Marstek venus A --- Simple UI to control the schedule modes (modbus schedule registers) .
Node-red script with UI to control the Marstek venus
Simple UI to control the schedule modes (modbus schedule registers) without diging deep into marstek app to toggle the options. The flow is easy to adapt to your needs. For now the script is using software ranges the target soc registers don't react yet on the values stored. Maybe in the future with different firmware it is different. If the limit is reached the mode is changed to manual. If in the morning enough solar is detected it switches back to self mode for charging and back to manual if not enough is generated and back to self if it does. Started to implement Price based mode, using enever (zonneplan) day ahead prices looking for the cheap and expensive hours. Default is 4 cheapest hours to charge and 1 hour for the expensive hours to discharge max power and save some capacity for self mode. The flow makes use of the "node-red-contrib-modbus" nodes. Adapt the marstek Ip number to your "your Ip number" with port ":502" Support up to 3 batteries, just disable the UI nodes from batteries which are not used.
Also it is easier to remove/ disable batteries than adding them. Due to the discharge bug I changed to different way of controlling the batteries. From version 0.1.7 I'm using the schedule's which I can change via Modbus. This is now a basic version and power settings now need to be adapted in the flow but later it can be done in the UI. The power is now set to 1400W to avoid the bug.
🚨 Link to the latest flows: https://github.com/hansvanlin/Marstek-venus-EMS
image\
flow Reading modbus registers: image
flow Write to modbus registers:
[{"id":"85f954b04cbf1a86","type":"subflow","name":"0.x","info":"","category":"","in":[{"x":60,"y":70,"wires":[{"id":"94cb59f282c2c911"}]}],"out":[{"x":370,"y":70,"wires":[{"id":"94cb59f282c2c911","port":0}]}],"env":[],"meta":{},"color":"#DDAA99"},{"id":"94cb59f282c2c911","type":"change","z":"85f954b04cbf1a86","name":"Convert to 0.x","rules":[{"t":"set","p":"payload","pt":"msg","to":"$number(msg.payload)\t\t","tot":"jsonata"},{"t":"set","p":"payload","pt":"msg","to":"$round(msg.payload, 1)\t","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":220,"y":70,"wires":[[]]},{"id":"3f235640b7cb44a9","type":"subflow","name":"0.xx","info":"","category":"","in":[{"x":60,"y":75,"wires":[{"id":"87ed2ab53564d859"},{"id":"57918fca3037144d"}]}],"out":[{"x":315,"y":75,"wires":[{"id":"57918fca3037144d","port":0}]}],"env":[],"meta":{},"color":"#DDAA99"},{"id":"87ed2ab53564d859","type":"function","z":"3f235640b7cb44a9","d":true,"name":"0.xx","func":"msg.payload = msg.payload.toFixed(2);\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":185,"y":75,"wires":[[]]},{"id":"57918fca3037144d","type":"change","z":"3f235640b7cb44a9","name":"Convert to 0.xx","rules":[{"t":"set","p":"payload","pt":"msg","to":"$number(msg.payload)\t\t","tot":"jsonata"},{"t":"set","p":"payload","pt":"msg","to":"$round(msg.payload, 2)\t","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":210,"y":160,"wires":[[]]},{"id":"8f32aaab05a0cf37","type":"tab","label":"Marstek","disabled":false,"info":"","env":[]},{"id":"6f3b06f9eece4ad3","type":"group","z":"8f32aaab05a0cf37","name":"Read modbus ","style":{"fill":"#c8e7a7","label":true,"color":"#000000"},"nodes":["6c4d3c287aec0c3e","4dfe5e2e19855d95","20f3caf5a2c0f481","32bd41d8e08a9b3b","54fa5f8bfb25d834","95b0b07b044c8838","90b1aba38348c387","a675f7131ee80f92","215d5466c4b068ec","042bb002e66c3f8c","88c3c38799829dc0","a49fd8e446273768","30c277fd994b3251","453e82db14621418","048de029a5d1ec8b","675866f5a0b9691f","92543281bc95c695","6a876bc9bc3262e7","36c5487010a1bd25","34eacb9e7e37bfcf","1c52218d552d26f3","b2a5504cc482e999","71d3a563e018f274","e3377b502f96ac1e","b5bb6dc92fe70310","cd0467fd237b7f8a","9889d5182e1600f5","bb2b200201d6c233","43c4aa7e73e1ce21","49ae5069ebacbe13","f93207f6ab543a11","e4758b5dbbde4843","8860e51f3343b411","b1c5f5222925e6d2","4f655706417f4268","9073e24faa59ff82","71f58bdd7d3c2951","f25f796de2c84a39","9c55c4d87a87bdd6","cf7c5f7115250f16","16a0a412f6cf533b","b8336de7be7b42eb","85cd7d9a3b7bd60d","e38b0198d57bef75","f5799e670d18983f"],"x":204,"y":39,"w":1712,"h":782},{"id":"27e7e9903a15f41c","type":"group","z":"8f32aaab05a0cf37","name":"Write modbus","style":{"fill":"#c8e7a7","label":true,"color":"#000000"},"nodes":["42b63cb6448e382e","87f678905bb139f8","7f4c689f0eec335e","907b234799299aea"],"x":204,"y":1039,"w":532,"h":142},{"id":"6c4d3c287aec0c3e","type":"modbus-getter","z":"8f32aaab05a0cf37","g":"6f3b06f9eece4ad3","name":"Marstek 1 SOC 32104","showStatusActivities":false,"showErrors":false,"showWarnings":true,"logIOActivities":false,"unitid":"1","dataType":"HoldingRegister","adr":"32104","quantity":"1","server":"67aa8a7899544f4d","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"keepMsgProperties":false,"delayOnStart":false,"enableDeformedMessages":false,"startDelayTime":"","x":580,"y":130,"wires":[["95b0b07b044c8838","71d3a563e018f274"],[]]},{"id":"4dfe5e2e19855d95","type":"inject","z":"8f32aaab05a0cf37","g":"6f3b06f9eece4ad3","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"120","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":320,"y":270,"wires":[["6c4d3c287aec0c3e","20f3caf5a2c0f481","43c4aa7e73e1ce21","49ae5069ebacbe13"]]},{"id":"20f3caf5a2c0f481","type":"modbus-getter","z":"8f32aaab05a0cf37","g":"6f3b06f9eece4ad3","name":"Marstek 2 SOC 32104","showStatusActivities":false,"showErrors":false,"showWarnings":true,"logIOActivities":false,"unitid":"2","dataType":"HoldingRegister","adr":"32104","quantity":"1","server":"076ca4c29c17cd9f","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"keepMsgProperties":false,"delayOnStart":false,"enableDeformedMessages":false,"startDelayTime":"","x":580,"y":220,"wires":[["90b1aba38348c387","b5bb6dc92fe70310"],[]]},{"id":"32bd41d8e08a9b3b","type":"inject","z":"8f32aaab05a0cf37","g":"6f3b06f9eece4ad3","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"10","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":330,"y":540,"wires":[["54fa5f8bfb25d834","215d5466c4b068ec"]]},{"id":"54fa5f8bfb25d834","type":"modbus-getter","z":"8f32aaab05a0cf37","g":"6f3b06f9eece4ad3","name":"Marstek 1 State 35100","showStatusActivities":false,"showErrors":false,"showWarnings":true,"logIOActivities":false,"unitid":"1","dataType":"HoldingRegister","adr":"35100","quantity":"1","server":"67aa8a7899544f4d","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"keepMsgProperties":false,"delayOnStart":false,"enableDeformedMessages":false,"startDelayTime":"","x":570,"y":510,"wires":[["a675f7131ee80f92"],[]]},{"id":"95b0b07b044c8838","type":"ui_gauge","z":"8f32aaab05a0cf37","g":"6f3b06f9eece4ad3","name":"SOC M1","group":"337a5786b63541f1","order":1,"width":2,"height":2,"gtype":"gage","title":"Battery 1","label":"%","format":"{{value}} ","min":"0","max":"100","colors":["#d7321e","#f4911f","#00b400"],"seg1":"15","seg2":"25","diff":false,"className":"","x":1150,"y":120,"wires":[]},{"id":"90b1aba38348c387","type":"ui_gauge","z":"8f32aaab05a0cf37","g":"6f3b06f9eece4ad3","name":"SOC M2","group":"337a5786b63541f1","order":8,"width":2,"height":2,"gtype":"gage","title":"Battery 2","label":"%","format":"{{value}} ","min":"0","max":"100","colors":["#d7321e","#f4911f","#00b400"],"seg1":"15","seg2":"25","diff":false,"className":"","x":1150,"y":210,"wires":[]},{"id":"a675f7131ee80f92","type":"function","z":"8f32aaab05a0cf37","g":"6f3b06f9eece4ad3","name":"Get Status","func":"var Status = msg.payload ;\n\nif (Status == \"0\") {(Status = \"Sleep\")\n}\nelse if(Status == \"1\") {(Status = \"Standby\")\n}\nelse if(Status == \"2\") {(Status = \"Charge\")\n}\nelse if(Status == \"3\") {(Status = \"Discharge\")\n}\nelse if(Status == \"4\") {(Status = \"Backup\")\n}\nelse if(Status == \"5\") {(Status = \"OTA\")\n}\n\nreturn [{ payload: Status }]\n","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":770,"y":510,"wires":[["30c277fd994b3251"]]},{"id":"215d5466c4b068ec","type":"modbus-getter","z":"8f32aaab05a0cf37","g":"6f3b06f9eece4ad3","name":"Marstek 2 State 35100","showStatusActivities":false,"showErrors":false,"showWarnings":true,"logIOActivities":false,"unitid":"2","dataType":"HoldingRegister","adr":"35100","quantity":"1","server":"076ca4c29c17cd9f","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"keepMsgProperties":false,"delayOnStart":false,"enableDeformedMessages":false,"startDelayTime":"","x":570,"y":580,"wires":[["042bb002e66c3f8c"],[]]},{"id":"042bb002e66c3f8c","type":"function","z":"8f32aaab05a0cf37","g":"6f3b06f9eece4ad3","name":"Get Status","func":"var Status = msg.payload ;\n\nif (Status == \"0\") {(Status = \"Sleep\")\n}\nelse if(Status == \"1\") {(Status = \"Standby\")\n}\nelse if(Status == \"2\") {(Status = \"Charge\")\n}\nelse if(Status == \"3\") {(Status = \"Discharge\")\n}\nelse if(Status == \"4\") {(Status = \"Backup\")\n}\nelse if(Status == \"5\") {(Status = \"OTA\")\n}\n\nreturn [{ payload: Status }]\n","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":770,"y":580,"wires":[["453e82db14621418"]]},{"id":"88c3c38799829dc0","type":"comment","z":"8f32aaab05a0cf37","g":"6f3b06f9eece4ad3","name":"2333","info":"","x":530,"y":100,"wires":[]},{"id":"a49fd8e446273768","type":"comment","z":"8f32aaab05a0cf37","g":"6f3b06f9eece4ad3","name":"0f8d","info":"","x":530,"y":190,"wires":[]},{"id":"30c277fd994b3251","type":"ui_text","z":"8f32aaab05a0cf37","g":"6f3b06f9eece4ad3","group":"337a5786b63541f1","order":2,"width":3,"height":1,"name":"status","label":"Status:","format":"{{msg.payload}}","layout":"row-left","className":"","style":true,"font":"","fontSize":16,"color":"#64c832","x":950,"y":510,"wires":[]},{"id":"453e82db14621418","type":"ui_text","z":"8f32aaab05a0cf37","g":"6f3b06f9eece4ad3","group":"337a5786b63541f1","order":9,"width":3,"height":1,"name":"status","label":"Status:","format":"{{msg.payload}}","layout":"row-left","className":"","style":true,"font":"","fontSize":16,"color":"#64c832","x":950,"y":580,"wires":[]},{"id":"46e0d981ca209592","type":"inject","z":"8f32aaab05a0cf37","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":410,"y":1490,"wires":[["2190cef513c0801a"]]},{"id":"2190cef513c0801a","type":"modbus-getter","z":"8f32aaab05a0cf37","name":"Marstek 1 test","showStatusActivities":false,"showErrors":false,"showWarnings":true,"logIOActivities":false,"unitid":"1","dataType":"HoldingRegister","adr":"37004","quantity":"4","server":"67aa8a7899544f4d","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"keepMsgProperties":false,"delayOnStart":false,"enableDeformedMessages":false,"startDelayTime":"","x":640,"y":1490,"wires":[["82a446165a26305c","9a9f0caa2717e56f"],[]]},{"id":"82a446165a26305c","type":"debug","z":"8f32aaab05a0cf37","name":"debug 11","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":990,"y":1480,"wires":[]},{"id":"ac0c3f4e9cf44081","type":"inject","z":"8f32aaab05a0cf37","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":400,"y":1600,"wires":[["f6251a784be63833"]]},{"id":"f6251a784be63833","type":"modbus-getter","z":"8f32aaab05a0cf37","name":"Marstek 2 test","showStatusActivities":false,"showErrors":false,"showWarnings":true,"logIOActivities":false,"unitid":"2","dataType":"HoldingRegister","adr":"44000","quantity":"1","server":"076ca4c29c17cd9f","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"keepMsgProperties":false,"delayOnStart":false,"enableDeformedMessages":false,"startDelayTime":"","x":630,"y":1600,"wires":[["0559d950ce126579"],[]]},{"id":"0559d950ce126579","type":"debug","z":"8f32aaab05a0cf37","name":"debug 22","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":990,"y":1590,"wires":[]},{"id":"048de029a5d1ec8b","type":"inject","z":"8f32aaab05a0cf37","g":"6f3b06f9eece4ad3","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"10","crontab":"","once":false,"onceDelay":"0.5","topic":"","payload":"","payloadType":"date","x":330,"y":780,"wires":[["675866f5a0b9691f","92543281bc95c695","0598cb858cadcc60","24db78fe6d18039e"]]},{"id":"675866f5a0b9691f","type":"modbus-getter","z":"8f32aaab05a0cf37","g":"6f3b06f9eece4ad3","name":"Marstek 1 Ch/Dis-charge Pow 30006","showStatusActivities":false,"showErrors":false,"showWarnings":true,"logIOActivities":false,"unitid":"1","dataType":"HoldingRegister","adr":"30006","quantity":"1","server":"67aa8a7899544f4d","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"keepMsgProperties":false,"delayOnStart":false,"enableDeformedMessages":false,"startDelayTime":"","x":620,"y":650,"wires":[["cf7c5f7115250f16","e38b0198d57bef75"],[]]},{"id":"92543281bc95c695","type":"modbus-getter","z":"8f32aaab05a0cf37","g":"6f3b06f9eece4ad3","name":"Marstek 2 Ch/Dis-charge Pow 30006","showStatusActivities":false,"showErrors":false,"showWarnings":true,"logIOActivities":false,"unitid":"2","dataType":"HoldingRegister","adr":"30006","quantity":"1","server":"076ca4c29c17cd9f","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"keepMsgProperties":false,"delayOnStart":false,"enableDeformedMessages":false,"startDelayTime":"","x":620,"y":740,"wires":[["9c55c4d87a87bdd6","f5799e670d18983f"],[]]},{"id":"6a876bc9bc3262e7","type":"change","z":"8f32aaab05a0cf37","g":"6f3b06f9eece4ad3","name":"topic1","rules":[{"t":"set","p":"topic","pt":"msg","to":"Discharge1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1150,"y":640,"wires":[["34eacb9e7e37bfcf","71f58bdd7d3c2951"]]},{"id":"36c5487010a1bd25","type":"change","z":"8f32aaab05a0cf37","g":"6f3b06f9eece4ad3","name":"topic2","rules":[{"t":"set","p":"topic","pt":"msg","to":"Discharge2","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1150,"y":750,"wires":[["34eacb9e7e37bfcf","f25f796de2c84a39"]]},{"id":"34eacb9e7e37bfcf","type":"SumUltimate","z":"8f32aaab05a0cf37","g":"6f3b06f9eece4ad3","name":"tot discharge","property":"payload","math":"sum","subtractstartfrom":"","x":1360,"y":690,"wires":[["1c52218d552d26f3"]]},{"id":"1c52218d552d26f3","type":"link out","z":"8f32aaab05a0cf37","g":"6f3b06f9eece4ad3","name":"Marstek Discharge","mode":"link","links":["01b8b0978fd6fc8a"],"x":1595,"y":690,"wires":[]},{"id":"b2a5504cc482e999","type":"comment","z":"8f32aaab05a0cf37","g":"6f3b06f9eece4ad3","name":"to actual calc","info":"","x":1820,"y":690,"wires":[]},{"id":"71d3a563e018f274","type":"function","z":"8f32aaab05a0cf37","g":"6f3b06f9eece4ad3","name":"remaining [kWh]","func":"var soc = (msg.payload)* (4.2/100);\n\nreturn [{ payload: soc }]","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":820,"y":80,"wires":[["e3377b502f96ac1e"]]},{"id":"e3377b502f96ac1e","type":"subflow:3f235640b7cb44a9","z":"8f32aaab05a0cf37","g":"6f3b06f9eece4ad3","name":"","x":990,"y":80,"wires":[["9889d5182e1600f5"]]},{"id":"b5bb6dc92fe70310","type":"function","z":"8f32aaab05a0cf37","g":"6f3b06f9eece4ad3","name":"remaining [kWh]","func":"var soc = (msg.payload)* (4.2/100);\n\nreturn [{ payload: soc }]","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":820,"y":170,"wires":[["cd0467fd237b7f8a"]]},{"id":"cd0467fd237b7f8a","type":"subflow:3f235640b7cb44a9","z":"8f32aaab05a0cf37","g":"6f3b06f9eece4ad3","name":"","x":990,"y":170,"wires":[["bb2b200201d6c233"]]},{"id":"9889d5182e1600f5","type":"ui_text","z":"8f32aaab05a0cf37","g":"6f3b06f9eece4ad3","group":"337a5786b63541f1","order":4,"width":2,"height":1,"name":"Remaining M1","label":"","format":"{{msg.payload}} kWh","layout":"row-left","className":"","style":true,"font":"","fontSize":16,"color":"#64c832","x":1170,"y":80,"wires":[]},{"id":"bb2b200201d6c233","type":"ui_text","z":"8f32aaab05a0cf37","g":"6f3b06f9eece4ad3","group":"337a5786b63541f1","order":11,"width":2,"height":1,"name":"Remaining M2","label":"","format":"{{msg.payload}} kWh","layout":"row-left","className":"","style":true,"font":"","fontSize":16,"color":"#64c832","x":1170,"y":170,"wires":[]},{"id":"43c4aa7e73e1ce21","type":"modbus-getter","z":"8f32aaab05a0cf37","g":"6f3b06f9eece4ad3","name":"Marstek 1 Int Temperature 35000","showStatusActivities":false,"showErrors":false,"showWarnings":true,"logIOActivities":false,"unitid":"1","dataType":"HoldingRegister","adr":"35000","quantity":"1","server":"67aa8a7899544f4d","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"keepMsgProperties":false,"delayOnStart":false,"enableDeformedMessages":false,"startDelayTime":"","x":620,"y":290,"wires":[["b1c5f5222925e6d2"],[]]},{"id":"49ae5069ebacbe13","type":"modbus-getter","z":"8f32aaab05a0cf37","g":"6f3b06f9eece4ad3","name":"Marstek 2 Int Temperature 35000","showStatusActivities":false,"showErrors":false,"showWarnings":true,"logIOActivities":false,"unitid":"2","dataType":"HoldingRegister","adr":"35000","quantity":"1","server":"076ca4c29c17cd9f","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"keepMsgProperties":false,"delayOnStart":false,"enableDeformedMessages":false,"startDelayTime":"","x":620,"y":330,"wires":[["f93207f6ab543a11"],[]]},{"id":"f93207f6ab543a11","type":"function","z":"8f32aaab05a0cf37","g":"6f3b06f9eece4ad3","name":"IT /10","func":"var iT = (msg.payload)/10;\n\nreturn [{ payload: iT }]","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":890,"y":330,"wires":[["8860e51f3343b411"]]},{"id":"e4758b5dbbde4843","type":"ui_text","z":"8f32aaab05a0cf37","g":"6f3b06f9eece4ad3","group":"337a5786b63541f1","order":3,"width":1,"height":1,"name":"Int Temperature M1","label":"","format":"{{msg.payload}}°C","layout":"row-right","className":"","style":true,"font":"","fontSize":"12","color":"#64c832","x":1180,"y":290,"wires":[]},{"id":"8860e51f3343b411","type":"ui_text","z":"8f32aaab05a0cf37","g":"6f3b06f9eece4ad3","group":"337a5786b63541f1","order":10,"width":1,"height":1,"name":"Int Temperature M2","label":"","format":"{{msg.payload}}°C","layout":"row-right","className":"","style":true,"font":"","fontSize":"12","color":"#64c832","x":1180,"y":330,"wires":[]},{"id":"b1c5f5222925e6d2","type":"function","z":"8f32aaab05a0cf37","g":"6f3b06f9eece4ad3","name":"IT /10","func":"var iT = (msg.payload)/10;\n\nreturn [{ payload: iT }]","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":890,"y":290,"wires":[["e4758b5dbbde4843"]]},{"id":"4f655706417f4268","type":"ui_text","z":"8f32aaab05a0cf37","g":"6f3b06f9eece4ad3","group":"337a5786b63541f1","order":5,"width":2,"height":1,"name":"AC M1","label":"","format":"{{msg.payload}}","layout":"row-left","className":"","style":true,"font":"","fontSize":16,"color":"#64c832","x":1500,"y":640,"wires":[]},{"id":"9073e24faa59ff82","type":"ui_text","z":"8f32aaab05a0cf37","g":"6f3b06f9eece4ad3","group":"337a5786b63541f1","order":12,"width":2,"height":1,"name":"AC M2","label":"","format":"{{msg.payload}}","layout":"row-left","className":"","style":true,"font":"","fontSize":16,"color":"#64c832","x":1500,"y":750,"wires":[]},{"id":"71f58bdd7d3c2951","type":"template","z":"8f32aaab05a0cf37","g":"6f3b06f9eece4ad3","name":"Add Suffix","field":"payload","fieldType":"msg","format":"html","syntax":"mustache","template":"{{ payload }} W","output":"str","x":1330,"y":640,"wires":[["4f655706417f4268"]]},{"id":"f25f796de2c84a39","type":"template","z":"8f32aaab05a0cf37","g":"6f3b06f9eece4ad3","name":"Add Suffix","field":"payload","fieldType":"msg","format":"html","syntax":"mustache","template":"{{ payload }} W","output":"str","x":1330,"y":750,"wires":[["9073e24faa59ff82"]]},{"id":"9c55c4d87a87bdd6","type":"StatusUltimate","z":"8f32aaab05a0cf37","g":"6f3b06f9eece4ad3","name":"Status","property":"payload","x":805,"y":780,"wires":[[]],"l":false},{"id":"cf7c5f7115250f16","type":"StatusUltimate","z":"8f32aaab05a0cf37","g":"6f3b06f9eece4ad3","name":"Status","property":"payload","x":805,"y":690,"wires":[[]],"l":false},{"id":"9a9f0caa2717e56f","type":"StatusUltimate","z":"8f32aaab05a0cf37","name":"Status","property":"payload","x":815,"y":1510,"wires":[[]],"l":false},{"id":"42b63cb6448e382e","type":"ui_dropdown","z":"8f32aaab05a0cf37","g":"27e7e9903a15f41c","name":"","label":"Mode B1","tooltip":"","place":"Select option","group":"337a5786b63541f1","order":13,"width":5,"height":1,"passthru":true,"multiple":false,"options":[{"label":"Manual","value":"0","type":"str"},{"label":"AntiFeed","value":1,"type":"num"}],"payload":"","topic":"topic","topicType":"msg","className":"","x":290,"y":1080,"wires":[["7f4c689f0eec335e"]]},{"id":"87f678905bb139f8","type":"ui_dropdown","z":"8f32aaab05a0cf37","g":"27e7e9903a15f41c","name":"","label":"Mode B2","tooltip":"","place":"Select option","group":"337a5786b63541f1","order":15,"width":5,"height":1,"passthru":true,"multiple":false,"options":[{"label":"Manual","value":"0","type":"str"},{"label":"AntiFeed","value":1,"type":"num"}],"payload":"","topic":"topic","topicType":"msg","className":"","x":290,"y":1140,"wires":[["907b234799299aea"]]},{"id":"7f4c689f0eec335e","type":"modbus-write","z":"8f32aaab05a0cf37","g":"27e7e9903a15f41c","name":"Modbus Write 43000 ( Mode M1)","showStatusActivities":false,"showErrors":false,"showWarnings":true,"unitid":"1","dataType":"HoldingRegister","adr":"43000","quantity":"1","server":"67aa8a7899544f4d","emptyMsgOnFail":false,"keepMsgProperties":false,"delayOnStart":false,"startDelayTime":"","x":570,"y":1080,"wires":[[],[]]},{"id":"907b234799299aea","type":"modbus-write","z":"8f32aaab05a0cf37","g":"27e7e9903a15f41c","name":"Modbus Write 43000 ( Mode M1)","showStatusActivities":false,"showErrors":false,"showWarnings":true,"unitid":"2","dataType":"HoldingRegister","adr":"43000","quantity":"1","server":"076ca4c29c17cd9f","emptyMsgOnFail":false,"keepMsgProperties":false,"delayOnStart":false,"startDelayTime":"","x":570,"y":1140,"wires":[[],[]]},{"id":"16a0a412f6cf533b","type":"link in","z":"8f32aaab05a0cf37","g":"6f3b06f9eece4ad3","name":"kWh meter from home","links":["ea9b415971beca6e"],"x":825,"y":450,"wires":[["b8336de7be7b42eb"]]},{"id":"b8336de7be7b42eb","type":"ui_text","z":"8f32aaab05a0cf37","g":"6f3b06f9eece4ad3","group":"337a5786b63541f1","order":6,"width":5,"height":1,"name":"P1 Power meter","label":"P1 Power meter:","format":"{{msg.payload}} W","layout":"row-right","className":"","style":false,"font":"","fontSize":16,"color":"#64c832","x":980,"y":450,"wires":[]},{"id":"85cd7d9a3b7bd60d","type":"comment","z":"8f32aaab05a0cf37","g":"6f3b06f9eece4ad3","name":"charging thenregister 30001 ?","info":"","x":1690,"y":650,"wires":[]},{"id":"0598cb858cadcc60","type":"modbus-getter","z":"8f32aaab05a0cf37","d":true,"name":"Marstek 1 Charge Pow 30001","showStatusActivities":false,"showErrors":false,"showWarnings":true,"logIOActivities":false,"unitid":"1","dataType":"HoldingRegister","adr":"30001","quantity":"1","server":"67aa8a7899544f4d","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"keepMsgProperties":false,"delayOnStart":false,"enableDeformedMessages":false,"startDelayTime":"","x":590,"y":870,"wires":[[],[]]},{"id":"24db78fe6d18039e","type":"modbus-getter","z":"8f32aaab05a0cf37","d":true,"name":"Marstek 2 Charge Pow 30001","showStatusActivities":false,"showErrors":false,"showWarnings":true,"logIOActivities":false,"unitid":"2","dataType":"HoldingRegister","adr":"30001","quantity":"2","server":"076ca4c29c17cd9f","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"keepMsgProperties":false,"delayOnStart":false,"enableDeformedMessages":false,"startDelayTime":"","x":590,"y":960,"wires":[[],[]]},{"id":"30fdbb27de8f0e01","type":"function","z":"8f32aaab05a0cf37","name":"function 10","func":"msg = msg.payload /1000 ;\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":830,"y":1740,"wires":[["c603ccf7263b6cc0"]]},{"id":"c603ccf7263b6cc0","type":"subflow:85f954b04cbf1a86","z":"8f32aaab05a0cf37","name":"","x":1000,"y":1740,"wires":[["53c5da69417d132c"]]},{"id":"53c5da69417d132c","type":"json","z":"8f32aaab05a0cf37","name":"","property":"payload","action":"","pretty":false,"x":1130,"y":1730,"wires":[[]]},{"id":"e38b0198d57bef75","type":"function","z":"8f32aaab05a0cf37","g":"6f3b06f9eece4ad3","name":"Convert charge value","func":"var value = msg.payload ;\n//var convert = (msg.payload << 16) >> 16 ;\n\nif (value > 2000) {(value = value - (65536 ))\n}\n//else if (value < 2000) {(value = value )}\nreturn [{ payload: value }]\n\n// Input: msg.payload = 64324\n// msg.payload = (msg.payload << 16) >> 16;\n\n// Output: msg.payload = -1212\n","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":960,"y":640,"wires":[["6a876bc9bc3262e7"]]},{"id":"f5799e670d18983f","type":"function","z":"8f32aaab05a0cf37","g":"6f3b06f9eece4ad3","name":"Convert charge value","func":"var value = msg.payload ;\n//var convert = (msg.payload << 16) >> 16 ;\n\nif (value > 2000) {(value = value - (65536 ))\n}\n//else if (value < 2000) {(value = value )}\nreturn [{ payload: value }]\n\n// Input: msg.payload = 64324\n// msg.payload = (msg.payload << 16) >> 16;\n\n// Output: msg.payload = -1212\n","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":960,"y":750,"wires":[["36c5487010a1bd25"]]},{"id":"2c30472e5c3e4bab","type":"comment","z":"8f32aaab05a0cf37","name":"another option for the same","info":"","x":490,"y":920,"wires":[]},{"id":"1377251758eb852e","type":"comment","z":"8f32aaab05a0cf37","name":"testing write to marstek modbus","info":"","x":620,"y":1430,"wires":[]},{"id":"6f5618204a535f33","type":"ui_spacer","z":"8f32aaab05a0cf37","name":"spacer","group":"dca5125.1377bf","order":1,"width":2,"height":1},{"id":"9a3cf49ffa732650","type":"ui_spacer","z":"8f32aaab05a0cf37","name":"spacer","group":"4fb0db5cea9cd881","order":11,"width":2,"height":1},{"id":"3c22a48f8b9bb41b","type":"ui_spacer","z":"8f32aaab05a0cf37","name":"spacer","group":"4fb0db5cea9cd881","order":13,"width":6,"height":1},{"id":"604312073c2c27a8","type":"ui_spacer","z":"8f32aaab05a0cf37","name":"spacer","group":"337a5786b63541f1","order":7,"width":1,"height":1},{"id":"450b9da8a556f3f8","type":"ui_spacer","z":"8f32aaab05a0cf37","name":"spacer","group":"337a5786b63541f1","order":14,"width":1,"height":1},{"id":"85bcebbd1a613442","type":"ui_spacer","z":"8f32aaab05a0cf37","name":"spacer","group":"337a5786b63541f1","order":16,"width":1,"height":1},{"id":"0504976c7fd449ee","type":"ui_spacer","z":"8f32aaab05a0cf37","name":"spacer","group":"d15c50bb.6b0f38","order":10,"width":6,"height":1},{"id":"67aa8a7899544f4d","type":"modbus-client","name":"Marstek 1","clienttype":"tcp","bufferCommands":true,"stateLogEnabled":false,"queueLogEnabled":false,"failureLogEnabled":true,"tcpHost":"192.168.178.7","tcpPort":"502","tcpType":"DEFAULT","serialPort":"/dev/ttyUSB","serialType":"RTU-BUFFERD","serialBaudrate":"9600","serialDatabits":"8","serialStopbits":"1","serialParity":"none","serialConnectionDelay":"100","serialAsciiResponseStartDelimiter":"0x3A","unit_id":3,"commandDelay":1,"clientTimeout":1000,"reconnectOnTimeout":true,"reconnectTimeout":2000,"parallelUnitIdsAllowed":true,"showErrors":false,"showWarnings":true,"showLogs":true},{"id":"076ca4c29c17cd9f","type":"modbus-client","name":"Marstek 2","clienttype":"tcp","bufferCommands":true,"stateLogEnabled":false,"queueLogEnabled":false,"failureLogEnabled":true,"tcpHost":"192.168.178.8","tcpPort":502,"tcpType":"DEFAULT","serialPort":"/dev/ttyUSB","serialType":"RTU-BUFFERD","serialBaudrate":9600,"serialDatabits":8,"serialStopbits":1,"serialParity":"none","serialConnectionDelay":100,"serialAsciiResponseStartDelimiter":"0x3A","unit_id":1,"commandDelay":1,"clientTimeout":1000,"reconnectOnTimeout":true,"reconnectTimeout":2000,"parallelUnitIdsAllowed":true,"showErrors":false,"showWarnings":true,"showLogs":true},{"id":"337a5786b63541f1","type":"ui_group","name":"Marstek","tab":"cccf47e4.857ec8","order":6,"disp":true,"width":6,"collapse":true,"className":""},{"id":"dca5125.1377bf","type":"ui_group","name":"Solar","tab":"cccf47e4.857ec8","order":2,"disp":true,"width":"6","collapse":true,"className":""},{"id":"4fb0db5cea9cd881","type":"ui_group","name":"SMA  settings","tab":"cccf47e4.857ec8","order":4,"disp":true,"width":"6","collapse":true,"className":""},{"id":"d15c50bb.6b0f38","type":"ui_group","name":"kWh Meter","tab":"cccf47e4.857ec8","order":7,"disp":true,"width":"6","collapse":true,"className":""},{"id":"cccf47e4.857ec8","type":"ui_tab","name":"Energy","icon":"battery_charging_60","order":2,"disabled":false,"hidden":false},{"id":"7944a2340127fc83","type":"global-config","env":[],"modules":{"node-red-contrib-modbus":"5.45.2","node-red-dashboard":"3.6.6","node-red-contrib-boolean-logic-ultimate":"1.2.3"}}]
Created 10 months, 3 weeks ago
Updated 3 weeks, 3 days ago
  • change (x4)
  • comment (x6)
  • debug (x2)
  • function (x10)
  • inject (x5)
  • json (x1)
  • link in (x1)
  • link out (x1)
  • template (x2)
  • StatusUltimate (x3)
  • SumUltimate (x1)
  • global-config (x1)
  • group (x2)
  • modbus-client (x2)
  • modbus-getter (x12)
  • modbus-write (x2)
  • subflow (x2)
  • subflow:3f235640b7cb44a9 (x2)
  • subflow:85f954b04cbf1a86 (x1)
  • ui_dropdown (x2)
  • ui_gauge (x2)
  • ui_group (x4)
  • ui_spacer (x7)
  • ui_text (x9)
  • Marstek
  • venus
  • A
