node-red-contrib-thinger 1.9.2
Node-Red library for Thinger.io Platform
npm install node-red-contrib-thinger
NPM Version
Nodes to assist with the integration, automation and communication of Node-RED and IoT devices with Thinger.io
To see what has changed in recent versions, have a look a the project's Changelog.
Getting Started
Documentation regarding the module and nodes can be found here.
Prerequisites
Cloud
Have a valid Thinger.io cloud instance with capacity to install a new plugin.
Local
Have a local instance of Node-RED with the following characteristics:
Cloud
To install the plugin on the Thinger.io instance follow the instructions from the documentation.
Local
To install the stable version use the Menu - Manage palette - Install option and search for node-red-contrib-thinger, or run the following command in your Node-RED user directory:
To connect the Node-RED instance to Thinger.io follow the instructions from here.
Once installed, detailed documentation of each node can be found in the Help dialog of Node-RED. Below is a brief description of the actions allowed:
  • Iterate over the assets from the Thinger.io Platform (asset iterator node).
  • Create buckets when an event occurs (bucket create node).
  • Read from data buckets (bucket read node).
  • Writing to data buckets (bucket write node).
  • Calling devices callbacks with autoprovisioning (device callback node).
  • Creating any type of devices or updating its details (device create node).
  • Reading a device resource when an event occurs (device read node).
  • Subscribing to device resources at a given interval (device stream node).
  • Sending data to a connected device (device write node).
  • Calling endpoints (endpoint call node).
  • Reading properties of devices, types or groups (property read node).
  • Writing and modifying properties of devices, types or groups (property write node).
  • Detecting different events of devices, buckets, endpoints and others (server events node).
  • Reading files (plain, csv, json, images, ...) from file storages (read storage node).
  • Storing files (plain, csv, json, images, ...) to file storages (write storage node).
The class is licensed under the MIT License:
Copyright © Thinger.io
Version: 1.9.2
Updated 1 year, 4 months ago
Rating: 5.0 5
137 in the last week
  • asset-iterator
  • bucket-create
  • bucket-export
  • bucket-read
  • bucket-write
  • device-callback
  • device-create
  • device-read
  • device-stream
  • device-write
  • endpoint-call
  • property-read
  • property-write
  • storage-read
  • storage-write
  • server-events
  • thinger-server
  • thinger.io
  • IoT
  • arduino
  • raspberry
