node-red-contrib-nodegen 0.0.6
make function node for node-red
npm install node-red-contrib-nodegen
nodegen NodeRED Node
Installing with npm
Adding nodes to the palette
Using the Editor You can install nodes directly within the editor by selecting the Manage Palette option from the main menu to open the Palette Manager.
The ‘Nodes’ tab lists all of the modules you have installed. It shows which you are using and whether updates are available for any of them.
The ‘Install’ tab lets you search the catalogue of available node modules and install them.
  • inspired by nodegen
  • make function node for node-red
Example
https://flows.nodered.org/add/node
Parameters
  • prefix : Prefix of npm module (default: "node-red-contrib-")
  • fname : Node name (default: name defined in source)
  • module : Module name (default: "node-red-contrib-")
  • version : Node version (format: "number.number.number" like "4.5.1")
  • keywords : Additional keywords (format: comma separated string, default: "node-red-nodegen")
  • category : Node category (default: "function")
  • icon : PNG file for node appearance (image size should be 10x20)
  • color : Color for node appearance (format: color hexadecimal numbers like "A6BBCF")
  • dst : Destination folder to be created (default: node-red execution location)
  • template : Template folder location required to create (default: /home/server/.node-red/node_modules/node-red-contrib-nodegen/templates/function
  • lang : Language negotiation information when retrieve a Thing Description
  • content : function contents
msg = {};
msg.prefix = 'node-red-contrib-';
msg.fname = 'lower-case';
msg.module = '';
msg.version = '1.0.0';
msg.keywords = 'lower-case';
msg.category = '';
msg.icon = '';
msg.color = '';
// if OS is linux, MAC
msg.dst = '$HOME/.node-red/node_modules/';
// if OS is Window
msg.dst = 'C:/Users/gagag/.node-red/node_modules/';
msg.lang = '';
msg.content = '// name: lower-case\n';
msg.content += '// outputs: 1\n';
msg.content += 'msg.payload = msg.payload.toLowerCase();\n';
msg.content += 'return msg;\n';
Results
Success: node-red-contrib-test-module
Sample Flow
    "id": "6d3e3068.04443",
    "type": "inject",
    "z": "c49414ec.9c4508",
    "props": [
        "p": "payload"
        "p": "topic",
        "vt": "str"
    "repeat": "",
    "crontab": "",
    "once": false,
    "onceDelay": 0.1,
    "topic": "",
    "payload": "",
    "payloadType": "date",
    "x": 130,
    "y": 60,
        "fa546363.caa9f"
    "id": "fa546363.caa9f",
    "type": "function",
    "func": "msg = {};\nmsg.prefix = 'node-red-contrib-';\nmsg.fname = 'lower-case';\nmsg.module = '';\nmsg.version = '1.0.0';\nmsg.keywords = 'lower-case';\nmsg.category = '';\nmsg.icon = '';\nmsg.color = '';\n// if OS is linux, MAC\nmsg.dst = '/home/server/.node-red/node_modules/';\n// if OS is Window\n// msg.dst = 'C:/Users/user/.node-red/node_modules/';\nmsg.lang = '';\nmsg.content = '// name: lower-case\\n';\nmsg.content += '// outputs: 1\\n';\nmsg.content += 'msg.payload = msg.payload.toLowerCase();\\n';\nmsg.content += 'return msg;\\n';\n\nreturn msg;",
    "outputs": 1,
    "noerr": 0,
    "initialize": "",
    "finalize": "",
    "x": 310,
    "y": 60,
        "268809eb.cbceb6"
    "id": "fa48932.8d7ee7",
    "type": "debug",
    "active": true,
    "tosidebar": true,
    "console": false,
    "tostatus": false,
    "complete": "true",
    "targetType": "full",
    "statusVal": "",
    "statusType": "auto",
    "x": 640,
    "y": 60,
    "id": "268809eb.cbceb6",
    "type": "nodegen",
    "prefix": "",
    "fname": "",
    "module": "",
    "version": "",
    "keywords": "",
    "category": "",
    "icon": "",
    "color": "",
    "dst": "",
    "lang": "",
    "name": "nodegen",
    "x": 490,
    "y": 60,
        "fa48932.8d7ee7"
Version: 0.0.6
Updated 6 years, 2 months ago
9 in the last week
  • nodegen
  • gen
  • fuctionnodegen
  • fuctiongen
  • nodegen
