node-red-contrib-pinecone 1.0.7
Pinecone makes it easy to provide long-term memory for high-performance AI applications
npm install node-red-contrib-pinecone
Ubos - End-to-End Software Development Platform
UBOS • Community • Youtube • Discord • GitHub
flow npm
Quick Start
Install with the built in Node-RED Palette manager or using npm:
Properties Index Operations
msg.PINECONE_API_KEY = "Your API key";
msg.PINECONE_ENVIRONMENT = "Your environment";
msg.PINECONE_BASE_URL = "https://controller.[Your environment].pinecone.io";
  1. When msg.actionType is set to list_collections: This operation returns a list of your Pinecone collections
  2. When msg.actionType is set to create_collection:
    • [Required] name: [Type: string] The name of the collection to be created
    • [Required] source: [Type: string] The name of the source index to be used as the source for the collection
  3. When msg.actionType is set to describe_collection:
  4. When msg.actionType is set to delete_collection:
  5. When msg.actionType is set to list_collections: This operation returns a list of your Pinecone indexes
  6. When msg.actionType is set to create_index:
    • [Required] dimension: [Type: integer] The dimensions of the vectors to be inserted in the index
    • metric: [Type: string] The distance metric to be used for similarity search. You can use 'euclidean', 'cosine', or 'dotproduct'
    • pods: [Type: integer] The number of pods for the index to use,including replicas
    • replicas: [Type: integer] The number of replicas. Replicas duplicate your index. They provide higher availability and throughput
    • pod_type: [Type: string] The type of pod to use. One of s1, p1, or p2 appended with . and one of x1, x2, x4, or x8.
    • metadata_config: [Type: object | null] Configuration for the behavior of Pinecone's internal metadata index. By default, all metadata is indexed; when metadata_config is present, only specified metadata fields are indexed. To specify metadata fields to index, provide a JSON object of the following form:
    {"indexed": ["example_metadata_field"]}
    • source_collection: [Type: string] The name of the collection to create an index from
Example:
    msg.payload = {
        metric: "cosine",
        pods: 1,
        replicas: 1,
        pod_type: "p1.x1"
  1. When msg.actionType is set to describe_index:
  2. When msg.actionType is set to delete_index:
  3. When msg.actionType is set to configure_index:
    • replicas: [Type: string] The desired number of replicas for the index
    • pod_type: [Type: string] The new pod type for the index. One of s1, p1, or p2 appended with . and one of x1, x2, x4, or x8.
Properties Vector operations
msg.PINECONE_BASE_URL = "https://index_name-project_id.svc.environment.pinecone.io";
  1. When msg.actionType is set to fetch:
    • [Required] msg.name: The name of the index
    • [Required] msg.vectors: The vector IDs to fetch. Does not accept values containing spaces. For example:
     msg.payload = {
         vectors: ["vec1", "vec2"]
  2. When msg.actionType is set to query:
    • [Required] name: [Type: string] The name of the index
    • [Required] topK: [Type: int64] The number of results to return for each query
    • filter: [Type: object] The filter to apply. You can use vector metadata to limit your search. See docs
    • includeValues: [Type: boolean] Indicates whether vector values are included in the response
    • includeMetadata: [Type: boolean] Indicates whether metadata is included in the response as well as the ids
    • vector: [Type: array of floats] The query vector. This should be the same length as the dimension of the index being queried. Each query() request can contain only one of the parameters id or vector.
    • sparseVector: [Type: object] Vector sparse data. Represented as a list of indices and a list of corresponded values, which must be the same length
    • id: [Type: string] The unique ID of the vector to be used as a query vector. Each query() request can contain only one of the parameters queries, vector, or id
    Example:
     msg.payload = {
         topK: 10,
         vector: [0.1,0.2,0.3],
         namespace: 'example-namespace'
  3. When msg.actionType is set to update:
    • [Required] id: [Type: string] Vector's unique id
    • values: [Type: array of floats] Vector data
    • sparseValues: [Type: object] Vector sparse data. Represented as a list of indices and a list of corresponded values, which must be the same length
    • setMetadata: [Type: object] Metadata to set for the vector
    • namespace: [Type: string] The namespace containing the vector to update
    Example:
     msg.payload = {
         values: [0.1,0.2,0.3,0.4],
         setMetadata: {'genre': 'drama'},
  4. When msg.actionType is set to upsert:
    • [Required] vectors: [Type: array of objects] An array containing the vectors to upsert. Recommended batch limit is 100 vectors
    • namespace: [Type: string] This is the namespace name where you upsert vectors
    Example:
     msg.payload = {
         vectors: [
                 values: [0.2,0.3,0.4,0.5],
                 metadata: {'genre': 'action'}
  5. When msg.delete is set to upsert:
    • [Required] ids: [Type: array of strings] Vectors to delete
    • deleteAll: [Type: boolean] This indicates that all vectors in the index namespace should be deleted
    • namespace: [Type: string] The namespace to delete vectors from, if applicable
    • filter: [Type: boolean] If specified, the metadata filter here will be used to select the vectors to delete. This is mutually exclusive with specifying IDs to delete in the ids param or using delete_all=True. See doc
    Example:
     msg.payload = {
         ids: ["vec1", "vec2"]
  6. When msg.delete is set to describeIndexStats:
    • filter: [Type: boolean] If this parameter is present, the operation only returns statistics for vectors that satisfy the filter. See doc
Bugs reports and feature requests
Please report any issues or feature requests at GitHub.
MIT License
Version: 1.0.7
Updated 3 years, 2 months ago
1 in the last week
  • pinecone
  • nodejs
  • javascript
  • api
  • flow
  • npm
  • machine-learning
  • node
  • example
  • ai
