node-red-contrib-ui-actions 0.1.8
node-red custom widgets
npm install node-red-contrib-ui-actions
GitHub package.json version npm npm
Have you tried to disable a button in the node-red dashboard? Or set the value of a text input in a different flow?
This project is a set of custom dashboard nodes that support advanced control of the UI.
Example of a text input:
text input
To report an issue use the project GitHub page
Text Input
Available actions:
  • Set input value (set)
  • Get value to the output connection (get)
  • Retrieve value to an action node (retrieve)
  • Disable input field (disable)
  • Enable input field (enable)
  • Hide field (hide)
  • Show field (show)
Configuration:
configuration
Button
Available actions:
  • Emulate click (click)
  • Disable button (disable)
  • Enable button (enable)
  • Hide button (hide)
  • Show button (show)
Configuration:
configuration
Light
Available actions:
  • Set color (set)
  • Hide light (hide)
  • Show light (show)
Example:
green light
UI Action
Allows to call any of the above actions in any node without a wire
UI Load
Allows to start a flow when a dashboard tab is loaded
Configuration:
configuration
To install:
Install node-red.
Install this package with "npm install node-red-contrib-ui-actions --save" in ~./node-red or via the Palette Manager in node-red.
If everything was successfull you should see the new nodes under the dashboard category.
https://flows.nodered.org/node/node-red-contrib-ui-actions
Version: 0.1.8
Updated 7 years, 6 months ago
Rating: 5.0 4
102 in the last week
  • ui_text-input
  • ui_ui-button
  • ui_ui-light
  • hidden-ui-action
  • hidden-ui-load
  • node
  • ui
