node-red-contrib-sensibo-stream 0.0.13
Node-RED nodes for the Sensibo API v2 real-time Event Stream (Server-Sent Events)
npm install node-red-contrib-sensibo-stream
Node-RED nodes for the Sensibo API v2 Event Stream: real-time temperature/humidity measurements and AC state changes over Server-Sent Events, instead of polling.
  • One shared stream connection per account, with all of Sensibo's client rules built in
  • Every device's full state on start-up, so values are available immediately
  • Optional lookup of what caused an AC change (app, remote, Climate React, schedule…)
  • No runtime dependencies. Requires Node.js 18+ and Node-RED 3+
It works alongside node-red-contrib-sensibo (which uses the older REST polling) — the node types have different names, so both can be installed.
Contents
Node-RED flow library npm
The package is in the Node-RED flow library, so the easiest way is the palette manager:
  1. In the Node-RED editor open Menu → Manage palette → Install.
  2. Search for sensibo-stream and click install next to node-red-contrib-sensibo-stream.
  3. Reload the editor (Ctrl+Shift+R). The sensibo stream node appears under home automation.
Updates show up in the same place: Manage palette → Nodes offers an update button when a new version is out. After updating, restart Node-RED if prompted, then reload the editor.
From the command line
From your Node-RED user directory (often ~/.node-red, check User directory in the Node-RED start-up log), as the user Node-RED runs as:
Then restart Node-RED and reload the editor in the browser (Ctrl+Shift+R).
Always reload the editor after installing or upgrading. The editor loads node definitions only when the page loads, so a tab opened before the upgrade shows the old options and drops new settings when you deploy. See Troubleshooting.
Quick start
  1. Create an API key at https://home.sensibo.com/me/api. It is the same kind of key the older Sensibo packages use.
  2. Drag sensibo stream (palette category home automation) into a flow.
  3. Open it, click the pencil next to Account, paste the API key, click Add.
  4. Wire it to a debug node and deploy.
Within a few seconds you get one poll message per device with its full state, then live measurements and device messages as things change.
Examples: Menu → Import → Examples → node-red-contrib-sensibo-stream.
Account (sensibo-stream-account, config node)
Setting Default Meaning
API key Stored as a Node-RED credential.
Slow poll 15 min All devices are re-read at this interval because not every field has a stream event. Sensibo asks for ≥ 15 minutes. Polling continues at this rate while the stream is unavailable.
Re-read device on changed events on Fetch /pods/{id} after a changed event and emit a device message with the full new state.
Look up what caused AC state changes off See What caused a change. One extra API call per AC change.
All stream nodes using the same account share one connection — Sensibo allows at most 10 open streams per account, and one stream carries every device.
sensibo stream (sensibo-event-stream)
Setting Meaning
Account The account above.
Devices Blank for all, or comma-separated device ids to limit output.
Output Which message types to send (see below).
Attach cached device state Adds msg.device — the last known full state with stream measurements merged in.
Input — msg.payload = "reconnect" reopens the stream; any other message re-reads all devices and emits poll messages.
Output messages
Route them with a switch node on msg.event.
msg.event When msg.payload Default
measurements New readings — at most once a minute per device, only when a value changed; motion/presence instantly { id, measurements, podId? } on
device Full device re-read after a changed event full device object (as /pods/{id}) on
poll Start-up, every slow poll, or on input full device object on
changed Raw "something changed" notice { id, fields } on
hello Stream opened { version, heartbeatSeconds, pods } off
resync Server is closing the stream (reconnects automatically) {} off
AC settings are in msg.payload.acState on device and poll messages:
{ "on": true, "mode": "cool", "targetTemperature": 22, "temperatureUnit": "C",
  "fanLevel": "high", "swing": "fixedTop", "horizontalSwing": "fixedRight",
  "timestamp": { "time": "2026-11-22T05:35:22.091891Z", "secondsAgo": 0 } }
Other message properties:
Property Present on Meaning
topic all sensibo/<event>/<deviceId>
deviceId device events Device (or sensor) id
podId sensor measurements The device a room/window sensor belongs to
fields changed, device What changed, e.g. ["acState"]. Empty = anything may have changed (schedule, timer, Climate React)
reason poll, device Why the state was loaded: hello (stream opened), startup (stream unavailable at start-up), cached (only this node was redeployed), poll, refresh (input), changed
cause, change device What caused the AC change — see below
device when enabled Cached full device state
measurements messages only contain measurements. AC state only arrives in device and poll messages, so keep those enabled if you need it.
The stream itself only says that a device changed. Enable Look up what caused AC state changes on the account, and after each AC change the node also reads the latest entry of Sensibo's AC state history (/pods/{id}/acStates) and adds it to the device message:
  • msg.cause — the entry's reason, for example:
    msg.cause Typically means
    UserRequest Sensibo app, web app or API
    ExternalIrCommand The AC's own IR remote
    Trigger Climate React
    ScheduledCommand A Sensibo schedule or timer
  • msg.change — the whole history entry (e.g. reason, causedByUser, changedProperties, status, time).
Notes:
  • These history fields are not part of Sensibo's published API schema. They are passed through as Sensibo returns them; the list of values above is what has been observed, not an official list. Check msg.change in a debug node if you need other details.
  • Only AC state changes are looked up, so changes to e.g. connection status cost nothing extra.
  • The cause is only known for changes. poll messages and values loaded at start-up have none.
Recipes
Store the current state in global context
Wire this function node (0 outputs) after the stream node. Enable device, poll and measurements on the stream node, and the cause lookup on the account if you want lastChange. It is also in the store-state-in-global example.
// Keeps global "sensibo" up to date:
//   sensibo.<deviceId> and sensibo["<room name>"]
//     -> { id, name, acState, measurements, connected, lastChange, updated }
const all = global.get('sensibo') || {};
const id = msg.deviceId;
if (!id) return null;
const entry = all[id] || { id };
if (msg.event === 'device' || msg.event === 'poll') {
    const d = msg.payload;                         // full device from Sensibo
    entry.name = d.room ? d.room.name : entry.name;
    if (d.acState) entry.acState = d.acState;
    if (d.measurements) entry.measurements = Object.assign({}, entry.measurements, d.measurements);
    if (d.connectionStatus) entry.connected = d.connectionStatus.isAlive;
    if (msg.change) {                              // what caused this AC change
        const c = msg.change;
        entry.lastChange = {
            reason: msg.cause,
            causedBy: c.causedByUser ? (c.causedByUser.firstName || c.causedByUser.username) : null,
            changed: c.changedProperties,
            status: c.status,
            time: c.time ? c.time.time : new Date().toISOString()
        node.status({ text: `${entry.name || id}: ${msg.cause || '?'}` });
} else if (msg.event === 'measurements') {
    entry.measurements = Object.assign({}, entry.measurements, msg.payload.measurements);
} else {
    return null;
entry.updated = new Date().toISOString();
all[id] = entry;
if (entry.name) all[entry.name] = entry;           // also reachable by room name
global.set('sensibo', all);
return null;
No persistent context store is needed: the stream sends every device on start-up, so the context refills within seconds of a restart.
Room names are easier to read but change if you rename the room in the Sensibo app; device ids never change.
Read it elsewhere
  • change node: Set msg.payload to global sensibo["Bedroom"].acState
  • switch node: property global sensibo["Bedroom"].acState.on, rule is true
  • function node:
    msg.payload = global.get('sensibo')?.["Bedroom"]?.acState;   // undefined until loaded
  • To watch it change: the Context Data sidebar → Global → refresh.
acState.timestamp.secondsAgo is only accurate at the moment it arrived; use updated or acState.timestamp.time to judge age.
Control the AC
The stream is receive-only (Server-Sent Events are one-way); commands go through Sensibo's REST API. After a command, the stream reports the result as a changed → device message, which doubles as confirmation.
  • The sensibo send node from node-red-contrib-sensibo (msg.on, msg.mode, msg.targetTemperature, msg.fanlevel, msg.swing), or
  • an http request node: method POST, URL https://home.sensibo.com/api/v2/pods/<deviceId>/acStates?apiKey=<key>, body {"acState":{"on":true,"mode":"cool","targetTemperature":22}}.
For a single setting send just that field — a full acState overwrites all fields.
Node-RED's http request node does not use gzip, and Sensibo grants a higher rate limit to gzip clients. Avoid polling Sensibo with it; the stream node handles all reads with gzip.
Rate limiting your commands
Put a delay node (Rate Limit, All messages, e.g. 1 msg / 5 s) before whatever sends commands. For sliders or bursts where only the final value matters, use a trigger node as a debounce instead (send nothing, then the latest message after 3 s, extend delay if new message arrives).
The stream node's own traffic needs no limiting: one connection, slow poll ≥ 15 min, Retry-After respected, one re-read per change (bursts for the same device are coalesced).
How the connection behaves
Implements Sensibo's rules for clients:
  • Reconnects with exponential backoff plus jitter, capped at 5 minutes
  • On HTTP 429/503 waits at least Retry-After and keeps slow-polling meanwhile
  • Reconnects if nothing — not even a heartbeat — arrives for two heartbeat intervals
  • Reopens promptly after resync (Sensibo closes streams after some hours, or when the account's device list changes)
  • Fetches all devices right after hello, then every slow poll
  • gzip on every request; the API key goes in the X-Api-Key header for the stream and the documented apiKey query parameter for REST calls
  • An invalid key (HTTP 401/403) backs off straight to the maximum delay
Node status: green connected (N devices), yellow connecting / stream unavailable, polling, red auth failed or disconnected, retry in Ns.
Troubleshooting
A new setting is missing, or doesn't stick after deploy. The editor loads node definitions only when the page loads. After upgrading the package and restarting Node-RED, reload the editor (Ctrl+Shift+R). An editor tab opened before the upgrade keeps showing the old options and silently drops new settings when you deploy.
type_already_registered. Versions before 0.0.2 used node type names that clash with node-red-contrib-sensibo. Upgrade, then replace any old nodes in your flows.
No nodes in the palette. Look under home automation, or search the palette for "sensibo". Make sure you installed into the user directory of the Node-RED instance you are running (the start-up log shows it) and restarted it.
No values at start-up. Tick poll on the stream node. Nodes saved with an older version may have it unticked.
HTTP 401 on /users/me/pods. Fixed in 0.0.5 — upgrade.
API Limit exceeded. Use "Accept-Encoding: gzip"… Something is calling Sensibo without gzip — usually an http request node in your own flow, polling or in a loop. Let the stream node do the reads, and rate-limit your commands. Limits clear after a few minutes.
msg.cause is missing. Enable Look up what caused AC state changes on the account node (reload the editor first if you don't see it). It only appears on device messages after an AC state change.
"msg properties can no longer override set node properties". On an http request node, clear the URL field and set Method to set by msg.method if you set them from msg.
Development
npm test
Tests run against a local mock SSE/REST server (no network, no API key). To run the nodes inside Node-RED against a mock API, set SENSIBO_BASE_URL, e.g. SENSIBO_BASE_URL=http://127.0.0.1:18999/api/v2 node-red.
Releases are published to npm from GitHub Actions (trusted publishing) when a GitHub release is created; the release tag sets the version.
See CHANGELOG.md for changes.
See LICENSE.
Version: 0.0.13
Updated 14 hours ago
License: Unlicense
  • sensibo-stream-account
  • sensibo-event-stream
  • sensibo
  • air conditioner
  • sse
  • event stream
  • home automation
