Synology Calendar API - List calendars
This is an example how to list all the available calendars on your synology using the SYNO.Cal.Cal API version 5.
Please look at the flow Synology API Auth login to authentificate the user to be authorised to run this flow.
Check the Synology API Collection for related examples.
[{"id":"70cfcd28d32bcc90","type":"group","z":"55979001e6fb4b69","style":{"stroke":"#999999","stroke-opacity":"1","fill":"none","fill-opacity":"1","label":true,"label-position":"nw","color":"#a4a4a4"},"nodes":["92a3aad42c1ef629","baeb98c0b6f3a029","5a1e13fda682647f","e54c7a15f4730ab1","4e2b58b26528a699","621ab49ab08d1348"],"x":34,"y":39,"w":1032,"h":142},{"id":"92a3aad42c1ef629","type":"http request","z":"55979001e6fb4b69","g":"70cfcd28d32bcc90","name":"","method":"use","ret":"obj","paytoqs":"query","url":"","tls":"","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[],"x":550,"y":140,"wires":[["4e2b58b26528a699"]]},{"id":"baeb98c0b6f3a029","type":"inject","z":"55979001e6fb4b69","g":"70cfcd28d32bcc90","name":"","props":[],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":130,"y":140,"wires":[["e54c7a15f4730ab1"]]},{"id":"5a1e13fda682647f","type":"debug","z":"55979001e6fb4b69","g":"70cfcd28d32bcc90","name":"reponse","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":960,"y":140,"wires":[]},{"id":"e54c7a15f4730ab1","type":"function","z":"55979001e6fb4b69","g":"70cfcd28d32bcc90","name":"SYNO.Cal.Cal/list","func":"msg.method = \"GET\";\nmsg.url = flow.get(\"synoentryurl\");\nmsg.cookies = { id: flow.get(\"sid\") };\nmsg.headers = { 'X-SYNO-TOKEN': flow.get(\"synotoken\") };\n\n// Set the query parameters\nmsg.payload = {\n api: \"SYNO.Cal.Cal\",\n version: 5,\n method: \"list\",\n cal_type: `\"event\"`\n};\n\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":330,"y":140,"wires":[["92a3aad42c1ef629"]]},{"id":"4e2b58b26528a699","type":"function","z":"55979001e6fb4b69","g":"70cfcd28d32bcc90","name":"save calendars","func":"node.status({\n fill: (msg.payload.data.list.length != 0) ? \"green\" : \"red\",\n shape: \"ring\",\n text: \"# calendars: \" + msg.payload.data.list.length\n}); \n\nvar calendars = [];\n\nmsg.payload.data.list.map(cal => {\n calendars.push({\n cal_displayname: cal.cal_displayname,\n cal_color: cal.cal_color,\n cal_id: cal.cal_id,\n original_cal_id: cal.original_cal_id\n });\n flow.set(cal.cal_displayname.replace(/\\s+/g, '_'), cal.cal_id);\n});\n\nflow.set(\"calendars\", calendars);\n\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":760,"y":140,"wires":[["5a1e13fda682647f"]]},{"id":"621ab49ab08d1348","type":"comment","z":"55979001e6fb4b69","g":"70cfcd28d32bcc90","name":"List all available calendars","info":"","x":170,"y":80,"wires":[]}]
