node-red-contrib-sensibo 0.6.4
Communication nodes to Sensibo cloud
npm install node-red-contrib-sensibo
Node Red Sensibo Controller
Set of nodes for the Sensibo Sky air conditioning controllers.
https://sensibo.com/
This is a release of two nodes to communicate with the Sensibo Cloud.
  • Sensibo-in -> Either trigger or timer poll the cloud for measurements. Can also retrieve full config of the node
  • Sensibo-send -> Send commands to the cloud.
Once the API key is set up there is automatic pod discovery of available pods for configuration (no need to look up pod IDs), though it will store the ID after lookup.
Requirements
  • Node-RED 3.0 or newer
  • Node.js 18 or newer
Recent Updates
  • 0.6.x – Package modernised. The HTTP layer was refactored onto a single node-fetch helper with proper error handling, so failed requests now surface a meaningful message on the node and via catch/done instead of failing silently. The Sensibo API key is now stored as a Node-RED credential (encrypted, password field) rather than plain text in the flow. ESLint flat config and GitHub Actions CI were also added.
  • 0.5.0 – Removed the deprecated request module and its promise dependencies; all calls moved to node-fetch. Also fixed binary vs string true/false handling when calling the send node. Existing users need to force an upgrade.
The way messages go in and out of the nodes is unchanged, to keep compatibility with existing flows.
In your Node-RED user directory, typically ~/.node-red, run:
Then restart Node-RED, e.g.:
sudo systemctl restart nodered.service
Support / Issues
Please log any issues, feature requests on Github. All feedback is appreciated.
Development
Before publishing a new release, run:
npm run check
This runs both linting and the automated test suite. npm publish now also runs the same check automatically via prepublishOnly.
  • Lookup of available pods via room name.
  • User defined polling of temperature and humidity from cloud (min 60 seconds)
  • Option to retrieve all device information
  • Option to retrieve the current AC State
  • API key stored as an encrypted Node-RED credential
  • Clear error reporting on the node status and via msg / done when a request fails
  • Example flows provided to show the various deployments. Help pages also well populated.
Device Information
While there are many common options each device type has additional supported options. To find the full range of option you can configure the Sensibo mode to retrieve the full configuration in the msg.payload. The examples provided has a nifty flow to show you the various modes you pod supports.
Good stuff is here from a call to get config: msg.result.remoteCapabilities.modes.heat.fanLevels
Change Log / Roadmap
The nodes work very well so far and now updated there is no major roadmap ahead unless requested. The changelog file has detailed information on the various releases
Credits:
LukeGT The latest version (0.5.0 onwards no longer uses any of the code from LukeGT due to the deprecation of his work this remains as a credit to the original work.
Version: 0.6.4
Updated 2 months, 2 weeks ago
Rating: 4.0 2
37 in the last week
  • sensibo-config
  • sensibo in
  • sensibo send
  • sensibo
