node-red-contrib-boolean-logic-ultimate 1.2.22
A set of Node-RED enhanced boolean logic and utility nodes, flow interruption, blinker, debouncer, invert, filter, toggle etc.., with persistent values after reboot. Compatible also with Homeassistant values.
Boolean Logic Ultimate
A collection of enhanced logic and utility nodes for Node-RED. It supports persistent values after reboot and conversion of common Home Assistant values.
Getting started
Install the package from the Node-RED palette manager or run this command in your Node-RED user directory:
npm install node-red-contrib-boolean-logic-ultimate
Importable flows are available from the Node-RED editor under Menu (☰) → Import → Examples, or directly in the examples/ folder. See the examples overview for the complete list.
📘 Documentation
The full documentation is on maxsupervibe.com, together with the help of every other Max Supervibe node.
Release notes: CHANGELOG.md
