node-red-camunda8 2.0.2
Camunda 8 nodes for Node-RED
npm install node-red-camunda8
node-red-camunda8
Compatible with: Camunda Platform 8.2+
npm
This module leverages the official Camunda 8 SDK to bring comprehensive Camunda 8 process automation capabilities to Node-RED!
This package provides 19 nodes for complete Camunda 8 integration, built on the official @camunda8/sdk for security and ongoing support.
Security and Best Practices
This package follows Node-RED and FlowFuse best practices for security and maintainability:
  • Input Validation: All nodes validate input payloads and required fields
  • Error Handling: Comprehensive error handling with proper context
  • Resource Management: Proper cleanup of workers and connections
  • Security: See SECURITY.md for detailed security considerations
  • Migration: See MIGRATION.md for dependency migration notes
Learn more about how these nodes can be used from basic example flows.
worker / complete
task-worker and complete node
Creates a task worker and subscribes to specific tasks/jobs. The worker node outputs a Node-RED message for each newly received task/job. When a Node-RED message is received at the complete nodes's input, that task/job gets completed in Zeebe (with either success, failure or error).
Please note: These nodes only work in combination. Make sure, the complete object from the worker node output payload gets injected into the input of the complete node.
See example flow.
message
publish-message node
This node publishes a message to Zeebe, when a Node-RED message is received at the input.
The message must contain a name and a correlation key. Optionally you can pass in variables and configuration options like timeToLive.
See example flow.
start message
publish-start-message node
This node publishes a start message to Zeebe, when a Node-RED message is received at the input.
The message must contain a name, no correlation key needed. Optionally you can pass in variables and configuration options like timeToLive.
See example flow.
process
deploy node
Inject a bpmn process definition string to the input of this node to deploy it to Zeebe.
You can use the 'file in' node from Node-RED to read a bpmn file from disk, or get the process definition from anywhere you want.
See example flow.
process instance
workflow-instance node
A new process instance gets started in Zeebe, when a Node-RED message is received at the input.
Once the process instance has been created, the output sends a Node-RED message containing some meta-info, i.e. the processInstanceKey.
See example flow.
Developing
To test these nodes locally in node-red, the npm install <folder> command can be used. This allows you to develop the node in a local directory and have it linked into a local node-red install during development.
In your node-red user directory, typically ~/.node-red, run:
npm install <path to location of node-red-camunda8>
This creates the appropriate symbolic link to the directory so that Node-RED will discover the node when it starts. Any changes to the node’s file can be picked up by simply restarting Node-RED.
Tests
Tests are written in Jest, and live in the __tests__ directory. To run the unit tests:
npm test
Integration tests are in the __tests__/integration.js file.
They require a Zeebe broker to run. You can start a dockerised broker:
cd resources/travis/
docker-compose up
And then run them manually:
npm run test:integration
Version: 2.0.2
Updated 1 year, 5 months ago
  • camunda
  • process-instance
  • task-worker
  • complete-task
  • message
  • start-message
  • deploy
  • cancel-process-instance
  • set-variables
  • broadcast-signal
  • evaluate-decision
  • create-process-instance-with-result
  • throw-error
  • operate-query
  • resolve-incident
  • topology
  • delete-resource
  • tasklist-query
  • modify-process-instance
  • camunda8
  • camunda
  • bpmn
  • workflow
  • process-automation
