Seneye Aquarium Monitor - SWS Webserver → API → Home Assistant
Details and Attributes
See this original post by @notovich Влад Нотович without him this would not work.
What it Does
  • This flow will extract data from the Seneye API every 3 minutes (Matches the 20 manual requests per hour)
  • Sensor Output to Node Red Companion Sensors
  • Alternate MQTT Sensor Output
  • Use sensor output in Home Assistant to create graphs or display outputs
Requirements
NodeRed Companion: node-red-contrib-home-assistant-websocket
MQTT Sensors
  • Built In
Step 1 - Setup SWS (Seneye Web Server)
Step 2 - Access the Seneye API
  • It is critical to test your API link and ensure it works
    • DeviceID - Find your 12 character Device ID - e.g. 2mop534r4o6l
    • [email protected] - The email address you registered with eye
    • User_Password - Seneye.me password
  • Copy and place your details into the below URL remove the asteriks ** if there is any.
  • https ://api.seneye.com/v1/devices/DeviceID?IncludeState=1&user=[email protected]&pwd=User_Password
  • Paste your URL into a webbrowser and you should be greeted with the output of the Seneye API image
  • NOTE: If you have two devices they will show up, use this to change the function node to read from that device. image
Step 3 - Import Flow and Setup
IMPORT FLOW
  • Copy and Paste the below flow
  • In NodeRED click the hamburger icon and click import
  • Paste the flow into Import nodes dialoge (suggest selecting Import to new flow) image
  • Click Import to import the flow into your NodeRed instance
HTTPS REQUEST NODE
  • In the http request node paste your URL image
DEBUG NODE USAGE
  • If you have two devices use the debug node to copy the path of the reading you want image
EDIT FUNCTION NODE
  • Ensure the function node matches the path for the reading you want image
SETUP NodeRED Companion Sensor
  • Click on the Entity Config edit button image image
  • Select your Home Assistant Server image
  • Repeat for all sensors and name/translate as you feel fit.
SETUP MQTT Sensor
  • Select your MQTT Server image
Make your aquarium monitoring dashboard
[{"id":"097aa92b38953411","type":"group","z":"f1939796.abade8","name":"SENEYE MONITORING","style":{"label":true},"nodes":["a34e20ef.d65e8","8b274ef6.c7352","acbfe05f.fe984","e4ac4c11.167ef","97c2f3df.31cf5","23e3f222.9577ae","81942829.17e618","1bc0627b.4d29be","e9f6285a.609b58","ba2dfea6.ec175","6c40e3cd.3dc99c","edb8f828.f14df8","e2ecbfec.37f08","6916bb1d.35e384","fe5a48e8.54aec8","21a3d1a9.bca3fe","acfb54c9.a8ba28","db52d51e.3a7fb8","422061fa6f7fe183","a04be8591519d3dc","eb92c7aba036f7e1","bc7b222d14ec9ee9","8398c7612b911d52"],"x":134,"y":19,"w":1332,"h":582},{"id":"a34e20ef.d65e8","type":"function","z":"f1939796.abade8","g":"097aa92b38953411","name":"Temp","func":"msg.payload = Math.round(msg.payload[0].exps.temperature.curr * 10) / 10;\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":510,"y":280,"wires":[["bd9204ad849dace5"]]},{"id":"8b274ef6.c7352","type":"inject","z":"f1939796.abade8","g":"097aa92b38953411","name":"3 min","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"180","crontab":"","once":true,"onceDelay":"60","topic":"","payload":"","payloadType":"date","x":230,"y":360,"wires":[["acbfe05f.fe984"]]},{"id":"acbfe05f.fe984","type":"http request","z":"f1939796.abade8","g":"097aa92b38953411","name":"","method":"GET","ret":"obj","paytoqs":"ignore","url":"https://api.seneye.com/v1/devices/**DeviceID**?IncludeState=1&user=**[email protected]**&pwd=**User_Password**","tls":"","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[],"x":250,"y":300,"wires":[["a34e20ef.d65e8","e4ac4c11.167ef","23e3f222.9577ae","6c40e3cd.3dc99c","e2ecbfec.37f08","97c2f3df.31cf5","81942829.17e618","1bc0627b.4d29be","e9f6285a.609b58","ba2dfea6.ec175","eb92c7aba036f7e1"]]},{"id":"e4ac4c11.167ef","type":"function","z":"f1939796.abade8","g":"097aa92b38953411","name":"Ph","func":"msg.payload = msg.payload[0].exps.ph.curr;\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":510,"y":320,"wires":[["c9135df4c206d7de"]]},{"id":"97c2f3df.31cf5","type":"function","z":"f1939796.abade8","g":"097aa92b38953411","name":"O2","func":"msg.payload = msg.payload[0].exps.o2.curr;\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":510,"y":360,"wires":[["32261c4eaf51df0a"]]},{"id":"23e3f222.9577ae","type":"function","z":"f1939796.abade8","g":"097aa92b38953411","name":"NH3","func":"msg.payload = msg.payload[0].exps.nh3.curr;\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":510,"y":400,"wires":[["cfca1a0c59f4efb8"]]},{"id":"81942829.17e618","type":"function","z":"f1939796.abade8","g":"097aa92b38953411","name":"NH4","func":"msg.payload = msg.payload[0].exps.nh4.curr;\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":510,"y":440,"wires":[["13f7473191f64493"]]},{"id":"1bc0627b.4d29be","type":"function","z":"f1939796.abade8","d":true,"g":"097aa92b38953411","name":"LUX","func":"msg.payload = msg.payload[0].exps.lux.curr;\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":510,"y":480,"wires":[[]]},{"id":"e9f6285a.609b58","type":"function","z":"f1939796.abade8","d":true,"g":"097aa92b38953411","name":"PAR","func":"msg.payload = msg.payload[0].exps.par.curr;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":510,"y":520,"wires":[[]]},{"id":"ba2dfea6.ec175","type":"function","z":"f1939796.abade8","d":true,"g":"097aa92b38953411","name":"Kelvin","func":"msg.payload = msg.payload[0].exps.kelvin.curr;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":510,"y":560,"wires":[[]]},{"id":"6c40e3cd.3dc99c","type":"function","z":"f1939796.abade8","g":"097aa92b38953411","name":"Last","func":"msg.payload = msg.payload[0].status.last_experiment;\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":510,"y":120,"wires":[["edb8f828.f14df8"]]},{"id":"edb8f828.f14df8","type":"moment","z":"f1939796.abade8","g":"097aa92b38953411","name":"","topic":"","input":"","inputType":"msg","inTz":"Australia/Hobart","adjAmount":0,"adjType":"days","adjDir":"add","format":"","locale":"C","output":"","outputType":"msg","outTz":"Australia/Hobart","x":700,"y":120,"wires":[["fe5a48e8.54aec8"]]},{"id":"e2ecbfec.37f08","type":"function","z":"f1939796.abade8","g":"097aa92b38953411","name":"slide","func":"msg.payload = msg.payload[0].status.slide_expires;\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":510,"y":160,"wires":[["6916bb1d.35e384"]]},{"id":"6916bb1d.35e384","type":"moment","z":"f1939796.abade8","g":"097aa92b38953411","name":"","topic":"","input":"","inputType":"msg","inTz":"Europe/London","adjAmount":0,"adjType":"days","adjDir":"add","format":"","locale":"C","output":"","outputType":"msg","outTz":"Europe/London","x":700,"y":160,"wires":[["21a3d1a9.bca3fe"]]},{"id":"fe5a48e8.54aec8","type":"change","z":"f1939796.abade8","g":"097aa92b38953411","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$moment(msg.payload).fromNow()","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":920,"y":120,"wires":[["acfb54c9.a8ba28","422061fa6f7fe183"]]},{"id":"21a3d1a9.bca3fe","type":"change","z":"f1939796.abade8","g":"097aa92b38953411","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$moment(msg.payload).fromNow()","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":920,"y":160,"wires":[["a04be8591519d3dc"]]},{"id":"acfb54c9.a8ba28","type":"switch","z":"f1939796.abade8","g":"097aa92b38953411","name":"if >45min","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"45 minutes ago","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":1120,"y":120,"wires":[["db52d51e.3a7fb8"]]},{"id":"db52d51e.3a7fb8","type":"function","z":"f1939796.abade8","g":"097aa92b38953411","name":"Seneye no updated for 1H","func":"msg.payload = {}\nmsg.payload.chatId = 448821241\nmsg.payload.type = \"message\"\nmsg.payload.content = \"Seneye not updated for 1H\"\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":1330,"y":120,"wires":[[]]},{"id":"422061fa6f7fe183","type":"ha-sensor","z":"f1939796.abade8","g":"097aa92b38953411","name":"Seneye Last Reading","entityConfig":"c2248a7503069b40","version":0,"state":"payload","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":1160,"y":60,"wires":[[]],"server":"Select_Your_Server"},{"id":"a04be8591519d3dc","type":"ha-sensor","z":"f1939796.abade8","g":"097aa92b38953411","name":"Seneye Slide Expiry","entityConfig":"8b4b6e6dde0731e4","version":0,"state":"payload","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":1160,"y":180,"wires":[[]],"server":"Select_Your_Server"},{"id":"eb92c7aba036f7e1","type":"debug","z":"f1939796.abade8","g":"097aa92b38953411","name":"debug 2","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":280,"y":140,"wires":[]},{"id":"bc7b222d14ec9ee9","type":"group","z":"f1939796.abade8","g":"097aa92b38953411","name":"Sensor Output Alternate MQTT","style":{"label":true},"nodes":["a2fc219047efdd72","58a2c3b2c39c90da","02488545fb8722fc","7cbba0526b248c01","ecf391724ee899ab"],"x":894,"y":239,"w":232,"h":242},{"id":"a2fc219047efdd72","type":"mqtt out","z":"f1939796.abade8","g":"bc7b222d14ec9ee9","name":"tele/seneye/last","topic":"tele/seneye/last","qos":"1","retain":"false","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"34f7583aa6e3efb2","x":1000,"y":280,"wires":[]},{"id":"58a2c3b2c39c90da","type":"mqtt out","z":"f1939796.abade8","g":"bc7b222d14ec9ee9","name":"tele/seneye/slide","topic":"tele/seneye/slide","qos":"1","retain":"false","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"34f7583aa6e3efb2","x":1010,"y":320,"wires":[]},{"id":"02488545fb8722fc","type":"mqtt out","z":"f1939796.abade8","g":"bc7b222d14ec9ee9","name":"tele/seneye/temp","topic":"tele/seneye/temp","qos":"1","retain":"false","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"34f7583aa6e3efb2","x":1010,"y":360,"wires":[]},{"id":"7cbba0526b248c01","type":"mqtt out","z":"f1939796.abade8","g":"bc7b222d14ec9ee9","name":"tele/seneye/ph","topic":"tele/seneye/ph","qos":"","retain":"false","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"34f7583aa6e3efb2","x":1000,"y":400,"wires":[]},{"id":"ecf391724ee899ab","type":"mqtt out","z":"f1939796.abade8","g":"bc7b222d14ec9ee9","name":"tele/seneye/nh3","topic":"tele/seneye/nh3","qos":"","retain":"false","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"34f7583aa6e3efb2","x":1000,"y":440,"wires":[]},{"id":"34f7583aa6e3efb2","type":"mqtt-broker","name":"core-mosquitto: 1883 192.168.2.40","broker":"core-mosquitto","port":"1883","clientid":"","autoConnect":true,"usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"autoUnsubscribe":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"userProps":"","sessionExpiry":""},{"id":"8398c7612b911d52","type":"group","z":"f1939796.abade8","g":"097aa92b38953411","name":"Sensor Output Node Red Companion","style":{"label":true},"nodes":["bd9204ad849dace5","c9135df4c206d7de","cfca1a0c59f4efb8","32261c4eaf51df0a","13f7473191f64493"],"x":594,"y":239,"w":252,"h":242},{"id":"bd9204ad849dace5","type":"ha-sensor","z":"f1939796.abade8","g":"8398c7612b911d52","name":"Seneye Temperature","entityConfig":"f9f3b6aeb2d49d08","version":0,"state":"payload","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":720,"y":280,"wires":[[]],"server":"Select_Your_Server"},{"id":"c9135df4c206d7de","type":"ha-sensor","z":"f1939796.abade8","g":"8398c7612b911d52","name":"Seneye pH","entityConfig":"a352104e4fa8fbca","version":0,"state":"payload","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":690,"y":320,"wires":[[]],"server":"Select_Your_Server"},{"id":"cfca1a0c59f4efb8","type":"ha-sensor","z":"f1939796.abade8","g":"8398c7612b911d52","name":"Seneye NH3","entityConfig":"a17420f2dde5b686","version":0,"state":"payload","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":690,"y":400,"wires":[[]],"server":"Select_Your_Server"},{"id":"32261c4eaf51df0a","type":"ha-sensor","z":"f1939796.abade8","g":"8398c7612b911d52","name":"Seneye ORP","entityConfig":"e12640e89ea0c86b","version":0,"state":"payload","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":690,"y":360,"wires":[[]],"server":"Select_Your_Server"},{"id":"13f7473191f64493","type":"ha-sensor","z":"f1939796.abade8","g":"8398c7612b911d52","name":"Seneye NH4","entityConfig":"3c013944355a91a8","version":0,"state":"payload","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":690,"y":440,"wires":[[]],"server":"Select_Your_Server"},{"id":"f9f3b6aeb2d49d08","type":"ha-entity-config","server":"Select_Your_Server","deviceConfig":"371510540596ad0d","name":"Seneye Temperature","version":"6","entityType":"sensor","haConfig":[{"property":"name","value":"Seneye Temperature"},{"property":"icon","value":"mdi:thermometer"},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":"temperature"},{"property":"unit_of_measurement","value":"°C"},{"property":"state_class","value":"measurement"}],"resend":true,"debugEnabled":false},{"id":"a352104e4fa8fbca","type":"ha-entity-config","server":"Select_Your_Server","deviceConfig":"a37ac1a20a75d8b8","name":"Seneye pH","version":"6","entityType":"sensor","haConfig":[{"property":"name","value":"Seneye pH"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":"potential_hydrogen"},{"property":"unit_of_measurement","value":"pH"},{"property":"state_class","value":"measurement"}],"resend":true,"debugEnabled":false},{"id":"a17420f2dde5b686","type":"ha-entity-config","server":"Select_Your_Server","deviceConfig":"d2821b3dea19909c","name":"Seneye NH3","version":"6","entityType":"sensor","haConfig":[{"property":"name","value":"Seneye Ammonia"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""},{"property":"unit_of_measurement","value":"ppm"},{"property":"state_class","value":"measurement"}],"resend":true,"debugEnabled":false},{"id":"e12640e89ea0c86b","type":"ha-entity-config","server":"Select_Your_Server","deviceConfig":"9f95cf7c12bccc84","name":"Seneye ORP","version":6,"entityType":"sensor","haConfig":[{"property":"name","value":"Seneye ORP"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""},{"property":"unit_of_measurement","value":"mV"},{"property":"state_class","value":"measurement"}],"resend":true,"debugEnabled":false},{"id":"3c013944355a91a8","type":"ha-entity-config","server":"Select_Your_Server","deviceConfig":"1d19b28a31ebd95a","name":"Seneye NH4","version":6,"entityType":"sensor","haConfig":[{"property":"name","value":"Seneye NH4"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""},{"property":"unit_of_measurement","value":"ppb"},{"property":"state_class","value":"measurement"}],"resend":true,"debugEnabled":false},{"id":"371510540596ad0d","type":"ha-device-config","name":"Seneye Temperature","hwVersion":"","manufacturer":"Node-RED","model":"Seneye","swVersion":"","server":"Select_Your_Server"},{"id":"a37ac1a20a75d8b8","type":"ha-device-config","name":"Seneye pH","hwVersion":"","manufacturer":"Node-RED","model":"Seneye","swVersion":"","server":"Select_Your_Server"},{"id":"d2821b3dea19909c","type":"ha-device-config","name":"Seneye NH3","hwVersion":"","manufacturer":"Node-RED","model":"Seneye","swVersion":"","server":"Select_Your_Server"},{"id":"9f95cf7c12bccc84","type":"ha-device-config","name":"Seneye ORP","hwVersion":"","manufacturer":"Node-RED","model":"Seneye","swVersion":"","server":"Select_Your_Server"},{"id":"1d19b28a31ebd95a","type":"ha-device-config","name":"Seneye NH4","hwVersion":"","manufacturer":"Node-RED","model":"Seneye","swVersion":"","server":"Select_Your_Server"},{"id":"c2248a7503069b40","type":"ha-entity-config","server":"Select_Your_Server","deviceConfig":"9046cab53ca274cb","name":"Seneye Last Reading","version":"6","entityType":"sensor","haConfig":[{"property":"name","value":"Seneye Last Reading"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""},{"property":"unit_of_measurement","value":""},{"property":"state_class","value":""}],"resend":true,"debugEnabled":false},{"id":"8b4b6e6dde0731e4","type":"ha-entity-config","server":"Select_Your_Server","deviceConfig":"33b17011dd640a15","name":"Seneye Slide Expiry","version":"6","entityType":"sensor","haConfig":[{"property":"name","value":"Seneye Slide Expiry"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""},{"property":"unit_of_measurement","value":""},{"property":"state_class","value":""}],"resend":true,"debugEnabled":false},{"id":"9046cab53ca274cb","type":"ha-device-config","name":"Seneye Last Reading","hwVersion":"","manufacturer":"Node-RED","model":"Seneye","swVersion":"","server":"Select_Your_Server"},{"id":"33b17011dd640a15","type":"ha-device-config","name":"Seneye Slide Expiry","hwVersion":"","manufacturer":"Node-RED","model":"Seneye Slide Expiry","swVersion":"","server":"Select_Your_Server"}]
Created 1 year ago
Rating: 5 1
  • change (x2)
  • function (x11)
  • http request (x1)
  • mqtt out (x5)
  • mqtt-broker (x1)
  • switch (x1)
  • group (x3)
  • ha-device-config (x7)
  • ha-entity-config (x7)
  • ha-sensor (x7)
  • moment (x2)
  • seneye
  • homeassistant
  • api
  • sws
  • seneye-sws
  • webserver
  • aquarium
  • ph
  • temperature
  • orp
  • nh3
  • nh4
