node-red-contrib-rpc-toolkit 2.3.3
JSON-RPC 2.0 client and server nodes for Node-RED with Safe Mode support
npm install node-red-contrib-rpc-toolkit
CI npm version npm downloads Node-RED node License Status
JSON-RPC 2.0 client and server nodes for Node-RED, with optional RPC Toolkit Safe Mode interoperability.
Turn Node-RED flows into structured JSON-RPC methods - and call JSON-RPC services from your flows.
node-red-contrib-rpc-toolkit lets you expose Node-RED flows as named JSON-RPC methods and call JSON-RPC / RPC Toolkit services from your flows.
Use it when you want method names, structured errors, schema validation, introspection, and service-style communication instead of wiring custom HTTP endpoints manually.
Safe Mode is enabled by default because it makes interoperability with the RPC Toolkit libraries smoother. It does not change how you build Node-RED flows, and you can disable it when you want a plain JSON-RPC 2.0 endpoint for generic clients.
The package is designed to connect Node-RED flows with RPC Toolkit endpoints such as rpc-express-toolkit, rpc-php-toolkit, rpc-dotnet-toolkit, rpc-python-toolkit, rpc-java-toolkit, and rpc-arduino-toolkit.
Why use this?
Use node-red-contrib-rpc-toolkit when you want Node-RED to expose or call structured JSON-RPC methods instead of wiring custom HTTP endpoints manually.
Typical use cases:
  • expose Node-RED flows as callable RPC methods;
  • call services written with rpc-express-toolkit, .NET, PHP, Python, Java, or Arduino/ESP32;
  • build small local automation APIs;
  • connect edge, IoT, and industrial services;
  • validate method parameters with JSON Schema;
  • discover available methods through built-in introspection;
  • preserve string/date intent with optional Safe Mode.
Try it in 60 seconds
1. Install
Install from the Node-RED Palette Manager, or from your Node-RED user directory:
Restart Node-RED after installing from the command line.
2. Create a simple RPC method
Create this flow:
[RPC Method: "ping"] -> [Function: msg.payload = "pong"] -> [RPC Response]
Configure an rpc-server config node with endpoint /rpc, then configure the rpc-method node to use that server and method name ping.
Function node:
msg.payload = 'pong';
3. Test with the default Safe Mode
Safe Mode is enabled by default for RPC Toolkit interoperability. For this simple example, a raw HTTP client only needs to send the X-RPC-Safe-Enabled header. RPC Toolkit clients handle Safe Mode encoding and decoding automatically:
curl -X POST http://localhost:1880/rpc \
  -H "Content-Type: application/json" \
  -H "X-RPC-Safe-Enabled: true" \
  -d '{"jsonrpc":"2.0","method":"ping","id":1}'
Raw Safe Mode response:
{"jsonrpc":"2.0","id":1,"result":"S:pong"}
The S: prefix is expected only when looking at raw HTTP responses from a Safe Mode endpoint. RPC Toolkit clients decode Safe Mode values automatically, so application flows receive normal values.
4. Test as plain JSON-RPC
For generic JSON-RPC clients, disable Safe Mode on the rpc-server config node and call the endpoint without the Safe Mode header:
Expected response:
{"jsonrpc":"2.0","id":1,"result":"pong"}
Palette Manager
  1. Open Node-RED.
  2. Go to Menu > Manage palette.
  3. Open the Install tab.
  4. Search for node-red-contrib-rpc-toolkit.
  5. Click Install.
When not to use this
Use the built-in Node-RED HTTP nodes if you only need one or two simple REST endpoints.
Use this package when you want named methods, structured JSON-RPC errors, schema validation, introspection, or interoperability with RPC Toolkit services.
  • rpc-server - configuration node that mounts a JSON-RPC HTTP endpoint on the Node-RED HTTP server.
  • rpc-method - registers a flow-backed JSON-RPC method on an rpc-server.
  • rpc-response - completes a pending request started by an rpc-method.
  • rpc-client - calls a remote JSON-RPC HTTP endpoint.
  • rpc-request - parses an incoming JSON-RPC request from an existing HTTP flow.
Typical flows
Create an RPC endpoint with a flow-backed method:
[rpc-method: ping] -> [function: msg.payload = "pong"] -> [rpc-response]
Call a remote endpoint from a flow:
[inject params] -> [rpc-client: ping] -> [debug result]
Parse an existing HTTP flow manually only when you need custom routing outside the rpc-server config node:
[http in] -> [rpc-request] -> [function] -> [http response]
JSON-RPC modes
Standard JSON-RPC mode
Disable Safe Mode on the rpc-server or rpc-client node when you want normal JSON-RPC 2.0 payloads for generic clients and services.
In this mode:
  • requests do not need the X-RPC-Safe-Enabled header;
  • strings and dates are returned as normal JSON values;
  • JSON-RPC errors, notifications, batch requests, and introspection still work.
Safe Mode is useful when both sides use RPC Toolkit libraries. It preserves application-level value intent across JSON, for example strings that could otherwise be confused with encoded date or numeric marker values.
In this mode:
  • RPC Toolkit clients and servers handle encoding and decoding automatically;
  • raw HTTP clients need to add X-RPC-Safe-Enabled: true;
  • raw HTTP responses may show marker strings such as S:hello;
  • Node-RED flow code still reads and writes normal msg.payload values.
Implemented features
  • JSON-RPC 2.0 calls, errors, notifications, and batch requests.
  • Flow-backed method registration.
  • Built-in introspection through __rpc.listMethods, __rpc.describe, __rpc.describeAll, __rpc.version, and __rpc.capabilities.
  • Per-method JSON Schema validation when a method schema is configured.
  • Optional RPC Toolkit Safe Mode over HTTP.
  • Explicit Safe Mode header handling on the server when Safe Mode is enabled.
  • CORS support on the server node.
  • Optional bearer token authentication on the server node, with tokens stored in Node-RED credentials.
  • Optional Authorization header passthrough on the client node, with tokens stored in Node-RED credentials.
  • Client editor helper for loading remote methods through introspection.
Not currently implemented by this package:
  • Server-side JWT validation middleware.
  • Server-side rate limiting configuration.
  • WebSocket transport.
  • A dedicated visual batch node. Batch requests are supported by the JSON-RPC endpoint, but not exposed as a separate Node-RED node.
Node details
RPC Server
Creates a JSON-RPC endpoint under the Node-RED HTTP server.
Configuration:
  • Endpoint - HTTP path, for example /rpc.
  • CORS - enables CORS headers, including X-RPC-Safe-Enabled.
  • Authentication - optional bearer token authentication. The token is stored in Node-RED credentials.
  • Safe Mode - enabled by default for RPC Toolkit interoperability. Disable it to expose a standard JSON-RPC 2.0 endpoint for generic clients.
When bearer authentication is enabled, requests must include Authorization: Bearer <token>. Unauthorized requests are rejected with HTTP 401 before JSON-RPC method dispatch.
When Safe Mode is enabled, the server expects the X-RPC-Safe-Enabled header so both sides know encoded values are in use. Requests without that header are rejected with JSON-RPC error -32600.
When Safe Mode is disabled, the endpoint does not require the header and returns raw JSON values without S: or D: prefixes.
RPC Method
Registers a method on an rpc-server.
Configuration:
  • Server - target rpc-server config node.
  • Method Name - JSON-RPC method name.
  • Description - optional introspection text.
  • Expose Schema - makes schema metadata visible via __rpc.describe.
  • Validate Schema - validates params before invoking the flow.
  • Schema - JSON Schema generated by the editor UI or provided manually.
The node sends incoming method params on output 1. The flow must keep msg.rpc intact and pass the final result to an rpc-response node.
RPC Response
Completes a pending request created by an rpc-method.
Input:
  • msg.payload - successful result.
  • msg.error - optional JSON-RPC error object.
  • msg.rpc.id and msg.rpc.methodNodeId - routing metadata from rpc-method.
Example custom error:
msg.error = {
  code: -32042,
  message: 'Domain failure',
  data: {
    reason: 'intentional-test-error'
RPC Client
Calls a remote JSON-RPC HTTP endpoint.
Configuration:
  • Server URL - full endpoint URL, for example http://localhost:3000/api.
  • Method - default method name.
  • Timeout - request timeout in milliseconds.
  • Auth Token - optional bearer token stored in Node-RED credentials and sent as an Authorization header.
  • Safe Mode - enabled by default.
Input:
  • msg.payload - method params.
  • msg.method - optional method override.
Outputs:
  • Output 1: successful result in msg.payload.
  • Output 2: error object in msg.error.
RPC Request
Parses a JSON-RPC request from an existing HTTP flow. Use this only when you are building a custom HTTP flow instead of the rpc-server config node.
Introspection
The server supports:
  • __rpc.listMethods
  • __rpc.describe
  • __rpc.describeAll
  • __rpc.version
  • __rpc.capabilities
Example:
  -d '{"jsonrpc":"2.0","method":"__rpc.listMethods","id":1}'
{"jsonrpc":"2.0","id":1,"result":["S:ping","S:sum"]}
Safe Mode notes
Safe Mode is an RPC Toolkit extension for preserving application-level value intent across plain JSON. It is mainly relevant at the HTTP boundary; inside Node-RED flows you continue working with normal msg.payload values.
  • HTTP requests and responses use X-RPC-Safe-Enabled when Safe Mode is enabled.
  • The Node-RED server defaults to Safe Mode enabled for RPC Toolkit interoperability.
  • Raw HTTP clients must send X-RPC-Safe-Enabled when calling a Safe Mode server.
  • Raw HTTP responses from a Safe Mode server contain encoded string values such as S:hello.
  • Disable Safe Mode on the server when generic JSON-RPC clients need unprefixed JSON strings.
  • RPC Toolkit clients decode these values automatically.
  • Date and BigInt marker handling follows rpc-express-toolkit behavior.
  • BigInt markers are transported as marker strings; Node-RED flows do not receive JavaScript BigInt values automatically.
Example flows
Ready-to-import Node-RED flows are available in examples.
The examples are grouped by test type:
  • standard JSON-RPC server;
  • Safe Mode server;
  • validation and custom error responses;
  • standard JSON-RPC client;
  • Safe Mode client;
  • client error output;
  • bearer token auth loopback;
  • request parser;
  • full local server/client loopback.
Status and compatibility
  • Published on npm as node-red-contrib-rpc-toolkit.
  • Indexed in the Node-RED Flow Library and installable through Palette Manager.
  • Requires Node.js 18 or newer.
  • CI verifies compatibility across supported Node.js and Node-RED versions.
  • Public Node-RED Flow Library scorecard is green.
  • Runtime dependency audit is checked before release.
Node-RED Tested Node.js versions
3.1.x 18, 20, 22, 24
4.1.x 18, 20, 22, 24
5.0.x 22, 24
Node-RED 5 requires Node.js 22.9 or newer.
Local development
git clone https://github.com/n-car/node-red-contrib-rpc-toolkit.git
cd node-red-contrib-rpc-toolkit
npm install
npm test
Useful checks:
npm run audit:runtime
npm run pack:check
Related projects
MIT. See LICENSE.
Version: 2.3.3
Updated 1 month, 2 weeks ago
Rating: 0.0
2 in the last week
  • rpc-server
  • rpc-client
  • rpc-method
  • rpc-request
  • rpc-response
  • json-rpc
  • rpc
  • client
  • server
  • iot
  • automation
  • microservices
  • http
  • safe-mode
  • edge
