node-red-contrib-waveshare-sense-hat-b-16864 1.5.0
Plug and Play Node-RED nodes for a Waveshare Sense Hat (b) 16864
npm install node-red-contrib-waveshare-sense-hat-b-16864
A set of Node-RED nodes to control the numerous hardware components on the Waveshare(tm) Sense Hat (B) model aka 16864 which is a Raspberry Pi expansion board.
The sensors on this board all use I2C, remember to enable I2C when running "sudo raspi-config"
Simply plug in the shield, install this Node-RED node, the hardware just works with no configuration required.
This board contains the following sensors: ICM20948 accelerometer / gyroscope / magnetometer SHTC3 temperature / humidity LPS22HB barometer TCS34725 color sensor ADS1015 four channel twelve bit ADC
See the wiki for more details.
You can watch the Youtube video describing how to set up the board: (To be Added)
Either use the Node-RED Menu - Manage Palette option to install, or run the following command in your Node-RED user directory - typically ~/.node-red
    npm i node-red-contrib-waveshare-sense-hat-b-16864
Enable I2C using raspi-config
Run the following line at the Pi command line: sudo apt-get install i2c-tools python3-smbus
Run i2cdetect 1 and hit y and you should see the devices on 29, 48, 5c, 68, and 70 If this works, the nodes will work. If this does not work, then you probably need to enable I2C or maybe reboot the Pi.
Here is a link to the Youtube video describing how to use the software: (To be Added)
Also you might want to watch the Youtube video showing electronics test bench performance of the hardware: (To be Added)
The analog input, barometer, light sensor, temperature, humidity, magnetometer, gyroscope, and accelerometer all work.
Input
  • msg.payload - boolean | number | string
Any msg.payload will initiate a sample of any of the devices.
Funding
Please consider becoming a patron of Spring City Solutions LLC Your support directly funds the development of new drivers and nodes for Node-RED.
For the latest news, detailed daily dev logs are posted on the Patreon page.
https://www.patreon.com/springcitysolutions_nodered
Links
Hardware Links:
Board Manufacturer Store: https://www.waveshare.com/sense-hat-b.htm
Board Manufacturer Wiki: https://www.waveshare.com/wiki/Sense_HAT_(B)
ADS1015 four channel twelve bit ADC from Texas Instruments (tm): https://www.ti.com/product/ADS1015
Free Ebook "Fundamentals of Precision ADC Noise Analysis": https://www.ti.com/lit/pdf/slyy192
Analog Design Journal Article "How delta-sigma ADCs work" two parts: https://www.ti.com/lit/pdf/slyt423 https://www.ti.com/lit/pdf/slyt438
Application Note "SBAA230" Digital Filter Types in Delta Sigma ADCs: https://www.ti.com/lit/pdf/sbaa230
Grove Protoshield (Not a part of the board but IS a part of my development system): http://wiki.seeedstudio.com/Grove-Protoshield/
ICM-20948 accelerometer / gyroscope / magnetometer from TDK (tm): https://invensense.tdk.com/products/motion-tracking/9-axis/icm-20948/
LPS22HB barometer from ST Microelectronics (tm) : https://www.st.com/en/mems-and-sensors/lps22hb.html
Application Note AN4833 "Measuring pressure data from ST's LPS22HB digital pressure sensor" : https://www.st.com/resource/en/application_note/an4833-measuring-pressure-data-from-sts-lps22hb-digital-pressure-sensor-stmicroelectronics.pdf
Technical Note TN1229 "How to interpret pressure and temperature readings in the LPS22HB pressure sensor" : https://www.st.com/resource/en/technical_note/tn1229-how-to-interpret-pressure-and-temperature-readings-in-the-lps22hb-pressure-sensor-stmicroelectronics.pdf
RT9193 voltage regulator from RICHTEK (tm): https://www.richtek.com/assets/product_file/RT9193/DS9193-16.pdf
SHTC3 temperature / humidity from Sensirion (tm): https://www.sensirion.com/en/environmental-sensors/humidity-sensors/digital-humidity-sensor-shtc3-our-new-standard-for-consumer-electronics/
TCS34725 color sensor from AMS (tm) : https://ams.com/tcs34725
Application Note DN20 Colorimetry Tutorial : https://ams.com/documents/20143/36005/LightSensors_AN000519_1-00.pdf/d2a0670d-7557-ed94-cc0e-225cfa8cb031
Application Note DN25 Calculating Color Temperature and Illuminance : https://ams.com/documents/20143/36005/TCS34xx_AN000517_1-00.pdf/616f6ed0-8409-a21d-cd85-307a1e377102
Application Note Improving Color Sensor Lux Accuracy : https://ams.com/documents/20143/36005/ColorSensors_AN000261_1-00.pdf/5d76b23f-7670-505c-a4d2-94cae758855e
Application Note DN40 Lux and CCT calculations : https://ams.com/documents/20143/36005/ColorSensors_AN000166_1-00.pdf/d1290c78-4ef1-5b88-bff0-8e80c2f92b6b
Spring City Solutions Links:
Spring City Solutions Node-RED project page: https://www.springcitysolutions.com/nodered
Spring City Solutions page for this node: https://www.springcitysolutions.com/nodered-waveshare-sense-hat
Spring City Solutions Node-RED project email: [email protected]
Spring City Solutions Gitlab for this node: https://gitlab.com/SpringCitySolutionsLLC/waveshare-sense-hat-b-16864
Patreon Page: https://www.patreon.com/springcitysolutions_nodered
Software Links:
Doxygen docs for this node autogenerated by Gitlab CI/CD: https://springcitysolutionsllc.gitlab.io/waveshare-sense-hat-b-16864/index.html
npmjs for this node: https://www.npmjs.com/package/node-red-contrib-waveshare-sense-hat-b-16864
Node-RED flows for this node: https://flows.nodered.org/node/node-red-contrib-waveshare-sense-hat-b-16864
Documentation Links:
Gitlab wiki for this node (the master copy of list of links is here): https://gitlab.com/SpringCitySolutionsLLC/waveshare-sense-hat-b-16864/-/wikis/home
Youtube video "How to set up": TODO
Youtube video "How to use": TODO
Youtube video "Testing Results": TODO
Trademarks
AMS (tm) is a trademark of AMS Osram Group AG
Node-RED and node.js are a trademark of the OpenJS Foundation in the United States
Python is a registered trademark of the Python Software Foundation.
Raspberry Pi is a trademark of Raspberry Pi Trading
Richtek is a registered trademark of Richtek Technology Corporation
Sensirion (tm) is a trademark of Sensirion AG
ST Microelectronics (tm) is a trademark of STMICROELECTRONICS, INC.
TDK (tm) is a trademark of TDK KABUSHIKI KAISHA TDK CORPORATION
Texas Instruments (tm) is a trademark of Texas Instruments
WAVESHARE (tm) is a trademark of Shenzhen Weixue Electronic Co., Ltd.
"All trademarks are property of their respective owners"
Copyrights and Licenses
Majority of code Copyright (c) 2021-2022 Spring City Solutions LLC and other contributors and licensed under the Apache License, Version 2.0
Icon made from http://www.onlinewebfonts.com/icon aka Icon Fonts is licensed by CC BY 3.0
Version: 1.5.0
Updated 3 years, 3 months ago
Rating: 5.0 2
3 in the last week
  • accelmag
  • analog
  • barometer
  • lightsensor
  • temphumidity
  • Pi
