node-red-contrib-ros2-suite 0.2.0
Node-RED nodes for ROS 2 over rosbridge — subscribe, publish, services and actions (client and server), parameters, TF and discovery. No local ROS install, no rclnodejs.
npm install node-red-contrib-ros2-suite
Node-RED nodes for ROS 2: subscribe, publish, service client and server, action client and server, parameters, TF and discovery. They talk to rosbridge (JSON over WebSocket), so Node-RED needs no ROS installation and no rclnodejs. Install from the palette and point the nodes at your robot.
  • Auto type detection. Leave the type empty and it is looked up via rosapi.
  • Autocomplete for topics, services and actions in the editor, with each type shown next to the name.
  • Message templates for any type, one click in the editor or via the browse node.
  • Validation of outgoing messages against the type definition (strict / warn / off).
  • Silent-topic diagnosis. A subscription that gets nothing tells you whether the topic is missing (with "did you mean …") or advertised but silent (QoS, idle publisher, transport).
  • Actions with three outputs (feedback, result, status events), ready for state machines.
  • Service server mode. A flow can provide a ROS service.
  • Action server. A flow can provide a ROS action, with feedback and cancel.
  • Parameters. Get, set, list and describe the parameters of any ROS node.
  • TF. Look up the transform between two frames, e.g. the robot's pose in the map.
  • QoS per subscribe and publish node, and header stamps filled in for you.
  • Binary data. uint8[] fields as Buffer in both directions, and CBOR for images, scans and point clouds.
  • Reconnect with backoff. Subscriptions, advertisements and services are restored, and running calls and goals fail cleanly instead of hanging.
In Node-RED: Menu → Manage palette → Install, search for node-red-contrib-ros2-suite.
Or with npm in your Node-RED user directory:
Requires Node-RED ≥ 3 and Node.js ≥ 18. The only dependency is ws.
Start rosbridge on the robot
sudo apt install ros-$ROS_DISTRO-rosbridge-suite
ros2 launch rosbridge_server rosbridge_websocket_launch.xml   # ws://<robot>:9090
On Humble, add the thread options that later distros use by default:
ros2 launch rosbridge_server rosbridge_websocket_launch.xml \
    call_services_in_new_thread:=true send_action_goals_in_new_thread:=true
Without them, rosbridge handles a running action goal in its main thread. Everything the clients send then waits until the goal ends, including cancel requests, publishes and service calls. The action node warns when a cancel was ignored this way.
The launch file also starts rosapi, which powers type detection, autocomplete, templates and validation. Without rosapi the nodes still work if you set every type yourself.
Tested with
Each distro ran 22 end-to-end checks against turtlesim through Node-RED: every node, cancel, the service server called from ros2 service call, the QoS diagnosis, the xstate example below, and a reconnect after restarting ROS.
ROS 2 rosbridge Result Action types
Humble 2.0.8 22/22 (with the thread options above) matched by name
Jazzy 2.7.1 22/22 matched by name
Kilted 3.3.1 22/22 matched by name
Rolling 4.2.1 22/22 read exactly via rosapi
The table covers the nodes of version 0.1.0. What was added since (parameters, the action server, TF, QoS, header stamps, CBOR and Buffers) is covered by the integration tests in test/integration/, which CI runs on all four distros; so far they have been run on Humble (rosbridge 2.0.8) and Jazzy (2.7.1).
rosbridge has no authentication of its own. Keep port 9090 on a trusted network, or put it behind a reverse proxy (TLS and a token are supported by the connection node).
Quick start with Docker
docker/ contains ROS 2 (Jazzy by default) with turtlesim and rosbridge, plus Node-RED with this package mounted from the working copy:
cd docker
docker compose up --build
ROS_DISTRO=humble docker compose up --build    # or kilted, rolling
Open http://localhost:1880. The example flow (examples/turtlesim.json) is preloaded:
Group Does
Subscribe /turtle1/pose; the status shows the rate (~62 Hz)
Publish drives the turtle via /turtle1/cmd_vel (geometry_msgs/msg/Twist); one inject sends an invalid message that strict validation blocks and a Catch node reports
Service client /turtle1/teleport_absolute puts the turtle back in the centre
Action /turtle1/rotate_absolute with feedback, result, status events and cancel
Service server Node-RED provides /nodered/greet (std_srvs/srv/Trigger); try ros2 service call /nodered/greet std_srvs/srv/Trigger
Browse the whole graph, and a Twist template
Parameters list turtlesim's parameters, read and change background_r
Node-RED shares the ROS container's network, so the flow's ws://localhost:9090 works both in Docker and against a rosbridge on your own machine. Ports 1880 and 9090 must be free. Package changes on the host only need docker compose restart nodered.
To import the example into another Node-RED: Menu → Import → Examples → node-red-contrib-ros2-suite → turtlesim.
A second example, action-server, provides the action /nodered/fibonacci from a flow: a function node sends feedback and the result back into the action server node, and an action client node calls it. It needs the ROS package example_interfaces, which the Docker setup installs. From ROS: ros2 action send_goal --feedback /nodered/fibonacci example_interfaces/action/Fibonacci "{order: 8}".
All nodes follow the same conventions:
  • msg.payload is the ROS message, request or goal as JSON.
  • msg.rosType overrides the type. Both pkg/msg/Name and pkg/Name are accepted.
  • msg.topic / msg.service / msg.action are used when the node has no name configured, or when "msg.… overrides" is ticked. That is off by default, so a msg.topic left over from an upstream subscribe node cannot redirect a publisher.
  • msg.ros carries metadata (type, goalId, status, receivedAt, …).
  • Errors always go through done(err), so Catch nodes see them. The status dot shows them in red with a concrete next step.
ros2-connection (config)
Host, port, path and TLS, or a full URL. The optional token is sent as Authorization: Bearer …. Untick verify the server certificate for rosbridge's own TLS with a self-signed certificate (ssl:=true certfile:=… keyfile:=…). Also sets the reconnect backoff limits and the default service timeout. The socket opens when the first node using the connection starts. The config dialog shows the live connection state.
Autocomplete also works for a connection that is new or edited but not deployed. In that case the editor asks the Node-RED server to connect with the settings from the dialog, which needs write permission (flows.write).
ros2-subscribe
Output payload the message
Output topic the topic name
Output ros {topic, type, receivedAt}
Status e.g. 61.9 Hz · turtlesim/Pose
Throttle and queue are passed to rosbridge (throttle_rate, queue_length), so dropped messages never cross the network. If a type is configured but the topic is advertised with a different one, the node reports the mismatch instead of subscribing.
Sharing a topic. rosbridge keeps one subscription per topic and connection and sends at the fastest rate any subscribe node asked for. A node with a slower throttle is throttled inside Node-RED, so every node gets the rate it is configured for.
QoS. auto leaves the choice to rosbridge (see the diagnosis below). The presets default (reliable, volatile), sensor data (best effort, volatile) and latched (reliable, transient local), or custom, set it explicitly. Match the publisher: ros2 topic info -v /x. rosbridge creates one ROS subscription per topic for all its clients, so the QoS of the first subscriber wins until nobody is subscribed to the topic through rosbridge any more. The qos field needs a current rosbridge (tested with 2.0.8 on Humble and 2.7.1 on Jazzy); older versions ignore it.
Encoding. With JSON (the default), uint8[] fields such as image data arrive as base64 strings, or as Buffer when deliver uint8[] fields as Buffer is ticked. With CBOR, rosbridge sends compact binary frames: uint8[] fields arrive as Buffer, numeric arrays are not spelled out as text, and NaN/Infinity survive. Use it for images, laser scans and point clouds. rosbridge picks one encoding per topic and connection, so if one subscribe node asks for CBOR, every subscribe node of that topic on the same connection receives Buffers.
ros2-publish
Input payload the message. A plain value is wrapped as {data: …} for single-field types like std_msgs/msg/String
Input topic, rosType optional overrides (see above)
Output the input message, with msg.ros = {topic, type}
Status sent 12 · geometry_msgs/Twist
Validation checks field names, JSON types, integer ranges and fixed array lengths. uint8[] may be given as a Buffer (sent as base64), as base64 or as an array of numbers. The same holds for service requests and action goals. strict blocks invalid messages via done(err), warn logs and publishes anyway, off checks nothing. When nothing advertises the topic yet, set the type: "no message type for /x — nothing advertises it yet, so set the type on the node".
Stamp. Node-RED has no ROS clock, and a stamped message with stamp: 0 is rejected or ignored by many ROS nodes (TF, navigation). With Stamp set, the node fills every std_msgs/Header whose stamp is missing or zero, also in nested messages and arrays (e.g. each transform of a TFMessage). The time is the system time, or ROS time from /clock for simulations running with use_sim_time. Stamps you set yourself are kept. The service client and the action client have the same option for requests and goals, e.g. the pose of a NavigateToPose goal.
QoS. As for subscribe: auto uses rosbridge's default (or latched, when ticked), the presets and custom set reliability, durability and depth. The first publisher of a topic through rosbridge decides.
ros2-service
Client mode: payload is the request. The output payload is the response and msg.ros = {service, type, durationMs}. A missing service fails with similar names as suggestions; a timeout fails with a hint to check ros2 service list. The node's timeout is passed to rosbridge, so calls longer than rosbridge's own 5 s default work. The node refuses to call /rosapi/action_type, which crashes rosapi on Humble, Jazzy and Kilted.
Server mode: the node advertises the service. Each request leaves the output with payload (the request) and msg._ros2 = {replyTo, requestId}. Wire the end of your flow back into the same node with payload set to the response. msg.error answers with an error instead. rosbridge cannot tell the ROS caller that a call failed, so the caller gets success: false and message: <error> when the response type has those fields, otherwise the default response. Requests the flow does not answer within the timeout get the same error response. Requests that are open when the connection to rosbridge drops are discarded, because rosbridge has already failed them on the ROS side.
ros2-action
Three outputs:
  1. feedback: payload = feedback message
  2. result: payload = result message, msg.ros.status = succeeded | aborted | canceled
  3. status: payload is always {event, goalId, action, at, status?, error?}
event is one of sent, executing, feedback, succeeded, aborted, canceled, failed, cancel-requested:
  • executing is emitted once, with the first feedback message. rosbridge reports no separate acceptance step.
  • feedback events are off by default so high-rate feedback does not flood a state machine. Turn them on with Status out.
  • failed means there was no normal result: the goal was rejected, timed out (it is then cancelled), or the connection dropped.
All outputs keep the properties of the input message, so correlation fields survive.
msg.cancel = true cancels msg.goalId, or all running goals of the node. Without concurrent goals, a second goal while one is running is refused. The status dot shows N goals running. Goals still running when the node is redeployed or removed are cancelled.
ros2-action-server
Provides an action from a flow. Two outputs:
  1. goal: payload = the goal, msg._ros2 = {replyTo, goalId}
  2. cancel request: payload = {goalId}, with the same msg._ros2
Wire the flow back into the same node and keep msg._ros2:
  • msg.feedback = true publishes payload as feedback; the goal keeps running.
  • Otherwise payload is the result and ends the goal. msg.status is succeeded (default), canceled or aborted; msg.error aborts.
Every goal is accepted. An aborted goal reaches the client with an empty result, because rosbridge does not pass the result of an abort on. Goals running when the connection drops or the node is redeployed are aborted. On Humble, rosbridge needs send_action_goals_in_new_thread:=true, as for the action client.
ros2-browse
what = topics | services | actions | nodes | all | template. It can also be passed as msg.payload. Lists come back as [{name, type}]. Actions whose type was matched by name carry guessed: true. rosapi's own services are left out of the service list. template returns a complete default message for msg.rosType; msg.kind selects msg, request, response, goal, result or feedback.
ros2-param
Reads and changes the parameters of a ROS node through the parameter services every ROS 2 node offers. The editor completes node names and, for the chosen node, parameter names.
Operation Input Output payload
get msg.param: a name or an array of names (or the configured name) the value, or {name: value} for several names
set payload: the value; or no name and payload = {name: value, …} unchanged
list – [{name, type}]
describe like get the ParameterDescriptor (an array for several names), with typeName added
msg.operation overrides the configured operation; msg.node and msg.param follow the override rule above. msg.ros is {node, operation, param, type}.
JavaScript cannot tell 1.0 from 1. With Type: auto the node asks for the parameter's current type before setting it, so a whole number sent to a double parameter is sent as double. Set the type on the node, or pass msg.paramType, for parameters that are not declared yet. An unknown parameter and a ROS node that is not running fail with similar names as suggestions; a value the ROS node rejects fails with its reason.
ros2-tf
Looks up the transform between two frames. The output payload is a geometry_msgs/TransformStamped: {header: {stamp, frame_id: target}, child_frame_id: source, transform: {translation, rotation}}, the pose of the source frame in the target frame. msg.ros adds {ageMs, static, rpy: {roll, pitch, yaw}} (radians). The operation frames lists the tree as [{frame, parent, static}].
While a tf node exists, the connection subscribes to /tf and /tf_static and keeps the latest transform of every frame. A lookup combines these latest transforms; it does not interpolate to a point in time, so for a fast-moving robot the result is as old as the slowest transform in the chain (msg.ros.ageMs; Max age turns a stale transform into an error). Trigger the node with an inject node to poll. Unknown frames fail with similar names as suggestions.
Silent-topic diagnosis (QoS)
A subscription that receives nothing for 5 s checks the topic list and keeps checking until data arrives. It tells two cases apart:
  • topic not advertised (did you mean /turtle1/pose?): nothing publishes this name. Without a configured type, the node keeps waiting and subscribes as soon as the topic appears.
  • no data — check QoS / publisher: the topic exists but nothing arrives. The debug sidebar gets the likely causes once:
    1. The publisher is idle. Check ros2 topic hz /x.
    2. QoS. rosbridge fixes the QoS of its subscription when the topic is first subscribed through it, by any rosbridge client. It uses BEST_EFFORT + VOLATILE, which matches every publisher. The exception: if all publishers present at that moment are latched (TRANSIENT_LOCAL), rosbridge uses TRANSIENT_LOCAL + RELIABLE. That subscription never receives VOLATILE or BEST_EFFORT publishers that join later. A typical case is /map from a map server, with a SLAM node publishing later. Compare with ros2 topic info -v /x and set the QoS of the subscribe node to match the publisher. A changed QoS takes effect only once no rosbridge client keeps the topic subscribed.
    3. Discovery works but data does not arrive. Typical causes are DDS shared-memory transport between containers without a shared /dev/shm, firewalls, or large messages (images, point clouds) lost over Wi-Fi with BEST_EFFORT.
The QoS case (2) is part of the end-to-end tests: a latched publisher first, a BEST_EFFORT/VOLATILE publisher later.
State machine with ros2-action
The status output is flat and stable, so payload.event can drive a state machine directly. Example with node-red-contrib-xstate-machine (its smxstate node takes the event name from msg.topic and the event data from msg.payload):
[inject "start"] ──► [smxstate] ──(2nd output: node.send)──► [ros2-action /turtle1/rotate_absolute]
                        ▲                                            │ status output
                        └──── [change: msg.topic = msg.payload.event] ◄┘
Machine definition for the smxstate node:
const { assign } = xstate;
return {
    machine: {
        initial: 'idle',
        context: { retries: 0 },
        states: {
            idle: { on: { start: 'rotating' } },
            rotating: {
                entry: 'sendGoal',
                on: {
                    succeeded: { target: 'done', actions: 'resetRetries' },
                    aborted: [
                        { target: 'rotating', cond: 'canRetry', actions: 'countRetry' },
                        { target: 'failed' }
                    canceled: 'idle',
                    failed: 'failed'
            done: { on: { start: 'rotating' } },
            failed: { on: { start: { target: 'rotating', actions: 'resetRetries' } } }
    config: {
        actions: {
            sendGoal: () => node.send({ payload: { theta: 1.57 } }),
            countRetry: assign({ retries: (ctx) => ctx.retries + 1 }),
            resetRetries: assign({ retries: 0 })
        guards: { canRetry: (ctx) => ctx.retries < 2 }
Events the machine does not handle (sent, executing, cancel-requested) are ignored. To abort from the machine, send {cancel: true} to the action node. This example runs as part of the end-to-end tests on all four distros.
Notes and limits
  • Action types: rosapi hides the _action/* topics. /rosapi/action_type crashes the rosapi node on Humble, Jazzy and Kilted, so this package calls it only on other distros (it works on Rolling). Elsewhere the type is matched by name against the installed action interfaces (rotate_absolute → turtlesim/action/RotateAbsolute, or turtlesim_msgs/action/RotateAbsolute on Kilted and newer). The editor marks such types as guessed, and the node warns once. Set the type on the node to be sure. Keep in mind that interface packages move between distros, as turtlesim's did.
  • The first message after a fresh advertisement is delayed by 250 ms so that DDS subscribers can match. Otherwise ROS silently drops it.
  • 64-bit integers (int64, uint64) arrive as JavaScript numbers, which are exact only up to 2^53. Larger values lose precision on the way in; on the way out the validation warns.
  • Latch belongs to the advertisement of a topic, which the nodes of one connection share. The first publish node decides; a second one with a different setting gets a warning.
  • The connection closes a few seconds after the last node using it is removed, and a connection used only for the editor's autocomplete closes after a minute.
Roadmap
  • Zenoh transport as a second backend behind the same client interface
  • MQTT / UNS bridge node
Development
npm install
npm test                    # mocha: client, registry and all nodes against a mock rosbridge
npm run lint                # eslint
npm run coverage            # the same tests with a coverage report
npm run test:integration    # against a real rosbridge at ws://localhost:9090
test/mock-rosbridge.js imitates rosbridge and rosapi, including the typedef spellings, the hidden action topics and the action_type crash of real rosapi.
The integration tests in test/integration/ drive the nodes against real turtlesim: subscribe (JSON and CBOR), publish, service client and server, action client and server with cancel, parameters, QoS, header stamps (system time and /clock), TF, binary data and a reconnect. Start the ROS side first (ROS_DISTRO selects the distro; set ROSBRIDGE_URL to test against another rosbridge):
docker build -f docker/Dockerfile.ros2 --build-arg ROS_DISTRO=jazzy -t ros2-suite-ros2 docker
docker run --rm -d -p 9090:9090 ros2-suite-ros2
CI runs the unit tests on Node.js 18 to 24 and the integration tests on Humble, Jazzy, Kilted and Rolling. See ARCHITECTURE.md for the layering and CHANGELOG.md for changes.
Apache-2.0
Version: 0.2.0
Updated 3 weeks, 6 days ago
  • ros2-connection
  • ros2-subscribe
  • ros2-publish
  • ros2-service
  • ros2-action
  • ros2-action-server
  • ros2-browse
  • ros2-param
  • ros2-tf
  • ros
  • ros2
  • rosbridge
  • robotics
  • robot
