node-red-contrib-wikipedia 1.0.1
A node which get information from Wiki based on filters provided using Open Search API
npm install node-red-contrib-wikipedia
npm node-red-contrib-wikipedia Github All Releases
Node-RED node to search input payload on wiki using OpenSearch API which will return wiki results in json|jsonfm|xml|xmlfm formats node-red-contrib-wikipedia.
Run the following command in your Node-RED user directory – typically ~/.node-red:
npm i node-red-contrib-wikipedia
Provides one palette node which will use the message payload in string format and returns wiki search results based on configured parameters.
Output
Returns wiki results using OpenSearch API for given input message payload.
msg.payload is having wiki search results in json,jsonfm,xml,xmlfm format.
References
This node's input payload structure is based on node-red-contrib-wikipedia, which uses Wiki OpenSearch API.
Input
msg.payload :This will be of type String, which needs to be searched on wiki.
Configure the parameters based on Wiki OpenSearch API Doc
Details
This node will help user to search input payload on wiki using OpenSearch API
Support
If something is not working as expected, or if you think this node could be improved in other ways, please file an issue on GitHub.
Version: 1.0.1
Updated 4 years, 6 months ago
Rating: 3.0 2
46 in the last week
  • wikipedia
  • opensearch
  • wikipedia
  • mediawiki
