":800,"wires":[["28be7cc1a2a0d197"]]},{"id":"f5ebbdddb8cb16f8","type":"ha-button","z":"fbc96b6cec386837","g":"8369e92cdf06c9ce","name":"Harmony Pause","version":0,"debugenabled":false,"outputs":1,"entityConfig":"73daed85ed139a5b","outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"x":340,"y":860,"wires":[["c532fc6a545f0ad0"]]},{"id":"c44160c392ee6666","type":"ha-button","z":"fbc96b6cec386837","g":"8369e92cdf06c9ce","name":"Harmony Home","version":0,"debugenabled":false,"outputs":1,"entityConfig":"300c0c2e7774969c","outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"x":340,"y":920,"wires":[["98d1bad9eae01129"]]},{"id":"75642f1f8d166d08","type":"ha-button","z":"fbc96b6cec386837","g":"8369e92cdf06c9ce","name":"Harmony Back","version":0,"debugenabled":false,"outputs":1,"entityConfig":"3b2edc921282b0b0","outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"x":340,"y":980,"wires":[["061bb0ff3b0b982f"]]},{"id":"15aec5c5c450e28d","type":"ha-button","z":"fbc96b6cec386837","g":"8369e92cdf06c9ce","name":"Harmony Menu","version":0,"debugenabled":false,"outputs":1,"entityConfig":"cef3bacd7f9c2fdf","outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"x":340,"y":1040,"wires":[["150a14637a42b1b1"]]},{"id":"e9b0340a9dce1390","type":"group","z":"fbc96b6cec386837","g":"8369e92cdf06c9ce","name":"Detect Activity & Switch Device Buttons","style":{"label":true,"fill":"#ffff00"},"nodes":["77e68bfdefaecc6b","b5bdce60f3d30526","018f9716714a0b55","aa30ad05053e822c","d1c61411014527ab","b6f4a92e1a1e6de3","d7d7e9ba6f178ebe","493644565a2a7f3b","7e9b8bf19378ebf7","23cc066878440174","aa20ebd4dd5c206c","1e545c5f8d69de3e","37ea27d72985dc74","5bafb3b12480ed6c","c03533b17d3de9e6","28be7cc1a2a0d197","3b8f75a5f756670d","c532fc6a545f0ad0","5c8f61d36c074567","98d1bad9eae01129","2ab84e99dbfdad34","061bb0ff3b0b982f","489fb2e660cb352d","150a14637a42b1b1"],"x":494,"y":324,"w":532,"h":764.5},{"id":"77e68bfdefaecc6b","type":"switch","z":"fbc96b6cec386837","g":"e9b0340a9dce1390","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"power_off","vt":"str"},{"t":"eq","v":"SHIELD TV","vt":"str"},{"t":"eq","v":"Normal TV","vt":"str"},{"t":"eq","v":"OPPO Bluray DVD","vt":"str"}],"checkall":"true","repair":false,"outputs":4,"x":950,"y":380,"wires":[["0cb62e55a4e64b84"],["0cb62e55a4e64b84"],["20ab07433a5c5aa2"],["998e966d8ff1e7d6"]]},{"id":"b5bdce60f3d30526","type":"api-current-state","z":"fbc96b6cec386837","g":"e9b0340a9dce1390","name":"Hub Activity","server":"bb380e72.b8825","version":3,"outputs":2,"halt_if":"unavailable","halt_if_type":"str","halt_if_compare":"is_not","entity_id":"select.harmony_hub_activities","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"string","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":590,"y":380,"wires":[["77e68bfdefaecc6b"],["e6058a2e41facfd8"]]},{"id":"018f9716714a0b55","type":"switch","z":"fbc96b6cec386837","g":"e9b0340a9dce1390","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"SHIELD TV","vt":"str"},{"t":"eq","v":"Normal TV","vt":"str"},{"t":"eq","v":"OPPO Bluray DVD","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":950,"y":440,"wires":[["6024f0c9f909373e"],["9a01cf25f034e640"],["fe3783031bf72266"]]},{"id":"aa30ad05053e822c","type":"api-current-state","z":"fbc96b6cec386837","g":"e9b0340a9dce1390","name":"Hub Activity","server":"bb380e72.b8825","version":3,"outputs":2,"halt_if":"unavailable","halt_if_type":"str","halt_if_compare":"is_not","entity_id":"select.harmony_hub_activities","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":590,"y":440,"wires":[["018f9716714a0b55"],["e6058a2e41facfd8"]]},{"id":"d1c61411014527ab","type":"switch","z":"fbc96b6cec386837","g":"e9b0340a9dce1390","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"SHIELD TV","vt":"str"},{"t":"eq","v":"Normal TV","vt":"str"},{"t":"eq","v":"OPPO Bluray DVD","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":950,"y":500,"wires":[["7d5af41b519ee4a8"],["cac8fb5ebb2a5cf0"],["847af42e7336ebbc"]]},{"id":"b6f4a92e1a1e6de3","type":"api-current-state","z":"fbc96b6cec386837","g":"e9b0340a9dce1390","name":"Hub Activity","server":"bb380e72.b8825","version":3,"outputs":2,"halt_if":"unavailable","halt_if_type":"str","halt_if_compare":"is_not","entity_id":"select.harmony_hub_activities","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":590,"y":500,"wires":[["d1c61411014527ab"],["e6058a2e41facfd8"]]},{"id":"d7d7e9ba6f178ebe","type":"switch","z":"fbc96b6cec386837","g":"e9b0340a9dce1390","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"SHIELD TV","vt":"str"},{"t":"eq","v":"Normal TV","vt":"str"},{"t":"eq","v":"OPPO Bluray DVD","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":950,"y":560,"wires":[["66b22a050c99fb41"],["6a3e5c194633ed5f"],["7e86c40833254840"]]},{"id":"493644565a2a7f3b","type":"api-current-state","z":"fbc96b6cec386837","g":"e9b0340a9dce1390","name":"Hub Activity","server":"bb380e72.b8825","version":3,"outputs":2,"halt_if":"unavailable","halt_if_type":"str","halt_if_compare":"is_not","entity_id":"select.harmony_hub_activities","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":590,"y":560,"wires":[["d7d7e9ba6f178ebe"],["e6058a2e41facfd8"]]},{"id":"7e9b8bf19378ebf7","type":"switch","z":"fbc96b6cec386837","g":"e9b0340a9dce1390","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"SHIELD TV","vt":"str"},{"t":"eq","v":"Normal TV","vt":"str"},{"t":"eq","v":"OPPO Bluray DVD","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":950,"y":620,"wires":[["2afeca396b559fed"],["d5f2f6eff52d9861"],["8f977f1bf6688733"]]},{"id":"23cc066878440174","type":"api-current-state","z":"fbc96b6cec386837","g":"e9b0340a9dce1390","name":"Hub Activity","server":"bb380e72.b8825","version":3,"outputs":2,"halt_if":"unavailable","halt_if_type":"str","halt_if_compare":"is_not","entity_id":"select.harmony_hub_activities","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":590,"y":620,"wires":[["7e9b8bf19378ebf7"],["e6058a2e41facfd8"]]},{"id":"aa20ebd4dd5c206c","type":"switch","z":"fbc96b6cec386837","g":"e9b0340a9dce1390","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"SHIELD TV","vt":"str"},{"t":"eq","v":"Normal TV","vt":"str"},{"t":"eq","v":"OPPO Bluray DVD","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":950,"y":680,"wires":[["b5c1df5e77154d59"],["09efd3d6a6567d36"],["e16074eba19420e6"]]},{"id":"1e545c5f8d69de3e","type":"api-current-state","z":"fbc96b6cec386837","g":"e9b0340a9dce1390","name":"Hub Activity","server":"bb380e72.b8825","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"select.harmony_hub_activities","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":590,"y":680,"wires":[["aa20ebd4dd5c206c"]]},{"id":"37ea27d72985dc74","type":"switch","z":"fbc96b6cec386837","g":"e9b0340a9dce1390","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"SHIELD TV","vt":"str"},{"t":"eq","v":"Normal TV","vt":"str"},{"t":"eq","v":"OPPO Bluray DVD","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":950,"y":740,"wires":[["a7baa377280bcf5e"],["e0ccbc4279838ce0"],["6e4169f897ea2eee"]]},{"id":"5bafb3b12480ed6c","type":"api-current-state","z":"fbc96b6cec386837","g":"e9b0340a9dce1390","name":"Hub Activity","server":"bb380e72.b8825","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"select.harmony_hub_activities","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":590,"y":740,"wires":[["37ea27d72985dc74"]]},{"id":"c03533b17d3de9e6","type":"switch","z":"fbc96b6cec386837","g":"e9b0340a9dce1390","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"SHIELD TV","vt":"str"},{"t":"eq","v":"Normal TV","vt":"str"},{"t":"eq","v":"OPPO Bluray DVD","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":950,"y":800,"wires":[["de65340f4dc7afa8"],["9a07059dc7dfd33c"],["5af3a69722f6ccc5"]]},{"id":"28be7cc1a2a0d197","type":"api-current-state","z":"fbc96b6cec386837","g":"e9b0340a9dce1390","name":"Hub Activity","server":"bb380e72.b8825","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"select.harmony_hub_activities","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":590,"y":800,"wires":[["c03533b17d3de9e6"]]},{"id":"3b8f75a5f756670d","type":"switch","z":"fbc96b6cec386837","g":"e9b0340a9dce1390","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"SHIELD TV","vt":"str"},{"t":"eq","v":"Normal TV","vt":"str"},{"t":"eq","v":"OPPO Bluray DVD","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":950,"y":860,"wires":[["f60b31c4c9cbe3cf"],["dd9b576c65ab8a53"],["2665f0f7d282961c"]]},{"id":"c532fc6a545f0ad0","type":"api-current-state","z":"fbc96b6cec386837","g":"e9b0340a9dce1390","name":"Hub Activity","server":"bb380e72.b8825","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"select.harmony_hub_activities","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":590,"y":860,"wires":[["3b8f75a5f756670d"]]},{"id":"5c8f61d36c074567","type":"switch","z":"fbc96b6cec386837","g":"e9b0340a9dce1390","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"SHIELD TV","vt":"str"},{"t":"eq","v":"Normal TV","vt":"str"},{"t":"eq","v":"OPPO Bluray DVD","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":950,"y":920,"wires":[["c9703b784a8b3fea"],["e0de9ffcc1100f73"],["5fe04b6054e61be8"]]},{"id":"98d1bad9eae01129","type":"api-current-state","z":"fbc96b6cec386837","g":"e9b0340a9dce1390","name":"Hub Activity","server":"bb380e72.b8825","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"select.harmony_hub_activities","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":590,"y":920,"wires":[["5c8f61d36c074567"]]},{"id":"2ab84e99dbfdad34","type":"switch","z":"fbc96b6cec386837","g":"e9b0340a9dce1390","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"SHIELD TV","vt":"str"},{"t":"eq","v":"Normal TV","vt":"str"},{"t":"eq","v":"OPPO Bluray DVD","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":950,"y":980,"wires":[["c40a02f5270300d0"],["e28447ab158ae0ec"],["2f5b6abccdad364e"]]},{"id":"061bb0ff3b0b982f","type":"api-current-state","z":"fbc96b6cec386837","g":"e9b0340a9dce1390","name":"Hub Activity","server":"bb380e72.b8825","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"select.harmony_hub_activities","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":590,"y":980,"wires":[["2ab84e99dbfdad34"]]},{"id":"489fb2e660cb352d","type":"switch","z":"fbc96b6cec386837","g":"e9b0340a9dce1390","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"SHIELD TV","vt":"str"},{"t":"eq","v":"Normal TV","vt":"str"},{"t":"eq","v":"OPPO Bluray DVD","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":950,"y":1040,"wires":[["6fae332435f49a5e"],["7b6b2e500985e770"],["2144f3b97ad9c498"]]},{"id":"150a14637a42b1b1","type":"api-current-state","z":"fbc96b6cec386837","g":"e9b0340a9dce1390","name":"Hub Activity","server":"bb380e72.b8825","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"select.harmony_hub_activities","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":590,"y":1040,"wires":[["489fb2e660cb352d"]]},{"id":"ee291ac418d0f613","type":"group","z":"fbc96b6cec386837","g":"8369e92cdf06c9ce","name":"ADB Commands to start apps on Shield","style":{"label":true,"fill":"#b797cf"},"nodes":["bedb375b1b8b59e0","6412417bcd1b3787","e1fdc1557ded80b7","72e60e418a0f3d64","454bfc3a1250c1ab","c5b5d142aea16f22","4d361a9a02573759","c04c6473d94541a7","866e63cdc3e4786c","82d67133efa14d5f"],"x":234,"y":1099,"w":512,"h":322},{"id":"bedb375b1b8b59e0","type":"api-call-service","z":"fbc96b6cec386837","g":"ee291ac418d0f613","name":"SHIELD Netflix","server":"bb380e72.b8825","version":7,"debugenabled":false,"action":"androidtv.adb_command","floorId":[],"areaId":[],"deviceId":[],"entityId":["media_player.shield_debug_bridge"],"labelId":[],"data":"{\"command\" : \"am start -n com.netflix.ninja/.MainActivity -a android.intent.action.VIEW\"}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"androidtv","service":"adb_command","x":600,"y":1140,"wires":[[]]},{"id":"6412417bcd1b3787","type":"api-call-service","z":"fbc96b6cec386837","g":"ee291ac418d0f613","name":"SHIELD YouTube","server":"bb380e72.b8825","version":7,"debugenabled":false,"action":"androidtv.adb_command","floorId":[],"areaId":[],"deviceId":[],"entityId":["media_player.shield_debug_bridge"],"labelId":[],"data":"{\"command\" : \"am start -a android.intent.action.VIEW -n   com.google.android.youtube.tv/com.google.android.apps.youtube.tv.activity.ShellActivity\"}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"androidtv","service":"adb_command","x":610,"y":1200,"wires":[[]]},{"id":"e1fdc1557ded80b7","type":"api-call-service","z":"fbc96b6cec386837","g":"ee291ac418d0f613","name":"SHIELD AmazonPrime","server":"bb380e72.b8825","version":7,"debugenabled":false,"action":"androidtv.adb_command","floorId":[],"areaId":[],"deviceId":[],"entityId":["media_player.shield_debug_bridge"],"labelId":[],"data":"{\"command\" : \"am start -a android.intent.action.VIEW -n   com.amazon.amazonvideo.livingroom/com.amazon.ignition.IgnitionActivity\"}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"androidtv","service":"adb_command","x":620,"y":1260,"wires":[[]]},{"id":"72e60e418a0f3d64","type":"api-call-service","z":"fbc96b6cec386837","g":"ee291ac418d0f613","name":"SHIELD Disney+","server":"bb380e72.b8825","version":7,"debugenabled":false,"action":"androidtv.adb_command","floorId":[],"areaId":[],"deviceId":[],"entityId":["media_player.shield_debug_bridge"],"labelId":[],"data":"{\"command\" : \"am start -a android.intent.action.VIEW -n   com.disney.disneyplus/com.bamtechmedia.dominguez.main.MainActivity\"}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"androidtv","service":"adb_command","x":610,"y":1320,"wires":[[]]},{"id":"454bfc3a1250c1ab","type":"api-call-service","z":"fbc96b6cec386837","g":"ee291ac418d0f613","name":"SHIELD Spotify","server":"bb380e72.b8825","version":7,"debugenabled":false,"action":"androidtv.adb_command","floorId":[],"areaId":[],"deviceId":[],"entityId":["media_player.shield_debug_bridge"],"labelId":[],"data":"{\"command\" : \"am start -a android.intent.action.VIEW -n   com.spotify.tv.android/.SpotifyTVActivity\"}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"androidtv","service":"adb_command","x":600,"y":1380,"wires":[[]]},{"id":"c5b5d142aea16f22","type":"ha-button","z":"fbc96b6cec386837","g":"ee291ac418d0f613","name":"Harmony Netflix","version":0,"debugenabled":false,"outputs":1,"entityConfig":"b20dbad6d8438faa","outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"x":340,"y":1140,"wires":[["bedb375b1b8b59e0"]]},{"id":"4d361a9a02573759","type":"ha-button","z":"fbc96b6cec386837","g":"ee291ac418d0f613","name":"Harmony YouTube","version":0,"debugenabled":false,"outputs":1,"entityConfig":"32f2067294374521","outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"x":350,"y":1200,"wires":[["6412417bcd1b3787"]]},{"id":"c04c6473d94541a7","type":"ha-button","z":"fbc96b6cec386837","g":"ee291ac418d0f613","name":"Harmony AmazonPrime","version":0,"debugenabled":false,"outputs":1,"entityConfig":"4c469ca8902b466c","outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"x":360,"y":1260,"wires":[["e1fdc1557ded80b7"]]},{"id":"866e63cdc3e4786c","type":"ha-button","z":"fbc96b6cec386837","g":"ee291ac418d0f613","name":"Harmony Disney+","version":0,"debugenabled":false,"outputs":1,"entityConfig":"30d4aff715e23ddd","outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"x":350,"y":1320,"wires":[["72e60e418a0f3d64"]]},{"id":"82d67133efa14d5f","type":"ha-button","z":"fbc96b6cec386837","g":"ee291ac418d0f613","name":"Harmony Spotify","version":0,"debugenabled":false,"outputs":1,"entityConfig":"055fdccbcf46e33e","outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"x":340,"y":1380,"wires":[["454bfc3a1250c1ab"]]},{"id":"b20dbad6d8438faa","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"89c6c7100d33424f","name":"Harmony Netflix","version":"6","entityType":"button","haConfig":[{"property":"name","value":"Harmony Netflix"},{"property":"icon","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"32f2067294374521","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"bc0b6f57947e28bc","name":"Harmony YouTube","version":"6","entityType":"button","haConfig":[{"property":"name","value":"Harmony YouTube"},{"property":"icon","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"4c469ca8902b466c","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"c5825a91c30b5489","name":"Harmony AmazonPrime","version":"6","entityType":"button","haConfig":[{"property":"name","value":"Harmony AmazonPrime"},{"property":"icon","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"30d4aff715e23ddd","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"4e7132f3a331d20c","name":"Harmony Disney+","version":"6","entityType":"button","haConfig":[{"property":"name","value":"Harmony Disney+"},{"property":"icon","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"055fdccbcf46e33e","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"b9dd6d17f430b8f7","name":"Harmony Spotify","version":"6","entityType":"button","haConfig":[{"property":"name","value":"Harmony Spotify"},{"property":"icon","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"89c6c7100d33424f","type":"ha-device-config","name":"Harmony Netflix","hwVersion":"","manufacturer":"Node-RED","model":"Harmony","swVersion":""},{"id":"bc0b6f57947e28bc","type":"ha-device-config","name":"Harmony YouTube","hwVersion":"","manufacturer":"Node-RED","model":"Harmony","swVersion":""},{"id":"c5825a91c30b5489","type":"ha-device-config","name":"Harmony AmazonPrime","hwVersion":"","manufacturer":"Node-RED","model":"Harmony","swVersion":""},{"id":"4e7132f3a331d20c","type":"ha-device-config","name":"Harmony Disney+","hwVersion":"","manufacturer":"Node-RED","model":"Harmony","swVersion":""},{"id":"b9dd6d17f430b8f7","type":"ha-device-config","name":"Harmony Spotify","hwVersion":"","manufacturer":"Node-RED","model":"Harmony","swVersion":""},{"id":"1220c1d58bb31502","type":"group","z":"fbc96b6cec386837","g":"8369e92cdf06c9ce","name":"Volume and Sound Commands (Moved to NAD Amplifier Flow)","style":{"label":true,"fill":"#3f5787"},"nodes":["298591cea737a228","2ac202ca1419196c","92615d0be6054cfa","ff14d451c964677a","6d37662a01f13fd6","c4737b581247e594","6858d2ca586da141","1d8459499528f18f","7c20747936fba0af","b29844a19d712a2f","c063eb8707f46276","5e28b3c6c026eda0","7b270561e3f4200a"],"x":234,"y":1459,"w":792,"h":322},{"id":"298591cea737a228","type":"H press","z":"fbc96b6cec386837","g":"1220c1d58bb31502","name":"NAD VolumeUp","server":"21dd4f96b9a6b12b","activity":null,"label":"","command":"%7B%22command%22::%22VolumeUp%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250718543%22%7D","timestamp":0,"repeat":"1","x":600,"y":1560,"wires":[["ff14d451c964677a"]]},{"id":"2ac202ca1419196c","type":"H press","z":"fbc96b6cec386837","g":"1220c1d58bb31502","name":"NAD VolumeDown","server":"21dd4f96b9a6b12b","activity":"50718543","harmony_type":"dev","label":"NAD AV Receiver","command":"%7B%22command%22::%22VolumeDown%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250718543%22%7D","timestamp":0,"repeat":"1","x":610,"y":1620,"wires":[["6d37662a01f13fd6"]]},{"id":"92615d0be6054cfa","type":"H press","z":"fbc96b6cec386837","g":"1220c1d58bb31502","name":"NAD Surround Mode","server":"21dd4f96b9a6b12b","activity":null,"label":"","command":"%7B%22command%22::%22SurroundMode%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250718543%22%7D","timestamp":0,"repeat":"1","x":620,"y":1680,"wires":[["c4737b581247e594"]]},{"id":"ff14d451c964677a","type":"H release","z":"fbc96b6cec386837","g":"1220c1d58bb31502","name":"NAD VolumeUp Release","server":"21dd4f96b9a6b12b","activity":null,"label":"","command":null,"timestamp":0,"repeat":"1","x":870,"y":1560,"wires":[[]]},{"id":"6d37662a01f13fd6","type":"H release","z":"fbc96b6cec386837","g":"1220c1d58bb31502","name":"NAD VolumeDown Release","server":"21dd4f96b9a6b12b","activity":null,"label":"","command":"%7B%22command%22::%22VolumeDown%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250718543%22%7D","timestamp":0,"repeat":"1","x":880,"y":1620,"wires":[[]]},{"id":"c4737b581247e594","type":"H release","z":"fbc96b6cec386837","g":"1220c1d58bb31502","name":"NAD Surround Release","server":"21dd4f96b9a6b12b","activity":"50718543","harmony_type":"dev","label":"NAD AV Receiver","command":"%7B%22command%22::%22SurroundMode%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250718543%22%7D","timestamp":0,"repeat":"1","x":870,"y":1680,"wires":[[]]},{"id":"6858d2ca586da141","type":"ha-button","z":"fbc96b6cec386837","g":"1220c1d58bb31502","name":"Harmony Mute","version":0,"debugenabled":false,"outputs":1,"entityConfig":"b7bc05028d08f8f8","outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"x":340,"y":1740,"wires":[[]]},{"id":"1d8459499528f18f","type":"H press","z":"fbc96b6cec386837","g":"1220c1d58bb31502","name":"NAD Mute","server":"21dd4f96b9a6b12b","activity":null,"label":"","command":"%7B%22command%22::%22Mute%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250718543%22%7D","timestamp":0,"repeat":"1","x":590,"y":1740,"wires":[["7c20747936fba0af"]]},{"id":"7c20747936fba0af","type":"H release","z":"fbc96b6cec386837","g":"1220c1d58bb31502","name":"NAD Mute Release","server":"21dd4f96b9a6b12b","activity":"50718543","harmony_type":"dev","label":"NAD AV Receiver","command":"%7B%22command%22::%22Mute%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250718543%22%7D","timestamp":0,"repeat":"1","x":850,"y":1740,"wires":[[]]},{"id":"b29844a19d712a2f","type":"comment","z":"fbc96b6cec386837","g":"1220c1d58bb31502","name":"Buttons Moved to NAD Amplifier","info":"x","x":390,"y":1500,"wires":[]},{"id":"c063eb8707f46276","type":"ha-button","z":"fbc96b6cec386837","g":"1220c1d58bb31502","name":"Harmony VolumeUp","version":0,"debugenabled":false,"outputs":1,"entityConfig":"1a9add5205a9b03a","outputProperties":[{"property":"payload","propertyType":"msg","value":"Main.Volume+","valueType":"str"},{"property":"topic","propertyType":"msg","value":"Main.Volume","valueType":"str"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"x":350,"y":1560,"wires":[[]]},{"id":"5e28b3c6c026eda0","type":"ha-button","z":"fbc96b6cec386837","g":"1220c1d58bb31502","name":"Harmony VolumeDown","version":0,"debugenabled":false,"outputs":1,"entityConfig":"0a1b1fc1b2819349","outputProperties":[{"property":"payload","propertyType":"msg","value":"Main.Volume-","valueType":"str"},{"property":"topic","propertyType":"msg","value":"Main.Volume","valueType":"str"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"x":360,"y":1620,"wires":[[]]},{"id":"7b270561e3f4200a","type":"ha-button","z":"fbc96b6cec386837","g":"1220c1d58bb31502","name":"Harmony SurroundMode","version":0,"debugenabled":false,"outputs":1,"entityConfig":"dcb15db54ef8a925","outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"x":370,"y":1680,"wires":[[]]},{"id":"21dd4f96b9a6b12b","type":"harmony-server","name":"Living Room Hub","ip":"192.168.1.252"},{"id":"b7bc05028d08f8f8","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"c0acba481ece0f36","name":"Harmony Mute","version":"6","entityType":"button","haConfig":[{"property":"name","value":"Harmony Mute"},{"property":"icon","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"1a9add5205a9b03a","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"75d5123548c93cf7","name":"Harmony VolumeUp","version":"6","entityType":"button","haConfig":[{"property":"name","value":"Harmony VolumeUp"},{"property":"icon","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"0a1b1fc1b2819349","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"b4eb9deebcc2d3b3","name":"Harmony VolumeDown","version":"6","entityType":"button","haConfig":[{"property":"name","value":"Harmony VolumeDown"},{"property":"icon","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"dcb15db54ef8a925","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"8b8753f0cbe85dea","name":"Harmony SurroundMode","version":"6","entityType":"button","haConfig":[{"property":"name","value":"Harmony SurroundMode"},{"property":"icon","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"c0acba481ece0f36","type":"ha-device-config","name":"Harmony Mute","hwVersion":"","manufacturer":"Node-RED","model":"Harmony","swVersion":""},{"id":"75d5123548c93cf7","type":"ha-device-config","name":"Harmony VolumeUp","hwVersion":"","manufacturer":"Node-RED","model":"Harmony","swVersion":""},{"id":"b4eb9deebcc2d3b3","type":"ha-device-config","name":"Harmony VolumeDown","hwVersion":"","manufacturer":"Node-RED","model":"Harmony","swVersion":""},{"id":"8b8753f0cbe85dea","type":"ha-device-config","name":"Harmony SurroundMode","hwVersion":"","manufacturer":"Node-RED","model":"Harmony","swVersion":""},{"id":"67bc85994e5c6d17","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"0d9c109473b3a4e0","name":"Harmony Up","version":"6","entityType":"button","haConfig":[{"property":"name","value":"Harmony Up"},{"property":"icon","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"dfc4830a913f1d86","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"88644d2331f18c82","name":"Harmony Down","version":"6","entityType":"button","haConfig":[{"property":"name","value":"Harmony Down"},{"property":"icon","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"ca1b92ca8bacf0c3","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"4684b2986eaf6e14","name":"Harmony Left","version":"6","entityType":"button","haConfig":[{"property":"name","value":"Harmony Left"},{"property":"icon","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"ca2a4c203e9cc0b1","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"125cf7ae76e0c388","name":"Harmony Right","version":"6","entityType":"button","haConfig":[{"property":"name","value":"Harmony Right"},{"property":"icon","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"5db89a4bf57bce2b","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"76ac485e2c4fdccd","name":"Harmony Select","version":"6","entityType":"button","haConfig":[{"property":"name","value":"Harmony Select"},{"property":"icon","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"bc296c6b71a6c03a","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"ddcf8614d5d59e31","name":"Harmony Skip Back","version":"6","entityType":"button","haConfig":[{"property":"name","value":"Harmony Skip Back"},{"property":"icon","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"7e00791ced34893f","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"737f84739dbad570","name":"Harmony Skip Forward","version":"6","entityType":"button","haConfig":[{"property":"name","value":"Harmony Skip Forward"},{"property":"icon","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"f0f91851098d8ea9","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"d4851b2a094cd7ce","name":"Harmony Play","version":"6","entityType":"button","haConfig":[{"property":"name","value":"Harmony Play"},{"property":"icon","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"73daed85ed139a5b","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"721540598fc5f29c","name":"Harmony Pause","version":"6","entityType":"button","haConfig":[{"property":"name","value":"Harmony Pause"},{"property":"icon","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"300c0c2e7774969c","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"8a3f3bc238b063e7","name":"Harmony Home","version":"6","entityType":"button","haConfig":[{"property":"name","value":"Harmony Home"},{"property":"icon","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"3b2edc921282b0b0","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"85c02c31e4aaf810","name":"Harmony Back","version":"6","entityType":"button","haConfig":[{"property":"name","value":"Harmony Back"},{"property":"icon","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"cef3bacd7f9c2fdf","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"057d28438f8cc9d3","name":"Harmony Menu","version":"6","entityType":"button","haConfig":[{"property":"name","value":"Harmony Menu"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"0d9c109473b3a4e0","type":"ha-device-config","name":"Harmony Up","hwVersion":"","manufacturer":"Node-RED","model":"Harmony","swVersion":""},{"id":"88644d2331f18c82","type":"ha-device-config","name":"Harmony Down","hwVersion":"","manufacturer":"Node-RED","model":"Harmony","swVersion":""},{"id":"4684b2986eaf6e14","type":"ha-device-config","name":"Harmony Left","hwVersion":"","manufacturer":"Node-RED","model":"Harmony","swVersion":""},{"id":"125cf7ae76e0c388","type":"ha-device-config","name":"Harmony Right","hwVersion":"","manufacturer":"Node-RED","model":"Harmony","swVersion":""},{"id":"76ac485e2c4fdccd","type":"ha-device-config","name":"Harmony Select","hwVersion":"","manufacturer":"Node-RED","model":"Harmony","swVersion":""},{"id":"ddcf8614d5d59e31","type":"ha-device-config","name":"Harmony Skip Back","hwVersion":"","manufacturer":"Node-RED","model":"Harmony","swVersion":""},{"id":"737f84739dbad570","type":"ha-device-config","name":"Harmony Skip Forward","hwVersion":"","manufacturer":"Node-RED","model":"Harmony","swVersion":""},{"id":"d4851b2a094cd7ce","type":"ha-device-config","name":"Harmony Play","hwVersion":"","manufacturer":"Node-RED","model":"Harmony","swVersion":""},{"id":"721540598fc5f29c","type":"ha-device-config","name":"Harmony Pause","hwVersion":"","manufacturer":"Node-RED","model":"Harmony","swVersion":""},{"id":"8a3f3bc238b063e7","type":"ha-device-config","name":"Harmony Home","hwVersion":"","manufacturer":"Node-RED","model":"Harmony","swVersion":""},{"id":"85c02c31e4aaf810","type":"ha-device-config","name":"Harmony Back","hwVersion":"","manufacturer":"Node-RED","model":"Harmony","swVersion":""},{"id":"057d28438f8cc9d3","type":"ha-device-config","name":"Harmony Menu","hwVersion":"","manufacturer":"Node-RED","model":"Harmony","swVersion":""},{"id":"ee4a849dbd0d5c66","type":"group","z":"fbc96b6cec386837","name":"Activity SHIELD TV","style":{"label":true},"nodes":["0cb62e55a4e64b84","6024f0c9f909373e","7d5af41b519ee4a8","66b22a050c99fb41","2afeca396b559fed","b5c1df5e77154d59","a7baa377280bcf5e","de65340f4dc7afa8","f60b31c4c9cbe3cf","c9703b784a8b3fea","c40a02f5270300d0","dea3a1c909329c4d","13ae345a5e1bedce","a83eda4916a357a6","9164df77c6b03223","106342df9f379077","9dc4ef2ff0b992ce","821bb1485945d23d","d114ea180d81998f","b9885b11d76589fd","f367f3147e16c762","81a0c3fe6caf5467","e11920d206c43ed2","6fae332435f49a5e"],"x":1154,"y":259,"w":552,"h":742},{"id":"0cb62e55a4e64b84","type":"H press","z":"fbc96b6cec386837","g":"ee4a849dbd0d5c66","name":"SHIELD Up","server":"21dd4f96b9a6b12b","activity":"48067014","harmony_type":"act","label":"SHIELD TV","command":"%7B%22command%22::%22DirectionUp%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2274458086%22%7D","timestamp":0,"repeat":"1","x":1250,"y":300,"wires":[["dea3a1c909329c4d"]]},{"id":"6024f0c9f909373e","type":"H press","z":"fbc96b6cec386837","g":"ee4a849dbd0d5c66","name":"SHIELD Down","server":"21dd4f96b9a6b12b","activity":null,"label":"","command":"%7B%22command%22::%22DirectionDown%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2274458086%22%7D","timestamp":0,"repeat":"1","x":1260,"y":360,"wires":[["13ae345a5e1bedce"]]},{"id":"7d5af41b519ee4a8","type":"H press","z":"fbc96b6cec386837","g":"ee4a849dbd0d5c66","name":"SHEILD Left","server":"21dd4f96b9a6b12b","activity":"48067014","harmony_type":"act","label":"SHIELD TV","command":"%7B%22command%22::%22DirectionLeft%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2274458086%22%7D","timestamp":0,"repeat":"1","x":1250,"y":420,"wires":[["a83eda4916a357a6"]]},{"id":"66b22a050c99fb41","type":"H press","z":"fbc96b6cec386837","g":"ee4a849dbd0d5c66","name":"SHEILD Right","server":"21dd4f96b9a6b12b","activity":"48067014","harmony_type":"act","label":"SHIELD TV","command":"%7B%22command%22::%22DirectionRight%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2274458086%22%7D","timestamp":0,"repeat":"1","x":1260,"y":480,"wires":[["9164df77c6b03223"]]},{"id":"2afeca396b559fed","type":"H press","z":"fbc96b6cec386837","g":"ee4a849dbd0d5c66","name":"SHIELD Select","server":"21dd4f96b9a6b12b","activity":"48067014","harmony_type":"act","label":"SHIELD TV","command":"%7B%22command%22::%22Select%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2274458086%22%7D","timestamp":0,"repeat":"1","x":1260,"y":540,"wires":[["106342df9f379077"]]},{"id":"b5c1df5e77154d59","type":"H press","z":"fbc96b6cec386837","g":"ee4a849dbd0d5c66","name":"SHIELD SkipBack","server":"21dd4f96b9a6b12b","activity":"48067014","harmony_type":"act","label":"SHIELD TV","command":"%7B%22command%22::%22PreviousTrack%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2274458086%22%7D","timestamp":0,"repeat":"1","x":1270,"y":600,"wires":[["821bb1485945d23d"]]},{"id":"a7baa377280bcf5e","type":"H press","z":"fbc96b6cec386837","g":"ee4a849dbd0d5c66","name":"SHIELD SkipForward","server":"21dd4f96b9a6b12b","activity":"48067014","harmony_type":"act","label":"SHIELD TV","command":"%7B%22command%22::%22NextTrack%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2274458086%22%7D","timestamp":0,"repeat":"1","x":1280,"y":660,"wires":[["d114ea180d81998f"]]},{"id":"de65340f4dc7afa8","type":"H press","z":"fbc96b6cec386837","g":"ee4a849dbd0d5c66","name":"SHIELD Play","server":"21dd4f96b9a6b12b","activity":"48067014","harmony_type":"act","label":"SHIELD TV","command":"%7B%22command%22::%22Play%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2274458086%22%7D","timestamp":0,"repeat":"1","x":1250,"y":720,"wires":[["9dc4ef2ff0b992ce"]]},{"id":"f60b31c4c9cbe3cf","type":"H press","z":"fbc96b6cec386837","g":"ee4a849dbd0d5c66","name":"SHIELD Pause","server":"21dd4f96b9a6b12b","activity":"48067014","harmony_type":"act","label":"SHIELD TV","command":"%7B%22command%22::%22Pause%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2274458086%22%7D","timestamp":0,"repeat":"1","x":1260,"y":780,"wires":[["b9885b11d76589fd"]]},{"id":"c9703b784a8b3fea","type":"H press","z":"fbc96b6cec386837","g":"ee4a849dbd0d5c66","name":"SHIELD Home","server":"21dd4f96b9a6b12b","activity":"48067014","harmony_type":"act","label":"SHIELD TV","command":"%7B%22command%22::%22Home%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2274458086%22%7D","timestamp":0,"repeat":"1","x":1260,"y":840,"wires":[["f367f3147e16c762"]]},{"id":"c40a02f5270300d0","type":"H press","z":"fbc96b6cec386837","g":"ee4a849dbd0d5c66","name":"SHIELD Back","server":"21dd4f96b9a6b12b","activity":"48067014","harmony_type":"act","label":"SHIELD TV","command":"%7B%22command%22::%22Back%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2274458086%22%7D","timestamp":0,"repeat":"1","x":1260,"y":900,"wires":[["81a0c3fe6caf5467"]]},{"id":"dea3a1c909329c4d","type":"H release","z":"fbc96b6cec386837","g":"ee4a849dbd0d5c66","name":"SHIELD Up Release","server":"21dd4f96b9a6b12b","activity":null,"label":"","command":"%7B%22command%22::%22DirectionUp%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2274458086%22%7D","timestamp":0,"repeat":"1","x":1520,"y":300,"wires":[["1c0305e181a69a96"]]},{"id":"13ae345a5e1bedce","type":"H release","z":"fbc96b6cec386837","g":"ee4a849dbd0d5c66","name":"SHIELD Down Release","server":"21dd4f96b9a6b12b","activity":"48067014","harmony_type":"act","label":"SHIELD TV","command":"%7B%22command%22::%22DirectionDown%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2274458086%22%7D","timestamp":0,"repeat":"1","x":1530,"y":360,"wires":[["53b2d45edf939238"]]},{"id":"a83eda4916a357a6","type":"H release","z":"fbc96b6cec386837","g":"ee4a849dbd0d5c66","name":"SHIELD Left Release","server":"21dd4f96b9a6b12b","activity":"48067014","harmony_type":"act","label":"SHIELD TV","command":"%7B%22command%22::%22DirectionLeft%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2274458086%22%7D","timestamp":0,"repeat":"1","x":1520,"y":420,"wires":[["f659e0cf96a8539f"]]},{"id":"9164df77c6b03223","type":"H release","z":"fbc96b6cec386837","g":"ee4a849dbd0d5c66","name":"SHIELD Right Release","server":"21dd4f96b9a6b12b","activity":"48067014","harmony_type":"act","label":"SHIELD TV","command":"%7B%22command%22::%22DirectionRight%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2274458086%22%7D","timestamp":0,"repeat":"1","x":1520,"y":480,"wires":[["cc38149e45b8c783"]]},{"id":"106342df9f379077","type":"H release","z":"fbc96b6cec386837","g":"ee4a849dbd0d5c66","name":"SHIELD Select Release","server":"21dd4f96b9a6b12b","activity":"48067014","harmony_type":"act","label":"SHIELD TV","command":"%7B%22command%22::%22Select%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2274458086%22%7D","timestamp":0,"repeat":"1","x":1530,"y":540,"wires":[["7d087e72be5b0c69"]]},{"id":"9dc4ef2ff0b992ce","type":"H release","z":"fbc96b6cec386837","g":"ee4a849dbd0d5c66","name":"SHIELD Play Release","server":"21dd4f96b9a6b12b","activity":"48067014","harmony_type":"act","label":"SHIELD TV","command":"%7B%22command%22::%22Play%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2274458086%22%7D","timestamp":0,"repeat":"1","x":1520,"y":720,"wires":[[]]},{"id":"821bb1485945d23d","type":"H release","z":"fbc96b6cec386837","g":"ee4a849dbd0d5c66","name":"SHIELD SkipBack Release","server":"21dd4f96b9a6b12b","activity":"48067014","harmony_type":"act","label":"SHIELD TV","command":"%7B%22command%22::%22PreviousTrack%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2274458086%22%7D","timestamp":0,"repeat":"1","x":1540,"y":600,"wires":[[]]},{"id":"d114ea180d81998f","type":"H release","z":"fbc96b6cec386837","g":"ee4a849dbd0d5c66","name":"SHIELD SkipForward Release","server":"21dd4f96b9a6b12b","activity":"48067014","harmony_type":"act","label":"SHIELD TV","command":"%7B%22command%22::%22NextTrack%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2274458086%22%7D","timestamp":0,"repeat":"1","x":1550,"y":660,"wires":[[]]},{"id":"b9885b11d76589fd","type":"H release","z":"fbc96b6cec386837","g":"ee4a849dbd0d5c66","name":"SHIELD Pause Release","server":"21dd4f96b9a6b12b","activity":"48067014","harmony_type":"act","label":"SHIELD TV","command":"%7B%22command%22::%22Pause%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2274458086%22%7D","timestamp":0,"repeat":"1","x":1530,"y":780,"wires":[[]]},{"id":"f367f3147e16c762","type":"H release","z":"fbc96b6cec386837","g":"ee4a849dbd0d5c66","name":"SHIELD Home Release","server":"21dd4f96b9a6b12b","activity":"48067014","harmony_type":"act","label":"SHIELD TV","command":"%7B%22command%22::%22Home%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2274458086%22%7D","timestamp":0,"repeat":"1","x":1530,"y":840,"wires":[[]]},{"id":"81a0c3fe6caf5467","type":"H release","z":"fbc96b6cec386837","g":"ee4a849dbd0d5c66","name":"SHIELD Back Release","server":"21dd4f96b9a6b12b","activity":"48067014","harmony_type":"act","label":"SHIELD TV","command":"%7B%22command%22::%22Back%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2274458086%22%7D","timestamp":0,"repeat":"1","x":1520,"y":900,"wires":[[]]},{"id":"e11920d206c43ed2","type":"H release","z":"fbc96b6cec386837","g":"ee4a849dbd0d5c66","name":"SHIELD Menu Release","server":"21dd4f96b9a6b12b","activity":"48067014","harmony_type":"act","label":"SHIELD TV","command":"%7B%22command%22::%22Menu%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2274458086%22%7D","timestamp":0,"repeat":"1","x":1530,"y":960,"wires":[[]]},{"id":"6fae332435f49a5e","type":"H press","z":"fbc96b6cec386837","g":"ee4a849dbd0d5c66","name":"SHIELD Menu","server":"21dd4f96b9a6b12b","activity":"48067014","harmony_type":"act","label":"SHIELD TV","command":"%7B%22command%22::%22Menu%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2274458086%22%7D","timestamp":0,"repeat":"1","x":1260,"y":960,"wires":[["e11920d206c43ed2"]]},{"id":"a1c45424e0313b66","type":"group","z":"fbc96b6cec386837","name":"Activity Norm TV","style":{"label":true},"nodes":["20ab07433a5c5aa2","9a01cf25f034e640","cac8fb5ebb2a5cf0","6a3e5c194633ed5f","d5f2f6eff52d9861","09efd3d6a6567d36","e0ccbc4279838ce0","9a07059dc7dfd33c","dd9b576c65ab8a53","e0de9ffcc1100f73","e28447ab158ae0ec","61563018142b498e","94818b48dfd2ec7c","422107d34de4747d","fe9a7cfca8e50217","039e94ee8e88332e","9247b27e6a021d5f","c8e61e63c8eda151","e0d8d027a1c3c92c","5a2e7c7ece21f8fe","6ab167b0c6b4f3f4","98d47f9cab9cd2c4","204e2a06560e84ca","7b6b2e500985e770"],"x":1754,"y":699,"w":552,"h":742},{"id":"20ab07433a5c5aa2","type":"H press","z":"fbc96b6cec386837","g":"a1c45424e0313b66","name":"Norm TV Up","server":"21dd4f96b9a6b12b","activity":"42679719","harmony_type":"act","label":"Normal TV","command":"%7B%22command%22::%22DirectionUp%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250780464%22%7D","timestamp":0,"repeat":"1","x":1850,"y":740,"wires":[["61563018142b498e"]]},{"id":"9a01cf25f034e640","type":"H press","z":"fbc96b6cec386837","g":"a1c45424e0313b66","name":"Norm TV Down","server":"21dd4f96b9a6b12b","activity":"42679719","harmony_type":"act","label":"Normal TV","command":"%7B%22command%22::%22DirectionDown%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250780464%22%7D","timestamp":0,"repeat":"1","x":1860,"y":800,"wires":[["94818b48dfd2ec7c"]]},{"id":"cac8fb5ebb2a5cf0","type":"H press","z":"fbc96b6cec386837","g":"a1c45424e0313b66","name":"Norm TV Left","server":"21dd4f96b9a6b12b","activity":"42679719","harmony_type":"act","label":"Normal TV","command":"%7B%22command%22::%22DirectionLeft%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250780464%22%7D","timestamp":0,"repeat":"1","x":1850,"y":860,"wires":[["422107d34de4747d"]]},{"id":"6a3e5c194633ed5f","type":"H press","z":"fbc96b6cec386837","g":"a1c45424e0313b66","name":"Norm TV Right","server":"21dd4f96b9a6b12b","activity":"42679719","harmony_type":"act","label":"Normal TV","command":"%7B%22command%22::%22DirectionRight%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250780464%22%7D","timestamp":0,"repeat":"1","x":1860,"y":920,"wires":[["fe9a7cfca8e50217"]]},{"id":"d5f2f6eff52d9861","type":"H press","z":"fbc96b6cec386837","g":"a1c45424e0313b66","name":"Norm Select","server":"21dd4f96b9a6b12b","activity":"42679719","harmony_type":"act","label":"Normal TV","command":"%7B%22command%22::%22OK%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250780464%22%7D","timestamp":0,"repeat":"1","x":1850,"y":980,"wires":[["039e94ee8e88332e"]]},{"id":"09efd3d6a6567d36","type":"H press","z":"fbc96b6cec386837","g":"a1c45424e0313b66","name":"Norm TV Rewind","server":"21dd4f96b9a6b12b","activity":"42679719","harmony_type":"act","label":"Normal TV","command":"%7B%22command%22::%22Rewind%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250780464%22%7D","timestamp":0,"repeat":"1","x":1870,"y":1040,"wires":[["c8e61e63c8eda151"]]},{"id":"e0ccbc4279838ce0","type":"H press","z":"fbc96b6cec386837","g":"a1c45424e0313b66","name":"Norm TV Fast Foward","server":"21dd4f96b9a6b12b","activity":"42679719","harmony_type":"act","label":"Normal TV","command":"%7B%22command%22::%22FastForward%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250780464%22%7D","timestamp":0,"repeat":"1","x":1880,"y":1100,"wires":[["e0d8d027a1c3c92c"]]},{"id":"9a07059dc7dfd33c","type":"H press","z":"fbc96b6cec386837","g":"a1c45424e0313b66","name":"Norm TV Play","server":"21dd4f96b9a6b12b","activity":"42679719","harmony_type":"act","label":"Normal TV","command":"%7B%22command%22::%22Play%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250780464%22%7D","timestamp":0,"repeat":"1","x":1860,"y":1160,"wires":[["9247b27e6a021d5f"]]},{"id":"dd9b576c65ab8a53","type":"H press","z":"fbc96b6cec386837","g":"a1c45424e0313b66","name":"Norm TV Pause","server":"21dd4f96b9a6b12b","activity":"42679719","harmony_type":"act","label":"Normal TV","command":"%7B%22command%22::%22Pause%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250780464%22%7D","timestamp":0,"repeat":"1","x":1860,"y":1220,"wires":[["5a2e7c7ece21f8fe"]]},{"id":"e0de9ffcc1100f73","type":"H press","z":"fbc96b6cec386837","g":"a1c45424e0313b66","name":"Norm TV Home","server":"21dd4f96b9a6b12b","activity":null,"label":"","command":"%7B%22command%22::%22Home%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250780464%22%7D","timestamp":0,"repeat":"1","x":1860,"y":1280,"wires":[["6ab167b0c6b4f3f4"]]},{"id":"e28447ab158ae0ec","type":"H press","z":"fbc96b6cec386837","g":"a1c45424e0313b66","name":"Norm TV Back","server":"21dd4f96b9a6b12b","activity":"42679719","harmony_type":"act","label":"Normal TV","command":"%7B%22command%22::%22Back%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250780464%22%7D","timestamp":0,"repeat":"1","x":1860,"y":1340,"wires":[["98d47f9cab9cd2c4"]]},{"id":"61563018142b498e","type":"H release","z":"fbc96b6cec386837","g":"a1c45424e0313b66","name":"Norm TV Up Release","server":"21dd4f96b9a6b12b","activity":"42679719","harmony_type":"act","label":"Normal TV","command":"%7B%22command%22::%22DirectionUp%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250780464%22%7D","timestamp":0,"repeat":"1","x":2120,"y":740,"wires":[[]]},{"id":"94818b48dfd2ec7c","type":"H release","z":"fbc96b6cec386837","g":"a1c45424e0313b66","name":"Norm TV Down Release","server":"21dd4f96b9a6b12b","activity":"42679719","harmony_type":"act","label":"Normal TV","command":"%7B%22command%22::%22DirectionDown%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250780464%22%7D","timestamp":0,"repeat":"1","x":2130,"y":800,"wires":[[]]},{"id":"422107d34de4747d","type":"H release","z":"fbc96b6cec386837","g":"a1c45424e0313b66","name":"Norm TV Left Release","server":"21dd4f96b9a6b12b","activity":"42679719","harmony_type":"act","label":"Normal TV","command":"%7B%22command%22::%22DirectionLeft%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250780464%22%7D","timestamp":0,"repeat":"1","x":2120,"y":860,"wires":[[]]},{"id":"fe9a7cfca8e50217","type":"H release","z":"fbc96b6cec386837","g":"a1c45424e0313b66","name":"Norm TV Right Release","server":"21dd4f96b9a6b12b","activity":"42679719","harmony_type":"act","label":"Normal TV","command":"%7B%22command%22::%22DirectionRight%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250780464%22%7D","timestamp":0,"repeat":"1","x":2130,"y":920,"wires":[[]]},{"id":"039e94ee8e88332e","type":"H release","z":"fbc96b6cec386837","g":"a1c45424e0313b66","name":"Norm TV Select Release","server":"21dd4f96b9a6b12b","activity":"42679719","harmony_type":"act","label":"Normal TV","command":"%7B%22command%22::%22OK%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250780464%22%7D","timestamp":0,"repeat":"1","x":2130,"y":980,"wires":[[]]},{"id":"9247b27e6a021d5f","type":"H release","z":"fbc96b6cec386837","g":"a1c45424e0313b66","name":"Norm TV Play Release","server":"21dd4f96b9a6b12b","activity":"42679719","harmony_type":"act","label":"Normal TV","command":"%7B%22command%22::%22Play%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250780464%22%7D","timestamp":0,"repeat":"1","x":2120,"y":1160,"wires":[[]]},{"id":"c8e61e63c8eda151","type":"H release","z":"fbc96b6cec386837","g":"a1c45424e0313b66","name":"Norm TV Rewind Release","server":"21dd4f96b9a6b12b","activity":"42679719","harmony_type":"act","label":"Normal TV","command":"%7B%22command%22::%22Rewind%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250780464%22%7D","timestamp":0,"repeat":"1","x":2130,"y":1040,"wires":[[]]},{"id":"e0d8d027a1c3c92c","type":"H release","z":"fbc96b6cec386837","g":"a1c45424e0313b66","name":"Norm TV Fast Forward Release","server":"21dd4f96b9a6b12b","activity":"42679719","harmony_type":"act","label":"Normal TV","command":"%7B%22command%22::%22FastForward%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250780464%22%7D","timestamp":0,"repeat":"1","x":2150,"y":1100,"wires":[[]]},{"id":"5a2e7c7ece21f8fe","type":"H release","z":"fbc96b6cec386837","g":"a1c45424e0313b66","name":"Norm TV Pause Release","server":"21dd4f96b9a6b12b","activity":"42679719","harmony_type":"act","label":"Normal TV","command":"%7B%22command%22::%22Pause%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250780464%22%7D","timestamp":0,"repeat":"1","x":2130,"y":1220,"wires":[[]]},{"id":"6ab167b0c6b4f3f4","type":"H release","z":"fbc96b6cec386837","g":"a1c45424e0313b66","name":"Norm TV Home Release","server":"21dd4f96b9a6b12b","activity":null,"label":"","command":"%7B%22command%22::%22Home%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250780464%22%7D","timestamp":0,"repeat":"1","x":2130,"y":1280,"wires":[[]]},{"id":"98d47f9cab9cd2c4","type":"H release","z":"fbc96b6cec386837","g":"a1c45424e0313b66","name":"Norm TV Back Release","server":"21dd4f96b9a6b12b","activity":"42679719","harmony_type":"act","label":"Normal TV","command":"%7B%22command%22::%22Back%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250780464%22%7D","timestamp":0,"repeat":"1","x":2130,"y":1340,"wires":[[]]},{"id":"204e2a06560e84ca","type":"H release","z":"fbc96b6cec386837","g":"a1c45424e0313b66","name":"Norm TV Menu Release","server":"21dd4f96b9a6b12b","activity":null,"label":"","command":"%7B%22command%22::%22Home%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250780464%22%7D","timestamp":0,"repeat":"1","x":2130,"y":1400,"wires":[[]]},{"id":"7b6b2e500985e770","type":"H press","z":"fbc96b6cec386837","g":"a1c45424e0313b66","name":"Norm TV Menu","server":"21dd4f96b9a6b12b","activity":null,"label":"","command":"%7B%22command%22::%22Home%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250780464%22%7D","timestamp":0,"repeat":"1","x":1860,"y":1400,"wires":[["204e2a06560e84ca"]]},{"id":"fc4baa47eb50d58b","type":"group","z":"fbc96b6cec386837","name":"Activity OPPO Bluray TV","style":{"label":true},"nodes":["998e966d8ff1e7d6","fe3783031bf72266","847af42e7336ebbc","7e86c40833254840","8f977f1bf6688733","e16074eba19420e6","6e4169f897ea2eee","5af3a69722f6ccc5","2665f0f7d282961c","5fe04b6054e61be8","2f5b6abccdad364e","b59720dd07fbf625","8d93322aa506dc3a","c5eed6191a6e37c7","583d1550f0bf2eb0","1f585d2c2f19e919","b56317bd5301ebe1","d81f5fa6a61f3a90","07b54c24f50afad3","236760d9bb41796c","0bb45b6ccac12b61","c69b59dca4e865d6","848a1bfcee986bb4","2144f3b97ad9c498"],"x":1154,"y":1039,"w":532,"h":742},{"id":"998e966d8ff1e7d6","type":"H press","z":"fbc96b6cec386837","g":"fc4baa47eb50d58b","name":"OPPO Up","server":"21dd4f96b9a6b12b","activity":"30822006","harmony_type":"act","label":"OPPO Bluray DVD","command":"%7B%22command%22::%22DirectionUp%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250718544%22%7D","timestamp":0,"repeat":"1","x":1240,"y":1080,"wires":[["b59720dd07fbf625"]]},{"id":"fe3783031bf72266","type":"H press","z":"fbc96b6cec386837","g":"fc4baa47eb50d58b","name":"OPPO Down","server":"21dd4f96b9a6b12b","activity":"30822006","harmony_type":"act","label":"OPPO Bluray DVD","command":"%7B%22command%22::%22DirectionDown%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250718544%22%7D","timestamp":0,"repeat":"1","x":1250,"y":1140,"wires":[["8d93322aa506dc3a"]]},{"id":"847af42e7336ebbc","type":"H press","z":"fbc96b6cec386837","g":"fc4baa47eb50d58b","name":"OPPO Left","server":"21dd4f96b9a6b12b","activity":"30822006","harmony_type":"act","label":"OPPO Bluray DVD","command":"%7B%22command%22::%22DirectionLeft%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250718544%22%7D","timestamp":0,"repeat":"1","x":1250,"y":1200,"wires":[["c5eed6191a6e37c7"]]},{"id":"7e86c40833254840","type":"H press","z":"fbc96b6cec386837","g":"fc4baa47eb50d58b","name":"OPPO Right","server":"21dd4f96b9a6b12b","activity":"30822006","harmony_type":"act","label":"OPPO Bluray DVD","command":"%7B%22command%22::%22DirectionRight%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250718544%22%7D","timestamp":0,"repeat":"1","x":1250,"y":1260,"wires":[["583d1550f0bf2eb0"]]},{"id":"8f977f1bf6688733","type":"H press","z":"fbc96b6cec386837","g":"fc4baa47eb50d58b","name":"OPPO Select","server":"21dd4f96b9a6b12b","activity":"30822006","harmony_type":"act","label":"OPPO Bluray DVD","command":"%7B%22command%22::%22Select%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250718544%22%7D","timestamp":0,"repeat":"1","x":1250,"y":1320,"wires":[["1f585d2c2f19e919"]]},{"id":"e16074eba19420e6","type":"H press","z":"fbc96b6cec386837","g":"fc4baa47eb50d58b","name":"OPPO SkipBack","server":"21dd4f96b9a6b12b","activity":"30822006","harmony_type":"act","label":"OPPO Bluray DVD","command":"%7B%22command%22::%22ChapterPrev%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250718544%22%7D","timestamp":0,"repeat":"1","x":1260,"y":1380,"wires":[["d81f5fa6a61f3a90"]]},{"id":"6e4169f897ea2eee","type":"H press","z":"fbc96b6cec386837","g":"fc4baa47eb50d58b","name":"OPPO SkipForward","server":"21dd4f96b9a6b12b","activity":"30822006","harmony_type":"act","label":"OPPO Bluray DVD","command":"%7B%22command%22::%22ChapterNext%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250718544%22%7D","timestamp":0,"repeat":"1","x":1270,"y":1440,"wires":[["07b54c24f50afad3"]]},{"id":"5af3a69722f6ccc5","type":"H press","z":"fbc96b6cec386837","g":"fc4baa47eb50d58b","name":"OPPO Play","server":"21dd4f96b9a6b12b","activity":"30822006","harmony_type":"act","label":"OPPO Bluray DVD","command":"%7B%22command%22::%22Play%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250718544%22%7D","timestamp":0,"repeat":"1","x":1250,"y":1500,"wires":[["b56317bd5301ebe1"]]},{"id":"2665f0f7d282961c","type":"H press","z":"fbc96b6cec386837","g":"fc4baa47eb50d58b","name":"OPPO Pause","server":"21dd4f96b9a6b12b","activity":"30822006","harmony_type":"act","label":"OPPO Bluray DVD","command":"%7B%22command%22::%22Pause%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250718544%22%7D","timestamp":0,"repeat":"1","x":1260,"y":1560,"wires":[["236760d9bb41796c"]]},{"id":"5fe04b6054e61be8","type":"H press","z":"fbc96b6cec386837","g":"fc4baa47eb50d58b","name":"OPPO Home","server":"21dd4f96b9a6b12b","activity":"","label":"Loading activities and devices...","command":"","timestamp":0,"repeat":"1","x":1250,"y":1620,"wires":[["0bb45b6ccac12b61"]]},{"id":"2f5b6abccdad364e","type":"H press","z":"fbc96b6cec386837","g":"fc4baa47eb50d58b","name":"OPPO Return","server":"21dd4f96b9a6b12b","activity":"30822006","harmony_type":"act","label":"OPPO Bluray DVD","command":"%7B%22command%22::%22Return%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250718544%22%7D","timestamp":0,"repeat":"1","x":1260,"y":1680,"wires":[["c69b59dca4e865d6"]]},{"id":"b59720dd07fbf625","type":"H release","z":"fbc96b6cec386837","g":"fc4baa47eb50d58b","name":"OPPO Up Release","server":"21dd4f96b9a6b12b","activity":"30822006","harmony_type":"act","label":"OPPO Bluray DVD","command":"%7B%22command%22::%22DirectionUp%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250718544%22%7D","timestamp":0,"repeat":"1","x":1510,"y":1080,"wires":[[]]},{"id":"8d93322aa506dc3a","type":"H release","z":"fbc96b6cec386837","g":"fc4baa47eb50d58b","name":"OPPO Down Release","server":"21dd4f96b9a6b12b","activity":"30822006","harmony_type":"act","label":"OPPO Bluray DVD","command":"%7B%22command%22::%22DirectionDown%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250718544%22%7D","timestamp":0,"repeat":"1","x":1520,"y":1140,"wires":[[]]},{"id":"c5eed6191a6e37c7","type":"H release","z":"fbc96b6cec386837","g":"fc4baa47eb50d58b","name":"OPPO Left Release","server":"21dd4f96b9a6b12b","activity":"30822006","harmony_type":"act","label":"OPPO Bluray DVD","command":"%7B%22command%22::%22DirectionLeft%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250718544%22%7D","timestamp":0,"repeat":"1","x":1510,"y":1200,"wires":[[]]},{"id":"583d1550f0bf2eb0","type":"H release","z":"fbc96b6cec386837","g":"fc4baa47eb50d58b","name":"OPPO Right Release","server":"21dd4f96b9a6b12b","activity":"30822006","harmony_type":"act","label":"OPPO Bluray DVD","command":"%7B%22command%22::%22DirectionRight%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250718544%22%7D","timestamp":0,"repeat":"1","x":1520,"y":1260,"wires":[[]]},{"id":"1f585d2c2f19e919","type":"H release","z":"fbc96b6cec386837","g":"fc4baa47eb50d58b","name":"OPPO Select Release","server":"21dd4f96b9a6b12b","activity":"30822006","harmony_type":"act","label":"OPPO Bluray DVD","command":"%7B%22command%22::%22Select%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250718544%22%7D","timestamp":0,"repeat":"1","x":1520,"y":1320,"wires":[[]]},{"id":"b56317bd5301ebe1","type":"H release","z":"fbc96b6cec386837","g":"fc4baa47eb50d58b","name":"OPPO Play Release","server":"21dd4f96b9a6b12b","activity":"30822006","harmony_type":"act","label":"OPPO Bluray DVD","command":"%7B%22command%22::%22Play%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250718544%22%7D","timestamp":0,"repeat":"1","x":1520,"y":1500,"wires":[[]]},{"id":"d81f5fa6a61f3a90","type":"H release","z":"fbc96b6cec386837","g":"fc4baa47eb50d58b","name":"OPPO SkipBack Release","server":"21dd4f96b9a6b12b","activity":"30822006","harmony_type":"act","label":"OPPO Bluray DVD","command":"%7B%22command%22::%22ChapterPrev%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250718544%22%7D","timestamp":0,"repeat":"1","x":1530,"y":1380,"wires":[[]]},{"id":"07b54c24f50afad3","type":"H release","z":"fbc96b6cec386837","g":"fc4baa47eb50d58b","name":"OPPO SkipForward Release","server":"21dd4f96b9a6b12b","activity":"30822006","harmony_type":"act","label":"OPPO Bluray DVD","command":"%7B%22command%22::%22ChapterNext%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250718544%22%7D","timestamp":0,"repeat":"1","x":1540,"y":1440,"wires":[[]]},{"id":"236760d9bb41796c","type":"H release","z":"fbc96b6cec386837","g":"fc4baa47eb50d58b","name":"OPPO Pause Release","server":"21dd4f96b9a6b12b","activity":"30822006","harmony_type":"act","label":"OPPO Bluray DVD","command":"%7B%22command%22::%22Pause%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250718544%22%7D","timestamp":0,"repeat":"1","x":1520,"y":1560,"wires":[[]]},{"id":"0bb45b6ccac12b61","type":"H release","z":"fbc96b6cec386837","g":"fc4baa47eb50d58b","name":"OPPO Home Release","server":"21dd4f96b9a6b12b","activity":"30822006","harmony_type":"act","label":"OPPO Bluray DVD","command":"%7B%22command%22::%22Home%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250718544%22%7D","timestamp":0,"repeat":"1","x":1520,"y":1620,"wires":[[]]},{"id":"c69b59dca4e865d6","type":"H release","z":"fbc96b6cec386837","g":"fc4baa47eb50d58b","name":"OPPO Return Release","server":"21dd4f96b9a6b12b","activity":"30822006","harmony_type":"act","label":"OPPO Bluray DVD","command":"%7B%22command%22::%22Return%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250718544%22%7D","timestamp":0,"repeat":"1","x":1520,"y":1680,"wires":[[]]},{"id":"848a1bfcee986bb4","type":"H release","z":"fbc96b6cec386837","g":"fc4baa47eb50d58b","name":"OPPO Top Menu Release","server":"21dd4f96b9a6b12b","activity":"30822006","harmony_type":"act","label":"OPPO Bluray DVD","command":"%7B%22command%22::%22TopMenu%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250718544%22%7D","timestamp":0,"repeat":"1","x":1530,"y":1740,"wires":[[]]},{"id":"2144f3b97ad9c498","type":"H press","z":"fbc96b6cec386837","g":"fc4baa47eb50d58b","name":"OPPO Top Menu","server":"21dd4f96b9a6b12b","activity":"30822006","harmony_type":"act","label":"OPPO Bluray DVD","command":"%7B%22command%22::%22TopMenu%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250718544%22%7D","timestamp":0,"repeat":"1","x":1270,"y":1740,"wires":[["848a1bfcee986bb4"]]},{"id":"cd277bfe6b3e6902","type":"group","z":"fbc96b6cec386837","name":"Harmony Activity Selector","style":{"label":true,"fill":"#92d04f"},"nodes":["e8e64796c78a7ada","6c94326b55ad9ff0","c9db54871ce8dbab","788a113f95d18612","7e03604132b85a00","e0b23b0661dab4a9","c4574f8c472c8852"],"x":228,"y":1833,"w":1564,"h":1674},{"id":"e8e64796c78a7ada","type":"group","z":"fbc96b6cec386837","g":"cd277bfe6b3e6902","name":"TV Switch for HA Assist and Astrion (Mapped to ROS Switch Control Card)","style":{"label":true},"nodes":["08ede92361d08444","73222b9076431d3e","8c04090b70f21b5a","395665a7f965a022","cb68f00d9dbc1789","df240b98e0450261","ae184ea44ce77368","e408dc4ed64ce8f1","1ac4689e0117c1ba"],"x":254,"y":2539,"w":632,"h":282},{"id":"08ede92361d08444","type":"H activity","z":"fbc96b6cec386837","g":"e8e64796c78a7ada","name":"Turn ON Shield","server":"21dd4f96b9a6b12b","activity":"48067014","label":"SHIELD TV","x":540,"y":2620,"wires":[[]]},{"id":"73222b9076431d3e","type":"ha-switch","z":"fbc96b6cec386837","g":"e8e64796c78a7ada","name":"TV","version":0,"debugenabled":false,"inputs":0,"outputs":2,"entityConfig":"fe79d7fb9b892728","enableInput":false,"outputOnStateChange":true,"outputProperties":[{"property":"outputType","propertyType":"msg","value":"state change","valueType":"str"},{"property":"payload","propertyType":"msg","value":"string","valueType":"entityState"}],"x":330,"y":2640,"wires":[["08ede92361d08444","e408dc4ed64ce8f1"],[]]},{"id":"8c04090b70f21b5a","type":"trigger-state","z":"fbc96b6cec386837","g":"e8e64796c78a7ada","name":"Shield TV ON","server":"bb380e72.b8825","version":5,"inputs":0,"outputs":2,"exposeAsEntityConfig":"","entities":{"entity":["select.harmony_hub_activities"],"substring":[],"regex":[]},"debugEnabled":false,"constraints":[{"targetType":"this_entity","targetValue":"","propertyType":"current_state","propertyValue":"new_state.state","comparatorType":"is","comparatorValueDatatype":"str","comparatorValue":"SHIELD TV"}],"customOutputs":[],"outputInitially":true,"stateType":"str","enableInput":false,"x":350,"y":2720,"wires":[["df240b98e0450261"],[]]},{"id":"395665a7f965a022","type":"api-call-service","z":"fbc96b6cec386837","g":"e8e64796c78a7ada","name":"TV SWITCH OFF","server":"bb380e72.b8825","version":7,"debugenabled":false,"action":"switch.turn_off","floorId":[],"areaId":[],"deviceId":[],"entityId":["switch.tv"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":true,"domain":"switch","service":"turn_off","x":770,"y":2780,"wires":[[]]},{"id":"cb68f00d9dbc1789","type":"api-call-service","z":"fbc96b6cec386837","g":"e8e64796c78a7ada","name":"TV SWITCH ON","server":"bb380e72.b8825","version":7,"debugenabled":false,"action":"switch.turn_on","floorId":[],"areaId":[],"deviceId":[],"entityId":["switch.tv"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":true,"domain":"switch","service":"turn_on","x":780,"y":2720,"wires":[[]]},{"id":"df240b98e0450261","type":"api-current-state","z":"fbc96b6cec386837","g":"e8e64796c78a7ada","name":"Switch OFF","server":"bb380e72.b8825","version":3,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.tv","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"string","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":590,"y":2720,"wires":[["cb68f00d9dbc1789"],[]]},{"id":"ae184ea44ce77368","type":"api-current-state","z":"fbc96b6cec386837","g":"e8e64796c78a7ada","name":"Switch ON","server":"bb380e72.b8825","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.tv","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"string","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":590,"y":2780,"wires":[["395665a7f965a022"],[]]},{"id":"e408dc4ed64ce8f1","type":"link out","z":"fbc96b6cec386837","g":"e8e64796c78a7ada","name":"OUT Shield TV ON","mode":"link","links":["5822eacd465e6e2d","ddb57e3f789be864","1d6a1872a334539d","45ac3ea58ab506a8","93d4ba1fe642d988"],"x":475,"y":2580,"wires":[]},{"id":"1ac4689e0117c1ba","type":"link in","z":"fbc96b6cec386837","g":"e8e64796c78a7ada","name":"IN Shield TV OFF","links":["a66a461c9c1bc1a7","6a0c6091e769de9f","85e25312dd2f2db5","92d8062d1e413974","b2d96de4075dae77"],"x":405,"y":2780,"wires":[["ae184ea44ce77368"]]},{"id":"fe79d7fb9b892728","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"e3d65fbe01b3b8d9","name":"TV","version":"6","entityType":"switch","haConfig":[{"property":"name","value":"TV"},{"property":"icon","value":"phu:nvidia-shield"},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":"switch"}],"resend":false,"debugEnabled":false},{"id":"e3d65fbe01b3b8d9","type":"ha-device-config","name":"TV","hwVersion":"","manufacturer":"Node-RED","model":"","swVersion":""},{"id":"6c94326b55ad9ff0","type":"group","z":"fbc96b6cec386837","g":"cd277bfe6b3e6902","name":"Record Player Switch for HA Assist and Astrion (Mapped to ROS Switch Control Card)","style":{"label":true},"nodes":["63726bf27dfbebc9","afdfb00319763c64","e3d370f4582e9aa0","3b48b0bbcd07a805","a09bf79e28d71754","1f59ae3dea2329df","ae50fb3b8ae870c8","6a0c6091e769de9f","ddb57e3f789be864"],"x":254,"y":2199,"w":732,"h":282},{"id":"63726bf27dfbebc9","type":"H activity","z":"fbc96b6cec386837","g":"6c94326b55ad9ff0","name":"Turn ON Record Player","server":"21dd4f96b9a6b12b","activity":"39069297","label":"Play Vinyl","x":570,"y":2280,"wires":[[]]},{"id":"afdfb00319763c64","type":"ha-switch","z":"fbc96b6cec386837","g":"6c94326b55ad9ff0","name":"Record Player","version":0,"debugenabled":false,"inputs":0,"outputs":2,"entityConfig":"57b89ad6209b60ea","enableInput":false,"outputOnStateChange":true,"outputProperties":[{"property":"outputType","propertyType":"msg","value":"state change","valueType":"str"},{"property":"payload","propertyType":"msg","value":"string","valueType":"entityState"}],"x":350,"y":2300,"wires":[["63726bf27dfbebc9","6a0c6091e769de9f"],[]]},{"id":"e3d370f4582e9aa0","type":"trigger-state","z":"fbc96b6cec386837","g":"6c94326b55ad9ff0","name":"Play Vinyl ON","server":"bb380e72.b8825","version":5,"inputs":0,"outputs":2,"exposeAsEntityConfig":"","entities":{"entity":["select.harmony_hub_activities"],"substring":[],"regex":[]},"debugEnabled":false,"constraints":[{"targetType":"this_entity","targetValue":"","propertyType":"current_state","propertyValue":"new_state.state","comparatorType":"is","comparatorValueDatatype":"str","comparatorValue":"Play Vinyl"}],"customOutputs":[],"outputInitially":true,"stateType":"str","enableInput":false,"x":350,"y":2380,"wires":[["1f59ae3dea2329df"],[]]},{"id":"3b48b0bbcd07a805","type":"api-call-service","z":"fbc96b6cec386837","g":"6c94326b55ad9ff0","name":"RECORD PLAYER SWITCH OFF","server":"bb380e72.b8825","version":7,"debugenabled":false,"action":"switch.turn_off","floorId":[],"areaId":[],"deviceId":[],"entityId":["switch.record_player"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":true,"domain":"switch","service":"turn_off","x":820,"y":2440,"wires":[[]]},{"id":"a09bf79e28d71754","type":"api-call-service","z":"fbc96b6cec386837","g":"6c94326b55ad9ff0","name":"RECORD PLAYER SWITCH ON","server":"bb380e72.b8825","version":7,"debugenabled":false,"action":"switch.turn_on","floorId":[],"areaId":[],"deviceId":[],"entityId":["switch.record_player"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":true,"domain":"switch","service":"turn_on","x":810,"y":2380,"wires":[[]]},{"id":"1f59ae3dea2329df","type":"api-current-state","z":"fbc96b6cec386837","g":"6c94326b55ad9ff0","name":"Switch OFF","server":"bb380e72.b8825","version":3,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.record_player","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"string","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":590,"y":2380,"wires":[["a09bf79e28d71754"],[]]},{"id":"ae50fb3b8ae870c8","type":"api-current-state","z":"fbc96b6cec386837","g":"6c94326b55ad9ff0","name":"Switch ON","server":"bb380e72.b8825","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.record_player","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"string","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":590,"y":2440,"wires":[[],[]]},{"id":"6a0c6091e769de9f","type":"link out","z":"fbc96b6cec386837","g":"6c94326b55ad9ff0","name":"OUT Play Vinyl ON","mode":"link","links":["1ac4689e0117c1ba","5822eacd465e6e2d","1d6a1872a334539d","45ac3ea58ab506a8","93d4ba1fe642d988"],"x":475,"y":2240,"wires":[]},{"id":"ddb57e3f789be864","type":"link in","z":"fbc96b6cec386837","g":"6c94326b55ad9ff0","name":"IN Record Player OFF","links":["a66a461c9c1bc1a7","e408dc4ed64ce8f1","85e25312dd2f2db5","92d8062d1e413974","b2d96de4075dae77"],"x":415,"y":2440,"wires":[["ae50fb3b8ae870c8"]]},{"id":"57b89ad6209b60ea","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"7e50d0c1b174e8f7","name":"Record Player","version":"6","entityType":"switch","haConfig":[{"property":"name","value":"Record Player"},{"property":"icon","value":"mdi:record_player"},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":"switch"}],"resend":false,"debugEnabled":false},{"id":"7e50d0c1b174e8f7","type":"ha-device-config","name":"Record Player","hwVersion":"","manufacturer":"Node-RED","model":"","swVersion":""},{"id":"c9db54871ce8dbab","type":"group","z":"fbc96b6cec386837","g":"cd277bfe6b3e6902","name":"DVD Switch for Google Assistant (Mapped to ROS Switch Control Card)","style":{"label":true},"nodes":["12fe3859fdf66567","244196238ff5e6c2","6cb9a647635f0702","5c9556ee2fc5a05a","68f7f5de606197f0","6da9ccfe5d2b6806","1aad56c36b2fb623","85e25312dd2f2db5","45ac3ea58ab506a8"],"x":254,"y":2879,"w":632,"h":282},{"id":"12fe3859fdf66567","type":"H activity","z":"fbc96b6cec386837","g":"c9db54871ce8dbab","name":"Turn ON DVD","server":"21dd4f96b9a6b12b","activity":"30822006","label":"OPPO Bluray DVD","x":540,"y":2960,"wires":[[]]},{"id":"244196238ff5e6c2","type":"ha-switch","z":"fbc96b6cec386837","g":"c9db54871ce8dbab","name":"DVD","version":0,"debugenabled":false,"inputs":0,"outputs":2,"entityConfig":"b5c641c8471ca970","enableInput":false,"outputOnStateChange":true,"outputProperties":[{"property":"outputType","propertyType":"msg","value":"state change","valueType":"str"},{"property":"payload","propertyType":"msg","value":"string","valueType":"entityState"}],"x":330,"y":2980,"wires":[["12fe3859fdf66567","85e25312dd2f2db5"],[]]},{"id":"6cb9a647635f0702","type":"trigger-state","z":"fbc96b6cec386837","g":"c9db54871ce8dbab","name":"OPPO Bluray DVD ON","server":"bb380e72.b8825","version":5,"inputs":0,"outputs":2,"exposeAsEntityConfig":"","entities":{"entity":["select.harmony_hub_activities"],"substring":[],"regex":[]},"debugEnabled":false,"constraints":[{"targetType":"this_entity","targetValue":"","propertyType":"current_state","propertyValue":"new_state.state","comparatorType":"is","comparatorValueDatatype":"str","comparatorValue":"OPPO Bluray DVD"}],"customOutputs":[],"outputInitially":true,"stateType":"str","enableInput":false,"x":380,"y":3060,"wires":[["6da9ccfe5d2b6806"],[]]},{"id":"5c9556ee2fc5a05a","type":"api-call-service","z":"fbc96b6cec386837","g":"c9db54871ce8dbab","name":"DVD SWITCH OFF","server":"bb380e72.b8825","version":7,"debugenabled":false,"action":"switch.turn_off","floorId":[],"areaId":[],"deviceId":[],"entityId":["switch.dvd"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":true,"domain":"switch","service":"turn_off","x":770,"y":3120,"wires":[[]]},{"id":"68f7f5de606197f0","type":"api-call-service","z":"fbc96b6cec386837","g":"c9db54871ce8dbab","name":"DVD SWITCH ON","server":"bb380e72.b8825","version":7,"debugenabled":false,"action":"switch.turn_on","floorId":[],"areaId":[],"deviceId":[],"entityId":["switch.dvd"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":true,"domain":"switch","service":"turn_on","x":770,"y":3060,"wires":[[]]},{"id":"6da9ccfe5d2b6806","type":"api-current-state","z":"fbc96b6cec386837","g":"c9db54871ce8dbab","name":"Switch OFF","server":"bb380e72.b8825","version":3,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.dvd","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"string","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":590,"y":3060,"wires":[["68f7f5de606197f0"],[]]},{"id":"1aad56c36b2fb623","type":"api-current-state","z":"fbc96b6cec386837","g":"c9db54871ce8dbab","name":"Switch ON","server":"bb380e72.b8825","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.dvd","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"string","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":590,"y":3120,"wires":[["5c9556ee2fc5a05a"],[]]},{"id":"85e25312dd2f2db5","type":"link out","z":"fbc96b6cec386837","g":"c9db54871ce8dbab","name":"OUT Oppo DVD ON","mode":"link","links":["1ac4689e0117c1ba","5822eacd465e6e2d","ddb57e3f789be864","1d6a1872a334539d","93d4ba1fe642d988"],"x":475,"y":2920,"wires":[]},{"id":"45ac3ea58ab506a8","type":"link in","z":"fbc96b6cec386837","g":"c9db54871ce8dbab","name":"IN Oppo DVD OFF","links":["a66a461c9c1bc1a7","6a0c6091e769de9f","e408dc4ed64ce8f1","92d8062d1e413974","b2d96de4075dae77"],"x":465,"y":3120,"wires":[["1aad56c36b2fb623"]]},{"id":"b5c641c8471ca970","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"5608ffb005953ad8","name":"DVD","version":"6","entityType":"switch","haConfig":[{"property":"name","value":"DVD"},{"property":"icon","value":"phu:dvd"},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":"switch"}],"resend":false,"debugEnabled":false},{"id":"5608ffb005953ad8","type":"ha-device-config","name":"DVD","hwVersion":"","manufacturer":"Node-RED","model":"","swVersion":""},{"id":"788a113f95d18612","type":"group","z":"fbc96b6cec386837","g":"cd277bfe6b3e6902","name":"Normal TV Switch for HA Assist and Astrion (Mapped to ROS Switch Control Card)","style":{"label":true},"nodes":["76b9adc6bea6d856","47e54400996d441c","b22d811b6d731d2f","0dde7d9b9c741cdf","b63ce5dbf1a68d98","8f23386a103fcef6","999f813739eda340","a66a461c9c1bc1a7","5822eacd465e6e2d"],"x":254,"y":1859,"w":692,"h":282},{"id":"76b9adc6bea6d856","type":"H activity","z":"fbc96b6cec386837","g":"788a113f95d18612","name":"Turn ON Normal TV","server":"21dd4f96b9a6b12b","activity":"42679719","label":"Normal TV","x":560,"y":1940,"wires":[[]]},{"id":"47e54400996d441c","type":"ha-switch","z":"fbc96b6cec386837","g":"788a113f95d18612","name":"Normal TV","version":0,"debugenabled":false,"inputs":0,"outputs":2,"entityConfig":"ecdc8ff7518bb0d8","enableInput":false,"outputOnStateChange":true,"outputProperties":[{"property":"outputType","propertyType":"msg","value":"state change","valueType":"str"},{"property":"payload","propertyType":"msg","value":"string","valueType":"entityState"}],"x":340,"y":1960,"wires":[["76b9adc6bea6d856","a66a461c9c1bc1a7"],[]]},{"id":"b22d811b6d731d2f","type":"trigger-state","z":"fbc96b6cec386837","g":"788a113f95d18612","name":"Normal TV ON","server":"bb380e72.b8825","version":5,"inputs":0,"outputs":2,"exposeAsEntityConfig":"","entities":{"entity":["select.harmony_hub_activities"],"substring":[],"regex":[]},"debugEnabled":false,"constraints":[{"targetType":"this_entity","targetValue":"","propertyType":"current_state","propertyValue":"new_state.state","comparatorType":"is","comparatorValueDatatype":"str","comparatorValue":"Normal TV"}],"customOutputs":[],"outputInitially":true,"stateType":"str","enableInput":false,"x":360,"y":2040,"wires":[["8f23386a103fcef6"],[]]},{"id":"0dde7d9b9c741cdf","type":"api-call-service","z":"fbc96b6cec386837","g":"788a113f95d18612","name":"Normal TV SWITCH OFF","server":"bb380e72.b8825","version":7,"debugenabled":false,"action":"switch.turn_off","floorId":[],"areaId":[],"deviceId":[],"entityId":["switch.normal_tv"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":true,"domain":"switch","service":"turn_off","x":810,"y":2100,"wires":[[]]},{"id":"b63ce5dbf1a68d98","type":"api-call-service","z":"fbc96b6cec386837","g":"788a113f95d18612","name":"Normal TV SWITCH ON","server":"bb380e72.b8825","version":7,"debugenabled":false,"action":"switch.turn_on","floorId":[],"areaId":[],"deviceId":[],"entityId":["switch.normal_tv"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":true,"domain":"switch","service":"turn_on","x":810,"y":2040,"wires":[[]]},{"id":"8f23386a103fcef6","type":"api-current-state","z":"fbc96b6cec386837","g":"788a113f95d18612","name":"Switch OFF","server":"bb380e72.b8825","version":3,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.normal_tv","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"string","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":590,"y":2040,"wires":[["b63ce5dbf1a68d98"],[]]},{"id":"999f813739eda340","type":"api-current-state","z":"fbc96b6cec386837","g":"788a113f95d18612","name":"Switch ON","server":"bb380e72.b8825","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.normal_tv","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"string","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":590,"y":2100,"wires":[["0dde7d9b9c741cdf"],[]]},{"id":"a66a461c9c1bc1a7","type":"link out","z":"fbc96b6cec386837","g":"788a113f95d18612","name":"OUT Normal TV ON","mode":"link","links":["1ac4689e0117c1ba","ddb57e3f789be864","1d6a1872a334539d","45ac3ea58ab506a8","93d4ba1fe642d988"],"x":475,"y":1900,"wires":[]},{"id":"5822eacd465e6e2d","type":"link in","z":"fbc96b6cec386837","g":"788a113f95d18612","name":"IN Normal TV OFF","links":["6a0c6091e769de9f","e408dc4ed64ce8f1","85e25312dd2f2db5","92d8062d1e413974","b2d96de4075dae77"],"x":425,"y":2100,"wires":[["999f813739eda340"]]},{"id":"ecdc8ff7518bb0d8","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"f03ec738168a5393","name":"Normal TV","version":"6","entityType":"switch","haConfig":[{"property":"name","value":"Normal TV"},{"property":"icon","value":"mdi:television-classic"},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":"switch"}],"resend":false,"debugEnabled":false},{"id":"f03ec738168a5393","type":"ha-device-config","name":"Normal TV","hwVersion":"","manufacturer":"Node-RED","model":"","swVersion":""},{"id":"7e03604132b85a00","type":"group","z":"fbc96b6cec386837","g":"cd277bfe6b3e6902","name":"Nintendo Switch for HA Assist and Astrion (Mapped to ROS Switch Control Card)","style":{"label":true},"nodes":["e4a5fbbeccf1a5c7","db48139868d1cb90","6d348d19a8e4479c","a4f079efc9613ce4","6ee0fb116647aeea","2f2253a69d636b53","b145aca352b28644","92d8062d1e413974","1d6a1872a334539d"],"x":254,"y":3219,"w":652,"h":262},{"id":"e4a5fbbeccf1a5c7","type":"H activity","z":"fbc96b6cec386837","g":"7e03604132b85a00","name":"Turn ON Nintendo Switch 2","server":"21dd4f96b9a6b12b","activity":"53662309","label":"Nintendo Switch 2","x":580,"y":3300,"wires":[[]]},{"id":"db48139868d1cb90","type":"ha-switch","z":"fbc96b6cec386837","g":"7e03604132b85a00","name":"Nintendo","version":0,"debugenabled":false,"inputs":0,"outputs":2,"entityConfig":"9a2e6ea3b691b804","enableInput":false,"outputOnStateChange":true,"outputProperties":[{"property":"outputType","propertyType":"msg","value":"state change","valueType":"str"},{"property":"payload","propertyType":"msg","value":"string","valueType":"entityState"}],"x":340,"y":3320,"wires":[["e4a5fbbeccf1a5c7","92d8062d1e413974"],[]]},{"id":"6d348d19a8e4479c","type":"trigger-state","z":"fbc96b6cec386837","g":"7e03604132b85a00","name":"Nintendo Switch 2 ON","server":"bb380e72.b8825","version":5,"inputs":0,"outputs":2,"exposeAsEntityConfig":"","entities":{"entity":["select.harmony_hub_activities"],"substring":[],"regex":[]},"debugEnabled":false,"constraints":[{"targetType":"this_entity","targetValue":"","propertyType":"current_state","propertyValue":"new_state.state","comparatorType":"is","comparatorValueDatatype":"str","comparatorValue":"Nintendo Switch 2"}],"customOutputs":[],"outputInitially":true,"stateType":"str","enableInput":false,"x":380,"y":3400,"wires":[["2f2253a69d636b53"],[]]},{"id":"a4f079efc9613ce4","type":"api-call-service","z":"fbc96b6cec386837","g":"7e03604132b85a00","name":"Nintendo SWITCH OFF","server":"bb380e72.b8825","version":7,"debugenabled":false,"action":"switch.turn_off","floorId":[],"areaId":[],"deviceId":[],"entityId":["switch.nintendo"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":true,"domain":"switch","service":"turn_off","x":730,"y":3440,"wires":[[]]},{"id":"6ee0fb116647aeea","type":"api-call-service","z":"fbc96b6cec386837","g":"7e03604132b85a00","name":"Nintendo SWITCH ON","server":"bb380e72.b8825","version":7,"debugenabled":false,"action":"switch.turn_on","floorId":[],"areaId":[],"deviceId":[],"entityId":["switch.nintendo"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":true,"domain":"switch","service":"turn_on","x":780,"y":3400,"wires":[[]]},{"id":"2f2253a69d636b53","type":"api-current-state","z":"fbc96b6cec386837","g":"7e03604132b85a00","name":"Switch OFF","server":"bb380e72.b8825","version":3,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.nintendo","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"string","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":590,"y":3400,"wires":[["6ee0fb116647aeea"],[]]},{"id":"b145aca352b28644","type":"api-current-state","z":"fbc96b6cec386837","g":"7e03604132b85a00","name":"Switch ON","server":"bb380e72.b8825","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.nintendo","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"string","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":530,"y":3440,"wires":[["a4f079efc9613ce4"],[]]},{"id":"92d8062d1e413974","type":"link out","z":"fbc96b6cec386837","g":"7e03604132b85a00","name":"OUT Nintendo Switch ON","mode":"link","links":["1ac4689e0117c1ba","5822eacd465e6e2d","ddb57e3f789be864","45ac3ea58ab506a8","93d4ba1fe642d988"],"x":475,"y":3260,"wires":[]},{"id":"1d6a1872a334539d","type":"link in","z":"fbc96b6cec386837","g":"7e03604132b85a00","name":"IN Nintendo Switch OFF","links":["a66a461c9c1bc1a7","6a0c6091e769de9f","e408dc4ed64ce8f1","85e25312dd2f2db5","b2d96de4075dae77"],"x":405,"y":3440,"wires":[["b145aca352b28644"]]},{"id":"9a2e6ea3b691b804","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"c3d07af1c382fa6b","name":"Nintendo","version":6,"entityType":"switch","haConfig":[{"property":"name","value":"Nintendo"},{"property":"icon","value":"phu:nintendo-switch-logo"},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":"switch"}],"resend":false,"debugEnabled":false},{"id":"c3d07af1c382fa6b","type":"ha-device-config","name":"Nintendo","hwVersion":"","manufacturer":"Node-RED","model":"Nintendo","swVersion":""},{"id":"e0b23b0661dab4a9","type":"group","z":"fbc96b6cec386837","g":"cd277bfe6b3e6902","name":"Power_Off Switch for HA Assist and Astrion (Mapped to ROS Switch Control Card)","style":{"label":true},"nodes":["c0a9c1d1b78b9215","a030bf475dcb6c3d","5b603835edb9fc01","a7860b2ad1aefc8a","6b0df0bf3114b06f","728d018334d9e4f5","b2d96de4075dae77","93d4ba1fe642d988","2f0499c2724b5080","11ef956d5a6299ac"],"x":1048,"y":2739,"w":718,"h":608},{"id":"c0a9c1d1b78b9215","type":"H activity","z":"fbc96b6cec386837","g":"e0b23b0661dab4a9","name":"Harmony OFF","server":"21dd4f96b9a6b12b","activity":"-1","label":"PowerOff","x":1360,"y":2820,"wires":[[]]},{"id":"a030bf475dcb6c3d","type":"ha-switch","z":"fbc96b6cec386837","g":"e0b23b0661dab4a9","name":"Harmony OFF","version":0,"debugenabled":false,"inputs":0,"outputs":2,"entityConfig":"ecce05b37d5e9822","enableInput":false,"outputOnStateChange":true,"outputProperties":[{"property":"outputType","propertyType":"msg","value":"state change","valueType":"str"},{"property":"payload","propertyType":"msg","value":"string","valueType":"entityState"}],"x":1170,"y":2840,"wires":[["b2d96de4075dae77","c0a9c1d1b78b9215"],[]]},{"id":"5b603835edb9fc01","type":"api-call-service","z":"fbc96b6cec386837","g":"e0b23b0661dab4a9","name":"Harmony OFF SWITCH OFF","server":"bb380e72.b8825","version":7,"debugenabled":false,"action":"switch.turn_off","floorId":[],"areaId":[],"deviceId":[],"entityId":["switch.harmony_off_harmony_off"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":true,"domain":"switch","service":"turn_off","x":1620,"y":2940,"wires":[[]]},{"id":"a7860b2ad1aefc8a","type":"api-call-service","z":"fbc96b6cec386837","g":"e0b23b0661dab4a9","name":"Harmony OFF SWITCH ON","server":"bb380e72.b8825","version":7,"debugenabled":false,"action":"switch.turn_on","floorId":[],"areaId":[],"deviceId":[],"entityId":["switch.harmony_off_harmony_off"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":true,"domain":"switch","service":"turn_on","x":1620,"y":3000,"wires":[[]]},{"id":"6b0df0bf3114b06f","type":"api-current-state","z":"fbc96b6cec386837","g":"e0b23b0661dab4a9","name":"Switch OFF","server":"bb380e72.b8825","version":3,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.harmony_off_harmony_off","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"string","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1410,"y":3000,"wires":[["a7860b2ad1aefc8a"],[]]},{"id":"728d018334d9e4f5","type":"api-current-state","z":"fbc96b6cec386837","g":"e0b23b0661dab4a9","name":"Switch ON","server":"bb380e72.b8825","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.harmony_off_harmony_off","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"string","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1410,"y":2940,"wires":[["5b603835edb9fc01"],[]]},{"id":"b2d96de4075dae77","type":"link out","z":"fbc96b6cec386837","g":"e0b23b0661dab4a9","name":"OUT Harmony OFF Switch ON","mode":"link","links":["1ac4689e0117c1ba","1d6a1872a334539d","45ac3ea58ab506a8","5822eacd465e6e2d","ddb57e3f789be864"],"x":1295,"y":2780,"wires":[]},{"id":"93d4ba1fe642d988","type":"link in","z":"fbc96b6cec386837","g":"e0b23b0661dab4a9","name":"IN Harmony OFF Switch OFF","links":["6a0c6091e769de9f","85e25312dd2f2db5","92d8062d1e413974","a66a461c9c1bc1a7","e408dc4ed64ce8f1"],"x":1245,"y":2940,"wires":[["728d018334d9e4f5"]]},{"id":"2f0499c2724b5080","type":"trigger-state","z":"fbc96b6cec386837","g":"e0b23b0661dab4a9","name":"Harmony Power_OFF","server":"bb380e72.b8825","version":5,"inputs":0,"outputs":2,"exposeAsEntityConfig":"","entities":{"entity":["select.harmony_hub_activities"],"substring":[],"regex":[]},"debugEnabled":false,"constraints":[{"targetType":"this_entity","targetValue":"","propertyType":"current_state","propertyValue":"new_state.state","comparatorType":"is","comparatorValueDatatype":"str","comparatorValue":"power_off"}],"customOutputs":[],"outputInitially":true,"stateType":"str","enableInput":false,"x":1200,"y":3000,"wires":[["6b0df0bf3114b06f"],[]]},{"id":"11ef956d5a6299ac","type":"group","z":"fbc96b6cec386837","g":"e0b23b0661dab4a9","name":"Specific HA Assist, OFF Phrases","style":{"label":true},"nodes":["756596dc7af48927","0aca7871295ea59a","17d0b0323aef19a8","7fdb21c99f2babe4"],"x":1074,"y":3059,"w":272,"h":262},{"id":"756596dc7af48927","type":"ha-sentence","z":"fbc96b6cec386837","g":"11ef956d5a6299ac","name":"Turn OFF TV","server":"bb380e72.b8825","version":2,"inputs":0,"outputs":1,"exposeAsEntityConfig":"","mode":"trigger","sentences":["Turn OFF TV"],"response":"","responseType":"str","triggerResponse":"","triggerResponseType":"fixed","responseTimeout":1000,"outputProperties":[{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"},{"property":"payload","propertyType":"msg","value":"","valueType":"triggerId"}],"x":1170,"y":3100,"wires":[["6b0df0bf3114b06f"]]},{"id":"0aca7871295ea59a","type":"ha-sentence","z":"fbc96b6cec386837","g":"11ef956d5a6299ac","name":"Turn OFF DVD","server":"bb380e72.b8825","version":2,"inputs":0,"outputs":1,"exposeAsEntityConfig":"","mode":"trigger","sentences":["Turn OFF DVD","Turn OFF Oppo"],"response":"","responseType":"str","triggerResponse":"","triggerResponseType":"fixed","responseTimeout":1000,"outputProperties":[{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"},{"property":"payload","propertyType":"msg","value":"","valueType":"triggerId"}],"x":1180,"y":3220,"wires":[["6b0df0bf3114b06f"]]},{"id":"17d0b0323aef19a8","type":"ha-sentence","z":"fbc96b6cec386837","g":"11ef956d5a6299ac","name":"Turn OFF Redord Player","server":"bb380e72.b8825","version":2,"inputs":0,"outputs":1,"exposeAsEntityConfig":"","mode":"trigger","sentences":["Turn OFF Record Player"],"response":"","responseType":"str","triggerResponse":"","triggerResponseType":"fixed","responseTimeout":1000,"outputProperties":[{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"},{"property":"payload","propertyType":"msg","value":"","valueType":"triggerId"}],"x":1210,"y":3160,"wires":[["6b0df0bf3114b06f"]]},{"id":"7fdb21c99f2babe4","type":"ha-sentence","z":"fbc96b6cec386837","g":"11ef956d5a6299ac","name":"Turn OFF Nintendo","server":"bb380e72.b8825","version":2,"inputs":0,"outputs":1,"exposeAsEntityConfig":"","mode":"trigger","sentences":["Turn OFF Nintendo"],"response":"","responseType":"str","triggerResponse":"","triggerResponseType":"fixed","responseTimeout":1000,"outputProperties":[{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"},{"property":"payload","propertyType":"msg","value":"","valueType":"triggerId"}],"x":1190,"y":3280,"wires":[["6b0df0bf3114b06f"]]},{"id":"ecce05b37d5e9822","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"e455041794ca2da2","name":"Harmony OFF","version":6,"entityType":"switch","haConfig":[{"property":"name","value":"Harmony OFF"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"e455041794ca2da2","type":"ha-device-config","name":"Harmony_OFF","hwVersion":"","manufacturer":"Node-RED","model":"Harmony","swVersion":""},{"id":"c4574f8c472c8852","type":"group","z":"fbc96b6cec386837","g":"cd277bfe6b3e6902","name":"Mapped to Power Button on ROS TV Card","style":{"label":true},"nodes":["530d2afe4751b324","d8a044ab5034fcc4"],"x":1074,"y":2579,"w":412,"h":102},{"id":"530d2afe4751b324","type":"ha-switch","z":"fbc96b6cec386837","g":"c4574f8c472c8852","name":"ROS TV Toggle","version":0,"debugenabled":false,"inputs":0,"outputs":2,"entityConfig":"65fb7a5ed682f9cc","enableInput":false,"outputOnStateChange":true,"outputProperties":[{"property":"outputType","propertyType":"msg","value":"state change","valueType":"str"},{"property":"payload","propertyType":"msg","value":"string","valueType":"entityState"}],"x":1180,"y":2640,"wires":[["d8a044ab5034fcc4"],["c0a9c1d1b78b9215"]]},{"id":"d8a044ab5034fcc4","type":"api-call-service","z":"fbc96b6cec386837","g":"c4574f8c472c8852","name":"","server":"bb380e72.b8825","version":7,"debugenabled":false,"action":"remote.turn_on","floorId":[],"areaId":[],"deviceId":[],"entityId":["remote.harmony_hub"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":true,"domain":"remote","service":"turn_on","x":1380,"y":2620,"wires":[[]]},{"id":"65fb7a5ed682f9cc","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"1dfed0fbb09e8ed6","name":"ROS TV Toggle","version":6,"entityType":"switch","haConfig":[{"property":"name","value":"ROS TV Toggle"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"1dfed0fbb09e8ed6","type":"ha-device-config","name":"ROS TV Toggle","hwVersion":"","manufacturer":"Node-RED","model":"ROS","swVersion":""},{"id":"cb792b00a0db4b1a","type":"group","z":"fbc96b6cec386837","name":"Keep harmony Alive in NodeRED","style":{"label":true},"nodes":["f104b5ceb5f48b29","74d1a38e572fc8e5","412bb9b264369a70","rec_persist_group2"],"x":2338,"y":193,"w":2624,"h":574},{"id":"f104b5ceb5f48b29","type":"inject","z":"fbc96b6cec386837","g":"cb792b00a0db4b1a","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":2980,"y":280,"wires":[["1c4688d463866e83"]]},{"id":"74d1a38e572fc8e5","type":"group","z":"fbc96b6cec386837","g":"cb792b00a0db4b1a","name":"Harmony Heartbeat and Recovery","style":{"label":true},"nodes":["604b7fbaa3a4861f","e98f6ee8fc6224ee","addbe4b6910aba6f","4543d0d08b9b960b","2ad542c92756d5a4","31fcf70bffacec68","52a9471cdc5c03db","e1dccbb2c7018f2a","56b3d13069c87ba2","affbf6bcda221a4a","69f41ec17f5ad4fe","088fd76ca53124b5","c36481170edd23cd","46fb9b1af719e279","hb_timeout","retest_timeout","5ae5bc9def0f20f8","5eeeb0e214c24182","0aa61780c21fb5d5","catch_harmony_errors"],"x":2364,"y":399,"w":2252,"h":342},{"id":"604b7fbaa3a4861f","type":"link in","z":"fbc96b6cec386837","g":"74d1a38e572fc8e5","name":"Recovery entry (false/TIMEOUT)","links":["69f41ec17f5ad4fe"],"x":2725,"y":440,"wires":[["e98f6ee8fc6224ee"]]},{"id":"e98f6ee8fc6224ee","type":"delay","z":"fbc96b6cec386837","g":"74d1a38e572fc8e5","name":"limit: 1 recovery / 60s","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"60","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":true,"allowrate":false,"outputs":1,"x":2870,"y":440,"wires":[["addbe4b6910aba6f","1c4688d463866e83"]]},{"id":"addbe4b6910aba6f","type":"api-call-service","z":"fbc96b6cec386837","g":"74d1a38e572fc8e5","name":"Call script.restart_harmony_hub","server":"bb380e72.b8825","version":7,"debugenabled":false,"action":"script.restart_harmony_hub","floorId":[],"areaId":[],"deviceId":[],"entityId":[],"labelId":[],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"script","service":"restart_harmony_hub","x":3160,"y":440,"wires":[["4543d0d08b9b960b","5eeeb0e214c24182"]]},{"id":"4543d0d08b9b960b","type":"delay","z":"fbc96b6cec386837","g":"74d1a38e572fc8e5","name":"wait 30s","pauseType":"delay","timeout":"30","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":3450,"y":440,"wires":[["2ad542c92756d5a4"]]},{"id":"2ad542c92756d5a4","type":"change","z":"fbc96b6cec386837","g":"74d1a38e572fc8e5","name":"topic=retest, payload={op:getCurrentActivity}","rules":[{"t":"set","p":"topic","pt":"msg","to":"harmony/retest","tot":"str"},{"t":"set","p":"payload","pt":"msg","to":"{\"op\":\"getCurrentActivity\"}","tot":"json"}],"x":3740,"y":440,"wires":[["088fd76ca53124b5","retest_timeout"]]},{"id":"31fcf70bffacec68","type":"api-call-service","z":"fbc96b6cec386837","g":"74d1a38e572fc8e5","name":"Call script.restart_node_red (ESCALATE)","server":"bb380e72.b8825","version":7,"debugenabled":false,"action":"script.restart_node_red","floorId":[],"areaId":[],"deviceId":[],"entityId":[],"labelId":[],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"script","service":"restart_node_red","x":4430,"y":580,"wires":[["52a9471cdc5c03db"]]},{"id":"52a9471cdc5c03db","type":"debug","z":"fbc96b6cec386837","g":"74d1a38e572fc8e5","name":"ESCALATED → restart_node_red","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":4430,"y":660,"wires":[]},{"id":"e1dccbb2c7018f2a","type":"inject","z":"fbc96b6cec386837","g":"74d1a38e572fc8e5","name":"Heartbeat every 7 min","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"420","crontab":"","once":true,"onceDelay":"10","topic":"harmony/heartbeat","payload":"","payloadType":"date","x":2540,"y":620,"wires":[["affbf6bcda221a4a"]]},{"id":"56b3d13069c87ba2","type":"inject","z":"fbc96b6cec386837","g":"74d1a38e572fc8e5","name":"Heartbeat (manual)","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"harmony/heartbeat","payload":"","payloadType":"date","x":2540,"y":700,"wires":[["affbf6bcda221a4a"]]},{"id":"affbf6bcda221a4a","type":"change","z":"fbc96b6cec386837","g":"74d1a38e572fc8e5","name":"topic=hb, payload={op:getCurrentActivity}","rules":[{"t":"set","p":"topic","pt":"msg","to":"harmony/heartbeat","tot":"str"},{"t":"set","p":"payload","pt":"msg","to":"{\"op\":\"getCurrentActivity\"}","tot":"json"}],"x":2890,"y":660,"wires":[["088fd76ca53124b5","hb_timeout"]]},{"id":"69f41ec17f5ad4fe","type":"link out","z":"fbc96b6cec386837","g":"74d1a38e572fc8e5","name":"→ Recovery entry","mode":"link","links":["604b7fbaa3a4861f"],"x":3535,"y":660,"wires":[]},{"id":"088fd76ca53124b5","type":"H GetActivity","z":"fbc96b6cec386837","g":"74d1a38e572fc8e5","name":"Harmony getCurrentActivity","server":"21dd4f96b9a6b12b","x":3330,"y":560,"wires":[["46fb9b1af719e279","c36481170edd23cd"]]},{"id":"c36481170edd23cd","type":"function","z":"fbc96b6cec386837","g":"74d1a38e572fc8e5","name":"mark healthy (resets hb/retest)","func":"flow.set('harmony_last_ok', Date.now());\nnode.status({fill:'green', shape:'dot', text:'Harmony OK'});\nreturn { topic: msg.topic, payload: '__HARMONY_OK__' };","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":3800,"y":660,"wires":[["hb_timeout","retest_timeout"]]},{"id":"46fb9b1af719e279","type":"debug","z":"fbc96b6cec386837","g":"74d1a38e572fc8e5","name":"Heartbeat OK (Harmony reply)","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":3780,"y":540,"wires":[]},{"id":"hb_timeout","type":"trigger","z":"fbc96b6cec386837","g":"74d1a38e572fc8e5","name":"10s hb_timeout → go to recovery","op1":"","op2":"TIMEOUT","op1type":"nul","op2type":"str","duration":"10","extend":false,"overrideDelay":false,"units":"s","reset":"__HARMONY_OK__","bytopic":"all","topic":"topic","outputs":1,"x":3350,"y":660,"wires":[["69f41ec17f5ad4fe"]]},{"id":"retest_timeout","type":"trigger","z":"fbc96b6cec386837","g":"74d1a38e572fc8e5","name":"12s retest_timeout → escalate","op1":"","op2":"TIMEOUT","op1type":"nul","op2type":"str","duration":"12","extend":false,"overrideDelay":false,"units":"s","reset":"__HARMONY_OK__","bytopic":"all","topic":"topic","outputs":1,"x":4120,"y":440,"wires":[["5ae5bc9def0f20f8"]]},{"id":"5ae5bc9def0f20f8","type":"delay","z":"fbc96b6cec386837","g":"74d1a38e572fc8e5","name":"limit: 1 recovery / 2mins","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"2","rateUnits":"minute","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":true,"allowrate":false,"outputs":1,"x":4140,"y":500,"wires":[["31fcf70bffacec68","0aa61780c21fb5d5"]]},{"id":"5eeeb0e214c24182","type":"function","z":"fbc96b6cec386837","g":"74d1a38e572fc8e5","name":"Restarting Hub","func":"node.status({fill:'yellow',shape:'ring',text:'Recovering: restarting hub…'})\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":3210,"y":500,"wires":[[]]},{"id":"0aa61780c21fb5d5","type":"function","z":"fbc96b6cec386837","g":"74d1a38e572fc8e5","name":"Restarting Node Red","func":"node.status({fill:'red',shape:'dot',text:'Escalate: restarting Node-RED'})\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":4430,"y":500,"wires":[[]]},{"id":"catch_harmony_errors","type":"catch","z":"fbc96b6cec386837","g":"74d1a38e572fc8e5","name":"Catch H GetActivity errors → recovery","scope":["088fd76ca53124b5"],"uncaught":false,"x":2540,"y":440,"wires":[["e98f6ee8fc6224ee"]]},{"id":"412bb9b264369a70","type":"group","z":"fbc96b6cec386837","g":"cb792b00a0db4b1a","name":"Recovery Counter (per day)","style":{"label":true,"fill":"#f3f3f3","fill-opacity":"0.4"},"nodes":["1c4688d463866e83","65c031a36ddf215c","9b3884e70a051d26","3f5d6d8bf91c7e09"],"x":3094,"y":239,"w":642,"h":142},{"id":"1c4688d463866e83","type":"function","z":"fbc96b6cec386837","g":"412bb9b264369a70","name":"Increment recovery counter","func":"// Keep a per-day counter in default (memory) flow context\nconst today = new Date().toISOString().slice(0,10); // YYYY-MM-DD\nlet state = flow.get('harmonyRecover') || { date: today, count: 0 };\nif (state.date !== today) state = { date: today, count: 0 };\n\nstate.count += 1;\nflow.set('harmonyRecover', state);\n\n// Expose on msg and set node status\nmsg.recovery = state;\nnode.status({ fill:'yellow', shape:'ring', text:`Recoveries today: ${state.count}` });\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":3240,"y":280,"wires":[["65c031a36ddf215c","recpv_read"]]},{"id":"65c031a36ddf215c","type":"debug","z":"fbc96b6cec386837","g":"412bb9b264369a70","name":"recovery count → msg.recovery","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"recovery","targetType":"msg","x":3560,"y":280,"wires":[]},{"id":"9b3884e70a051d26","type":"inject","z":"fbc96b6cec386837","g":"412bb9b264369a70","name":"Reset at midnight","props":[{"p":"payload"}],"repeat":"","crontab":"00 00 * * 0","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":3240,"y":340,"wires":[["3f5d6d8bf91c7e09"]]},{"id":"3f5d6d8bf91c7e09","type":"function","z":"fbc96b6cec386837","g":"412bb9b264369a70","name":"Reset counter (new day)","func":"const today = new Date().toISOString().slice(0,10);\nflow.set('harmonyRecover', { date: today, count: 0 });\nnode.status({ fill:'green', shape:'dot', text:'Recoveries today: 0 (reset)' });\nreturn null;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":3530,"y":340,"wires":[[]]},{"id":"rec_persist_group2","type":"group","z":"fbc96b6cec386837","g":"cb792b00a0db4b1a","name":"Recovery Counter (persistent value)","style":{"label":true,"fill":"#f3f3f3","fill-opacity":"0.4"},"nodes":["recpv_read","recpv_inc_fn","recpv_write","recpv_dbg","recpv_init","recpv_init_fn"],"x":3774,"y":219,"w":1162,"h":162},{"id":"recpv_read","type":"persistent value","z":"fbc96b6cec386837","g":"rec_persist_group2","name":"READ HarmonyRecoverCount","valuesConfig":"a5c68c181fad7f5e","valuesConfigName":"Harmony Reload Count READ","valueId":"8bc1d1b0-8a4f-11f0-8fec-37a7f886b757","value":"Value 1","command":"read","msgProperty":"payload","dynamicControl":true,"dynamicCommandMsgProperty":"command","dynamicValueMsgProperty":"","deepCloneValue":false,"outputPreviousValue":false,"outputPreviousValueMsgProperty":"previous_value","collectValues":false,"collectValuesMsgProperty":"values","blockIfEnable":false,"blockIfRule":"eq","blockIfCompareValue":"","outputMetaData":false,"outputMetaDataMsgProperty":"meta","x":4200,"y":280,"wires":[["recpv_inc_fn"],[]]},{"id":"recpv_inc_fn","type":"function","z":"fbc96b6cec386837","g":"rec_persist_group2","name":"Increment → prepare WRITE","func":"let n = Number(msg.payload);\nif (!Number.isFinite(n)) n = 0;\nmsg.payload = n + 1;\nmsg.command = 'write';\nmsg.recovery = { count: msg.payload };\nnode.status({ fill:'yellow', shape:'ring', text:`Recoveries today: ${msg.payload}` });\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":4480,"y":280,"wires":[["recpv_write","recpv_dbg"]]},{"id":"recpv_write","type":"persistent value","z":"fbc96b6cec386837","g":"rec_persist_group2","name":"WRITE HarmonyRecoverCount","valuesConfig":"a5c68c181fad7f5e","valuesConfigName":"Harmony Reload Count READ","valueId":"8bc1d1b0-8a4f-11f0-8fec-37a7f886b757","value":"Value 1","command":"write","msgProperty":"payload","dynamicControl":false,"dynamicCommandMsgProperty":"command","dynamicValueMsgProperty":"topic","deepCloneValue":false,"outputPreviousValue":false,"outputPreviousValueMsgProperty":"previous_value","collectValues":false,"collectValuesMsgProperty":"values","blockIfEnable":false,"blockIfRule":"eq","blockIfCompareValue":"","outputMetaData":false,"outputMetaDataMsgProperty":"meta","x":4780,"y":320,"wires":[[],[]]},{"id":"recpv_dbg","type":"debug","z":"fbc96b6cec386837","g":"rec_persist_group2","name":"recovery count","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"recovery","targetType":"msg","x":4760,"y":260,"wires":[]},{"id":"recpv_init","type":"inject","z":"fbc96b6cec386837","g":"rec_persist_group2","name":"Init once (5s) + reset weekly 00:01","props":[{"p":"payload"},{"p":"command","v":"write","vt":"str"}],"repeat":"","crontab":"01 00 * * 0","once":false,"onceDelay":"5","topic":"","payload":"","payloadType":"date","x":3960,"y":340,"wires":[["recpv_init_fn"]]},{"id":"recpv_init_fn","type":"function","z":"fbc96b6cec386837","g":"rec_persist_group2","name":"WRITE 0 (reset/init)","func":"msg.payload = 0;\nmsg.command = 'write';\nnode.status({ fill:'green', shape:'dot', text:'Recoveries today: 0 (init/reset)' });\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":4240,"y":340,"wires":[["recpv_write"]]},{"id":"a5c68c181fad7f5e","type":"persistent values config","name":"Harmony Reload Count READ","values":[{"id":"8bc1d1b0-8a4f-11f0-8fec-37a7f886b757","name":"Value 1","datatype":"num","default":0,"description":"","scope":"global","storage":"default"}]},{"id":"bb380e72.b8825","type":"server","name":"Home Assistant","version":6,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":["y","yes","true","on","home","open"],"connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":"30","areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true},{"id":"5e427661b7f1b53f","type":"global-config","env":[],"modules":{"node-red-contrib-home-assistant-websocket":"0.80.3","node-red-contrib-harmony-extra":"1.0.1","@waldbaer/node-red-persistent-values":"1.6.1"}}]
Created 3 months ago
  • catch (x1)
  • change (x2)
  • debug (x5)
  • delay (x3)
  • function (x7)
  • inject (x5)
  • link in (x7)
  • link out (x7)
  • switch (x17)
  • trigger (x2)
  • astrion
  • home
  • assistant
  • sanytron
  • harmony
  • logitech
