node-red-contrib-home-assistant-websocket 0.83.0
Node-RED integration with Home Assistant through websocket and REST API
npm install node-red-contrib-home-assistant-websocket
Release Version Build Status License
BuyMeCoffee
Various nodes to assist in setting up automation using Node-RED communicating with Home Assistant.
Getting Started
Documentation can be found here.
Prerequisites
Have Node-RED installed and working, if you need to install Node-RED see here.
Install via Node-RED Manage Palette
Install via npm
$ cd ~/.node-red
$ npm install node-red-contrib-home-assistant-websocket
# then restart node-red
For Home Assistant add-on users:
The Community add-on ships with this node right out of the box.
Under the server node config just check the checkbox for I use the Home Assistant Add-on
The add-on can be found here: https://github.com/hassio-addons/addon-node-red#readme
Contribute
List of all contributors
Version: 0.83.0
Updated 6 days ago
Rating: 4.6 47
3939 in the last week
  • home-assistant
  • home assistant
  • home automation
  • websocket
