Individual roller blind control Shading 0/10/50/100% - HomeAssistant
  1. Roller blind bedroom should be set to 0 % shading
If early azimuth greater than 340 Crad suitable for my house. Or evening azimuth less than 160 Crad to suit my house. And the expected temperature is above 20 Crad, and it will be sunny or partly cloudy. And also all windows in the room under the blind are closed.
Then the shading should be set to 0% once. (i.e. completely closed)
  1. Roller blind bedroom should be set to 100 If either weekend is from 10 o'clock Or weekdays from 8 am.
And Asimuth greater than 130 Crad angle of incidence skylight has no more sun. And It is brighter than 100 lux on the terrace. Or Bedroom window has been opened to the right. Or Bedroom window left was opened.
Then The roller blind should open completely once, if it is not already completely open.
  1. Roller blind bedroom should be set to 50 % at night When Rollo not already 50 % and Outside temperature below 22 Crad. And Terrace darker 100 Lux. And All bedroom windows are closed.
Then The roller blind should be moved to 50 % once.
  1. Roller blind bedroom should be set to 10 % early to 2 hours before 100 When weekend is 2 hours before the roller blind opens completely. Or On weekdays 2 hours before the roller blind is fully open.
And It is brighter on the terrace with 50 lux. And All bedroom windows are closed.
The roller blind should then be set to 10% once so that you are not dazzled by the sun early in the morning.
  1. Feedback Unfortunately, the portal here is just as difficult to use as NodeRed. It is a pity that there seems to be no possibility for comments or mutual contact for mutual improvement.
Many, many hours of work have gone into my flows.
Suggestions on how to make flows easier or improve them are welcome via GitHub or https://www.facebook.com/Friek/
[{"id":"927ce83aaf4e922f","type":"tab","label":"Flow 1","disabled":false,"info":"","env":[]},{"id":"dcefb44c3f6408ee","type":"inject","z":"927ce83aaf4e922f","name":"Manueller Test","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":400,"y":140,"wires":[["01b1eaba18ef9ab9"]]},{"id":"ec7999e917ce87bc","type":"api-current-state","z":"927ce83aaf4e922f","name":"Schlafzimmer Fenster Rechts zu","server":"e26448c8b8b5c235","version":3,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"binary_sensor.0000d709a14889_state","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"30","forType":"num","forUnits":"seconds","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":330,"y":380,"wires":[["b36a3a58b53f2dbe"],["2231010e90abee42"]]},{"id":"b36a3a58b53f2dbe","type":"api-current-state","z":"927ce83aaf4e922f","name":"Schlafzimmer Fenster Links zu","server":"e26448c8b8b5c235","version":3,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"binary_sensor.0000e0c98cce18_state","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"30","forType":"num","forUnits":"seconds","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":330,"y":440,"wires":[["5345686e3abd5101"],["2231010e90abee42"]]},{"id":"db7352556df7916d","type":"comment","z":"927ce83aaf4e922f","name":"Rollo Schlafzimmer soll auf (100 %)","info":"","x":220,"y":680,"wires":[]},{"id":"34c02f0b14e69326","type":"comment","z":"927ce83aaf4e922f","name":"Rollo Schlafzimmer soll 50 % Nachts","info":"","x":220,"y":1380,"wires":[]},{"id":"7b0b07728edeacc3","type":"server-state-changed","z":"927ce83aaf4e922f","name":"Temp unter 22","server":"e26448c8b8b5c235","version":5,"outputs":2,"exposeAsEntityConfig":"","entityId":"sensor.openweathermap_temperature","entityIdType":"exact","outputInitially":true,"stateType":"str","ifState":"22","ifStateType":"num","ifStateOperator":"lt","outputOnlyOnStateChange":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"true","valueType":"bool"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":150,"y":1480,"wires":[["e80cab64528c8832","d030cdc1ee7d8903"],["0417c7e056cbf1d9"]]},{"id":"4f649f3dd8ff3bdf","type":"server-state-changed","z":"927ce83aaf4e922f","name":"Terasse dunkler 100 Lux","server":"e26448c8b8b5c235","version":5,"outputs":2,"exposeAsEntityConfig":"","entityId":"sensor.000d58a9ab10e8_average_illumination","entityIdType":"exact","outputInitially":true,"stateType":"num","ifState":"100","ifStateType":"num","ifStateOperator":"lt","outputOnlyOnStateChange":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"true","valueType":"bool"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":190,"y":1540,"wires":[["e80cab64528c8832","d030cdc1ee7d8903"],["0417c7e056cbf1d9"]]},{"id":"5f216b89e104f270","type":"server-state-changed","z":"927ce83aaf4e922f","name":"Schlafzimmer Fenster Rechts zu","server":"e26448c8b8b5c235","version":5,"outputs":2,"exposeAsEntityConfig":"","entityId":"binary_sensor.0000d709a14889_state","entityIdType":"exact","outputInitially":true,"stateType":"str","ifState":"off","ifStateType":"str","ifStateOperator":"is","outputOnlyOnStateChange":true,"for":"30","forType":"num","forUnits":"seconds","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"true","valueType":"bool"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":210,"y":1600,"wires":[["e80cab64528c8832","d030cdc1ee7d8903"],["0417c7e056cbf1d9"]]},{"id":"7c24d5d606043b54","type":"server-state-changed","z":"927ce83aaf4e922f","name":"Schlafzimmer Fenster Links zu","server":"e26448c8b8b5c235","version":5,"outputs":2,"exposeAsEntityConfig":"","entityId":"binary_sensor.0000e0c98cce18_state","entityIdType":"exact","outputInitially":true,"stateType":"str","ifState":"off","ifStateType":"str","ifStateOperator":"is","outputOnlyOnStateChange":true,"for":"30","forType":"num","forUnits":"seconds","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"},{"property":"payload","propertyType":"msg","value":"true","valueType":"bool"}],"x":210,"y":1660,"wires":[["e80cab64528c8832","d030cdc1ee7d8903"],["0417c7e056cbf1d9"]]},{"id":"e80cab64528c8832","type":"debug","z":"927ce83aaf4e922f","name":"Eingang debug 50","active":false,"tosidebar":true,"console":true,"tostatus":true,"complete":"true","targetType":"full","statusVal":"payload","statusType":"auto","x":260,"y":1760,"wires":[]},{"id":"3ca30afb32c997b8","type":"server-state-changed","z":"927ce83aaf4e922f","d":true,"name":"SZ Rollo nicht bereits 50 %","server":"e26448c8b8b5c235","version":5,"outputs":2,"exposeAsEntityConfig":"","entityId":"cover.frieks_schlafzimmerrollo","entityIdType":"exact","outputInitially":true,"stateType":"str","ifState":"open","ifStateType":"str","ifStateOperator":"is","outputOnlyOnStateChange":false,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"true","valueType":"bool"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":190,"y":1420,"wires":[["aadb1fb4835f4225","e80cab64528c8832"],[]]},{"id":"aadb1fb4835f4225","type":"switch","z":"927ce83aaf4e922f","d":true,"name":"Is position nicht 50?","property":"data.new_state.attributes.current_position","propertyType":"msg","rules":[{"t":"neq","v":"50","vt":"str"},{"t":"eq","v":"50","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":440,"y":1420,"wires":[["8a14c1d3c6306b10","d030cdc1ee7d8903"],["8a14c1d3c6306b10"]]},{"id":"8a14c1d3c6306b10","type":"debug","z":"927ce83aaf4e922f","d":true,"name":"Ist nicht position 50!","active":false,"tosidebar":true,"console":false,"tostatus":true,"complete":"data.new_state.attributes.current_position","targetType":"msg","statusVal":"payload","statusType":"auto","x":720,"y":1420,"wires":[]},{"id":"6dca2f42d45cd177","type":"server-state-changed","z":"927ce83aaf4e922f","name":"Oder Schlafzimmer Fenster Rechts auf","server":"e26448c8b8b5c235","version":5,"outputs":2,"exposeAsEntityConfig":"","entityId":"binary_sensor.0000d709a14889_state","entityIdType":"exact","outputInitially":true,"stateType":"str","ifState":"off","ifStateType":"str","ifStateOperator":"is_not","outputOnlyOnStateChange":true,"for":"0","forType":"num","forUnits":"seconds","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"true","valueType":"bool"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":230,"y":1060,"wires":[["2b73657e7c51343c","6d04bc966ef13bc8"],[]]},{"id":"7ef139201cfe0f9f","type":"server-state-changed","z":"927ce83aaf4e922f","name":"Oder Schlafzimmer Fenster Links auf","server":"e26448c8b8b5c235","version":5,"outputs":2,"exposeAsEntityConfig":"","entityId":"binary_sensor.0000e0c98cce18_state","entityIdType":"exact","outputInitially":true,"stateType":"str","ifState":"off","ifStateType":"str","ifStateOperator":"is_not","outputOnlyOnStateChange":true,"for":"0","forType":"num","forUnits":"seconds","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"true","valueType":"bool"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":230,"y":1140,"wires":[["2b73657e7c51343c","6d04bc966ef13bc8"],[]]},{"id":"1fb6d5b75f8d16c5","type":"switch","z":"927ce83aaf4e922f","name":"Is position nicht 100?","property":"data.attributes.current_position","propertyType":"msg","rules":[{"t":"lt","v":"95","vt":"num"},{"t":"gt","v":"95","vt":"num"}],"checkall":"true","repair":false,"outputs":2,"x":1040,"y":1200,"wires":[["c16ce318fee81cf7","011ecb92d8689177"],["f74a4f484bf89b34"]]},{"id":"7b19821d2b759a6a","type":"bigtimer","z":"927ce83aaf4e922f","outtopic":"Zeit-aktiv","outpayload1":"true","outpayload2":"false","name":"Start werktags 8 Uhr frühestens","comment":"Zeit-aktiv","lat":"49","lon":"10","starttime":"480","endtime":"5004","starttime2":0,"endtime2":0,"startoff":0,"endoff":0,"startoff2":0,"endoff2":0,"offs":0,"outtext1":"","outtext2":"","timeout":1440,"sun":false,"mon":true,"tue":true,"wed":true,"thu":true,"fri":true,"sat":false,"jan":true,"feb":true,"mar":true,"apr":true,"may":true,"jun":true,"jul":true,"aug":true,"sep":true,"oct":true,"nov":true,"dec":true,"day1":0,"month1":0,"day2":0,"month2":0,"day3":0,"month3":0,"day4":0,"month4":0,"day5":0,"month5":0,"day6":0,"month6":0,"day7":0,"month7":0,"day8":0,"month8":0,"day9":0,"month9":0,"day10":0,"month10":0,"day11":0,"month11":0,"day12":0,"month12":0,"d1":0,"w1":0,"d2":0,"w2":0,"d3":0,"w3":0,"d4":0,"w4":0,"d5":0,"w5":0,"d6":0,"w6":0,"xday1":0,"xmonth1":0,"xday2":0,"xmonth2":0,"xday3":0,"xmonth3":0,"xday4":0,"xmonth4":0,"xday5":0,"xmonth5":0,"xday6":0,"xmonth6":0,"xday7":0,"xmonth7":0,"xday8":0,"xmonth8":0,"xday9":0,"xmonth9":0,"xday10":0,"xmonth10":0,"xday11":0,"xmonth11":0,"xday12":0,"xmonth12":0,"xd1":0,"xw1":0,"xd2":0,"xw2":0,"xd3":0,"xw3":0,"xd4":0,"xw4":0,"xd5":0,"xw5":0,"xd6":0,"xw6":0,"suspend":false,"random":false,"randon1":false,"randoff1":false,"randon2":false,"randoff2":false,"repeat":true,"atstart":true,"odd":false,"even":false,"x":210,"y":800,"wires":[["2508c4fe0dff3b72"],[],[]]},{"id":"ab3a676f368876ab","type":"bigtimer","z":"927ce83aaf4e922f","outtopic":"Zeit-aktiv","outpayload1":"true","outpayload2":"false","name":"Start Wochenende 10 Uhr frühestens","comment":"Zeit-aktiv","lat":"49","lon":"10","starttime":"600","endtime":"5004","starttime2":0,"endtime2":0,"startoff":0,"endoff":0,"startoff2":0,"endoff2":0,"offs":0,"outtext1":"","outtext2":"","timeout":1440,"sun":true,"mon":false,"tue":false,"wed":false,"thu":false,"fri":false,"sat":true,"jan":true,"feb":true,"mar":true,"apr":true,"may":true,"jun":true,"jul":true,"aug":true,"sep":true,"oct":true,"nov":true,"dec":true,"day1":0,"month1":0,"day2":0,"month2":0,"day3":0,"month3":0,"day4":0,"month4":0,"day5":0,"month5":0,"day6":0,"month6":0,"day7":0,"month7":0,"day8":0,"month8":0,"day9":0,"month9":0,"day10":0,"month10":0,"day11":0,"month11":0,"day12":0,"month12":0,"d1":0,"w1":0,"d2":0,"w2":0,"d3":0,"w3":0,"d4":0,"w4":0,"d5":0,"w5":0,"d6":0,"w6":0,"xday1":0,"xmonth1":0,"xday2":0,"xmonth2":0,"xday3":0,"xmonth3":0,"xday4":0,"xmonth4":0,"xday5":0,"xmonth5":0,"xday6":0,"xmonth6":0,"xday7":0,"xmonth7":0,"xday8":0,"xmonth8":0,"xday9":0,"xmonth9":0,"xday10":0,"xmonth10":0,"xday11":0,"xmonth11":0,"xday12":0,"xmonth12":0,"xd1":0,"xw1":0,"xd2":0,"xw2":0,"xd3":0,"xw3":0,"xd4":0,"xw4":0,"xd5":0,"xw5":0,"xd6":0,"xw6":0,"suspend":false,"random":false,"randon1":false,"randoff1":false,"randon2":false,"randoff2":false,"repeat":true,"atstart":true,"odd":false,"even":false,"x":230,"y":740,"wires":[["2508c4fe0dff3b72"],[],[]]},{"id":"48dc337b072b1e18","type":"api-call-service","z":"927ce83aaf4e922f","name":"Rollo Schlafzimmer auf 50 %","server":"e26448c8b8b5c235","version":5,"debugenabled":false,"domain":"cover","service":"set_cover_position","areaId":[],"deviceId":[],"entityId":["cover.frieks_schlafzimmerrollo"],"data":"{\"position\": 50}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[{"property":"cover.set_cover_position","propertyType":"msg","value":"50","valueType":"num"}],"queue":"none","x":960,"y":1680,"wires":[[]]},{"id":"011ecb92d8689177","type":"api-call-service","z":"927ce83aaf4e922f","name":"Rollo Schlafzimmer auf 100 %","server":"e26448c8b8b5c235","version":5,"debugenabled":false,"domain":"cover","service":"set_cover_position","areaId":[],"deviceId":[],"entityId":["cover.frieks_schlafzimmerrollo"],"data":"{\"position\": 100}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[{"property":"cover.set_cover_position","propertyType":"msg","value":"100","valueType":"num"}],"queue":"none","x":1310,"y":1160,"wires":[[]]},{"id":"2508c4fe0dff3b72","type":"or-gate","z":"927ce83aaf4e922f","name":"OR-Gate","rules":[{"t":"eq","v":"true","vt":"str","propertyType":"msg","property":"payload","topic":"Zeit-aktiv"}],"outputTopic":"OR-Gate","gateType":"or","emitOnlyIfTrue":false,"x":480,"y":780,"wires":[["2b73657e7c51343c","480af31f1e0ed8c4"]]},{"id":"29bedd384dbf2b31","type":"change","z":"927ce83aaf4e922f","name":"Wandle String in Number","rules":[{"t":"set","p":"data.attributes.current_position","pt":"msg","to":"data.attributes.current_position","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":810,"y":1200,"wires":[["1fb6d5b75f8d16c5"]]},{"id":"2b73657e7c51343c","type":"debug","z":"927ce83aaf4e922f","name":"Eingang debug 100","active":false,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":570,"y":1120,"wires":[]},{"id":"d030cdc1ee7d8903","type":"BooleanLogicUltimate","z":"927ce83aaf4e922f","name":"AND","payloadPropName":"payload","filtertrue":"onlytrue","persist":true,"sInitializeWith":"WaitForPayload","triggertopic":"true","outputtriggeredby":"all","inputCount":"4","topic":"result","restrictinputevaluation":false,"delayEvaluation":0,"translatorConfig":"","x":560,"y":1500,"wires":[["bd2a7e5af175fe6e","29042d5a5fdffb7b"],[],[]]},{"id":"bd2a7e5af175fe6e","type":"debug","z":"927ce83aaf4e922f","name":"Gate 5","active":false,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":750,"y":1480,"wires":[]},{"id":"675124a43891555a","type":"change","z":"927ce83aaf4e922f","name":"Setze Nein auf False","rules":[{"t":"set","p":"payload","pt":"msg","to":"False","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":600,"y":1060,"wires":[["480af31f1e0ed8c4","182a892b5d8944df"]]},{"id":"480af31f1e0ed8c4","type":"BooleanLogicUltimate","z":"927ce83aaf4e922f","name":"AND","payloadPropName":"payload","filtertrue":"onlytrue","persist":true,"sInitializeWith":"WaitForPayload","triggertopic":"true","outputtriggeredby":"all","inputCount":"3","topic":"result","restrictinputevaluation":false,"delayEvaluation":0,"translatorConfig":"","x":700,"y":980,"wires":[["609ae8d3f6c61efc","34722ae04e5c7ed3"],[],[]]},{"id":"609ae8d3f6c61efc","type":"debug","z":"927ce83aaf4e922f","name":"Gate 4","active":false,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":950,"y":980,"wires":[]},{"id":"c16ce318fee81cf7","type":"debug","z":"927ce83aaf4e922f","name":"Ist nicht position 100!","active":false,"tosidebar":true,"console":true,"tostatus":true,"complete":"data.attributes.current_position","targetType":"msg","statusVal":"payload","statusType":"auto","x":1310,"y":1220,"wires":[]},{"id":"8ca94229014ea4f4","type":"api-call-service","z":"927ce83aaf4e922f","name":"Rollo Schlafzimmer auf 0 %","server":"e26448c8b8b5c235","version":5,"debugenabled":false,"domain":"cover","service":"set_cover_position","areaId":[],"deviceId":[],"entityId":["cover.frieks_schlafzimmerrollo"],"data":"{\"position\": 0}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[{"property":"cover.set_cover_position","propertyType":"msg","value":"0","valueType":"num"}],"queue":"none","x":940,"y":440,"wires":[[]]},{"id":"5345686e3abd5101","type":"function","z":"927ce83aaf4e922f","name":"Verschattung einmal aktiv setzen","func":"var speicher = flow.get('verschattung_aktiv') || \"Nein\";\nif (speicher===\"Nein\")\n{\n    flow.set('verschattung_aktiv',\"Ja\");\n    msg.payload=\"Ja\";\n    return msg;\n} else {\n    return null;\n}","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":640,"y":440,"wires":[["8ca94229014ea4f4"]]},{"id":"610db465d0fa4031","type":"trigger-state","z":"927ce83aaf4e922f","name":"Abend Azimuth kleiner 160 Crad Einfallswinkel Dachfenster Sonne","server":"e26448c8b8b5c235","version":4,"inputs":0,"outputs":2,"exposeAsEntityConfig":"","entityId":"sensor.sun_azimuth","entityIdType":"exact","debugEnabled":false,"constraints":[{"targetType":"this_entity","targetValue":"","propertyType":"current_state","propertyValue":"new_state.state","comparatorType":"<=","comparatorValueDatatype":"num","comparatorValue":"160"}],"customOutputs":[],"outputInitially":true,"stateType":"num","enableInput":false,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"x":300,"y":280,"wires":[["01b1eaba18ef9ab9"],["2231010e90abee42"]]},{"id":"01b1eaba18ef9ab9","type":"api-current-state","z":"927ce83aaf4e922f","name":"Erw. Temperatur über 20","server":"e26448c8b8b5c235","version":3,"outputs":2,"halt_if":"20","halt_if_type":"num","halt_if_compare":"gte","entity_id":"sensor.openweathermap_forecast_temperature","state_type":"num","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","x":710,"y":260,"wires":[["7e61363b13d8cc74","329b59a8dd089bf0"],["2231010e90abee42"]]},{"id":"f592a8a2126d04d0","type":"trigger-state","z":"927ce83aaf4e922f","name":"Asimuth größer 130 Crad Einfallswinkel Dachfenster keine Sonne mehr","server":"e26448c8b8b5c235","version":4,"inputs":0,"outputs":2,"exposeAsEntityConfig":"","entityId":"sensor.sun_azimuth","entityIdType":"exact","debugEnabled":false,"constraints":[{"targetType":"this_entity","targetValue":"","propertyType":"current_state","propertyValue":"new_state.state","comparatorType":">","comparatorValueDatatype":"num","comparatorValue":"130"}],"customOutputs":[],"outputInitially":true,"stateType":"num","enableInput":false,"x":330,"y":860,"wires":[["480af31f1e0ed8c4"],["675124a43891555a"]]},{"id":"0b619905aaa2b43d","type":"trigger-state","z":"927ce83aaf4e922f","name":"Terasse heller 100 Lux","server":"e26448c8b8b5c235","version":4,"inputs":0,"outputs":2,"exposeAsEntityConfig":"","entityId":"sensor.000d58a9ab10e8_average_illumination","entityIdType":"exact","debugEnabled":false,"constraints":[{"targetType":"this_entity","targetValue":"","propertyType":"current_state","propertyValue":"new_state.state","comparatorType":">","comparatorValueDatatype":"num","comparatorValue":"100"}],"customOutputs":[],"outputInitially":true,"stateType":"num","enableInput":false,"x":180,"y":920,"wires":[["480af31f1e0ed8c4"],["675124a43891555a"]]},{"id":"34722ae04e5c7ed3","type":"function","z":"927ce83aaf4e922f","name":"Rollo einmal aktiv 100 setzen","func":"var speicher = flow.get('rollo_100_aktiv') || \"Nein\";\nif (speicher === \"Nein\") {\n    flow.set('rollo_100_aktiv', \"Ja\");\n    msg.payload = \"Ja\";\n    return msg;\n} else {\n    return null;\n}\n","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":960,"y":1060,"wires":[["011ecb92d8689177","c6dcb61669136740"]]},{"id":"c6dcb61669136740","type":"debug","z":"927ce83aaf4e922f","name":"debug 37","active":false,"tosidebar":true,"console":true,"tostatus":true,"complete":"true","targetType":"full","statusVal":"payload","statusType":"auto","x":1230,"y":1040,"wires":[]},{"id":"182a892b5d8944df","type":"function","z":"927ce83aaf4e922f","name":"Rollo einmal inaktiv 100 setzen","func":"var speicher = flow.get('rollo_100_aktiv') || \"Nein\";\nif (speicher===\"Ja\")\n{\n    flow.set('rollo_100_aktiv',\"Nein\");\n    msg.payload=\"Nein\";\n    return msg;\n} else {\n    return null;\n}\n","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":950,"y":1100,"wires":[["c6dcb61669136740","99a2172b3c4c5a2f"]]},{"id":"29042d5a5fdffb7b","type":"function","z":"927ce83aaf4e922f","name":"Rollo einmal aktiv 50 setzen","func":"var speicher = flow.get('rollo_50_aktiv') || \"Nein\";\nif (speicher === \"Nein\") {\n    flow.set('rollo_50_aktiv', \"Ja\");\n    msg.payload = \"Ja\";\n    return msg;\n} else {\n    return null;\n}\n","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":960,"y":1560,"wires":[["45fd7da43ce72fd5","48dc337b072b1e18"]]},{"id":"45fd7da43ce72fd5","type":"debug","z":"927ce83aaf4e922f","name":"debug 38","active":false,"tosidebar":true,"console":true,"tostatus":true,"complete":"true","targetType":"full","statusVal":"payload","statusType":"auto","x":1190,"y":1540,"wires":[]},{"id":"675d484d9089b879","type":"function","z":"927ce83aaf4e922f","name":"Rollo einmal inaktiv 50 setzen","func":"var speicher = flow.get('rollo_50_aktiv') || \"Nein\";\nif (speicher===\"Ja\")\n{\n    flow.set('rollo_50_aktiv',\"Nein\");\n    msg.payload=\"Nein\";\n    return msg;\n} else {\n    return null;\n}\n","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":830,"y":1600,"wires":[["45fd7da43ce72fd5"]]},{"id":"0417c7e056cbf1d9","type":"change","z":"927ce83aaf4e922f","name":"Setze Nein auf False","rules":[{"t":"set","p":"payload","pt":"msg","to":"False","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":560,"y":1600,"wires":[["675d484d9089b879","d030cdc1ee7d8903"]]},{"id":"1e5a7f71e70cfad3","type":"comment","z":"927ce83aaf4e922f","name":"Rollo Schlafzimmer soll auf Verschattung 0 %","info":"","x":250,"y":80,"wires":[]},{"id":"2231010e90abee42","type":"function","z":"927ce83aaf4e922f","name":"Verschattung inaktiv setzen","func":"var speicher = flow.get('verschattung_aktiv') || \"Nein\";\nif (speicher===\"Ja\")\n{\n    flow.set('verschattung_aktiv',\"Nein\");\n    msg.payload=\"Nein\";\n    return msg;\n} else {\n    return null;\n}","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":680,"y":380,"wires":[[]]},{"id":"7e61363b13d8cc74","type":"api-current-state","z":"927ce83aaf4e922f","name":"Wird es Sonnig?","server":"e26448c8b8b5c235","version":3,"outputs":2,"halt_if":"sunny","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.openweathermap_condition","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":940,"y":200,"wires":[["67e84d4da8d74646"],["2231010e90abee42"]]},{"id":"329b59a8dd089bf0","type":"api-current-state","z":"927ce83aaf4e922f","name":"Wird es teilweise bedeckt?","server":"e26448c8b8b5c235","version":3,"outputs":2,"halt_if":"partlycloudy","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.openweathermap_condition","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":980,"y":260,"wires":[["67e84d4da8d74646"],["2231010e90abee42"]]},{"id":"282c852647cb99bb","type":"link in","z":"927ce83aaf4e922f","name":"Rollo dunkel raus","links":["67e84d4da8d74646"],"x":135,"y":400,"wires":[["ec7999e917ce87bc"]]},{"id":"67e84d4da8d74646","type":"link out","z":"927ce83aaf4e922f","name":"Schlafzimmer Rollo dunkel rein","mode":"link","links":["282c852647cb99bb"],"x":1175,"y":220,"wires":[]},{"id":"6d04bc966ef13bc8","type":"api-current-state","z":"927ce83aaf4e922f","name":"SZ Rollo nicht 100% offen","server":"e26448c8b8b5c235","version":3,"outputs":2,"halt_if":"open","halt_if_type":"str","halt_if_compare":"is","entity_id":"cover.frieks_schlafzimmerrollo","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":570,"y":1220,"wires":[["29bedd384dbf2b31"],[]]},{"id":"cb08d6b1ee1332be","type":"comment","z":"927ce83aaf4e922f","name":"Rollo Schlafzimmer soll zu 10 % früh bis 2 Stunden vor 100 %","info":"","x":300,"y":1840,"wires":[]},{"id":"0127733f5098bbc5","type":"server-state-changed","z":"927ce83aaf4e922f","name":"Oder Schlafzimmer Fenster Rechts auf","server":"e26448c8b8b5c235","version":5,"outputs":2,"exposeAsEntityConfig":"","entityId":"binary_sensor.0000d709a14889_state","entityIdType":"exact","outputInitially":true,"stateType":"str","ifState":"off","ifStateType":"str","ifStateOperator":"is_not","outputOnlyOnStateChange":true,"for":"30","forType":"num","forUnits":"seconds","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"true","valueType":"bool"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":230,"y":2220,"wires":[[],["d141ff71f402f9bb","f78670abdbf24d70"]]},{"id":"1453bf62567f3d0b","type":"server-state-changed","z":"927ce83aaf4e922f","name":"Oder Schlafzimmer Fenster Links auf","server":"e26448c8b8b5c235","version":5,"outputs":2,"exposeAsEntityConfig":"","entityId":"binary_sensor.0000e0c98cce18_state","entityIdType":"exact","outputInitially":true,"stateType":"str","ifState":"off","ifStateType":"str","ifStateOperator":"is_not","outputOnlyOnStateChange":true,"for":"30","forType":"num","forUnits":"seconds","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"true","valueType":"bool"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":230,"y":2300,"wires":[[],["d141ff71f402f9bb","f78670abdbf24d70"]]},{"id":"c6052ee701aa8bde","type":"bigtimer","z":"927ce83aaf4e922f","outtopic":"Zeit-aktiv","outpayload1":"true","outpayload2":"false","name":"Start werktags 8-2 Uhr frühestens","comment":"Zeit-aktiv","lat":"49","lon":"10","starttime":"300","endtime":"390","starttime2":0,"endtime2":0,"startoff":0,"endoff":0,"startoff2":0,"endoff2":0,"offs":0,"outtext1":"","outtext2":"","timeout":1440,"sun":false,"mon":true,"tue":true,"wed":true,"thu":true,"fri":true,"sat":false,"jan":true,"feb":true,"mar":true,"apr":true,"may":true,"jun":true,"jul":true,"aug":true,"sep":true,"oct":true,"nov":true,"dec":true,"day1":0,"month1":0,"day2":0,"month2":0,"day3":0,"month3":0,"day4":0,"month4":0,"day5":0,"month5":0,"day6":0,"month6":0,"day7":0,"month7":0,"day8":0,"month8":0,"day9":0,"month9":0,"day10":0,"month10":0,"day11":0,"month11":0,"day12":0,"month12":0,"d1":0,"w1":0,"d2":0,"w2":0,"d3":0,"w3":0,"d4":0,"w4":0,"d5":0,"w5":0,"d6":0,"w6":0,"xday1":0,"xmonth1":0,"xday2":0,"xmonth2":0,"xday3":0,"xmonth3":0,"xday4":0,"xmonth4":0,"xday5":0,"xmonth5":0,"xday6":0,"xmonth6":0,"xday7":0,"xmonth7":0,"xday8":0,"xmonth8":0,"xday9":0,"xmonth9":0,"xday10":0,"xmonth10":0,"xday11":0,"xmonth11":0,"xday12":0,"xmonth12":0,"xd1":0,"xw1":0,"xd2":0,"xw2":0,"xd3":0,"xw3":0,"xd4":0,"xw4":0,"xd5":0,"xw5":0,"xd6":0,"xw6":0,"suspend":false,"random":false,"randon1":false,"randoff1":false,"randon2":false,"randoff2":false,"repeat":true,"atstart":true,"odd":false,"even":false,"x":220,"y":1980,"wires":[["b739b9502f4a9d95"],[],[]]},{"id":"fadebf3b144dacbf","type":"bigtimer","z":"927ce83aaf4e922f","outtopic":"Zeit-aktiv","outpayload1":"true","outpayload2":"false","name":"Start Wochenende 10-2 Uhr frühestens","comment":"Zeit-aktiv","lat":"49","lon":"10","starttime":"300","endtime":"480","starttime2":0,"endtime2":0,"startoff":0,"endoff":0,"startoff2":0,"endoff2":0,"offs":0,"outtext1":"","outtext2":"","timeout":1440,"sun":true,"mon":false,"tue":false,"wed":false,"thu":false,"fri":false,"sat":true,"jan":true,"feb":true,"mar":true,"apr":true,"may":true,"jun":true,"jul":true,"aug":true,"sep":true,"oct":true,"nov":true,"dec":true,"day1":0,"month1":0,"day2":0,"month2":0,"day3":0,"month3":0,"day4":0,"month4":0,"day5":0,"month5":0,"day6":0,"month6":0,"day7":0,"month7":0,"day8":0,"month8":0,"day9":0,"month9":0,"day10":0,"month10":0,"day11":0,"month11":0,"day12":0,"month12":0,"d1":0,"w1":0,"d2":0,"w2":0,"d3":0,"w3":0,"d4":0,"w4":0,"d5":0,"w5":0,"d6":0,"w6":0,"xday1":0,"xmonth1":0,"xday2":0,"xmonth2":0,"xday3":0,"xmonth3":0,"xday4":0,"xmonth4":0,"xday5":0,"xmonth5":0,"xday6":0,"xmonth6":0,"xday7":0,"xmonth7":0,"xday8":0,"xmonth8":0,"xday9":0,"xmonth9":0,"xday10":0,"xmonth10":0,"xday11":0,"xmonth11":0,"xday12":0,"xmonth12":0,"xd1":0,"xw1":0,"xd2":0,"xw2":0,"xd3":0,"xw3":0,"xd4":0,"xw4":0,"xd5":0,"xw5":0,"xd6":0,"xw6":0,"suspend":false,"random":false,"randon1":false,"randoff1":false,"randon2":false,"randoff2":false,"repeat":true,"atstart":true,"odd":false,"even":false,"x":230,"y":1920,"wires":[["b739b9502f4a9d95"],[],[]]},{"id":"cc8958938847a1d0","type":"api-call-service","z":"927ce83aaf4e922f","name":"Rollo Schlafzimmer auf 10 %","server":"e26448c8b8b5c235","version":5,"debugenabled":false,"domain":"cover","service":"set_cover_position","areaId":[],"deviceId":[],"entityId":["cover.frieks_schlafzimmerrollo"],"data":"{\"position\": 10}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[{"property":"cover.set_cover_position","propertyType":"msg","value":"10","valueType":"num"}],"queue":"none","x":1280,"y":2200,"wires":[[]]},{"id":"b739b9502f4a9d95","type":"or-gate","z":"927ce83aaf4e922f","name":"OR-Gate","rules":[{"t":"eq","v":"true","vt":"str","propertyType":"msg","property":"payload","topic":"Zeit-aktiv"}],"outputTopic":"OR-Gate","gateType":"or","emitOnlyIfTrue":false,"x":480,"y":1960,"wires":[["8a147513ee1e991f","d141ff71f402f9bb"]]},{"id":"8a147513ee1e991f","type":"debug","z":"927ce83aaf4e922f","name":"Eingang debug 10","active":false,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":690,"y":1940,"wires":[]},{"id":"92e2baa8b1bcc97d","type":"change","z":"927ce83aaf4e922f","name":"Setze Nein auf False","rules":[{"t":"set","p":"payload","pt":"msg","to":"False","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":600,"y":2200,"wires":[["d141ff71f402f9bb","ac7d46569c223beb"]]},{"id":"d141ff71f402f9bb","type":"BooleanLogicUltimate","z":"927ce83aaf4e922f","name":"AND","payloadPropName":"payload","filtertrue":"onlytrue","persist":true,"sInitializeWith":"WaitForPayload","triggertopic":"true","outputtriggeredby":"all","inputCount":"4","topic":"result","restrictinputevaluation":false,"delayEvaluation":0,"translatorConfig":"","x":640,"y":2080,"wires":[["88c6f3ffe569a026","1dc3abec94e6472a"],["916d0e4cba253abb"],[]]},{"id":"88c6f3ffe569a026","type":"debug","z":"927ce83aaf4e922f","name":"Gate 4 - Rollo 10% SZ","active":false,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":960,"y":2020,"wires":[]},{"id":"d95c3ef712c43bf9","type":"function","z":"927ce83aaf4e922f","name":"Rollo einmal aktiv 10 setzen","func":"var speicher = flow.get('rollo_10_aktiv') || \"Nein\";\nif (speicher === \"Nein\") {\n    flow.set('rollo_10_aktiv', \"Ja\");\n    msg.payload = \"Ja\";\n    return msg;\n} else {\n    return null;\n}\n","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":1260,"y":2120,"wires":[["cc8958938847a1d0","56abba3a8266ff0c"]]},{"id":"56abba3a8266ff0c","type":"debug","z":"927ce83aaf4e922f","name":"Rollo einmal 10 setzen","active":false,"tosidebar":true,"console":true,"tostatus":true,"complete":"true","targetType":"full","statusVal":"payload","statusType":"auto","x":1350,"y":2020,"wires":[]},{"id":"ac7d46569c223beb","type":"function","z":"927ce83aaf4e922f","name":"Rollo einmal inaktiv 10 setzen","func":"var speicher = flow.get('rollo_10_aktiv') || \"Nein\";\nif (speicher===\"Ja\")\n{\n    flow.set('rollo_10_aktiv',\"Nein\");\n    msg.payload=\"Nein\";\n    return msg;\n} else {\n    return null;\n}\n","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":890,"y":2200,"wires":[["56abba3a8266ff0c"]]},{"id":"f78670abdbf24d70","type":"debug","z":"927ce83aaf4e922f","name":"debug 39","active":false,"tosidebar":true,"console":true,"tostatus":true,"complete":"true","targetType":"full","statusVal":"payload","statusType":"auto","x":540,"y":2300,"wires":[]},{"id":"149537dba1a1ad01","type":"inject","z":"927ce83aaf4e922f","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":300,"y":1280,"wires":[["6d04bc966ef13bc8"]]},{"id":"f74a4f484bf89b34","type":"debug","z":"927ce83aaf4e922f","name":"SZ Rollo ist offen größer 95!","active":false,"tosidebar":true,"console":true,"tostatus":true,"complete":"data.attributes.current_position","targetType":"msg","statusVal":"data.attributes.current_position","statusType":"auto","x":1310,"y":1280,"wires":[]},{"id":"99a2172b3c4c5a2f","type":"debug","z":"927ce83aaf4e922f","name":"debug 40","active":false,"tosidebar":true,"console":true,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1230,"y":1100,"wires":[]},{"id":"916d0e4cba253abb","type":"debug","z":"927ce83aaf4e922f","name":"Rollo SZ 10% OR","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":950,"y":2060,"wires":[]},{"id":"5f86e3356ce50070","type":"debug","z":"927ce83aaf4e922f","name":"terasse heller 50 lux","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":280,"y":2140,"wires":[]},{"id":"db492827215b638f","type":"server-state-changed","z":"927ce83aaf4e922f","name":"Terasse heller 50 Lux","server":"e26448c8b8b5c235","version":5,"outputs":2,"exposeAsEntityConfig":"","entityId":"sensor.000d58a9ab10e8_average_illumination","entityIdType":"exact","outputInitially":true,"stateType":"num","ifState":"50","ifStateType":"num","ifStateOperator":"gt","outputOnlyOnStateChange":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"true","valueType":"bool"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":180,"y":2040,"wires":[["d141ff71f402f9bb","5f86e3356ce50070"],["92e2baa8b1bcc97d"]]},{"id":"1dc3abec94e6472a","type":"api-current-state","z":"927ce83aaf4e922f","name":"SZ Links zu","server":"e26448c8b8b5c235","version":3,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"binary_sensor.0000e0c98cce18_state","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":830,"y":2140,"wires":[["e89c0d5207646633"],[]]},{"id":"e89c0d5207646633","type":"api-current-state","z":"927ce83aaf4e922f","name":"SZ Rechts zu","server":"e26448c8b8b5c235","version":3,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"binary_sensor.0000d709a14889_state","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1000,"y":2140,"wires":[["d95c3ef712c43bf9"],[]]},{"id":"7bc1b4264d5bcdb9","type":"trigger-state","z":"927ce83aaf4e922f","name":"Früh Azimuth größer 340 Crad Einfallswinkel Dachfenster Sonne","server":"e26448c8b8b5c235","version":4,"inputs":0,"outputs":2,"exposeAsEntityConfig":"","entityId":"sensor.sun_azimuth","entityIdType":"exact","debugEnabled":false,"constraints":[{"targetType":"this_entity","targetValue":"","propertyType":"current_state","propertyValue":"new_state.state","comparatorType":">=","comparatorValueDatatype":"num","comparatorValue":"340"}],"customOutputs":[],"outputInitially":true,"stateType":"num","enableInput":false,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"x":290,"y":220,"wires":[["01b1eaba18ef9ab9"],["2231010e90abee42"]]},{"id":"e26448c8b8b5c235","type":"server","name":"Home Assistant Friek","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":false,"cacheJson":false,"heartbeat":false,"heartbeatInterval":"30","areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":": ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"default","statusTimeFormat":"h:m","enableGlobalContextStore":false}]
Created 1 year, 3 months ago
  • change (x4)
  • comment (x4)
  • debug (x16)
  • function (x8)
  • inject (x2)
  • link in (x1)
  • link out (x1)
  • switch (x2)
  • HomeAssistant
  • rollerblind
  • shading
