node-red-dashboard-2-state-inspector-energiam 0.1.7
Native Dashboard 2.0 widget for Node-RED — capture variable snapshots at different machine states and compare them side-by-side in a live table. Data-source agnostic, designed for IIoT state machine debugging.
npm install node-red-dashboard-2-state-inspector-energiam
EnergIAM State Inspector
State Inspector
Native Dashboard 2.0 widget for Node-RED — freeze variable snapshots at different machine states and compare them side-by-side in a live dark-theme table. Built for IIoT state machine debugging.
npm Node-RED palette Dashboard 2.0 Node.js MIT
State Inspector — live comparison table
What it does
Each message adds or updates a column in the table. Each key in valores becomes a row. Send one message per machine state and get an instant side-by-side comparison.
Inhabilitado   Habilitado   Rampa↑   Régimen
enable   false      true      true     true
start    false     false      true     true
rampa    false     false      true    false
valorAct     0         0        43       50
Values are color-coded by type — no configuration required:
Type Color Style
true #3fb950 green bordered badge
false #f85149 red bordered badge
number #58a6ff blue plain
string #e3b341 yellow plain
null / undefined #484f58 grey dimmed
New variable keys are auto-discovered and added as rows on arrival. Columns accumulate up to the configured maximum, dropping the oldest (FIFO).
Requirements
Dependency Version
Node-RED ≥ 3.0
@flowfuse/node-red-dashboard ≥ 1.0
Node.js ≥ 18
Via Palette Manager — search for node-red-dashboard-2-state-inspector-energiam in
Menu → Manage Palette → Install.
Via npm:
# then restart Node-RED
Quick start
1. Place the node
Drag state inspector (category: EnergIAM) onto the canvas and assign it a Dashboard 2.0 group.
2. Send a snapshot
// Function node example
msg.payload = {
    nombre: "Habilitado",          // column header
    valores: {
        enable:      true,
        start:       false,
        objetivo:    50,
        valorActual: flow.get("valorActual")
return msg
Each call to the node with a different nombre adds a new column.
Calling it again with the same nombre updates that column in-place.
3. Reset or remove columns
// Clear the whole table
msg.topic = "state-inspector/reset"
// Remove one column by name
msg.topic   = "state-inspector/remove"
msg.payload = { nombre: "Habilitado" }
// Same via payload.action
msg.payload = { action: "reset" }
msg.payload = { action: "remove", nombre: "Habilitado" }
Node configuration
Property Default Description
Group — Dashboard 2.0 group (required)
Width / Height auto Widget size in grid units
Max columns 10 Oldest column is dropped when the limit is exceeded (FIFO)
Row order arrival arrival — insertion order · alpha — alphabetical
Color true #3fb950 Badge background for true values
Color false #f85149 Badge background for false values
Color number #58a6ff Text color for numeric values
Color string #e3b341 Text color for string values
Color null #484f58 Text color for null / undefined
Runtime settings — ⚙ gear panel
Click the ⚙ button in the widget toolbar to open the settings panel. Changes apply instantly and persist in localStorage.
Setting Options Default
Font size XS (10px) · S (12px) · M (14px) · L (16px) S
Row density Compact · Normal · Relaxed Normal
Timestamps on / off off
Sticky variable column on / off on
Input message reference
Add / update a column
msg.payload = {
    nombre:  string    // column label (required)
    valores: object    // flat key → value map (required)
Control messages
msg.topic = "state-inspector/reset"           // clear all columns
msg.topic = "state-inspector/remove"          // remove column
msg.payload = { nombre: "ColumnName" }        //   ↑ column to remove
// Equivalent via payload.action:
msg.payload = { action: "remove", nombre: "ColumnName" }
Node status indicators
Indicator Meaning
🟢 N estado(s) N columns currently in the table
⚫ sin datos Table is empty — waiting for input
🔴 sin grupo No Dashboard 2.0 group assigned
Example flow
Import examples/flows_state_inspector_test.json via Menu → Import.
The example simulates a variable-speed drive cycling through four states:
Inhabilitado → Habilitado → Rampa↑ → Régimen — one inject button per state plus a RESET button.
Architecture
This is a first-class native Dashboard 2.0 widget, not a ui-template workaround.
Layer Implementation
Backend Registers via group.register(node, config, evts) — same API as built-in widgets
Transport msg-input:<nodeId> socket channel (standard Dashboard 2.0 protocol)
Frontend Vue 3 SFC compiled to UMD, loaded by Dashboard from /resources/
Socket inject: ['$socket'] — Dashboard 2.0 provides the socket via Vue DI
State Per-instance Node-RED context (node.context())
Styling CSS injected into UMD bundle — no external stylesheet dependency
Contributing
Issues and PRs are welcome at
github.com/energiamEcoTouch/node-red-dashboard-2-state-inspector-energiam
MIT © 2026 EnergIAM EcoTouch
Made with ☕ and monospace fonts by Adrian Iskow
Version: 0.1.7
Updated 6 months, 3 weeks ago
Rating: 5.0 2
521 in the last week
  • state-inspector
  • node-red-dashboard
  • node-red-dashboard-2
  • dashboard
  • energiam
  • state
  • inspector
  • debug
  • table
  • context
  • iiot
  • widget
  • monitoring
  • state-machine
