node-red-contrib-s7-plus 0.3.0
Node-RED nodes for symbolic read/write/subscribe to Siemens S7-1200/1500 over native S7CommPlus (Optimized DBs, no PUT/GET).
npm install node-red-contrib-s7-plus
npm: node-red-contrib-s7-plus · Node-RED: flows.nodered.org · GitHub: DataLogXE/node-red-contrib-s7-plus
Node-RED nodes for symbolic read, write, and subscribe access to Siemens S7-1200/1500 PLCs over the native S7CommPlus protocol without using PUT/GET.
Why this package
Read, write, and subscribe to S7-1200/1500 tags in Node-RED by symbol name. Optimized data blocks need no layout changes. Addresses and datatypes are resolved from the live PLC. Requires TIA Portal ≥ V17 and secure communication (TLS) — see Requirements.
Built on S7CommPlus, the symbolic protocol that TIA Portal uses to talk to the CPU. Pure JavaScript. Runs on a standard PC (x64), Raspberry Pi, Siemens IoT2050, and any platform where Node.js runs out of the box.
  • Optimized and standard-access blocks — no need to disable Optimized block access or alter DB layout for external read/write.
  • No PUT/GET — external access uses the symbolic protocol stack of current TIA projects; only normal secure-communication settings apply.
  • Symbolic access — browse the live PLC tree (Pick from PLC) or pass names from S7+ Explore. SymbolCRC mismatch after a PLC program change is detected and tags are re-resolved.
  • Native subscriptions — S7CommPlus push notifications; value changes are pushed from the PLC.
  • Batched multi-tag I/O — one request for many symbols; per-symbol status in msg.payload (a single invalid tag does not fail the entire batch). Reads/writes are chunked to the PLC's tagsPerReadMax / tagsPerWriteMax limits.
  • Shared endpoint — one TCP/TLS session per PLC; reconnect, watchdog, subscription re-establishment after disconnect, and overload protection.
  • Any CPU architecture — pure JavaScript end to end. No compiler or platform-specific binary to ship with your flow.
Quick start
Install from the Node-RED palette manager (Manage palette → Install → node-red-contrib-s7-plus), or from the command line in your Node-RED user directory:
Then build a minimal read flow:
[inject] → [S7+ Read] → [debug]
  1. Add an S7+ Read node and create the S7+ Endpoint config in its settings (PLC IP address).
  2. In the S7+ Read node, click Pick from PLC and select your tags from the tree.
  3. Wire an inject in front and deploy — every incoming message triggers one read.
The result lands in msg.payload (object format):
  "Motor.speed": { "value": 1450, "status": "ok", "error": "" },
  "Tank.level":  { "value": 73.2, "status": "ok", "error": "" }
Writing works the same way: pick the tags, then send the value(s) in msg.payload (a single value for one tag, or an object keyed by tag name for several).
Node Description
S7+ Endpoint Shared connection (IP, port 102, timeout, reconnect/watchdog).
S7+ Read Read symbol(s) on input; results in msg.payload. Override with msg.symbols, add extras with msg.addSymbols.
S7+ Write Write values via msg.payload; override symbols with msg.symbols. Result replaces msg.payload.
S7+ Subs Native subscription: the PLC pushes value changes (no polling). Emits changed symbols in msg.payload per cycle.
S7+ Explore Full symbol catalog: flat names in msg.payload, optional msg.infos, browse summary in msg.meta.
S7+ Info Session and PLC diagnostics in msg.payload (firmware, PAOM, limits, protection level, connection status).
Data type mapping
S7 datatype → JavaScript type
S7 Datatype JavaScript Type Note
Bool boolean
Byte, Word, DWord number
LWord BigInt 64-bit, exceeds JS number
Char, WChar string single character
String, WString string
SInt, Int, DInt, USInt, UInt, UDInt number
LInt, ULInt BigInt
Real, LReal number
Time, S5Time number milliseconds
LTime BigInt nanoseconds
TOD (Time_Of_Day) number milliseconds since midnight
LTOD BigInt nanoseconds since midnight
Date Date
LDT, DTL Date ms resolution; sub-ms nanoseconds are not represented in a JS Date
Hardware datatypes (HW_IO, HW_DEVICE, …) number
Requirements
  • Node.js >= 20
  • Node-RED >= 3.0
  • S7-1200/1500 with secure communication (TLS) enabled; symbolic access for optimized and non-optimized blocks
  • Project engineered with TIA Portal ≥ V17
Examples
Example flows live in [examples/](examples/). They target the test data blocks in [plc/s7-1500/](plc/s7-1500/) (S7-1500, optimized access).
PLC setup: import the DB_*.db sources and FB_TestSignalGenerator.scl from plc/s7-1500/ into your TIA Portal project. Call FB_TestSignalGenerator in the main cycle OB (e.g. OB1) so DB_TestSignals is filled with animated test values, then compile and download to the PLC.
Node-RED setup: Import one or more JSON files from examples/, Deploy, then open the shared S7+ Endpoint config node (PLC) and set the PLC IP address. All example flows reuse the same endpoint id (example_plc_ep), so importing multiple flows creates only one config node.
File Purpose
[explore-symbols-flow.json](examples/explore-symbols-flow.json) Symbol catalog browse — full PLC tree, scoped DB/area browse (static + msg.exploreScope), msg.infos formats, output limit demo, and Explore → Read pipeline for DB_TestSignals.
[read-multiple-values-flow.json](examples/read-multiple-values-flow.json) Read multiple values in one request — static symbol list in the read node, plus a second path with the same symbols via runtime msg.symbols.
[read-write-single-values-flow.json](examples/read-write-single-values-flow.json) Manual write tests — one inject per scalar constant writes to the matching *_write tag; each datatype group includes a read-back row. Covers Binary through Timers; hardware and system datatypes are excluded.
[verify-read-write-values-flow.json](examples/verify-read-write-values-flow.json) Automated verification — one inject runs write → read-back → compare for every scalar constant across all datatypes. Emits one result per datatype and a final summary.
[subscribe-values-flow.json](examples/subscribe-values-flow.json) Native subscription — static DB_TestSignals symbols on deploy (object format) with per-symbol extraction; dynamic msg.symbols via inject (array format).
Status
  • Open-source software (LGPL-3.0-or-later), provided as-is without warranty
  • Development stage — not approved for production use
  • You are responsible for how and where you use it
  • Not affiliated with or supported by Siemens
Copyright (C) 2026 Robert Mederer - DataLogXE. Licensed under LGPL-3.0-or-later. See LICENSE.
This project builds on the following work:
  • S7CommPlus protocol portions — derived from S7CommPlusDriver (Thomas Wiens, LGPL-3.0-or-later).
  • ISO-on-TCP/COTP transport patterns — informed by Snap7 (Davide Nardella, LGPL-3.0) and the C# reference driver above.
  • S7CommPlus SymbolCRC (CRC32 polynomial and algorithm) — informed by HarpoS7 (bonk, MIT); see LICENSE for the full MIT notice.
Version: 0.3.0
Updated 4 months, 1 week ago
License: LGPL-3.0-or-later
Rating: 4.3 6
54 in the last week
  • s7-plus endpoint
  • s7-plus read
  • s7-plus write
  • s7-plus subscribe
  • s7-plus explore
  • s7-plus info
  • siemens
  • simatic
  • s7
  • s7-1200
  • s7-1500
  • s7commplus
  • s7comm-plus
  • plc
  • iso-on-tcp
  • symbolic-access
  • optimized-blocks
  • tia-portal
  • tls
  • subscription
  • industrial-automation
