node-red-contrib-trello-basis 0.3.3
A set of Node-RED nodes to interact with the Trello API.
npm install node-red-contrib-trello-basis
Platform npm@latest npm@beta npm License: MIT
Codacy LGTM LGTM alert vulnerabilities
$ npm install -s node-red-contrib-trello-basis
get-all-lists
WARNING:
The DELETE action is not reversible.
To learn more about Adding Nodes, take a look through Node-RED documents.
You can use a mustache-syntax to include variables from msg
For example, dynamically changing the Path field:
  1. Configure the Path field on the trello node to be /boards/{{payload.id}}/lists.
  2. Add a Function node and copy the following code into the Function field:
    msg.payload = {
        "id": "YOUR_BOARD_ID"
    your-board-id
  3. Wire the function and trello nodes.
Acknowledgements
This project uses the following open source software:
This project is released under the MIT License.
Version: 0.3.3
Updated 7 years, 3 months ago
Rating: 4.5 2
16 in the last week
  • trello-config
  • trello
  • trello
  • api
