node-red-contrib-pisupply-pijuice-pis0212 1.0.1
Node-RED nodes for a Pi Supply PiJuice model PIS0212
npm install node-red-contrib-pisupply-pijuice-pis0212
node-red-contrib-pisuppy-pijuice-pis0212
A set of Node-RED nodes to monitor a PiJuice battery backup system
First follow the instructions on the Pi Supply PiJuice site. I enable I2C using sudo raspi-config, in the Interface options. Note that some battery types can be configured by adjusting the PiJuice DIP switches or any battery type can be selected via later software configuration.
I run sudo apt-get install pijuice-base as in my application the GUI is not required.
After I verify thru testing that the hardware and pijuice_cli work, then its time to install this Node-RED node.
Either use the Node-RED Menu - Manage Palette option to install, or run the following command in your Node-RED user directory - typically ~/.node-red
    npm i node-red-contrib-pisupply-pijuice-pis0212
The node provides an example flow. In Node-RED, click the right side hamburger menu, "import", "Examples", "node-red-contrib-pisupply-pijuice-pis0212"
I would suggest trying the example demo flow before creating your own flow.
Battery Capacity
  • msg.payload - any
msg.payload any input triggers the start of a poll.
The output payload will be a numeric percentage of battery capacity.
For example, given an input payload of a timestamp, a fraction of a second later will result in an output payload of number 97, if the battery is 97 percent charged.
See help file for more detail.
Battery Temperature
  • msg.payload - any
The output payload will be a numeric Celsius temperature of the battery.
For example, given an input payload of a timestamp, a fraction of a second later will result in an output payload of number 25, if the battery is around 25 degrees C room temperature.
Battery Voltage
  • msg.payload - any
The output payload will be a numeric battery voltage in units of Volts.
For example, given an input payload of a timestamp, a fraction of a second later will result in an output payload of number 4.165, if the battery is nearly fully charged.
GPIO Current
  • msg.payload - any
The output payload will be a numeric current in mA on the UPS GPIO pins.
For example, given an input payload of a timestamp, a fraction of a second later will result in an output payload of number 594, implying the Pi is using 594 mA of current at this instant.
GPIO Voltage
  • msg.payload - any
The output payload will be a numeric voltage in Volts on the UPS GPIO pins.
For example, given an input payload of a timestamp, a fraction of a second later will result in an output payload of number 5.039, which is pretty close to the designed Pi operating voltage of 5 volts.
USB Power
  • msg.payload - any
For example, given an input payload of a timestamp, a fraction of a second later will result in an output payload of string PRESENT, if the USB charge input has power to charge the battery, or NOT_PRESENT, if there is no or not enough power at the USB charge input to charge the battery.
Links
https://uk.pi-supply.com/products/pijuice-standard
https://learn.pi-supply.com/make/pijuice-quick-start-guide-faq/
https://learn.pi-supply.com/make/how-to-save-power-on-your-raspberry-pi/
https://github.com/PiSupply/PiJuice
https://gitlab.com/SpringCitySolutionsLLC/pisupply-pijuice-pis0212
https://www.npmjs.com/package/node-red-contrib-pisupply-pijuice-pis0212
https://flows.nodered.org/node/node-red-contrib-pisupply-pijuice-pis0212
https://nodered.org/
Copyrights and Licenses
Majority of code Copyright (c) 2020 Spring City Solutions LLC and other contributors and licensed under the Apache License, Version 2.0
Icon made from http://www.onlinewebfonts.com/icon aka Icon Fonts is licensed by CC BY 3.0
Version: 1.0.1
Updated 6 years, 7 months ago
Rating: 4.5 2
7 in the last week
  • batterypercent
  • batterytemperature
  • batteryvoltage
  • gpiocurrent
  • gpiovoltage
  • usbpower
  • Pi
