node-red-contrib-scheduler-plus 1.1.4
A Node Red Timer with dusk, dawn and months
Scheduler for Node-RED
A scheduler node for Node-RED offering better timing facilities than the standard inject node: fixed times, dawn and dusk (handy for lighting), days of the week and months.
Originally written by Peter Scargill — see http://tech.scargill.net/node-red-scheduler/
Requirements
- Node-RED >= 1.0
- Node.js >= 14
- suncalc ^2.1.1 (installed automatically)
The node is listed in the Node-RED Flow Library.
From the Node-RED palette manager, search for node-red-contrib-scheduler-plus, or from your
Node-RED user directory (usually ~/.node-red):
npm install node-red-contrib-scheduler-plus
Then restart Node-RED. The node appears in the input category of the palette.
This is a maintained fork of
node-red-contrib-scheduler, whose npm package is the original version and does not include the fixes below. Remove it before installing this one: both provide the sameschedulernode type.
| Field | Description |
| On Time | Start time, in 15-minute steps, or Dawn / Dusk. |
| Off Time | End time, in 15-minute steps, Dawn / Dusk, or a duration from On Time (1 to 120 minutes). |
| Dawn / Dusk Offset | Minutes added to dawn / dusk: positive for later, negative for earlier. |
| Latitude / Longitude | Location used to compute dawn and dusk. Filled from the browser geolocation if left empty. |
| Topic | msg.topic of the messages sent on output 1. |
| ON / OFF Msg | msg.payload sent on output 1 when the schedule turns on / off. |
| Days / Months | Days of the week and months on which the schedule is active. |
The schedule is active from On Time (included) until Off Time (excluded), and may cross midnight (e.g. 22:00 → 06:00). Dawn is sunrise and dusk is sunset, computed for the current day.
All times use the local time zone of the Node-RED server: make sure it matches the location you configure.
Outputs
- Change — sends
{ topic: <Topic>, payload: <ON Msg | OFF Msg> }when the state changes, or when the button of the node is pressed. Nothing is sent at start-up: the first evaluation only initialises the state. - Status — sends
{ topic: "status", payload: "1" | "0" }every minute.
The node status shows the remaining time when on, off otherwise, and a red status when there is no
dawn or dusk on that day (polar day or night at high latitudes).
Development
git clone https://github.com/ltoinel/node-red-contrib-scheduler-plus.git
cd scheduler
npm install # also enables the git hooks
npm run lint # ESLint
npm test # unit tests (node:test)
npm run coverage # tests + coverage report, fails under 90% of lines
Git hooks (in .githooks/, enabled by npm install):
- pre-commit runs the lint,
- pre-push runs the unit tests.
Releasing
- Bump
versioninpackage.jsonand update the changelog. - Create a GitHub release with the tag
v<version>(e.g.v1.1.0). - The Release workflow lints, tests and publishes to npm with provenance.
Changelog
1.1.4
- The package is now under the MIT license (SPDX
MIT), so the Node-RED Flow Library recognises it.
1.1.3
- Breaking change: the node type is renamed from
schedulertoscheduler-plus, so it no longer clashes withnode-red-contrib-schedulerandnode-red-contrib-majordomus. Existing flows show the old nodes as unknown: export the flow, replace"type": "scheduler"with"type": "scheduler-plus", then import it again. - Added a
LICENSEfile and thelicensefield inpackage.json(same terms as before). - Added an example flow, available in Node-RED under Import > Examples.
1.1.2
- Repository URLs updated to
ltoinel/node-red-contrib-scheduler-plus(fixes npm provenance on publish).
1.1.1
- The npm publishing workflow is renamed to
release.yml.
1.1.0
- Fixed wrong On Time values between 21:45 and 23:45 (offset by 10 minutes); existing flows are migrated automatically.
- Fixed a one-minute delay and negative values in the time computation.
- Fixed schedules with a duration crossing midnight.
- The button of the node sends on output 1 again.
- Fixed the help panel and the button notification.
- No crash when there is no dawn or dusk (polar regions).
- Updated to Node-RED >= 1.0 APIs and suncalc 2.x.
- New SVG icon.
- Published on npm as
node-red-contrib-scheduler-plus, with unit tests, lint and CI. - Behaviour change: Off Time is now excluded (a 07:00–08:00 slot turns off at 08:00, not 08:01).
1.0.0
- Initial version by Peter Scargill.
MIT. Originally written by Peter Scargill (http://tech.scargill.net), please keep the original author's name and link.
