Process an image with multiple deep learning models
This flow uses the object-detector and image-caption-generator deep learning models from the Model Asset Exchange to display bounding boxes on an input image then display a generated caption. Refer to the model documentation for information about the returned messages.
Install the following three modules to run this example flow:
Note: The object-detector and image-caption-generator nodes have been pre-configured to use hosted model evaluation instances. We recommend using your own local or cloud instance for purposes other than evaluation.
[{"id":"fb9f2f1a.6de7f","type":"tab","label":"Using Multiple Models","disabled":false,"info":"This flow uses the [object-detector](https://developer.ibm.com/exchanges/models/all/max-object-detector/) and [image-caption-generator](https://developer.ibm.com/exchanges/models/all/max-image-caption-generator/) deep learning models from the Model Asset Exchange to display bounding boxes on an input image, then displays a generated caption. Refer to the model documentation for information about the returned messages.\n\nInstall the following three modules to run this example flow:\n - [node-red-contrib-model-asset-exchange](https://www.npmjs.com/package/node-red-contrib-model-asset-exchange)\n - [node-red-contrib-browser-utils](https://www.npmjs.com/package/node-red-contrib-browser-utils)\n - [node-red-contrib-image-output](https://npmjs.org/package/node-red-contrib-image-output)\n \n> Note: The object-detector and image-caption-generator nodes have been pre-configured to use hosted model evaluation instances. We recommend using your own local or cloud instance for purposes other than evaluation."},{"id":"6c39a79e.485748","type":"debug","z":"fb9f2f1a.6de7f","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":1156,"y":120,"wires":[]},{"id":"8bafdf80.fa7da","type":"object-detector","z":"fb9f2f1a.6de7f","service":"96195b68.679e18","method":"predict","passthrough":true,"annotated_input":true,"predict_body":"","predict_bodyType":"str","predict_threshold":"0.7","predict_thresholdType":"str","name":"","x":360,"y":120,"wires":[["dd67bf05.d8256","e3f9db88.50b798"]]},{"id":"2384d389.022c1c","type":"fileinject","z":"fb9f2f1a.6de7f","name":"","x":140,"y":120,"wires":[["8bafdf80.fa7da"]]},{"id":"7a3149a4.b9f218","type":"camera","z":"fb9f2f1a.6de7f","name":"","x":130,"y":214,"wires":[["8bafdf80.fa7da"]]},{"id":"5992ec00.f522e4","type":"comment","z":"fb9f2f1a.6de7f","name":"Display bounding boxes on an input image using the object-detector node, then pass the input to the image-caption-generator to display a generated caption.","info":"This flow uses the [object-detector](https://developer.ibm.com/exchanges/models/all/max-object-detector/) and [image-caption-generator](https://developer.ibm.com/exchanges/models/all/max-image-caption-generator/) deep learning models from the Model Asset Exchange to display bounding boxes on an input image, then displays a generated caption. Refer to the model documentation for information about the returned messages.\n\nInstall the following three modules to run this example flow:\n - [node-red-contrib-model-asset-exchange](https://www.npmjs.com/package/node-red-contrib-model-asset-exchange)\n - [node-red-contrib-browser-utils](https://www.npmjs.com/package/node-red-contrib-browser-utils)\n - [node-red-contrib-image-output](https://npmjs.org/package/node-red-contrib-image-output)\n \n> Note: The object-detector and image-caption-generator nodes have been pre-configured to use hosted model evaluation instances. We recommend using your own local or cloud instance for purposes other than evaluation.","x":560,"y":40,"wires":[]},{"id":"62fba4c.11ec95c","type":"image","z":"fb9f2f1a.6de7f","name":"","width":"300","x":774.5,"y":220,"wires":[]},{"id":"dd67bf05.d8256","type":"function","z":"fb9f2f1a.6de7f","name":"Extract Bounding Box Image Data","func":"// if the incoming message contains the annotated image\n// send it to the image output node to display\n\nmsg.payload = msg.annotatedInput;\nif (msg.payload) {\n    return msg;\n}","outputs":1,"noerr":0,"x":479.5,"y":220,"wires":[["62fba4c.11ec95c"]]},{"id":"49c3158c.658edc","type":"image-caption-generator","z":"fb9f2f1a.6de7f","service":"82a87cae.a2fec","method":"predict","predict_body":"","predict_bodyType":"str","name":"","x":901.5,"y":120,"wires":[["6c39a79e.485748"]]},{"id":"e3f9db88.50b798","type":"function","z":"fb9f2f1a.6de7f","name":"Extract Input Image Data","func":"// if the incoming message contains the input image\n// send it to the image-caption-generator node\n// for further processing\n\nmsg.payload = msg.inputData;\nif (msg.payload) {\n    return msg;\n}","outputs":1,"noerr":0,"x":609,"y":120,"wires":[["49c3158c.658edc"]]},{"id":"96195b68.679e18","type":"object-detector-service","z":"","host":"https://max-object-detector.max.us-south.containers.appdomain.cloud","name":"cloud"},{"id":"82a87cae.a2fec","type":"image-caption-generator-service","z":"","host":"https://max-image-caption-generator.max.us-south.containers.appdomain.cloud","name":"cloud"}]
Created 8 years ago
Rating: 5 1
  • function (x2)
  • object detector
  • image caption generator
  • deep learning
  • artificial intelligence
  • model asset exchange
