node-red-contrib-waveshare-shield-adda-11010 2.0.3
Plug and Play Node-RED nodes for a Waveshare model 11010 Raspberry Pi AD/DA Shield
npm install node-red-contrib-waveshare-shield-adda-11010
A set of Node-RED nodes to control the AD and DA converters on a Waveshare AD/DA raspberry pi shield
This node provides plug and play use of the hardware on the shield.
Simply set the jumpers on the shield, plug in the shield, enable SPI port on the Raspberry Pi, install some python libraries, install this Node-RED node, then every pin on the board just works with no further configuration required.
See the wiki for more details.
Either use the Node-RED Menu - Manage Palette option to install, or run the following command in your Node-RED user directory - typically ~/.node-red
    npm i node-red-contrib-waveshare-shield-adda-11010
Enable the SPI port. On a Raspberry Pi it would look like this:
    sudo raspi-config
Enable the SPI interface. Option "3 Interfacing Options". Option "P4 SPI". Enable "Yes". Probably have to reboot.
Then install python and pip:
    sudo apt-get install python3-pip
    pip3 install --upgrade pip --user
You will probably have to reboot at this time for ~/.local/bin to be automatically added to your path.
Now install, or upgrade the python rpi.gpio and spidev libraries using the script at:
    ~/.node-red/node_modules/node-red-contrib-waveshare-shield-adda-11010/upgrade_pip.sh
or manually:
    pip install --upgrade rpi.gpio --user
    pip install --upgrade spidev --user
Finally after the node is installed, SPI is enabled, python and pip are installed, and rpi.gpio and spidev are installed, you'll probably have to do one final reboot before the node works.
On the hardware I would suggest installing the shorting horizontal jumper between AINCOM and AGND unless your application has an unusual need for a floating ground input.
I would suggest on a Raspberry Pi installing the vertical right side jumper between Vcc and 3V3 and the adjacent vertical right side jumper between Vref and 3V3. The Vref on that jumper refers to the DAC converter the ADC converter has a hard wired LM285 voltage reference.
For initial testing and experimentation purposes I would suggest installing the vertical jumpers on the right side connecting LEDB to DAC1, LEDA to DAC0, AD1 to LDR (light sensor), and AD0 to ADJ (adjustable on board potentiometer).
There are working example flows for all ports. In Node-RED, click the right side hamburger menu, "import", "Examples", "node-red-contrib-waveshare-shield-adda-11010"
Some demo flows may require jumper wires to be installed, for example, from DAC1 to LEDB.
DAC Input
  • msg.payload - number | string
msg.payload out of range high or low will be rounded.
msg.payload scale for maximum can be set to 3.3, or 5.0 to match Vref hardware jumper.
See help file for more detail.
ADC Output
  • msg.payload - any
msg.payload any input triggers the start of an analog to digital conversion.
About two seconds after the conversion is triggered, a numeric voltage will be output.
Digital Inputs
msg.payload any input triggers the start of an digital read.
A numeric binary 1 or 0 will be output based on the pin voltage.
The pin will be set to input mode.
Digital Outputs
msg.payload a binary 1 or 0 sets the pin voltage Vcc or zero.
The pin will be set to output mode.
Links
Hardware Links:
Board Manufacturer Store: https://www.waveshare.com/High-Precision-AD-DA-Board.htm
Board Manufacturer Wiki: https://www.waveshare.com/wiki/High-Precision_AD/DA_Board
Links for ADS1256 chip: https://www.ti.com/product/ADS1256 https://www.ti.com/lit/gpn/ads1256
Book "Fundamentals of Precision ADC Noise Analysis" https://www.ti.com/lit/pdf/slyy192
Journal Series "How delta-sigma ADCs work" https://www.ti.com/lit/pdf/slyt423 https://www.ti.com/lit/pdf/slyt438
App Note "Digital Filter Types in Delta-Sigma ADCs" https://www.ti.com/lit/pdf/sbaa230
Link for LM285 chip, connected to the ADS1256: https://www.ti.com/product/LM285-2.5-N https://www.ti.com/lit/gpn/lm285-2.5-n
Link for DAC8532 chip: https://www.ti.com/product/DAC8532 https://www.ti.com/lit/gpn/dac8532
Spring City Solutions Links:
Spring City Solutions Node-RED project page: https://www.springcitysolutions.com/nodered
Spring City Solutions page for this node: https://www.springcitysolutions.com/nodered-waveshare-adda-shield
Spring City Solutions Node-RED project email: [email protected]
Spring City Solutions Gitlab for this node: https://gitlab.com/SpringCitySolutionsLLC/waveshare-shield-adda-11010
Patreon Page: https://www.patreon.com/springcitysolutions_nodered
Software Links:
Doxygen docs for this node autogenerated by Gitlab CI/CD: https://springcitysolutionsllc.gitlab.io/waveshare-shield-adda-11010/index.html
npmjs for this node: https://npmjs.org/package/node-red-contrib-waveshare-shield-adda-11010
Node-RED flows for this node: https://flows.nodered.org/node/node-red-contrib-waveshare-shield-adda-11010
Documentation Links:
Gitlab wiki for this node (the master copy of list of links is here): https://gitlab.com/SpringCitySolutionsLLC/waveshare-shield-adda-11010/-/wikis/home
Waveshare's libraries for this hardware: https://github.com/waveshare/High-Precision-AD-DA-Board
Youtube video "How to set up": ?
Youtube video "How to use": ?
Youtube video "Testing Results": ?
Trademarks
WAVESHARE (tm) is a trademark of Shenzhen Weixue Electronic Co., Ltd.
Raspberry Pi is a trademark of Raspberry Pi Trading
Node-RED and node.js are a trademark of the OpenJS Foundation in the United States
Python is a registered trademark of the Python Software Foundation.
"All trademarks are property of their respective owners"
Copyrights and Licenses
Majority of code Copyright (c) 2020-2022 Spring City Solutions LLC and other contributors and licensed under the Apache License, Version 2.0
Icon made from http://www.onlinewebfonts.com/icon aka Icon Fonts is licensed by CC BY 3.0
Version: 2.0.3
Updated 5 years, 2 months ago
15 in the last week
  • analoginput
  • analogoutput
  • gpioinput
  • gpiooutput
  • Pi
