Classify an image
This flow uses the https://developer.ibm.com/exchanges/models/all/max-inception-resnet-v2/ deep learning model from the Model Asset Exchange to identify objects in images using a third-generation deep residual network. Refer to the documentation for information about the returned message.
Install the following two modules to run this example flow:
Note: The inception-resnet-v2 node has been pre-configured to use a hosted model evaluation instance. We recommend using your own local or cloud instance for purposes other than evaluation.
[{"id":"689e4f8c.4f1a7","type":"tab","label":"Image classification example flow","disabled":false,"info":"This flow uses the https://developer.ibm.com/exchanges/models/all/max-inception-resnet-v2/ deep learning model from the Model Asset Exchange to identify objects in images using a third-generation deep residual network. Refer to the documentation for information about the returned message.\n\nInstall the following two modules to run this example flow:\n - [node-red-contrib-model-asset-exchange](https://www.npmjs.com/package/node-red-contrib-model-asset-exchange)\n - [node-red-contrib-browser-utils](https://www.npmjs.com/package/node-red-contrib-browser-utils)\n \n> Note: The inception-resnet-v2 node has been pre-configured to use a hosted model evaluation instance. We recommend using your own local or cloud instance for purposes other than evaluation."},{"id":"3d3b73cf.5c74ec","type":"debug","z":"689e4f8c.4f1a7","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":610,"y":120,"wires":[]},{"id":"528534f4.f6cf8c","type":"fileinject","z":"689e4f8c.4f1a7","name":"","x":140,"y":120,"wires":[["4b7e262c.e5b7e8"]]},{"id":"b2f7c59f.c2a7a8","type":"camera","z":"689e4f8c.4f1a7","name":"","x":150,"y":180,"wires":[["4b7e262c.e5b7e8"]]},{"id":"8beb18b5.880c28","type":"comment","z":"689e4f8c.4f1a7","name":"Classify an image ","info":"","x":120,"y":40,"wires":[]},{"id":"4b7e262c.e5b7e8","type":"inception-resnet-v2","z":"689e4f8c.4f1a7","service":"de324847.ff5a58","method":"predict","predict_image":"","predict_imageType":"str","name":"","x":370,"y":120,"wires":[["3d3b73cf.5c74ec"]]},{"id":"de324847.ff5a58","type":"inception-resnet-v2-service","z":"","host":"https://max-inception-resnet-v2.max.us-south.containers.appdomain.cloud","name":"cloud"}]
Created 8 years, 4 months ago
  • 'deep learning'
  • 'image classification'
  • max
