node-red-contrib-tello 1.1.0
Tello control using Node-RED
npm install node-red-contrib-tello
Platform License npm version npm
This node uses Tello SDK 2.0 commands.
Thanks for your donation
If you want to support this free project. Any help is welcome. You can donate by clicking one of the following here:
Donate
npm
$ cd ~/.node-red
$ npm install node-red-contrib-tello
from Node-RED
  • Select Manage Pallete
  • Click Add Node tab
  • Type node-red-contrib-tello
  • Install
All Nodes
node about
takeoff Send command takeoff to Tello
land Send land to Tello
up Send up to Tello. If Distance form is blank, it refers to msg.payload,
down Send down to Tello. If Distance form is blank, it refers to msg.payload.
left Send left to Tello. If Distance form is blank, it refers to msg.paylaod.
right Send right to Tello. If Distance form is blank, it refers to msg.payload.
clockwise Send cw to Tello. If Angle form is blank, it refers to msg.payload.
counterclockwise Send ccw to Tello. If Angle form is blank, it refers to msg.payload.
flip Send flip to Tello. Direction required to selectbox.
speed Send speed to Tello. If Speed form is blank, it refers to msg.paylaod.
state Send state commands to Tello. These commands select select from select.
streamon Send streamon to Tello
streamoff Send streamoff to Tello
Example Flows
Flow Example
example_flow.json
Streaming Sample
This flow needs setup node-red-contrib-ffmpeg
Streaming Sample
stream_flow.json
Contact Me
Twitter: @k_miura_io
Version: 1.1.0
Updated 6 years, 2 months ago
4 in the last week
  • takeoff
  • land
  • up
  • down
  • forward
  • back
  • right
  • left
  • clockwise
  • counterclockwise
  • flip
  • speed
  • state
  • streamon
  • streamoff
  • Tello
  • Drone
