Deploy workflow to Zeebe
Inject a bpmn workflow definition string to the input of the deploy node to deploy it to Zeebe.
You can use the 'file in' node from Node-RED to read a bpmn file from disk, or get the workflow definition from anywhere you want.
[{"id":"38ead71f.e78928","type":"deploy","z":"4fdab399.ad8454","name":"","zeebe":"","x":710,"y":340,"wires":[["ddbbfd58.f17f2"]]},{"id":"ec749d70.07711","type":"file in","z":"4fdab399.ad8454","name":"bpmn file","filename":"/path/to/workflow.bpmn","format":"utf8","chunk":false,"sendError":false,"encoding":"none","x":400,"y":340,"wires":[["f65be93a.5651c8"]]},{"id":"757de494.6c4784","type":"inject","z":"4fdab399.ad8454","name":"","topic":"","payload":"","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":250,"y":340,"wires":[["ec749d70.07711"]]},{"id":"f65be93a.5651c8","type":"change","z":"4fdab399.ad8454","name":"prepare","rules":[{"t":"move","p":"payload","pt":"msg","to":"payload.definition","tot":"msg"},{"t":"set","p":"payload.resourceName","pt":"msg","to":"workflow.bpmn","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":560,"y":340,"wires":[["38ead71f.e78928"]]},{"id":"ddbbfd58.f17f2","type":"debug","z":"4fdab399.ad8454","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":870,"y":340,"wires":[]}]
Created 7 years, 8 months ago
  • change (x1)
  • file in (x1)
  • deploy (x1)
  • zeebe
  • workflow
  • bpmn
  • microservice
  • camunda
