Synology API Auth login
This is an example how to authenticate and get the token/security identifier for any further Synology API calls. The main inputs are the account and passwd, and the url for the Synology.
The security identifier and url for further API requests are saved as flow variables.
Check the Synology API Collection for related examples.
[{"id":"8aa55e266ba632b3","type":"group","z":"55979001e6fb4b69","style":{"stroke":"#999999","stroke-opacity":"1","fill":"none","fill-opacity":"1","label":true,"label-position":"nw","color":"#a4a4a4"},"nodes":["56e4d38c48aacc92","be7703250d7ddf97","d0e4714f3eaa0ba0","99823cbcf8373d34","f32d04c276ea1f55","c9e532a58f329643"],"x":34,"y":39,"w":972,"h":142},{"id":"56e4d38c48aacc92","type":"http request","z":"55979001e6fb4b69","g":"8aa55e266ba632b3","name":"","method":"use","ret":"obj","paytoqs":"query","url":"","tls":"","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[],"x":530,"y":140,"wires":[["d0e4714f3eaa0ba0"]]},{"id":"be7703250d7ddf97","type":"inject","z":"55979001e6fb4b69","g":"8aa55e266ba632b3","name":"","props":[{"p":"account","v":"myaccount","vt":"str"},{"p":"passwd","v":"mypasswd","vt":"str"},{"p":"session","v":"mysession","vt":"str"},{"p":"baseurl","v":"https://mysynology:5001/","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":130,"y":140,"wires":[["99823cbcf8373d34"]]},{"id":"d0e4714f3eaa0ba0","type":"function","z":"55979001e6fb4b69","g":"8aa55e266ba632b3","name":"save sid","func":"node.status({ \n    fill: msg.payload.success ? \"green\" : \"red\", \n    shape: \"ring\", \n    text: msg.payload.success ? msg.payload.data.synotoken : \"failed\" \n});\n\nflow.set(\"sid\", msg.payload.data.sid); // Authorized session ID.\nflow.set(\"synotoken\", msg.payload.data.synotoken); // (Optional) This token avoids Cross-Site Request Forgery.\nflow.set(\"device_id\", msg.payload.data.device_id); // A.k.a. device id, to identify which device.\n\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":720,"y":140,"wires":[["c9e532a58f329643"]]},{"id":"99823cbcf8373d34","type":"function","z":"55979001e6fb4b69","g":"8aa55e266ba632b3","name":"Login request","func":"/*\nINPUT\n  msg.account  Login account name\n  msg.passwd   Login account password\n  msg.session  (Optional) Login session name for DSM Applications\n  msg.baseurl 'https://mysynology:port/'\n*/\n\nflow.set(\"synoentryurl\", msg.baseurl + \"webapi/entry.cgi\");\n\nmsg.method = \"GET\";\nmsg.url = msg.baseurl + \"webapi/auth.cgi\";\nmsg.payload = {\n    \"api\": \"SYNO.API.Auth\",\n    \"version\": 7,\n    \"method\": \"login\",\n    \"account\": msg.account,\n    \"passwd\": msg.passwd,\n    \"session\": msg.session,\n    \"format\": \"sid\",\n    \"enable_syno_token\": \"yes\"\n}\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":320,"y":140,"wires":[["56e4d38c48aacc92"]]},{"id":"f32d04c276ea1f55","type":"comment","z":"55979001e6fb4b69","g":"8aa55e266ba632b3","name":"Request token using SYNO.API.Auth","info":"","x":200,"y":80,"wires":[]},{"id":"c9e532a58f329643","type":"debug","z":"55979001e6fb4b69","g":"8aa55e266ba632b3","name":"debug 68","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":900,"y":140,"wires":[]}]
Created 2 years, 5 months ago
  • function (x2)
  • http request (x1)
  • Synology
  • API
  • SYNO.API.Auth
