node-red-contrib-nixtla 1.0.2
Nodes for connecting to the Nixtla APIs.
npm install node-red-contrib-nixtla
Node-RED integration for nixtla
References
Project Links
Install via npm
npm install node-red-contrib-nixtla@latest
  • Follow the steps mentioned here or click here to get your token.
  • Drag and drop a nixtla node into node-Red Flow editor pane.
  • Create a new nixtla configuration and paste the token.
Override values from previous node
The input values for the nixtla node can be overriden by passing respective properties from the previous node.
The topic for the nixtla node can be set as follows msg.topic
msg.topic = 'automl_forecast';
The payload for the nixtla node can be set as follows msg.payload
msg = {}
payload = {};
payload.forecast_horizon = 1;
payload.timestamp = ["2022-05-10", "2022-05-11", "2022-05-12"];
payload.value = [0.5, 0.3, 0.1];
msg.payload = payload;
Supported Topics:
"automl_forecast"
"automl_anomaly"
"forecast"
"neural_transfer"
"anomaly_detector"
Accepted properties in the payload for different topics:
"automl_forecast":
    "forecast_horizon" (int): Steps ahead you want to predict.
    "timestamp" (list): Each element of the list defines the timestamp of the time series.
    "value" (list): Time series values.
"automl_anomaly":
    "sensibility" (int): Confidence level for prediction intervals.
"forecast":
    "model" (str): Model name.
    "seasonality" (int): Seasonality
    "cv" (boolean): Whether to perform cross validation.
"neural_transfer":
    "max_steps" (int): K-shot learning steps.
"anomaly_detector":
    "seasonality" (int): Seasonality.
model
Statistical:
    "arima" | "seasonal_exponential_smoothing" | "prophet" | "complex_es" | "ets"
Transfer Learning:
    "nhits_m4_hourly" | "nhits_m4_hourly_tiny" | "nhits_m4_daily" | "nhits_m4_monthly" | "nhits_m4_yearly" | "nbeats_m4_hourly" | "nbeats_m4_daily" | "nbeats_m4_monthly" | "nbeats_m4_yearly"
Release
To release a new version of the package
  • commit the changes
  • create a tag with semantic version
  • push the changes and tag
git tag -a v1.0.1 -m "release v1.0.1"
git push --follow-tags
Version: 1.0.2
Updated 4 years, 1 month ago
Rating: 5.0 2
2 in the last week
  • nixtla
  • nixtla-config
  • nixtla
  • ml
  • timeseries
