node-red-contrib-wysiwyg 1.0.3
A stable and reliable WYSIWYG editor for Node-RED with rich text editing capabilities, perfect for email templates and HTML content. Battle-tested in production environments.
npm install node-red-contrib-wysiwyg
Node-RED WYSIWYG Editor
A WYSIWYG (What You See Is What You Get) editor node for Node-RED.
Overview
This node allows you to create and edit rich text content directly within your Node-RED flows. It's particularly useful for creating:
  • Email templates
  • HTML content
  • Formatted reports
  • Documentation
  • Any scenario requiring rich text editing
WYSIWYG Editor Node
  • Rich Text Editor: Full-featured WYSIWYG editor with formatting options
  • Flexible Output: Store content in msg, flow, or global context
  • Email Ready: Perfect for creating HTML email templates
  • Easy Integration: Works seamlessly with Node-RED's email nodes
  • Customizable: Set custom field names for better flow organization
After installation, restart Node-RED to make the node available in your palette.
  1. Drag the WYSIWYG node from the palette to your flow
  2. Double-click the node to open its configuration
  3. Enter a name for the node (optional but recommended)
  4. Configure the output settings:
    • Field: The property name to output to (default: 'payload')
    • Field Type: Where to store the output (msg, flow, or global context)
  5. Click "Done" to save the configuration
  6. Connect the node to other nodes in your flow as needed
Email Template Example
Here's how to use this node to create an email template:
  1. Add a WYSIWYG node to your flow
  2. Double-click to open the editor
  3. Create your email template with formatting, images, and links
  4. Set the output field to html (or your preferred property name)
  5. Connect it to an email node (like node-red-node-email)
  6. In your email node, use msg.html as the email body
Example Flow:
[ WYSIWYG (Email Template) ] --> [ Email Node ]
Using Template Variables
You can include dynamic content using handlebars syntax in your templates:
<h1>Hello {{msg.name}}!</h1>
<p>Your order #{{msg.orderId}} has been shipped.</p>
These placeholders will be replaced with actual values from the message when the flow runs.
Node Properties
  • Name: A friendly name for the node (appears under the node in the flow)
  • Text: The rich text content to output
  • Field Type: Where to store the output:
    • msg: Output to message object (default)
    • flow: Store in flow context
    • global: Store in global context
Example
A simple flow that uses the WYSIWYG node to set a welcome message:
[ WYSIWYG ] --> [ Debug ]
Contributing
Contributions are welcome! Please feel free to submit a Pull Request.
SEE LICENSE IN LICENSE.md
Version: 1.0.3
Updated 1 year, 5 months ago
25 in the last week
  • wysiwyg
  • wysiwyg
  • editor
  • rich text
  • email
  • template
