node-red-contrib-nostr 0.1.0
Node-RED nodes for seamless Nostr protocol integration. Features robust WebSocket handling, event filtering, and NPUB-based routing. Built with TypeScript for type safety and extensive testing. Perfect for Nostr automation flows.
npm install node-red-contrib-nostr
npm version License: MIT Node-RED Tests JavaScript Style Guide Known Vulnerabilities
A Node-RED node for integrating with the Nostr protocol. This node allows you to connect to Nostr relays, publish events, and subscribe to events in the Nostr network.
⚠️ Security Note
A private key is only required if you want to:
  • Publish events to relays
  • Send encrypted direct messages
  • Perform any action that requires signing
For just listening to relays or subscribing to events, no private key is needed.
If you do need to publish events, follow these security guidelines:
  1. Generate a separate key pair specifically for your Node-RED automation using services like:
  2. Keep the scope of this automation key limited:
    • Only give it permissions it actually needs
    • Consider it like a "bot account"
    • Regularly rotate the key if possible
  3. Store the private key securely:
    • Use Node-RED's encrypted credentials
    • Never share or expose the key
    • Don't commit it to version control
Description
This package provides nodes for interacting with Nostr relays, allowing you to:
  • Connect to multiple relays simultaneously
  • Monitor specific NPUBs for events
  • Filter events by type (text notes, DMs, etc.)
  • Post events to relays (using a dedicated automation key)
  • Support for multiple NIPs (see Supported NIPs section)
  • TypeScript support with full type definitions
  • Secure credential management
  • Automatic reconnection handling
Technical Architecture
Module System
This package uses a hybrid approach to module systems to ensure maximum compatibility:
  • Built as CommonJS for Node-RED compatibility
  • Handles ESM dependencies through dynamic imports
  • Supports both modern and legacy Node.js environments
WebSocket Management
Built on nostr-websocket-utils for enterprise-grade reliability:
  • Automatic Reconnection: Smart backoff strategy for connection drops
  • Connection Health: Built-in heartbeat monitoring
  • Type Safety: Full TypeScript support
  • Error Resilience: Comprehensive error handling
  • Memory Efficient: Proper cleanup of resources
  • Debug Support: Detailed logging
From npm (Recommended)
From Source
git clone https://github.com/HumanjavaEnterprises/node-red-contrib-nostr.git
cd node-red-contrib-nostr
npm install
npm run build
Using Docker
docker compose up -d
1. Nostr Relay Config Node
Configuration node for managing relay connections:
  • Multiple relay support
  • Secure private key storage
  • Connection status monitoring
  • Dynamic import of ESM dependencies
2. Nostr Filter Node
Specialized node for event filtering:
  • Filter by event kinds
  • Filter by authors (NPUBs)
  • Filter by tags
  • Time-based filtering
  • Custom filter combinations
  • Real-time event processing
3. Nostr NPUB Filter Node
Dedicated node for NPUB-based filtering:
  • Filter by event types
  • Real-time NPUB event tracking
  • Automatic hex key conversion
Example Flows
Basic Event Monitoring
    "id": "basic-monitor",
    "type": "nostr-filter",
    "relay": "wss://relay.example.com",
    "filterType": "kind",
    "eventKinds": [1],
    "wires": [["debug"]]
NPUB Tracking
    "id": "npub-track",
    "type": "nostr-npub-filter",
    "npubValue": "npub1...",
    "eventKinds": [1, 6],
Error Handling
The nodes implement comprehensive error handling:
  • Invalid private key detection
  • Relay connection failures
  • Message parsing errors
  • NPUB validation
  • WebSocket connection issues
Development
Building from Source
npm install
npm run build
Running Tests
npm test
Test coverage includes:
  • Unit tests for all nodes
  • WebSocket connection handling
  • Event filtering logic
  • Error handling
Docker Development
docker compose -f docker-compose.dev.yml up
Supported NIPs
NIP Description Status
NIP-01 Basic Protocol ✅ Implemented
NIP-02 Contact List and Petnames ✅ Implemented
NIP-03 OpenTimestamps Attestations 🚧 Planned
NIP-04 Encrypted Direct Messages 🚧 Planned
NIP-09 Event Deletion 🚧 Planned
NIP-11 Relay Information Document ✅ Implemented
NIP-15 End of Stored Events Notice ✅ Implemented
NIP-20 Command Results ✅ Implemented
NIP-28 Public Chat 🚧 Planned
NIP-40 Expiration Timestamp 🚧 Planned
Legend:
  • ✅ Implemented: Fully supported
  • 🚧 Planned: On the roadmap
  • ❌ Not Planned: Not currently planned for implementation
Contributing
  1. Fork the repository
  2. Create your feature branch (git checkout -b feature/amazing-feature)
  3. Commit your changes (git commit -m 'feat: add amazing feature')
  4. Push to the branch (git push origin feature/amazing-feature)
  5. Open a Pull Request
Node-RED Specific Tags
This module provides nodes for working with Nostr protocol in Node-RED.
Node Properties
  • Category: network
  • Name: node-red-contrib-nostr
  • Types: nostr-relay-config, nostr-filter, nostr-npub-filter
  • Description: Node-RED nodes for interacting with Nostr protocol
  • Author: Vveerrgg
  • Keywords: node-red,nostr,websocket,relay,filter,npub
  • Dependencies: @humanjavaenterprises/nostr-tools,nostr-websocket-utils
  • Node-RED: >= 2.0.0
Version: 0.1.0
Updated 2 years ago
3 in the last week
  • nostr-relay-config
  • nostr-filter
  • nostr-npub-filter
  • nostr
  • websocket
  • relay
  • filter
  • npub
  • network
  • protocol
