Sunsynk Logger
Flow for getting data from Sunsynk data logger platform to home assistant
[{"id":"8058a44447c9337f","type":"tab","label":"SunSynk Automation","disabled":false,"info":"","env":[]},{"id":"5b7d29d1d965a3ed","type":"function","z":"8058a44447c9337f","name":"Create Request for Setting Invertor Settings","func":"var sn = global.get(\"SS.Invertor1sn\");\nvar timeruse = parseInt(global.get(global.get(\"HA\") + '.states[\\'sensor.sunsynk_settings\\'].attributes.peakAndVallery'));\nvar ErrorCk = global.get(\"SS.ErrorCk\"); //Error types to check against \n\n//error checking\nif (ErrorCk.includes(sn)) { node.status(\"Undefined\"); return null }\nif (ErrorCk.includes(timeruse)) { node.status(\"Undefined\"); return null }\n\nif (timeruse === parseInt(msg.payload)) { node.status(\"No Action  Current:\" + timeruse + \"  Payload:\" + msg.payload) ; return null } else {}\nmsg.headers = global.get(\"SS.Header.Bearer\");\nmsg.url = global.get(\"SS.url.i1.set\");\n//msg.payload = \"{sn:2106054422,\"safetyType\":\"2\",\"battMode\":\"-1\",\"solarSell\":\"0\",\"pvMaxLimit\":\"8000\",\"energyMode\":\"1\",\"peakAndVallery\":\"0\",\"sysWorkMode\":\"1\",\"sellTime1\":\"00:00\",\"sellTime2\":\"04:00\",\"sellTime3\":\"09:00\",\"sellTime4\":\"15:00\",\"sellTime5\":\"22:00\",\"sellTime6\":\"23:00\",\"sellTime1Pac\":\"8000\",\"sellTime2Pac\":\"8000\",\"sellTime3Pac\":\"8000\",\"sellTime4Pac\":\"8000\",\"sellTime5Pac\":\"8000\",\"sellTime6Pac\":\"8000\",\"cap1\":\"50\",\"cap2\":\"40\",\"cap3\":\"30\",\"cap4\":\"90\",\"cap5\":\"70\",\"cap6\":\"60\",\"sellTime1Volt\":\"49\",\"sellTime2Volt\":\"49\",\"sellTime3Volt\":\"49\",\"sellTime4Volt\":\"49\",\"sellTime5Volt\":\"49\",\"sellTime6Volt\":\"49\",\"zeroExportPower\":\"20\",\"solarMaxSellPower\":\"9000\",\"mondayOn\":true,\"tuesdayOn\":true,\"wednesdayOn\":true,\"thursdayOn\":true,\"fridayOn\":true,\"saturdayOn\":true,\"sundayOn\":true,\"time1on\":true,\"time2on\":true,\"time3on\":true,\"time4on\":true,\"time5on\":true,\"time6on\":true,\"genTime1on\":true,\"genTime2on\":true,\"genTime3on\":true,\"genTime4on\":true,\"genTime5on\":true,\"genTime6on\":true}\"\nmsg.payload = { \"sn\": sn, \"peakAndVallery\": msg.payload }\nlet currdate = new Date(); node.status(msg.payload.peakAndVallery + \" - \" + currdate.toLocaleString());\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1270,"y":720,"wires":[["d2122f7768b26272","80f8fc1d444774db"]]},{"id":"e4a575d083ae578d","type":"http request","z":"8058a44447c9337f","name":"Set Invertor Settings","method":"POST","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[],"x":1880,"y":840,"wires":[["81f674df3194fdef","80f8fc1d444774db"]]},{"id":"2ba21a318ddc4a6a","type":"function","z":"8058a44447c9337f","name":"Check If Need to Put Into UPS Mode for Upcoming load shedding","func":"var origpayload = msg.payload;\nvar current = \"\";\nvar debugme = global.get(\"SunSynkDebug\");\nvar totalw = 3500 * 3; //total wattage of batteries\nvar wmin = 40 * 48 / 60; //watt.min charge Setting in invertor. Based on amps ( Inv Settinhsg )  * volts of battery / 60 minutes  \nvar soclow = 50; // default low end soc value \nvar sochigh = 60; // default high end soc value \nvar pt = 60; // default charge time \nvar pvtest = 2000; //value to test current pv against for some decisions \nvar LSTCheck = [\"clear-sky\", \"sunny\", \"partlycloudy\"]; //Weather types Used to decide if we need charge \nvar ErrorCk = global.get(\"SS.ErrorCk\"); //Error types to check against \nif (debugme === 1) { node.error(\"soclow:\" + soclow + \" sochigh:\" + sochigh + \" pt:\" + pt + \" pvtest:\" + pvtest + \" totalw:\" + totalw + \" wmin:\" + wmin) }\n\n// Overriding Critcal Check ---- Logger Status and Update \nvar loggerupd   = global.get(global.get(\"HA\") + '.states[\\'sensor.sunsynk_logger_last_update\\'].state');\nvar loggerstat = global.get(global.get(\"HA\") + '.states[\\'sensor.sunsynk_logger_status\\'].state');\nvar estatus = global.get(global.get(\"HA\") + '.states[\\'sensor.sunsynk_stats_last_update\\'].state');\nif (ErrorCk.includes(loggerupd))  { node.status(\"Undefined/Error\"); return null }\nif (ErrorCk.includes(loggerstat)) { node.status(\"Undefined/Error\"); return null }\nif (ErrorCk.includes(estatus)) { node.status(\"Undefined/Error\"); return null }\n// Bad Gather Data\nif (estatus.toString() === \"Invalid Date\") \n{ node.status(\" ERROR : Bad Gather Data \"); node.error(\" ERROR : Bad Gather Data \"); return null; } else \n{\n  var startdate = new Date(estatus);\n  var start = startdate.getTime();\n  var currentdate = new Date();\n  var currentt = currentdate.getTime();\n  var diff = currentt - start;\n  if (debugme === 1) { node.error(\"Status check\" + start + \" \" + currentt + \" \" + diff) }\n  if (diff > 180000) { node.error(\"Status last updated more than 3 minutes ago. Should be minimum less than a minute\"); return null }\n}\n// Logger last updated more than 3 minutes ago ?\nif (loggerupd.toString() === \"Invalid Date\") \n{ node.status(\" ERROR : Bad Last Logger Update \"); node.error(\" ERROR : Bad Last Logger Update \"); return null; } else\n{\n  var startdate = new Date(loggerupd);\n  var start = startdate.getTime();\n  var currentdate = new Date();\n  var currentt = currentdate.getTime();\n  var diff = currentt - start;\n  if (debugme === 1) { node.error(\"Date check\" + start + \" \" + currentt + \" \" + diff) }\n  if (diff > 180000) { node.error(\"Data last updated more than 3 minutes ago. Should be minimum less than a minute\"); return null }\n}\n//Logger Online ? \nif (debugme === 1) { node.error(\"Logger Status\" + loggerstat); }\nif (loggerstat === \"Online\") {} else\n{ node.status(\" ERROR : Logger Not Online : \" + loggerstat); node.error(\" ERROR : Logger Not Online : \"+ loggerstat ); return null; } \n\n// Custom variables\nvar lengthls = global.get(global.get(\"HA\") + '.states[\\'sensor.new_length_load_shedding\\'].state');\nvar timeleft = global.get(global.get(\"HA\") + '.states[\\'sensor.new_minutes_to_load_shedding\\'].state');\nvar timeruse = parseInt(global.get(global.get(\"HA\") + '.states[\\'sensor.sunsynk_settings\\'].attributes.peakAndVallery'));\nvar soc      = parseInt(global.get(global.get(\"HA\") + '.states[\\'sensor.sunsynk_battery\\'].attributes.soc'));\nvar pv1      = parseInt(global.get(global.get(\"HA\") + '.states[\\'sensor.sunsynk_input\\'].attributes.pv1'));\nvar pv2      = parseInt(global.get(global.get(\"HA\") + '.states[\\'sensor.sunsynk_input\\'].attributes.pv2'));\nvar pv       = parseInt(global.get(global.get(\"HA\") + '.states[\\'sensor.sunsynk_input\\'].attributes.pv'));\nvar gridv    = parseInt(global.get(global.get(\"HA\") + '.states[\\'sensor.sunsynk_grid\\'].attributes.volt'));\nvar override = global.get(global.get(\"HA\") + '.states[\\'input_boolean.enable_ups_manual_override\\'].state');\nif (debugme === 1) { node.error(\"lengthls:\" + lengthls + \" override:\" + override + \" gridv:\" + gridv + \" pv:\" + pv + \" pv1:\" + pv1 + \" pv2:\" + pv2 + \" timeleft:\" + timeleft + \" timeruse:\" + timeruse + \" soc:\" + soc) }\n\n\n// Error Checking\nif (ErrorCk.includes(lengthls))  { node.status(\"Undefined/Error\"); return null }\nif (ErrorCk.includes(timeleft))  { node.status(\"Undefined/Error\"); return null }\nif (ErrorCk.includes(timeruse))  { node.status(\"Undefined/Error\"); return null }\nif (ErrorCk.includes(soc))       { node.status(\"Undefined/Error\"); return null }\nif (ErrorCk.includes(pv1))       { node.status(\"Undefined/Error\"); return null }\nif (ErrorCk.includes(pv2))       { node.status(\"Undefined/Error\"); return null }\nif (ErrorCk.includes(pv))        { node.status(\"Undefined/Error\"); return null }\nif (ErrorCk.includes(gridv))     { node.status(\"Undefined/Error\"); return null }\nif (ErrorCk.includes(override))  { node.status(\"Undefined/Error\"); return null }\n\n// Drop out if No Load Shedding, enable Use Timer\nif (parseInt(lengthls) === 0 || parseInt(lengthls) === 99997) {\n  node.status(\"No Load Shedding Events Scheduled\");\n  msg.payload = \"1\";\n  return [msg, \"No Load Shedding Events Scheduled\"];\n}\n\n// Calculate Load shedding Params Based on time windows of load shedding\nvar lls = parseInt(lengthls);\nif (lls > 180) { pt = 120; soclow = 80; sochigh = 90 } // Longer than 2 hours load shedding\nif (lls > 240) { pt = 180; soclow = 85; sochigh = 95 } // Longer than 4 hours load shedding \nif (lls > 300) { pt = 240; soclow = 95; sochigh = 98 } // Longer than 5 hours load shedding\n\n// Check for Weather and Early Load Shedding\nvar CF = global.get(global.get(\"HA\") + '.states[\\'sensor.openweathermap_forecast_condition\\'].state');\nvar CC = global.get(global.get(\"HA\") + '.states[\\'sensor.openweathermap_condition\\'].state');\nvar LST = global.get(global.get(\"HA\") + '.states[\\'calendar.loadshedding_local_events\\'].attributes.start_time');\nif ((ErrorCk.includes(CF)) || (ErrorCk.includes(CC)) || (ErrorCk.includes(LST))) { node.error(\"CF/CC/LST undefined/error\")} else\n{\n  var LSTdate = new Date(global.get(global.get(\"HA\") + '.states[\\'calendar.loadshedding_local_events\\'].attributes.start_time'));\n  var LSThour = LSTdate.getHours();\n  if (debugme === 1) { node.error(\"CF:\" + CF + \" CC:\" + CC + \" LSTdate:\" + LSTdate.toLocaleString() + \" LSThour:\" + LSThour) }\n  if ((LSThour >= 7) && (LSThour <= 11) && (LSTCheck.includes(CF)) && (LSTCheck.includes(CC)) ) \n  { \n    // Based on good weather, no need for excessive battery charge even for long load shedding\n    pt = 30; soclow = 40; sochigh = 45; \n    current = current + \" EA_LS\";\n  } else \n  {\n    if ((soc <= soclow)) \n    // Calculate Variable charge time based on soc being lower than soc low threshhold \n    {\n      var minneeded = 0;\n      var soctemp = 0;\n      soctemp = sochigh - soc;\n      minneeded = (((soctemp / 100) * totalw) / wmin).toFixed(0);\n      current = current + \" wmin:\" + minneeded;\n      pt = minneeded;\n    } else { current = current + \" NoWmin\" }\n  }\n  // current = current + \" LSTH:\" + LSThour ;\n}\n\nif (debugme === 1) { node.error(\"pt after calc:\" + pt + \" soclow:\" + soclow + \" sochigh:\" + sochigh + \" pt:\" + pt + \" wmin:\" + wmin + \" lls:\" + lls) }\ncurrent = current + \" sl:\" + soclow + \" sh:\" + sochigh;\n\n// Setup Info for Status line \nif (parseInt(timeleft) <= pt) { current = current + \" TL\" }\nif (soc <= soclow) { current = current + \" SOC\" }\nif (pv <= pvtest) { current = current + \" PV\" }\nif (timeruse === 1) { current = current + \" TIMER\" }\n\n// If Override enabled dont calc, just disable use timer\nif (override === \"on\" ) {\n  // Override is enabled, disable USE TIMER\n  msg.payload = \"0\";\n  current = current + \" OVERRIDE - No Further Actions\";\n} else if (gridv <= 200) \n{ \n// There is no grid, enable USE TIMER\n  current = current + \" NOGRID\"; \n  msg.payload = \"1\";\n} else\n// Start soc checks \n{\n  msg.payload = \"1\";\n  //if Timeleft <= calculated time and soc < soclow and pv < test pv value \n  if ((parseInt(timeleft) <= pt) &&\n    (soc <= soclow) &&\n    (pv <= pvtest)) {\n    msg.payload = \"0\"\n  } else {\n    // If timeruse is allready disabled \n    if (timeruse === 0) {\n    // soc in state between soclow and sochigh - 50-60% example, dont renenable till soc high \n      if ((soc >= soclow) && (soc <= sochigh) && (pv <= pvtest)) {\n        current = current + \" Delay Reactivate\";\n        msg.payload = \"0\";\n      } else {\n        current = current + \" Reactivate\";\n        msg.payload = \"1\";\n      }\n    } else { current = current + \" No Action\"; msg.payload = \"1\"; }\n  }\n}\n// Setup status \ncurrent = current + \" soc:\" + soc + \" pt:\" + pt + \" t:\" + timeruse + \" pv:\" + pv + \" t:\" + timeleft + \" p:\" + msg.payload;\nnode.status(current);\nglobal.set(\"SS.currentcalcstatus\",current);\nvar msgstatus = {}; msgstatus.payload = {}; msgstatus.payload.state = current;\nreturn [msg, msgstatus];","outputs":2,"noerr":0,"initialize":"","finalize":"","libs":[],"x":800,"y":720,"wires":[["5b7d29d1d965a3ed","57f33094a9fea81d"],["094e24f7f9f4eb5b"]]},{"id":"81f674df3194fdef","type":"function","z":"8058a44447c9337f","name":"Set Status","func":"var origmsg = msg.payload;\nnode.status(origmsg.msg);\nmsg.payload = {};\nmsg.payload.state = origmsg.msg;\nreturn msg\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":2090,"y":840,"wires":[["9034a98cee7ec8c8"]]},{"id":"57f33094a9fea81d","type":"function","z":"8058a44447c9337f","name":"Check for Notification - UPS Change","func":"var timeruse = parseInt(global.get(global.get(\"HA\") + '.states[\\'sensor.sunsynk_settings\\'].attributes.peakAndVallery'));\nif (timeruse != undefined) { } else { node.status(\"Undef\");return null }\nif (timeruse === parseInt(msg.payload)) { node.status(msg.payload + ' No Action') ; return null } else {}\nlet currdate = new Date(); node.status(msg.payload + \" - \" + currdate.toLocaleString());\nif (parseInt(msg.payload) === 0 ) \n{\n   msg.payload = \n     { data: \n       {\n         title: \"Solar UPS Mode Enabled\",\n         message:\"UPS Mode Enabled\",\n         data:\n          {\n            tag: \"ups\",\n            sticky: \"true\",\n            color: \"red\",\n            channel: \"29PtaRd\"\n          }       \n       }\n     } ;\n} else\n{\n  msg.payload =\n  {\n    data:\n    {\n      title: \"Solar UPS Mode Disabled\",\n      message: \"UPS Mode Disabled\",\n      data:\n      {\n        tag: \"ups\",\n        sticky: \"true\",\n        color: \"red\",\n        channel: \"29PtaRd\"\n      }       \n    }\n  };\n}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1250,"y":660,"wires":[["eb571a0a10c64e8f"]]},{"id":"eb571a0a10c64e8f","type":"api-call-service","z":"8058a44447c9337f","name":"Send to Gary","server":"49784c25.476704","version":5,"debugenabled":false,"domain":"notify","service":"mobile_app_gary_note_9","areaId":[],"deviceId":[],"entityId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1630,"y":660,"wires":[[]]},{"id":"431cc9134896f5dd","type":"server-state-changed","z":"8058a44447c9337f","name":"Grid State Change","server":"49784c25.476704","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.sunsynk_grid_online","entityidfiltertype":"exact","outputinitially":false,"state_type":"num","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"}],"x":930,"y":600,"wires":[["3998b016e59d18a2"]]},{"id":"3998b016e59d18a2","type":"function","z":"8058a44447c9337f","name":"Check for Notification - Grid Change","func":"node.status(msg.payload);\nif (parseInt(msg.payload) === 0 ) \n{\n   msg.payload = \n     { data: \n       {\n         title: \"Grid Disconnected\",\n         message: \"Grid has been disconneced\",\n         data : \n           {\n            tag: \"grid\",\n            sticky: \"true\",\n            color: \"red\",\n            channel: \"29PtaRd\"\n           }\n       }\n     } ;\n} else\n{\n  msg.payload =\n  {\n    data:\n    {\n      title: \"Grid Connected\",\n      message: \"Grid has been connected\",\n      data:\n      {\n        tag: \"grid\",\n        sticky: \"true\",\n        color: \"red\",\n        channel: \"29PtaRd\"\n      }\n    }\n  };\n}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1250,"y":600,"wires":[["eb571a0a10c64e8f","14fb6a4702b8b44c"]]},{"id":"14fb6a4702b8b44c","type":"api-call-service","z":"8058a44447c9337f","name":"Send to Tinus","server":"49784c25.476704","version":5,"debugenabled":false,"domain":"notify","service":"mobile_app_sm_n986b","areaId":[],"deviceId":[],"entityId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1640,"y":600,"wires":[[]]},{"id":"c1864f058f9521d7","type":"inject","z":"8058a44447c9337f","name":"Inject","props":[],"repeat":"45","crontab":"","once":true,"onceDelay":"20","topic":"","x":190,"y":720,"wires":[["539a99f6c7f7d9c3","f79c2dc4aeb080f0","425a72a811c00bdb"]]},{"id":"539a99f6c7f7d9c3","type":"delay","z":"8058a44447c9337f","name":"","pauseType":"rate","timeout":"60","timeoutUnits":"seconds","rate":"1","nbRateUnits":"30","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":true,"allowrate":false,"outputs":1,"x":400,"y":720,"wires":[["2ba21a318ddc4a6a"]]},{"id":"c5c9bd45f83c9c04","type":"server-state-changed","z":"8058a44447c9337f","name":"Check Battery","server":"49784c25.476704","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.sunsynk_battery","entityidfiltertype":"exact","outputinitially":false,"state_type":"num","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":170,"y":780,"wires":[["539a99f6c7f7d9c3","425a72a811c00bdb"]]},{"id":"f28b6ef5451ecbec","type":"server-state-changed","z":"8058a44447c9337f","name":"Check PV","server":"49784c25.476704","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.sunsynk_input","entityidfiltertype":"exact","outputinitially":false,"state_type":"num","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":180,"y":840,"wires":[["539a99f6c7f7d9c3","425a72a811c00bdb"]]},{"id":"beb6beea7da5cdf1","type":"server-state-changed","z":"8058a44447c9337f","name":"Check Grid","server":"49784c25.476704","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.sunsynk_grid","entityidfiltertype":"exact","outputinitially":false,"state_type":"num","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":180,"y":900,"wires":[["539a99f6c7f7d9c3","425a72a811c00bdb"]]},{"id":"2c4be0172c0ab9e2","type":"server-state-changed","z":"8058a44447c9337f","name":"Check Load","server":"49784c25.476704","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.sunsynk_load","entityidfiltertype":"exact","outputinitially":false,"state_type":"num","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":170,"y":960,"wires":[["539a99f6c7f7d9c3","425a72a811c00bdb"]]},{"id":"dc4e070bcce3acdf","type":"server-state-changed","z":"8058a44447c9337f","name":"Check LE Eta","server":"49784c25.476704","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.new_minutes_to_load_shedding","entityidfiltertype":"exact","outputinitially":false,"state_type":"num","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":170,"y":1020,"wires":[["539a99f6c7f7d9c3","425a72a811c00bdb"]]},{"id":"7c59f9044e31cf5a","type":"server-state-changed","z":"8058a44447c9337f","name":"Check LS Length","server":"49784c25.476704","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.new_length_load_shedding","entityidfiltertype":"exact","outputinitially":false,"state_type":"num","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":160,"y":1080,"wires":[["539a99f6c7f7d9c3","425a72a811c00bdb"]]},{"id":"f79c2dc4aeb080f0","type":"api-current-state","z":"8058a44447c9337f","name":"SE Push Calendar","server":"49784c25.476704","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"calendar.loadshedding_local_events","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"$entity().attributes","valueType":"jsonata"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":430,"y":340,"wires":[["b901da7832a87289","13b88f03eea09f15"]]},{"id":"b901da7832a87289","type":"function","z":"8058a44447c9337f","name":"Start Time","func":"var origmsg = msg.payload;\nif (origmsg.start_time != undefined) {\n    var startdate = new Date(origmsg.start_time);\n    var start = startdate.getTime();\n    var currentdate = new Date();\n    var current = currentdate.getTime();\n    var diff = start - current;\n    msg.payload = parseInt((diff / 1000 / 60).toFixed(1));\n    node.status(startdate.toLocaleString());\n    if ( msg.payload <= 0 ) { msg.payload = 99999 } else { }\n//    if ( msg.state === \"on\" ) { msg.payload = 99998 } else { }\n} else {\n    msg.payload = 99997;\n    node.status(\"No Events\");\n}\n//if (origmsg.next_start_time != undefined) {\n//    msg.payload = (parseInt(msg.payload.starts_in));\n//    if ( msg.payload <= 0 ) { msg.payload = 99999 } else { }\n//    if ( origmsg.state === \"on\" ) { msg.payload = 99998 } else { }\n//    node.status(origmsg.last_update);\n//} else {\n//    msg.payload = 99997;\n//    node.status(\"No Events\");\n//}\nvar temp = msg.payload;\nmsg.payload = {};\nmsg.payload.state = temp;\nreturn msg;\n\n// Error States \n// 99997 - No new event \n// 99998 - Current Event Running \n// 99999 - Start time has passed ","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":650,"y":340,"wires":[["27ad4453b30a2d6e"]]},{"id":"13b88f03eea09f15","type":"function","z":"8058a44447c9337f","name":"Load Shedding Length","func":"var origmsg = msg.payload;\nmsg.payload = 0;\nif ((origmsg.start_time != undefined ) && (origmsg.end_time != undefined) ) {\n    var startdate = new Date(origmsg.start_time);\n    var start = startdate.getTime();\n    var enddate = new Date(origmsg.end_time);\n    var end = enddate.getTime();\n    var diff = end - start;\n    if ( diff <= 0 ) { diff = 1 } \n    msg.payload = parseInt((diff / 1000 / 60).toFixed(1));\n    // add 60 min due to se being 2 hours instead of 3 hours \n    msg.payload = msg.payload + 60;\n    node.status(startdate.toLocaleString());\n} else {\n    msg.payload = 0;\n    node.status(\"No Events\");\n}\n//if ((origmsg.next_start_time != undefined) && (origmsg.next_end_time != undefined)) {\n//    var startdate = new Date(origmsg.next_start_time);\n//    var start = startdate.getTime();\n//    var enddate = new Date(origmsg.next_end_time);\n//    var end = enddate.getTime();\n//    var diff = end - start;\n//    if (diff <= 0) { diff = 1 }\n//    msg.payload = parseInt((diff / 1000 / 60).toFixed(1));\n//    // add 60 min due to se being 2 hours instead of 3 hours \n//    msg.payload = msg.payload + 60;\n//    node.status(startdate.toLocaleString());\n//} else {\n//    msg.payload = 0;\n//    node.status(\"No Events\");\n//}\nvar temp = msg.payload;\nmsg.payload = {};\nmsg.payload.state = temp;\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":680,"y":400,"wires":[["1cca7e715956c6e3"]]},{"id":"9c6bfeda14cd94bd","type":"function","z":"8058a44447c9337f","name":"Check Weather for Soc - cap2","func":"var debugme = global.get(\"SunSynkDebug\") ;\nvar origpayload = msg.payload;\nvar CF = global.get(global.get(\"HA\") + '.states[\\'sensor.openweathermap_forecast_condition\\'].state');\nvar CC = global.get(global.get(\"HA\") + '.states[\\'sensor.openweathermap_condition\\'].state');\nvar pv = parseInt(global.get(global.get(\"HA\") + '.states[\\'sensor.sunsynk_input\\'].attributes.pv'));\nvar currcap2 = global.get(global.get(\"HA\") + '.states[\\'sensor.sunsynk_settings\\'].attributes.cap2');\nvar tempset = \"30\"\nvar ErrorCk = global.get(\"SS.ErrorCk\"); //Error types to check against \nif (debugme === 1) { node.error(\"CC:\" + CC + \" CF:\" + CF + \" PV:\" + pv + \" Current Cap:\" + currcap2 + \",\" ) }\n\n// Overriding Critcal Check ---- Logger Status and Update \nvar loggerupd = global.get(global.get(\"HA\") + '.states[\\'sensor.sunsynk_logger_last_update\\'].state');\nvar loggerstat = global.get(global.get(\"HA\") + '.states[\\'sensor.sunsynk_logger_status\\'].state');\nvar estatus = global.get(global.get(\"HA\") + '.states[\\'sensor.sunsynk_stats_last_update\\'].state');\nif (ErrorCk.includes(loggerupd)) { node.status(\"Undefined/Error\"); return null }\nif (ErrorCk.includes(loggerstat)) { node.status(\"Undefined/Error\"); return null }\nif (ErrorCk.includes(estatus)) { node.status(\"Undefined/Error\"); return null }\n// Bad Gather Data\nif (estatus.toString() === \"Invalid Date\") { node.status(\" ERROR : Bad Gather Data \"); node.error(\" ERROR : Bad Gather Data \"); return null; } else {\n    var startdate = new Date(estatus);\n    var start = startdate.getTime();\n    var currentdate = new Date();\n    var currentt = currentdate.getTime();\n    var diff = currentt - start;\n    if (debugme === 1) { node.error(\"Status check\" + start + \" \" + currentt + \" \" + diff) }\n    if (diff > 180000) { node.error(\"Status last updated more than 3 minutes ago. Should be minimum less than a minute\"); return null }\n}\n// Logger last updated more than 3 minutes ago ?\nif (loggerupd.toString() === \"Invalid Date\") { node.status(\" ERROR : Bad Last Logger Update \"); node.error(\" ERROR : Bad Last Logger Update \"); return null; } else {\n    var startdate = new Date(loggerupd);\n    var start = startdate.getTime();\n    var currentdate = new Date();\n    var currentt = currentdate.getTime();\n    var diff = currentt - start;\n    if (debugme === 1) { node.error(\"Date check\" + start + \" \" + currentt + \" \" + diff) }\n    if (diff > 180000) { node.error(\"Data last updated more than 3 minutes ago. Should be minimum less than a minute\"); return null }\n}\n//Logger Online ? \nif (debugme === 1) { node.error(\"Logger Status\" + loggerstat); }\nif (loggerstat === \"Online\") { } else { node.status(\" ERROR : Logger Not Online : \" + loggerstat); node.error(\" ERROR : Logger Not Online : \" + loggerstat); return null; } \n \n\n// Error Checking\nif (ErrorCk.includes(CF)) { node.status(\"Undefined\"); return null }\nif (ErrorCk.includes(CC)) { node.status(\"Undefined\"); return null }\nif (ErrorCk.includes(pv)) { node.status(\"Undefined\"); return null }\nif (ErrorCk.includes(currcap2)) { node.status(\"Undefined\"); return null }\n\nvar tempset = \"30\"\nif ((CF === \"rainy\") || (CC === \"rainy\")) { tempset = \"50\" }\nif ((CF === \"hail\") || (CC === \"hail\")) { tempset = \"50\" }\nif ((CF === \"pouring\") || (CC === \"pouring\")) { tempset = \"50\" }\nif (CF === \"cloudy\") { tempset = \"40\" }\nif ((CF === \"partlycloudy\") && (CC === \"partlycloudy\")) { tempset = \"35\" }\n\nif ( tempset === currcap2 ) {\n    node.status(\"No Action - \" +  CC + \",\" + CF + \" --- \" + tempset );\n    return null;\n} else {\n    msg.payload = tempset;\n    node.status(\"Action - \" + CC + \",\" + CF + \" --- \" + tempset);\n    return msg;\n}\nnode.status(\" Why am I here ? \");\nreturn null;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":870,"y":1000,"wires":[["44d1d28658d0dc2e"]]},{"id":"44d1d28658d0dc2e","type":"function","z":"8058a44447c9337f","name":"Create Request for Setting Invertor Settings - cap2","func":"var sn = global.get(\"SS.Invertor1sn\");\nvar currcap2 = global.get(global.get(\"HA\") + '.states[\\'sensor.sunsynk_settings\\'].attributes.cap2');\nvar ErrorCk = global.get(\"SS.ErrorCk\"); //Error types to check against \n\n//error checking\nif (ErrorCk.includes(sn)) { node.status(\"Undefined\"); return null }\nif (ErrorCk.includes(currcap2)) { node.status(\"Undefined\"); return null }\nmsg.headers = global.get(\"SS.Header.Bearer\");\nmsg.url = global.get(\"SS.url.i1.set\");\n//msg.payload = \"{sn:2106054422,\"safetyType\":\"2\",\"battMode\":\"-1\",\"solarSell\":\"0\",\"pvMaxLimit\":\"8000\",\"energyMode\":\"1\",\"peakAndVallery\":\"0\",\"sysWorkMode\":\"1\",\"sellTime1\":\"00:00\",\"sellTime2\":\"04:00\",\"sellTime3\":\"09:00\",\"sellTime4\":\"15:00\",\"sellTime5\":\"22:00\",\"sellTime6\":\"23:00\",\"sellTime1Pac\":\"8000\",\"sellTime2Pac\":\"8000\",\"sellTime3Pac\":\"8000\",\"sellTime4Pac\":\"8000\",\"sellTime5Pac\":\"8000\",\"sellTime6Pac\":\"8000\",\"cap1\":\"50\",\"cap2\":\"40\",\"cap3\":\"30\",\"cap4\":\"90\",\"cap5\":\"70\",\"cap6\":\"60\",\"sellTime1Volt\":\"49\",\"sellTime2Volt\":\"49\",\"sellTime3Volt\":\"49\",\"sellTime4Volt\":\"49\",\"sellTime5Volt\":\"49\",\"sellTime6Volt\":\"49\",\"zeroExportPower\":\"20\",\"solarMaxSellPower\":\"9000\",\"mondayOn\":true,\"tuesdayOn\":true,\"wednesdayOn\":true,\"thursdayOn\":true,\"fridayOn\":true,\"saturdayOn\":true,\"sundayOn\":true,\"time1on\":true,\"time2on\":true,\"time3on\":true,\"time4on\":true,\"time5on\":true,\"time6on\":true,\"genTime1on\":true,\"genTime2on\":true,\"genTime3on\":true,\"genTime4on\":true,\"genTime5on\":true,\"genTime6on\":true}\"\nmsg.payload = { \"sn\": sn, \"cap2\": msg.payload }\nnode.status(\"Action Sent cap2 - \" + msg.payload.cap2 );\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1270,"y":1000,"wires":[["d2122f7768b26272"]]},{"id":"b90991eaa943e80f","type":"inject","z":"8058a44447c9337f","name":"Long Check","props":[],"repeat":"600","crontab":"","once":true,"onceDelay":"60","topic":"","x":530,"y":1000,"wires":[["9c6bfeda14cd94bd","2640734fc5630dae","ea90cbc4d7319b78"]]},{"id":"d2122f7768b26272","type":"api-current-state","z":"8058a44447c9337f","name":"Enable SunSynk Auto Mode","server":"49784c25.476704","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.enable_sunsynk_auto_mode","state_type":"str","blockInputOverrides":false,"outputProperties":[],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1640,"y":840,"wires":[["e4a575d083ae578d","80f8fc1d444774db"],[]]},{"id":"094e24f7f9f4eb5b","type":"hass-post","z":"8058a44447c9337f","endpoint":"bc1c0f273da7bbae","entityid":"sensor.new_sunsynk_override_result","name":"Sunsynk Override Result","x":1210,"y":780,"wires":[]},{"id":"9034a98cee7ec8c8","type":"hass-post","z":"8058a44447c9337f","endpoint":"bc1c0f273da7bbae","entityid":"sensor.new_sunsynk_update_status","name":"Sunsynk Update Status","x":2330,"y":840,"wires":[]},{"id":"27ad4453b30a2d6e","type":"hass-post","z":"8058a44447c9337f","endpoint":"bc1c0f273da7bbae","entityid":"sensor.new_minutes_to_load_shedding","name":"Minutes To Load Shedding","x":940,"y":340,"wires":[]},{"id":"1cca7e715956c6e3","type":"hass-post","z":"8058a44447c9337f","endpoint":"bc1c0f273da7bbae","entityid":"sensor.new_length_load_shedding","name":"Length Load Shedding","x":920,"y":400,"wires":[]},{"id":"2640734fc5630dae","type":"function","z":"8058a44447c9337f","name":"Check Weather for Soc - cap3","func":"var debugme = global.get(\"SunSynkDebug\") ;\nvar origpayload = msg.payload;\nvar CF = global.get(global.get(\"HA\") + '.states[\\'sensor.openweathermap_forecast_condition\\'].state');\nvar CC = global.get(global.get(\"HA\") + '.states[\\'sensor.openweathermap_condition\\'].state');\nvar pv = parseInt(global.get(global.get(\"HA\") + '.states[\\'sensor.sunsynk_input\\'].attributes.pv'));\nvar currcap3 = global.get(global.get(\"HA\") + '.states[\\'sensor.sunsynk_settings\\'].attributes.cap3');\nvar tempset = \"30\"\nvar ErrorCk = global.get(\"SS.ErrorCk\"); //Error types to check against \nif (debugme === 1) { node.error(\"CC:\" + CC + \" CF:\" + CF + \" PV:\" + pv + \" Current Cap:\" + currcap3 ) }\n\n// Overriding Critcal Check ---- Logger Status and Update \nvar loggerupd = global.get(global.get(\"HA\") + '.states[\\'sensor.sunsynk_logger_last_update\\'].state');\nvar loggerstat = global.get(global.get(\"HA\") + '.states[\\'sensor.sunsynk_logger_status\\'].state');\nvar estatus = global.get(global.get(\"HA\") + '.states[\\'sensor.sunsynk_stats_last_update\\'].state');\nif (ErrorCk.includes(loggerupd)) { node.status(\"Undefined/Error\"); return null }\nif (ErrorCk.includes(loggerstat)) { node.status(\"Undefined/Error\"); return null }\nif (ErrorCk.includes(estatus)) { node.status(\"Undefined/Error\"); return null }\n// Bad Gather Data\nif (estatus.toString() === \"Invalid Date\") { node.status(\" ERROR : Bad Gather Data \"); node.error(\" ERROR : Bad Gather Data \"); return null; } else {\n    var startdate = new Date(estatus);\n    var start = startdate.getTime();\n    var currentdate = new Date();\n    var currentt = currentdate.getTime();\n    var diff = currentt - start;\n    if (debugme === 1) { node.error(\"Status check\" + start + \" \" + currentt + \" \" + diff) }\n    if (diff > 180000) { node.error(\"Status last updated more than 3 minutes ago. Should be minimum less than a minute\"); return null }\n}\n// Logger last updated more than 3 minutes ago ?\nif (loggerupd.toString() === \"Invalid Date\") { node.status(\" ERROR : Bad Last Logger Update \"); node.error(\" ERROR : Bad Last Logger Update \"); return null; } else {\n    var startdate = new Date(loggerupd);\n    var start = startdate.getTime();\n    var currentdate = new Date();\n    var currentt = currentdate.getTime();\n    var diff = currentt - start;\n    if (debugme === 1) { node.error(\"Date check\" + start + \" \" + currentt + \" \" + diff) }\n    if (diff > 180000) { node.error(\"Data last updated more than 3 minutes ago. Should be minimum less than a minute\"); return null }\n}\n//Logger Online ? \nif (debugme === 1) { node.error(\"Logger Status\" + loggerstat); }\nif (loggerstat === \"Online\") { } else { node.status(\" ERROR : Logger Not Online : \" + loggerstat); node.error(\" ERROR : Logger Not Online : \" + loggerstat); return null; } \n\n// Error Checking\nif (ErrorCk.includes(CF)) { node.status(\"Undefined\"); return null }\nif (ErrorCk.includes(CC)) { node.status(\"Undefined\"); return null }\nif (ErrorCk.includes(pv)) { node.status(\"Undefined\"); return null }\nif (ErrorCk.includes(currcap3)) { node.status(\"Undefined\"); return null }\n\nvar tempset = \"30\"\nif ((CF === \"rainy\") || (CC === \"rainy\")) { tempset = \"50\" }\nif ((CF === \"hail\") || (CC === \"hail\")) { tempset = \"50\" }\nif ((CF === \"pouring\") || (CC === \"pouring\")) { tempset = \"50\" }\nif (CF === \"cloudy\") { tempset = \"40\" }\nif ((CF === \"partlycloudy\") && (CC === \"partlycloudy\")) { tempset = \"35\" }\nif ((CF === \"sunny\") || ( CF === \"clear-night\")) { tempset = \"25\" }\n\nif (tempset === currcap3)  {\n    node.status(\"No Action - \" +  CC + \",\" + CF + \" --- \" + tempset );\n    return null;\n} else {\n    msg.payload = tempset;\n    node.status(\"Action - \" + CC + \",\" + CF + \" --- \" + tempset);\n    return msg;\n}\nnode.status(\" Why am I here ? \");\nreturn null;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":870,"y":1080,"wires":[["f4ebfff1733f4299"]]},{"id":"f4ebfff1733f4299","type":"function","z":"8058a44447c9337f","name":"Create Request for Setting Invertor Settings - cap3","func":"var sn = global.get(\"SS.Invertor1sn\");\nvar currcap3 = global.get(global.get(\"HA\") + '.states[\\'sensor.sunsynk_settings\\'].attributes.cap3');\nvar ErrorCk = global.get(\"SS.ErrorCk\"); //Error types to check against \n\n//error checking\nif (ErrorCk.includes(sn)) { node.status(\"Undefined sn\"); return null }\nif (ErrorCk.includes(currcap3)) { node.status(\"Undefined cap3\"); return null }\nmsg.headers = global.get(\"SS.Header.Bearer\");\nmsg.url = global.get(\"SS.url.i1.set\");\n//msg.payload = \"{sn:2106054422,\"safetyType\":\"2\",\"battMode\":\"-1\",\"solarSell\":\"0\",\"pvMaxLimit\":\"8000\",\"energyMode\":\"1\",\"peakAndVallery\":\"0\",\"sysWorkMode\":\"1\",\"sellTime1\":\"00:00\",\"sellTime2\":\"04:00\",\"sellTime3\":\"09:00\",\"sellTime4\":\"15:00\",\"sellTime5\":\"22:00\",\"sellTime6\":\"23:00\",\"sellTime1Pac\":\"8000\",\"sellTime2Pac\":\"8000\",\"sellTime3Pac\":\"8000\",\"sellTime4Pac\":\"8000\",\"sellTime5Pac\":\"8000\",\"sellTime6Pac\":\"8000\",\"cap1\":\"50\",\"cap2\":\"40\",\"cap3\":\"30\",\"cap4\":\"90\",\"cap5\":\"70\",\"cap6\":\"60\",\"sellTime1Volt\":\"49\",\"sellTime2Volt\":\"49\",\"sellTime3Volt\":\"49\",\"sellTime4Volt\":\"49\",\"sellTime5Volt\":\"49\",\"sellTime6Volt\":\"49\",\"zeroExportPower\":\"20\",\"solarMaxSellPower\":\"9000\",\"mondayOn\":true,\"tuesdayOn\":true,\"wednesdayOn\":true,\"thursdayOn\":true,\"fridayOn\":true,\"saturdayOn\":true,\"sundayOn\":true,\"time1on\":true,\"time2on\":true,\"time3on\":true,\"time4on\":true,\"time5on\":true,\"time6on\":true,\"genTime1on\":true,\"genTime2on\":true,\"genTime3on\":true,\"genTime4on\":true,\"genTime5on\":true,\"genTime6on\":true}\"\nmsg.payload = { \"sn\": sn, \"cap3\": msg.payload }\nnode.status(\"Action Sent cap3 - \" + msg.payload.cap3);\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1270,"y":1080,"wires":[["d2122f7768b26272"]]},{"id":"ea90cbc4d7319b78","type":"function","z":"8058a44447c9337f","name":"Check Sunrise for Timeslot 3","func":"let options = { hour12: false , hour: \"2-digit\", minute: \"2-digit\" };\nvar debugme = global.get(\"SunSynkDebug\") ;\nvar origpayload = msg.payload;\nvar sunrise = new Date(global.get(global.get(\"HA\") + '.states[\\'sun.sun\\'].attributes.next_dawn'));\nvar time3 = global.get(global.get(\"HA\") + '.states[\\'sensor.sunsynk_settings\\'].attributes.sellTime3');\nvar ErrorCk = global.get(\"SS.ErrorCk\"); //Error types to check against \nif (debugme === 1) { node.error(\"time3:\" + time3 + \" sunrise:\" + sunrise.toLocaleString() ) }\n\n// Overriding Critcal Check ---- Logger Status and Update \nvar loggerupd = global.get(global.get(\"HA\") + '.states[\\'sensor.sunsynk_logger_last_update\\'].state');\nvar loggerstat = global.get(global.get(\"HA\") + '.states[\\'sensor.sunsynk_logger_status\\'].state');\nvar estatus = global.get(global.get(\"HA\") + '.states[\\'sensor.sunsynk_stats_last_update\\'].state');\nif (ErrorCk.includes(loggerupd)) { node.status(\"Undefined/Error\"); return null }\nif (ErrorCk.includes(loggerstat)) { node.status(\"Undefined/Error\"); return null }\nif (ErrorCk.includes(estatus)) { node.status(\"Undefined/Error\"); return null }\n// Bad Gather Data\nif (estatus.toString() === \"Invalid Date\") { node.status(\" ERROR : Bad Gather Data \"); node.error(\" ERROR : Bad Gather Data \"); return null; } else {\n    var startdate = new Date(estatus);\n    var start = startdate.getTime();\n    var currentdate = new Date();\n    var currentt = currentdate.getTime();\n    var diff = currentt - start;\n    if (debugme === 1) { node.error(\"Status check\" + start + \" \" + currentt + \" \" + diff) }\n    if (diff > 180000) { node.error(\"Status last updated more than 3 minutes ago. Should be minimum less than a minute\"); return null }\n}\n// Logger last updated more than 3 minutes ago ?\nif (loggerupd.toString() === \"Invalid Date\") { node.status(\" ERROR : Bad Last Logger Update \"); node.error(\" ERROR : Bad Last Logger Update \"); return null; } else {\n    var startdate = new Date(loggerupd);\n    var start = startdate.getTime();\n    var currentdate = new Date();\n    var currentt = currentdate.getTime();\n    var diff = currentt - start;\n    if (debugme === 1) { node.error(\"Date check\" + start + \" \" + currentt + \" \" + diff) }\n    if (diff > 180000) { node.error(\"Data last updated more than 3 minutes ago. Should be minimum less than a minute\"); return null }\n}\n//Logger Online ? \nif (debugme === 1) { node.error(\"Logger Status\" + loggerstat); }\nif (loggerstat === \"Online\") { } else { node.status(\" ERROR : Logger Not Online : \" + loggerstat); node.error(\" ERROR : Logger Not Online : \" + loggerstat); return null; } \n\n// Error Checking\nif (ErrorCk.includes(sunrise)) { node.status(\"Undefined\"); return null }\nif (ErrorCk.includes(time3)) { node.status(\"Undefined\"); return null }\n\nvar timetemp = sunrise.toLocaleTimeString(\"en-us\", options);\nif (debugme === 1) {node.error(\"timetemp:\" + timetemp)}\n\nif (timetemp === time3 )  {\n    node.status(\"No Action - \" +  time3 + \"  ---  \" + timetemp );\n    return null;\n} else {\n    msg.payload = timetemp;\n    node.status(\"Action - \" + time3 + \"  ---  \" + timetemp);\n    return msg;\n}\nnode.status(\" Why am I here ? \");\nreturn null;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":860,"y":1160,"wires":[["b64d6f4f8315ef87"]]},{"id":"b64d6f4f8315ef87","type":"function","z":"8058a44447c9337f","name":"Create Request for Setting Invertor Settings - timeslot3","func":"var time3 = global.get(global.get(\"HA\") + '.states[\\'sensor.sunsynk_settings\\'].attributes.sellTime3');\nvar sn = global.get(\"SS.Invertor1sn\");\nvar ErrorCk = global.get(\"SS.ErrorCk\"); //Error types to check against \n\n//error checking\nif (ErrorCk.includes(sn)) { node.status(\"Undefined\"); return null }\nif (ErrorCk.includes(time3)) { node.status(\"Undefined\"); return null }\n\nif (time3 === parseInt(msg.payload)) { node.status(\"No Action  Current:\" + time3 + \"  Payload:\" + msg.payload) ; return null } else {}\nmsg.headers = global.get(\"SS.Header.Bearer\");\nmsg.url = global.get(\"SS.url.i1.set\");\n//msg.payload = \"{sn:2106054422,\"safetyType\":\"2\",\"battMode\":\"-1\",\"solarSell\":\"0\",\"pvMaxLimit\":\"8000\",\"energyMode\":\"1\",\"peakAndVallery\":\"0\",\"sysWorkMode\":\"1\",\"sellTime1\":\"00:00\",\"sellTime2\":\"04:00\",\"sellTime3\":\"09:00\",\"sellTime4\":\"15:00\",\"sellTime5\":\"22:00\",\"sellTime6\":\"23:00\",\"sellTime1Pac\":\"8000\",\"sellTime2Pac\":\"8000\",\"sellTime3Pac\":\"8000\",\"sellTime4Pac\":\"8000\",\"sellTime5Pac\":\"8000\",\"sellTime6Pac\":\"8000\",\"cap1\":\"50\",\"cap2\":\"40\",\"cap3\":\"30\",\"cap4\":\"90\",\"cap5\":\"70\",\"cap6\":\"60\",\"sellTime1Volt\":\"49\",\"sellTime2Volt\":\"49\",\"sellTime3Volt\":\"49\",\"sellTime4Volt\":\"49\",\"sellTime5Volt\":\"49\",\"sellTime6Volt\":\"49\",\"zeroExportPower\":\"20\",\"solarMaxSellPower\":\"9000\",\"mondayOn\":true,\"tuesdayOn\":true,\"wednesdayOn\":true,\"thursdayOn\":true,\"fridayOn\":true,\"saturdayOn\":true,\"sundayOn\":true,\"time1on\":true,\"time2on\":true,\"time3on\":true,\"time4on\":true,\"time5on\":true,\"time6on\":true,\"genTime1on\":true,\"genTime2on\":true,\"genTime3on\":true,\"genTime4on\":true,\"genTime5on\":true,\"genTime6on\":true}\"\nmsg.payload = { \"sn\": sn, \"sellTime3\": msg.payload }\nnode.status(\"Action Sent sellTime3 - \" + msg.payload.sellTime3);\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1280,"y":1160,"wires":[["d2122f7768b26272"]]},{"id":"80f8fc1d444774db","type":"debug","z":"8058a44447c9337f","name":"Automation Debug Output","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1910,"y":720,"wires":[]},{"id":"3d33801b9e6abdb8","type":"function","z":"8058a44447c9337f","name":"Calculate Time Left Till 20%","func":"var origpayload = msg.payload;\nvar current = \"\";\nvar debugme = global.get(\"SunSynkDebug\");\nvar totalw = 3500 * 3; //total wattage of batteries\nvar socmin = 20; // Min Soc Value to Use for Calculations \nvar ErrorCk = global.get(\"SS.ErrorCk\"); //Error types to check against \nif (debugme === 1) { node.error(\"somin:\" + socmin + \" totalw:\" + totalw ) }\n\n// Overriding Critcal Check ---- Logger Status and Update \nvar loggerupd   = global.get(global.get(\"HA\") + '.states[\\'sensor.sunsynk_logger_last_update\\'].state');\nvar loggerstat = global.get(global.get(\"HA\") + '.states[\\'sensor.sunsynk_logger_status\\'].state');\nvar estatus = global.get(global.get(\"HA\") + '.states[\\'sensor.sunsynk_stats_last_update\\'].state');\nif (ErrorCk.includes(loggerupd))  { node.status(\"Undefined/Error\"); return null }\nif (ErrorCk.includes(loggerstat)) { node.status(\"Undefined/Error\"); return null }\nif (ErrorCk.includes(estatus)) { node.status(\"Undefined/Error\"); return null }\n// Bad Gather Data\nif (estatus.toString() === \"Invalid Date\") \n{ node.status(\" ERROR : Bad Gather Data \"); node.error(\" ERROR : Bad Gather Data \"); return null; } else \n{\n  var startdate = new Date(estatus);\n  var start = startdate.getTime();\n  var currentdate = new Date();\n  var currentt = currentdate.getTime();\n  var diff = currentt - start;\n  if (debugme === 1) { node.error(\"Status check\" + start + \" \" + currentt + \" \" + diff) }\n  if (diff > 180000) { node.error(\"Status last updated more than 3 minutes ago. Should be minimum less than a minute\"); return null }\n}\n// Logger last updated more than 3 minutes ago ?\nif (loggerupd.toString() === \"Invalid Date\") \n{ node.status(\" ERROR : Bad Last Logger Update \"); node.error(\" ERROR : Bad Last Logger Update \"); return null; } else\n{\n  var startdate = new Date(loggerupd);\n  var start = startdate.getTime();\n  var currentdate = new Date();\n  var currentt = currentdate.getTime();\n  var diff = currentt - start;\n  if (debugme === 1) { node.error(\"Date check\" + start + \" \" + currentt + \" \" + diff) }\n  if (diff > 180000) { node.error(\"Data last updated more than 3 minutes ago. Should be minimum less than a minute\"); return null }\n}\n//Logger Online ? \nif (debugme === 1) { node.error(\"Logger Status\" + loggerstat); }\nif (loggerstat === \"Online\") {} else\n{ node.status(\" ERROR : Logger Not Online : \" + loggerstat); node.error(\" ERROR : Logger Not Online : \"+ loggerstat ); return null; } \n\n// Custom variables\nvar soc = parseFloat(global.get(global.get(\"HA\") + '.states[\\'sensor.sunsynk_battery\\'].attributes.soc'));\nvar load = parseFloat(global.get(global.get(\"HA\") + '.states[\\'sensor.sunsynk_load\\'].attributes.power'));\nif (debugme === 1) { node.error(\"soc:\" + soc + \" load:\" + load) }\n\n\n// Error Checking\nif (ErrorCk.includes(soc))       { node.status(\"Undefined/Error\"); return null }\nif (ErrorCk.includes(load))       { node.status(\"Undefined/Error\"); return null }\n\nvar tminutes = (secondstemp / 60);\nvar thours = (secondstemp / (60 * 60));\nvar tthours = \"\";\nvar ttime = \"\";\n\nif ( soc < 20 )\n{ ttime = \"Battery Below \" + socmin +\"%\" } else \n{\n var secondstemp = 0;\n var soctemp = 0;\n secondstemp = ((((soc - socmin) / 100 * totalw) / (load + 60)) * 60 * 60);\n current = current + \" secondstemp:\" + secondstemp;\n var thours = parseInt((secondstemp / (60*60)));\n var tminutes = (secondstemp / 60) - (thours*60);\n var ttime =\"\";\n  if ((tminutes <= 1) && ( thours === 0)) \n { \n   ttime = \" Less than 1 Minute \" \n } else if ( thours === 0 )\n { \n   ttime = tminutes.toFixed(0) + \" Minutes Left\" ;\n } else \n {\n   ttime = thours + \" Hour(s) \" + tminutes.toFixed(0) + \" Minutes Left\";\n }\n}\n\n// Setup status \nnode.status(ttime);\nmsg.payload = {};\nmsg.payload.state = ttime; \nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":680,"y":840,"wires":[["739e194bf1a34532"]]},{"id":"739e194bf1a34532","type":"hass-post","z":"8058a44447c9337f","endpoint":"bc1c0f273da7bbae","entityid":"sensor.sunsynk_battery_depletion","name":"Battery Depletion Time","x":1100,"y":840,"wires":[]},{"id":"2f1bef6cc37e91b6","type":"function","z":"8058a44447c9337f","name":"Calculate Time Left Till 20% Current Battery Load","func":"var origpayload = msg.payload;\nvar current = \"\";\nvar debugme = global.get(\"SunSynkDebug\");\nvar totalw = 3500 * 3; //total wattage of batteries\nvar socmin = 20; // Min Soc Value to Use for Calculations \nvar ErrorCk = global.get(\"SS.ErrorCk\"); //Error types to check against \nif (debugme === 1) { node.error(\"somin:\" + socmin + \" totalw:\" + totalw ) }\n\n// Overriding Critcal Check ---- Logger Status and Update \nvar loggerupd   = global.get(global.get(\"HA\") + '.states[\\'sensor.sunsynk_logger_last_update\\'].state');\nvar loggerstat = global.get(global.get(\"HA\") + '.states[\\'sensor.sunsynk_logger_status\\'].state');\nvar estatus = global.get(global.get(\"HA\") + '.states[\\'sensor.sunsynk_stats_last_update\\'].state');\nif (ErrorCk.includes(loggerupd))  { node.status(\"Undefined/Error\"); return null }\nif (ErrorCk.includes(loggerstat)) { node.status(\"Undefined/Error\"); return null }\nif (ErrorCk.includes(estatus)) { node.status(\"Undefined/Error\"); return null }\n// Bad Gather Data\nif (estatus.toString() === \"Invalid Date\") \n{ node.status(\" ERROR : Bad Gather Data \"); node.error(\" ERROR : Bad Gather Data \"); return null; } else \n{\n  var startdate = new Date(estatus);\n  var start = startdate.getTime();\n  var currentdate = new Date();\n  var currentt = currentdate.getTime();\n  var diff = currentt - start;\n  if (debugme === 1) { node.error(\"Status check\" + start + \" \" + currentt + \" \" + diff) }\n  if (diff > 180000) { node.error(\"Status last updated more than 3 minutes ago. Should be minimum less than a minute\"); return null }\n}\n// Logger last updated more than 3 minutes ago ?\nif (loggerupd.toString() === \"Invalid Date\") \n{ node.status(\" ERROR : Bad Last Logger Update \"); node.error(\" ERROR : Bad Last Logger Update \"); return null; } else\n{\n  var startdate = new Date(loggerupd);\n  var start = startdate.getTime();\n  var currentdate = new Date();\n  var currentt = currentdate.getTime();\n  var diff = currentt - start;\n  if (debugme === 1) { node.error(\"Date check\" + start + \" \" + currentt + \" \" + diff) }\n  if (diff > 180000) { node.error(\"Data last updated more than 3 minutes ago. Should be minimum less than a minute\"); return null }\n}\n//Logger Online ? \nif (debugme === 1) { node.error(\"Logger Status\" + loggerstat); }\nif (loggerstat === \"Online\") {} else\n{ node.status(\" ERROR : Logger Not Online : \" + loggerstat); node.error(\" ERROR : Logger Not Online : \"+ loggerstat ); return null; } \n\n// Custom variables\nvar soc = parseFloat(global.get(global.get(\"HA\") + '.states[\\'sensor.sunsynk_battery\\'].attributes.soc'));\nvar load = parseFloat(global.get(global.get(\"HA\") + '.states[\\'sensor.sunsynk_battery\\'].attributes.power'));\nif (debugme === 1) { node.error(\"soc:\" + soc + \" load:\" + load) }\n\n\n// Error Checking\nif (ErrorCk.includes(soc))       { node.status(\"Undefined/Error\"); return null }\nif (ErrorCk.includes(load))       { node.status(\"Undefined/Error\"); return null }\n\nvar tminutes = (secondstemp / 60);\nvar thours = (secondstemp / (60 * 60));\nvar tthours = \"\";\nvar ttime = \"\";\n\nif ( soc < 20 ) { ttime = \"Battery Below \" + socmin +\"%\" } else \nif ( load < 0 ) { ttime = \" \"} else\nif ( load == 0) { ttime = \" \" } else\nif ( (load > 0) || ( load < 30 )) { ttime = \" \" } else\n{\n var secondstemp = 0;\n var soctemp = 0;\n secondstemp = ((((soc - socmin) / 100 * totalw) / ( load )) * 60 * 60);\n current = current + \" secondstemp:\" + secondstemp;\n var thours = parseInt((secondstemp / (60*60)));\n var tminutes = (secondstemp / 60) - (thours*60);\n var ttime =\"\";\n  if ((tminutes <= 1) && ( thours === 0)) \n { \n   ttime = \" Less than 1 Minute \" \n } else if ( thours === 0 )\n { \n   ttime = \" 0:\" + tminutes.toFixed(0) + \" Left\" ;\n } else \n {\n   ttime = thours + \":\" + tminutes.toFixed(0) + \" Left\";\n }\n}\n\n// Setup status \nnode.status(ttime);\nmsg.payload = {};\nmsg.payload.state = ttime; \nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":750,"y":900,"wires":[["a0449fa93a9eb188"]]},{"id":"a0449fa93a9eb188","type":"hass-post","z":"8058a44447c9337f","endpoint":"bc1c0f273da7bbae","entityid":"sensor.sunsynk_battery_depletion_load","name":"Battery Depletion Time Current Battery Load","x":1170,"y":900,"wires":[]},{"id":"425a72a811c00bdb","type":"delay","z":"8058a44447c9337f","name":"","pauseType":"rate","timeout":"60","timeoutUnits":"seconds","rate":"1","nbRateUnits":"5","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":true,"allowrate":false,"outputs":1,"x":400,"y":840,"wires":[["3d33801b9e6abdb8","2f1bef6cc37e91b6"]]},{"id":"49784c25.476704","type":"server","name":"Home Assistant","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30,"areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true},{"id":"bc1c0f273da7bbae","type":"hass-config","host":"http://localhost","port":"8123"}]
Created 2 years, 5 months ago
  • delay (x2)
  • function (x15)
  • http request (x1)
  • inject (x2)
