RFID Door Lock User & Access Management
This is a complete flow to manage multiple marelab RFID-DOOR or ESP-RFID opensource hard/software Door access controls over a Node-Red based home automatisation system. When you follow the tutrial here and configure the needed settings, you get a Web GUI with the following functionality. The hole communication is done over MQTT. The GUI can be also accessed over cell phone / tablett. Atm the focus was to get it feature complete and not fancy as hell. It is also possible to setup a selfmade board just using the ESP8266 for it use the schematic to see how
  • A ready to use marelab RFID-DOOR board or a pcb can be ordered here at the marlab.org webside.
  • The openhardware schematic & gerbers files and KiCad Project can be found at marelab RFID-DOOR
  • More detailed Instuctions to that flow can be found on the GitHub Project pages rfid-door-node-red The flow uses several additional Nodes that have to get installed to!
Features:
  • Central managment & administration GUI to manage device, users access
  • Central event and access store to visualize what happen when and on which device
  • Remote opening Door over GUI or voice with Google home or Alexa
GUI Overview
Dialog GUI to manage RFID devices
  • New Devices are added automatic after they sync over MQTT
  • The List starts with the device name as link to the device Gui
  • The IP Adress of the device
  • Del | Door open | Sync Users to device | Sync Users form device | Delete Device Button
Dialog GUI to manage Users of the devices
This list stores all users of all devices found by the rfid-door sync. If you press the bottom at the RFID Devices Tab "Sync Users form device" the rfid device sends all user data over MQTT to this List (Database). This list is a central DB based archive of all users from the devices. You can edit the User here for example rename or delete a user, but keep in mind until it is synced to the device this list is only persitent at the Database. To sync all devices with that list use the Sync Button at the end of the list. All Users get overwritten at the device, so the RFID device local stored list reflects the central stored DB List.
Dialog GUI to manage new Users
If you add new users to the system you got two ways. The one used over the Web Gui of the RFID device or over this tab. It woorks like that:
  • A unknown RFID chip is recognized by the reader
  • This RIFID information is send oover MQTT to this list to be further added too the system by the Administrator
  • You select the unknown RFID in that list
  • Add a name and the group for it
  • It will be stored in the central DB list and should show up under GUI to manage Users
  • Then you just need to sync the User List to the devices
after that the new User can open the door.
Dialog GUI to List events and access trys of the devices
If you enable logging over MQTT at the rfid devices this list gets filled like the list you can see at the local rfid devices. But keep in mind enabling MQTT logging disables local device logging. Its implemented like that to reduce the RFID device write cycles and to have a central logging space. Also in the central log you get the Door Name where the access or event happend. You can scroll the list by << >> Buttons, per page 10 entrys are shown the sort order is last entry at top first at the end.
Installation Instructions
This instruction is based on a Node-Red Installation for Rasberry PI but should also work on any Linux based system.
Basic prepareations
You need the following tools to get the flow running:
  • marelab rfid-door firmware
  • MySQL Database (stores devices, user & logs)
  • webserver and phpmyadmin
  • MQTT Server
Configure the marelab rfid-door device
To use this workflow you must enable & configure MQTT on every rfid device that should be managed by this flow. If you want the central logging functionality you need to enable it to on the rfid-device see the screenshot as exmaple:
Install the marelab rfid-door-node-red flow
The installation is very easy just download it and import it over the node-red functionality like shown here.
Configure the marelab rfid-door-node-red flow
After the flow is installed you need to configure some items of the flow. That can't be done automatic. Follow these steps to get it to work correct:
  • Import the database shema / tables into mysql use the SQL esp-door-install-DB.sql for that
  • enter the DB IP adress & user/password in one of the DB nodes all other will then use that info automatic
  • enter the MQTT Server IP adress user/password in the MQTT nodes
[{"id":"5da0880e.c537d","type":"tab","label":"RFID","disabled":false,"info":""},{"id":"6609ed16.bc3684","type":"mqtt in","z":"5da0880e.c537d","name":"","topic":"/devnfc/sync","qos":"2","datatype":"json","broker":"c264cdd5.9ebcc8","x":150,"y":900,"wires":[["8845710b.a83d1"]]},{"id":"f117dc63.eb4cd","type":"mqtt out","z":"5da0880e.c537d","name":"","topic":"/devnfc","qos":"2","retain":"false","broker":"c264cdd5.9ebcc8","x":220,"y":720,"wires":[]},{"id":"fbee6f99.1cca","type":"mqtt in","z":"5da0880e.c537d","name":"","topic":"/devnfc/accesslist","qos":"2","datatype":"json","broker":"c264cdd5.9ebcc8","x":160,"y":1020,"wires":[["6dd39820.eab9e8"]]},{"id":"e0f095d4.f88388","type":"mysql","z":"5da0880e.c537d","mydb":"833fda8f.b825a8","name":"esp-door","x":780,"y":1020,"wires":[["69c343cc.b2eedc"]]},{"id":"6dd39820.eab9e8","type":"json","z":"5da0880e.c537d","name":"JSON2OBJ","property":"payload","action":"obj","pretty":false,"x":370,"y":1020,"wires":[["bee5be3b.7e98f"]]},{"id":"bee5be3b.7e98f","type":"function","z":"5da0880e.c537d","name":"MakeMySQLinsert","func":"msg.topic = \"INSERT INTO users (uuid, user, acctype, validuntil) VALUES ('\"+msg.payload.uid+\"','\"+msg.payload.user+\"',\"+msg.payload.acctype+\",'\"+msg.payload.validuntil+\"')\";\nreturn msg;","outputs":1,"noerr":0,"x":570,"y":1020,"wires":[["e0f095d4.f88388"]]},{"id":"36748a74.8204a6","type":"mysql","z":"5da0880e.c537d","mydb":"833fda8f.b825a8","name":"esp-door","x":460,"y":780,"wires":[["cae0de7d.159e2"]]},{"id":"4c3c3ea0.e4f7c","type":"function","z":"5da0880e.c537d","name":"100 *ALL USERS","func":"msg.topic = \"SELECT * FROM users\";\nflow.set(\"doorip\", msg.payload.doorip);\nreturn msg;","outputs":1,"noerr":0,"x":250,"y":780,"wires":[["36748a74.8204a6"]]},{"id":"a05ffa44.6953f8","type":"function","z":"5da0880e.c537d","name":"IterateUsers","func":"var person = new Object();\nperson.cmd        = \"adduser\";\nperson.doorip     = flow.get(\"doorip\");\nperson.uid        = msg.payload.uuid;\nperson.user       = msg.payload.user;\nperson.acctype    = msg.payload.acctype;\nperson.validuntil = msg.payload.validuntil;\n\nmsg.payload = person;\n\nreturn msg;","outputs":1,"noerr":0,"x":850,"y":680,"wires":[["cae0de7d.159e2","45205e51.86309"]]},{"id":"cae0de7d.159e2","type":"Serial Iterator","z":"5da0880e.c537d","name":"USER ITER","property":"payload","inputFlow":"input","saveOutput":1,"recursive":0,"storeId":0,"x":670,"y":780,"wires":[["27bd83c9.c3fd3c"],[]]},{"id":"27bd83c9.c3fd3c","type":"delay","z":"5da0880e.c537d","name":"","pauseType":"delay","timeout":"200","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":880,"y":780,"wires":[["a05ffa44.6953f8"]]},{"id":"8845710b.a83d1","type":"function","z":"5da0880e.c537d","name":"SYNCtoDB","func":"\nif (msg.payload.type == \"heartbeat\")\n{\n    msg.topic = \"replace INTO readers (ip, doorname) VALUES ('\"+msg.payload.ip+\"','\"+msg.payload.door+\"');\";\n    return msg;\n}    \n\nmsg.payload = \" ???? \";\nreturn msg;","outputs":1,"noerr":0,"x":370,"y":900,"wires":[["5338b911.e89a68"]]},{"id":"5338b911.e89a68","type":"mysql","z":"5da0880e.c537d","mydb":"833fda8f.b825a8","name":"esp-door","x":580,"y":900,"wires":[["c4faea87.3efed8"]]},{"id":"77b03cfe.286384","type":"mqtt in","z":"5da0880e.c537d","name":"","topic":"/devnfc/send","qos":"2","datatype":"json","broker":"c264cdd5.9ebcc8","x":150,"y":1160,"wires":[["78d3b8cb.253d28"]]},{"id":"704e364f.e28c28","type":"function","z":"5da0880e.c537d","name":"10*Readers","func":"msg.topic = \"Select * from readers;\";\n\nreturn msg;\n\n","outputs":1,"noerr":0,"x":210,"y":100,"wires":[["cd9c0915.d9da08"]]},{"id":"cd9c0915.d9da08","type":"mysql","z":"5da0880e.c537d","mydb":"833fda8f.b825a8","name":"esp-door","x":380,"y":100,"wires":[["44ac504a.5324a","b23a5348.4cb","3030dbc.4b49c24"]]},{"id":"44ac504a.5324a","type":"ui_template","z":"5da0880e.c537d","group":"f74cd7d7.b7cdc8","name":"GUI READER LIST","order":1,"width":"12","height":"3","format":"<style>\n  a:link    {color: #ffffff;}\n  a:visited {color: #999999;}\n  a:hover   {color: #ff3300;} \n  \n  .md-button.black-text {\n    color: black;\n  }\n\n  /* Metal ------------------------- */\n  \n  .metal {\n    position: relative;\n    margin: auto;\n    \n    text-align: center;\n    color: hsla(0,0%,20%,1);\n    text-shadow:\n      hsla(0,0%,40%,.5) 0 -1px 0,\n      hsla(0,0%,100%,.6) 0 2px 1px;\n    \n    background-color: hsl(0,0%,90%);\n    box-shadow:\n      inset hsla(0,0%,15%,  1) 0  0px 0px 2px, /* border */\n      inset hsla(0,0%,15%, .8) 0 -1px 3px 2px, /* soft SD */\n      inset hsla(0,0%,0%, .25) 0 -1px 0px 3px, /* bottom SD */\n      inset hsla(0,0%,100%,.7) 0  2px 1px 3px, /* top HL */\n      \n      hsla(0,0%, 0%,.15) 0 -2px 3px 2px, /* outer SD */\n      hsla(0,0%,100%,.5) 0  2px 3px 2px; /* outer HL */ \n\n    transition: color .2s;\n  }\n  \n  /* Linear ------------------------- */\n\n  .metal.linear {\n    width: 40px;\n    height: 40px;\n    font-size: 1.2em;\n    border-radius: .5em;\n    background-image:\n      -webkit-repeating-linear-gradient(left, hsla(0,0%,100%,0) 0%, hsla(0,0%,100%,0)   6%, hsla(0,0%,100%, .1) 7.5%),\n      -webkit-repeating-linear-gradient(left, hsla(0,0%,  0%,0) 0%, hsla(0,0%,  0%,0)   4%, hsla(0,0%,  0%,.03) 4.5%),\n      -webkit-repeating-linear-gradient(left, hsla(0,0%,100%,0) 0%, hsla(0,0%,100%,0) 1.2%, hsla(0,0%,100%,.15) 2.2%),\n      \n      linear-gradient(180deg,\n      hsl(0,0%,78%)  0%, \n      hsl(0,0%,90%) 47%, \n      hsl(0,0%,78%) 53%,\n      hsl(0,0%,70%)100%);\n  }\n    \n  /* Wide ------------------------- */\n\n  .metal.wide {\n    width: 90px;\n    height: 40px;\n  }\n\n  /* active ------------------------- */\n\n  .metal:active {\n    color: hsl(210, 100%, 40%);\n    text-shadow:\n      hsla(210,100%,20%,.3) 0 -1px 0,\n      hsl(210,100%,85%) 0 2px 1px,\n      hsla(200,100%,80%,1) 0 0 5px,\n      hsla(210,100%,50%,.6) 0 0 20px;\n    box-shadow: \n      inset hsla(210,100%,30%,  1) 0  0px 0px 2px, /* border */\n      inset hsla(210,100%,15%, .4) 0 -1px 3px 2px, /* soft SD */\n      inset hsla(210,100%,20%,.25) 0 -1px 0px 3px, /* bottom SD */\n      inset hsla(210,100%,100%,.7) 0  2px 1px 3px, /* top HL */\n      \n      hsla(210,100%,75%, .8) 0  0px 3px 2px, /* outer SD */\n      hsla(210,50%,40%, .25) 0 -2px 3px 2px, /* outer SD */\n      hsla(210,80%,95%,   1) 0  2px 3px 2px; /* outer HL */\n  }   \n\n</style>\n\n<script>\n    scope.buttons = [{\n        icon: 'pause', color: 'black',\n        icon2: 'play_arrow', color2: 'red',\n        payload: 'play',\n    }, {\n        icon: 'alarm', color: 'black',\n        icon2: 'alarm', color2: 'red',\n        payload: 'alarm',\n    }];\n    \n    scope.click = function(b) {\n        var json = new Object();\n        json.cmd = 'opendoor';\n        json.ip  = b;\n        //this.msg.payload = json;\n        alert(b); \n    }.bind(scope);\n    //click(door.ip)\n</script>\n<div layout=\"column\" layout-fill >\n  <md-content>\n    <md-list-item ng-repeat=\"door in msg.payload\">\n        <div flex=\"40\" class=\"md-list-item-text\" layout=\"row\" md-colors=\"{color: 'red-A100'}\">\n            <a href=\"http://{{door.ip}}\" class=\"md-body-1\">{{door.doorname}}</a>\n        </div>\n        <div flex=\"40\" class=\"md-list-item-text\" layout=\"row\" md-colors=\"{color: 'red-A100'}\">\n            <i class=\"md-body-1\">{{door.ip}}</i>\n        </div>\n        <div flex=\"10\" class=\"md-list-item-text\" layout=\"row\" md-colors=\"{color: 'red-A100'}\">\n            <i class=\"fa fa-trash\" aria-hidden=\"true\"  ng-click=\"send({payload:{cmd:'deletedoor',doorip:door.ip}})\"></i>\n        </div>\n        <div flex=\"10\" class=\"md-list-item-text\" layout=\"row\" md-colors=\"{color: 'red-A100'}\">\n            <i class=\"fa fa-unlock\" aria-hidden=\"true\"  ng-click=\"send({payload:{cmd:'opendoor',doorip:door.ip}})\"></i>\n        </div>\n        <div flex=\"10\" class=\"md-list-item-text\" layout=\"row\" md-colors=\"{color: 'red-A100'}\">\n            <i class=\"fa fa-download\" aria-hidden=\"true\"  ng-click=\"send({payload:{cmd:'getuser',doorip:door.ip}})\"></i>\n        </div>\n        <div flex=\"10\" class=\"md-list-item-text\" layout=\"row\" md-colors=\"{color: 'red-A100'}\">\n            <i class=\"fa fa-upload\" aria-hidden=\"true\"  ng-click=\"send({payload:{cmd:'sync',doorip:door.ip}})\"></i>\n        </div>\n        <div flex=\"10\" class=\"md-list-item-text\" layout=\"row\" md-colors=\"{color: 'red-A100'}\">\n            <i class=\"fa fa-times\" aria-hidden=\"true\"  ng-click=\"send({payload:{cmd:'deletusers',doorip:door.ip}})\"></i>\n        </div>\n    </md-list-item>\n  </md-content>\n</div>\n\n\n  \n","storeOutMessages":false,"fwdInMessages":false,"templateScope":"local","x":690,"y":100,"wires":[["8ec7d22e.f9403"]]},{"id":"b1d4a132.801f8","type":"function","z":"5da0880e.c537d","name":"20*users","func":"msg.topic = \"Select * from users;\";\nreturn msg;\n\n","outputs":1,"noerr":0,"x":200,"y":260,"wires":[["b080907b.edfc2"]]},{"id":"78234a57.6f1194","type":"ui_template","z":"5da0880e.c537d","group":"27ac83fc.9d43cc","name":"GUI USER LIST","order":1,"width":"12","height":"10","format":"<div layout=\"column\" layout-fill >\n  <md-content>\n    <md-list-item ng-repeat=\"users in msg.payload\">\n         <div flex=\"15\" class=\"md-list-item-text\" layout=\"row\">\n            <i class=\"md-body-1\">{{users.uuid}}</i>\n         </div>\n         <div flex=\"40\" class=\"md-list-item-text\" layout=\"row\">\n            <i class=\"md-body-1\">{{users.user}}</i>\n         </div>\n         <div flex=\"10\" class=\"md-list-item-text\" layout=\"row\">\n            <i class=\"md-body-1\">{{users.acctype}}</i>\n         </div>\n         <div flex=\"20\" class=\"md-list-item-text\" layout=\"row\">\n            <i class=\"md-body-1\">{{users.validuntil * 1000 |  date:'MM/dd/yyyy'}}</i>\n         </div>\n         <div flex=\"10\" class=\"md-list-item-text\" layout=\"row\">\n            <i class=\"fa fa-trash\" aria-hidden=\"true\" ng-click=\"send({payload:{cmd:'delete',user:users.uuid}})\"></i>\n         </div>\n         <div flex=\"10\" class=\"md-list-item-text\" layout=\"row\">\n            <i class=\"fa fa-pencil-square-o\" aria-hidden=\"true\" ng-click=\"editUser(users)\"></i>\n         </div>\n    </md-list-item>\n    <md-button type=\"submit\" class=\"md-primary\" ng-click=\"send({payload:{cmd:'syncall'}})\">Sync to all Readers</md-button>\n  </md-content>\n</div>\n\n\n<!-- The Modal -->\n<div id=\"userModal\" class=\"modal\">\n  <!-- Modal content -->\n  <div class=\"modal-content\">\n    <div class=\"modal-header\">\n      <span class=\"close\">&times;</span>\n      <span class=\"dialogheader\">Add User Access</span>\n    </div>\n    <div class=\"modal-body\">\n        <label class=\"infotext\">Some text in the Modal Body</label>\n        <form name=\"useraddForm\">\n         <div layout-gt-xs=\"row\" md-theme=\"docs-dark\" layout-padding=\"\">\n            <md-input-container class=\"md-block\" flex-gt-xs=\"\">\n                <label>RFID UUID</label>\n                <input type=\"text\" ng-model=\"uid\"  name=\"uid\" id=\"uid\"  disabled=\"\" value=\"{{uid}}\">\n            </md-input-container>\n            <md-input-container class=\"md-block\" flex-gt-xs=\"\">\n                <label>Username:</label>\n                <input type=\"text\" class=\"md-body-1\"  ng-model=\"username\" name=\"username\" id=\"username\" required=\"\">\n                <div ng-messages=\"useraddForm.username.$error\">\n                    <div ng-message=\"required\">This is required.</div>\n                </div>\n            </md-input-container>\n        </div>\n        <div layout-gt-xs=\"row\" md-theme=\"docs-dark\" layout-padding=\"\">\n            <md-input-container class=\"md-block\" flex-gt-xs=\"\">\n                <label>Valid until</label>\n                <md-datepicker ng-model=\"validuntil\" name=\"validuntil\" id=\"validuntil\"  required=\"\">{{ validuntil | date : \"dd.MM.y\" }}</md-datepicker>\n            </md-input-container>\n            <md-input-container flex=\"50\">\n                <label>Project Type</label>\n                 <md-select name=\"type\" ng-model=\"accesstype\" required=\"\" class=\"dropdown-menu model-top\" id=\"accesstype\">\n                    <md-option class=\"dropdown-menu model-top\" value=\"user\">normal</md-option>\n                    <md-option class=\"dropdown-menu model-top\" value=\"admin\">admin</md-option>\n                </md-select>\n            </md-input-container>\n        </div>\n        <md-button type=\"submit\" class=\"md-primary\" ng-click=\"SendCloseUserDlg(msg)\">Add User</md-button>\n        </form>\n      </div>\n    </div>\n  </div>\n\n<script>\n(function($scope) {\n    $scope.editUser = function(users) {\n        //alert(\"UID:\"+users.uuid +\" user:\" +users.user);\n        $scope.uid = users.uuid;\n        $scope.username = users.user;\n        var date =  new Date( users.validuntil*1000).toDateString();\n        //var date = new Date(unix_timestamp*1000);\n        $scope.validuntil = date;\n        if (users.acctype==\"99\")\n            $scope.accesstype = \"admin\";\n        else\n            $scope.accesstype = \"user\";\n        modalUser.style.display = \"block\";\n    };\n    \n    \n    $scope.SendCloseUserDlg = function(unknownuser) {\n        var date = Date.parse($scope.validuntil);\n        $scope.send({payload:{cmd:'change',uuid:$scope.uid,user:$scope.username,valid:(date/1000),type:$scope.accesstype}});\n        modalUser.style.display = \"none\";\n    };\n    \n    $scope.changeDate = function(newDate){\n        $scope.validuntil =  newDate;\n    }\n})(scope);\n\n\n    // Get the modal\nvar modalUser = document.getElementById('userModal');\n\n// Get the button that opens the modal\nvar btn = document.getElementById(\"myBtn\");\n\n// Get the <span> element that closes the modal\nvar span = document.getElementsByClassName(\"close\")[0];\n\n\n// When the user clicks on <span> (x), close the modal\nspan.onclick = function() {\n    modalUser.style.display = \"none\";\n}\n\n</script>\n\n\n","storeOutMessages":false,"fwdInMessages":false,"templateScope":"local","x":680,"y":260,"wires":[["863979b6.693e38"]]},{"id":"b080907b.edfc2","type":"mysql","z":"5da0880e.c537d","mydb":"833fda8f.b825a8","name":"esp-door","x":380,"y":260,"wires":[["78234a57.6f1194","8e081880.a1e0a8"]]},{"id":"8509d636.4ff248","type":"function","z":"5da0880e.c537d","name":"DEL USER","func":"if (msg.payload.cmd==\"delete\"){\n    msg.topic   = \"DELETE FROM users WHERE uuid='\"+msg.payload.user+\"';\";\n}\nreturn msg;\n\n","outputs":1,"noerr":0,"x":1110,"y":220,"wires":[["34a7bfce.97c8e"]]},{"id":"34a7bfce.97c8e","type":"mysql","z":"5da0880e.c537d","mydb":"833fda8f.b825a8","name":"esp-door","x":1380,"y":260,"wires":[["72570b0a.4897b4"]]},{"id":"8ec7d22e.f9403","type":"switch","z":"5da0880e.c537d","name":"","property":"payload.cmd","propertyType":"msg","rules":[{"t":"eq","v":"getuser","vt":"str"},{"t":"eq","v":"opendoor","vt":"str"},{"t":"eq","v":"sync","vt":"str"},{"t":"eq","v":"deletusers","vt":"str"},{"t":"eq","v":"deletedoor","vt":"str"}],"checkall":"true","repair":false,"outputs":5,"x":910,"y":100,"wires":[["80ae6453.e47798"],["80ae6453.e47798"],["c38ac048.df19d"],["80ae6453.e47798"],["5eb3c1d2.5ba3b"]]},{"id":"93ca91b1.d4eb","type":"cast-to-client","z":"5da0880e.c537d","name":"Google Home Voice MSG","url":"","contentType":"","message":"","language":"de","ip":"192.168.2.60","port":"","volume":"50","x":1090,"y":1160,"wires":[[]]},{"id":"bea8e868.509ee8","type":"google-tts","z":"5da0880e.c537d","name":"TextToSpeech","inputField":"payload","inputFieldType":"msg","outputField":"url","outputFieldType":"msg","languageField":"de","languageFieldType":"str","speedField":"1","speedFieldType":"num","x":840,"y":1160,"wires":[["93ca91b1.d4eb"]]},{"id":"78d3b8cb.253d28","type":"function","z":"5da0880e.c537d","name":"Check if user is known","func":"// Access log on node-red\nif ((msg.payload.type == \"access\") && (msg.payload.isKnown == \"true\")){\n    if (msg.payload.cmd == \"log\"){\n        msg.topic = \"INSERT INTO accesslog (uid, type, isknown, username,door,time) VALUES ('\"+msg.payload.uid+\"','\"+msg.payload.type+\"',\"+msg.payload.isKnown+\",'\"+msg.payload.username+\"','\"+msg.payload.door+\"','\"+msg.payload.time+\"')\";\n    }\n    msg.payload = \"Tür von \"+ msg.payload.username+ \" geöffnet\";\n    return msg;\n}\n// adding event\nelse if(msg.payload.cmd == \"event\"){\n    msg.topic = \"INSERT INTO events (type, src, description, data,time,door) VALUES ('\"+msg.payload.type+\"','\"+msg.payload.src+\"','\"+msg.payload.desc+\"','\"+msg.payload.data+\"','\"+msg.payload.time+\"','\"+msg.payload.door +\"')\";\n    msg.paylod = \"\";\n    return msg;\n}\n// user unknown with out log\nelse if((msg.payload.type == \"access\") &&(msg.payload.isKnown==\"false\"))\n{\n    // user unknown adding to newuser db\n    if (msg.payload.cmd == \"log\"){\n        msg.topic = \"INSERT INTO accesslog (uid, type, isknown, username,door,time) VALUES ('\"+msg.payload.uid+\"','\"+msg.payload.type+\"',\"+msg.payload.isKnown+\",'\"+msg.payload.username+\"','\"+msg.payload.door+\"','\"+msg.payload.time+\"');\" + \" INSERT INTO newuser (uid, type, isknown, username,door,time) VALUES ('\"+msg.payload.uid+\"','\"+msg.payload.type+\"',\"+msg.payload.isKnown+\",'\"+msg.payload.username+\"','\"+msg.payload.door+\"','\"+msg.payload.time+\"');\";\n    }\n    else{\n        msg.topic = \"INSERT INTO newuser (uid, type, isknown, username,door,time) VALUES ('\"+msg.payload.uid+\"','\"+msg.payload.type+\"',\"+msg.payload.isKnown+\",'\"+msg.payload.username+\"','\"+msg.payload.door+\"','\"+msg.payload.time+\"')\";\n    }\n    msg.payload = \"Kein Zugang User unbekannt\";\n    return msg;\n}\n\n","outputs":1,"noerr":0,"x":400,"y":1160,"wires":[["93035a62.342298","1ab00e98.cef0c1","bea8e868.509ee8"]]},{"id":"25e4887.0c12178","type":"http in","z":"5da0880e.c537d","name":"opendoor","url":"/opendoor","method":"post","upload":false,"swaggerDoc":"","x":140,"y":1300,"wires":[["d2a1fa23.2e47e8"]]},{"id":"d2a1fa23.2e47e8","type":"function","z":"5da0880e.c537d","name":"VOICE DOOR OPEN","func":"var doors = flow.get(\"doors\");\nvar voiceDoor = \"\";\nvar sysDoor = \"\"; \nvoiceDoor = msg.payload.obj;\n\nfor (index = 0; index < doors.length; ++index) {\n  sysDoor = doors[index].doorname.toString().toLowerCase();\n  voiceDoor = voiceDoor.toLowerCase();\n  if (sysDoor==voiceDoor)\n  {\n     msg.payload.cmd = \"opendoor\";\n     msg.payload.doorip = doors[index].ip.toString();\n     return msg;\n  }\n // msg.payload = sysDoor +\" \" +voiceDoor;\n}\nreturn msg;\n\n","outputs":1,"noerr":0,"x":380,"y":1300,"wires":[["ceb9b5e0.48edb8"]]},{"id":"b23a5348.4cb","type":"function","z":"5da0880e.c537d","name":"SET doors","func":"flow.set(\"doors\",msg.payload);\nreturn msg;","outputs":1,"noerr":0,"x":670,"y":140,"wires":[[]]},{"id":"25527db2.d91872","type":"ui_template","z":"5da0880e.c537d","group":"9f2672e3.3b8cd","name":"GUI NEW USERS","order":1,"width":"0","height":"0","format":"<style>\nbody {font-family: Arial, Helvetica, sans-serif;}\n\n/* The Modal (background) */\n.modal {\n    display: none; /* Hidden by default */\n    position: fixed; /* Stay in place */\n    opacity:0.99;\n    z-index: 100; /* Sit on top */\n    padding-top: 100px; /* Location of the box */\n    left: 0;\n    top: 0;\n    width: 100%; /* Full width */\n    height: 100%; /* Full height */\n    overflow: auto; /* Enable scroll if needed */\n    background-color:  rgba(0,0,0,0.99) /* Fallback color */\n    background-color: rgba(0,0,0,0.99); /* Black w/ opacity */\n}\n/* Modal Content */\n.modal-content {\n    position: relative;\n    background-color: #fefefe;\n    margin: auto;\n    padding: 0;\n    border: 0px solid #FFFFFF;\n    width: 50%;\n    box-shadow: 0 4px 8px 0 rgba(0,0,0,0.2),0 6px 20px 0 rgba(0,0,0,0.19);\n    -webkit-animation-name: animatetop;\n    -webkit-animation-duration: 0.4s;\n    animation-name: animatetop;\n    animation-duration: 0.4s\n}\n\n\n/* Add Animation */\n@-webkit-keyframes animatetop {\n    from {top:-300px; opacity:0} \n    to {top:0; opacity:1}\n}\n\n@keyframes animatetop {\n    from {top:-300px; opacity:0}\n    to {top:0; opacity:1}\n}\n\n/* The Close Button */\n.close {\n    color: white;\n    float: right;\n    font-size: 28px;\n    font-weight: bold;\n}\n\n.close:hover,\n.close:focus {\n    color: #000;\n    text-decoration: none;\n    cursor: pointer;\n}\n\n.modal-header {\n    padding: 0px 0px;\n    background-color: #097479;\n}\n\n.modal-body {\n    padding: 10px 10px;\n    background-color: #097479;\n}\n\n.dropdown-menu.model-top{\n    z-index:101;\n}\n\n.md-select-menu-container { \n    z-index: 99999 !important; \n    \n}\n\n.infotext{\n    color: white;\n    background-color: #097479;\n}\n\n.dialogheader {\n    background-color: #222222 !important;\n    margin-top: 0px  !important;\n    margin-right: 0px;\n    margin-bottom: 0px  !important;\n    margin-left: 0px;\n    margin: 0px !important;\n}\n}\n\n</style>\n\n<div layout=\"column\" layout-fill >\n  <md-content>\n    <md-list-item ng-repeat=\"newusers in msg.payload\" id = $index ng-click=\"\">\n         <div flex=\"20\" class=\"md-list-item-text\" layout=\"row\">\n            <i class=\"md-body-1\" >{{newusers.uid}}</i>\n         </div>\n         <div flex=\"20\" class=\"md-list-item-text\" layout=\"row\">\n            <i class=\"md-body-1\" contenteditable=\"true\">{{newusers.user}}unknown</i>\n         </div>\n         <div flex=\"20\" class=\"md-list-item-text\" layout=\"row\">\n            <i class=\"md-body-1\" contenteditable=\"true\">{{newusers.door}}</i>\n         </div>\n          <div flex=\"20\" class=\"md-list-item-text\" layout=\"row\">\n            <i class=\"md-body-1\">{{newusers.time * 1000 |  date:'MM/dd/yyyy'}}</i>\n         </div>\n         <div flex=\"10\" class=\"md-list-item-text\" layout=\"row\">\n          <i class=\"fa fa-check-circle-o\" aria-hidden=\"true\" ng-click=\"addUidToDbRow(newusers)\"></i>\n         </div>\n         <div flex=\"10\" class=\"md-list-item-text\" layout=\"row\">\n          <i class=\"fa fa-trash\" aria-hidden=\"true\" ng-click=\"delteRow(newusers)\"></i>\n         </div>\n    </md-list-item>\n  </md-content>\n</div>\n\n\n<!-- The Modal -->\n<div id=\"myModal\" class=\"modal\">\n  <!-- Modal content -->\n  <div class=\"modal-content\">\n    <div class=\"modal-header\">\n      <span class=\"close\">&times;</span>\n      <span class=\"dialogheader\">Add User Access</span>\n    </div>\n    <div class=\"modal-body\">\n        <label class=\"infotext\">Some text in the Modal Body</label>\n        <form name=\"useraddForm\">\n         <div layout-gt-xs=\"row\" md-theme=\"docs-dark\" layout-padding=\"\">\n            <md-input-container class=\"md-block\" flex-gt-xs=\"\">\n                <label>RFID UUID</label>\n                <input type=\"text\" ng-model=\"uid\"  name=\"uid\" id=\"uid\"  disabled=\"\" value=\"{{newusers.uid}}\">{{newusers.uid}}\n            </md-input-container>\n            <md-input-container class=\"md-block\" flex-gt-xs=\"\">\n                <label>Username:</label>\n                <input type=\"text\" class=\"md-body-1\"  ng-model=\"username\" name=\"username\" id=\"username\" required=\"\">\n                <div ng-messages=\"useraddForm.username.$error\">\n                    <div ng-message=\"required\">This is required.</div>\n                </div>\n            </md-input-container>\n        </div>\n        <div layout-gt-xs=\"row\" md-theme=\"docs-dark\" layout-padding=\"\">\n            <md-input-container class=\"md-block\" flex-gt-xs=\"\">\n                <label>Valid until</label>\n                <md-datepicker ng-model=\"validuntil\" name=\"validuntil\" id=\"validuntil\"  required=\"\">{{ validuntil | date : \"dd.MM.y\" }}</md-datepicker>\n            </md-input-container>\n            <md-input-container flex=\"50\">\n                <label>Project Type</label>\n                 <md-select name=\"type\" ng-model=\"accesstype\" required=\"\" class=\"dropdown-menu model-top\" id=\"accesstype\">\n                    <md-option class=\"dropdown-menu model-top\" value=\"user\">normal</md-option>\n                    <md-option class=\"dropdown-menu model-top\" value=\"admin\">admin</md-option>\n                </md-select>\n            </md-input-container>\n        </div>\n        <md-button type=\"submit\" class=\"md-primary\" ng-click=\"SendCloseUserDlg(msg)\">Add User</md-button>\n        </form>\n      </div>\n    </div>\n  </div>\n\n<script>\n(function($scope) {\n    $scope.delteRow = function(unknownuser) {\n        $scope.send({payload:{cmd:'delete',uuid:unknownuser.uid}});\n    };\n    \n    $scope.addUidToDbRow = function(unknownuser) {\n        // alert(\"UID:\"+unknownuser.uid +\" user:\" +$scope.username+\" valid:\" + $scope.validuntil+\" access:\"+$scope.accesstype);\n        $scope.uid = unknownuser.uid;\n        modal.style.display = \"block\";\n    };\n    $scope.SendCloseUserDlg = function(unknownuser) {\n        //alert(\"close\" + unknownuser.payload.uid);\n        //var uid         = document.getElementById(\"uid\").value;\n        //var username    = document.getElementById(\"username\").value;\n        //var validuntil  = document.getElementById(\"validuntil\").value;\n        //var accesstype  = document.getElementById(\"accesstype\").value;\n         \n        //alert(\"UID:\"+$scope.uid +\" user:\" +$scope.username+\" valid:\" + $scope.validuntil+\" access:\"+$scope.accesstype);\n        var date = Date.parse($scope.validuntil);\n   \n        $scope.send({payload:{cmd:'add',uuid:$scope.uid,user:$scope.username,valid:(date/1000),type:$scope.accesstype}});\n        modal.style.display = \"none\";\n    };\n    $scope.changeDate = function(newDate){\n        $scope.validuntil =  newDate;\n    }\n})(scope);\n\n\n    // Get the modal\nvar modal = document.getElementById('myModal');\n\n// Get the button that opens the modal\nvar btn = document.getElementById(\"myBtn\");\n\n// Get the <span> element that closes the modal\nvar span = document.getElementsByClassName(\"close\")[0];\n\n\n// When the user clicks on <span> (x), close the modal\nspan.onclick = function() {\n    modal.style.display = \"none\";\n}\n\n</script>\n\n\n\n","storeOutMessages":false,"fwdInMessages":false,"templateScope":"local","x":690,"y":520,"wires":[["b3c0c90b.4f8fc8"]]},{"id":"508f0b61.02bfc4","type":"mysql","z":"5da0880e.c537d","mydb":"833fda8f.b825a8","name":"esp-door-userUnknown","x":430,"y":520,"wires":[["25527db2.d91872"]]},{"id":"37ec6a44.a37916","type":"function","z":"5da0880e.c537d","name":"30*newusers","func":"msg.topic = \"Select * from newuser\";\nreturn msg;\n\n","outputs":1,"noerr":0,"x":210,"y":520,"wires":[["508f0b61.02bfc4"]]},{"id":"5eb3c1d2.5ba3b","type":"function","z":"5da0880e.c537d","name":"Delete Door","func":"msg.topic = \"DELETE FROM readers WHERE ip='\"+msg.payload.doorip+\"';\";\nflow.set(\"doorip\", msg.payload.doorip);\nreturn msg;","outputs":1,"noerr":0,"x":1210,"y":120,"wires":[["7308952b.614fac"]]},{"id":"7308952b.614fac","type":"mysql","z":"5da0880e.c537d","mydb":"833fda8f.b825a8","name":"esp-door","x":1355,"y":120,"wires":[["a386d64f.08b708"]],"l":false},{"id":"85243abc.fe2f08","type":"link in","z":"5da0880e.c537d","name":"L_10","links":["a386d64f.08b708","c4faea87.3efed8"],"x":75,"y":100,"wires":[["704e364f.e28c28"]]},{"id":"a386d64f.08b708","type":"link out","z":"5da0880e.c537d","name":"","links":["85243abc.fe2f08"],"x":1515,"y":120,"wires":[]},{"id":"2dbc57f6.171838","type":"link in","z":"5da0880e.c537d","name":"L_20","links":["69c343cc.b2eedc","72570b0a.4897b4","be205a5f.b1b658"],"x":75,"y":260,"wires":[["b1d4a132.801f8"]]},{"id":"72570b0a.4897b4","type":"link out","z":"5da0880e.c537d","name":"","links":["2dbc57f6.171838"],"x":1515,"y":260,"wires":[]},{"id":"c4faea87.3efed8","type":"link out","z":"5da0880e.c537d","name":"","links":["85243abc.fe2f08"],"x":695,"y":900,"wires":[]},{"id":"69c343cc.b2eedc","type":"link out","z":"5da0880e.c537d","name":"","links":["2dbc57f6.171838"],"x":915,"y":1020,"wires":[]},{"id":"c38ac048.df19d","type":"link out","z":"5da0880e.c537d","name":"","links":["11511bfd.2c0d04"],"x":1255,"y":80,"wires":[]},{"id":"11511bfd.2c0d04","type":"link in","z":"5da0880e.c537d","name":"L_100","links":["c38ac048.df19d","b3ef853e.13f528"],"x":95,"y":780,"wires":[["4c3c3ea0.e4f7c"]]},{"id":"8829206d.fe1ff","type":"link in","z":"5da0880e.c537d","name":"RFID_MQTT_OUT","links":["45205e51.86309","80ae6453.e47798","ceb9b5e0.48edb8"],"x":95,"y":720,"wires":[["f117dc63.eb4cd"]]},{"id":"80ae6453.e47798","type":"link out","z":"5da0880e.c537d","name":"","links":["8829206d.fe1ff"],"x":1255,"y":40,"wires":[]},{"id":"45205e51.86309","type":"link out","z":"5da0880e.c537d","name":"","links":["8829206d.fe1ff"],"x":995,"y":680,"wires":[]},{"id":"ceb9b5e0.48edb8","type":"link out","z":"5da0880e.c537d","name":"","links":["8829206d.fe1ff"],"x":555,"y":1300,"wires":[]},{"id":"e7a9ca4f.5799b8","type":"comment","z":"5da0880e.c537d","name":"DB Selects for User, Readers to fill template","info":"","x":190,"y":60,"wires":[]},{"id":"7d4d49f7.a57728","type":"comment","z":"5da0880e.c537d","name":"Iterates over user and sends them over MQTT to a Device","info":"","x":250,"y":680,"wires":[]},{"id":"1ad982b5.57decd","type":"comment","z":"5da0880e.c537d","name":"Recv Sync over MQTT and writs unknow Reader to DB","info":"","x":240,"y":860,"wires":[]},{"id":"b3addda4.3e246","type":"comment","z":"5da0880e.c537d","name":"Recv userlist of a Reader and inserts into DB","info":"","x":210,"y":980,"wires":[]},{"id":"b817fe32.f93e4","type":"comment","z":"5da0880e.c537d","name":"Recv access event over MQTT","info":"","x":170,"y":1120,"wires":[]},{"id":"2dde2749.f120d8","type":"comment","z":"5da0880e.c537d","name":"Google Voice Command to open a door ","info":"","x":190,"y":1260,"wires":[]},{"id":"b3c0c90b.4f8fc8","type":"switch","z":"5da0880e.c537d","name":"","property":"payload.cmd","propertyType":"msg","rules":[{"t":"eq","v":"delete","vt":"str"},{"t":"eq","v":"add","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":910,"y":520,"wires":[["f2059899.69b328"],["1b3f5681.d5de79"]]},{"id":"f2059899.69b328","type":"function","z":"5da0880e.c537d","name":"SQL Del new user","func":"if (msg.payload.cmd==\"delete\"){\n    var uuid = msg.payload.uuid;\n    msg.payload = \"DELTE NEWUSER\"\n    msg.topic   = \"DELETE FROM newuser WHERE uid='\"+uuid+\"';\";\n}\nreturn msg;","outputs":1,"noerr":0,"x":1110,"y":480,"wires":[["8c1b6cab.0320f"]]},{"id":"8c1b6cab.0320f","type":"mysql","z":"5da0880e.c537d","mydb":"833fda8f.b825a8","name":"esp-door","x":1400,"y":520,"wires":[["76d1bd85.2eed64"]]},{"id":"36d1ce90.0ebc42","type":"link in","z":"5da0880e.c537d","name":"L_30","links":["15104682.e46449","7a6e89ba.af0c98","b329b1e4.73a9"],"x":75,"y":520,"wires":[["37ec6a44.a37916"]]},{"id":"1b3f5681.d5de79","type":"function","z":"5da0880e.c537d","name":"SQL Add User for access","func":"if (msg.payload.cmd==\"add\"){\n    var uuid = msg.payload.uuid;\n    var name  = msg.payload.name;\n    var type = \"\";\n    if (msg.payload.type==\"admin\")\n        type = \"99\";\n    else\n        type = \"1\";\n    msg.topic = \"INSERT INTO users (uuid, user, acctype, validuntil) VALUES ('\"+msg.payload.uuid+\"','\"+msg.payload.user+\"','\"+type+\"','\"+msg.payload.valid+\"')\";\n}\nreturn msg;\n","outputs":1,"noerr":0,"x":1130,"y":540,"wires":[["9a9490a7.07229","8c1b6cab.0320f"]]},{"id":"be205a5f.b1b658","type":"link out","z":"5da0880e.c537d","name":"","links":["2dbc57f6.171838"],"x":1695,"y":540,"wires":[]},{"id":"41d9ad6f.fdf554","type":"inject","z":"5da0880e.c537d","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":true,"onceDelay":"1","x":150,"y":340,"wires":[["37ec6a44.a37916","b1d4a132.801f8","704e364f.e28c28"]]},{"id":"9a9490a7.07229","type":"function","z":"5da0880e.c537d","name":"40 SQL Del newuser ","func":"if (msg.payload.cmd==\"add\"){\n    var uuid = msg.payload.uuid;\n    msg.topic   = \"DELETE FROM newuser WHERE uid='\"+uuid+\"';\";\n }\nreturn msg;\n","outputs":1,"noerr":0,"x":1120,"y":600,"wires":[["8c1b6cab.0320f"]]},{"id":"9c6b2990.0a8528","type":"function","z":"5da0880e.c537d","name":"20*users","func":"msg.topic = \"Select * from users;\";\nreturn msg;\n\n","outputs":1,"noerr":0,"x":1180,"y":940,"wires":[["d6115e2a.d877f"]]},{"id":"d6115e2a.d877f","type":"mysql","z":"5da0880e.c537d","mydb":"833fda8f.b825a8","name":"esp-door","x":1340,"y":940,"wires":[["bebaa6f9.d7a698"]]},{"id":"6e35c1b2.06214","type":"json","z":"5da0880e.c537d","name":"","property":"payload","action":"str","pretty":true,"x":1650,"y":940,"wires":[["b745abf2.3b4248"]]},{"id":"4371b96f.18e288","type":"inject","z":"5da0880e.c537d","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":1020,"y":940,"wires":[["9c6b2990.0a8528","d126cf5.724c73"]]},{"id":"b745abf2.3b4248","type":"function","z":"5da0880e.c537d","name":"","func":"flow.set(\"RFID_Users\",msg.payload);\nreturn msg;","outputs":1,"noerr":0,"x":1820,"y":940,"wires":[[]]},{"id":"d126cf5.724c73","type":"function","z":"5da0880e.c537d","name":"20*users","func":"msg.topic = \"Select * from readers;\";\nreturn msg;\n\n","outputs":1,"noerr":0,"x":1180,"y":1000,"wires":[["d6115e2a.d877f"]]},{"id":"d5b6f03.c3ba11","type":"json","z":"5da0880e.c537d","name":"","property":"payload","action":"str","pretty":true,"x":1650,"y":1000,"wires":[["6ac6a90.4fb6758"]]},{"id":"6ac6a90.4fb6758","type":"function","z":"5da0880e.c537d","name":"","func":"flow.set(\"RFID_readers\",msg.payload);\nreturn msg;","outputs":1,"noerr":0,"x":1820,"y":1000,"wires":[[]]},{"id":"863979b6.693e38","type":"switch","z":"5da0880e.c537d","name":"","property":"payload.cmd","propertyType":"msg","rules":[{"t":"eq","v":"delete","vt":"str"},{"t":"eq","v":"change","vt":"str"},{"t":"eq","v":"syncall","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":910,"y":260,"wires":[["8509d636.4ff248"],["1e1335d6.41dada"],["3b2c4359.3d54cc"]]},{"id":"1e1335d6.41dada","type":"function","z":"5da0880e.c537d","name":"CHANGE USER","func":"if (msg.payload.cmd==\"change\"){\n    var type = \"\";\n    if (msg.payload.type==\"admin\")\n        type = \"99\";\n    else\n        type = \"1\";\n    msg.topic = \"REPLACE INTO users (uuid, user, acctype, validuntil) VALUES ('\"+msg.payload.uuid+\"','\"+msg.payload.user+\"','\"+type+\"','\"+msg.payload.valid+\"')\";\n}\nreturn msg;\n\n","outputs":1,"noerr":0,"x":1120,"y":260,"wires":[["34a7bfce.97c8e"]]},{"id":"3b2c4359.3d54cc","type":"function","z":"5da0880e.c537d","name":"SYNC al RFID Reader with DB","func":"// Send Userlist to all rfid readers\nmsg.payload = flow.get(\"RFID_Readers\");\nreturn msg;\n\n","outputs":1,"noerr":0,"x":1170,"y":380,"wires":[["cc886e50.a8b02"]]},{"id":"8e081880.a1e0a8","type":"function","z":"5da0880e.c537d","name":"FLOW Set RFID_Users","func":"flow.set(\"RFID_Users\",msg.payload);\nreturn msg;","outputs":1,"noerr":0,"x":710,"y":300,"wires":[[]]},{"id":"3030dbc.4b49c24","type":"function","z":"5da0880e.c537d","name":"FLOW Set RFID_Readers","func":"flow.set(\"RFID_Readers\",msg.payload);\nreturn msg;","outputs":1,"noerr":0,"x":710,"y":180,"wires":[[]]},{"id":"ca61b0ce.bc601","type":"function","z":"5da0880e.c537d","name":"IterateReaders","func":"msg.payload.doorip = msg.payload.ip;\nreturn msg;","outputs":1,"noerr":0,"x":1480,"y":320,"wires":[["cc886e50.a8b02","b3ef853e.13f528"]]},{"id":"cc886e50.a8b02","type":"Serial Iterator","z":"5da0880e.c537d","name":"REARDE ITER","property":"payload","inputFlow":"input","saveOutput":1,"recursive":0,"storeId":0,"x":1440,"y":380,"wires":[["7edc5af0.ec31f4"],[]]},{"id":"7edc5af0.ec31f4","type":"delay","z":"5da0880e.c537d","name":"","pauseType":"delay","timeout":"200","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1660,"y":380,"wires":[["ca61b0ce.bc601"]]},{"id":"b3ef853e.13f528","type":"link out","z":"5da0880e.c537d","name":"","links":["11511bfd.2c0d04"],"x":1635,"y":320,"wires":[]},{"id":"67a4d7c0.422c98","type":"inject","z":"5da0880e.c537d","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":true,"onceDelay":0.1,"x":150,"y":180,"wires":[["704e364f.e28c28","b1d4a132.801f8","37ec6a44.a37916"]]},{"id":"d0ff54fc.98bd98","type":"cast-to-client","z":"5da0880e.c537d","name":"Google Home Voice MSG","url":"","contentType":"","message":"","language":"de","ip":"192.168.2.59","port":"","volume":"100","x":1090,"y":1220,"wires":[[]]},{"id":"80fdc09a.7b5f1","type":"google-tts","z":"5da0880e.c537d","name":"TextToSpeech","inputField":"payload","inputFieldType":"msg","outputField":"url","outputFieldType":"msg","languageField":"de","languageFieldType":"str","speedField":"1","speedFieldType":"num","x":840,"y":1220,"wires":[["d0ff54fc.98bd98"]]},{"id":"d9f733ba.91759","type":"comment","z":"5da0880e.c537d","name":"event DB create","info":"CREATE TABLE `esp-door`. ( `id` SERIAL NOT NULL , `type` VARCHAR(20) NOT NULL , `src` VARCHAR(20) NOT NULL , `description` VARCHAR(40) NOT NULL , `data` VARCHAR(20) NOT NULL , `time` TIMESTAMP NOT NULL ) ENGINE = InnoDB;","x":120,"y":1400,"wires":[]},{"id":"93035a62.342298","type":"mysql","z":"5da0880e.c537d","mydb":"833fda8f.b825a8","name":"esp-door","x":600,"y":1120,"wires":[["b329b1e4.73a9"]]},{"id":"612d7f33.4b2da","type":"ui_list","z":"5da0880e.c537d","group":"3593b017.0613f","name":"LIST_ACCESS","order":7,"width":"12","height":"11","lineType":"two","actionType":"click","allowHTML":true,"x":1320,"y":2160,"wires":[[]]},{"id":"2cb41425.6b7a0c","type":"inject","z":"5da0880e.c537d","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":true,"onceDelay":"1","x":130,"y":2040,"wires":[["70617ff5.2e8b7"]]},{"id":"6900deea.ba36e","type":"comment","z":"5da0880e.c537d","name":"Loogging Display on GUI","info":"","x":150,"y":1460,"wires":[]},{"id":"18fca357.5ae96d","type":"function","z":"5da0880e.c537d","name":"PREPARE ACCESS LOG","func":"\n\nvar options = { weekday: 'long', year: 'numeric', month: 'long', day: 'numeric'};\n\nvar optionsTime = { timeZone:\"Europe/Berlin\", hour12 : false, hour:  \"2-digit\", minute: \"2-digit\", second: \"2-digit\"};\n\ntablelog=[];\n\nfor (index = 0; index < msg.payload.length; ++index) {\n    var json = new Object();\n    var datum =  new Date( msg.payload[index].time*1000);\n    json.title = datum.toLocaleDateString(\"de-DE\", options) + \" \" + datum.toLocaleTimeString(\"de-DE\",optionsTime);\n    json.description=\"User: \" +msg.payload[index].username +\" - Door: \" + msg.payload[index].door;\n    if (msg.payload[index].isknown == 1)\n        json.icon=\"http://192.168.2.110/img/unlock.png\";\n    else\n        json.icon=\"http://192.168.2.110/img/lock.png\";\n    tablelog.push(json);\n}\nmsg.payload = tablelog;\nreturn msg;\n\n","outputs":1,"noerr":0,"x":1070,"y":2180,"wires":[["612d7f33.4b2da","cdc282ea.976f8"]]},{"id":"cdc282ea.976f8","type":"debug","z":"5da0880e.c537d","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":1310,"y":2200,"wires":[]},{"id":"254cf4f3.0c522c","type":"ui_list","z":"5da0880e.c537d","group":"e96ae11.a1dd42","name":"LIST_EVENTS","order":7,"width":"12","height":"11","lineType":"two","actionType":"click","allowHTML":true,"x":1320,"y":1760,"wires":[[]]},{"id":"3a0fc33f.5ecb7c","type":"inject","z":"5da0880e.c537d","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":true,"onceDelay":"1","x":130,"y":1660,"wires":[["abf5adde.d9f41"]]},{"id":"24372f1d.3a7d1","type":"function","z":"5da0880e.c537d","name":"PREPARE EVENTS LOG","func":"\nvar options = { weekday: 'long', year: 'numeric', month: 'long', day: 'numeric'};\nvar optionsTime = { timeZone:\"Europe/Berlin\", hour12 : false, hour:  \"2-digit\", minute: \"2-digit\", second: \"2-digit\"};\ntablelog=[];\n\nfor (index = 0; index < msg.payload.length; ++index) {\n    var json = new Object();\n    var datum =  new Date( msg.payload[index].time*1000);\n    json.title = datum.toLocaleDateString(\"de-DE\", options) + \" \" + datum.toLocaleTimeString(\"de-DE\",optionsTime);\n    json.description=msg.payload[index].type +\" \"+ msg.payload[index].src +\" \"+ msg.payload[index].description +\" \"+ msg.payload[index].data  +\" - Door: \" + msg.payload[index].door ;\n    \n    if (msg.payload[index].type == \"INFO\")\n        json.icon=\"http://192.168.2.110/img/info.png\";\n    else if (msg.payload[index].type == \"WARN\")\n        json.icon=\"http://192.168.2.110/img/warn.png\";\n    else\n        json.icon=\"http://192.168.2.110/img/warn.png\";\n        \n    tablelog.push(json);\n}\nmsg.payload = tablelog;\nreturn msg;\n\n","outputs":1,"noerr":0,"x":1070,"y":1780,"wires":[["254cf4f3.0c522c","61f1b48a.6412fc"]]},{"id":"41cb3cc0.a5f3d4","type":"debug","z":"5da0880e.c537d","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":1750,"y":1640,"wires":[]},{"id":"ef05f4c1.2ddc38","type":"ui_button","z":"5da0880e.c537d","name":"","group":"e96ae11.a1dd42","order":1,"width":"3","height":"1","passthru":false,"label":"Refresh","tooltip":"","color":"","bgcolor":"","icon":"","payload":"refresh","payloadType":"str","topic":"","x":100,"y":1600,"wires":[["abf5adde.d9f41"]]},{"id":"89049b8b.58fd68","type":"ui_button","z":"5da0880e.c537d","name":"","group":"e96ae11.a1dd42","order":5,"width":"3","height":"1","passthru":false,"label":"Del Log","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":1300,"y":1520,"wires":[["faf8ea8d.176ae8"]]},{"id":"a1c93ead.abd9a","type":"ui_button","z":"5da0880e.c537d","name":"","group":"e96ae11.a1dd42","order":2,"width":"1","height":"1","passthru":false,"label":"<<","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":1290,"y":1580,"wires":[["b4e9991c.287b78"]]},{"id":"b270a3f4.c3ed4","type":"ui_button","z":"5da0880e.c537d","name":"","group":"e96ae11.a1dd42","order":4,"width":"1","height":"1","passthru":false,"label":">>","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":1290,"y":1700,"wires":[["f1843205.3a7a9"]]},{"id":"e0c9c93c.9ece68","type":"ui_text","z":"5da0880e.c537d","group":"e96ae11.a1dd42","order":3,"width":"2","height":"1","name":"","label":"","format":"{{msg.payload}}","layout":"row-left","x":1290,"y":1640,"wires":[]},{"id":"abf5adde.d9f41","type":"function","z":"5da0880e.c537d","name":"REFRESH EVENTS","func":"msg.topic = \"SELECT COUNT(*) FROM events;\";\nreturn msg;","outputs":1,"noerr":0,"x":360,"y":1600,"wires":[["e986f181.a5b3d"]]},{"id":"e986f181.a5b3d","type":"mysql","z":"5da0880e.c537d","mydb":"833fda8f.b825a8","name":"esp-door","x":280,"y":1800,"wires":[["50d57b25.b09744"]]},{"id":"2a95f935.2ca0a6","type":"function","z":"5da0880e.c537d","name":"Set Context page count","func":"var counter = msg.payload[0]['COUNT(*)'];\nvar page = 10;\n\nvar page_count = Math.trunc(counter / page);\nflow.set(\"page_size\",page);\nflow.set(\"page_count_events\", page_count);\nflow.set(\"page_sel_events\",0);\nvar limit = \"0,\"+page;\n\nmsg.payload = \"0 of \"+page_count;\nmsg.topic = \"SELECT * FROM events ORDER BY id DESC LIMIT \"+limit;\nreturn msg;","outputs":1,"noerr":0,"x":670,"y":1600,"wires":[["e0c9c93c.9ece68","917e5587.311f78"]]},{"id":"917e5587.311f78","type":"mysql","z":"5da0880e.c537d","mydb":"833fda8f.b825a8","name":"esp-door","x":860,"y":1780,"wires":[["24372f1d.3a7d1"]]},{"id":"b4e9991c.287b78","type":"function","z":"5da0880e.c537d","name":"modify page count","func":"pagesize   = flow.get(\"page_size\");\npage_count = flow.get(\"page_count_events\");\n//var page_count = Math.trunc(page_count / pagesize);\npage       = flow.get(\"page_sel_events\");\n\npage = page - 1;\n\nif (page < 0){\n    page = page_count;    \n}\nlimit = pagesize*(page) +\",\"+pagesize;\n\nflow.set(\"page_sel_events\",page)\nmsg.payload = page +\" of \"+ page_count;\nmsg.topic = \"SELECT * FROM events ORDER BY id DESC LIMIT \"+limit;\nreturn msg;","outputs":1,"noerr":0,"x":1490,"y":1580,"wires":[["e0c9c93c.9ece68","41cb3cc0.a5f3d4","315645fd.37886a"]]},{"id":"f1843205.3a7a9","type":"function","z":"5da0880e.c537d","name":"modify page count","func":"pagesize   = flow.get(\"page_size\");\npage_count = flow.get(\"page_count_events\");\n//var page_count = Math.trunc(page_count / pagesize);\npage       = flow.get(\"page_sel_events\");\n\npage = page + 1;\nif (page > page_count){\n    page = 0;\n    limit = pagesize*page +\",\"+pagesize;\n}else{\n    limit = pagesize*page +\",\"+pagesize;\n}\n\nflow.set(\"page_sel_events\",page)\nmsg.payload = msg.payload = page +\" of \"+ page_count;\nmsg.topic = \"SELECT * FROM events ORDER BY id DESC LIMIT \"+limit;\nreturn msg;","outputs":1,"noerr":0,"x":1490,"y":1700,"wires":[["e0c9c93c.9ece68","41cb3cc0.a5f3d4","315645fd.37886a"]]},{"id":"66cd3079.24f93","type":"debug","z":"5da0880e.c537d","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":1730,"y":2040,"wires":[]},{"id":"a2f75be.9e5b1a8","type":"ui_button","z":"5da0880e.c537d","name":"","group":"3593b017.0613f","order":2,"width":"1","height":"1","passthru":false,"label":"<<","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":1290,"y":1980,"wires":[["1721bbbd.cf8b34"]]},{"id":"17f56dc.38cb792","type":"ui_button","z":"5da0880e.c537d","name":"","group":"3593b017.0613f","order":4,"width":"1","height":"1","passthru":false,"label":">>","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":1290,"y":2100,"wires":[["1b083d88.ed6422"]]},{"id":"c82ddf87.33c4b","type":"ui_text","z":"5da0880e.c537d","group":"3593b017.0613f","order":3,"width":"2","height":"1","name":"","label":"","format":"{{msg.payload}}","layout":"row-left","x":1290,"y":2040,"wires":[]},{"id":"1721bbbd.cf8b34","type":"function","z":"5da0880e.c537d","name":"modify page count","func":"pagesize   = flow.get(\"page_size_access\");\npage_count = flow.get(\"page_count_events_access\");\n//var page_count = Math.trunc(page_count / pagesize);\npage       = flow.get(\"page_sel_events_access\");\n\npage = page - 1;\n\nif (page < 0){\n    page = page_count;    \n}\nlimit = pagesize*(page) +\",\"+pagesize;\n\nflow.set(\"page_sel_events_access\",page)\nmsg.payload = page +\" of \"+ page_count;\nmsg.topic = \"SELECT * FROM accesslog ORDER BY id DESC LIMIT \"+limit;\nreturn msg;","outputs":1,"noerr":0,"x":1470,"y":1980,"wires":[["c82ddf87.33c4b","66cd3079.24f93","80bb7cf5.14a38"]]},{"id":"1b083d88.ed6422","type":"function","z":"5da0880e.c537d","name":"modify page count","func":"pagesize   = flow.get(\"page_size_access\");\npage_count = flow.get(\"page_count_events_access\");\n//var page_count = Math.trunc(page_count / pagesize);\npage       = flow.get(\"page_sel_events_access\");\n\npage = page + 1;\nif (page > page_count){\n    page = 0;\n    limit = pagesize*page +\",\"+pagesize;\n}else{\n    limit = pagesize*page +\",\"+pagesize;\n}\n\nflow.set(\"page_sel_events_access\",page)\nmsg.payload = msg.payload = page +\" of \"+ page_count;\nmsg.topic = \"SELECT * FROM accesslog ORDER BY id DESC LIMIT \"+limit;\nreturn msg;","outputs":1,"noerr":0,"x":1470,"y":2100,"wires":[["c82ddf87.33c4b","66cd3079.24f93","80bb7cf5.14a38"]]},{"id":"7305d0e4.4d34f","type":"ui_button","z":"5da0880e.c537d","name":"","group":"3593b017.0613f","order":1,"width":"3","height":"1","passthru":false,"label":"Refresh","tooltip":"","color":"","bgcolor":"","icon":"","payload":"refresh","payloadType":"str","topic":"","x":100,"y":1980,"wires":[["70617ff5.2e8b7"]]},{"id":"70617ff5.2e8b7","type":"function","z":"5da0880e.c537d","name":"REFRESH ACCESSLOG","func":"msg.topic = \"SELECT COUNT(*) FROM accesslog;\";\nreturn msg;","outputs":1,"noerr":0,"x":370,"y":1980,"wires":[["e986f181.a5b3d"]]},{"id":"44e86277.84644c","type":"function","z":"5da0880e.c537d","name":"Set Context page count","func":"var counter = msg.payload[0]['COUNT(*)'];\nvar page = 10;\n\nvar page_count = Math.trunc(counter / page);\nflow.set(\"page_size_access\",page);\nflow.set(\"page_count_events_access\", page_count);\nflow.set(\"page_sel_events_access\",0);\nvar limit = \"0,\"+page;\n\nmsg.payload = \"0 of \"+page_count;\nmsg.topic = \"SELECT * FROM accesslog ORDER BY id DESC LIMIT \"+limit;\nreturn msg;","outputs":1,"noerr":0,"x":670,"y":1980,"wires":[["bf12f045.f0481","c82ddf87.33c4b"]]},{"id":"bf12f045.f0481","type":"mysql","z":"5da0880e.c537d","mydb":"833fda8f.b825a8","name":"esp-door","x":860,"y":2180,"wires":[["18fca357.5ae96d"]]},{"id":"61f1b48a.6412fc","type":"debug","z":"5da0880e.c537d","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":1310,"y":1800,"wires":[]},{"id":"f2ea7896.04b608","type":"ui_button","z":"5da0880e.c537d","name":"","group":"3593b017.0613f","order":5,"width":"3","height":"1","passthru":false,"label":"Del Log","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":1300,"y":1920,"wires":[["d5d42f44.83bec"]]},{"id":"d5d42f44.83bec","type":"function","z":"5da0880e.c537d","name":"Delete ACCESSLOG","func":"msg.topic = \"TRUNCATE TABLE accesslog;\";\nreturn msg;","outputs":1,"noerr":0,"x":1480,"y":1920,"wires":[["80bb7cf5.14a38"]]},{"id":"faf8ea8d.176ae8","type":"function","z":"5da0880e.c537d","name":"Delete EVENTSLOG","func":"msg.topic = \"TRUNCATE TABLE events;\";\nreturn msg;","outputs":1,"noerr":0,"x":1500,"y":1520,"wires":[["315645fd.37886a"]]},{"id":"b329b1e4.73a9","type":"link out","z":"5da0880e.c537d","name":"NEW_ENTRY_DB","links":["36d1ce90.0ebc42","964c4c17.e613b","dba1660e.c57a98"],"x":735,"y":1120,"wires":[]},{"id":"964c4c17.e613b","type":"link in","z":"5da0880e.c537d","name":"","links":["b329b1e4.73a9"],"x":55,"y":1540,"wires":[["abf5adde.d9f41"]]},{"id":"dba1660e.c57a98","type":"link in","z":"5da0880e.c537d","name":"","links":["b329b1e4.73a9"],"x":55,"y":1920,"wires":[["70617ff5.2e8b7"]]},{"id":"c62d4abc.814448","type":"link in","z":"5da0880e.c537d","name":"TRIGGER_EVENT_DB","links":["315645fd.37886a"],"x":735,"y":1780,"wires":[["917e5587.311f78"]]},{"id":"315645fd.37886a","type":"link out","z":"5da0880e.c537d","name":"","links":["c62d4abc.814448"],"x":1695,"y":1580,"wires":[]},{"id":"703d26ed.66a4f8","type":"link in","z":"5da0880e.c537d","name":"TRIGGER_ACESSLOG_DB","links":["80bb7cf5.14a38"],"x":735,"y":2180,"wires":[["bf12f045.f0481"]]},{"id":"80bb7cf5.14a38","type":"link out","z":"5da0880e.c537d","name":"","links":["703d26ed.66a4f8"],"x":1675,"y":1980,"wires":[]},{"id":"daf8fd1a.da744","type":"debug","z":"5da0880e.c537d","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"topic","targetType":"msg","x":1740,"y":460,"wires":[]},{"id":"76d1bd85.2eed64","type":"switch","z":"5da0880e.c537d","name":"","property":"topic","propertyType":"msg","rules":[{"t":"cont","v":"DELETE FROM newuser WHERE uid","vt":"str"},{"t":"cont","v":"INSERT INTO users","vt":"str"}],"checkall":"false","repair":false,"outputs":2,"x":1550,"y":520,"wires":[["daf8fd1a.da744","7a6e89ba.af0c98"],["be205a5f.b1b658"]]},{"id":"7a6e89ba.af0c98","type":"link out","z":"5da0880e.c537d","name":"","links":["36d1ce90.0ebc42"],"x":1695,"y":500,"wires":[]},{"id":"bebaa6f9.d7a698","type":"switch","z":"5da0880e.c537d","name":"","property":"topic","propertyType":"msg","rules":[{"t":"cont","v":"Select * from users","vt":"str"},{"t":"cont","v":"INSERT INTO users","vt":"str"}],"checkall":"false","repair":false,"outputs":2,"x":1490,"y":940,"wires":[["6e35c1b2.06214"],["d5b6f03.c3ba11"]]},{"id":"50d57b25.b09744","type":"switch","z":"5da0880e.c537d","name":"","property":"topic","propertyType":"msg","rules":[{"t":"cont","v":"SELECT COUNT(*) FROM events","vt":"str"},{"t":"cont","v":"SELECT COUNT(*) FROM accesslog","vt":"str"}],"checkall":"false","repair":false,"outputs":2,"x":430,"y":1800,"wires":[["2a95f935.2ca0a6"],["44e86277.84644c"]]},{"id":"1ab00e98.cef0c1","type":"debug","z":"5da0880e.c537d","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":610,"y":1240,"wires":[]},{"id":"c264cdd5.9ebcc8","type":"mqtt-broker","z":"","name":"IOT","broker":"localhost","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"833fda8f.b825a8","type":"MySQLdatabase","z":"","host":"127.0.0.1","port":"3306","db":"esp-door","tz":""},{"id":"f74cd7d7.b7cdc8","type":"ui_group","z":"","name":"Reader List","tab":"f0b5fcb6.816c7","order":1,"disp":true,"width":"12","collapse":true},{"id":"27ac83fc.9d43cc","type":"ui_group","z":"","name":"User List","tab":"f0b5fcb6.816c7","order":2,"disp":true,"width":"12","collapse":true},{"id":"9f2672e3.3b8cd","type":"ui_group","z":"","name":"Unknown RFID","tab":"f0b5fcb6.816c7","order":3,"disp":true,"width":"12","collapse":true},{"id":"3593b017.0613f","type":"ui_group","z":"","name":"Access Log","tab":"f0b5fcb6.816c7","order":5,"disp":true,"width":"12","collapse":true},{"id":"e96ae11.a1dd42","type":"ui_group","z":"","name":"Event Logs","tab":"f0b5fcb6.816c7","order":4,"disp":true,"width":"12","collapse":true},{"id":"f0b5fcb6.816c7","type":"ui_tab","z":"","name":"Door","icon":"dashboard","order":6,"disabled":false,"hidden":false}]
Created 8 years, 1 month ago
Rating: 5 2
  • comment (x8)
  • debug (x6)
  • delay (x2)
  • function (x36)
  • http in (x1)
  • inject (x5)
  • json (x3)
  • link in (x9)
  • link out (x14)
  • mqtt in (x3)
  • mqtt out (x1)
  • mqtt-broker (x1)
  • switch (x6)
  • RFID
  • WIEGAND
  • MQTT
  • Doorlock
  • look
  • smarthome
  • access
  • ESP8266
  • arduino
