node-red-contrib-opentok 0.0.2
nodered nodes to wrap opentok
npm install node-red-contrib-opentok
node-red-contrib-opentok (beta)
Support for the OpenTok serverside functionality from within NodeRED
  • Create Sessions
  • Generate Tokens
  • Archiving
  • SIP Interconnect
  • Send Signals
Account Setup
The first time you use a node you will need to create OpenTok authentication parameters. You can get an API key and Secret by creating a new application in the OpenTok dashboard
Getting Started
This repository contains a file named opentok_test.html which can be used as a basic web client for 1-1 video calls with signals. You can save this file to you local filesystem and then serve it from within nodered.
See the demo_flow.json file for an example flow to use with this
Version: 0.0.2
Updated 8 years, 4 months ago
4 in the last week
  • createsession
  • generatetoken
  • startarchive
  • stoparchive
  • getarchive
  • dial
  • signal
  • opentokauth
  • tokbox
  • opentok
  • webrtc
  • video
