node-red-contrib-model-asset-exchange 0.2.8
Node-RED node for Model Asset eXchange
npm install node-red-contrib-model-asset-exchange
Build Status npm version
Node-RED nodes for deep learning microservices from the Model Asset eXchange, providing support for common audio, image, video, and text processing tasks.
Sample Node-RED Flow for MAX Object Detector
Getting started
To get started follow the comprehensive tutorial or complete the quick start steps listed below.
Setup
Docker installation
If you have Docker installed, you can use this Docker image to try out the examples.
Native installation
  1. Install Node-RED.
    Before you can install Node-RED, you'll need a working install of Node.js. We recommend the use of Node.js LTS 8.x or 10.x, as Node-RED no longer supports Node.js 6.x or earlier.
  2. Run the following command in your Node-RED user directory - typically ~/.node-red to install the node-red-contrib-model-asset-exchange module:
     $ cd ~/.node-red
     $ npm install node-red-contrib-model-asset-exchange
You can also install the module in the Node-RED editor. Choose ☰ > Manage palette > Install and enter model-asset as the search term.
  1. Launch Node-RED and open the displayed URL in a web browser to access the flow editor.
     $ node-red
       ... - [info] Server now running at http://127.0.0.1:1880/
  2. The nodes are displayed in the palette under the Model-Asset-eXchange category.
Explore the sample flows
The node-red-contrib-model-asset-exchange module includes a couple of example flows to get you started. To import the flows into the workspace:
  1. In the Node-RED editor open ☰ > Import > Examples > model asset exchange.
  2. Select one of the sub-directories to choose between the basic flows in getting started, some more complex examples in beyond the basics, or some flows designed to run on the raspberry pi.
  3. Choose a flow.
    import sample flows
Note: The flows utilize nodes from the node-red-contrib-browser-util and node-red-contrib-image-output modules. See the flow description for more details on which nodes are used in a particular example.
You can deploy and run these flows as is. The deep learning nodes in these flows have been pre-configured (service: cloud) to connect to hosted evaluation instances of the deep learning microservices.
Use the nodes in your own flows
Microservice evaluation instances are not suitable for production use. We recommend running microservice instance(s) on your local machine or in the cloud using IBM Cloud Kubernetes, Azure Kubernetes Service, or Google Kubernetes Engine:
  1. Deploy the deep learning microservice in the desired environment.
  2. Take note of its URL (e.g. http://localhost:5000)
  3. Add the corresponding deep learning node to your canvas.
  4. Open the node properties.
  5. Add a service entry for the URL and assign it a unique name.
configure microservice connectivity
Supported application domains
This Node-RED node module supports the following application domains:
Note: file inject node in node-red-contrib-browser-utils is useful to test these nodes.
Apache-2.0
Version: 0.2.8
Updated 7 years, 1 month ago
Rating: 4.3 7
100 in the last week
  • image-caption-generator
  • image-caption-generator-service
  • object-detector
  • object-detector-service
  • human-pose-estimator
  • human-pose-estimator-service
  • audio-classifier
  • audio-classifier-service
  • image-segmenter
  • image-segmenter-service
  • scene-classifier
  • scene-classifier-service
  • inception-resnet-v2
  • inception-resnet-v2-service
  • model asset exchange
  • image caption generator
  • object detector
  • human pose estimator
  • audio classifier
  • image segmenter
  • scene classifier
  • inception resnet v2
  • deep learning
