Localize and identify multiple objects in a single image
This flow uses the https://developer.ibm.com/exchanges/models/all/max-object-detector/ deep learning model from the Model Asset Exchange to localize and identify multiple objects in a single image. Refer to the documentation for information about the returned message.
Install the following three modules to run this example flow:
Note: The object-detector node has been pre-configured to use a hosted model evaluation instance. We recommend using your own local or cloud instance for purposes other than evaluation.
[{"id":"257b0fcf.c1302","type":"tab","label":"Object detection example flow","disabled":false,"info":"This flow uses the https://developer.ibm.com/exchanges/models/all/max-object-detector/ deep learning model from the Model Asset Exchange to localize and identify multiple objects in a single image. Refer to the documentation for information about the returned message.\n\nInstall the following three modules to run this example flow:\n - [node-red-contrib-model-asset-exchange](https://www.npmjs.com/package/node-red-contrib-model-asset-exchange)\n - [node-red-contrib-browser-utils](https://www.npmjs.com/package/node-red-contrib-browser-utils)\n - [node-red-contrib-image-output](https://npmjs.org/package/node-red-contrib-image-output)\n \n> Note: The object-detector node has been pre-configured to use a hosted model evaluation instance. We recommend using your own local or cloud instance for purposes other than evaluation."},{"id":"5680e5ee.1441cc","type":"debug","z":"257b0fcf.c1302","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":650,"y":120,"wires":[]},{"id":"d266c943.67ce48","type":"object-detector","z":"257b0fcf.c1302","service":"96195b68.679e18","method":"predict","passthrough":false,"annotated_input":true,"predict_body":"","predict_bodyType":"str","predict_threshold":"0.7","predict_thresholdType":"str","name":"","x":360,"y":120,"wires":[["5680e5ee.1441cc","9f36df26.ff3c9"]]},{"id":"b20eb66e.1fa248","type":"fileinject","z":"257b0fcf.c1302","name":"","x":140,"y":120,"wires":[["d266c943.67ce48"]]},{"id":"520cd665.7725c8","type":"camera","z":"257b0fcf.c1302","name":"","x":130,"y":178,"wires":[["d266c943.67ce48"]]},{"id":"f124cc22.5c93a","type":"comment","z":"257b0fcf.c1302","name":"Localize and identify multiple objects in a single image, then display the output","info":"","x":320,"y":40,"wires":[]},{"id":"fd5d2cbc.ed717","type":"image","z":"257b0fcf.c1302","name":"","width":"300","x":670.5,"y":178,"wires":[]},{"id":"9f36df26.ff3c9","type":"function","z":"257b0fcf.c1302","name":"Extract Bounding Box Image Data","func":"// if the incoming message contains the annotated image\n// send it to the image output node to display\n\nmsg.payload = msg.annotatedInput;\nif (msg.payload) {\n    return msg;\n}","outputs":1,"noerr":0,"x":419.5,"y":178,"wires":[["fd5d2cbc.ed717"]]},{"id":"96195b68.679e18","type":"object-detector-service","z":"","host":"https://max-object-detector.max.us-south.containers.appdomain.cloud","name":"cloud"}]
Created 8 years, 4 months ago
Updated 8 years, 2 months ago
  • 'deep learning'
  • 'object detection'
  • max
