Manage a website with node-red, google sheets and websocket
With the google sheets node (node-red-contrib-google-sheets) it is easy to setup a "cms like website" where you store your text for each page in a google sheet. With a short javascript on each page that communicates over websocket with the node-red server we have a convenient way of updating information on our website.
How to setup google sheets can be found here: https://flows.nodered.org/flow/a36ccbcfc43c264cda892383fe034fe3
In this example I use a div tag that is updated from google sheets. The javascript on the website can handle both text and html. Set the id of the div tag to received-text.
<script>
        const ws = new WebSocket('wss://myserver.onrender.com/nodes/ws/mywebsite'); // Replace with your server URL
        // When the WebSocket connection is open
        ws.addEventListener('open', () => {
            console.log('WebSocket connection established.');
            ws.send('Hello from the web page!'); // Send your message here
        ws.addEventListener('message', (event) => {
            const receivedText = event.data; // Assuming the server sends plain text or HTML
            const paragraphElement = document.getElementById('received-text');
            paragraphElement.innerHTML = receivedText; // Use innerHTML to handle HTML content
    </script>
If we want to avoid to much traffic and load on the node-red server we can save the text or html to github instead of sending it to the website over websocket and using a headless approach. This could be setup with a website hosted at netlify, cloudflare or other similar services.
[{"id":"7812f0c77c3b8d66","type":"tab","label":"my web page","disabled":false,"info":"","env":[]},{"id":"b142eb56d4ff7532","type":"websocket in","z":"7812f0c77c3b8d66","name":"websocket in","server":"2209ac3497499772","client":"","x":250,"y":180,"wires":[["f5a679a25edf4b3e"]]},{"id":"f64219ce19003389","type":"websocket out","z":"7812f0c77c3b8d66","name":"websocket out","server":"2209ac3497499772","client":"","x":750,"y":180,"wires":[]},{"id":"f5a679a25edf4b3e","type":"GSheet","z":"7812f0c77c3b8d66","creds":"2027e7ce351cf6b7","method":"get","action":"","sheet":"1dkdkcKKIXYrRIPpmTtKeLX66rQeLFogLQzj70Xc_8","cells":"Sheet1!A2","flatten":true,"name":"text for my page","x":430,"y":180,"wires":[["0aac57bed8d6aab2"]]},{"id":"0aac57bed8d6aab2","type":"split","z":"7812f0c77c3b8d66","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":580,"y":180,"wires":[["12f0815e3fddeee6","f64219ce19003389"]]},{"id":"12f0815e3fddeee6","type":"debug","z":"7812f0c77c3b8d66","name":"debug 571","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":740,"y":220,"wires":[]},{"id":"2209ac3497499772","type":"websocket-listener","path":"/ws/mysite","wholemsg":"false"},{"id":"2027e7ce351cf6b7","type":"gauth","name":""}]
Created 2 years, 5 months ago
Updated 1 year, 3 months ago
  • split (x1)
  • websocket in (x1)
  • websocket out (x1)
  • websocket-listener (x1)
  • GSheet (x1)
  • gauth (x1)
  • google sheets
  • node-red-contrib-google-sheets
  • update html
  • websocket
  • cms
