node-red-contrib-viewtron 2.1.1
Receive AI detection events from Viewtron IP cameras — license plate recognition (LPR/ALPR), human detection, vehicle detection, face detection. On-camera AI, no cloud required.
npm install node-red-contrib-viewtron
Viewtron AI camera node for Node-RED. Receives AI detection events from Viewtron AI security cameras and NVRs. License plate recognition (LPR/ALPR), human detection, vehicle detection, face detection, people counting, and intrusion detection — all processed on the camera with no cloud service required. Supports both direct camera connections (IPC v1.x) and NVR forwarding (v2.x) with automatic version detection.
Viewtron AI Camera node in Node-RED with live LPR events
In Node-RED: Menu > Manage palette > Install > search node-red-contrib-viewtron
Or via command line:
Requires Node.js 18+, Node-RED 2.0+, and viewtron-sdk 1.1.0 or newer. The SDK dependency is installed automatically.
How It Works
v2.0.0 uses a Config Node + Listener Node architecture built on the Viewtron Node.js SDK.
                                    +---> Viewtron AI Camera node ---> LPR Flow
Camera 1 ---+                       +---> Viewtron AI Camera node ---> Intrusion Flow
Camera 2 ----+---> Viewtron Server -+
             /    (Config Node)     |
Camera 3 ---+     port 5050        +---> Viewtron AI Camera node ---> Dashboard
NVR ---------+                      +---> Viewtron AI Camera node ---> MQTT Bridge
Viewtron Server (config node) — runs a shared HTTP server on a single port. All cameras and NVRs connect to this one server. Handles persistent connections, keepalive heartbeats, XML parsing, and all camera protocol requirements via the SDK. Hidden from the palette; created from the server dropdown on the Viewtron AI Camera node.
Viewtron AI Camera (listener node) — receives parsed events from the server and routes them to 5 category outputs: LPR, Intrusion, Face, Counting, and Other. Multiple listener nodes can share one server. Each listener receives every event from every connected camera. Optional filters on the listener (direction, minimum confidence, plate list) apply to the LPR output only and default to passing every plate. Use standard Node-RED Switch nodes after any output to branch by camera, channel, plate list, direction, confidence, or any other field.
No middleware, no bridge, no cloud API. The cameras post directly to Node-RED.
Camera Setup
1. Add the node to your flow
Drag the Viewtron AI Camera node from the palette onto the canvas. Select a Viewtron Server from the dropdown (or create one with the pencil icon). The default port is 5050.
2. Configure HTTP POST on the camera
Open your camera's web interface and navigate to Network > Advanced > HTTP Notification.
Viewtron camera HTTP POST settings
Set the Push Protocol Version to V1, then click Add to create a server entry.
3. Configure the server connection
HTTP POST server configuration
Setting Value
Enable Checked
Domain/IP Your Node-RED machine's IP address
Server Port Port configured in the Viewtron Server config node (default: 5050)
Path /API
Connection Type Persistent connection
Send Heartbeat Checked
Heartbeat Interval 30 seconds
Smart Alarm Data Check Smart event data
Original picture Check to include full scene image in events
Target picture Check to include cropped target image in events
Smart Alarm Type Select the detection types you want (e.g., License Plate Detection)
Click Save, then reboot the camera — required after changing HTTP POST settings. Deploy your flow in Node-RED and events will start arriving immediately.
Connection status
The camera maintains a persistent HTTP connection and sends heartbeats to confirm the server is reachable. The node status shows a green ring when listening and updates with a green dot and the latest event data (e.g., plate number and group).
Direct Connection vs NVR
For the easiest filtering, connect IP cameras directly to your network and configure each camera's HTTP POST to send events to the Viewtron Server. Each camera connects from its own IP address, so you can filter events using msg.payload.cameraIp in a Switch node.
When cameras are connected to an NVR's PoE ports and the NVR forwards events, all events arrive from the NVR's IP address. Intrusion, face, and counting events include a msg.payload.channelId that identifies which camera on the NVR triggered the event. However, NVR license plate events do not include a channel ID, so there is no way to determine which LPR camera behind the NVR detected the plate.
For LPR cameras, always connect directly to the network so each camera has its own IP address for filtering.
IPC (Direct) NVR (Forwarded)
Connection Camera -> Node-RED Camera -> NVR -> Node-RED
XML Version v1.x v2.x
Plate detection Yes Yes
Plate database groups Fixed: whiteList, blackList, temporaryList, strangerList User-defined: any group name
Direction approach, away, or null null
Confidence 0–100, or null when the camera omits it null
Vehicle attributes When the camera sends them Yes (brand, color, type, model)
Owner from database No Yes
Channel ID No Yes (intrusion, face, counting only — not LPR)
Images Yes (both) Yes (both)
Outputs
The node has 5 outputs, one per detection category:
Output Category Key Fields
1 LPR plateNumber, plateGroup, plateList, direction, confidence, eventTime, vehicle / vehicleColor / vehicleBrand / vehicleType / vehicleModel, carOwner (NVR only)
2 Intrusion targetType (person, car, motorcycle), eventId, status, boundary (area, tripwire — NVR only)
3 Face face.age, face.sex, face.glasses, face.mask (NVR only)
4 Counting targetType, boundary
5 Other Video metadata and unclassified events
Wire each output to the flow logic you need — separate handling for plates vs. people vs. faces.
LPR Fields (Output 1)
Field IPC NVR Description
plateNumber Yes Yes Detected license plate text
plateGroup Yes Yes Raw plate database group — see Plate Groups
plateList Yes When the group name is one of the four known lists whiteList, blackList, temporaryList, strangerList, or null
direction Yes null approach, away, or null when the camera does not send a direction
confidence Yes null Recognition confidence from 0 to 100. A camera value of 9900 is 99. 0 is a real score. Missing is null
eventTime Yes Yes Date parsed from the camera clock. timestamp stays the raw text
vehicle.type / vehicleType When sent Yes Vehicle type (e.g., "sedan", "SUV")
vehicle.color / vehicleColor When sent Yes Vehicle color
vehicle.brand / vehicleBrand When sent Yes Vehicle brand (e.g., "Toyota")
vehicle.model / vehicleModel When sent Yes Vehicle model
plateColor No Yes Plate color (e.g., "white")
carOwner No Yes Owner name from NVR plate database
sourceImage Yes Yes Overview image (base64 JPEG)
sourceImageBytes Yes Yes Overview image (Buffer)
targetImage Yes Yes Plate crop image (base64 JPEG)
targetImageBytes Yes Yes Plate crop image (Buffer)
vehicle and the flat vehicleColor, vehicleBrand, vehicleType, and vehicleModel fields carry the same attributes. The flat fields are empty strings when the post has no vehicle attributes. plateList is null for custom NVR group names; those names stay on plateGroup.
Common Fields
Every event message includes:
Field Type Description
msg.payload.source string IPC (direct from camera) or NVR (via NVR)
msg.payload.category string lpr, intrusion, face, counting, metadata
msg.payload.eventType string Raw alarm type from camera (e.g., VEHICE, PEA, regionIntrusion)
msg.payload.eventDescription string Human-readable description of the event type
msg.payload.cameraIp string Camera IP (direct connection) or NVR IP (NVR connection)
msg.payload.cameraName string Device name configured on the camera or NVR
msg.payload.cameraMac string MAC address of the camera or NVR
msg.payload.channelId string NVR channel number (intrusion, face, counting only — not present on NVR LPR events)
msg.payload.timestamp string Raw camera currentTime text. Direct camera posts often send microseconds, including on 5.3.x firmware. This value is not converted
msg.payload.eventTime Date The same instant as a Date, or null when the camera time is missing. Values of 100 trillion or more are microseconds, 100 billion or more are milliseconds, and smaller values are seconds
msg.payload.configVersion string Config version from the post, for example 1.7 or 2.1.0
msg.payload.format string v1 or v2, from the config version major
msg.payload.hasImages boolean true when images are present
msg.topic string viewtron/{category} for easy MQTT republishing
Images
When Original picture and Target picture are enabled on the camera, events include both base64 strings and decoded Buffer bytes:
sourceImage string Full scene image as base64 JPEG
sourceImageBytes Buffer Full scene image as decoded JPEG bytes
targetImage string Cropped target (plate, face) as base64 JPEG
targetImageBytes Buffer Cropped target as decoded JPEG bytes
The Buffer fields are ready to pipe directly to file nodes, dashboard image widgets, or MQTT nodes. The base64 fields are useful for embedding in HTML or sending via API.
Viewtron LPR camera dashboard in Node-RED
Screenshot of sourceImage and targetImage displayed in a Dashboard 2.0 template widget. To recreate this, wire the LPR output (output 1) to a ui-template node with this content:
<div v-if="msg?.payload?.plateNumber">
  <h3>{{ msg.payload.plateNumber }} — {{ msg.payload.plateList || msg.payload.plateGroup || "unknown" }}</h3>
  <p v-if="msg.payload.confidence != null">
    {{ msg.payload.direction || "direction unknown" }} · {{ msg.payload.confidence }}
  </p>
</div>
<div v-if="msg?.payload?.sourceImage" style="margin-bottom:10px">
  <img :src="'data:image/jpeg;base64,' + msg.payload.sourceImage" style="width:100%" />
</div>
<div v-if="msg?.payload?.targetImage">
  <img :src="'data:image/jpeg;base64,' + msg.payload.targetImage" style="width:100%" />
</div>
Requires @flowfuse/node-red-dashboard (Dashboard 2.0).
Filtering by Camera
By default the node outputs every event from every connected camera. The listener has three optional LPR filters. Leave them blank and every plate is passed through. They do not affect intrusion, face, counting, or other events.
Node setting Default Effect on the LPR output
Direction Any Keep only approach or only away
Min confidence Blank Drop plates below this score. A plate with no confidence is dropped when a minimum is set
Plate list Any Keep one of whiteList, blackList, temporaryList, or strangerList
All three are combined. A plate must match every filter that is set. Existing flows have no filter values, so they keep receiving every plate.
Use a Switch node when one event needs more than one destination, for example opening a gate and also alerting. Switch fields:
Field Use Case
msg.payload.cameraIp Filter by camera IP address (best for direct connections)
msg.payload.channelId Filter by NVR channel number (intrusion, face, counting events only)
msg.payload.source Filter by IPC (direct) or NVR
msg.payload.plateList Route known lists: whiteList, blackList, temporaryList, strangerList
msg.payload.plateGroup Route by the raw plate database group, including custom NVR names
msg.payload.direction Route approach or away
msg.payload.confidence Route by a minimum score
msg.payload.targetType Filter by person, car, motorcycle
Example: filter LPR events from a specific camera. Wire the LPR output to a Switch node with property msg.payload.cameraIp equals 192.168.1.100.
Example: LPR Gate Access
Import this flow to get started with license plate gate access control. The Viewtron AI Camera node reads plates, and a Switch node routes plates based on their group.
        "id": "server1",
        "type": "viewtron-server",
        "name": "Camera Server",
        "port": "5050"
        "id": "viewtron1",
        "type": "viewtron-camera",
        "name": "Gate Camera",
        "server": "server1",
        "wires": [["switch1"], [], [], [], []]
        "id": "switch1",
        "type": "switch",
        "name": "Check Group",
        "property": "payload.plateGroup",
        "rules": [
            {"t": "eq", "v": "whiteList"},
            {"t": "else"}
        "outputs": 2,
        "wires": [["gate_open"], ["notify"]]
        "id": "gate_open",
        "type": "debug",
        "name": "Open Gate"
        "id": "notify",
        "type": "debug",
        "name": "Alert: Unknown Vehicle"
Example: Allow List Gate and Block List Alert
Leave the node's direction, confidence, and plate list filters blank.
This is the same allow / block logic we use for license plate recognition gate access. For a code version of an entry gate, see LPR camera API for entry gate automation.
This flow uses the LPR output and Switch nodes so one camera can do both jobs:
  • Open the gate only for an allow-list plate (plateList = whiteList) that is approaching with confidence of at least 90.
  • Alert when the plate is on the block list (plateList = blackList).
Plates that miss any of the allow-list checks are dropped. Custom NVR group names are on plateGroup instead of plateList; switch on plateGroup for those.
        "id": "server1",
        "port": "5050"
        "id": "gate_camera",
        "direction": "",
        "minConfidence": "",
        "plateList": "",
        "wires": [["switch_list"], [], [], [], []]
        "id": "switch_list",
        "type": "switch",
        "name": "Plate list",
        "property": "payload.plateList",
        "propertyType": "msg",
        "rules": [
            {"t": "eq", "v": "whiteList", "vt": "str"},
            {"t": "eq", "v": "blackList", "vt": "str"}
        "checkall": "false",
        "outputs": 2,
        "wires": [["switch_direction"], ["alert_block"]]
        "id": "switch_direction",
        "type": "switch",
        "name": "Approaching",
        "property": "payload.direction",
        "rules": [
            {"t": "eq", "v": "approach", "vt": "str"}
        "outputs": 1,
        "wires": [["switch_confidence"]]
        "id": "switch_confidence",
        "type": "switch",
        "name": "Confidence at least 90",
        "property": "payload.confidence",
        "rules": [
            {"t": "gte", "v": "90", "vt": "num"}
        "outputs": 1,
        "wires": [["gate_open"]]
        "id": "gate_open",
        "type": "debug",
        "name": "Open Gate"
        "id": "alert_block",
        "type": "debug",
        "name": "Alert: Block list"
The same allow-list rule can be set on the node itself (Direction = Approaching, Min confidence = 90, Plate list = Allow list) when that listener should not receive other plates. Use a second listener on the same server, with Plate list = Block list, for the alert.
Plate Groups
The plateGroup field contains the raw value from the camera or NVR plate database. Your flow decides what each group means. plateList repeats that value when it is whiteList, blackList, temporaryList, or strangerList, and is null for any other group name.
IPC cameras use fixed group names (these are the raw XML values):
plateGroup Camera UI Label
whiteList Allow list
blackList Block list
temporaryList Temporary vehicle
strangerList Stranger list
(empty) Not in database
NVRs use user-defined group names — you create groups and name them whatever you want (e.g., "Whitelist", "Residents", "Banned"). The plateGroup field shows the group name, or empty if the plate is not in the database.
Plates are added to the camera's database through its web interface or programmatically via the viewtron Python SDK (pip install viewtron).
Supported Event Types
IPC v1.x (Direct from Camera)
Alarm Type Category Detection
VEHICE / VEHICLE lpr License plate recognition
VFD face Face detection
PEA intrusion Perimeter intrusion
AOIENTRY zone_entry Zone entry
AOILEAVE zone_exit Zone exit
LOITER loitering Loitering detection
VSD metadata Video metadata
PASSLINECOUNT counting People/vehicle counting
NVR v2.x (Forwarded via NVR)
vehicle lpr LPR with vehicle brand, color, type, model
videoFaceDetect face Face with age, sex, glasses, mask attributes
regionIntrusion intrusion Perimeter intrusion
lineCrossing line_crossing Tripwire line crossing
targetCountingByLine counting Counting by line
targetCountingByArea counting Counting by area
videoMetadata metadata Continuous object detection
Version detection is automatic — the SDK handles both formats.
Compatible Cameras
Any Viewtron AI security camera or NVR with HTTP POST support:
  • Viewtron LPR-IP4 license plate recognition camera — 4MP LPR camera with on-camera plate recognition. API 2.1 firmware (5.3.x) adds direction, confidence, plate list and vehicle attributes to every plate. Fully tested with Node-RED.
  • AI security cameras — person, vehicle, and face detection. Testing scheduled.
  • NVRs — forward events from all connected cameras. LPR tested and working.
All Viewtron products are NDAA compliant.
Troubleshooting
Camera shows "Online" but no events appear: The camera's persistent connection is alive (heartbeats work) but alarm events may not be flowing. Try:
  1. Reboot the camera — required after changing HTTP POST settings
  2. Check that Smart event data and the correct Smart Alarm Type are enabled
  3. For NVR: ensure License Plate Detection is enabled in the HTTP Post settings
Port conflict ("port in use" status): Another process is already listening on the configured port. Either stop the other process or change the port in the Viewtron Server config node. Only one Viewtron Server config node should use a given port.
Debug tool: A standalone debug server is included for diagnosing connection issues:
node debug-server.js 5050
This logs every HTTP POST with full headers, body preview, and post classification (keepalive, alarm data, etc.) — no filtering. Raw XML is saved to raw_posts/ for inspection.
New in 2.1.1
Documentation only: link fixes and example updates. No code changes.
New in 2.1.0
2.1.0 adds fields. It does not change the five outputs or rename existing fields. Flows built for 2.0.0 keep working when the new filters are left blank.
Plate messages now include eventTime, direction, confidence, plateList, vehicleColor, vehicleBrand, vehicleType, and vehicleModel. Every event also includes configVersion and format. timestamp is still the raw camera time.
Alarm on/off notices are not detection events. They are not sent to any output. Keepalives are ignored the same way.
Requires viewtron-sdk 1.1.0 or newer.
Flows, screenshots and the full field list are in the Node-RED IP camera integration guide. See Compatible Cameras for the tested LPR camera.
Breaking Changes from v1
v2.0.0 is a full rewrite. Existing flows will need to be updated.
Change v1 v2
Architecture Single node with embedded HTTP server Config Node (Viewtron Server) + Listener Node (Viewtron AI Camera)
Server Each node runs its own server Shared server via config node — one port for all cameras
SDK XML parsing built into the node Uses viewtron-sdk npm package
Default port 5002 5050
Field names snake_case (plate_number, plate_group, car_owner, camera_ip, event_type, source_image) camelCase (plateNumber, plateGroup, carOwner, cameraIp, eventType, sourceImage)
Image Buffers Not available sourceImageBytes and targetImageBytes (decoded Buffer objects)
source field Not available IPC or NVR — identifies connection type
Image toggle includeImages checkbox on node Always included when camera sends them (enable/disable on the camera)
Filtering Not available Use Switch nodes on cameraIp, channelId, plateGroup, targetType
Node settings Port + Include images Server dropdown only (port is on the config node)
To migrate: Delete the old Viewtron AI Camera node, add a new one from the updated palette, create a Viewtron Server config node, and update any downstream nodes that reference payload field names from snake_case to camelCase.
Documentation
Related Projects
Maintainers: see RELEASING.md.
Author
Mike Haldas — CCTV Camera Pros
Version: 2.1.1
Updated 3 weeks, 2 days ago
14 in the last week
  • viewtron-server
  • viewtron-camera
  • viewtron
  • ip camera
  • security camera
  • lpr
  • alpr
  • anpr
  • license plate recognition
  • license plate
  • face detection
  • human detection
  • person detection
  • vehicle detection
  • intrusion detection
  • people counting
  • mqtt
  • camera api
  • cctv
  • ndaa
  • surveillance
  • gate access
  • access control
