node-red-contrib-webiq 2.0.0
Node-RED nodes for WebIQ API integration.
npm install node-red-contrib-webiq
This package is an independent WebIQ Node-RED integration focused on connection reliability: detecting links that die without notice, recovering from them, and never silently losing a request along the way.
  • WebIQ API Connect Node — holds the WebSocket connection to a WebIQ server: logs in, reconnects with exponential backoff and jitter, and detects a link that has died without a TCP close via a ping/pong heartbeat. Supports wss:// with a standard Node-RED tls-config node, keeps credentials in Node-RED's credential store rather than the flow file, and stops rather than retrying a rejected login into a server-side account lockout.
  • API Request Node — builds the request sent to the server. The whole request is one JSON object (cmd, id, data), written inline or taken at runtime from msg / flow / global / env.
  • Errors surface. Failures reach Catch nodes, including requests the server rejects — an io.write refused for an unknown tag or insufficient rights no longer looks identical to one that succeeded.
To install the nodes, use the following command in your Node-RED user directory (typically ~/.node-red):
  1. Drag the WebIQ API Connect node into your Node-RED workspace.
  2. Configure the node properties:
    • Name: A name for the node instance.
    • Host: The WebIQ server host — hostname, IP address, Docker container name, or a bracketed IPv6 literal.
    • Port: The WebIQ server port (1–65535).
    • Project: The WebIQ project name or UUID.
    • Secure: Connect with wss:// instead of ws://. Without it the login and all PLC data cross the network in cleartext.
    • TLS config: Optional. Points at a standard Node-RED tls-config node for custom CAs, client certificates or a passphrase. Selecting one implies Secure. Certificate verification is controlled by that node's own Verify server certificate setting — this node never overrides it.
    • Username / Password: Your WebIQ project credentials. Stored in Node-RED's credential store, not in flows.json, and stripped from flow exports.
    • Login timeout: Seconds to wait for the server's login reply before reporting a timeout and reconnecting. Defaults to 5, maximum 86400. Raise this if the project is backed by a slow PLC — a login that takes longer than the timeout will otherwise loop without ever authenticating.
    • Heartbeat: Seconds between liveness probes once authenticated. Defaults to 30; 0 disables; values between 0 and 1 are raised to 1 second. Without it, a connection that dies without a TCP close keeps reporting authenticated forever while every request disappears.
    • Login attempts: How many consecutive rejected logins (default 5, range 1–20) before the node latches and stops trying — WebIQ counts attempts server-side and can lock the account. A lockout reply latches immediately. Logins that go unanswered never latch: after the same count the node falls back to one probe every 60 seconds and recovers on its own.
  3. Deploy the changes.
API Request Node
  1. Drag the API Request node into your Node-RED workspace.
  2. Set the Data field. The type selector chooses where the request comes from:
    • json — written inline, parsed once at deploy time.
    • msg / flow / global / env — read from that source for every message, so the request can change at runtime. A JSON string is parsed automatically.
  3. Whatever the source, the value must contain cmd, id and data.
  4. Wire its output into a WebIQ API Connect node and deploy.
Example Flow
A ready-made example ships with the package. In the Node-RED editor open the menu and choose Import → Examples → node-red-contrib-webiq → simple example.
It imports with the connection node disabled and no credentials filled in, so nothing starts connecting until you have entered your own server details and enabled the node.
Do not paste connection nodes with credentials into issues, documentation or chat. From 2.0 the username and password are held in Node-RED's credential store and are stripped from flow exports — that only protects you if the credentials were entered in the editor rather than written into the flow JSON by hand.
Upgrading from 1.x
2.0 is a breaking release. Read this before upgrading a production system.
Prerequisites
1.x 2.0
Node-RED >= 3.0 >= 4.0 (4 and 5 both supported)
Node.js >= 18 >= 20
If your installation is older than that, npm install will refuse or Node-RED will fail to load the nodes. Check with node --version and the Node-RED startup log before upgrading. Node.js 20 is past end-of-life upstream; 22 or later is recommended, and Node-RED 5 requires 22.9 regardless of this package.
Step 1 — re-enter your credentials (required, do this first)
The username and password have moved out of the flow file into Node-RED's credential store. There is no fallback to the old values, so every WebIQ API Connect node stops connecting until you re-enter them. The node tells you so:
WebIQ credentials must be re-entered after upgrading to 2.0...
and its status reads credentials need re-entry. (If you ran a full deploy before opening the node, the old properties are already stripped and the badge reads the generic credentials missing instead — same cause, same remedy.)
This is deliberate. An automatic fallback was considered and rejected: Node-RED serializes only the properties a node declares, and the old username/password are no longer declared — so any full deploy silently discards them. A node that worked after upgrading and then lost its credentials on an unrelated deploy days later would be far harder to diagnose than one that fails immediately.
Before upgrading:
  1. Write down the username and password for every connection node, or export your flows and keep the export somewhere safe. Once the new version loads, the editor fields are blank and the old values are only recoverable from a backup.
After upgrading, for each WebIQ API Connect node:
  1. Open it, type the username and password in again, click Done.
  2. Deploy.
  3. Confirm: export the flow (menu → Export) and check that no "username" or "password" appears in the JSON.
Rotate any password that was previously exported, committed to version control, or included in a backup. It has been readable in plaintext for its entire life, and moving it into the credential store does not undo that.
Step 1b — API Request nodes from 1.0.x need rebuilding
Very old (1.0.x) API Request nodes stored cmd, id, data and interval as separate fields. That layout was dropped in 1.1 and is not supported: such a node shows needs migration and explains what to do. Open it and put the whole request into the Data field as JSON:
{ "cmd": "io.read", "id": 1, "data": ["DSin", "SInt"] }
Once the whole request is in the Data field (or the type is switched to a dynamic source), saving the dialog clears the old fields — that save is the migration, and the node reports ready on the next deploy. A save that leaves Data unmigrated — closing the dialog after just reading it, or saving a JSON typo — keeps the old fields and the needs migration guidance intact.
The old interval field polled automatically and was in milliseconds. There is no built-in polling — drive the node from an Inject node set to repeat. The node tells you its own former interval when it reports needs migration, so a 500 ms poll becomes an Inject repeating every 0.5 s. (An interval that was not a positive number never polled at all — 1.0.x ignored it — and the message says so.)
Give each API Request node a distinct, non-zero id. Replies all arrive on the connection node's single output, and id: 0 is reserved for the connection's own login — a node using it warns on deploy. If a downstream flow filters replies by id, keep the id the migration message quotes back: 1.0.x derived the request id from the node's own id, so a generated hex id sent its leading digits on the wire (and one starting with a letter sent null).
Step 2 — expect Catch nodes to start firing (behaviour change)
In 1.x, failures from these nodes never reached a Catch node — the message was dropped silently. They are now reported properly, so if you have a catch-all Catch node, it may start receiving errors it has never seen before from flows you did not change. Those errors were always happening; they were just invisible.
Step 3 — optional but recommended
  • Turn on Secure if your WebIQ server terminates TLS. 1.x could only speak ws://, so credentials crossed the network unencrypted.
  • Leave Heartbeat at 30 s. Field-tested: WebIQ answers WebSocket pings, so an idle connection stays green. If you ever see flapping on a very slow link, raise the interval rather than disabling — 0 restores the 1.x behaviour where a dead connection is undetectable.
Troubleshooting
The node's status badge names the problem. The most common ones:
Status / message What it means What to do
credentials need re-entry A 1.x node still has its credentials in the flow file. Open the node, type the username and password in again, redeploy. See Upgrading from 1.x.
credentials missing No username/password have been entered. Open the node and enter them. The node will not send a login without credentials.
TLS config unresolved A TLS configuration is selected but the config node is missing. The node refuses to connect rather than silently falling back to unencrypted — re-select or recreate the tls-config node.
TLS config invalid The selected configuration is not a tls-config node, or it is one whose certificate files failed to load (valid === false). The node refuses rather than connecting without the selected certificates. If it is a real tls-config node, fix the certificate/key/CA file paths on it; otherwise re-select a real one.
host missing The Host field is empty. Fill it in.
invalid connection settings The WebSocket could not be created from these settings at all. Rare — the host/port combination is malformed in a way the earlier checks did not catch. The node retries every 30 s in case an environment variable or DNS entry fixes it.
invalid host The Host contains URL syntax — userinfo (@), a scheme, a path, a query/fragment character, whitespace, or an embedded port. Enter only the host name or IP; the port belongs in the Port field. Userinfo is rejected because [email protected] looks like one host but connects to another — and would send your credentials there.
invalid port Port is not an integer in 1–65535. In 1.x an empty port silently dialled port 80 and reported it as a project failure. Set the real port, usually 10123.
project missing / invalid project Project is empty, or contains /, ?, # or \. Use the project name or UUID only, not a URL or path.
connected - login pending (stuck) The socket opened but the server has not answered the login. Usually a slow PLC. Raise Login timeout.
login timeout No login reply within the timeout. Raise Login timeout — a slow PLC-backed project may need considerably longer.
login unanswered - retrying every 60s Login attempts logins in a row went unanswered. The server is probably down or still booting. The node keeps probing every 60 seconds and recovers on its own the moment the server answers — no action needed unless the server should be up.
login failed (n/N) The server rejected the login; n of the configured Login attempts are used. Read the warning in the log — it carries WebIQ's own wording, which distinguishes a wrong password from a licence limit or a lockout. Fix the cause before the budget runs out.
login blocked - fix and redeploy The node has stopped trying: WebIQ reported a lockout, or Login attempts consecutive logins were rejected as bad credentials. (too many clients and unanswered logins never count toward this.) Deliberate. WebIQ counts login attempts and will lock the account — usually the same account your HMI clients use, so a typo here can take out operator screens. Fix the credentials and redeploy, or send msg.webiq = "reconnect" — it grants one fresh attempt, at most once per 60 s.
server full - retrying in Ns / server full - reconnecting / server full - retrying every 60s WebIQ replied too many clients: no free client/licence slot. After a network drop this is usually your own previous session, still held by the server until its dead-session detection reaps it. Usually nothing — this never latches and never spends the login budget; the node keeps retrying gently and logs in by itself the moment the slot frees. To recover faster, delete the stale session in WebIQ's Active Sessions panel.
reconnecting on request A msg.webiq = "reconnect" control message was accepted. Transient; the normal connection states follow.
connection refused / host not found / server unreachable Transport failure before any login was sent. Check host, port, network path and firewall. Earlier versions reported all of these as project not found, which pointed at the wrong field.
TLS certificate rejected The server certificate was not trusted (self-signed, unknown CA, missing intermediate). Check the tls-config node's CA settings.
connection failed A pre-login transport failure that matched no specific classification — most commonly the 10 s handshake timeout against a server that accepts TCP but never answers the upgrade. Check that the server is actually a WebIQ endpoint and that nothing on the path is black-holing traffic.
subprotocol rejected The server did not accept smarthmi-connect. Usually a reverse proxy stripping the Sec-WebSocket-Protocol header.
server rejected upgrade (HTTP nnn) The server refused the WebSocket handshake. A wrong Project name is the most likely cause — the project is part of the connection URL, so an unknown project is refused here, before any login. Shown for 400, 401, 403, 404, 410; retries every 30 s. Also check host, port and any reverse proxy.
server unavailable (HTTP nnn) The server or proxy is busy or broken, not misconfigured. Everything else, including 429 and every 5xx, retries on the normal fast ladder. Usually no action needed.
link stale - reconnecting Two consecutive probes went unanswered, with no other traffic. Normal after a network drop — it reconnects automatically. Persistent flapping means the server does not answer pings and sends nothing between probes; raise Heartbeat rather than disabling it.
send buffer full The server has stopped reading and 1 MB is queued. Requests are being dropped rather than buffered forever. Check server load.
disconnected No connection; reconnecting with backoff (1 s doubling to 30 s). Wait, or check the server.
After a network drop: too many clients
When the network between Node-RED and WebIQ fails uncleanly (pulled cable, Wi-Fi drop), the server keeps the old, dead session alive until its own detection reaps it — observed at roughly 15 minutes on an X3web. Until then, your reconnecting node bounces off the client limit with too many clients, because the seat is held by its own ghost.
The node handles this on its own: capacity rejections never latch, and it keeps retrying gently until the seat frees. If 15 minutes is too long:
  • Delete the dead session manually in WebIQ Setup → Active Sessions.
  • Raise the reap time with your WebIQ contact. ~15 minutes is suspiciously close to the Linux TCP retransmission timeout (tcp_retries2 = 15 ≈ 15.4 min), which suggests the server notices dead clients only when TCP gives up, rather than via an application-level ping of its own.
Errors you may see on a message (all trappable with a Catch node):
Error Cause
WebIQ node is not configured: ... The node has a configuration error. In 1.x this message vanished with no error at all.
Cannot send: not authenticated yet The request arrived before login completed.
WebSocket is not connected No live connection at that moment.
Payload is missing required fields: cmd, id, data The payload reaching the connect node is not a WebIQ request.
... is not a valid WebIQ request: missing "id" The API Request node's data — static or dynamic — is incomplete.
Could not serialise payload: ... The payload contains a circular reference or a BigInt.
WebIQ rejected <cmd>: [category errc n] ... The server refused the request — unknown tag, read-only item, insufficient rights. The reply is still forwarded on the output as well.
WebIQ login is blocked: ... The node is latched; the message was refused. See login blocked above.
WebIQ reconnect refused: ... A msg.webiq = "reconnect" arrived inside the 60 s cooldown.
WebIQ reconnect control message: the payload was NOT sent... A reconnect control message also carried a payload; the payload was not sent — resend it after the node authenticates.
WebIQ send buffer is backed up ... Backpressure: the request was dropped, not queued.
Unusable WebIQ frame forwarded as raw data: ... A frame could not be parsed, or was nested deeper than 64 levels. It is forwarded as a raw buffer instead of an object, so msg.payload arrives as a Buffer. The depth limit exists because Node-RED clones messages recursively, and an over-deep frame would otherwise crash the runtime.
If a request seems to vanish, check that the connection node reached authenticated (green). Requests sent while it is any other colour are rejected with an error rather than queued.
Contributing
Contributions are welcome! Please fork the repository and submit a pull request.
This project is licensed under the MIT License.
Links
Contact
For any questions or issues, please open an issue in the GitHub repository.
Version: 2.0.0
Updated 3 months ago
Rating: 5.0 4
3 in the last week
  • webiq-api-connect
  • api-request
  • webiq
  • iot
