Create Zeebe task worker
Creates a task worker and subscribes to specific tasks/jobs.
The worker node outputs a Node-RED message for each newly received task/job. When a Node-RED message is received at the complete nodes's input, that task/job gets completed in Zeebe (with either success or failure).
Please note: These nodes only work in combination. Make sure, the complete object from the worker node output payload gets injected into the input of the complete node.
[{"id":"8494146c.8a88d8","type":"task-worker","z":"b71ce72e.d756f8","name":"","maxActiveJobs":32,"timeout":1000,"x":250,"y":360,"wires":[["adc61cda.dd862"]]},{"id":"67eef6db.de8958","type":"complete-task","z":"b71ce72e.d756f8","name":"","x":640,"y":360,"wires":[]},{"id":"adc61cda.dd862","type":"function","z":"b71ce72e.d756f8","name":"do some work","func":"/**\n * Do some work here and make sure, the message\n * is routed to the 'complete' node.\n */\n\nreturn msg;","outputs":1,"noerr":0,"x":440,"y":360,"wires":[["67eef6db.de8958"]]}]
Created 7 years, 8 months ago
  • complete-task (x1)
  • task-worker (x1)
  • zeebe
  • bpmn
  • microservice
  • camunda
  • workflow
