node-red-contrib-ui-level 0.1.46
A Node Red dashboard ui node. Linear level indicator
npm install node-red-contrib-ui-level
NodeRed NPM version CodeFactor npm
Adds a linear Level type widget to the user interface
Node-RED dashboard widget node-red-contrib-ui-level
Requirements
Node-Red v0.20.5 or greater. Node-Red-dashboard v2.15.0 or greater.
Configuration and behavior
Widget has 3 different layouts: Single Horizontal, Pair Horizontal and Single Vertical.
Widget takes the configured input property and displays it's value at the top of the level graphics. For Pair Horizontal layout the input is expected to be an array. The value of input is validated to find a numeric value. So you can send number msg.payload = 15 or string msg.payload = "15"
The node's Label is displayed near the value. Leave the label field empty to show value only. The Label can be changed on fly by using msg.control = {label:"New Label"}. For Pair Horizontal layout the Label is not displayed but both Channels can be labelled independently.
All four colors for stripes can be customized. In addition, there is three options to modify the colors of the level bar. Multiple segments - Colors tied to stripes according to sector values. Single color bar - Single value-based color for all active stripes. Interpolated colors - Colors interpolated from normal to high color. If you choose Multiple segments for your stripe colors, you can optionally use the Peak mode.
By selecting the Peak mode, you can adjust peak hold time (in milliseconds, validated to be in between 800 ... 10000) or infinity to hold peak until node receives msg.peakreset = true
The node's Unit will be displayed near the current value. Exact position of the unit depends on layout. The unit can be any string, for example: lbs psi F° Set the unit to empty string if you don't need to display it.
The min and max values are customizable within the configuration or you can change them on fly by sending new values with msg.control property. The segments values are also customizable within the configuration and with msg.control
You can choose between 3 different stripe resolutions. Superfine, Fine and Normal
You have option to show intermediate tick values. By choosing Segments, the tick values placed at segment positions, with option Auto, the tick values will be spread evenly.
You can choose behavior of animations to be Soft, Reactive or Rocket representing speed of animations (800ms, 300ms and 100ms). Animations can be turned off completely. Animation of value text is turned off by default. You can turn it on but be aware, text animation affects performance significantly!
Texts sizes and color in widget can be customized within the configuration only. Color applies for all texts in widget. There is 3 different sizes for text elements in use. Values represent font relative size with unit "em"
Limitations
Widget layout is optimized to look best with default 1x1 unit size (48px x 48px). However, this is not a restriction. Smallest possible 1x1 unit size what is supported by dashboard (24px x 24px) is supported by widget also. But you cannot have intermediate tick values together with value field. Playing with text size options you can finetune the layout to fit better into your dashboard design.
Examples of msg.control usage
msg.control = {min:10, max:80} to change min and max values. msg.control = {min:10, max:80, seg1:30, seg2:60} to change min, max and segments all together. msg.control = {seg2:60} to change high segment value only.
Performance alert
This widget is not perfect choice to display high-frequent data changes like audio or similar. If you are using a lot of Level widgets on your dashboard and you are feeling performance loss, consider turning off animations of value text (if used) or turn off all animations.
Licence
This node uses GreenSock animation library GSAP licenced with Standard GreenSock License for non-commercial use https://greensock.com/standard-license/
Version: 0.1.46
Updated 5 years, 4 months ago
Rating: 4.5 15
1083 in the last week
  • ui_level
  • level
  • ui-level
  • dashboard
  • linear gauge
  • indicator
