node-red-contrib-servicely 0.1.4
A set of Node-RED nodes to facilitate integration with Servicely.ai.
npm install node-red-contrib-servicely
Node-RED nodes for integrating with Servicely.ai: the asynchronous queue (Actions), data imports and transforms, the REST API and Inbound Webhooks.
Requirements
  • Node-RED 3.0 or later (tested with Node-RED 5)
  • Node.js 18 or later (Node-RED 5 requires 22.9 or later)
  • Servicely 1.11.125 or later for the edit dialogs' lookups (webhooks, import tables, import sources and transforms) and Test auth. On earlier versions the dialogs say so, and names are typed instead.
  • Servicely 1.11.125 or later for combined Queue polling. On earlier versions each Queue node polls on its own.
From the Node-RED editor: Menu → Manage palette → Install, and search for node-red-contrib-servicely.
Or from your Node-RED user directory (usually ~/.node-red):
Upgrading from 0.0.x
Version 0.1.0 needs Node.js 18 and Node-RED 3.0 or later. You don't have to upgrade Servicely: the nodes work as before on any version. Only the edit dialogs' lookups, Test auth and combined Queue polling need Servicely 1.11.125 or later. On an earlier version, the dialogs show a note saying so, you type names in as before, and each Queue node polls on its own.
After upgrading, check your flows for these changes:
  • Credentials. Passwords, tokens and secrets are now stored as Node-RED credentials. Existing connections keep working. Open each connection, click Update and deploy to migrate it. After that, flow exports no longer include the secrets, so re-enter them wherever you import the flow.
  • Import and Transform results. These now go to msg.import_result / msg.transform_result, not msg["undefined"]. A failed import or transform, including row failures, is now reported to Catch nodes, where it used to pass as a success.
  • Errors reach Catch. Errors from the Success, Failure and Progress replies used to be ignored. They now reach Catch nodes.
  • Progress. The Progress node passes the message on only after the instance accepts the update, and not at all when the update fails.
  • Reply payloads. Success, Failure and Progress now send an object or array payload as JSON text.
  • URI templates. The REST node only substitutes message properties (${msg.payload.id}) and now URL-encodes the values. Templates that use expressions, or that insert values you have already encoded, need changing.
  • REST default method. A REST node saved with the default method now performs a GET. Before, it did nothing.
See CHANGELOG.md for the full list.
Node Purpose
Queue Claims actions from a Servicely asynchronous queue, one message per action.
Success / Failure Reply to an action claimed by the Queue node.
Progress Sends a progress update for an action, and passes the message on.
REST Calls the Servicely REST API.
Webhook Calls an Inbound Webhook (V2), with a picker for the instance's webhooks and their mappings.
Import / Transform Load data into an Import Table and run the transform, with pickers for the instance's import tables, import sources and transforms.
Connector Adds a connection to the message for the nodes that follow.
Each node has full help in the editor's help sidebar. Example flows are available from Menu → Import → Examples.
Connection
A Servicely connection holds the instance URL and credentials, stored as encrypted Node-RED credentials. Three authentication types are supported:
  • Username/Password (HTTP Basic)
  • HMAC Header Token: a System API Token and its secret sign each request
  • Bearer Token: a System API Token sent as Authorization: Bearer
Handling errors
All nodes report errors, including HTTP error responses, to Catch nodes. The message carries msg.error, msg.statusCode (for HTTP errors) and the error text in msg.payload. For queue actions, a Catch node wired to a Failure node reports any processing error back to Servicely. A Queue node's failed poll also reaches Catch, with msg._dequeue_error set and no msg._reply_to; the Failure node skips such a message with a warning, since no action was claimed.
Documentation
Usage documentation: https://docs-servicely.atlassian.net/wiki/spaces/SD/pages/2247196673/Node-RED
Links
Apache-2.0
Version: 0.1.4
Updated 1 month, 1 week ago
527 in the last week
  • servicely-queue
  • servicely-success
  • servicely-failure
  • servicely-progress
  • servicely-connection
  • servicely-connection-injector
  • servicely-rest
  • servicely-transform
  • servicely-import
  • servicely-webhook
  • servicely
