NAD RECEIVER AMPLIFIER, RS232 TCP (ETHERNET) CONTROL & HOME ASSISTANT OUTPUT SENSORS.
Author: Andrew Hunter GitHub: MankiniChykan Date: 23/10/2024
PREREQUISITES
WHAT IT DOES
  • Send commands to NAD AV Receivers supporting a RS232 TCP interface.
  • Recieves commands from NAD AV Receivers supporting a RS232 TCP interface. (Used to pick up hardware remote)
  • Send outputs to Home Assistant Sensors.
  • Uses Logitech Harmony Hub to Trigger Flow.
  • Confirmed to work on NAD T787 & T785 with VM150X HDMI Expansion Module via RS232 port (Ethernet).
  • NOTE: NAD Receivers seem to not have a "Wake on LAN" function. The Logitech Harmony Hub is used to Turn ON the Receiver, so it can start receiving RS232 TCP Commands. Any alternative IR Blaster can be used to Turn ON the Receiver.
INSTRUCTIONS
  1. Modify "NAD T787 TCP REQUEST" node with your specific IP Address for your Receiver.
  2. Modify "NAD T787 TCP IN" node with your specific IP Address for your Receiver.
  3. Modify "Sensors to display in Dashboard" to suit your naming convention.
  4. Modify "Button controls for Firemote UI" to suit your naming convention.
  5. Modify "Harmony hub ON" trigger node to suit your IR blaster.
  6. If using Logitech Harmony Hub modify "NAD Power ON 5X" node and setup the server to point to your hub and commands.
DOWNLOADS FOR RS232 COMMANDS
Downloads Available Here
RS232 TXX7 Documents
RS232 TXX5 Documents
RS232 M15HD
RS232 C427 Documents
RS C368/C388 Documents
ORIGINAL AUTHOR
Original Author: Mike Thompson, GitHub: mike-linus Date: 10/8/2016
These examples show how to send commands to Pioneer AV Receivers supporting a TCP interface.
The sample inject commands are a small subset of the available commands. Please refer to the full command list available from here: https://www.pioneerelectronics.com/StaticFiles/Custom%20Install/RS-232%20Codes/Av%20Receivers/Elite%20&%20Pioneer%20FY13AVR%20IP%20&%20RS-232%205-8-12.xls
See Mike Thompson's for an example of sending compound commands via an inject or MQTT node.
To use the flows, modify the 'TCP Request' node to your specific IP address.
https://flows.nodered.org/flow/a51723feee29d5c45d9b2f213c2e3d3a
[{"id":"65394b852cb37b2c","type":"group","z":"fbc96b6cec386837","name":"RS232 TCP control of NAD Reciever & Sensor Outputs","style":{"label":true,"fill":"#dbcbe7","fill-opacity":"0.13","color":"#000000"},"nodes":["4b3e9c2c.bddb94","0772f8cd0bfea5af","b7c005c386bbbd1f","23b7cca66bdc177c","90282eb243d4350f","489bf7a6b704f5b7","5491a5cc3247ecc6","7218ec018178974f","0093d507c4fddf57"],"x":122,"y":127,"w":2270,"h":1366},{"id":"4b3e9c2c.bddb94","type":"comment","z":"fbc96b6cec386837","g":"65394b852cb37b2c","name":"Read Me: Notes (please retain these notes if distributing the flows)","info":"Author: Andrew Hunter GitHub: MankiniChykan\nDate: 23/10/2024\n\nThese examples show how to send commands to NAD AV Receivers supporting a RS232 TCP interface.\nConfirmed to work on NAD T787 & T785 with VM150X HDMI Expansion Module via RS232 port (Ethernet).\n\nDownloads available here.\nhttps://nadelectronics.com/product/t-787-av-surround-sound-receiver/\n\nRS232 TXX7 Documents\nhttps://nadelectronics.com/wp-content/uploads/2022/09/NAD_TXX7_Control_Docs.zip\n\nRS232 TXX5 Documents\nhttps://nadelectronics.com/support/code/NAD_TXX5_Control_Docs.zip\n\nRS232 M15HD\nhttps://nadelectronics.com/support/code/NAD_M15HD_Control_Docs.zip\n\nRS232 C427 Documents\nhttps://nadelectronics.com/wp-content/uploads/2022/09/NAD_TXX7_Control_Docs.zip\n\nRS C368/C388 Documents\nhttps://nadelectronics.com/wp-content/uploads/2022/09/NAD_TXX7_Control_Docs.zip\n\nOriginal Author: Mike Thompson, GitHub: mike-linus\nDate: 10/8/2016\n\nThese examples show how to send commands to Pioneer AV Receivers supporting a TCP interface.\n\nThe sample inject commands are a small subset of the available commands. Please refer to the full command list available from here:\nhttps://www.pioneerelectronics.com/StaticFiles/Custom%20Install/RS-232%20Codes/Av%20Receivers/Elite%20&%20Pioneer%20FY13AVR%20IP%20&%20RS-232%205-8-12.xls\n\nAn example of sending compound commands via an inject or MQTT node is also included.\n\nTo use the flows, modify the 'TCP Request' node to your specific IP address.\n","x":900,"y":180,"wires":[]},{"id":"0772f8cd0bfea5af","type":"group","z":"fbc96b6cec386837","g":"65394b852cb37b2c","name":"Harmony Hub ON activates RS232 TCP to NAD T787","style":{"label":true,"fill":"#ffbfbf","fill-opacity":"0.13","color":"#000000"},"nodes":["287aed0a9f319fdc","7541781c2476d7c4"],"x":148,"y":153,"w":504,"h":474},{"id":"287aed0a9f319fdc","type":"group","z":"fbc96b6cec386837","g":"0772f8cd0bfea5af","name":"Harmony Hub Trigger NAD T787 (Set Volume & Power)","style":{"label":true,"fill":"#ffefbf","fill-opacity":"0.13","color":"#000000"},"nodes":["11545dfe98e4e1cb","f55cbab09881845e","756a10c67d680d61","ddc8049fd1fd48e5"],"x":174,"y":179,"w":452,"h":202},{"id":"11545dfe98e4e1cb","type":"trigger-state","z":"fbc96b6cec386837","g":"287aed0a9f319fdc","name":"Harmony hub ON","server":"bb380e72.b8825","version":5,"inputs":0,"outputs":2,"exposeAsEntityConfig":"","entities":{"entity":["remote.harmony_hub"],"substring":[],"regex":[]},"debugEnabled":false,"constraints":[{"targetType":"this_entity","targetValue":"","propertyType":"current_state","propertyValue":"new_state.state","comparatorType":"is","comparatorValueDatatype":"str","comparatorValue":"on"}],"customOutputs":[],"outputInitially":true,"stateType":"str","enableInput":false,"x":280,"y":220,"wires":[["f55cbab09881845e","ddc8049fd1fd48e5"],[]]},{"id":"f55cbab09881845e","type":"api-current-state","z":"fbc96b6cec386837","g":"287aed0a9f319fdc","name":"Main.Volume=-40","server":"bb380e72.b8825","version":3,"outputs":2,"halt_if":"0","halt_if_type":"num","halt_if_compare":"gte","entity_id":"sensor.nad_t785_volume","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"Main.Volume=-40","valueType":"str"},{"property":"topic","propertyType":"msg","value":"Main.Volume","valueType":"str"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":290,"y":280,"wires":[["756a10c67d680d61","2d1afa7e.34cad6"],[]]},{"id":"756a10c67d680d61","type":"delay","z":"fbc96b6cec386837","g":"287aed0a9f319fdc","name":"","pauseType":"delay","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":300,"y":340,"wires":[["4fba4cf6ee34306c","2d1afa7e.34cad6"]]},{"id":"ddc8049fd1fd48e5","type":"H command","z":"fbc96b6cec386837","g":"287aed0a9f319fdc","name":"NAD Power ON 5X","server":"21dd4f96b9a6b12b","activity":"50718543","harmony_type":"dev","label":"NAD AV Receiver","command":"%7B%22command%22::%22PowerOn%22,%22type%22::%22IRCommand%22,%22deviceId%22::%2250718543%22%7D","repeat":"5","presstimestamp":0,"releasetimestamp":50,"delay":0,"x":510,"y":220,"wires":[[]]},{"id":"bb380e72.b8825","type":"server","name":"Home Assistant","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":"30","areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true},{"id":"21dd4f96b9a6b12b","type":"harmony-server","name":"Living Room Hub","ip":"192.168.1.252"},{"id":"7541781c2476d7c4","type":"group","z":"fbc96b6cec386837","g":"0772f8cd0bfea5af","name":"Harmony Hub Activity sets Listening Mode","style":{"label":true,"fill":"#e3f3d3","fill-opacity":"0.34","color":"#000000"},"nodes":["9e5e8fab5821a378","250c52edeb864a49","4fba4cf6ee34306c"],"x":174,"y":399,"w":270,"h":202},{"id":"9e5e8fab5821a378","type":"api-current-state","z":"fbc96b6cec386837","g":"7541781c2476d7c4","name":"Vinyl = PLIIMusic","server":"bb380e72.b8825","version":3,"outputs":2,"halt_if":"Play Vinyl","halt_if_type":"str","halt_if_compare":"is","entity_id":"select.harmony_hub_activities","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"Main.ListeningMode=PLIIMusic","valueType":"str"},{"property":"topic","propertyType":"msg","value":"Listening.Mode","valueType":"str"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":290,"y":500,"wires":[["2d1afa7e.34cad6"],[]]},{"id":"250c52edeb864a49","type":"api-current-state","z":"fbc96b6cec386837","g":"7541781c2476d7c4","name":"Shield = PLIIMovie","server":"bb380e72.b8825","version":3,"outputs":2,"halt_if":"SHIELD TV","halt_if_type":"str","halt_if_compare":"is","entity_id":"select.harmony_hub_activities","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"Main.ListeningMode=PLIIMovie","valueType":"str"},{"property":"topic","propertyType":"msg","value":"Listening.Mode","valueType":"str"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":290,"y":560,"wires":[["2d1afa7e.34cad6"],[]]},{"id":"4fba4cf6ee34306c","type":"delay","z":"fbc96b6cec386837","g":"7541781c2476d7c4","name":"","pauseType":"delay","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":260,"y":440,"wires":[["9e5e8fab5821a378","250c52edeb864a49"]]},{"id":"b7c005c386bbbd1f","type":"group","z":"fbc96b6cec386837","g":"65394b852cb37b2c","name":"Button controls for Firemote UI","style":{"label":true,"fill":"#bfbfbf","fill-opacity":"0.25","color":"#000000"},"nodes":["d35324cd68b04851","e24174de57516db2","4423c6e9b044b748"],"x":148,"y":653,"w":424,"h":494},{"id":"d35324cd68b04851","type":"group","z":"fbc96b6cec386837","g":"b7c005c386bbbd1f","name":"Button Scroll Listening Modes (Topic.Listening.Mode)","style":{"label":true,"fill":"#ffffbf","fill-opacity":"0.4","color":"#000000"},"nodes":["cfb0720377ee5968","b8c91b3dc465ea1d"],"x":174,"y":679,"w":338,"h":142},{"id":"cfb0720377ee5968","type":"ha-button","z":"fbc96b6cec386837","g":"d35324cd68b04851","name":"Harmony SurroundMode","version":0,"debugenabled":false,"outputs":1,"entityConfig":"dcb15db54ef8a925","outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"x":310,"y":720,"wires":[["b8c91b3dc465ea1d"]]},{"id":"b8c91b3dc465ea1d","type":"api-current-state","z":"fbc96b6cec386837","g":"d35324cd68b04851","name":"Scroll Listening Modes","server":"bb380e72.b8825","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"remote.harmony_hub","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"Main.ListeningMode+","valueType":"str"},{"property":"topic","propertyType":"msg","value":"Listening.Mode","valueType":"str"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":320,"y":780,"wires":[["2d1afa7e.34cad6"],[]]},{"id":"dcb15db54ef8a925","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"8b8753f0cbe85dea","name":"Harmony SurroundMode","version":"6","entityType":"button","haConfig":[{"property":"name","value":"Harmony SurroundMode"},{"property":"icon","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"8b8753f0cbe85dea","type":"ha-device-config","name":"Harmony SurroundMode","hwVersion":"","manufacturer":"Node-RED","model":"Harmony","swVersion":""},{"id":"e24174de57516db2","type":"group","z":"fbc96b6cec386837","g":"b7c005c386bbbd1f","name":"Volume Controls (Topic.Main.Volume)","style":{"label":true,"fill":"#ffffbf","fill-opacity":"0.4","color":"#000000"},"nodes":["e83edd8306202173","469c76a812933b6f"],"x":174,"y":839,"w":252,"h":142},{"id":"e83edd8306202173","type":"ha-button","z":"fbc96b6cec386837","g":"e24174de57516db2","name":"Harmony VolumeUp","version":0,"debugenabled":false,"outputs":1,"entityConfig":"1a9add5205a9b03a","outputProperties":[{"property":"payload","propertyType":"msg","value":"Main.Volume+","valueType":"str"},{"property":"topic","propertyType":"msg","value":"Main.Volume","valueType":"str"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"x":290,"y":880,"wires":[["2d1afa7e.34cad6"]]},{"id":"469c76a812933b6f","type":"ha-button","z":"fbc96b6cec386837","g":"e24174de57516db2","name":"Harmony VolumeDown","version":0,"debugenabled":false,"outputs":1,"entityConfig":"0a1b1fc1b2819349","outputProperties":[{"property":"payload","propertyType":"msg","value":"Main.Volume-","valueType":"str"},{"property":"topic","propertyType":"msg","value":"Main.Volume","valueType":"str"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"x":300,"y":940,"wires":[["2d1afa7e.34cad6"]]},{"id":"1a9add5205a9b03a","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"75d5123548c93cf7","name":"Harmony VolumeUp","version":"6","entityType":"button","haConfig":[{"property":"name","value":"Harmony VolumeUp"},{"property":"icon","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"0a1b1fc1b2819349","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"b4eb9deebcc2d3b3","name":"Harmony VolumeDown","version":"6","entityType":"button","haConfig":[{"property":"name","value":"Harmony VolumeDown"},{"property":"icon","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"75d5123548c93cf7","type":"ha-device-config","name":"Harmony VolumeUp","hwVersion":"","manufacturer":"Node-RED","model":"Harmony","swVersion":""},{"id":"b4eb9deebcc2d3b3","type":"ha-device-config","name":"Harmony VolumeDown","hwVersion":"","manufacturer":"Node-RED","model":"Harmony","swVersion":""},{"id":"4423c6e9b044b748","type":"group","z":"fbc96b6cec386837","g":"b7c005c386bbbd1f","name":"Mute ON/OFF (Topic.Main.Mute)","style":{"label":true,"fill":"#ffffbf","fill-opacity":"0.4","color":"#000000"},"nodes":["e4861b93efc23f23","d44ecdd0c21a4216","6a69154aa2571475"],"x":174,"y":999,"w":372,"h":122},{"id":"e4861b93efc23f23","type":"ha-switch","z":"fbc96b6cec386837","g":"4423c6e9b044b748","name":"NAD Mute Switch","version":0,"debugenabled":false,"inputs":0,"outputs":2,"entityConfig":"bca256b79d536ba2","enableInput":false,"outputOnStateChange":true,"outputProperties":[{"property":"outputType","propertyType":"msg","value":"state change","valueType":"str"},{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"}],"x":280,"y":1060,"wires":[["d44ecdd0c21a4216"],["6a69154aa2571475"]]},{"id":"d44ecdd0c21a4216","type":"api-current-state","z":"fbc96b6cec386837","g":"4423c6e9b044b748","name":"Mute ON","server":"bb380e72.b8825","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"remote.harmony_hub","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"Main.Mute=On","valueType":"str"},{"property":"topic","propertyType":"msg","value":"Main.Mute","valueType":"str"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":460,"y":1040,"wires":[["2d1afa7e.34cad6"],[]]},{"id":"6a69154aa2571475","type":"api-current-state","z":"fbc96b6cec386837","g":"4423c6e9b044b748","name":"Mute OFF","server":"bb380e72.b8825","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"remote.harmony_hub","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"Main.Mute=Off","valueType":"str"},{"property":"topic","propertyType":"msg","value":"Main.Mute","valueType":"str"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":460,"y":1080,"wires":[["2d1afa7e.34cad6"],[]]},{"id":"bca256b79d536ba2","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"9af2a779016b2225","name":"NAD Mute Switch","version":"6","entityType":"switch","haConfig":[{"property":"name","value":"NAD Mute Switch"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":"switch"}],"resend":false,"debugEnabled":false},{"id":"9af2a779016b2225","type":"ha-device-config","name":"NAD Mute Switch","hwVersion":"","manufacturer":"Node-RED","model":"NAD","swVersion":""},{"id":"23b7cca66bdc177c","type":"group","z":"fbc96b6cec386837","g":"65394b852cb37b2c","name":"Send RS232 TCP Command to NAD T787","style":{"label":true,"fill":"#e3f3d3","fill-opacity":"0.49","color":"#000000"},"nodes":["db2db8a6.4b9ab8","2d1afa7e.34cad6","44e8e69efb540552"],"x":694,"y":599,"w":292,"h":202},{"id":"db2db8a6.4b9ab8","type":"function","z":"fbc96b6cec386837","g":"23b7cca66bdc177c","name":"Convert to String","func":"msg.payload = msg.payload.toString();\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":810,"y":640,"wires":[["da39d83e0824189b","8a0079b7830687a8","8572509cf40324c8"]]},{"id":"2d1afa7e.34cad6","type":"function","z":"fbc96b6cec386837","g":"23b7cca66bdc177c","name":"Add <CR>","func":"msg.payload = msg.payload + '\\r';\n\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":790,"y":760,"wires":[["44e8e69efb540552"]]},{"id":"44e8e69efb540552","type":"tcp request","z":"fbc96b6cec386837","g":"23b7cca66bdc177c","name":"NAD T787 TCP REQUEST","server":"192.168.1.72","port":"23","out":"time","ret":"buffer","splitc":"27","newline":"","trim":false,"tls":"","x":840,"y":700,"wires":[["db2db8a6.4b9ab8"]]},{"id":"90282eb243d4350f","type":"group","z":"fbc96b6cec386837","g":"65394b852cb37b2c","name":"TEST COMMANDS","style":{"label":true,"stroke":"#000000","color":"#000000"},"nodes":["19050063.a654b","97a1b45d.37f998","aefb2255ac4b926e"],"x":594,"y":999,"w":332,"h":162},{"id":"19050063.a654b","type":"inject","z":"fbc96b6cec386837","g":"90282eb243d4350f","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":"","topic":"Main.Volume","payload":"Main.Volume=-40","payloadType":"str","x":770,"y":1120,"wires":[["2d1afa7e.34cad6"]]},{"id":"97a1b45d.37f998","type":"inject","z":"fbc96b6cec386837","g":"90282eb243d4350f","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":"","topic":"Listening.Mode","payload":"Main.Power=On","payloadType":"str","x":770,"y":1040,"wires":[["2d1afa7e.34cad6"]]},{"id":"aefb2255ac4b926e","type":"inject","z":"fbc96b6cec386837","g":"90282eb243d4350f","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":"","topic":"Main.Volume","payload":"Main.Volume=-30","payloadType":"str","x":770,"y":1080,"wires":[["2d1afa7e.34cad6"]]},{"id":"489bf7a6b704f5b7","type":"group","z":"fbc96b6cec386837","g":"65394b852cb37b2c","name":"Route Messages by Topic and Truncate T787 Return","style":{"label":true,"fill":"#ffffbf","fill-opacity":"0.44","color":"#000000"},"nodes":["c6912a5f937d496f","e2c7f6e3b8165e52","da39d83e0824189b","8a0079b7830687a8","32ab8a9ad3f1dfe3","8572509cf40324c8"],"x":1034,"y":519,"w":572,"h":282},{"id":"c6912a5f937d496f","type":"change","z":"fbc96b6cec386837","g":"489bf7a6b704f5b7","name":"Change: Truncate T787 Return L.M","rules":[{"t":"change","p":"payload","pt":"msg","from":"Main.Model=T785","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.ListeningMode=","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.ListeningMode=None","fromt":"str","to":"Stereo","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1420,"y":760,"wires":[["5f149bdea50d15b9"]]},{"id":"e2c7f6e3b8165e52","type":"change","z":"fbc96b6cec386837","g":"489bf7a6b704f5b7","name":"Change: Truncate T787 Return M.V","rules":[{"t":"change","p":"payload","pt":"msg","from":"Main.Model=T785","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.Volume=","fromt":"str","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1420,"y":560,"wires":[["d146fa0a94df2b9a"]]},{"id":"da39d83e0824189b","type":"switch","z":"fbc96b6cec386837","g":"489bf7a6b704f5b7","name":"Topic.Listening.Mode","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"Listening.Mode","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":1160,"y":760,"wires":[["c6912a5f937d496f"]]},{"id":"8a0079b7830687a8","type":"switch","z":"fbc96b6cec386837","g":"489bf7a6b704f5b7","name":"Topic.Main.Volume","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"Main.Volume","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":1150,"y":560,"wires":[["e2c7f6e3b8165e52"]]},{"id":"32ab8a9ad3f1dfe3","type":"change","z":"fbc96b6cec386837","g":"489bf7a6b704f5b7","name":"Change: Truncate T787 Return M.M","rules":[{"t":"change","p":"payload","pt":"msg","from":"Main.Mute=Off","fromt":"str","to":"Mute OFF","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.Mute=On","fromt":"str","to":"Mute ON","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.Model=T785","fromt":"str","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1430,"y":660,"wires":[["571d220fe0ce898b"]]},{"id":"8572509cf40324c8","type":"switch","z":"fbc96b6cec386837","g":"489bf7a6b704f5b7","name":"Topic.Main.Mute","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"Main.Mute","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":1140,"y":660,"wires":[["32ab8a9ad3f1dfe3"]]},{"id":"5491a5cc3247ecc6","type":"group","z":"fbc96b6cec386837","g":"65394b852cb37b2c","name":"Sensors to display in Dashboard","style":{"label":true,"fill":"#bfdbef","fill-opacity":"0.48","color":"#000000"},"nodes":["d146fa0a94df2b9a","94732dcd.d1cdd","5f149bdea50d15b9","571d220fe0ce898b"],"x":1894,"y":519,"w":472,"h":282},{"id":"d146fa0a94df2b9a","type":"ha-sensor","z":"fbc96b6cec386837","g":"5491a5cc3247ecc6","name":"NAD T785 Volume","entityConfig":"8666c94e87bb8bfb","version":0,"state":"payload","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":2010,"y":560,"wires":[[]]},{"id":"94732dcd.d1cdd","type":"debug","z":"fbc96b6cec386837","g":"5491a5cc3247ecc6","name":"NAD String Debug","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":2230,"y":660,"wires":[]},{"id":"5f149bdea50d15b9","type":"ha-sensor","z":"fbc96b6cec386837","g":"5491a5cc3247ecc6","name":"Listening Mode","entityConfig":"c9c6419647df159d","version":0,"state":"payload","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":2000,"y":760,"wires":[[]]},{"id":"571d220fe0ce898b","type":"ha-sensor","z":"fbc96b6cec386837","g":"5491a5cc3247ecc6","name":"Mute Mode","entityConfig":"1837e12fe90c78b3","version":0,"state":"payload","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":1990,"y":660,"wires":[[]]},{"id":"8666c94e87bb8bfb","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"71901729afb98c9f","name":"NAD T785 Volume","version":"6","entityType":"sensor","haConfig":[{"property":"name","value":"NAD T785 Volume"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":"diagnostic"},{"property":"device_class","value":"sound_pressure"},{"property":"unit_of_measurement","value":"dB"},{"property":"state_class","value":"measurement"}],"resend":false,"debugEnabled":false},{"id":"c9c6419647df159d","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"fecc85cf67da82e7","name":"Listening Mode","version":"6","entityType":"sensor","haConfig":[{"property":"name","value":"Listening Mode"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":"diagnostic"},{"property":"device_class","value":""},{"property":"unit_of_measurement","value":""},{"property":"state_class","value":""}],"resend":false,"debugEnabled":false},{"id":"1837e12fe90c78b3","type":"ha-entity-config","server":"bb380e72.b8825","deviceConfig":"cef06d4750464118","name":"Mute Mode","version":"6","entityType":"sensor","haConfig":[{"property":"name","value":"Mute Mode"},{"property":"icon","value":"mdi.earhearing"},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""},{"property":"unit_of_measurement","value":""},{"property":"state_class","value":""}],"resend":false,"debugEnabled":false},{"id":"71901729afb98c9f","type":"ha-device-config","name":"NAD T785 Volume","hwVersion":"","manufacturer":"Node-RED","model":"NAD","swVersion":""},{"id":"fecc85cf67da82e7","type":"ha-device-config","name":"Listening Mode","hwVersion":"","manufacturer":"Node-RED","model":"NAD","swVersion":""},{"id":"cef06d4750464118","type":"ha-device-config","name":"Mute Mode","hwVersion":"","manufacturer":"Node-RED","model":"NAD","swVersion":""},{"id":"7218ec018178974f","type":"group","z":"fbc96b6cec386837","g":"65394b852cb37b2c","name":"Only Sends to Sensor Value. No Commands can be sent to T787 when OFF.","style":{"label":true,"fill":"#ff0000","fill-opacity":"0.29","color":"#000000"},"nodes":["147f72abb4b4f815","c0526e3bf16efe08","0ad690c9cf0ede4b","e3d91ba7b78942fb","062226e9367c7e14","187471b6836fd71a"],"x":1114,"y":259,"w":483,"h":202},{"id":"147f72abb4b4f815","type":"trigger-state","z":"fbc96b6cec386837","g":"7218ec018178974f","name":"Harmony hub OFF","server":"bb380e72.b8825","version":5,"inputs":0,"outputs":2,"exposeAsEntityConfig":"","entities":{"entity":["remote.harmony_hub"],"substring":[],"regex":[]},"debugEnabled":false,"constraints":[{"targetType":"this_entity","targetValue":"","propertyType":"current_state","propertyValue":"new_state.state","comparatorType":"is","comparatorValueDatatype":"str","comparatorValue":"off"}],"customOutputs":[],"outputInitially":true,"stateType":"str","enableInput":false,"x":1230,"y":300,"wires":[["c0526e3bf16efe08"],[]]},{"id":"c0526e3bf16efe08","type":"api-current-state","z":"fbc96b6cec386837","g":"7218ec018178974f","name":"NAD Less than 0","server":"bb380e72.b8825","version":3,"outputs":2,"halt_if":"0","halt_if_type":"num","halt_if_compare":"lt","entity_id":"sensor.nad_t785_volume","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"0","valueType":"num"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"Main.Volume","valueType":"str"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1450,"y":300,"wires":[["d146fa0a94df2b9a"],[]]},{"id":"0ad690c9cf0ede4b","type":"trigger-state","z":"fbc96b6cec386837","g":"7218ec018178974f","name":"Volume unknown","server":"bb380e72.b8825","version":5,"inputs":0,"outputs":2,"exposeAsEntityConfig":"","entities":{"entity":["sensor.nad_t785_volume"],"substring":[],"regex":[]},"debugEnabled":false,"constraints":[{"targetType":"this_entity","targetValue":"","propertyType":"current_state","propertyValue":"new_state.state","comparatorType":"is","comparatorValueDatatype":"str","comparatorValue":"unknown"}],"customOutputs":[],"outputInitially":true,"stateType":"str","enableInput":false,"x":1220,"y":360,"wires":[["062226e9367c7e14"],[]]},{"id":"e3d91ba7b78942fb","type":"trigger-state","z":"fbc96b6cec386837","g":"7218ec018178974f","name":"Volume unavailable","server":"bb380e72.b8825","version":5,"inputs":0,"outputs":2,"exposeAsEntityConfig":"","entities":{"entity":["sensor.nad_t785_volume"],"substring":[],"regex":[]},"debugEnabled":false,"constraints":[{"targetType":"this_entity","targetValue":"","propertyType":"current_state","propertyValue":"new_state.state","comparatorType":"is","comparatorValueDatatype":"str","comparatorValue":"unavailable"}],"customOutputs":[],"outputInitially":true,"stateType":"str","enableInput":false,"x":1230,"y":420,"wires":[["187471b6836fd71a"],[]]},{"id":"062226e9367c7e14","type":"api-current-state","z":"fbc96b6cec386837","g":"7218ec018178974f","name":"NAD unknown","server":"bb380e72.b8825","version":3,"outputs":2,"halt_if":"unknown","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.nad_t785_volume","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"0","valueType":"num"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"Main.Volume","valueType":"str"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1440,"y":360,"wires":[["d146fa0a94df2b9a"],[]]},{"id":"187471b6836fd71a","type":"api-current-state","z":"fbc96b6cec386837","g":"7218ec018178974f","name":"NAD unavailable","server":"bb380e72.b8825","version":3,"outputs":2,"halt_if":"unavailable","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.nad_t785_volume","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"0","valueType":"num"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"Main.Volume","valueType":"str"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1450,"y":420,"wires":[["d146fa0a94df2b9a"],[]]},{"id":"0093d507c4fddf57","type":"group","z":"fbc96b6cec386837","g":"65394b852cb37b2c","name":"TCP Input from NAD T787","style":{"label":true,"fill":"#6f2fa0","color":"#000000"},"nodes":["e5480208e97befc6","1564ab296db50472","7c6f23e3b5171c30","392bbbabe3570f46","dbbb5502c05443a2"],"x":1034,"y":813,"w":778,"h":654},{"id":"e5480208e97befc6","type":"tcp in","z":"fbc96b6cec386837","g":"0093d507c4fddf57","name":"NAD T787 TCP IN","server":"client","host":"192.168.1.72","port":"23","datamode":"stream","datatype":"utf8","newline":"","topic":"Amplifier.TCP.Output","trim":false,"base64":false,"tls":"","x":1150,"y":1020,"wires":[["1564ab296db50472"]]},{"id":"1564ab296db50472","type":"function","z":"fbc96b6cec386837","g":"0093d507c4fddf57","name":"Convert to String","func":"msg.payload = msg.payload.toString();\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":1150,"y":1080,"wires":[["3b105abea7c52812","77e39ae5e322113f","2c6457774e38f7af"]]},{"id":"7c6f23e3b5171c30","type":"group","z":"fbc96b6cec386837","g":"0093d507c4fddf57","name":"Filter for Listening Mode","style":{"label":true},"nodes":["77e39ae5e322113f","b8d9af997a08fe3b","1b08af7dd1d79224","20c7723b56522a4b","d339396d646dc62a","98294dcf73c01944","552683a400fe13dc","2fa822832df656da","6f13776c31465681"],"x":1314,"y":1079,"w":472,"h":362},{"id":"77e39ae5e322113f","type":"change","z":"fbc96b6cec386837","g":"7c6f23e3b5171c30","name":"","rules":[{"t":"change","p":"payload","pt":"msg","from":"Main.Model=T785","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.Volume=","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"connection limit exceeded","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.ListeningMode=None","fromt":"str","to":"Stereo","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.ListeningMode.Dolby.Stereo=None","fromt":"str","to":"Stereo","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.ListeningMode=ProLogic","fromt":"str","to":"ProLogic","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.ListeningMode.Dolby.Stereo=ProLogic","fromt":"str","to":"ProLogic","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.ListeningMode.Dolby.Stereo=PLIIMusic","fromt":"str","to":"PLIIMusic","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.ListeningMode.Dolby.Stereo=PLIIMovie","fromt":"str","to":"PLIIMovie","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.Mute=Off","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.Mute=On","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.Volume.Min=-97","fromt":"str","to":"ProLogic","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.Volume.Min=-78","fromt":"str","to":"ProLogic","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.Audio.Lock=Yes","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.Audio.Channels=2/0.0","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.Audio.CODEC=DolbyDigitalPlus","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.Power=Off","fromt":"str","to":"0","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"off","fromt":"str","to":"0","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Unknown","fromt":"str","to":"1","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.ListeningMode=PLIIMusic","fromt":"str","to":"PLIIMusic","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.ListeningMode=PLIIMovie","fromt":"str","to":"PLIIMovie","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.ListeningMode.PCM.Stereo=PLIIMovie","fromt":"str","to":"PLIIMovie","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.ListeningMode.PCM.Stereo=PLIIMusic","fromt":"str","to":"PLIIMusic","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.Volume.Max=0","fromt":"str","to":"NEO6Cinema","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.ListeningMode.PCM.Stereo=NEO6Cinema","fromt":"str","to":"NEO6Cinema","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.ListeningMode.PCM.Stereo=NEO6Music","fromt":"str","to":"NEO6Music","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.ListeningMode.PCM.Stereo=EARS","fromt":"str","to":"EARS","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.Volume.Max=3","fromt":"str","to":"EARS","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.ListeningMode.PCM.Stereo=EnhancedStereo","fromt":"str","to":"EnhancedStereo","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.ListeningMode.PCM.Stereo=None","fromt":"str","to":"Stereo","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.ListeningMode=NEO6Cinema","fromt":"str","to":"NEO6Cinema","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.ListeningMode=NEO6Music","fromt":"str","to":"NEO6Music","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.ListeningMode=EARS","fromt":"str","to":"EARS","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.ListeningMode=EnhancedStereo","fromt":"str","to":"EnhancedStereo","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.ListeningMode.PCM.Stereo=ProLogic","fromt":"str","to":"ProLogic","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.Volume.Min=-98","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.Volume.Min=-99","fromt":"str","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1430,"y":1260,"wires":[["b8d9af997a08fe3b","1b08af7dd1d79224","20c7723b56522a4b","d339396d646dc62a","98294dcf73c01944","552683a400fe13dc","2fa822832df656da","6f13776c31465681"]]},{"id":"b8d9af997a08fe3b","type":"filter-filename","z":"fbc96b6cec386837","g":"7c6f23e3b5171c30","name":"PLlIMovie","filter":"PLIIMovie","ignorecase":true,"x":1700,"y":1120,"wires":[["5f149bdea50d15b9"]]},{"id":"1b08af7dd1d79224","type":"filter-filename","z":"fbc96b6cec386837","g":"7c6f23e3b5171c30","name":"PLIIMusic","filter":"PLIIMusic","ignorecase":true,"x":1700,"y":1160,"wires":[["5f149bdea50d15b9"]]},{"id":"20c7723b56522a4b","type":"filter-filename","z":"fbc96b6cec386837","g":"7c6f23e3b5171c30","name":"NEO6Cinema","filter":"NEO6Cinema","ignorecase":true,"x":1680,"y":1200,"wires":[["5f149bdea50d15b9"]]},{"id":"d339396d646dc62a","type":"filter-filename","z":"fbc96b6cec386837","g":"7c6f23e3b5171c30","name":"NEO6Music","filter":"NEO6Music","ignorecase":true,"x":1690,"y":1240,"wires":[["5f149bdea50d15b9"]]},{"id":"98294dcf73c01944","type":"filter-filename","z":"fbc96b6cec386837","g":"7c6f23e3b5171c30","name":"EARS","filter":"EARS","ignorecase":true,"x":1710,"y":1280,"wires":[["5f149bdea50d15b9"]]},{"id":"552683a400fe13dc","type":"filter-filename","z":"fbc96b6cec386837","g":"7c6f23e3b5171c30","name":"EnhancedStereo","filter":"EnhancedStereo","ignorecase":true,"x":1670,"y":1320,"wires":[["5f149bdea50d15b9"]]},{"id":"2fa822832df656da","type":"filter-filename","z":"fbc96b6cec386837","g":"7c6f23e3b5171c30","name":"Stereo","filter":"Stereo","ignorecase":true,"x":1710,"y":1360,"wires":[["5f149bdea50d15b9"]]},{"id":"6f13776c31465681","type":"filter-filename","z":"fbc96b6cec386837","g":"7c6f23e3b5171c30","name":"ProLogic","filter":"ProLogic","ignorecase":true,"x":1700,"y":1400,"wires":[["5f149bdea50d15b9"]]},{"id":"392bbbabe3570f46","type":"group","z":"fbc96b6cec386837","g":"0093d507c4fddf57","name":"Filter for Mute Mode","style":{"label":true},"nodes":["2c6457774e38f7af","97e9fa3c48239015","5bad55e743322b7f"],"x":1314,"y":939,"w":472,"h":122},{"id":"2c6457774e38f7af","type":"change","z":"fbc96b6cec386837","g":"392bbbabe3570f46","name":"","rules":[{"t":"change","p":"payload","pt":"msg","from":"Main.Model=T785","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.Volume=","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"connection limit exceeded","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.ListeningMode=None","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.ListeningMode.Dolby.Stereo=None","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.ListeningMode=ProLogic","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.ListeningMode.Dolby.Stereo=ProLogic","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.ListeningMode.Dolby.Stereo=PLIIMusic","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.ListeningMode.Dolby.Stereo=PLIIMovie","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.Mute=Off","fromt":"str","to":"Mute OFF","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.Mute=On","fromt":"str","to":"Mute ON","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.Volume.Min=-97","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.Volume.Min=-78","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main...","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.Audio.Lock=Yes","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.Audio.Channels=2/0.0","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.Audio.CODEC=DolbyDigitalPlus","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.Power=Off","fromt":"str","to":"0","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"off","fromt":"str","to":"0","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Unknown","fromt":"str","to":"1","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.ListeningMode=PLIIMusic","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.ListeningMode=PLIIMovie","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.ListeningMode.PCM.Stereo=PLIIMovie","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.ListeningMode.PCM.Stereo=PLIIMusic","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.Volume.Max=0","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.ListeningMode.PCM.Stereo=NEO6Cinema","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.ListeningMode.PCM.Stereo=NEO6Music","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.ListeningMode.PCM.Stereo=EARS","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.Volume.Max=3","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.ListeningMode.PCM.Stereo=EnhancedStereo","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.ListeningMode.PCM.Stereo=None","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.ListeningMode=NEO6Cinema","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.ListeningMode=NEO6Music","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.ListeningMode=EARS","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.ListeningMode=EnhancedStereo","fromt":"str","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1430,"y":1000,"wires":[["97e9fa3c48239015","5bad55e743322b7f"]]},{"id":"97e9fa3c48239015","type":"filter-filename","z":"fbc96b6cec386837","g":"392bbbabe3570f46","name":"Mute ON","filter":"Mute ON","ignorecase":true,"x":1700,"y":980,"wires":[["571d220fe0ce898b"]]},{"id":"5bad55e743322b7f","type":"filter-filename","z":"fbc96b6cec386837","g":"392bbbabe3570f46","name":"MuteOFF","filter":"Mute OFF","ignorecase":true,"x":1700,"y":1020,"wires":[["571d220fe0ce898b"]]},{"id":"dbbb5502c05443a2","type":"group","z":"fbc96b6cec386837","g":"0093d507c4fddf57","name":"Filter for Volume","style":{"label":true},"nodes":["3b105abea7c52812","7f1bb8ce1eecd64f"],"x":1314,"y":839,"w":472,"h":82},{"id":"3b105abea7c52812","type":"change","z":"fbc96b6cec386837","g":"dbbb5502c05443a2","name":"","rules":[{"t":"change","p":"payload","pt":"msg","from":"Main.Model=T785","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.Volume=","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"connection limit exceeded","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.ListeningMode=None","fromt":"str","to":"Stereo","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.ListeningMode.Dolby.Stereo=None","fromt":"str","to":"Stereo","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.ListeningMode=ProLogic","fromt":"str","to":"ProLogic","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.ListeningMode.Dolby.Stereo=ProLogic","fromt":"str","to":"ProLogic","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.ListeningMode.Dolby.Stereo=PLIIMusic","fromt":"str","to":"PLIIMusic","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.ListeningMode.Dolby.Stereo=PLIIMovie","fromt":"str","to":"PLIIMovie","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.Mute=Off","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.Mute=On","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.Volume.Min=-97","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.Volume.Min=-78","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.Audio.Lock=Yes","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.Audio.Channels=2/0.0","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.Audio.CODEC=DolbyDigitalPlus","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Main.Power=Off","fromt":"str","to":"0","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"off","fromt":"str","to":"0","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Unknown","fromt":"str","to":"1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1430,"y":880,"wires":[["7f1bb8ce1eecd64f"]]},{"id":"7f1bb8ce1eecd64f","type":"rbe","z":"fbc96b6cec386837","g":"dbbb5502c05443a2","name":"","func":"deadband","gap":"1.6%","start":"","inout":"out","septopics":false,"property":"payload","topi":"topic","x":1700,"y":880,"wires":[["d146fa0a94df2b9a"]]}]
Created 2 years, 3 months ago
Updated 2 years ago
Rating: 5 1
  • change (x6)
  • delay (x2)
  • function (x3)
  • inject (x3)
  • rbe (x1)
  • switch (x3)
  • tcp in (x1)
  • tcp request (x1)
  • NAD
  • Reciever
  • RS232
  • TCP
  • T787
  • T785
  • M15HD
  • TXX7
  • TXX5
  • C427
  • C368
  • C388
  • Remote
  • Control
  • Homeassistant
  • Amplifier
