node-red-contrib-sun-position 3.0.1
NodeRED nodes to get sun and moon position
npm install node-red-contrib-sun-position
node-red-contrib-sun-position for NodeRED
Maintenance npm version License Issues code style NPM
This is a ultimate (Swiss-Army-Knife) Node-Red Timer based flow control with dusk, dawn (and variations) and much more. Additional you can get sun and moon position or to control a flow by sun or moon position. It is ideal for usage of control smart home, but also for all other time based flow control. There is also a roller blind control node and a clock timer node. The blind control node can determine the position of the roller shutter by time or position of the sun. The timer can send different payloads depending on the time.
nodes
Information on Version changes
If a Node has a warning sign on the label like this one: warning sign This is not an error, it hides only that the node needs to be opened, saved and deployed to fix the label.
⚠ Nodes that were created or saved with a version 2.0.0 or later do not work in versions prior 2.0.0 of the package.
Table of contents
Preconditions
These nodes need at least Node.js Version 22.9.0 and Node-RED Version 5.0.0 or newer. Earlier Node-RED releases are not supported by this package version.
General
Saving resources
The nodes are designed to do not calculate time events with every arriving message or with an interval every x time. This is to be able to handle a huge amount of messages also on even on computers with low resources.
second based accuracy
The nodes are designed to be accurate to seconds. This means it was designed to turn on/off at exact given second. Other timers often work using intervals where they check your schedule only once a minute or even less. This means when you want something to come on at 08:00am, it may actually not come on until 30 seconds later. This nodes does not have this problem, it will come on at exactly 08:00:00am.
Documentation of the nodes
The documentation of the nodes is moved to the wiki:
CHANGELOG
TODO
  • add possibility to select input/output timezone
Support, Bugs and Feedback
For bugs, questions and feature requests please use the GitHub Issues, or the Homematic forum.
:moneybag: Donations Donate
Even for those that don't have the technical knowhow to help developing on there are ways to support development. So if you want to donate some money please feel free to send money via PayPal.
LICENSE
Licensed under the Apache License, Version 2.0 (the "License"); you may not use this nodes except in compliance with the License. You may obtain a copy of the License at
Version: 3.0.1
Updated 5 months ago
Rating: 4.6 15
1158 in the last week
  • position-config
  • time-inject
  • within-time-switch
  • rdg-delay-until
  • sun-position
  • moon-position
  • time-comp
  • time-span
  • blind-control
  • clock-timer
  • nodes
  • flow
  • sun-position
  • moon-position
  • heavenly body
  • sun
  • sun events
  • moon
  • moon events
  • position
  • luminary
  • sunpos
  • suncalc
  • mooncalc
  • router
  • switch
  • inject
  • timer
  • time
  • timeswitch
  • timerswitch
  • timespan
  • time-range
  • time-range-switch
  • timecheck
  • time-calc
  • time-comp
  • time-compare
  • time-span
  • time-offset
  • compare
  • clock
  • schedule
  • compare
  • calculate
  • redmatic
  • blind
  • blind-control
  • home+automation
  • cover
  • roller
  • shutter
  • Hypnos3
  • Marc Hoppe
  • Mauricio Bonani
  • Tom Hoover
